Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Martin Jurík <martin.jurik.91@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu installation issues
- Date: Tue, 18 Nov 2014 08:59:58 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Martin,
It looks like there is a problem with your OpenCL installation. You should first make sure OpenCL is properly installed on your machine. You can also disable StarPU to start OpenCL workers. Either by giving the option --disable-opencl when calling configure or by setting the environment variable STARPU_OPENCL to 0. Cheers, Nathalie On 17/11/2014 17:44, Martin Jurík wrote: Hello, I am student at Slovak University of Technology in
Bratislava. I am trying to use StarPU libraries in my
Bachelor thesis but I figured out some problems with
installing. I am using ubuntu 14.04 LTS 32-bit and I ran
commands for installation as was written in documentation.
Firstly ./configure, secondly make and finally sudo make
install. Installation succeeded but when I run make check or
one of examples it fails. Make check wrote in
tools/test-suite.log following:
Could you help me please with these problems? Are there some
important parts of system which have to be installed before
StarPU installation? I have tried to change eager scheduler to
dmda but it did not help.======================================== StarPU 1.2.0: tools/test-suite.log ======================================== # TOTAL: 3 # PASS: 2 # SKIP: 0 # XFAIL: 0 # FAIL: 1 # XPASS: 0 # ERROR: 0 .. contents:: :depth: 2 FAIL: starpu_machine_display ============================ [starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding performance models in order to be able to use the dmda scheduler instead. lt-starpu_machine_display: ../include/starpu_opencl.h:43: starpu_opencl_report_error: Assertion `0' failed. oops in _starpu_opencl_limit_gpu_mem_if_needed (drivers/opencl/driver_opencl.c:87) ((null)) ... <Invalid value> (-30) [error] `./starpu_machine_display' killed with signal 6; test marked as failed while looking for core file of ./starpu_machine_display: core: No such file or directory #Execution_time_in_seconds 0.464905 ./starpu_machine_display Thank you,
With the best regards, Martin Jurik._______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] starpu installation issues, Martin Jurík, 17/11/2014
- Re: [Starpu-devel] starpu installation issues, Nathalie Furmento, 18/11/2014
