Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] MPI scaling
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] MPI scaling
  • Date: Tue, 24 Jun 2014 15:29:10 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 24 juin 2014 à 14:17, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Hello,
> Xavier Lacoste, le Mon 23 Jun 2014 09:19:19 +0200, a écrit :
>> I'm using eager scheduler has I have no GPUs
> Maybe you'd want to give a try to the lws scheduler.
Ok I'll have a try.
I don't see it in starpu 1.1.2, is it new in 1.2 ? Is it different from ws ?
The variable STARPU_SCHED can be set to one of the following strings:
eager -> eager policy with a central queue
prio -> eager (with priorities)
random -> weighted random based on worker overall performance
ws -> work stealing
dm -> performance model
dmda -> data-aware performance model
dmdar -> data-aware performance model (ready)
dmdas -> data-aware performance model (sorted)
pheft -> parallel HEFT
>> I attach the 4x8 execution trace. I would like to know is their is a mean
>> to see if a communication is triggered as soon as the last local update as
>> been performed.
> We can see big idle areas indeed. Is "local update" a particular kind
> of task? You could make vite show it in a different color and thus see
> where it is. Perhaps the problem here is rather that these tasks are
> scheduled late, and giving them a priority and using the prio scheduler
> would help.
This local update task is the same task as the update to local GEMMs (except
the written data is temporary buffer and will have to be send over MPI). I
could rename them to have a different color.
I already tried using eager and giving non zero priority to these update
tasks (as I saw in online documentation that the non zero priority tasks are
put in front of the queue). Is this different from prio scheduler behaviour ?
>> Have you got any advice to try to improve MPI scaling.
> Well, it's the matter of Marc's thesis :)
> Here it seems to me rather a problem of task order.
>> In my case here, using the whole 8 cores of a node is worse than using 7
>> threads per node... Have you already experience that ?
> That may not be surprising indeed, since this lets the MPI thread have
> its own core.
> Samuel
Attachment: signature.asc
Description: Message signed with OpenPGP using GPGMail
Haut de le page
