Accéder au contenu.
Menu Sympa
Archives de la liste
Chronologique Discussions
502.20758.2.7/sbin
PATH: /opt/cray/lustre-cray_ari_s/2.5_3.0.101_0.46.1_1.0502.8871.15.1-1.0=
502.20758.2.7/bin
PATH: /opt/cray/sdb/1.1-1.0502.63652.4.25.ari/bin
PATH: /opt/cray/nodestat/2.2-1.0502.60539.1.31.ari/bin
PATH: /opt/modules/3.2.10.3/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/bin/X11
PATH: /usr/X11R6/bin
PATH: /usr/games
PATH: /usr/lib/mit/bin
PATH: /usr/lib/mit/sbin
PATH: .
PATH: /usr/lib/qt3/bin
PATH: /opt/cray/bin
PATH: /project/k1044/favergm/opt/hwloc-1.11.1/bin
PATH: /project/k1044/favergm/opt/plasma-2.7.1/bin
## Core tests. ##
configure:3564: checking build system type
configure:3578: result: x86_64-unknown-linux-gnu
configure:3598: checking host system type
configure:3611: result: x86_64-unknown-linux-gnu
configure:3631: checking target system type
configure:3644: result: x86_64-unknown-linux-gnu
configure:3688: checking for a BSD-compatible install
configure:3756: result: /usr/bin/install -c
configure:3767: checking whether build environment is sane
configure:3822: result: yes
configure:3973: checking for a thread-safe mkdir -p
configure:4012: result: /bin/mkdir -p
configure:4019: checking for gawk
configure:4035: found /usr/bin/gawk
configure:4046: result: gawk
configure:4057: checking whether make sets $(MAKE)
configure:4079: result: yes
configure:4108: checking whether make supports nested variables
configure:4125: result: yes
configure:4263: checking whether make supports nested variables
configure:4280: result: yes
configure:4306: checking for style of include used by make
configure:4334: result: GNU
configure:4405: checking for gcc
configure:4432: result: cc
configure:4661: checking for C compiler version
configure:4670: cc --version >&5
gcc (GCC) 4.9.3 20150626 (Cray Inc.)
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is N=
O
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOS=
E.
configure:4681: $? =3D 0
configure:4670: cc -v >&5
Using built-in specs.
COLLECT_GCC=3D/opt/gcc/4.9.3/bin/../snos/bin/gcc
COLLECT_LTO_WRAPPER=3D/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4=
=2E9.3/lto-wrapper
Target: x86_64-suse-linux
Configured with: ../cray-gcc-4.9.3/configure --prefix=3D/opt/gcc/4.9.3/sn=
os --disable-nls --libdir=3D/opt/gcc/4.9.3/snos/lib --enable-languages=3D=
c,c++,fortran --with-gxx-include-dir=3D/opt/gcc/4.9.3/snos/include/g++ --=
with-slibdir=3D/opt/gcc/4.9.3/snos/lib --with-system-zlib --enable-shared=
--enable-__cxa_atexit --build=3Dx86_64-suse-linux --with-ppl --with-cloo=
g
Thread model: posix
gcc version 4.9.3 20150626 (Cray Inc.) (GCC)=20
COMPILER_PATH=3D/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4.9.3/:=
/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4.9.3/:/opt/gcc/4.9.3/s=
nos/libexec/gcc/x86_64-suse-linux/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-sus=
e-linux/4.9.3/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/
LIBRARY_PATH=3D/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/:/opt/=
gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/../../../../lib64/:/lib/..=
/lib64/:/usr/lib/../lib64/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/=
4.9.3/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS=3D'-march=3Dcore-avx2' '-D' '__CRAYXC' '-D' '__CRAY_H=
ASWELL' '-D' '__CRAYXT_COMPUTE_LINUX_TARGET' '-D' '__TARGET_LINUX__' '-v'=
'-I' '/opt/cray/libsci/13.1.0/GNU/4.9/x86_64/include' '-I' '/opt/cray/mp=
t/7.2.4/gni/mpich2-gnu/4.9/include' '-I' '/opt/cray/pmi/5.0.8-1.0000.1084=
3.170.1.ari/include' '-I' '/opt/cray/datawarp/1.0-1.0502.65549.14.21.ari/=
include' '-I' '/opt/cray/wlm_detect/1.0-1.0502.64649.2.1.ari/include' '-I=
' '/opt/cray/krca/1.0.0-2.0502.63139.4.31.ari/include' '-I' '/opt/cray/xp=
mem/0.1-2.0502.64982.5.3.ari/include' '-I' '/opt/cray/gni-headers/4.0-1.0=
502.10859.7.8.ari/include' '-I' '/opt/cray/ugni/6.0-1.0502.10863.8.29.ari=
/include' '-I' '/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/include' '-I'=
'/opt/cray/alps/5.2.4-2.0502.9822.32.1.ari/include' '-I' '/opt/cray/rca/=
1.0.0-2.0502.60530.1.62.ari/include' '-I' '/opt/cray-hss-devel/7.2.0/incl=
ude' '-L/opt/cray/libsci/13.1.0/GNU/4.9/x86_64/lib' '-L/opt/cray/dmapp/de=
fault/lib64' '-L/opt/cray/mpt/7.2.4/gni/mpich2-gnu/4.9/lib' '-L/opt/cray/=
datawarp/1.0-1.0502.65549.14.21.ari/lib64' '-L/opt/cray/atp/1.8.3/libApp'=
=2E.. rest of stderr output deleted ...
configure:4681: $? =3D 1
configure:4670: cc -V >&5
gcc: error: unrecognized command line option '-V'
configure:4670: cc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:4701: checking whether the C compiler works
configure:4723: cc conftest.c >&5
configure:4727: $? =3D 0
configure:4775: result: yes
configure:4778: checking for C compiler default output file name
configure:4780: result: a.out
configure:4786: checking for suffix of executables
configure:4793: cc -o conftest conftest.c >&5
configure:4797: $? =3D 0
configure:4819: result:=20
configure:4841: checking whether we are cross compiling
configure:4849: cc -o conftest conftest.c >&5
configure:4853: $? =3D 0
configure:4860: ./conftest
configure:4864: $? =3D 0
configure:4879: result: no
configure:4884: checking for suffix of object files
configure:4906: cc -c conftest.c >&5
configure:4910: $? =3D 0
configure:4931: result: o
configure:4935: checking whether we are using the GNU C compiler
configure:4954: cc -c conftest.c >&5
configure:4954: $? =3D 0
configure:4963: result: yes
configure:4972: checking whether cc accepts -g
configure:4992: cc -c -g conftest.c >&5
configure:4992: $? =3D 0
configure:5033: result: yes
configure:5050: checking for cc option to accept ISO C89
configure:5113: cc -c -g -O2 conftest.c >&5
configure:5113: $? =3D 0
configure:5126: result: none needed
configure:5151: checking whether cc understands -c and -o together
configure:5173: cc -c conftest.c -o conftest2.o
configure:5176: $? =3D 0
configure:5188: result: yes
configure:5207: checking dependency style of cc
configure:5318: result: gcc3
configure:5383: checking for ar
configure:5399: found /usr/bin/ar
configure:5410: result: ar
configure:5436: checking the archiver (ar) interface
configure:5452: cc -c -g -O2 conftest.c >&5
configure:5452: $? =3D 0
configure:5454: ar cru libconftest.a conftest.o >&5
configure:5457: $? =3D 0
configure:5485: result: ar
configure:5553: checking for gcc
configure:5580: result: cc
configure:5809: checking for C compiler version
configure:5818: cc --version >&5
O
E.
configure:5829: $? =3D 0
configure:5818: cc -v >&5
=2E9.3/lto-wrapper
g
Thread model: posix
configure:5829: $? =3D 1
configure:5818: cc -V >&5
configure:5818: cc -qversion >&5
configure:5833: checking whether we are using the GNU C compiler
configure:5861: result: yes
configure:5870: checking whether cc accepts -g
configure:5931: result: yes
configure:5948: checking for cc option to accept ISO C89
configure:6024: result: none needed
configure:6049: checking whether cc understands -c and -o together
configure:6086: result: yes
configure:6105: checking dependency style of cc
configure:6216: result: gcc3
configure:6344: checking for C++ compiler version
configure:6353: CC --version >&5
g++ (GCC) 4.9.3 20150626 (Cray Inc.)
O
E.
configure:6364: $? =3D 0
configure:6353: CC -v >&5
COLLECT_GCC=3D/opt/gcc/4.9.3/bin/../snos/bin/g++
=2E9.3/lto-wrapper
g
Thread model: posix
dmapp/default/lib64' '-L/opt/cray/mpt/7.2.4/gni/mpich2-gnu/4.9/lib' '-L/o=
pt/cray/datawarp/1.0-1.0502.65549.14.21.ari/lib64' '-L/opt/cray/atp/1.8.3=
/libApp' '-shared-libgcc'
configure:6364: $? =3D 1
configure:6353: CC -V >&5
g++: error: unrecognized command line option '-V'
configure:6353: CC -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:6368: checking whether we are using the GNU C++ compiler
configure:6387: CC -c conftest.cpp >&5
configure:6387: $? =3D 0
configure:6396: result: yes
configure:6405: checking whether CC accepts -g
configure:6425: CC -c -g conftest.cpp >&5
configure:6425: $? =3D 0
configure:6466: result: yes
configure:6491: checking dependency style of CC
configure:6602: result: gcc3
configure:6622: checking how to run the C preprocessor
configure:6653: cc -E conftest.c
configure:6653: $? =3D 0
configure:6667: cc -E conftest.c
conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or director=
y
#include <ac_nonexistent.h>
compilation terminated.
configure:6667: $? =3D 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.2.0rc4"
| #define PACKAGE_STRING "StarPU 1.2.0rc4"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 2
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.2.0rc4"
| /* end confdefs.h. */
configure:6692: result: cc -E
configure:6712: cc -E conftest.c
configure:6712: $? =3D 0
configure:6726: cc -E conftest.c
y
configure:6726: $? =3D 1
| /* confdefs.h */
configure:6754: checking for a sed that does not truncate output
configure:6818: result: /usr/bin/sed
configure:6823: checking whether ln -s works
configure:6827: result: yes
configure:6887: checking for g77
configure:6917: result: no
configure:6887: checking for xlf
configure:6887: checking for f77
configure:6887: checking for frt
configure:6887: checking for pgf77
configure:6887: checking for cf77
configure:6887: checking for fort77
configure:6887: checking for fl32
configure:6887: checking for af77
configure:6887: checking for xlf90
configure:6887: checking for f90
configure:6887: checking for pgf90
configure:6887: checking for pghpf
configure:6887: checking for epcf90
configure:6887: checking for gfortran
configure:6903: found /opt/gcc/4.9.3/bin/gfortran
configure:6914: result: gfortran
configure:6940: checking for Fortran 77 compiler version
configure:6949: gfortran --version >&5
GNU Fortran (GCC) 4.9.3 20150626 (Cray Inc.)
