Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU 1.2.0rc2, FAIL: datawizard/manual_reduction
Archives de la liste
Chronologique Discussions
  • To: <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] StarPU 1.2.0rc2, FAIL: datawizard/manual_reduction
  • Date: Mon, 11 May 2015 11:29:20 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear StarPU developers,
Just installed a new StarPU and got test error. But looking at the error
log it seems normal. Could you kindly gain me more insight? Thanks!
Kind regards,
Guowei HE
IBG-3: Agrosphere
Forschungszentrum Jülich
Phone: +49 2461 61-8832
email: g.he@fz-juelich.de
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
   StarPU 1.2.0rc2: tests/test-suite.log
# TOTAL: 178
# PASS:  136
# SKIP:  40
# XFAIL: 1
# FAIL:  1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
SKIP: main/starpu_init
Testing with env=-1 - conf=-1
[starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding performance models in order to be able to use the dmda or dmdas scheduler instead.
Number of CPUS:   1
#Execution_time_in_seconds 0.119259 ./main/starpu_init
5041 = 42 + 4999
10041 = 5041 + 5000
#Execution_time_in_seconds 0.233139 ./datawizard/manual_reduction
`./datawizard/manual_reduction' exited with return code 1
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
#Execution_time_in_seconds 0.111760 ./datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_data_release
#Execution_time_in_seconds 0.123353 ./datawizard/interfaces/multiformat/advanced/multiformat_data_release
SKIP: datawizard/gpu_register
#Execution_time_in_seconds 0.105065 ./datawizard/gpu_register
SKIP: datawizard/gpu_ptr_register
#Execution_time_in_seconds 0.111164 ./datawizard/gpu_ptr_register
SKIP: datawizard/readonly
copy 0
submission of task 0x10283d0 wih codelet 0x6020a0 failed (symbol `none') (err: ENODEV)
WARNING: No one can execute this task
#Execution_time_in_seconds 0.123073 ./datawizard/readonly
XFAIL: errorcheck/invalid_blocking_calls
[starpu][starpu_data_acquire_on_node][assert failure] Acquiring a data synchronously is not possible from a codelet or from a task callback, use starpu_data_acquire_cb instead.
lt-invalid_blocking_calls: datawizard/user_interactions.c:239: starpu_data_acquire_on_node: Assertion `_starpu_worker_may_perform_blocking_calls()' failed.
[error] `./errorcheck/invalid_blocking_calls' killed with signal 6; test marked as failed
while looking for core file of ./errorcheck/invalid_blocking_calls: core: No such file or directory
#Execution_time_in_seconds 0.352678 ./errorcheck/invalid_blocking_calls
SKIP: openmp/init_exit_01
#Execution_time_in_seconds 0.057531 ./openmp/init_exit_01
SKIP: openmp/init_exit_02
#Execution_time_in_seconds 0.045760 ./openmp/init_exit_02
SKIP: openmp/environment
#Execution_time_in_seconds 0.045375 ./openmp/environment
SKIP: openmp/api_01
#Execution_time_in_seconds 0.043518 ./openmp/api_01
SKIP: openmp/parallel_01
#Execution_time_in_seconds 0.048156 ./openmp/parallel_01
SKIP: openmp/parallel_02
#Execution_time_in_seconds 0.048868 ./openmp/parallel_02
SKIP: openmp/parallel_03
#Execution_time_in_seconds 0.050040 ./openmp/parallel_03
SKIP: openmp/parallel_barrier_01
#Execution_time_in_seconds 0.036483 ./openmp/parallel_barrier_01
SKIP: openmp/parallel_master_01
#Execution_time_in_seconds 0.035507 ./openmp/parallel_master_01
SKIP: openmp/parallel_master_inline_01
#Execution_time_in_seconds 0.035630 ./openmp/parallel_master_inline_01
SKIP: openmp/parallel_single_wait_01
#Execution_time_in_seconds 0.035341 ./openmp/parallel_single_wait_01
SKIP: openmp/parallel_single_nowait_01
#Execution_time_in_seconds 0.035618 ./openmp/parallel_single_nowait_01
SKIP: openmp/parallel_single_inline_01
#Execution_time_in_seconds 0.034975 ./openmp/parallel_single_inline_01
SKIP: openmp/parallel_single_copyprivate_01
#Execution_time_in_seconds 0.035131 ./openmp/parallel_single_copyprivate_01
SKIP: openmp/parallel_single_copyprivate_inline_01
#Execution_time_in_seconds 0.035668 ./openmp/parallel_single_copyprivate_inline_01
SKIP: openmp/parallel_critical_01
#Execution_time_in_seconds 0.035382 ./openmp/parallel_critical_01
SKIP: openmp/parallel_critical_inline_01
#Execution_time_in_seconds 0.035764 ./openmp/parallel_critical_inline_01
SKIP: openmp/parallel_critical_named_01
#Execution_time_in_seconds 0.035636 ./openmp/parallel_critical_named_01
SKIP: openmp/parallel_critical_named_inline_01
#Execution_time_in_seconds 0.046206 ./openmp/parallel_critical_named_inline_01
SKIP: openmp/parallel_simple_lock_01
#Execution_time_in_seconds 0.056543 ./openmp/parallel_simple_lock_01
SKIP: openmp/parallel_nested_lock_01
#Execution_time_in_seconds 0.056992 ./openmp/parallel_nested_lock_01
SKIP: openmp/parallel_for_01
#Execution_time_in_seconds 0.055715 ./openmp/parallel_for_01
SKIP: openmp/parallel_for_02
#Execution_time_in_seconds 0.047313 ./openmp/parallel_for_02
SKIP: openmp/parallel_for_ordered_01
#Execution_time_in_seconds 0.036418 ./openmp/parallel_for_ordered_01
SKIP: openmp/parallel_sections_01
#Execution_time_in_seconds 0.035471 ./openmp/parallel_sections_01
SKIP: openmp/parallel_sections_combined_01
#Execution_time_in_seconds 0.044922 ./openmp/parallel_sections_combined_01
SKIP: openmp/task_01
#Execution_time_in_seconds 0.040446 ./openmp/task_01
SKIP: openmp/task_02
#Execution_time_in_seconds 0.043067 ./openmp/task_02
SKIP: openmp/taskwait_01
#Execution_time_in_seconds 0.053124 ./openmp/taskwait_01
SKIP: openmp/taskgroup_01
#Execution_time_in_seconds 0.045002 ./openmp/taskgroup_01
SKIP: openmp/taskgroup_02
#Execution_time_in_seconds 0.045065 ./openmp/taskgroup_02
SKIP: openmp/array_slice_01
#Execution_time_in_seconds 0.050750 ./openmp/array_slice_01
SKIP: openmp/cuda_task_01
#Execution_time_in_seconds 0.051132 ./openmp/cuda_task_01
SKIP: perfmodels/feed
#Execution_time_in_seconds 0.115788 ./perfmodels/feed
Haut de le page
