Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: "Vergel, Julio" <Julio.Vergel@aeroflex.com>
- Cc: "jvergel@hotmail.com" <jvergel@hotmail.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU questions
- Date: Mon, 1 Sep 2014 17:28:23 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Vergel, Julio, le Fri 29 Aug 2014 18:38:10 +0000, a écrit :
> a) taskGain[0]
> b) taskAddConstant which has to wait for taskGain[0] completion
> c) taskGain[1] which has to wait for taskAddConstant completion
> d) taskGain[2] which has to wait for taskAddConstant completion
> everything works OK. However if I change the order of submitting the tasks
> starpu_task_submit( taskGain[2] );
> starpu_task_submit( taskGain[0] );
> starpu_task_submit( taskAddConstant );
> starpu_task_submit( taskGain[1] );
> the program hangs when i run it.
Remember that StarPU implements implicit dependencies generation from
sequential consistency, which add up to the dependencies that you create
by hand, and thus it will here add a dependency between taskGain[2] and
taskAddConstant, since taskGain[2] writes to vectorAddConstantHandle,
and taskAddConstant reads from it. To disable implicit dependencies,
use starpu_data_set_sequential_consistency_flag, or even
starpu_data_set_default_sequential_consistency_flag.
> 2) My second question is that I noticed that if I increase the value of NX
> (line 17) to a couple of millions, the program crashes immediately.
That's not really surprising:
> int main(int argc, char **argv)
> /* We consider a vector of float that is initialized just as any of C
> * data */
> float vector[NX];
Theses local arrays are allocated on the stack, which is usually limited
to only a few MiB in most systems. Increase the stack size with ulimit
-s, or make it a global variable, or allocate it dynamically from the
heap.
Samuel
- Re: [Starpu-devel] StarPU questions, Samuel Thibault, 01/09/2014
- Message indisponible
- Re: [Starpu-devel] StarPU questions, Samuel Thibault, 02/09/2014
- <Suite(s) possible(s)>
- [Starpu-devel] StarPU questions, David Pereira, 26/09/2014
- Re: [Starpu-devel] StarPU questions, Samuel Thibault, 30/09/2014