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:6960: $? =3D 0
configure:6949: gfortran -v >&5
COLLECT_GCC=3D/opt/gcc/4.9.3/bin/../snos/bin/gfortran
=2E9.3/lto-wrapper
g
Thread model: posix
configure:6949: gfortran -V >&5
gfortran: error: unrecognized command line option '-V'
gfortran: fatal error: no input files
configure:6960: $? =3D 1
configure:6949: gfortran -qversion >&5
gfortran: error: unrecognized command line option '-qversion'
configure:6969: checking whether we are using the GNU Fortran 77 compiler=
configure:6982: gfortran -c conftest.F >&5
configure:6982: $? =3D 0
configure:6991: result: yes
configure:6997: checking whether gfortran accepts -g
configure:7008: gfortran -c -g conftest.f >&5
configure:7008: $? =3D 0
configure:7016: result: yes
configure:7151: checking for Fortran compiler version
configure:7160: ftn --version >&5
configure:7171: $? =3D 0
configure:7160: ftn -v >&5
=2E9.3/lto-wrapper
g
Thread model: posix
/libApp'
configure:7171: $? =3D 1
configure:7160: ftn -V >&5
configure:7160: ftn -qversion >&5
configure:7180: checking whether we are using the GNU Fortran compiler
configure:7193: ftn -c conftest.F >&5
configure:7193: $? =3D 0
configure:7202: result: yes
configure:7208: checking whether ftn accepts -g
configure:7219: ftn -c -g conftest.f >&5
configure:7219: $? =3D 0
configure:7227: result: yes
configure:7260: checking for gstat
configure:7290: result: no
configure:7260: checking for stat
configure:7276: found /usr/bin/stat
configure:7287: result: stat
configure:7302: checking for gdate
configure:7332: result: no
configure:7302: checking for date
configure:7318: found /bin/date
configure:7329: result: date
configure:7388: checking how to print strings
configure:7415: result: printf
configure:7436: checking for a sed that does not truncate output
configure:7500: result: /usr/bin/sed
configure:7518: checking for grep that handles long lines and -e
configure:7576: result: /usr/bin/grep
configure:7581: checking for egrep
configure:7643: result: /usr/bin/grep -E
configure:7648: checking for fgrep
configure:7710: result: /usr/bin/grep -F
configure:7745: checking for ld used by cc
configure:7812: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld
configure:7819: checking if the linker (/sw/xc40/xalt/0.5.4/sles11.3_gnu4=
=2E9.2/bin/ld) is GNU ld
configure:7834: result: yes
configure:7846: checking for BSD- or MS-compatible name lister (nm)
configure:7895: result: /usr/bin/nm -B
configure:8025: checking the name lister (/usr/bin/nm -B) interface
configure:8032: cc -c -g -O2 conftest.c >&5
configure:8035: /usr/bin/nm -B "conftest.o"
configure:8038: output
0000000000000000 B some_variable
configure:8045: result: BSD nm
configure:8049: checking the maximum length of command line arguments
configure:8180: result: 1572864
configure:8197: checking whether the shell understands some XSI construct=
s
configure:8207: result: yes
configure:8211: checking whether the shell understands "+=3D"
configure:8217: result: yes
configure:8252: checking how to convert x86_64-unknown-linux-gnu file nam=
es to x86_64-unknown-linux-gnu format
configure:8292: result: func_convert_file_noop
configure:8299: checking how to convert x86_64-unknown-linux-gnu file nam=
es to toolchain format
configure:8319: result: func_convert_file_noop
configure:8326: checking for /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld=
option to reload object files
configure:8333: result: -r
configure:8407: checking for objdump
configure:8423: found /usr/bin/objdump
configure:8434: result: objdump
configure:8463: checking how to recognize dependent libraries
configure:8661: result: pass_all
configure:8746: checking for dlltool
configure:8776: result: no
configure:8803: checking how to associate runtime and link libraries
configure:8830: result: printf %s\n
configure:8954: checking for archiver @FILE support
configure:8971: cc -c -g -O2 conftest.c >&5
configure:8971: $? =3D 0
configure:8974: ar cru libconftest.a @conftest.lst >&5
configure:8977: $? =3D 0
configure:8982: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:8985: $? =3D 1
configure:8997: result: @
configure:9055: checking for strip
configure:9071: found /usr/bin/strip
configure:9082: result: strip
configure:9154: checking for ranlib
configure:9170: found /usr/bin/ranlib
configure:9181: result: ranlib
configure:9283: checking command to parse /usr/bin/nm -B output from cc o=
bject
configure:9403: cc -c -g -O2 conftest.c >&5
configure:9406: $? =3D 0
configure:9410: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGI=
RSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed =
'/ __gnu_lto/d' \> conftest.nm
configure:9413: $? =3D 0
configure:9479: cc -o conftest -g -O2 conftest.c conftstm.o >&5
configure:9482: $? =3D 0
configure:9520: result: ok
configure:9557: checking for sysroot
configure:9587: result: no
configure:9664: cc -c -g -O2 conftest.c >&5
configure:9667: $? =3D 0
configure:9856: checking for mt
configure:9872: found /usr/bin/mt
configure:9883: result: mt
configure:9906: checking if mt is a manifest tool
configure:9912: mt '-?'
mt: invalid option -- ?
configure:9920: result: no
configure:10558: checking for ANSI C header files
configure:10578: cc -c -g -O2 conftest.c >&5
configure:10578: $? =3D 0
configure:10651: cc -o conftest -g -O2 conftest.c >&5
configure:10651: $? =3D 0
configure:10651: ./conftest
configure:10662: result: yes
configure:10675: checking for sys/types.h
configure:10675: cc -c -g -O2 conftest.c >&5
configure:10675: $? =3D 0
configure:10675: result: yes
configure:10675: checking for sys/stat.h
configure:10675: checking for stdlib.h
configure:10675: checking for string.h
configure:10675: checking for memory.h
configure:10675: checking for strings.h
configure:10675: checking for inttypes.h
configure:10675: checking for stdint.h
configure:10675: checking for unistd.h
configure:10689: checking for dlfcn.h
configure:10689: cc -c -g -O2 conftest.c >&5
configure:10689: $? =3D 0
configure:10689: result: yes
configure:11206: checking for objdir
configure:11221: result: .libs
configure:11492: checking if cc supports -fno-rtti -fno-exceptions
configure:11510: cc -c -g -O2 -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but=
not for C
configure:11514: $? =3D 0
configure:11527: result: no
configure:11854: checking for cc option to produce PIC
configure:11861: result: -fPIC -DPIC
configure:11869: checking if cc PIC flag -fPIC -DPIC works
configure:11887: cc -c -g -O2 -fPIC -DPIC -DPIC conftest.c >&5
configure:11891: $? =3D 0
configure:11904: result: yes
configure:11933: checking if cc static flag -static works
configure:11961: result: yes
configure:11976: checking if cc supports -c -o file.o
configure:11997: cc -c -g -O2 -o out/conftest2.o conftest.c >&5
configure:12001: $? =3D 0
configure:12023: result: yes
configure:12031: checking if cc supports -c -o file.o
configure:12078: result: yes
configure:12111: checking whether the cc linker (/sw/xc40/xalt/0.5.4/sles=
11.3_gnu4.9.2/bin/ld -m elf_x86_64) supports shared libraries
configure:13268: result: yes
configure:13305: checking whether -lc should be explicitly linked in
configure:13313: cc -c -g -O2 conftest.c >&5
configure:13316: $? =3D 0
configure:13331: cc -shared -fPIC -DPIC conftest.o -v -Wl,-soname -Wl,c=
onftest -o conftest 2\>\&1 \| /usr/bin/grep -lc \>/dev/null 2\>\&1
configure:13334: $? =3D 0
configure:13348: result: no
configure:13508: checking dynamic linker characteristics
configure:14008: cc -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.c =
>&5
configure:14008: $? =3D 0
configure:14242: result: GNU/Linux ld.so
configure:14349: checking how to hardcode library paths into programs
configure:14374: result: immediate
configure:14914: checking whether stripping libraries is possible
configure:14919: result: yes
configure:14954: checking if libtool supports shared libraries
configure:14956: result: yes
configure:14959: checking whether to build shared libraries
configure:14980: result: yes
configure:14983: checking whether to build static libraries
configure:14987: result: yes
configure:15010: checking how to run the C++ preprocessor
configure:15037: CC -E conftest.cpp
configure:15037: $? =3D 0
configure:15051: CC -E conftest.cpp
conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or direct=
ory
configure:15051: $? =3D 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:15076: result: CC -E
configure:15096: CC -E conftest.cpp
configure:15096: $? =3D 0
configure:15110: CC -E conftest.cpp
ory
configure:15110: $? =3D 1
| /* confdefs.h */
configure:15279: checking for ld used by CC
configure:15346: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m =
elf_x86_64
configure:15353: checking if the linker (/sw/xc40/xalt/0.5.4/sles11.3_gnu=
4.9.2/bin/ld -m elf_x86_64) is GNU ld
configure:15368: result: yes
