Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error in .starpu/sampling
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Xavier Lacoste <xl64100@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error in .starpu/sampling
  • Date: Tue, 30 Sep 2014 14:49:29 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Xavier,
I do not think the error is directly related to StarPU. It seems for whatever reason, you do not have the right to write in your home directory.
Try to call by hand
mkdir -p /ccc/cont003/home/gen1567/lacoste/.starpu/sampling/
If that does not work, you should contact the CCRT system team. In the meantime, you can set the environment variable STARPU_HOME to another directory (for which you have the write permission).
Cheers,
Nathalie
On 30/09/2014 14:43, Xavier Lacoste wrote:
Hello,
On curie from CCRT I get the following error when trying to run on the hybrid partition:
Error making StarPU directory /ccc/cont003/home/gen1567/lacoste/.starpu/sampling/:
mkdir: Read-only file system
Do you have already experience such an error ?
Any idea what to do to avoid this ?
Regards,
XL
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
