Accéder au contenu.
Menu Sympa
Archives de la liste
Chronologique Discussions
## Core tests. ##
configure:3372: checking build system type
configure:3386: result: x86_64-unknown-linux-gnu
configure:3406: checking host system type
configure:3419: result: x86_64-unknown-linux-gnu
configure:3439: checking target system type
configure:3452: result: x86_64-unknown-linux-gnu
configure:3496: checking for a BSD-compatible install
configure:3564: result: /usr/bin/install -c
configure:3575: checking whether build environment is sane
configure:3630: result: yes
configure:3781: checking for a thread-safe mkdir -p
configure:3820: result: /usr/bin/mkdir -p
configure:3827: checking for gawk
configure:3843: found /usr/bin/gawk
configure:3854: result: gawk
configure:3865: checking whether make sets $(MAKE)
configure:3887: result: yes
configure:3916: checking whether make supports nested variables
configure:3933: result: yes
configure:4029: checking whether make supports nested variables
configure:4046: result: yes
configure:4072: checking for style of include used by make
configure:4100: result: GNU
configure:4171: checking for gcc
configure:4198: result: /cm/shared/apps/gcc/4.8.4/bin/gcc
configure:4427: checking for C compiler version
configure:4436: /cm/shared/apps/gcc/4.8.4/bin/gcc --version >&5
gcc (GCC) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4447: $? = 0
configure:4436: /cm/shared/apps/gcc/4.8.4/bin/gcc -v >&5
Using built-in specs.
COLLECT_GCC=/cm/shared/apps/gcc/4.8.4/bin/gcc
COLLECT_LTO_WRAPPER=/cm/shared/apps/gcc/4.8.4/libexec/gcc/x86_64-unknown-linux-gnu/4.8.4/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: ../gcc-4.8.4/configure --prefix=/cm/shared/apps/gcc/4.8.4
--enable-languages=c,c++,fortran
--with-gmp-include=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-gmp
--with-gmp-lib=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-gmp/.libs
--with-mpc-include=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-mpc/src
--with-mpc-lib=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-mpc/src/.libs
--with-mpfr-include=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-mpfr/src
--with-mpfr-lib=/root/rpmbuild/BUILD/gcc-4.8.4-obj/../gcc-4.8.4/our-mpfr/src/.libs
Thread model: posix
gcc version 4.8.4 (GCC)
configure:4436: /cm/shared/apps/gcc/4.8.4/bin/gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4447: $? = 1
configure:4436: /cm/shared/apps/gcc/4.8.4/bin/gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:4467: checking whether the C compiler works
configure:4489: /cm/shared/apps/gcc/4.8.4/bin/gcc conftest.c >&5
configure:4493: $? = 0
configure:4541: result: yes
configure:4544: checking for C compiler default output file name
configure:4546: result: a.out
configure:4552: checking for suffix of executables
configure:4559: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest conftest.c
>&5
configure:4563: $? = 0
configure:4585: result:
configure:4607: checking whether we are cross compiling
configure:4615: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest conftest.c
>&5
configure:4619: $? = 0
configure:4626: ./conftest
configure:4630: $? = 0
configure:4645: result: no
configure:4650: checking for suffix of object files
configure:4672: /cm/shared/apps/gcc/4.8.4/bin/gcc -c conftest.c >&5
configure:4676: $? = 0
configure:4697: result: o
configure:4701: checking whether we are using the GNU C compiler
configure:4720: /cm/shared/apps/gcc/4.8.4/bin/gcc -c conftest.c >&5
configure:4720: $? = 0
configure:4729: result: yes
configure:4738: checking whether /cm/shared/apps/gcc/4.8.4/bin/gcc accepts -g
configure:4758: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g conftest.c >&5
configure:4758: $? = 0
configure:4799: result: yes
configure:4816: checking for /cm/shared/apps/gcc/4.8.4/bin/gcc option to
accept ISO C89
configure:4879: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:4879: $? = 0
configure:4892: result: none needed
configure:4914: checking dependency style of /cm/shared/apps/gcc/4.8.4/bin/gcc
configure:5025: result: gcc3
configure:5090: checking for ar
configure:5106: found /usr/bin/ar
configure:5117: result: ar
configure:5143: checking the archiver (ar) interface
configure:5153: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:5153: $? = 0
configure:5155: ar cru libconftest.a conftest.o >&5
configure:5158: $? = 0
configure:5181: result: ar
configure:5249: checking for gcc
configure:5276: result: /cm/shared/apps/gcc/4.8.4/bin/gcc
configure:5505: checking for C compiler version
configure:5514: /cm/shared/apps/gcc/4.8.4/bin/gcc --version >&5
gcc (GCC) 4.8.4
configure:5525: $? = 0
configure:5514: /cm/shared/apps/gcc/4.8.4/bin/gcc -v >&5
Thread model: posix
configure:5514: /cm/shared/apps/gcc/4.8.4/bin/gcc -V >&5
configure:5525: $? = 1
configure:5514: /cm/shared/apps/gcc/4.8.4/bin/gcc -qversion >&5
configure:5529: checking whether we are using the GNU C compiler
configure:5557: result: yes
configure:5566: checking whether /cm/shared/apps/gcc/4.8.4/bin/gcc accepts -g
configure:5627: result: yes
configure:5644: checking for /cm/shared/apps/gcc/4.8.4/bin/gcc option to
accept ISO C89
configure:5720: result: none needed
configure:5742: checking dependency style of /cm/shared/apps/gcc/4.8.4/bin/gcc
configure:5853: result: gcc3
configure:5869: checking whether /cm/shared/apps/gcc/4.8.4/bin/gcc and cc
understand -c and -o together
configure:5900: /cm/shared/apps/gcc/4.8.4/bin/gcc -c conftest.c -o
conftest2.o >&5
configure:5904: $? = 0
configure:5910: /cm/shared/apps/gcc/4.8.4/bin/gcc -c conftest.c -o
conftest2.o >&5
configure:5914: $? = 0
configure:5925: cc -c conftest.c >&5
configure:5929: $? = 0
configure:5937: cc -c conftest.c -o conftest2.o >&5
configure:5941: $? = 0
configure:5947: cc -c conftest.c -o conftest2.o >&5
configure:5951: $? = 0
configure:5969: result: yes
configure:6106: checking for C++ compiler version
configure:6115: /cm/shared/apps/gcc/4.8.4/bin/g++ --version >&5
g++ (GCC) 4.8.4
configure:6126: $? = 0
configure:6115: /cm/shared/apps/gcc/4.8.4/bin/g++ -v >&5
COLLECT_GCC=/cm/shared/apps/gcc/4.8.4/bin/g++
Thread model: posix
configure:6115: /cm/shared/apps/gcc/4.8.4/bin/g++ -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6126: $? = 1
configure:6115: /cm/shared/apps/gcc/4.8.4/bin/g++ -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:6130: checking whether we are using the GNU C++ compiler
configure:6149: /cm/shared/apps/gcc/4.8.4/bin/g++ -c conftest.cpp >&5
configure:6149: $? = 0
configure:6158: result: yes
configure:6167: checking whether /cm/shared/apps/gcc/4.8.4/bin/g++ accepts -g
configure:6187: /cm/shared/apps/gcc/4.8.4/bin/g++ -c -g conftest.cpp >&5
configure:6187: $? = 0
configure:6228: result: yes
configure:6253: checking dependency style of /cm/shared/apps/gcc/4.8.4/bin/g++
configure:6364: result: gcc3
configure:6384: checking how to run the C preprocessor
configure:6415: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
configure:6415: $? = 0
configure:6429: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or directory
#include <ac_nonexistent.h>
configure:6429: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.1.5"
| #define PACKAGE_STRING "StarPU 1.1.5"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 1
| #define STARPU_RELEASE_VERSION 5
| #define PACKAGE "starpu"
| #define VERSION "1.1.5"
| /* end confdefs.h. */
configure:6454: result: /cm/shared/apps/gcc/4.8.4/bin/gcc -E
configure:6474: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
configure:6474: $? = 0
configure:6488: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
configure:6488: $? = 1
| /* confdefs.h */
configure:6516: checking for a sed that does not truncate output
configure:6580: result: /usr/bin/sed
configure:6585: checking whether ln -s works
configure:6589: result: yes
configure:6649: checking for g77
configure:6679: result: no
configure:6649: checking for xlf
configure:6649: checking for f77
configure:6649: checking for frt
configure:6649: checking for pgf77
configure:6649: checking for cf77
configure:6649: checking for fort77
configure:6649: checking for fl32
configure:6649: checking for af77
configure:6649: checking for xlf90
configure:6649: checking for f90
configure:6649: checking for pgf90
configure:6649: checking for pghpf
configure:6649: checking for epcf90
configure:6649: checking for gfortran
configure:6665: found /cm/shared/apps/gcc/4.8.4/bin/gfortran
configure:6676: result: gfortran
configure:6702: checking for Fortran 77 compiler version
configure:6711: gfortran --version >&5
GNU Fortran (GCC) 4.8.4
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:6722: $? = 0
configure:6711: gfortran -v >&5
COLLECT_GCC=gfortran
Thread model: posix
configure:6711: gfortran -V >&5
gfortran: error: unrecognized command line option '-V'
gfortran: fatal error: no input files
configure:6722: $? = 1
configure:6711: gfortran -qversion >&5
gfortran: error: unrecognized command line option '-qversion'
configure:6731: checking whether we are using the GNU Fortran 77 compiler
configure:6744: gfortran -c conftest.F >&5
configure:6744: $? = 0
configure:6753: result: yes
configure:6759: checking whether gfortran accepts -g
configure:6770: gfortran -c -g conftest.f >&5
configure:6770: $? = 0
configure:6778: result: yes
configure:6913: checking for Fortran compiler version
configure:6922: /cm/shared/apps/gcc/4.8.4/bin/gfortran --version >&5
configure:6933: $? = 0
configure:6922: /cm/shared/apps/gcc/4.8.4/bin/gfortran -v >&5
COLLECT_GCC=/cm/shared/apps/gcc/4.8.4/bin/gfortran
Thread model: posix
configure:6922: /cm/shared/apps/gcc/4.8.4/bin/gfortran -V >&5
configure:6933: $? = 1
configure:6922: /cm/shared/apps/gcc/4.8.4/bin/gfortran -qversion >&5
configure:6942: checking whether we are using the GNU Fortran compiler
configure:6955: /cm/shared/apps/gcc/4.8.4/bin/gfortran -c conftest.F >&5
configure:6955: $? = 0
configure:6964: result: yes
configure:6970: checking whether /cm/shared/apps/gcc/4.8.4/bin/gfortran
accepts -g
configure:6981: /cm/shared/apps/gcc/4.8.4/bin/gfortran -c -g conftest.f >&5
configure:6981: $? = 0
configure:6989: result: yes
configure:7066: checking how to print strings
configure:7093: result: printf
configure:7114: checking for a sed that does not truncate output
configure:7178: result: /usr/bin/sed
configure:7196: checking for grep that handles long lines and -e
configure:7254: result: /usr/bin/grep
configure:7259: checking for egrep
configure:7321: result: /usr/bin/grep -E
configure:7326: checking for fgrep
configure:7388: result: /usr/bin/grep -F
configure:7423: checking for ld used by /cm/shared/apps/gcc/4.8.4/bin/gcc
configure:7490: result: /usr/bin/ld
configure:7497: checking if the linker (/usr/bin/ld) is GNU ld
configure:7512: result: yes
configure:7524: checking for BSD- or MS-compatible name lister (nm)
configure:7573: result: /usr/bin/nm -B
configure:7703: checking the name lister (/usr/bin/nm -B) interface
configure:7710: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:7713: /usr/bin/nm -B "conftest.o"
configure:7716: output
0000000000000000 B some_variable
configure:7723: result: BSD nm
configure:7727: checking the maximum length of command line arguments
configure:7857: result: 1572864
configure:7874: checking whether the shell understands some XSI constructs
configure:7884: result: yes
configure:7888: checking whether the shell understands "+="
configure:7894: result: yes
configure:7929: checking how to convert x86_64-unknown-linux-gnu file names
to x86_64-unknown-linux-gnu format
configure:7969: result: func_convert_file_noop
configure:7976: checking how to convert x86_64-unknown-linux-gnu file names
to toolchain format