configure:15423: checking whether the CC linker (/sw/xc40/xalt/0.5.4/sles=
configure:16425: result: yes
configure:16461: CC -c -g -O2 conftest.cpp >&5
configure:16464: $? =3D 0
configure:16984: checking for CC option to produce PIC
configure:16991: result: -fPIC -DPIC
configure:16999: checking if CC PIC flag -fPIC -DPIC works
configure:17017: CC -c -g -O2 -fPIC -DPIC -DPIC conftest.cpp >&5
configure:17021: $? =3D 0
configure:17034: result: yes
configure:17057: checking if CC static flag -static works
configure:17085: result: yes
configure:17097: checking if CC supports -c -o file.o
configure:17118: CC -c -g -O2 -o out/conftest2.o conftest.cpp >&5
configure:17122: $? =3D 0
configure:17144: result: yes
configure:17149: checking if CC supports -c -o file.o
configure:17196: result: yes
configure:17226: checking whether the CC linker (/sw/xc40/xalt/0.5.4/sles=
configure:17265: result: yes
configure:17406: checking dynamic linker characteristics
configure:18074: result: GNU/Linux ld.so
configure:18127: checking how to hardcode library paths into programs
configure:18152: result: immediate
configure:18300: checking if libtool supports shared libraries
configure:18302: result: yes
configure:18305: checking whether to build shared libraries
configure:18325: result: yes
configure:18328: checking whether to build static libraries
configure:18332: result: yes
configure:18653: checking for gfortran option to produce PIC
configure:18660: result: -fPIC
configure:18668: checking if gfortran PIC flag -fPIC works
configure:18686: gfortran -c -g -O2 -fPIC conftest.f >&5
configure:18690: $? =3D 0
configure:18703: result: yes
configure:18726: checking if gfortran static flag -static works
configure:18754: result: yes
configure:18766: checking if gfortran supports -c -o file.o
configure:18787: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:18791: $? =3D 0
configure:18813: result: yes
configure:18818: checking if gfortran supports -c -o file.o
configure:18865: result: yes
configure:18895: checking whether the gfortran linker (/sw/xc40/xalt/0.5.=
4/sles11.3_gnu4.9.2/bin/ld -m elf_x86_64) supports shared libraries
configure:20002: result: yes
configure:20143: checking dynamic linker characteristics
configure:20805: result: GNU/Linux ld.so
configure:20858: checking how to hardcode library paths into programs
configure:20883: result: immediate
configure:21027: checking if libtool supports shared libraries
configure:21029: result: yes
configure:21032: checking whether to build shared libraries
configure:21052: result: yes
configure:21055: checking whether to build static libraries
configure:21059: result: yes
configure:21093: ftn -c -g -O2 conftest.f >&5
configure:21096: $? =3D 0
configure:21525: checking for ftn option to produce PIC
configure:21532: result: -fPIC
configure:21540: checking if ftn PIC flag -fPIC works
configure:21558: ftn -c -g -O2 -fPIC conftest.f >&5
configure:21562: $? =3D 0
configure:21575: result: yes
configure:21598: checking if ftn static flag -static works
configure:21626: result: yes
configure:21638: checking if ftn supports -c -o file.o
configure:21659: ftn -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:21663: $? =3D 0
configure:21685: result: yes
configure:21690: checking if ftn supports -c -o file.o
configure:21737: result: yes
configure:21767: checking whether the ftn linker (/sw/xc40/xalt/0.5.4/sle=
configure:22874: result: yes
configure:23015: checking dynamic linker characteristics
configure:23677: result: GNU/Linux ld.so
configure:23730: checking how to hardcode library paths into programs
configure:23755: result: immediate
configure:23808: checking whether ln -s works
configure:23812: result: yes
configure:23820: checking for ANSI C header files
configure:23924: result: yes
configure:23933: checking for C/C++ restrict keyword
configure:23958: cc -c -g -O2 conftest.c >&5
configure:23958: $? =3D 0
configure:23966: result: __restrict
configure:23985: checking for bash
configure:24012: result: /bin/sh
configure:24027: checking for svn
configure:24045: found /usr/bin/svn
configure:24057: result: /usr/bin/svn
configure:24067: checking for svnversion
configure:24085: found /usr/bin/svnversion
configure:24097: result: /usr/bin/svnversion
configure:24184: checking for lib
configure:24217: result: no
configure:24271: checking size of void *
configure:24276: cc -o conftest -g -O2 conftest.c >&5
configure:24276: $? =3D 0
configure:24276: ./conftest
configure:24290: result: 8
configure:24377: checking for pthread_create in -lpthread
configure:24402: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24402: $? =3D 0
configure:24411: result: yes
configure:24423: checking for struct timespec
configure:24423: cc -c -g -O2 conftest.c >&5
configure:24423: $? =3D 0
conftest.c: In function 'main':
conftest.c:49:30: error: expected expression before ')' token
if (sizeof ((struct timespec)))
configure:24423: $? =3D 1
| /* confdefs.h */
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/project/k1044/favergm/src/starpu-1.2.0rc4"
| #define STARPU_SRC_DIR "/lustre/project/k1044/favergm/src/starpu-1.2.0r=
c4/."
| #define HAVE_LIBPTHREAD 1
|=20
| #include <sys/types.h>
| #include <sys/stat.h>
| #ifdef HAVE_UNISTD_H
| #include <unistd.h>
| #endif
| #include <time.h>
| #ifndef STARPU_NATIVE_WINTHREADS
| #include <pthread.h>
| #endif
|=20
|=20
| int
| main ()
| return 0;
| return 0;
configure:24423: result: yes
configure:24442: checking for library containing sqrt
configure:24473: cc -o conftest -g -O2 conftest.c -lpthread >&5
conftest.c:42:6: warning: conflicting types for built-in function 'sqrt'
char sqrt ();
configure:24473: $? =3D 0
configure:24490: result: none required
configure:24500: checking for main in -lws2_32
configure:24519: cc -o conftest -g -O2 conftest.c -lws2_32 -lpthread =
>&5
/usr/bin/ld: cannot find -lws2_32
collect2: error: ld returned 1 exit status
configure:24519: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:24528: result: no
configure:24542: checking for sysconf
configure:24542: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24542: $? =3D 0
configure:24542: result: yes
configure:24552: checking for pthread_spin_lock
configure:24552: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24552: $? =3D 0
configure:24552: result: yes
configure:24568: checking for pthread_barrier_init
configure:24568: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24568: $? =3D 0
configure:24568: result: yes
configure:24584: checking for pthread_setaffinity_np
configure:24584: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24584: $? =3D 0
configure:24584: result: yes
configure:24597: checking for posix_memalign
configure:24597: cc -o conftest -g -O2 conftest.c -lpthread >&5
conftest.c:63:6: warning: conflicting types for built-in function 'posix_=
memalign'
char posix_memalign ();
configure:24597: $? =3D 0
configure:24597: result: yes
configure:24610: checking for memalign
configure:24610: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24610: $? =3D 0
configure:24610: result: yes
configure:24623: checking for drand48
configure:24623: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24623: $? =3D 0
configure:24623: result: yes
configure:24630: checking for erand48_r
configure:24630: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24630: $? =3D 0
configure:24630: result: yes
configure:24657: checking for strerror_r
configure:24657: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24657: $? =3D 0
configure:24657: result: yes
configure:24666: checking for setenv
configure:24666: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24666: $? =3D 0
configure:24666: result: yes
configure:24675: checking for unsetenv
configure:24675: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24675: $? =3D 0
configure:24675: result: yes
configure:24684: checking for nearbyintf
configure:24684: cc -o conftest -g -O2 conftest.c -lpthread >&5
conftest.c:72:6: warning: conflicting types for built-in function 'nearby=
intf'
char nearbyintf ();
configure:24684: $? =3D 0
configure:24684: result: yes
configure:24693: checking for rintf
configure:24693: cc -o conftest -g -O2 conftest.c -lpthread >&5
conftest.c:73:6: warning: conflicting types for built-in function 'rintf'=
char rintf ();
configure:24693: $? =3D 0
configure:24693: result: yes
configure:24769: checking malloc.h usability
configure:24769: cc -c -g -O2 conftest.c >&5
configure:24769: $? =3D 0
configure:24769: result: yes
configure:24769: checking malloc.h presence
configure:24769: cc -E conftest.c
configure:24769: checking for malloc.h
configure:24792: checking valgrind/valgrind.h usability
configure:24792: cc -c -g -O2 conftest.c >&5
conftest.c:86:31: fatal error: valgrind/valgrind.h: No such file or direc=
tory
#include <valgrind/valgrind.h>
configure:24792: $? =3D 1
| /* confdefs.h */
c4/."
