Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] segfault MPI execution and starpu_fxt_tool
- Date: Fri, 26 Jun 2015 16:43:10 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
This is a multi-part message in MIME format. Hi,
I've got a segfault with the starpu_fxt_tool program for prof_files generated with a starpu+mpi program:
I work on an experimental platform from Inria Bordeaux, PlaFRIM2, see attached file for the node characteristics
I use starpu branch 1.1 at rev 15648, linked with fxt-0.3.1 and openmpi-1.8.4 all compiled with gcc-4.8.4, see config.log.
I have four nodes, my execution is the following (a starpu mpi example):
$ mpirun -pernode ./mpi/examples/stencil/stencil5
Then I want to use starpu_fxt_tool to generate the paje trace file and I get the segfault
$ gdb --args ~/work/install/starpu-1.1/mpi-fxt-debug/gcc-4.8.4/bin/starpu_fxt_tool -i ~/prof_file_pruvost_*
(gdb) r
Starting program: /home/pruvost/work/install/starpu-1.1/mpi-fxt-debug/gcc-4.8.4/bin/starpu_fxt_tool -i /home/pruvost/prof_file_pruvost_0 /home/pruvost/prof_file_pruvost_1 /home/pruvost/prof_file_pruvost_2 /home/pruvost/prof_file_pruvost_3
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff63c4a94 in vfprintf () from /lib64/libc.so.6
Missing separate debuginfos, use: debuginfo-install glibc-2.17-78.el7.x86_64 libxml2-2.9.1-5.el7_1.2.x86_64 xz-libs-5.1.2-9alpha.el7.x86_64 zlib-1.2.7-13.el7.x86_64
(gdb) bt
#0 0x00007ffff63c4a94 in vfprintf () from /lib64/libc.so.6
#1 0x00007ffff63cdb77 in fprintf () from /lib64/libc.so.6
#2 0x00007ffff7b7ece6 in _starpu_fxt_dag_set_task_done (job_id=<optimized out>, label=<optimized out>, color=<optimized out>) at ../../src/debug/traces/starpu_fxt_dag.c:97
#3 0x00007ffff7b7cf70 in handle_task_done (options=0x6020a0 <options>, ev=0x7fffffffc6d0) at ../../src/debug/traces/starpu_fxt.c:1058
#4 starpu_fxt_parse_new_file (filename_in=<optimized out>, options=options@entry=0x6020a0 <options>) at ../../src/debug/traces/starpu_fxt.c:1531
#5 0x00007ffff7b7e3a7 in starpu_fxt_generate_trace (options=options@entry=0x6020a0 <options>) at ../../src/debug/traces/starpu_fxt.c:2009
#6 0x0000000000400bea in main (argc=6, argv=0x7fffffffca88) at ../../tools/starpu_fxt_tool.c:121
I have the same problem with the 1.2 branch.
Any idea? Thanks for your help.
Florent
miriel.info
Description: application/info
Package L#0
NUMANode L#0 (P#0 32GB)
L3 L#0 (15MB)
L2 L#0 (256KB) + L1d L#0 (32KB) + L1i L#0 (32KB) + Core L#0 + PU L#0
(P#0)
L2 L#1 (256KB) + L1d L#1 (32KB) + L1i L#1 (32KB) + Core L#1 + PU L#1
(P#2)
L2 L#2 (256KB) + L1d L#2 (32KB) + L1i L#2 (32KB) + Core L#2 + PU L#2
(P#4)
L2 L#3 (256KB) + L1d L#3 (32KB) + L1i L#3 (32KB) + Core L#3 + PU L#3
(P#6)
L2 L#4 (256KB) + L1d L#4 (32KB) + L1i L#4 (32KB) + Core L#4 + PU L#4
(P#8)
L2 L#5 (256KB) + L1d L#5 (32KB) + L1i L#5 (32KB) + Core L#5 + PU L#5
(P#10)
HostBridge L#0
PCIBridge
PCI 1077:7322