configure:7996: result: func_convert_file_noop
configure:8003: checking for /usr/bin/ld option to reload object files
configure:8010: result: -r
configure:8084: checking for objdump
configure:8100: found /usr/bin/objdump
configure:8111: result: objdump
configure:8140: checking how to recognize dependent libraries
configure:8342: result: pass_all
configure:8427: checking for dlltool
configure:8457: result: no
configure:8484: checking how to associate runtime and link libraries
configure:8511: result: printf %s\n
configure:8635: checking for archiver @FILE support
configure:8652: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:8652: $? = 0
configure:8655: ar cru libconftest.a @conftest.lst >&5
configure:8658: $? = 0
configure:8663: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:8666: $? = 1
configure:8678: result: @
configure:8736: checking for strip
configure:8752: found /usr/bin/strip
configure:8763: result: strip
configure:8835: checking for ranlib
configure:8851: found /usr/bin/ranlib
configure:8862: result: ranlib
configure:8964: checking command to parse /usr/bin/nm -B output from
/cm/shared/apps/gcc/4.8.4/bin/gcc object
configure:9084: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:9087: $? = 0
configure:9091: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[
]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'
| sed '/ __gnu_lto/d' \> conftest.nm
configure:9094: $? = 0
configure:9160: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c conftstm.o >&5
configure:9163: $? = 0
configure:9201: result: ok
configure:9238: checking for sysroot
configure:9268: result: no
configure:9345: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:9348: $? = 0
configure:9524: checking for mt
configure:9554: result: no
configure:9574: checking if : is a manifest tool
configure:9580: : '-?'
configure:9588: result: no
configure:10226: checking for ANSI C header files
configure:10246: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:10246: $? = 0
configure:10319: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c >&5
configure:10319: $? = 0
configure:10319: ./conftest
configure:10330: result: yes
configure:10343: checking for sys/types.h
configure:10343: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:10343: $? = 0
configure:10343: result: yes
configure:10343: checking for sys/stat.h
configure:10343: checking for stdlib.h
configure:10343: checking for string.h
configure:10343: checking for memory.h
configure:10343: checking for strings.h
configure:10343: checking for inttypes.h
configure:10343: checking for stdint.h
configure:10343: checking for unistd.h
configure:10357: checking for dlfcn.h
configure:10357: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:10357: $? = 0
configure:10357: result: yes
configure:10874: checking for objdir
configure:10889: result: .libs
configure:11160: checking if /cm/shared/apps/gcc/4.8.4/bin/gcc supports
-fno-rtti -fno-exceptions
configure:11178: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -fno-rtti
-fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not
for C [enabled by default]
configure:11182: $? = 0
configure:11195: result: no
configure:11522: checking for /cm/shared/apps/gcc/4.8.4/bin/gcc option to
produce PIC
configure:11529: result: -fPIC -DPIC
configure:11537: checking if /cm/shared/apps/gcc/4.8.4/bin/gcc PIC flag -fPIC
-DPIC works
configure:11555: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -fPIC -DPIC
-DPIC conftest.c >&5
configure:11559: $? = 0
configure:11572: result: yes
configure:11601: checking if /cm/shared/apps/gcc/4.8.4/bin/gcc static flag
-static works
configure:11629: result: no
configure:11644: checking if /cm/shared/apps/gcc/4.8.4/bin/gcc supports -c -o
file.o
configure:11665: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -o
out/conftest2.o conftest.c >&5
configure:11669: $? = 0
configure:11691: result: yes
configure:11699: checking if /cm/shared/apps/gcc/4.8.4/bin/gcc supports -c -o
file.o
configure:11746: result: yes
configure:11779: checking whether the /cm/shared/apps/gcc/4.8.4/bin/gcc
linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:12932: result: yes
configure:12969: checking whether -lc should be explicitly linked in
configure:12977: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:12980: $? = 0
configure:12995: /cm/shared/apps/gcc/4.8.4/bin/gcc -shared -fPIC -DPIC
conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /usr/bin/grep
-lc \>/dev/null 2\>\&1
configure:12998: $? = 0
configure:13012: result: no
configure:13172: checking dynamic linker characteristics
configure:13683: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
-Wl,-rpath -Wl,/foo conftest.c >&5
configure:13683: $? = 0
configure:13909: result: GNU/Linux ld.so
configure:14016: checking how to hardcode library paths into programs
configure:14041: result: immediate
configure:14581: checking whether stripping libraries is possible
configure:14586: result: yes
configure:14621: checking if libtool supports shared libraries
configure:14623: result: yes
configure:14626: checking whether to build shared libraries
configure:14647: result: yes
configure:14650: checking whether to build static libraries
configure:14654: result: yes
configure:14677: checking how to run the C++ preprocessor
configure:14704: /cm/shared/apps/gcc/4.8.4/bin/g++ -E conftest.cpp
configure:14704: $? = 0
configure:14718: /cm/shared/apps/gcc/4.8.4/bin/g++ -E conftest.cpp
conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or directory
configure:14718: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:14743: result: /cm/shared/apps/gcc/4.8.4/bin/g++ -E
configure:14763: /cm/shared/apps/gcc/4.8.4/bin/g++ -E conftest.cpp
configure:14763: $? = 0
configure:14777: /cm/shared/apps/gcc/4.8.4/bin/g++ -E conftest.cpp
configure:14777: $? = 1
| /* confdefs.h */
configure:14946: checking for ld used by /cm/shared/apps/gcc/4.8.4/bin/g++
configure:15013: result: /usr/bin/ld -m elf_x86_64
configure:15020: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:15035: result: yes
configure:15090: checking whether the /cm/shared/apps/gcc/4.8.4/bin/g++
configure:16095: result: yes
configure:16131: /cm/shared/apps/gcc/4.8.4/bin/g++ -c -g -O2 conftest.cpp >&5
configure:16134: $? = 0
configure:16654: checking for /cm/shared/apps/gcc/4.8.4/bin/g++ option to
produce PIC
configure:16661: result: -fPIC -DPIC
configure:16669: checking if /cm/shared/apps/gcc/4.8.4/bin/g++ PIC flag -fPIC
-DPIC works
configure:16687: /cm/shared/apps/gcc/4.8.4/bin/g++ -c -g -O2 -fPIC -DPIC
-DPIC conftest.cpp >&5
configure:16691: $? = 0
configure:16704: result: yes
configure:16727: checking if /cm/shared/apps/gcc/4.8.4/bin/g++ static flag
-static works
configure:16755: result: no
configure:16767: checking if /cm/shared/apps/gcc/4.8.4/bin/g++ supports -c -o
file.o
configure:16788: /cm/shared/apps/gcc/4.8.4/bin/g++ -c -g -O2 -o
out/conftest2.o conftest.cpp >&5
configure:16792: $? = 0
configure:16814: result: yes
configure:16819: checking if /cm/shared/apps/gcc/4.8.4/bin/g++ supports -c -o
file.o
configure:16866: result: yes
configure:16896: checking whether the /cm/shared/apps/gcc/4.8.4/bin/g++
configure:16932: result: yes
configure:17073: checking dynamic linker characteristics
configure:17744: result: GNU/Linux ld.so
configure:17797: checking how to hardcode library paths into programs
configure:17822: result: immediate
configure:17970: checking if libtool supports shared libraries
configure:17972: result: yes
configure:17975: checking whether to build shared libraries
configure:17995: result: yes
configure:17998: checking whether to build static libraries
configure:18002: result: yes
configure:18323: checking for gfortran option to produce PIC
configure:18330: result: -fPIC
configure:18338: checking if gfortran PIC flag -fPIC works
configure:18356: gfortran -c -g -O2 -fPIC conftest.f >&5
configure:18360: $? = 0
configure:18373: result: yes
configure:18396: checking if gfortran static flag -static works
configure:18424: result: no
configure:18436: checking if gfortran supports -c -o file.o
configure:18457: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:18461: $? = 0
configure:18483: result: yes
configure:18488: checking if gfortran supports -c -o file.o
configure:18535: result: yes
configure:18565: checking whether the gfortran linker (/usr/bin/ld -m
configure:19668: result: yes
configure:19809: checking dynamic linker characteristics
configure:20474: result: GNU/Linux ld.so
configure:20527: checking how to hardcode library paths into programs
configure:20552: result: immediate
configure:20696: checking if libtool supports shared libraries
configure:20698: result: yes
configure:20701: checking whether to build shared libraries
configure:20721: result: yes
configure:20724: checking whether to build static libraries
configure:20728: result: yes
configure:20762: /cm/shared/apps/gcc/4.8.4/bin/gfortran -c -g -O2 conftest.f
>&5
configure:20765: $? = 0
configure:21194: checking for /cm/shared/apps/gcc/4.8.4/bin/gfortran option
to produce PIC
configure:21201: result: -fPIC
configure:21209: checking if /cm/shared/apps/gcc/4.8.4/bin/gfortran PIC flag
-fPIC works
configure:21227: /cm/shared/apps/gcc/4.8.4/bin/gfortran -c -g -O2 -fPIC
conftest.f >&5
configure:21231: $? = 0
configure:21244: result: yes
configure:21267: checking if /cm/shared/apps/gcc/4.8.4/bin/gfortran static
flag -static works
configure:21295: result: no
configure:21307: checking if /cm/shared/apps/gcc/4.8.4/bin/gfortran supports
-c -o file.o
configure:21328: /cm/shared/apps/gcc/4.8.4/bin/gfortran -c -g -O2 -o
configure:21332: $? = 0
configure:21354: result: yes
configure:21359: checking if /cm/shared/apps/gcc/4.8.4/bin/gfortran supports
-c -o file.o
configure:21406: result: yes
configure:21436: checking whether the /cm/shared/apps/gcc/4.8.4/bin/gfortran
configure:22539: result: yes
configure:22680: checking dynamic linker characteristics
configure:23345: result: GNU/Linux ld.so
configure:23398: checking how to hardcode library paths into programs
configure:23423: result: immediate
configure:23476: checking whether ln -s works
configure:23480: result: yes
configure:23488: checking for ANSI C header files
configure:23592: result: yes
configure:23601: checking for C/C++ restrict keyword
configure:23626: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:23626: $? = 0
configure:23634: result: __restrict
configure:23653: checking for bash
configure:23680: result: /bin/sh
configure:23695: checking for svn
configure:23713: found /usr/bin/svn
configure:23725: result: /usr/bin/svn
configure:23735: checking for svnversion
configure:23753: found /usr/bin/svnversion
configure:23765: result: /usr/bin/svnversion
configure:23799: checking for lib
configure:23832: result: no
configure:23872: checking size of void *
configure:23877: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c >&5
configure:23877: $? = 0
configure:23877: ./conftest
configure:23891: result: 8
configure:23978: checking for pthread_create in -lpthread
configure:24003: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c -lpthread >&5
configure:24003: $? = 0
configure:24012: result: yes
configure:24024: checking for struct timespec
configure:24024: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:24024: $? = 0
conftest.c: In function 'main':
conftest.c:47:30: error: expected expression before ')' token
if (sizeof ((struct timespec)))
configure:24024: $? = 1
| /* confdefs.h */
| #define restrict __restrict
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/home/pruvost/work/svnwc/starpu-1.1/build"
| #define STARPU_SRC_DIR "/home/pruvost/work/svnwc/starpu-1.1/build/.."