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| # include <unistd.h>
| #endif
configure:24792: result: no
configure:24792: checking valgrind/valgrind.h presence
configure:24792: cc -E conftest.c
conftest.c:53:31: fatal error: valgrind/valgrind.h: No such file or direc=
tory
| /* confdefs.h */
c4/."
configure:24792: checking for valgrind/valgrind.h
configure:24806: checking valgrind/memcheck.h usability
configure:24806: cc -c -g -O2 conftest.c >&5
conftest.c:86:31: fatal error: valgrind/memcheck.h: No such file or direc=
tory
#include <valgrind/memcheck.h>
configure:24806: $? =3D 1
| /* confdefs.h */
c4/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24806: result: no
configure:24806: checking valgrind/memcheck.h presence
configure:24806: cc -E conftest.c
conftest.c:53:31: fatal error: valgrind/memcheck.h: No such file or direc=
tory
| /* confdefs.h */
c4/."
configure:24806: checking for valgrind/memcheck.h
configure:24820: checking valgrind/helgrind.h usability
configure:24820: cc -c -g -O2 conftest.c >&5
conftest.c:86:31: fatal error: valgrind/helgrind.h: No such file or direc=
tory
#include <valgrind/helgrind.h>
configure:24820: $? =3D 1
| /* confdefs.h */
c4/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24820: result: no
configure:24820: checking valgrind/helgrind.h presence
configure:24820: cc -E conftest.c
conftest.c:53:31: fatal error: valgrind/helgrind.h: No such file or direc=
tory
| /* confdefs.h */
c4/."
configure:24820: checking for valgrind/helgrind.h
configure:24839: checking for sched_yield
configure:24839: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24839: $? =3D 0
configure:24839: result: yes
configure:24849: checking aio.h usability
configure:24849: cc -c -g -O2 conftest.c >&5
configure:24849: $? =3D 0
configure:24849: result: yes
configure:24849: checking aio.h presence
configure:24849: cc -E conftest.c
configure:24849: checking for aio.h
configure:24862: checking for mkostemp
configure:24862: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24862: $? =3D 0
configure:24862: result: yes
configure:24875: checking for pread
configure:24875: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24875: $? =3D 0
configure:24875: result: yes
configure:24875: checking for pwrite
configure:24887: checking whether the target supports __sync_val_compare_=
and_swap
configure:24904: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24904: $? =3D 0
configure:24912: result: yes
configure:24922: checking whether the target supports __sync_bool_compare=
_and_swap
configure:24939: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24939: $? =3D 0
configure:24947: result: yes
configure:24957: checking whether the target supports __sync_fetch_and_ad=
d
configure:24974: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:24974: $? =3D 0
configure:24982: result: yes
configure:24992: checking whether the target supports __sync_fetch_and_or=
configure:25009: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:25009: $? =3D 0
configure:25017: result: yes
configure:25027: checking whether the target supports __sync_lock_test_an=
d_set
configure:25044: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:25044: $? =3D 0
configure:25052: result: yes
configure:25062: checking whether the target supports __sync_synchronize
configure:25079: cc -o conftest -g -O2 conftest.c -lpthread >&5
configure:25079: $? =3D 0
configure:25087: result: yes
configure:25099: checking for library containing set_mempolicy
configure:25130: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c >&5
/tmp/ccZ2aqYb.o: In function `main':
/project/k1044/favergm/src/starpu-1.2.0rc4/conftest.c:75: undefined refer=
ence to `set_mempolicy'
/usr/bin/ld: link errors found, deleting executable `conftest'
configure:25130: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
|=20
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
| return 0;
configure:25130: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c -lnuma=
>&5
configure:25130: $? =3D 0
configure:25147: result: -lnuma
configure:25161: checking whether libnuma is available
configure:25163: result: yes
configure:25176: checking maximum number of sched_ctxs
configure:25185: result: 10
configure:25263: checking maximum number of CPUs
configure:25272: result: 64
configure:25280: checking whether CPUs should be used
configure:25289: result: yes
configure:25314: checking maximum number of CUDA devices
configure:25323: result: 4
configure:27121: checking whether CUDA should be used
configure:27123: result: no
configure:27222: checking for pkg-config
configure:27240: found /usr/bin/pkg-config
configure:27252: result: /usr/bin/pkg-config
configure:27277: checking pkg-config is at least version 0.9.0
configure:27280: result: yes
configure:27379: checking whether MAGMA should be used
configure:27381: result: no
configure:27385: checking for cufftDoubleComplex
configure:27385: cc -c -g -O2 -D_GNU_SOURCE conftest.c >&5
conftest.c:69:19: fatal error: cufft.h: No such file or directory
#include <cufft.h>
configure:27385: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_HAVE_LIBNUMA /**/
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #include <cufft.h>
|=20
| int
| main ()
| if (sizeof (cufftDoubleComplex))
| return 0;
| return 0;
configure:27385: result: no
configure:27451: checking whether CURAND is available
configure:27453: result: no
configure:27509: checking maximum number of OpenCL devices
configure:27518: result: 8
configure:28138: checking whether OpenCL should be used
configure:28140: result: no
configure:28168: checking whether asynchronous copy should be disabled
configure:28181: result: no
configure:28189: checking whether asynchronous CUDA copy should be disabl=
ed
configure:28202: result: no
configure:28210: checking whether asynchronous OpenCL copy should be disa=
bled
configure:28223: result: no
configure:28231: checking whether asynchronous MIC copy should be disable=
d
configure:28244: result: no
configure:28480: checking whether SimGrid is enabled
configure:28482: result: no
configure:28485: checking whether blocking drivers should be enabled
configure:28494: result: no
configure:28509: checking maximum number of MIC devices
configure:28518: result: 4
configure:28527: checking maximum number of MIC threads
configure:28536: result:=20
configure:29109: checking RCCE.h usability
configure:29109: cc -c -g -O2 -D_GNU_SOURCE conftest.c >&5
conftest.c:107:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
configure:29109: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <RCCE.h>
configure:29109: result: no
configure:29109: checking RCCE.h presence
configure:29109: cc -E -D_GNU_SOURCE conftest.c
conftest.c:74:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
| /* confdefs.h */
c4/."
| #include <RCCE.h>
configure:29109: checking for RCCE.h
configure:29125: checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrm=
gmt
configure:29150: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c -lRC=
CE_bigflags_nongory_nopwrmgmt -lpthread >&5
/usr/bin/ld: cannot find -lRCCE_bigflags_nongory_nopwrmgmt
configure:29150: $? =3D 1
| /* confdefs.h */
c4/."
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char RCCE_init ();
| int
| main ()
| return RCCE_init ();
| return 0;
configure:29159: result: no
configure:29207: checking whether RCCE should be used
configure:29209: result: no
configure:29248: checking Maximum number of message-passing kernels
configure:29257: result: 10
configure:29273: checking whether debug mode should be enabled
configure:29282: result: no
configure:29313: checking whether extra checks should be performed
configure:29322: result: no
configure:29330: checking whether debug messages should be displayed
configure:29339: result: no
configure:29355: checking whether coverage testing should be enabled
configure:29364: result: no
configure:29383: checking whether FxT traces should be generated
configure:29414: result: no
configure:29767: checking whether additional locking systems FxT traces s=
hould be enabled
configure:29776: result: no
configure:29784: checking whether performance debugging should be enabled=
configure:29793: result: no
configure:29805: checking whether performance model debugging should be e=
nabled
configure:29814: result: no
configure:29822: checking whether statistics should be generated
configure:29831: result: no
configure:29843: checking whether memory stats should be displayed
configure:29852: result: no
configure:29862: checking glpk.h usability
configure:29862: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
conftest.c:109:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
configure:29862: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_USE_MP 1
| #define STARPU_MAXMPKERNELS 10
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:29862: result: no
configure:29862: checking glpk.h presence
configure:29862: cc -E -D_GNU_SOURCE conftest.c
conftest.c:76:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
| /* confdefs.h */
c4/."
| #include <glpk.h>
configure:29862: checking for glpk.h
configure:29876: checking for main in -lglpk
configure:29895: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lglpk >&5
/usr/bin/ld: cannot find -lglpk
configure:29895: $? =3D 1
| /* confdefs.h */
c4/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:29904: result: no
configure:29922: checking Ayudame.h usability
configure:29922: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
conftest.c:109:21: fatal error: Ayudame.h: No such file or directory
#include <Ayudame.h>
configure:29922: $? =3D 1
| /* confdefs.h */
c4/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:29922: result: no
configure:29922: checking Ayudame.h presence
configure:29922: cc -E -D_GNU_SOURCE conftest.c
conftest.c:76:21: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
c4/."
configure:29922: checking for Ayudame.h
configure:29939: checking how many buffers can be manipulated per task
configure:29948: result: 8
configure:29956: checking maximum number of nodes to use
configure:30005: checking maximum number of memory nodes
configure:30007: result: 4
configure:30016: checking whether allocation cache should be used
configure:30025: result: yes
configure:30059: checking using explicit performance model location
configure:30061: result: no
configure:30064: checking performance models location
configure:30066: result: $HOME/.starpu/sampling/
configure:30070: checking for clock_gettime in -lrt
configure:30095: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lrt -lpthread >&5
configure:30095: $? =3D 0
configure:30104: result: yes
configure:30117: checking for clock_gettime
configure:30117: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
configure:30117: $? =3D 0
configure:30117: result: yes
configure:30147: checking Maximum number of workers
configure:30149: result: 64
configure:30159: checking Maximum number of workers combinations
configure:30161: result: 64
configure:30172: checking maximum number of implementations
configure:30181: result: 4
configure:30198: checking leveldb/db.h usability
configure:30198: CC -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ecpp >&5
conftest.cpp:117:24: fatal error: leveldb/db.h: No such file or directory=
#include <leveldb/db.h>
configure:30198: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 4
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 64
| #define STARPU_NMAX_COMBINEDWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:30198: result: no
configure:30198: checking leveldb/db.h presence
configure:30198: CC -E -D_GNU_SOURCE conftest.cpp
conftest.cpp:84:24: fatal error: leveldb/db.h: No such file or directory
| /* confdefs.h */
c4/."
