Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Unexpected behavior - Not making task ready when they could be
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Unexpected behavior - Not making task ready when they could be
  • Date: Fri, 13 Feb 2015 11:51:43 +0100 (CET)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I am using starpu in a project that requires the STARPU_COMMUTE.
And so I am working with the svn trunk (taken the 12/02/2015).
However it seems that starpu is not turning tasks to ready even if there is no reason not to do it.
I attach to this email a small example that illustrate this behavior, it is a simple C++ file that use STARPU_COMMUTE (testCommute.cpp)
(and also a home made version of the STARPU_COMMUTE with sequential consistency turned to false for some handles testFakeCommute.cpp).
In the test I am submitting lots of tasks that use two handles in STARPU_RW|STARPU_COMMUTE.
The degree of parallelism is huge (as it is shown in the dag, dag.dog & dag.pdf) but StarPU has to finish a task to insert a new one as the trace is showing (paje.trace).
I suppose that it is just a matter of: when starpu finish a task with a COMMUTE what dependencies it will release.
Please see:
https://zimbra.inria.fr/home/berenger.bramas@inria.fr/Briefcase/Public/StarPU
The algorithm of task insertion I am using in the test is:
for i from 0 to nbA
    insert task handles[i] mode STARPU_RW|STARPU_COMMUTE
    for j from 0 to nbA
        if i != j
              insert task handles[i] mode STARPU_RW|STARPU_COMMUTE, and handles[j] mode STARPU_RW|STARPU_COMMUTE
Do you think you may change this behavior and move a task that can be computed into the ready tasks?
I am also available to discuss that in person :)
Thanks.
Bérenger Bramas
HiePACS Project
Tel (05 24 57) 40 76
INRIA BORDEAUX Sud Ouest
Haut de le page