| #define HAVE_LIBPTHREAD 1
| #include <sys/types.h>
| #include <sys/stat.h>
| #ifdef HAVE_UNISTD_H
| #include <unistd.h>
| #endif
| #include <time.h>
| #ifndef STARPU_NATIVE_WINTHREADS
| #include <pthread.h>
| #endif
| int
| main ()
| return 0;
| return 0;
configure:24024: result: yes
configure:24043: checking for library containing sqrt
configure:24074: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c:40:6: warning: conflicting types for built-in function 'sqrt'
char sqrt ();
/tmp/ccQtdKJd.o: In function `main':
/home/pruvost/work/svnwc/starpu-1.1/build/conftest.c:44: undefined reference
to `sqrt'
collect2: error: ld returned 1 exit status
configure:24074: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
| return 0;
conftest.c -lm -lpthread >&5
char sqrt ();
configure:24074: $? = 0
configure:24091: result: -lm
configure:24101: checking for main in -lws2_32
configure:24120: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c -lws2_32 -lm -lpthread >&5
/usr/bin/ld: cannot find -lws2_32
configure:24120: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
| return 0;
configure:24129: result: no
configure:24143: checking for sysconf
configure:24143: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24143: $? = 0
configure:24143: result: yes
configure:24153: checking for pthread_spin_lock
configure:24153: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24153: $? = 0
configure:24153: result: yes
configure:24166: checking for pthread_barrier_init
configure:24166: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24166: $? = 0
configure:24166: result: yes
configure:24182: checking for pthread_setaffinity_np
configure:24182: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24182: $? = 0
configure:24182: result: yes
configure:24195: checking for posix_memalign
configure:24195: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24195: $? = 0
configure:24195: result: yes
configure:24208: checking for memalign
configure:24208: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24208: $? = 0
configure:24208: result: yes
configure:24221: checking for drand48
configure:24221: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24221: $? = 0
configure:24221: result: yes
configure:24228: checking for erand48_r
configure:24228: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24228: $? = 0
configure:24228: result: yes
configure:24255: checking for strerror_r
configure:24255: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24255: $? = 0
configure:24255: result: yes
configure:24264: checking for setenv
configure:24264: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24264: $? = 0
configure:24264: result: yes
configure:24273: checking for unsetenv
configure:24273: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24273: $? = 0
configure:24273: result: yes
configure:24282: checking for nearbyintf
configure:24282: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c:69:6: warning: conflicting types for built-in function
'nearbyintf' [enabled by default]
char nearbyintf ();
configure:24282: $? = 0
configure:24282: result: yes
configure:24291: checking for rintf
configure:24291: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
conftest.c:70:6: warning: conflicting types for built-in function 'rintf'
char rintf ();
configure:24291: $? = 0
configure:24291: result: yes
configure:24345: checking malloc.h usability
configure:24345: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
configure:24345: $? = 0
configure:24345: result: yes
configure:24345: checking malloc.h presence
configure:24345: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
configure:24345: checking for malloc.h
configure:24368: checking valgrind/valgrind.h usability
configure:24368: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
conftest.c:83:31: fatal error: valgrind/valgrind.h: No such file or directory
#include <valgrind/valgrind.h>
configure:24368: $? = 1
| /* confdefs.h */
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| # include <unistd.h>
| #endif
configure:24368: result: no
configure:24368: checking valgrind/valgrind.h presence
configure:24368: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
conftest.c:50:31: fatal error: valgrind/valgrind.h: No such file or directory
| /* confdefs.h */
configure:24368: checking for valgrind/valgrind.h
configure:24382: checking valgrind/helgrind.h usability
configure:24382: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 conftest.c >&5
conftest.c:83:31: fatal error: valgrind/helgrind.h: No such file or directory
#include <valgrind/helgrind.h>
configure:24382: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24382: result: no
configure:24382: checking valgrind/helgrind.h presence
configure:24382: /cm/shared/apps/gcc/4.8.4/bin/gcc -E conftest.c
conftest.c:50:31: fatal error: valgrind/helgrind.h: No such file or directory
| /* confdefs.h */
configure:24382: checking for valgrind/helgrind.h
configure:24401: checking for sched_yield
configure:24401: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24401: $? = 0
configure:24401: result: yes
configure:24411: checking whether the target supports
__sync_val_compare_and_swap
configure:24428: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24428: $? = 0
configure:24436: result: yes
configure:24446: checking whether the target supports
__sync_bool_compare_and_swap
configure:24463: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24463: $? = 0
configure:24471: result: yes
configure:24481: checking whether the target supports __sync_fetch_and_add
configure:24498: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24498: $? = 0
configure:24506: result: yes
configure:24516: checking whether the target supports __sync_fetch_and_or
configure:24533: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24533: $? = 0
configure:24541: result: yes
configure:24551: checking whether the target supports __sync_lock_test_and_set
configure:24568: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24568: $? = 0
configure:24576: result: yes
configure:24586: checking whether the target supports __sync_synchronize
configure:24603: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
configure:24603: $? = 0
configure:24611: result: yes
configure:24623: checking for library containing set_mempolicy
configure:24654: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -g -O2
-D_GNU_SOURCE conftest.c >&5
/tmp/ccsVAUFy.o: In function `main':
/home/pruvost/work/svnwc/starpu-1.1/build/conftest.c:68: undefined reference
to `set_mempolicy'
configure:24654: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_SCHED_YIELD 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
| return 0;
-D_GNU_SOURCE conftest.c -lnuma >&5
/usr/bin/ld: cannot find -lnuma
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
| return 0;
configure:24671: result: no
configure:24685: checking whether libnuma is available
configure:24687: result: no
configure:24700: checking maximum number of sched_ctxs
configure:24709: result: 10
configure:24761: checking maximum number of CPUs
configure:24770: result: 64
configure:24778: checking whether CPUs should be used
configure:24787: result: yes
configure:24820: checking maximum number of CUDA devices
configure:24829: result: 4
configure:24908: checking whether CUDA is available
configure:24911: result:
configure:24925: checking cuda.h usability
configure:24925: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
conftest.c >&5
conftest.c:95:18: fatal error: cuda.h: No such file or directory
#include <cuda.h>
configure:24925: $? = 1
| /* confdefs.h */
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_NMAX_COMBINEDWORKERS 128
| #define STARPU_MAXCUDADEVS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:24925: result: no
configure:24925: checking cuda.h presence
configure:24925: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
conftest.c:62:18: fatal error: cuda.h: No such file or directory
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:24925: checking for cuda.h
configure:25459: checking whether CUDA is available
configure:25462: result:
configure:25476: checking cuda.h usability
configure:25476: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
conftest.c >&5
#include <cuda.h>
configure:25476: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:25476: result: no
configure:25476: checking cuda.h presence
configure:25476: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:25476: checking for cuda.h
configure:26010: checking whether CUDA is available in /usr/local/cuda
configure:26016: result:
configure:26030: checking cuda.h usability
configure:26030: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
-I/usr/local/cuda/include conftest.c >&5
#include <cuda.h>
configure:26030: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:26030: result: no
configure:26030: checking cuda.h presence
configure:26030: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:26030: checking for cuda.h
configure:26010: checking whether CUDA is available in /c/cuda
-I/c/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:26010: checking whether CUDA is available in /cygdrive/c/cuda
-I/cygdrive/c/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:26010: checking whether CUDA is available in /opt/cuda
-I/opt/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:26010: checking whether CUDA is available in /..