configure:30198: checking for leveldb/db.h
configure:30212: checking for main in -lleveldb
configure:30231: CC -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.cpp -lleveldb >&5
/usr/bin/ld: cannot find -lleveldb
configure:30231: $? =3D 1
| /* confdefs.h */
c4/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:30240: result: no
configure:30272: checking calibration heuristic of history-based StarPU c=
alibrator
configure:30281: result: 50
configure:30362: result: The mpicc compiler is not valid
configure:30412: checking mpicc path
configure:30414: result: cc
configure:30466: checking for mpiexec
configure:30485: found /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec
configure:30498: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexe=
c
configure:30510: checking whether mpiexec is available
configure:30512: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexe=
c
configure:30541: checking whether the StarPU MPI library should be genera=
ted
configure:30543: result: no
configure:30591: checking for StarPU-Top
configure:30600: checking for qmake-qt4
configure:30633: result: no
configure:30618: found /usr/bin/qmake
configure:30630: result: /usr/bin/qmake
configure:30646: $PKG_CONFIG --exists --print-errors "QtGui QtNetwork QtO=
penGL QtSql"
configure:30649: $? =3D 0
configure:30730: checking whether compiler support -Wall
configure:30752: cc -c -Wall -D_GNU_SOURCE conftest.c >&5
conftest.c:91:18: warning: unused variable 'hello' [-Wunused-variable]
const char *hello =3D "Hello World";
configure:30752: $? =3D 0
configure:30755: result: yes
configure:30769: checking whether compiler support -Werror=3Dimplicit
configure:30791: cc -c -Werror=3Dimplicit -D_GNU_SOURCE conftest.c >&5
configure:30791: $? =3D 0
configure:30794: result: yes
configure:30808: checking whether compiler support -Werror=3Dimplicit-fun=
ction-declaration
configure:30830: cc -c -Werror=3Dimplicit-function-declaration -D_GNU_SO=
URCE conftest.c >&5
configure:30830: $? =3D 0
configure:30833: result: yes
configure:31078: checking whether GCC supports plug-ins
configure:31133: cc -c -O3 -g -O2 -gdwarf-2 -g3 -I/opt/gcc/4.9.3/snos/li=
b/gcc/x86_64-suse-linux/4.9.3/plugin/include conftest.c >&5
In file included from /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3=
/plugin/include/config.h:6:0,
/plugin/include/gcc-plugin.h:27,
from conftest.c:85:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-h=
ost.h:1766:0: warning: "PACKAGE_BUGREPORT" redefined
#define PACKAGE_BUGREPORT ""
conftest.c:6:0: note: this is the location of the previous definition
from conftest.c:85:
ost.h:1772:0: warning: "PACKAGE_NAME" redefined
#define PACKAGE_NAME ""
conftest.c:2:0: note: this is the location of the previous definition
from conftest.c:85:
ost.h:1778:0: warning: "PACKAGE_STRING" redefined
#define PACKAGE_STRING ""
conftest.c:5:0: note: this is the location of the previous definition
from conftest.c:85:
ost.h:1784:0: warning: "PACKAGE_TARNAME" redefined
#define PACKAGE_TARNAME ""
conftest.c:3:0: note: this is the location of the previous definition
from conftest.c:85:
ost.h:1790:0: warning: "PACKAGE_URL" redefined
#define PACKAGE_URL ""
conftest.c:7:0: note: this is the location of the previous definition
from conftest.c:85:
ost.h:1796:0: warning: "PACKAGE_VERSION" redefined
#define PACKAGE_VERSION ""
conftest.c:4:0: note: this is the location of the previous definition
/plugin/include/gcc-plugin.h:29:0,
from conftest.c:85:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/corety=
pes.h:171:1: error: unknown type name 'class'
class rtl_opt_pass;
pes.h:173:1: error: unknown type name 'namespace'
namespace gcc {
pes.h:173:15: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '{' token
namespace gcc {
/plugin/include/tree-core.h:24:0,
/plugin/include/tree.h:23,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/machmo=
de.h:262:1: error: unknown type name 'class'
class bit_field_mode_iterator
de.h:263:1: error: expected '=3D', ',', ';', 'asm' or '__attribute__' bef=
ore '{' token
/plugin/include/tree-core.h:27:0,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:=
218:8: error: field 'register_overhead' declared as a function
void register_overhead (size_t, const char *, int, const char *);
219:8: error: field 'release_overhead' declared as a function
void release_overhead (void);
220:3: error: expected specifier-qualifier-list before 'static'
static unsigned calculate_allocation (vec_prefix *, unsigned, bool);
246:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
':' token
vec_prefix::calculate_allocation (vec_prefix *pfx, unsigned reserve,
256:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
template<typename, typename, typename> struct vec;
279:3: error: expected specifier-qualifier-list before 'typedef'
typedef vl_ptr default_layout;
295:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
template<typename T>
319:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
342:3: error: expected specifier-qualifier-list before 'typedef'
typedef vl_embed default_layout;
355:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
template<typename T, typename A>
370:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
408:21: error: expected identifier or '(' before ':' token
struct va_gc_atomic : va_gc
424:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
437:3: error: expected specifier-qualifier-list before 'template'
template <typename T, typename A, typename L>
440:8: error: unknown type name 'vnull'
extern vnull vNULL;
469:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
532:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
541:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
550:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
559:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
569:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
580:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
592:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
603:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
612:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
624:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
635:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
648:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
664:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
675:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
686:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
696:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
705:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
723:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
731:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
742:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
757:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
772:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
798:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
817:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
836:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
849:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
862:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
875:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
887:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
899:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
915:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
928:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
940:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
954:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
966:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before '=
<' token
1003:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1042:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1054:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1067:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1079:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1091:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1100:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1111:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1120:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1128:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1166:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1247:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
template<typename T, size_t N =3D 0>
1269:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1283:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1294:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1305:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1325:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1348:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1387:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1407:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1443:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1456:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1468:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1489:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1503:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1520:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1532:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1543:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1554:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1569:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1584:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1597:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1610:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1622:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1633:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1646:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1657:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1668:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1679:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1691:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1707:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
1716:9: error: expected '=3D', ',', ';', 'asm' or '__attribute__' before =
'<' token
/plugin/include/tree-core.h:28:0,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double=
-int.h:58:3: error: expected specifier-qualifier-list before 'static'
static double_int from_uhwi (unsigned HOST_WIDE_INT cst);
-int.h:207:8: error: unknown type name 'double_int'
inline double_int
-int.h:208:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::from_shwi (HOST_WIDE_INT cst)
-int.h:230:8: error: unknown type name 'double_int'
inline double_int
-int.h:231:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::from_uhwi (unsigned HOST_WIDE_INT cst)
-int.h:239:8: error: unknown type name 'double_int'
inline double_int
-int.h:240:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::from_pair (HOST_WIDE_INT high, unsigned HOST_WIDE_INT low)
-int.h:248:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '&' token
inline double_int &
-int.h:255:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '&' token
inline double_int &
-int.h:262:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '&' token
inline double_int &
-int.h:269:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '&' token
inline double_int &
-int.h:276:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '&' token
inline double_int &
-int.h:287:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::to_shwi () const
-int.h:296:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::to_uhwi () const
-int.h:304:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::fits_uhwi () const
-int.h:313:8: error: unknown type name 'double_int'
inline double_int
-int.h:314:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator ~ () const
