Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] STARPU_ENABLE_CUDA_GPU_GPU_DIRECT doesn't work
- Date: Tue, 15 Apr 2014 08:24:19 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
I'm trying to run the cholesky_implicit example with
STARPU_NCPU=2 STARPU_NCUDA=2 STARPU_ENABLE_CUDA_GPU_GPU_DIRECT=1
./cholesky_implicit
My machine is configured with:
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
GeForce GT 620
GeForce GTX 660
And the starpu was configured with:
--enable-verbose --enable-stats --enable-perf-debug --enabl
e-model-debug --enable-memory-stats --enable-sc-hypervisor
the STARPU_ENABLE_CUDA_GPU_GPU_DIRECT was enabled by default.
But the data transfer stats shows as following:
Data transfer stats:
TOTAL transfers 221.000000 MB
1 <-> 0 98.250000 MB
1 -> 0 46.000000 MB
0 -> 1 52.250000 MB
2 <-> 0 12.250000 MB
2 -> 0 3.750000 MB
0 -> 2 8.500000 MB
It seems that data didn't transfer directly from GPU to GPU. Is it
normal? How could I solve this problem?
Best,
Husheng
- [Starpu-devel] STARPU_ENABLE_CUDA_GPU_GPU_DIRECT doesn't work, Hush Zhou, 15/04/2014
- Re: [Starpu-devel] STARPU_ENABLE_CUDA_GPU_GPU_DIRECT doesn't work, Samuel Thibault, 15/04/2014
- Re: [Starpu-devel] STARPU_ENABLE_CUDA_GPU_GPU_DIRECT doesn't work, Samuel Thibault, 17/04/2014