-I/../include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:26552: checking whether CUDA is working
configure:26616: result: no
configure:26627: checking whether CUDA should be used
configure:26629: result: no
configure:26728: checking for pkg-config
configure:26746: found /usr/bin/pkg-config
configure:26758: result: /usr/bin/pkg-config
configure:26783: checking pkg-config is at least version 0.9.0
configure:26786: result: yes
configure:26885: checking whether MAGMA should be used
configure:26887: result: no
configure:26891: checking for cufftDoubleComplex
configure:26891: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
conftest.c >&5
conftest.c:62:19: fatal error: cufft.h: No such file or directory
#include <cufft.h>
configure:26891: $? = 1
| /* confdefs.h */
| #include <cufft.h>
| int
| main ()
| if (sizeof (cufftDoubleComplex))
| return 0;
| return 0;
configure:26891: result: no
configure:26957: checking whether CURAND is available
configure:26959: result: no
configure:27015: checking maximum number of OpenCL devices
configure:27024: result: 8
configure:27137: checking whether OpenCL is available
configure:27140: result:
configure:27153: checking CL/cl.h usability
configure:27153: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
conftest.c >&5
conftest.c:96:19: fatal error: CL/cl.h: No such file or directory
#include <CL/cl.h>
configure:27153: $? = 1
| /* confdefs.h */
| #define STARPU_MAXOPENCLDEVS 8
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:27153: result: no
configure:27153: checking CL/cl.h presence
configure:27153: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
conftest.c:63:19: fatal error: CL/cl.h: No such file or directory
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27153: checking for CL/cl.h
configure:27377: checking whether OpenCL is available in /usr/local/cuda no
and no
configure:27383: result:
configure:27396: checking CL/cl.h usability
configure:27396: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -g -O2 -D_GNU_SOURCE
#include <CL/cl.h>
configure:27396: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:27396: result: no
configure:27396: checking CL/cl.h presence
configure:27396: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27396: checking for CL/cl.h
configure:27377: checking whether OpenCL is available in /c/cuda no and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27377: checking whether OpenCL is available in /cygdrive/c/cuda no
and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27377: checking whether OpenCL is available in /opt/cuda no and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27377: checking whether OpenCL is available in /.. no and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:27630: checking whether OpenCL should be used
configure:27632: result: no
configure:27660: checking whether asynchronous copy should be disabled
configure:27673: result: no
configure:27681: checking whether asynchronous CUDA copy should be disabled
configure:27694: result: no
configure:27702: checking whether asynchronous OpenCL copy should be disabled
configure:27715: result: no
configure:27924: checking whether SimGrid is enabled
configure:27926: result: no
configure:27929: checking whether blocking drivers should be disabled
configure:27938: result: no
configure:27954: checking whether debug mode should be enabled
configure:27963: result: no
configure:27994: checking whether extra checks should be performed
configure:28003: result: no
configure:28011: checking whether debug messages should be displayed
configure:28020: result: no
configure:28028: checking whether coverage testing should be enabled
configure:28037: result: no
configure:28055: checking whether FxT traces should be generated
configure:28064: result: yes
configure:28202: checking for FXT
configure:28210: $PKG_CONFIG --exists --print-errors "fxt"
configure:28213: $? = 0
configure:28228: $PKG_CONFIG --exists --print-errors "fxt"
configure:28231: $? = 0
configure:28286: result: yes
configure:28297: checking for enable_fut_flush
configure:28297: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lm -lpthread
-L/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/fxt-0.3.1-si37ytj7fcck5e3pofxfvhdpblwn36if/lib
-lfxt >&5
configure:28297: $? = 0
configure:28297: result: yes
configure:28308: checking for fut_set_filename
configure:28308: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-lfxt >&5
configure:28308: $? = 0
configure:28308: result: yes
configure:28321: checking whether enable_fut_flush is declared
configure:28321: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
-g3
-I/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/fxt-0.3.1-si37ytj7fcck5e3pofxfvhdpblwn36if/include
conftest.c:108:10: error: 'enable_fut_flush' undeclared (first use in this
function)
(void) enable_fut_flush;
conftest.c:108:10: note: each undeclared identifier is reported only once for
each function it appears in
configure:28321: $? = 1
| /* confdefs.h */
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_USE_FXT 1
| #define CONFIG_FUT 1
| #define HAVE_ENABLE_FUT_FLUSH 1
| #define HAVE_FUT_SET_FILENAME 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef enable_fut_flush
| #ifdef __cplusplus
| #else
| #endif
| #endif
| return 0;
configure:28321: result: no
configure:28332: checking whether fut_set_filename is declared
configure:28332: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
-g3
conftest.c:109:10: error: 'fut_set_filename' undeclared (first use in this
function)
(void) fut_set_filename;
conftest.c:109:10: note: each undeclared identifier is reported only once for
configure:28332: $? = 1
| /* confdefs.h */
| #define HAVE_DECL_ENABLE_FUT_FLUSH 0
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef fut_set_filename
| #ifdef __cplusplus
| #else
| #endif
| #endif
| return 0;
configure:28332: result: no
configure:28350: checking for POTI
configure:28358: $PKG_CONFIG --exists --print-errors "poti"
Package poti was not found in the pkg-config search path.
Perhaps you should add the directory containing `poti.pc'
to the PKG_CONFIG_PATH environment variable
No package 'poti' found
configure:28361: $? = 1
configure:28376: $PKG_CONFIG --exists --print-errors "poti"
configure:28379: $? = 1
configure:28407: result: no
configure:28427: checking whether performance debugging should be enabled
configure:28436: result: no
configure:28448: checking whether performance model debugging should be
enabled
configure:28457: result: no
configure:28465: checking whether statistics should be generated
configure:28474: result: no
configure:28486: checking whether memory stats should be displayed
configure:28495: result: no
configure:28505: checking glpk.h usability
configure:28505: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
-g3 -D_GNU_SOURCE conftest.c >&5
conftest.c:103:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
configure:28505: $? = 1
| /* confdefs.h */
| #define HAVE_DECL_FUT_SET_FILENAME 0
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:28505: result: no
configure:28505: checking glpk.h presence
configure:28505: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
conftest.c:70:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
| /* confdefs.h */
| #include <glpk.h>
configure:28505: checking for glpk.h
configure:28519: checking for main in -lglpk
configure:28538: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lglpk >&5
/usr/bin/ld: cannot find -lglpk
configure:28538: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
| return 0;
configure:28547: result: no
configure:28565: checking Ayudame.h usability
configure:28565: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
conftest.c:103:21: fatal error: Ayudame.h: No such file or directory
#include <Ayudame.h>
configure:28565: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:28565: result: no
configure:28565: checking Ayudame.h presence
configure:28565: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
conftest.c:70:21: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
configure:28565: checking for Ayudame.h
configure:28582: checking how many buffers can be manipulated per task
configure:28591: result: 8
configure:28624: checking maximum number of memory nodes
configure:28626: result: 1
configure:28635: checking whether allocation cache should be used
configure:28644: result: yes
configure:28678: checking using explicit performance model location
configure:28680: result: no
configure:28683: checking performance models location
configure:28685: result: $HOME/.starpu/sampling/
configure:28689: checking for clock_gettime in -lrt
configure:28714: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5
configure:28714: $? = 0
configure:28723: result: yes
configure:28736: checking for clock_gettime
configure:28736: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
configure:28736: $? = 0
configure:28736: result: yes
configure:28760: checking Maximum number of workers
configure:28762: result: 64
configure:28771: checking maximum number of implementations
configure:28780: result: 4
configure:28809: checking for mpicc
configure:28827: found /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc
configure:28840: result: /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc
configure:28862: checking mpicc path
configure:28864: result: /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc
configure:28916: checking for mpiexec
configure:28935: found /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec
configure:28948: result: /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec
configure:28960: checking whether mpiexec is available
configure:28962: result: /cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec
configure:28983: checking whether MPI tests should be run
configure:28985: result: no
configure:28991: checking whether the StarPU MPI library should be generated
configure:28993: result: yes
configure:29041: checking for StarPU-Top
configure:29050: checking for qmake-qt4
configure:29083: result: no
configure:29180: checking whether compiler support -Wall
configure:29202: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -Wall -D_GNU_SOURCE
conftest.c >&5
conftest.c:84:18: warning: unused variable 'hello' [-Wunused-variable]
const char *hello = "Hello World";
configure:29202: $? = 0
configure:29205: result: yes
configure:29219: checking whether compiler support -Werror=implicit
configure:29241: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -Werror=implicit
configure:29241: $? = 0
configure:29244: result: yes
configure:29258: checking whether compiler support
-Werror=implicit-function-declaration
configure:29280: /cm/shared/apps/gcc/4.8.4/bin/gcc -c
-Werror=implicit-function-declaration -D_GNU_SOURCE conftest.c >&5
configure:29280: $? = 0
configure:29283: result: yes
configure:29528: checking whether GCC supports plug-ins
configure:29583: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
-g3
-I/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include
conftest.c >&5
In file included from
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/config.h:6:0,
from
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gcc-plugin.h:27,
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1698:0:
warning: "PACKAGE_BUGREPORT" redefined [enabled by default]
#define PACKAGE_BUGREPORT ""
conftest.c:6:0: note: this is the location of the previous definition
from
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1704:0:
warning: "PACKAGE_NAME" redefined [enabled by default]
#define PACKAGE_NAME ""
conftest.c:2:0: note: this is the location of the previous definition
from
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1710:0:
warning: "PACKAGE_STRING" redefined [enabled by default]
#define PACKAGE_STRING ""
conftest.c:5:0: note: this is the location of the previous definition
from
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1716:0:
warning: "PACKAGE_TARNAME" redefined [enabled by default]
#define PACKAGE_TARNAME ""
conftest.c:3:0: note: this is the location of the previous definition
from
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1722:0:
warning: "PACKAGE_URL" redefined [enabled by default]
#define PACKAGE_URL ""
conftest.c:7:0: note: this is the location of the previous definition
from
from conftest.c:78:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/auto-host.h:1728:0:
warning: "PACKAGE_VERSION" redefined [enabled by default]
#define PACKAGE_VERSION ""
conftest.c:4:0: note: this is the location of the previous definition
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:24:0,
from conftest.c:79:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/machmode.h:262:1:
error: unknown type name 'class'
class bit_field_mode_iterator
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/machmode.h:263:1:
error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:27:0,
from conftest.c:79:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:220:8:
error: field 'register_overhead' declared as a function
void register_overhead (size_t, const char *, int, const char *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:221:8:
error: field 'release_overhead' declared as a function
void release_overhead (void);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:222:3:
error: expected specifier-qualifier-list before 'static'
static unsigned calculate_allocation (vec_prefix *, unsigned, bool);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:242:9:
error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
template<typename, typename, typename> struct vec;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:266:3:
error: expected specifier-qualifier-list before 'typedef'
typedef vl_ptr default_layout;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:282:9:
template<typename T>
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:310:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:333:3:
typedef vl_embed default_layout;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:349:9:
template<typename T, typename A>
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:387:21:
error: expected identifier or '(' before ':' token
struct va_gc_atomic : va_gc
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:396:3:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:419:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:436:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:471:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:504:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:517:3:
error: expected specifier-qualifier-list before 'template'
template <typename T, typename A, typename L>
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:520:1:
error: unknown type name 'vnull'
extern vnull vNULL;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:549:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:612:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:621:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:630:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:639:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:649:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:660:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:672:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:683:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:692:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:704:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:715:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:728:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:744:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:755:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:766:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:776:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:785:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:803:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:811:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:822:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:837:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:852:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:878:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:897:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:916:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:929:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:942:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:955:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:967:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:979:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:995:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1008:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1020:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1034:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1047:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1086:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1098:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1110:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1122:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1134:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1143:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1154:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1163:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1171:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1209:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1289:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1299:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1310:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1321:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1380:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1403:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1442:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1462:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1478:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1491:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1503:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1517:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1531:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1547:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1559:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1570:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1581:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1596:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1611:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1624:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1637:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1649:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1660:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1673:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1684:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1695:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1706:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/vec.h:1720:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:28:0,
