Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] mpi_isend_detached / mpi_irecv_detached with starpu-trunk with tag
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Jean-Marie Couteyen <jean-marie.couteyen@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] mpi_isend_detached / mpi_irecv_detached with starpu-trunk with tag
  • Date: Thu, 26 Feb 2015 10:36:32 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 26/02/2015 10:08, Jean-Marie Couteyen wrote:
Hello,
it seems that tag are no longer taken into account for communication when calling "starpu_mpi_isend_detached" / "starpu_mpi_irecv_detached" with the trunk version.
A magical value (_STARPU_MPI_TAG_DATA) replace the tag given when StarPU calls Isend (_starpu_mpi_isend_data_func:327)
I do rely on tags to make my communications on my application (multiple isend_detached/irecv_detached identified by tags) and I can't see a way to do them without it.
Is there a good reason to override the given tag ?
Regards,
Jean-Marie Couteyen
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
The communication engine in the trunk has been completely rewritten compared to the 1.1 version. We found out that implementations of MPI were not efficient when using too many different tags.
Thus the new engine sends all data using the same tag. However the tags given by the application should be matched properly. It might not be tested though by our testcases. I will have a look.
How long have you been using the trunk? I recently modified the engine to properly implement synchronous communications, it may have broken the tag matching system.
Cheers,
Nathalie
Haut de le page
