Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] fortran error Starpu 1.2 RC3
- Date: Mon, 3 Aug 2015 17:38:34 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
When building/testing starpu I receive the error:
FAIL: fortran90/f90_example
Direct Execution StarPU 1.2 RC3:FAIL: fortran90/f90_example
/StarPU-prefix/src/StarPU/examples/fortran90/f90_example
[starpu][_starpu_opencl_driver_init] Warning: reducing STARPU_OPENCL_PIPELINE to 0 because blocking drivers are enabled (and simgrid is not enabled)
Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
Backtrace for this error:
StarPU version: 1. 2. 0
#0 0x7F131CCA6777
#1 0x7F131CCA6D7E
#2 0x7F131C8FED3F
#3 0x7F131CFCA979
#4 0x7F131CFCCD84
#5 0x7F131CFF3DA0
#6 0x7F131D01DBDD
#7 0x7F131D01DE4C
#8 0x7F131C063181
#9 0x7F131C9C247C
#10 0xFFFFFFFFFFFFFFFF
Segmentation fault (core dumped)
#0 0x7F131CCA6777
#1 0x7F131CCA6D7E
#2 0x7F131C8FED3F
#3 0x7F131CFCA979
#4 0x7F131CFCCD84
#5 0x7F131CFF3DA0
#6 0x7F131D01DBDD
#7 0x7F131D01DE4C
#8 0x7F131C063181
#9 0x7F131C9C247C
Configuration Used:
./configure --enable-opencl --with-hwloc --enable-blocking-drivers --disable-starpu-top --with-mpicc=/invalid/mpicc --disable-socl --disable-cuda
Ways I can deal with the failure:
1. Remove fortran packages
- This works. If I needed the fortran package it would be an issue.
- I'd rather have "--disable-fortran".
2. don't use "--enable-blocking-drivers"
- I presume this isn't a good solution because of CPU utilization. Probably a symptom.
3. Trunk has Revision 15703 change for --disable-fortran
- This works when hand patched. This would require a StarPU RC4.
thanks,
Jeff
- [Starpu-devel] fortran error Starpu 1.2 RC3, Jeff Hand, 04/08/2015
- Re: [Starpu-devel] fortran error Starpu 1.2 RC3, Samuel Thibault, 04/08/2015