from conftest.c:79:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:58:3:
static double_int from_uhwi (unsigned HOST_WIDE_INT cst);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:206:1:
error: unknown type name 'double_int'
double_int::from_shwi (HOST_WIDE_INT cst)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:206:11:
error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:229:1:
double_int::from_uhwi (unsigned HOST_WIDE_INT cst)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:229:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:238:1:
double_int::from_pair (HOST_WIDE_INT high, unsigned HOST_WIDE_INT low)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:238:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:246:19:
error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:253:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:260:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:267:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:274:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:281:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:288:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:295:19:
inline double_int &
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:306:11:
double_int::to_shwi () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:315:11:
double_int::to_uhwi () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:323:11:
double_int::fits_uhwi () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:333:1:
double_int::operator ~ () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:333:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:344:1:
double_int::operator | (double_int b) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:344:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:355:1:
double_int::operator & (double_int b) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:355:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:366:1:
double_int::and_not (double_int b) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:366:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:377:1:
double_int::operator ^ (double_int b) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:377:11:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:385:31:
void dump_double_int (FILE *, double_int, bool);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:396:11:
double_int::is_zero () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:404:11:
double_int::is_one () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:412:11:
double_int::is_minus_one () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:420:11:
double_int::is_negative () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:428:11:
double_int::operator == (double_int cst2) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:436:11:
double_int::operator != (double_int cst2) const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:444:11:
double_int::popcount () const
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:453:33:
void mpz_set_double_int (mpz_t, double_int, bool);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/double-int.h:454:1:
double_int mpz_get_double_int (const_tree, mpz_t, bool);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:30:0,
from conftest.c:79:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/fixed-value.h:29:3:
double_int data; /* Store data up to 2 wide integers. */
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/fixed-value.h:55:12:
error: expected ')' before 'enum'
enum machine_mode);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/fixed-value.h:60:30:
const_fixed_from_double_int (double_int payload,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/fixed-value.h:81:9:
double_int, bool, bool);
In file included from conftest.c:79:0:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:251:19:
extern GTY(()) vec<alias_pair, va_gc> *alias_pairs;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:1415:3:
double_int int_cst;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:1580:3:
error: expected specifier-qualifier-list before 'vec'
vec<constructor_elt, va_gc> *elts;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:2085:3:
vec<tree, va_gc> *nonlocalized_vars;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:2551:3:
vec<tree, va_gc> *base_accesses;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:3428:11:
extern vec<tree, va_gc> **decl_debug_args_lookup (tree);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:3429:11:
extern vec<tree, va_gc> **decl_debug_args_insert (tree);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:3534:20:
extern GTY (()) vec<tree, va_gc> *all_translation_units;
In function 'tree_operand_length':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:1398:52:
error: request for member 'low' in something not a structure or union
#define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:1600:9:
note: in expansion of macro 'TREE_INT_CST_LOW'
((int)TREE_INT_CST_LOW (VL_EXP_CHECK (NODE)->exp.operands[0]))
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4105:12:
note: in expansion of macro 'VL_EXP_OPERAND_LENGTH'
return VL_EXP_OPERAND_LENGTH (node);
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4646:38:
error: unknown type name 'vec'
extern tree build_nt_call_vec (tree, vec<tree, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4646:48:
error: unknown type name 'va_gc'
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4731:1:
tree_to_double_int (const_tree cst)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4736:39:
extern tree double_int_to_tree (tree, double_int);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4737:52:
extern bool double_int_fits_to_tree_p (const_tree, double_int);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4738:42:
extern tree force_fit_type_double (tree, double_int, int, bool);
In function 'build_int_cstu':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4745:36:
error: 'double_int' undeclared (first use in this function)
return double_int_to_tree (type, double_int::from_uhwi (cst));
note: each undeclared identifier is reported only once for each function it
appears in
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4745:46:
error: expected ')' before ':' token
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4755:43:
extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4755:64:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4757:38:
extern tree build_constructor (tree, vec<constructor_elt, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4757:59:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4769:48:
error: expected ';', ',' or ')' before '<' token
extern tree build_tree_list_vec_stat (const vec<tree, va_gc> *MEM_STAT_DECL);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4788:41:
extern tree build_call_vec (tree, tree, vec<tree, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4788:51:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4833:37:
extern bool vec_member (const_tree, vec<tree, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4833:47:
In function 'tree_low_cst':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:4852:10:
return TREE_INT_CST_LOW (t);
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5135:3:
vec<tree, va_gc> *pending_statics;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5289:11:
extern vec<tree, va_gc> *ctor_to_vec (tree);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5371:45:
extern void find_placeholder_in_expr (tree, vec<tree> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5773:1:
extern double_int mem_ref_offset (const_tree);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5871:56:
extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5871:66:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5990:32:
error: expected ')' before '<' token
extern void debug_vec_tree (vec<tree, va_gc> *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5994:51:
extern void print_vec_tree (FILE *, const char *, vec<tree, va_gc> *, int);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:5994:61:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:6295:3:
vec<tree, va_gc> *to;
In function 'init_call_expr_arg_iterator':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:1733:32:
#define call_expr_nargs(NODE) (VL_EXP_OPERAND_LENGTH(NODE) - 3)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:6373:13:
note: in expansion of macro 'call_expr_nargs'
iter->n = call_expr_nargs (exp);
In function 'init_const_call_expr_arg_iterator':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/tree.h:6381:13:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:25:0,
from
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:28,
from conftest.c:80:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:152:3:
vec<uchar, va_gc> *action_record_data;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:309:3:
vec<temp_slot_p, va_gc> *x_used_temp_slots;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:544:3:
vec<tree, va_gc> *local_decls;
In function 'add_local_decl':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:651:21:
error: 'struct function' has no member named 'local_decls'
vec_safe_push (fun->local_decls, d);
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/function.h:695:19:
extern GTY(()) vec<tree, va_gc> *types_used_by_cur_var_decl;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:28:0,
from conftest.c:80:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:65:24:
error: unknown type name 'edge_def'
extern void gt_ggc_mx (edge_def *e);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:66:24:
extern void gt_pch_nx (edge_def *e);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:67:24:
extern void gt_pch_nx (edge_def *e, gt_pointer_operator, void *);
from conftest.c:80:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:181:3:
vec<edge, va_gc> *preds;
from conftest.c:80:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:295:3:
vec<basic_block, va_gc> *x_basic_block_info;
In function 'single_succ_p':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:524:24:
error: 'const struct basic_block_def' has no member named 'succs'
return EDGE_COUNT (bb->succs) == 1;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:514:43:
note: in definition of macro 'EDGE_COUNT'
#define EDGE_COUNT(ev) vec_safe_length (ev)
In function 'single_pred_p':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:532:24:
error: 'const struct basic_block_def' has no member named 'preds'
return EDGE_COUNT (bb->preds) == 1;
In function 'single_succ_edge':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:517:33:
#define EDGE_SUCC(bb,i) (*(bb)->succs)[(i)]
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:542:10:
note: in expansion of macro 'EDGE_SUCC'
return EDGE_SUCC (bb, 0);
In function 'single_pred_edge':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:516:33:
#define EDGE_PRED(bb,i) (*(bb)->preds)[(i)]
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:552:10:
note: in expansion of macro 'EDGE_PRED'
return EDGE_PRED (bb, 0);
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:577:3:
vec<edge, va_gc> **container;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:580:18:
static inline vec<edge, va_gc> *
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:592:16:
ei_start_1 (vec<edge, va_gc> **ev)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:605:15:
ei_last_1 (vec<edge, va_gc> **ev)
In function 'ei_edge':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:515:25:
error: invalid type argument of unary '*' (have 'int')
#define EDGE_I(ev,i) (*ev)[(i)]
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:650:10:
note: in expansion of macro 'EDGE_I'
return EDGE_I (ei_container (i), i.index);
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:844:11:
extern vec<basic_block> get_dominated_by (enum cdi_direction, basic_block);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:845:11:
extern vec<basic_block> get_dominated_by_region (enum cdi_direction,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:848:11:
extern vec<basic_block> get_dominated_to_depth (enum cdi_direction,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:850:11:
extern vec<basic_block> get_all_dominated_blocks (enum cdi_direction,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:858:9:
vec<basic_block> , bool);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:880:0,
from
from conftest.c:80:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/cfghooks.h:122:15:
edge, vec<edge> *,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/cfghooks.h:191:11:
vec<edge> *to_remove,
from conftest.c:80:
In function 'bb_has_eh_pred':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:889:27:
error: 'struct basic_block_def' has no member named 'preds'
FOR_EACH_EDGE (e, ei, bb->preds)
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:587:38:
note: in definition of macro 'ei_start'
#define ei_start(iter) ei_start_1 (&(iter))
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:889:3:
note: in expansion of macro 'FOR_EACH_EDGE'
In function 'bb_has_abnormal_pred':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:904:27:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:904:3:
from conftest.c:80:
At top level:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/basic-block.h:914:24:
find_fallthru_edge (vec<edge, va_gc> *edges)
In file included from conftest.c:80:0:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:38:12:
typedef vec<gimple> gimple_vec;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:748:1:
error: conflicting types for 'gimple_build_assign_with_ops'
gimple_build_assign_with_ops (enum tree_code, tree,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:745:1:
note: previous declaration of 'gimple_build_assign_with_ops' was here
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:758:37:
gimple gimple_build_call_vec (tree, vec<tree> );
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:762:58:
gimple gimple_build_call_internal_vec (enum internal_fn, vec<tree> );
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:770:44:
gimple gimple_build_asm_vec (const char *, vec<tree, va_gc> *,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:770:54:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:771:9:
vec<tree, va_gc> *, vec<tree, va_gc> *,
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:771:19:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:771:29:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:771:39:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:772:9:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:772:19:
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:782:41:
gimple gimple_build_switch (tree, tree, vec<tree> );
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:801:27:
void sort_case_labels (vec<tree> );
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:802:47:
void preprocess_case_label_vec_for_gimple (vec<tree> , tree, tree *);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:904:13:
error: conflicting types for 'gimple_call_builtin_p'
extern bool gimple_call_builtin_p (gimple, enum built_in_function);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:903:13:
note: previous declaration of 'gimple_call_builtin_p' was here
extern bool gimple_call_builtin_p (gimple, enum built_in_class);
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:951:3:
vec<gimple> bind_expr_stack;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1001:11:
extern vec<gimple> gimple_bind_expr_stack (void);
In function 'bb_seq':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1129:15:
error: 'const struct basic_block_def' has no member named 'flags'
return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1129:38:
error: 'const struct basic_block_def' has no member named 'il'
In function 'bb_seq_addr':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1135:15:
error: 'struct basic_block_def' has no member named 'flags'
return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL;
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1135:39:
error: 'struct basic_block_def' has no member named 'il'
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gcc-plugin.h:28:0,
from conftest.c:78:
In function 'set_bb_seq':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1143:28:
gcc_checking_assert (!(bb->flags & BB_RTL));
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/system.h:697:49:
note: in definition of macro 'gcc_checking_assert'
#define gcc_checking_assert(EXPR) ((void)(0 && (EXPR)))
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1144:5:
bb->il.gimple.seq = seq;
In function 'block_in_transaction':
/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include/gimple.h:1598:23:
return flag_tm && bb->flags & BB_IN_TRANSACTION;
conftest.c: At top level:
conftest.c:83:45: warning: missing terminating ' character [enabled by
default]
Beware, this compiler is a fake. Don't use it.