-int.h:324:8: error: unknown type name 'double_int'
inline double_int
-int.h:325:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator | (double_int b) const
-int.h:335:8: error: unknown type name 'double_int'
inline double_int
-int.h:336:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator & (double_int b) const
-int.h:346:8: error: unknown type name 'double_int'
inline double_int
-int.h:347:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::and_not (double_int b) const
-int.h:357:8: error: unknown type name 'double_int'
inline double_int
-int.h:358:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator ^ (double_int b) const
-int.h:366:31: error: unknown type name 'double_int'
void dump_double_int (FILE *, double_int, bool);
-int.h:377:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::is_zero () const
-int.h:385:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::is_one () const
-int.h:393:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::is_minus_one () const
-int.h:401:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::is_negative () const
-int.h:409:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator =3D=3D (double_int cst2) const
-int.h:417:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::operator !=3D (double_int cst2) const
-int.h:425:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before ':' token
double_int::popcount () const
-int.h:434:33: error: unknown type name 'double_int'
void mpz_set_double_int (mpz_t, double_int, bool);
-int.h:435:1: error: unknown type name 'double_int'
double_int mpz_get_double_int (const_tree, mpz_t, bool);
/plugin/include/tree-core.h:30:0,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fixed-=
value.h:29:3: error: unknown type name 'double_int'
double_int data; /* Store data up to 2 wide integers. */
value.h:55:12: error: expected ')' before 'enum'
enum machine_mode);
value.h:60:30: error: unknown type name 'double_int'
const_fixed_from_double_int (double_int payload,
value.h:81:9: error: unknown type name 'double_int'
double_int, bool, bool);
/plugin/include/flags.h:24:0,
/plugin/include/tree-core.h:32,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/option=
s.h:4093:28: error: unknown type name 'diagnostic_context'
diagnostic_context *dc); =20
s.h:4101:28: error: unknown type name 'diagnostic_context'
s.h:4109:28: error: unknown type name 'diagnostic_context'
s.h:4117:28: error: unknown type name 'diagnostic_context'
s.h:4125:28: error: unknown type name 'diagnostic_context'
s.h:4133:28: error: unknown type name 'diagnostic_context'
s.h:4141:28: error: unknown type name 'diagnostic_context'
s.h:4149:28: error: unknown type name 'diagnostic_context'
s.h:4157:28: error: unknown type name 'diagnostic_context'
s.h:4165:28: error: unknown type name 'diagnostic_context'
s.h:4173:28: error: unknown type name 'diagnostic_context'
s.h:4181:28: error: unknown type name 'diagnostic_context'
/plugin/include/tree.h:23:0,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-c=
ore.h:1051:3: error: unknown type name 'double_int'
double_int int_cst;
ore.h:1109:3: error: expected specifier-qualifier-list before 'vec'
vec<constructor_elt, va_gc> *elts;
ore.h:1233:3: error: expected specifier-qualifier-list before 'vec'
vec<tree, va_gc> *nonlocalized_vars;
ore.h:1304:3: error: expected specifier-qualifier-list before 'vec'
vec<tree, va_gc> *base_accesses;
ore.h:1704:3: error: expected specifier-qualifier-list before 'vec'
vec<tree, va_gc> *pending_statics;
ore.h:1752:3: error: expected specifier-qualifier-list before 'vec'
vec<tree, va_gc> *to;
ore.h:1798:19: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '<' token
extern GTY(()) vec<alias_pair, va_gc> *alias_pairs;
ore.h:1811:20: error: expected '=3D', ',', ';', 'asm' or '__attribute__' =
before '<' token
extern GTY (()) vec<tree, va_gc> *all_translation_units;
ore.h:1833:16: error: unknown type name 'builtin_info_type'
extern GTY(()) builtin_info_type builtin_info;
/plugin/include/tree.h:29:0,
from conftest.c:86:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fold-c=
onst.h:121:8: error: unknown type name 'double_int'
extern double_int mem_ref_offset (const_tree);
In file included from conftest.c:86:0:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h=
:2592:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' befor=
e '<' token
extern vec<tree, va_gc> **decl_debug_args_lookup (tree);
:2593:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' befor=
e '<' token
extern vec<tree, va_gc> **decl_debug_args_insert (tree);
: In function 'tree_operand_length':
:880:52: error: request for member 'low' in something not a structure or =
union
#define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low)
:1011:9: note: in expansion of macro 'TREE_INT_CST_LOW'
((int)TREE_INT_CST_LOW (VL_EXP_CHECK (NODE)->exp.operands[0]))
:3145:12: note: in expansion of macro 'VL_EXP_OPERAND_LENGTH'
return VL_EXP_OPERAND_LENGTH (node);
: At top level:
:3457:38: error: unknown type name 'vec'
extern tree build_nt_call_vec (tree, vec<tree, va_gc> *);
:3457:48: error: unknown type name 'va_gc'
:3541:15: error: unknown type name 'double_int'
static inline double_int
:3547:39: error: unknown type name 'double_int'
extern tree double_int_to_tree (tree, double_int);
:3548:52: error: unknown type name 'double_int'
extern bool double_int_fits_to_tree_p (const_tree, double_int);
:3549:42: error: unknown type name 'double_int'
extern tree force_fit_type_double (tree, double_int, int, bool);
: In function 'build_int_cstu':
:3556:36: error: 'double_int' undeclared (first use in this function)
return double_int_to_tree (type, double_int::from_uhwi (cst));
:3556:36: note: each undeclared identifier is reported only once for each=
function it appears in
:3556:46: error: expected ')' before ':' token
: At top level:
:3566:43: error: unknown type name 'vec'
extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *)=
:3566:64: error: unknown type name 'va_gc'
:3568:38: error: unknown type name 'vec'
extern tree build_constructor (tree, vec<constructor_elt, va_gc> *);
:3568:59: error: unknown type name 'va_gc'
:3581:48: error: expected ';', ',' or ')' before '<' token
extern tree build_tree_list_vec_stat (const vec<tree, va_gc> *MEM_STAT_D=
ECL);
:3600:41: error: unknown type name 'vec'
extern tree build_call_vec (tree, tree, vec<tree, va_gc> *);
:3600:51: error: unknown type name 'va_gc'
:3637:37: error: unknown type name 'vec'
extern bool vec_member (const_tree, vec<tree, va_gc> *);
:3637:47: error: unknown type name 'va_gc'
: In function 'tree_to_shwi':
union
:3662:10: note: in expansion of macro 'TREE_INT_CST_LOW'
return TREE_INT_CST_LOW (t);
: In function 'tree_to_uhwi':
union
:3669:10: note: in expansion of macro 'TREE_INT_CST_LOW'
: At top level:
:3877:11: error: expected '=3D', ',', ';', 'asm' or '__attribute__' befor=
e '<' token
extern vec<tree, va_gc> *ctor_to_vec (tree);
:3964:45: error: unknown type name 'vec'
extern void find_placeholder_in_expr (tree, vec<tree> *);
:4063:26: error: unknown type name 'function_args_iterator'
function_args_iter_init (function_args_iterator *i, const_tree fntype)
:4072:30: error: unknown type name 'function_args_iterator'
function_args_iter_cond_ptr (function_args_iterator *i)
:4081:26: error: unknown type name 'function_args_iterator'
function_args_iter_cond (function_args_iterator *i)
:4088:26: error: unknown type name 'function_args_iterator'
function_args_iter_next (function_args_iterator *i)
:4305:40: error: unknown type name 'call_expr_arg_iterator'
init_call_expr_arg_iterator (tree exp, call_expr_arg_iterator *iter)
:4313:52: error: unknown type name 'const_call_expr_arg_iterator'
init_const_call_expr_arg_iterator (const_tree exp, const_call_expr_arg_i=
terator *iter)
:4323:21: error: unknown type name 'call_expr_arg_iterator'
next_call_expr_arg (call_expr_arg_iterator *iter)
:4334:27: error: unknown type name 'const_call_expr_arg_iterator'
next_const_call_expr_arg (const_call_expr_arg_iterator *iter)
:4349:32: error: unknown type name 'call_expr_arg_iterator'
first_call_expr_arg (tree exp, call_expr_arg_iterator *iter)
:4356:44: error: unknown type name 'const_call_expr_arg_iterator'
first_const_call_expr_arg (const_tree exp, const_call_expr_arg_iterator =
*iter)
:4365:30: error: unknown type name 'call_expr_arg_iterator'
more_call_expr_args_p (const call_expr_arg_iterator *iter)
: In function 'more_call_expr_args_p':
:4367:15: error: request for member 'i' in something not a structure or u=
nion
return (iter->i < iter->n);
:4367:25: error: request for member 'n' in something not a structure or u=
nion
: In function 'builtin_decl_explicit':
:4397:22: error: request for member 'decl' in something not a structure o=
r union
return builtin_info.decl[(size_t)fncode];
: In function 'builtin_decl_implicit':
:4407:20: error: request for member 'implicit_p' in something not a struc=
ture or union
if (!builtin_info.implicit_p[uns_fncode])
:4410:22: error: request for member 'decl' in something not a structure o=
r union
return builtin_info.decl[uns_fncode];
: In function 'set_builtin_decl':
:4424:15: error: request for member 'decl' in something not a structure o=
r union
builtin_info.decl[ufncode] =3D decl;
:4425:15: error: request for member 'implicit_p' in something not a struc=
ture or union
builtin_info.implicit_p[ufncode] =3D implicit_p;
/plugin/include/gcc-plugin.h:28:0,
from conftest.c:85:
: In function 'set_builtin_decl_implicit_p':
:4436:25: error: request for member 'decl' in something not a structure o=
r union
&& builtin_info.decl[uns_fncode] !=3D NULL_TREE);
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/system=
=2Eh:703:49: note: in definition of macro 'gcc_checking_assert'
#define gcc_checking_assert(EXPR) ((void)(0 && (EXPR)))
:4438:15: error: request for member 'implicit_p' in something not a struc=
ture or union
builtin_info.implicit_p[uns_fncode] =3D implicit_p;
: In function 'builtin_decl_explicit_p':
:4448:23: error: request for member 'decl' in something not a structure o=
r union
return (builtin_info.decl[(size_t)fncode] !=3D NULL_TREE);
: In function 'builtin_decl_implicit_p':
:4459:23: error: request for member 'decl' in something not a structure o=
r union
return (builtin_info.decl[uns_fncode] !=3D NULL_TREE
:4460:19: error: request for member 'implicit_p' in something not a struc=
ture or union
&& builtin_info.implicit_p[uns_fncode]);
: At top level:
:4573:56: error: unknown type name 'vec'
extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> =
:4573:66: error: unknown type name 'va_gc'
In file included from conftest.c:87:0:
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple=
=2Eh:29:12: error: expected '=3D', ',', ';', 'asm' or '__attribute__' bef=
ore '<' token
typedef vec<gimple> gimple_vec;
=2Eh:210:34: error: expected identifier or '(' before ':' token
gimple_statement_with_ops_base : public gimple_statement_base
=2Eh:226:29: error: expected identifier or '(' before ':' token
gimple_statement_with_ops : public gimple_statement_with_ops_base
=2Eh:241:41: error: expected identifier or '(' before ':' token
gimple_statement_with_memory_ops_base : public gimple_statement_with_o=
ps_base
=2Eh:256:36: error: expected identifier or '(' before ':' token
gimple_statement_with_memory_ops :
=2Eh:272:25: error: expected identifier or '(' before ':' token
gimple_statement_call : public gimple_statement_with_memory_ops_base
=2Eh:297:24: error: expected identifier or '(' before ':' token
gimple_statement_omp : public gimple_statement_base
=2Eh:309:25: error: expected identifier or '(' before ':' token
gimple_statement_bind : public gimple_statement_base
=2Eh:333:26: error: expected identifier or '(' before ':' token
