Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu_data_unregister_submit() and MPI
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Benoît Lizé <benoit.lize@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] starpu_data_unregister_submit() and MPI
  • Date: Wed, 12 Mar 2014 10:21:19 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Benoît Lizé, le Wed 12 Mar 2014 10:03:38 +0100, a écrit :
> Is there any known issue between the MPI layer in StarPU and
> starpu_data_unregister_submit() ?
Not that I know of.
> I am having trouble using it in my HMatrix code with r12389 (trunk). In this
> code, I submit all the tasks whils StarPU is "paused" (using starpu_pause()
> before starting to submit any task), and starpu_data_unregister_submit()
> hangs
> here:
Could you also provide the backtraces of other threads?
> I'm calling starpu_data_unregister_submit() on all the nodes, even the ones
> that don't own the handle. Maybe this is not the way it should be done, but
> I
> couldn't find any reference to it in the documentation.
Well, be it sent over MPI or not, the rule doesn't change: a registered
data has to be unregistered.
Samuel
Haut de le page
