Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Starpu-1.1.0 Configure --enable-blas-lib=goto
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Hush Zhou <hush.zhou@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Starpu-1.1.0 Configure --enable-blas-lib=goto
  • Date: Fri, 11 Apr 2014 11:29:20 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
configure tries to detect the goto library in the standard directories, with
configure:27638: checking for sgemm_ in -lgoto2
configure:27663: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lgoto2 >&5
/usr/bin/ld: cannot find -lgoto2
If the goto library is installed in a non standard directory, you should specify it with the option --with-goto-dir=directory when calling configure
Regards,
Nathalie
On 10/04/2014 17:46, Hush Zhou wrote:
Attached please find the config.log
Thanks.
On Thu, Apr 10, 2014 at 9:52 AM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
Hi,
Could you post the file config.log?
Regards,
Nathalie
On Apr 10, 09:41, Hush Zhou wrote:
Hi,
I'm trying to configure starpu-1.1 with --enable-blas-lib=goto or
--enable-blas-lib=atlas, but I get such error:
checking for main in -lgfortran... no
checking for main in -lifcore... no
checking for sgemm_ in -lgoto2... no
checking for sgemm_ in -lgoto... no
configure: error: cannot find goto lib
I'm sure I have installed libopenblas-dev, do you have some suggestions?
Thanks.
Best,
Husheng
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