gimple_statement_catch : public gimple_statement_base
=2Eh:348:30: error: expected identifier or '(' before ':' token
gimple_statement_eh_filter : public gimple_statement_base
=2Eh:364:28: error: expected identifier or '(' before ':' token
gimple_statement_eh_else : public gimple_statement_base
=2Eh:375:27: error: expected identifier or '(' before ':' token
gimple_statement_eh_mnt : public gimple_statement_base
=2Eh:386:24: error: expected identifier or '(' before ':' token
gimple_statement_phi : public gimple_statement_base
=2Eh:405:28: error: expected identifier or '(' before ':' token
gimple_statement_eh_ctrl : public gimple_statement_base
=2Eh:415:25: error: expected identifier or '(' before ':' token
gimple_statement_resx : public gimple_statement_eh_ctrl
=2Eh:422:32: error: expected identifier or '(' before ':' token
gimple_statement_eh_dispatch : public gimple_statement_eh_ctrl
=2Eh:432:24: error: expected identifier or '(' before ':' token
gimple_statement_try : public gimple_statement_base
=2Eh:462:24: error: expected identifier or '(' before ':' token
gimple_statement_wce : public gimple_statement_base
=2Eh:480:24: error: expected identifier or '(' before ':' token
gimple_statement_asm : public gimple_statement_with_memory_ops_base
=2Eh:505:33: error: expected identifier or '(' before ':' token
gimple_statement_omp_critical : public gimple_statement_omp
=2Eh:535:28: error: expected identifier or '(' before ':' token
gimple_statement_omp_for : public gimple_statement_omp
=2Eh:557:40: error: expected identifier or '(' before ':' token
gimple_statement_omp_parallel_layout : public gimple_statement_omp
=2Eh:576:32: error: expected identifier or '(' before ':' token
gimple_statement_omp_taskreg : public gimple_statement_omp_parallel_la=
yout
=2Eh:586:33: error: expected identifier or '(' before ':' token
gimple_statement_omp_parallel : public gimple_statement_omp_taskreg
=2Eh:593:31: error: expected identifier or '(' before ':' token
gimple_statement_omp_target : public gimple_statement_omp_parallel_lay=
out
=2Eh:602:29: error: expected identifier or '(' before ':' token
gimple_statement_omp_task : public gimple_statement_omp_taskreg
=2Eh:624:33: error: expected identifier or '(' before ':' token
gimple_statement_omp_sections : public gimple_statement_omp
=2Eh:643:33: error: expected identifier or '(' before ':' token
gimple_statement_omp_continue : public gimple_statement_base
=2Eh:657:38: error: expected identifier or '(' before ':' token
gimple_statement_omp_single_layout : public gimple_statement_omp
=2Eh:666:31: error: expected identifier or '(' before ':' token
gimple_statement_omp_single : public gimple_statement_omp_single_layou=
t
=2Eh:673:30: error: expected identifier or '(' before ':' token
gimple_statement_omp_teams : public gimple_statement_omp_single_layout=
=2Eh:685:36: error: expected identifier or '(' before ':' token
gimple_statement_omp_atomic_load : public gimple_statement_base
=2Eh:697:44: error: expected identifier or '(' before ':' token
gimple_statement_omp_atomic_store_layout : public gimple_statement_bas=
e
=2Eh:706:37: error: expected identifier or '(' before ':' token
gimple_statement_omp_atomic_store :
=2Eh:714:31: error: expected identifier or '(' before ':' token
gimple_statement_omp_return :
=2Eh:750:32: error: expected identifier or '(' before ':' token
gimple_statement_transaction : public gimple_statement_with_memory_ops=
_base
=2Eh:768:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:776:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:784:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:792:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:800:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:808:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:816:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:824:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:832:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:840:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:848:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:856:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:864:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:872:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:880:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:888:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:896:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:904:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:912:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:920:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:928:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:936:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:944:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:952:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:960:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:968:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:976:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:984:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:992:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' be=
fore '<' token
template <>
=2Eh:1000:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1008:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1016:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1024:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1032:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1040:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1048:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1056:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1064:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1072:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1080:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1088:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1096:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1104:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1112:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1120:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1128:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1136:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1144:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1167:37: error: unknown type name 'vec'
gimple gimple_build_call_vec (tree, vec<tree> );
=2Eh:1170:41: warning: 'enum internal_fn' declared inside parameter list
gimple gimple_build_call_internal (enum internal_fn, unsigned, ...);
=2Eh:1170:41: warning: its scope is only this definition or declaration, =
which is probably not what you want
=2Eh:1171:58: error: unknown type name 'vec'
gimple gimple_build_call_internal_vec (enum internal_fn, vec<tree> );
=2Eh:1177:8: error: conflicting types for 'gimple_build_assign_with_ops'
gimple gimple_build_assign_with_ops (enum tree_code, tree,
=2Eh:1175:8: note: previous declaration of 'gimple_build_assign_with_ops'=
was here
=2Eh:1186:44: error: unknown type name 'vec'
gimple gimple_build_asm_vec (const char *, vec<tree, va_gc> *,
=2Eh:1186:54: error: unknown type name 'va_gc'
=2Eh:1187:9: error: unknown type name 'vec'
vec<tree, va_gc> *, vec<tree, va_gc> *,
=2Eh:1187:19: error: unknown type name 'va_gc'
=2Eh:1187:29: error: unknown type name 'vec'
=2Eh:1187:39: error: unknown type name 'va_gc'
=2Eh:1188:9: error: unknown type name 'vec'
=2Eh:1188:19: error: unknown type name 'va_gc'
=2Eh:1193:1: error: unknown type name 'gimple_statement_try'
gimple_statement_try *gimple_build_try (gimple_seq, gimple_seq,
=2Eh:1198:41: error: unknown type name 'vec'
gimple gimple_build_switch (tree, tree, vec<tree> );
=2Eh:1224:54: warning: 'enum prediction' declared inside parameter list
gimple gimple_build_predict (enum br_predictor, enum prediction);
=2Eh:1224:54: warning: 'enum br_predictor' declared inside parameter list=
=2Eh:1228:59: error: unknown type name 'gimple_stmt_iterator'
extern void annotate_all_with_location_after (gimple_seq, gimple_stmt_it=
erator,
=2Eh:1241:39: error: unknown type name 'gimple_stmt_iterator'
void gimple_assign_set_rhs_from_tree (gimple_stmt_iterator *, tree);
=2Eh:1242:40: error: unknown type name 'gimple_stmt_iterator'
void gimple_assign_set_rhs_with_ops_1 (gimple_stmt_iterator *, enum tree=
_code,
=2Eh:1262:13: error: conflicting types for 'gimple_call_builtin_p'
extern bool gimple_call_builtin_p (gimple, enum built_in_class);
=2Eh:1261:13: note: previous declaration of 'gimple_call_builtin_p' was h=
ere
extern bool gimple_call_builtin_p (gimple);
=2Eh:1263:13: error: conflicting types for 'gimple_call_builtin_p'
extern bool gimple_call_builtin_p (gimple, enum built_in_function);
ere
=2Eh:1268:34: error: expected ')' before '<' token
extern void sort_case_labels (vec<tree> );
=2Eh:1269:54: error: expected ')' before '<' token
extern void preprocess_case_label_vec_for_gimple (vec<tree> , tree, tree=
=2Eh: In function 'gimple_stmt_max_uid':
=2Eh:1285:12: error: dereferencing pointer to incomplete type
return fn->last_stmt_uid;
=2Eh: In function 'set_gimple_stmt_max_uid':
=2Eh:1292:5: error: dereferencing pointer to incomplete type
fn->last_stmt_uid =3D maxid;
=2Eh: In function 'inc_gimple_stmt_max_uid':
=2Eh:1299:12: error: dereferencing pointer to incomplete type
return fn->last_stmt_uid++;
=2Eh: In function 'bb_seq':
=2Eh:1382:15: error: dereferencing pointer to incomplete type
return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL;
=2Eh:1382:25: error: 'BB_RTL' undeclared (first use in this function)
=2Eh:1382:38: error: dereferencing pointer to incomplete type
=2Eh: In function 'bb_seq_addr':
=2Eh:1388:15: error: dereferencing pointer to incomplete type
return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL;
=2Eh:1388:25: error: 'BB_RTL' undeclared (first use in this function)
=2Eh:1388:39: error: dereferencing pointer to incomplete type
from conftest.c:85:
=2Eh: In function 'set_bb_seq':
=2Eh:1396:28: error: dereferencing pointer to incomplete type
gcc_checking_assert (!(bb->flags & BB_RTL));
=2Eh:1396:38: error: 'BB_RTL' undeclared (first use in this function)
=2Eh:1397:5: error: dereferencing pointer to incomplete type
bb->il.gimple.seq =3D seq;
=2Eh: At top level:
=2Eh:1648:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1656:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1672:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh:1680:10: error: expected '=3D', ',', ';', 'asm' or '__attribute__' b=
efore '<' token
template <>
=2Eh: In function 'gimple_use_ops':
=2Eh:1693:9: error: unknown type name 'gimple_statement_with_ops'
const gimple_statement_with_ops *ops_stmt =3D
=2Eh:1694:5: error: 'dyn_cast' undeclared (first use in this function)
dyn_cast <const gimple_statement_with_ops> (g);
=2Eh:1694:15: error: expected expression before 'const'
=2Eh:1697:18: error: request for member 'use_ops' in something not a stru=
cture or union
return ops_stmt->use_ops;
=2Eh: In function 'gimple_set_use_ops':
=2Eh:1706:3: error: unknown type name 'gimple_statement_with_ops'
=2Eh:1707:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_with_ops> (g);
=2Eh:1707:11: error: 'gimple_statement_with_ops' undeclared (first use in=
this function)
=2Eh:1708:11: error: request for member 'use_ops' in something not a stru=
cture or union
ops_stmt->use_ops =3D use;
=2Eh: In function 'gimple_vuse':
=2Eh:1717:9: error: unknown type name 'gimple_statement_with_memory_ops'
const gimple_statement_with_memory_ops *mem_ops_stmt =3D
=2Eh:1718:6: error: 'dyn_cast' undeclared (first use in this function)
dyn_cast <const gimple_statement_with_memory_ops> (g);
=2Eh:1718:16: error: expected expression before 'const'
=2Eh:1721:22: error: request for member 'vuse' in something not a structu=
re or union
return mem_ops_stmt->vuse;
=2Eh: In function 'gimple_vdef':