conftest.c: In function 'foo':
conftest.c:94:10: warning: return makes pointer from integer without a cast
return lookup_name (get_identifier ("puts"));
configure:29583: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.1.5"
| #define PACKAGE_STRING "StarPU 1.1.5"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 1
| #define STARPU_RELEASE_VERSION 5
| #define PACKAGE "starpu"
| #define VERSION "1.1.5"
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| #define restrict __restrict
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/home/pruvost/work/svnwc/starpu-1.1/build"
| #define STARPU_SRC_DIR "/home/pruvost/work/svnwc/starpu-1.1/build/.."
| #define HAVE_LIBPTHREAD 1
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 1
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #define STARPU_USE_MPI /**/
| /* end confdefs.h. */
| #include <gcc-plugin.h>
| #include <tree.h>
| #include <gimple.h>
| #if defined __INTEL_COMPILER || defined __ICC
| #endif
| tree fndecl; gimple call;
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| discriminate it this way. */
| tree foo (void)
| fndecl = foo ();
| call = gimple_build_call (fndecl, 0);
| return 0;
configure:29599: result: no
configure:29883: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in
will not be built
configure:30021: checking for SOCL
configure:30036: result: no
configure:30085: checking for gdb
configure:30103: found /usr/bin/gdb
configure:30116: result: /usr/bin/gdb
configure:30328: checking whether OpenGL rendering is enabled
configure:30332: result: no
configure:30343: checking for X
configure:30451: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
configure:30451: $? = 0
configure:30482: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lX11 -lrt -lm -lpthread >&5
configure:30482: $? = 0
configure:30532: result: libraries , headers
configure:30631: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread -lX11 >&5
configure:30631: $? = 0
configure:30729: checking for gethostbyname
configure:30729: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
configure:30729: $? = 0
configure:30729: result: yes
configure:30826: checking for connect
configure:30826: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
configure:30826: $? = 0
configure:30826: result: yes
configure:30875: checking for remove
configure:30875: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
configure:30875: $? = 0
configure:30875: result: yes
configure:30924: checking for shmat
configure:30924: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
configure:30924: $? = 0
configure:30924: result: yes
configure:30982: checking for IceConnectionNumber in -lICE
configure:31007: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lICE -lrt -lm -lpthread >&5
configure:31007: $? = 0
configure:31016: result: yes
configure:31465: checking for library containing sgemm_
configure:31496: /cm/shared/apps/gcc/4.8.4/bin/gcc -o conftest -O3 -g -O2
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5
/tmp/cchtrwid.o: In function `main':
/home/pruvost/work/svnwc/starpu-1.1/build/conftest.c:91: undefined reference
to `sgemm_'
collect2: error: ld returned 1 exit status
configure:31496: $? = 1
| /* confdefs.h */
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #define STARPU_GDB_PATH "/usr/bin/gdb"
| #define STARPU_HAVE_X11 1
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
-gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lblas >&5
configure:31496: $? = 0
configure:31513: result: -lblas
configure:31584: checking which BLAS lib should be used
configure:31586: result: system
configure:31610: checking for FFTW
configure:31618: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
No package 'fftw3' found
configure:31621: $? = 1
configure:31636: $PKG_CONFIG --exists --print-errors "fftw3"
configure:31639: $? = 1
configure:31667: result: no
configure:31697: checking for FFTWF
configure:31705: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:31708: $? = 1
configure:31723: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:31726: $? = 1
configure:31754: result: no
configure:31784: checking for FFTWL
configure:31792: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:31795: $? = 1
configure:31810: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:31813: $? = 1
configure:31841: result: no
configure:31937: checking for HWLOC
configure:31945: $PKG_CONFIG --exists --print-errors "hwloc"
configure:31948: $? = 0
configure:31963: $PKG_CONFIG --exists --print-errors "hwloc"
configure:31966: $? = 0
configure:32006: result: yes
configure:32095: checking whether hwloc should be used
configure:32097: result: yes
configure:32102: checking f77.h usability
configure:32102: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
conftest.c:115:17: fatal error: f77.h: No such file or directory
#include <f77.h>
compilation terminated.
configure:32102: $? = 1
| /* confdefs.h */
| #define STARPU_SYSTEM_BLAS 1
| #define STARPU_HAVE_HWLOC 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <f77.h>
configure:32102: result: no
configure:32102: checking f77.h presence
configure:32102: /cm/shared/apps/gcc/4.8.4/bin/gcc -E -D_GNU_SOURCE
conftest.c
conftest.c:82:17: fatal error: f77.h: No such file or directory
#include <f77.h>
| /* confdefs.h */
| #define STARPU_HAVE_SCHED_YIELD 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #include <f77.h>
configure:32102: checking for f77.h
configure:32131: checking for icc
configure:32161: result: no
configure:32243: checking for help2man
configure:32273: result: no
configure:32294: checking for struct cudaDeviceProp.pciDomainID
configure:32294: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
conftest.c:83:30: fatal error: cuda_runtime_api.h: No such file or directory
#include <cuda_runtime_api.h>
configure:32294: $? = 1
| /* confdefs.h */
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_NMAX_COMBINEDWORKERS 128
| #define STARPU_MAXCUDADEVS 4
| #define STARPU_HAVE_FC /**/
| int
| main ()
| static struct cudaDeviceProp ac_aggr;
| if (ac_aggr.pciDomainID)
| return 0;
| return 0;
| /* confdefs.h */
| int
| main ()
| if (sizeof ac_aggr.pciDomainID)
| return 0;
| return 0;
configure:32294: result: no
configure:32303: checking for struct cudaDeviceProp.pciBusID
configure:32303: /cm/shared/apps/gcc/4.8.4/bin/gcc -c -O3 -g -O2 -gdwarf-2
configure:32303: $? = 1
| /* confdefs.h */
| int
| main ()
| if (ac_aggr.pciBusID)
| return 0;
| return 0;
| /* confdefs.h */
| int
| main ()
| if (sizeof ac_aggr.pciBusID)
| return 0;
| return 0;
configure:32303: result: no
configure:32337: checking for doxygen
configure:32370: result: no
configure:32388: checking for pdflatex
configure:32421: result: no
configure:32431: checking for epstopdf
configure:32464: result: no
configure:32473: checking whether documentation should be compiled
configure:32475: result: no
configure:32650: checking that generated files are newer than configure
configure:32656: result: done
configure:32863: creating ./config.status
## Running config.status. ##
This file was extended by StarPU config.status 1.1.5, which was
generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on devel11
config.status:1587: creating tests/regression/regression.sh
config.status:1587: creating tests/regression/profiles
config.status:1587: creating tests/regression/profiles.build.only
config.status:1587: creating Makefile
config.status:1587: creating src/Makefile
config.status:1587: creating tools/Makefile
config.status:1587: creating tools/starpu_codelet_profile
config.status:1587: creating tools/starpu_codelet_histo_profile
config.status:1587: creating tools/starpu_workers_activity
config.status:1587: creating tools/starpu_paje_draw_histogram
config.status:1587: creating tools/starpu_paje_state_stats
config.status:1587: creating tools/starpu_paje_summary
config.status:1587: creating tools/starpu_paje_sort
config.status:1587: creating socl/Makefile
config.status:1587: creating socl/src/Makefile
config.status:1587: creating socl/examples/Makefile
config.status:1587: creating socl/vendors/socl.icd
config.status:1587: creating socl/vendors/install/socl.icd
config.status:1587: creating libstarpu.pc
config.status:1587: creating starpu-1.0.pc
config.status:1587: creating starpu-1.1.pc