Net L#0 "ib0"
OpenFabrics L#1 "qib0"
PCIBridge
PCI 8086:10fb
Net L#2 "em1"
PCI 8086:10fb
Net L#3 "em2"
PCI 8086:8d62
Block(Disk) L#4 "sda"
PCIBridge
PCI 8086:1521
Net L#5 "em3"
PCI 8086:1521
Net L#6 "em4"
PCIBridge
PCIBridge
PCIBridge
PCIBridge
PCI 102b:0534
GPU L#7 "card0"
GPU L#8 "controlD64"
PCI 8086:8d02
NUMANode L#1 (P#2 32GB) + L3 L#1 (15MB)
L2 L#6 (256KB) + L1d L#6 (32KB) + L1i L#6 (32KB) + Core L#6 + PU L#6
(P#12)
L2 L#7 (256KB) + L1d L#7 (32KB) + L1i L#7 (32KB) + Core L#7 + PU L#7
(P#14)
L2 L#8 (256KB) + L1d L#8 (32KB) + L1i L#8 (32KB) + Core L#8 + PU L#8
(P#16)
L2 L#9 (256KB) + L1d L#9 (32KB) + L1i L#9 (32KB) + Core L#9 + PU L#9
(P#18)
L2 L#10 (256KB) + L1d L#10 (32KB) + L1i L#10 (32KB) + Core L#10 + PU
L#10 (P#20)
L2 L#11 (256KB) + L1d L#11 (32KB) + L1i L#11 (32KB) + Core L#11 + PU
L#11 (P#22)
Package L#1
NUMANode L#2 (P#1 32GB) + L3 L#2 (15MB)
L2 L#12 (256KB) + L1d L#12 (32KB) + L1i L#12 (32KB) + Core L#12 + PU
L#12 (P#1)
L2 L#13 (256KB) + L1d L#13 (32KB) + L1i L#13 (32KB) + Core L#13 + PU
L#13 (P#3)
L2 L#14 (256KB) + L1d L#14 (32KB) + L1i L#14 (32KB) + Core L#14 + PU
L#14 (P#5)
L2 L#15 (256KB) + L1d L#15 (32KB) + L1i L#15 (32KB) + Core L#15 + PU
L#15 (P#7)
L2 L#16 (256KB) + L1d L#16 (32KB) + L1i L#16 (32KB) + Core L#16 + PU
L#16 (P#9)
L2 L#17 (256KB) + L1d L#17 (32KB) + L1i L#17 (32KB) + Core L#17 + PU
L#17 (P#11)
NUMANode L#3 (P#3 32GB) + L3 L#3 (15MB)
L2 L#18 (256KB) + L1d L#18 (32KB) + L1i L#18 (32KB) + Core L#18 + PU
L#18 (P#13)
L2 L#19 (256KB) + L1d L#19 (32KB) + L1i L#19 (32KB) + Core L#19 + PU
L#19 (P#15)
L2 L#20 (256KB) + L1d L#20 (32KB) + L1i L#20 (32KB) + Core L#20 + PU
L#20 (P#17)
L2 L#21 (256KB) + L1d L#21 (32KB) + L1i L#21 (32KB) + Core L#21 + PU
L#21 (P#19)
L2 L#22 (256KB) + L1d L#22 (32KB) + L1i L#22 (32KB) + Core L#22 + PU
L#22 (P#21)
L2 L#23 (256KB) + L1d L#23 (32KB) + L1i L#23 (32KB) + Core L#23 + PU
L#23 (P#23)
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.1.5, which was generated by GNU Autoconf 2.69. Invocation command line was $ ../configure --with-fxt --prefix=/home/pruvost/work/install/starpu-1.1/mpi-fxt-debug/gcc-4.8.4 ## --------- ## ## Platform. ## ## --------- ## hostname = devel11 uname -m = x86_64 uname -r = 3.10.0-229.4.2.el7.x86_64 uname -s = Linux uname -v = #1 SMP Wed May 13 10:06:09 UTC 2015 /usr/bin/uname -p = x86_64 /bin/uname -X = unknown /bin/arch = x86_64 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown
- [Starpu-devel] segfault MPI execution and starpu_fxt_tool, Florent Pruvost, 26/06/2015
- Re: [Starpu-devel] segfault MPI execution and starpu_fxt_tool, Samuel Thibault, 26/06/2015
- Re: [Starpu-devel] segfault MPI execution and starpu_fxt_tool, Florent Pruvost, 26/06/2015
- Re: [Starpu-devel] segfault MPI execution and starpu_fxt_tool, Samuel Thibault, 29/06/2015
- Re: [Starpu-devel] segfault MPI execution and starpu_fxt_tool, Florent Pruvost, 29/06/2015
