Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Task status invalid
Archives de la liste
Chronologique Discussions
  • From: mansouri farouk <farouk.mansouri@gipsa-lab.grenoble-inp.fr>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, mansouri farouk <farouk.mansouri@gipsa-lab.grenoble-inp.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Task status invalid
  • Date: Thu, 12 Jun 2014 17:19:54 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel, thanks for your response. So, i m sorry for the mistake. The aim is to reuse buffers (not handles). If i understood your answer, the buffer must be unregistered from "old handle" before it being registered again to the "new handle" ?
Farouk
Le 12-06-2014 13:55, Samuel Thibault a écrit :
Hello,
mansouri farouk, le Wed 28 May 2014 11:50:39 +0200, a écrit :
I use Starpu API to process iterative applications in DSP domain. So, in
order to re-use the handles (buffers) obtained by "starpu_malloc",
I'm not sure to understand: starpu_malloc returns a buffer, not a
handle.
I check writers and readers task's status from that handle ( If task
has a Terminated status ....affect the handle to another new task ).
Either you want to reuse the handle, and for this you just need to make
the new task write to the handle (STARPU_W), and this new task will be
made to wait for all previous tasks before being able to start.
Or you want to reuse the buffer, i.e. you want to unregister a handle,
and register the buffer again and get a new handle. The issue is that
data registration is synchronous, so you would have to make your main
thread wait for the the tasks, by using starpu_data_unregister for
instance.
So my questions are: - Is it possible (practicable) to do that ? (Affect a
handles to a new task if the oldest had terminated)
The mere data dependencies of StarPU should be all fine for this.
- What STARPU_TASK_INVALID status of task means after
it has been executed ?
I don't understand: the status of a task does not become
STARPU_TASK_INVALID at task termination. That being said, if you have
left task->destroy to 1, then on task termination the task structure is
freed, and thus reused for other purpose, which probably has zeroed the
memory area.
Samuel
Haut de le page