config.status:1587: creating mpi/libstarpumpi.pc
config.status:1587: creating mpi/starpumpi-1.0.pc
config.status:1587: creating mpi/starpumpi-1.1.pc
config.status:1587: creating starpufft/Makefile
config.status:1587: creating starpufft/src/Makefile
config.status:1587: creating starpufft/tests/Makefile
config.status:1587: creating starpufft/libstarpufft.pc
config.status:1587: creating starpufft/starpufft-1.0.pc
config.status:1587: creating starpufft/starpufft-1.1.pc
config.status:1587: creating examples/Makefile
config.status:1587: creating examples/stencil/Makefile
config.status:1587: creating tests/Makefile
config.status:1587: creating mpi/Makefile
config.status:1587: creating mpi/src/Makefile
config.status:1587: creating mpi/tests/Makefile
config.status:1587: creating mpi/examples/Makefile
config.status:1587: creating starpu-top/StarPU-Top.pro
config.status:1587: creating starpu-top/StarPU-Top-qwt-embed.pri
config.status:1587: creating starpu-top/StarPU-Top-qwt-system.pri
config.status:1587: creating gcc-plugin/Makefile
config.status:1587: creating gcc-plugin/src/Makefile
config.status:1587: creating gcc-plugin/tests/Makefile
config.status:1587: creating gcc-plugin/tests/run-test
config.status:1587: creating gcc-plugin/examples/Makefile
config.status:1587: creating sc_hypervisor/Makefile
config.status:1587: creating sc_hypervisor/src/Makefile
config.status:1587: creating sc_hypervisor/examples/Makefile
config.status:1587: creating doc/Makefile
config.status:1587: creating doc/doxygen/Makefile
config.status:1587: creating doc/doxygen/doxygen-config.cfg
config.status:1587: creating doc/doxygen/doxygen_filter.sh
config.status:1587: creating tools/mvsc/starpu_var.bat
config.status:1587: creating src/common/config.h
config.status:1587: creating include/starpu_config.h
config.status:1587: creating gcc-plugin/include/starpu-gcc/config.h
config.status:1587: creating starpu-top/config.h
config.status:1832: executing depfiles commands
config.status:1832: executing libtool commands
config.status:1832: executing executable-scripts commands
configure:35983:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 0
Maximum number of OpenCL devices: 0
Maximum number of memory nodes: 1
Maximum number of task buffers: 8
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: system
hwloc: yes
FxT trace enabled: yes
StarPU-Top: no
Documentation: no
Examples: yes
StarPU Extensions:
MPI enabled: yes
MPI test suite: no
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
SOCL enabled: no
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: no
ayudame enabled: no
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_c_restrict=__restrict
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_BLAS_LIBS_set=
ac_cv_env_BLAS_LIBS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=/cm/shared/apps/gcc/4.8.4/bin/gcc
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=/cm/shared/apps/gcc/4.8.4/bin/g++
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=set
ac_cv_env_FC_value=/cm/shared/apps/gcc/4.8.4/bin/gfortran
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FFTWF_CFLAGS_set=
ac_cv_env_FFTWF_CFLAGS_value=
ac_cv_env_FFTWF_LIBS_set=
ac_cv_env_FFTWF_LIBS_value=
ac_cv_env_FFTWL_CFLAGS_set=
ac_cv_env_FFTWL_CFLAGS_value=
ac_cv_env_FFTWL_LIBS_set=
ac_cv_env_FFTWL_LIBS_value=
ac_cv_env_FFTW_CFLAGS_set=
ac_cv_env_FFTW_CFLAGS_value=
ac_cv_env_FFTW_LIBS_set=
ac_cv_env_FFTW_LIBS_value=
ac_cv_env_FXT_CFLAGS_set=
ac_cv_env_FXT_CFLAGS_value=
ac_cv_env_FXT_LDFLAGS_set=
ac_cv_env_FXT_LDFLAGS_value=
ac_cv_env_FXT_LIBS_set=
ac_cv_env_FXT_LIBS_value=
ac_cv_env_HWLOC_CFLAGS_set=
ac_cv_env_HWLOC_CFLAGS_value=
ac_cv_env_HWLOC_LIBS_set=
ac_cv_env_HWLOC_LIBS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MAGMA_CFLAGS_set=
ac_cv_env_MAGMA_CFLAGS_value=
ac_cv_env_MAGMA_LIBS_set=
ac_cv_env_MAGMA_LIBS_value=
ac_cv_env_NVCCFLAGS_set=
ac_cv_env_NVCCFLAGS_value=
ac_cv_env_NVCC_set=
ac_cv_env_NVCC_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_POTI_CFLAGS_set=
ac_cv_env_POTI_CFLAGS_value=
ac_cv_env_POTI_LIBS_set=
ac_cv_env_POTI_LIBS_value=
ac_cv_env_STARPU_MS_LIB_set=
ac_cv_env_STARPU_MS_LIB_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=yes
ac_cv_fc_compiler_gnu=yes
ac_cv_func_clock_gettime=yes
ac_cv_func_connect=yes
ac_cv_func_drand48=yes
ac_cv_func_enable_fut_flush=yes
ac_cv_func_erand48_r=yes
ac_cv_func_fut_set_filename=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_memalign=yes
ac_cv_func_nearbyintf=yes
ac_cv_func_posix_memalign=yes
ac_cv_func_pthread_barrier_init=yes
ac_cv_func_pthread_setaffinity_np=yes
ac_cv_func_pthread_spin_lock=yes
ac_cv_func_remove=yes
ac_cv_func_rintf=yes
ac_cv_func_sched_yield=yes
ac_cv_func_setenv=yes
ac_cv_func_shmat=yes
ac_cv_func_strerror_r=yes
ac_cv_func_sysconf=yes
ac_cv_func_unsetenv=yes
ac_cv_have_decl_enable_fut_flush=no
ac_cv_have_decl_fut_set_filename=no
ac_cv_have_gcc_plugins=no
ac_cv_have_sync_bool_compare_and_swap=yes
ac_cv_have_sync_fetch_and_add=yes
ac_cv_have_sync_fetch_and_or=yes
ac_cv_have_sync_lock_test_and_set=yes
ac_cv_have_sync_synchronize=yes
ac_cv_have_sync_val_compare_and_swap=yes
ac_cv_have_x='have_x=yes ac_x_includes='\'''\''
ac_x_libraries='\'''\'''
ac_cv_header_Ayudame_h=no
ac_cv_header_dlfcn_h=yes
ac_cv_header_f77_h=no
ac_cv_header_glpk_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_malloc_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_valgrind_helgrind_h=no
ac_cv_header_valgrind_valgrind_h=no
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_ICE_IceConnectionNumber=yes
ac_cv_lib_glpk_main=no
ac_cv_lib_pthread_pthread_create=yes
ac_cv_lib_rt_clock_gettime=yes
ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=no
ac_cv_member_struct_cudaDeviceProp_pciBusID=no
ac_cv_member_struct_cudaDeviceProp_pciDomainID=no
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_FGREP='/usr/bin/grep -F'
ac_cv_path_GDB=/usr/bin/gdb
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_SED=/usr/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_path_mpicc_path=/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc
ac_cv_path_mpiexec_path=/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec
ac_cv_path_svncommand=/usr/bin/svn
ac_cv_path_svnversioncommand=/usr/bin/svnversion
ac_cv_prog_AWK=gawk
ac_cv_prog_BASH=/bin/sh
ac_cv_prog_CPP='/cm/shared/apps/gcc/4.8.4/bin/gcc -E'
ac_cv_prog_CXXCPP='/cm/shared/apps/gcc/4.8.4/bin/g++ -E'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=/cm/shared/apps/gcc/4.8.4/bin/gcc
ac_cv_prog_ac_ct_F77=gfortran
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc__cm_shared_apps_gcc_4_8_4_bin_gcc_c_o=yes
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_fc_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_set_mempolicy=no
ac_cv_search_sgemm_=-lblas
ac_cv_search_sqrt=-lm
ac_cv_sizeof_void_p=8
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_cufftDoubleComplex=no
ac_cv_type_struct_timespec=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_ar_interface=ar
am_cv_make_support_nested_variables=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_c_o_FC=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=-fPIC
lt_cv_prog_compiler_pic_FC=-fPIC
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_pic_works_F77=yes
lt_cv_prog_compiler_pic_works_FC=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=no
lt_cv_prog_compiler_static_works_CXX=no
lt_cv_prog_compiler_static_works_F77=no
lt_cv_prog_compiler_static_works_FC=no
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[
]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][
]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/
{\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/
{"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^
]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\)
\(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^
]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int
\1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=1572864
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
pkg_cv_FXT_CFLAGS='-I/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/fxt-0.3.1-si37ytj7fcck5e3pofxfvhdpblwn36if/include
pkg_cv_FXT_LIBS='-L/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/fxt-0.3.1-si37ytj7fcck5e3pofxfvhdpblwn36if/lib
-lfxt '
pkg_cv_HWLOC_CFLAGS='-I/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/hwloc-1.11.0-qvittohbef74co345dlmixnbzkzpkrs6/include
-I/usr/include/libxml2 '
pkg_cv_HWLOC_LIBS='-L/home/pruvost/work/git/spack-llnl-fpruvost/opt/spack/unknown_arch/gcc-4.8.4/hwloc-1.11.0-qvittohbef74co345dlmixnbzkzpkrs6/lib
-lhwloc '
## Output variables. ##
ACLOCAL='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing
aclocal-1.13'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='0'
AM_V='$(V)'
AR='ar'
AS='as'
ATLASDIR=''
ATLAS_BLAS_LIB_FALSE=''
ATLAS_BLAS_LIB_TRUE='#'
AUTOCONF='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing
autoconf'
AUTOHEADER='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing
autoheader'
AUTOMAKE='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing
automake-1.13'
AWK='gawk'
BASH='/bin/sh'
BLAS_LIB='system'
BLAS_LIBS=''
BUILD_DOC_FALSE=''
BUILD_DOC_TRUE='#'
BUILD_EXAMPLES_FALSE='#'
BUILD_EXAMPLES_TRUE=''
BUILD_GCC_PLUGIN_FALSE=''
BUILD_GCC_PLUGIN_TRUE='#'
BUILD_SOCL_FALSE=''
BUILD_SOCL_TRUE='#'
BUILD_STARPUFFT_EXAMPLES_FALSE=''
BUILD_STARPUFFT_EXAMPLES_TRUE='#'
BUILD_STARPUFFT_FALSE=''
BUILD_STARPUFFT_TRUE='#'
BUILD_STARPU_TOP_FALSE=''
BUILD_STARPU_TOP_TRUE='#'
CC='/cm/shared/apps/gcc/4.8.4/bin/gcc'
CCDEPMODE='depmode=gcc3'
CC_OR_MPICC='/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc'
CFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
COVERAGE='no'
CPPFLAGS=' -D_GNU_SOURCE '
CXX='/cm/shared/apps/gcc/4.8.4/bin/g++'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
CYGPATH_W='echo'
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DLLTOOL='false'
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
F77='gfortran'
FC='/cm/shared/apps/gcc/4.8.4/bin/gfortran'
FCFLAGS='-g -O2'
FFLAGS='-g -O2'
FFTWF_CFLAGS=''
FFTWF_LIBS=''
FFTWL_CFLAGS=''
FFTWL_LIBS=''
FFTW_CFLAGS=''
FFTW_LIBS=''
FXTDIR=''
FXT_LDFLAGS=''
-lfxt '
GCC_FOR_PLUGIN=''
GCC_FOR_PLUGIN_LIBTOOL_TAG=''
GCC_PLUGIN_DIR_PKGCONFIG=''
GCC_PLUGIN_INCLUDE_DIR='/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/plugin/include'
GCC_PLUGIN_PKGCONFIG=''
GDB='/usr/bin/gdb'
GLOBAL_AM_CFLAGS=' -Wall -Werror=implicit
-Werror=implicit-function-declaration'
GOTODIR=''
GOTO_BLAS_LIB_FALSE=''
GOTO_BLAS_LIB_TRUE='#'
GREP='/usr/bin/grep'
GUILE=''
HAVE_FFTWFL=''
HAVE_OPENGL_FALSE=''
HAVE_OPENGL_TRUE='#'
HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=''
HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE='#'
HAVE_X11_FALSE='#'
HAVE_X11_TRUE=''
HELP2MAN=''
-lhwloc '
HWLOC_REQUIRES='hwloc'
ICC=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS=''
LIBOBJS=''
LIBS='-lrt -lm -lpthread '
LIBSOCL_INTERFACE_AGE='0'
LIBSOCL_INTERFACE_CURRENT='1'
LIBSOCL_INTERFACE_REVISION='1'
LIBSTARPUFFT_INTERFACE_AGE='0'
LIBSTARPUFFT_INTERFACE_CURRENT='1'
LIBSTARPUFFT_INTERFACE_REVISION='1'
LIBSTARPUMPI_INTERFACE_AGE='0'
LIBSTARPUMPI_INTERFACE_CURRENT='2'
LIBSTARPUMPI_INTERFACE_REVISION='3'
LIBSTARPU_INTERFACE_AGE='1'
LIBSTARPU_INTERFACE_CURRENT='8'
LIBSTARPU_INTERFACE_REVISION='0'
LIBSTARPU_LDFLAGS=' '
LIBSTARPU_LINK='libstarpu-1.1.la'
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAGMA_CFLAGS=''
MAGMA_LIBS=''
MAKEINFO='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing
makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/usr/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=''
MKL_BLAS_LIB_TRUE='#'
MPICC_LDFLAGS='-pthread -Wl,-rpath -Wl,/cm/shared/apps/openmpi/gcc//1.8.4/lib
-Wl,--enable-new-dtags -L/cm/shared/apps/openmpi/gcc//1.8.4/lib -lmpi'
MPIEXEC='/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec'
NM='/usr/bin/nm -B'
NMEDIT=''
NO_BLAS_LIB_FALSE=''
NO_BLAS_LIB_TRUE='#'
NVCC=''
NVCCFLAGS=''
OBJDUMP='objdump'
OBJEXT='o'
OTOOL64=''
OTOOL=''
PACKAGE='starpu'
PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME='StarPU'
PACKAGE_STRING='StarPU 1.1.5'
PACKAGE_TARNAME='starpu'
PACKAGE_URL='http://runtime.bordeaux.inria.fr/StarPU/'
PACKAGE_VERSION='1.1.5'
PATH_SEPARATOR=':'
PKG_CONFIG='/usr/bin/pkg-config'
POTI_CFLAGS=''
POTI_LIBS=''
QMAKE='not-found'
QWT_PRI=''
RANLIB='ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=''
RUN_GCC_PLUGIN_TESTS_TRUE='#'
SED='/usr/bin/sed'
SET_MAKE=''
SHELL='/bin/sh'
SIMGRID_CFLAGS=''
SIMGRID_LIBS=''
SOCL_OCL_LIB_OPENCL_DIR=''
SOCL_VENDORS='vendors/install/socl.icd'
STARPU_BLAS_LDFLAGS=' -lblas '
STARPU_BUILD_DIR='/home/pruvost/work/svnwc/starpu-1.1/build'
STARPU_BUILD_SC_HYPERVISOR_FALSE=''
STARPU_BUILD_SC_HYPERVISOR_TRUE='#'
STARPU_COVERAGE_ENABLED_FALSE=''
STARPU_COVERAGE_ENABLED_TRUE='#'
STARPU_CUDA_CPPFLAGS=''
STARPU_CUDA_FORTRAN_LDFLAGS=''
STARPU_CUDA_LDFLAGS=''
STARPU_CUFFT_LDFLAGS=''
STARPU_CURAND_LDFLAGS=''
STARPU_DEVEL_FALSE=''
STARPU_DEVEL_TRUE='#'
STARPU_EFFECTIVE_VERSION='1.1'
STARPU_ENABLE_STATS='no'
STARPU_GCC_VERSION_MAJOR=''
STARPU_GCC_VERSION_MINOR=''
STARPU_GLPK_LDFLAGS=' '
STARPU_HAVE_AM111_FALSE='#'
STARPU_HAVE_AM111_TRUE=''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE='#'
STARPU_HAVE_F77_H='no'
STARPU_HAVE_F77_H_FALSE=''
STARPU_HAVE_F77_H_TRUE='#'
STARPU_HAVE_FC_FALSE='#'
STARPU_HAVE_FC_TRUE=''
STARPU_HAVE_FFTW=''
STARPU_HAVE_FFTWF=''
STARPU_HAVE_FFTWF_FALSE=''
STARPU_HAVE_FFTWF_TRUE='#'
STARPU_HAVE_FFTWL_FALSE=''
STARPU_HAVE_FFTWL_TRUE='#'
STARPU_HAVE_FFTW_FALSE=''
STARPU_HAVE_FFTW_TRUE='#'
STARPU_HAVE_HELP2MAN_FALSE=''
STARPU_HAVE_HELP2MAN_TRUE='#'
STARPU_HAVE_HWLOC='1'
STARPU_HAVE_ICC_FALSE=''
STARPU_HAVE_ICC_TRUE='#'
STARPU_HAVE_MAGMA=''
STARPU_HAVE_MAGMA_FALSE=''
STARPU_HAVE_MAGMA_TRUE='#'
STARPU_HAVE_MS_LIB_FALSE=''
STARPU_HAVE_MS_LIB_TRUE='#'
STARPU_HAVE_WINDOWS_FALSE=''
STARPU_HAVE_WINDOWS_TRUE='#'
STARPU_LIBNUMA_LDFLAGS=' '
STARPU_LONG_CHECK_FALSE=''
STARPU_LONG_CHECK_TRUE='#'
STARPU_MAJOR_VERSION='1'
STARPU_MINOR_VERSION='1'
STARPU_MPI_CHECK_FALSE=''
STARPU_MPI_CHECK_TRUE='#'
STARPU_MS_LIB=''
STARPU_MS_LIB_ARCH='X64'
STARPU_OPENCL_CPPFLAGS=''
STARPU_OPENCL_DATAdir=''
STARPU_OPENCL_LDFLAGS=''
STARPU_OPENGL_RENDER='no'
STARPU_OPENGL_RENDER_LDFLAGS=''
STARPU_PERF_DEBUG='no'
STARPU_QUICK_CHECK_FALSE=''
STARPU_QUICK_CHECK_TRUE='#'
STARPU_QWT_INCLUDE=''
STARPU_QWT_LDFLAGS=''
STARPU_RELEASE_VERSION='5'
STARPU_SANITIZE_FALSE=''
STARPU_SANITIZE_TRUE='#'
STARPU_SC_HYPERVISOR=''
STARPU_SIMGRID_FALSE=''
STARPU_SIMGRID_TRUE='#'
STARPU_SRC_DIR='/home/pruvost/work/svnwc/starpu-1.1/build/..'
STARPU_USE_CPU='yes'
STARPU_USE_CPU_FALSE='#'
STARPU_USE_CPU_TRUE=''
STARPU_USE_CUDA='no'
STARPU_USE_CUDA_FALSE=''
STARPU_USE_CUDA_TRUE='#'
STARPU_USE_FXT='yes'
STARPU_USE_FXT_FALSE='#'
STARPU_USE_FXT_TRUE=''
STARPU_USE_OPENCL='no'
STARPU_USE_OPENCL_FALSE=''
STARPU_USE_OPENCL_TRUE='#'
STARPU_USE_SC_HYPERVISOR_FALSE=''
STARPU_USE_SC_HYPERVISOR_TRUE='#'
STARPU_USE_SOCL_FALSE=''
STARPU_USE_SOCL_TRUE='#'
STARPU_USE_TOP='no'
STATS='no'
STRIP='strip'
SYSTEM_BLAS_LIB_FALSE='#'
SYSTEM_BLAS_LIB_TRUE=''
USE_MPI='yes'
USE_MPI_FALSE='#'
USE_MPI_TRUE=''
VERSION='1.1.5'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=' -lSM -lICE'
YACC='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/missing bison'
ac_ct_AR='ar'
ac_ct_CC='/cm/shared/apps/gcc/4.8.4/bin/gcc'
ac_ct_CXX=''
ac_ct_DUMPBIN=''
ac_ct_F77='gfortran'
ac_ct_FC=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=' -I$(srcdir)'
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=''
dvidir='${docdir}'
epstopdfcommand=''
exec_prefix='${prefix}'
gccplugindir=''
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/pruvost/work/svnwc/starpu-1.1/build-aux/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
mpicc_path='/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpicc'
mpiexec_path='/cm/shared/apps/openmpi/gcc/1.8.4/bin/mpiexec'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pdflatexcommand=''
pkglibdir='${libdir}/starpu'
prefix='/home/pruvost/work/install/starpu-1.1/mpi-fxt-debug/gcc-4.8.4'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
svncommand='/usr/bin/svn'
svnversioncommand='/usr/bin/svnversion'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define STARPU_MAXOPENCLDEVS 8
#define STARPU_NON_BLOCKING_DRIVERS 1
#define STARPU_USE_FXT 1
#define CONFIG_FUT 1
#define HAVE_ENABLE_FUT_FLUSH 1
#define HAVE_FUT_SET_FILENAME 1
#define HAVE_DECL_ENABLE_FUT_FLUSH 0
#define HAVE_DECL_FUT_SET_FILENAME 0
configure: exit 0
--------------090908000307020507040009--
  • [no subject], Unknown, 16/12/2020
Haut de le page