=2Eh:1729:9: error: unknown type name 'gimple_statement_with_memory_ops'
=2Eh:1730:6: error: 'dyn_cast' undeclared (first use in this function)
=2Eh:1730:16: error: expected expression before 'const'
=2Eh:1733:22: error: request for member 'vdef' in something not a structu=
re or union
return mem_ops_stmt->vdef;
=2Eh: In function 'gimple_vuse_ptr':
=2Eh:1741:3: error: unknown type name 'gimple_statement_with_memory_ops'
=2Eh:1742:6: error: 'dyn_cast' undeclared (first use in this function)
dyn_cast <gimple_statement_with_memory_ops> (g);
=2Eh:1742:16: error: 'gimple_statement_with_memory_ops' undeclared (first=
=2Eh:1745:23: error: request for member 'vuse' in something not a structu=
re or union
return &mem_ops_stmt->vuse;
=2Eh: In function 'gimple_vdef_ptr':
=2Eh:1753:3: error: unknown type name 'gimple_statement_with_memory_ops'
=2Eh:1754:6: error: 'dyn_cast' undeclared (first use in this function)
=2Eh:1754:16: error: 'gimple_statement_with_memory_ops' undeclared (first=
=2Eh:1757:23: error: request for member 'vdef' in something not a structu=
re or union
return &mem_ops_stmt->vdef;
=2Eh: In function 'gimple_set_vuse':
=2Eh:1765:3: error: unknown type name 'gimple_statement_with_memory_ops'
=2Eh:1766:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_with_memory_ops> (g);
=2Eh:1766:11: error: 'gimple_statement_with_memory_ops' undeclared (first=
=2Eh:1767:15: error: request for member 'vuse' in something not a structu=
re or union
mem_ops_stmt->vuse =3D vuse;
=2Eh: In function 'gimple_set_vdef':
=2Eh:1775:3: error: unknown type name 'gimple_statement_with_memory_ops'
=2Eh:1776:5: error: 'as_a' undeclared (first use in this function)
=2Eh:1776:11: error: 'gimple_statement_with_memory_ops' undeclared (first=
=2Eh:1777:15: error: request for member 'vdef' in something not a structu=
re or union
mem_ops_stmt->vdef =3D vdef;
=2Eh: In function 'gimple_omp_return_set_lhs':
=2Eh:1907:3: error: unknown type name 'gimple_statement_omp_return'
gimple_statement_omp_return *omp_return_stmt =3D
=2Eh:1908:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_return> (g);
=2Eh:1908:11: error: 'gimple_statement_omp_return' undeclared (first use =
in this function)
=2Eh:1909:18: error: request for member 'val' in something not a structur=
e or union
omp_return_stmt->val =3D lhs;
=2Eh: In function 'gimple_omp_return_lhs':
=2Eh:1918:9: error: unknown type name 'gimple_statement_omp_return'
const gimple_statement_omp_return *omp_return_stmt =3D
=2Eh:1919:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_return> (g);
=2Eh:1919:11: error: expected expression before 'const'
=2Eh:1920:25: error: request for member 'val' in something not a structur=
e or union
return omp_return_stmt->val;
=2Eh: In function 'gimple_omp_return_lhs_ptr':
=2Eh:1929:3: error: unknown type name 'gimple_statement_omp_return'
=2Eh:1930:5: error: 'as_a' undeclared (first use in this function)
=2Eh:1930:11: error: 'gimple_statement_omp_return' undeclared (first use =
in this function)
=2Eh:1931:26: error: request for member 'val' in something not a structur=
e or union
return &omp_return_stmt->val;
=2Eh: At top level:
=2Eh:2260:33: error: unknown type name 'gimple_stmt_iterator'
gimple_assign_set_rhs_with_ops (gimple_stmt_iterator *gsi, enum tree_cod=
e code,
=2Eh:2445:1: error: return type is an incomplete type
gimple_call_internal_fn (const_gimple gs)
=2Eh: In function 'gimple_call_internal_fn':
=2Eh:2448:10: error: 'static_cast' undeclared (first use in this function=
return static_cast <const gimple_statement_call *> (gs)->u.internal_fn=
=2Eh:2448:23: error: expected expression before 'const'
=2Eh:2448:3: warning: 'return' with a value, in function returning void
=2Eh: In function 'gimple_call_fntype':
=2Eh:2480:9: error: unknown type name 'gimple_statement_call'
const gimple_statement_call *call_stmt =3D
=2Eh:2481:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_call> (gs);
=2Eh:2481:11: error: expected expression before 'const'
=2Eh:2484:19: error: request for member 'u' in something not a structure =
or union
return call_stmt->u.fntype;
=2Eh: In function 'gimple_call_set_fntype':
=2Eh:2492:3: error: unknown type name 'gimple_statement_call'
gimple_statement_call *call_stmt =3D as_a <gimple_statement_call> (gs)=
=2Eh:2492:38: error: 'as_a' undeclared (first use in this function)
=2Eh:2492:44: error: 'gimple_statement_call' undeclared (first use in thi=
s function)
=2Eh:2494:12: error: request for member 'u' in something not a structure =
or union
call_stmt->u.fntype =3D fntype;
=2Eh: At top level:
=2Eh:2544:58: error: parameter 2 ('fn') has incomplete type
gimple_call_set_internal_fn (gimple gs, enum internal_fn fn)
=2Eh: In function 'gimple_call_set_internal_fn':
=2Eh:2546:3: error: unknown type name 'gimple_statement_call'
=2Eh:2546:38: error: 'as_a' undeclared (first use in this function)
=2Eh:2546:44: error: 'gimple_statement_call' undeclared (first use in thi=
s function)
=2Eh:2548:12: error: request for member 'u' in something not a structure =
or union
call_stmt->u.internal_fn =3D fn;
=2Eh: In function 'gimple_call_fndecl':
=2Eh:2559:3: warning: return makes pointer from integer without a cast
return gimple_call_addr_fndecl (gimple_call_fn (gs));
=2Eh: In function 'gimple_call_use_set':
=2Eh:2824:3: error: unknown type name 'gimple_statement_call'
gimple_statement_call *call_stmt =3D as_a <gimple_statement_call> (cal=
l);
=2Eh:2824:38: error: 'as_a' undeclared (first use in this function)
l);
=2Eh:2824:44: error: 'gimple_statement_call' undeclared (first use in thi=
s function)
l);
=2Eh:2825:20: error: request for member 'call_used' in something not a st=
ructure or union
return &call_stmt->call_used;
=2Eh: In function 'gimple_call_clobber_set':
=2Eh:2835:3: error: unknown type name 'gimple_statement_call'
l);
=2Eh:2835:38: error: 'as_a' undeclared (first use in this function)
l);
=2Eh:2835:44: error: 'gimple_statement_call' undeclared (first use in thi=
s function)
l);
=2Eh:2836:20: error: request for member 'call_clobbered' in something not=
a structure or union
return &call_stmt->call_clobbered;
=2Eh: In function 'gimple_bind_vars':
=2Eh:3104:9: error: unknown type name 'gimple_statement_bind'
const gimple_statement_bind *bind_stmt =3D
=2Eh:3105:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_bind> (gs);
=2Eh:3105:11: error: expected expression before 'const'
=2Eh:3106:19: error: request for member 'vars' in something not a structu=
re or union
return bind_stmt->vars;
=2Eh: In function 'gimple_bind_set_vars':
=2Eh:3116:3: error: unknown type name 'gimple_statement_bind'
gimple_statement_bind *bind_stmt =3D as_a <gimple_statement_bind> (gs)=
=2Eh:3116:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3116:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3117:12: error: request for member 'vars' in something not a structu=
re or union
bind_stmt->vars =3D vars;
=2Eh: In function 'gimple_bind_append_vars':
=2Eh:3127:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3127:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3127:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3128:12: error: request for member 'vars' in something not a structu=
re or union
bind_stmt->vars =3D chainon (bind_stmt->vars, vars);
=2Eh:3128:39: error: request for member 'vars' in something not a structu=
re or union
=2Eh: In function 'gimple_bind_body_ptr':
=2Eh:3135:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3135:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3135:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3136:20: error: request for member 'body' in something not a structu=
re or union
return &bind_stmt->body;
=2Eh: In function 'gimple_bind_set_body':
=2Eh:3154:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3154:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3154:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3155:12: error: request for member 'body' in something not a structu=
re or union
bind_stmt->body =3D seq;
=2Eh: In function 'gimple_bind_add_stmt':
=2Eh:3164:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3164:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3164:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3165:34: error: request for member 'body' in something not a structu=
re or union
gimple_seq_add_stmt (&bind_stmt->body, stmt);
=2Eh: In function 'gimple_bind_add_seq':
=2Eh:3174:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3174:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3174:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3175:33: error: request for member 'body' in something not a structu=
re or union
gimple_seq_add_seq (&bind_stmt->body, seq);
=2Eh: In function 'gimple_bind_block':
=2Eh:3185:9: error: unknown type name 'gimple_statement_bind'
=2Eh:3186:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3186:11: error: expected expression before 'const'
=2Eh:3187:19: error: request for member 'block' in something not a struct=
ure or union
return bind_stmt->block;
=2Eh: In function 'gimple_bind_set_block':
=2Eh:3197:3: error: unknown type name 'gimple_statement_bind'
=2Eh:3197:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3197:44: error: 'gimple_statement_bind' undeclared (first use in thi=
s function)
=2Eh:3200:12: error: request for member 'block' in something not a struct=
ure or union
bind_stmt->block =3D block;
=2Eh: In function 'gimple_asm_ninputs':
=2Eh:3209:9: error: unknown type name 'gimple_statement_asm'
const gimple_statement_asm *asm_stmt =3D
=2Eh:3210:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_asm> (gs);
=2Eh:3210:11: error: expected expression before 'const'
=2Eh:3211:18: error: request for member 'ni' in something not a structure=
or union
return asm_stmt->ni;
=2Eh: In function 'gimple_asm_noutputs':
=2Eh:3220:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3221:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3221:11: error: expected expression before 'const'
=2Eh:3222:18: error: request for member 'no' in something not a structure=
or union
return asm_stmt->no;
=2Eh: In function 'gimple_asm_nclobbers':
=2Eh:3231:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3232:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3232:11: error: expected expression before 'const'
=2Eh:3233:18: error: request for member 'nc' in something not a structure=
or union
return asm_stmt->nc;
=2Eh: In function 'gimple_asm_nlabels':
=2Eh:3241:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3242:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3242:11: error: expected expression before 'const'
=2Eh:3243:18: error: request for member 'nl' in something not a structure=
or union
return asm_stmt->nl;
=2Eh: In function 'gimple_asm_input_op':
=2Eh:3251:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3252:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3252:11: error: expected expression before 'const'
=2Eh:3253:47: error: request for member 'ni' in something not a structure=
or union
gcc_gimple_checking_assert (index < asm_stmt->ni);
=2Eh:56:56: note: in definition of macro 'gcc_gimple_checking_assert'
#define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR)))
=2Eh:3254:41: error: request for member 'no' in something not a structure=
or union
return gimple_op (gs, index + asm_stmt->no);
=2Eh: In function 'gimple_asm_input_op_ptr':
=2Eh:3262:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3263:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3263:11: error: expected expression before 'const'
=2Eh:3264:47: error: request for member 'ni' in something not a structure=
or union
=2Eh:3265:45: error: request for member 'no' in something not a structure=
or union
return gimple_op_ptr (gs, index + asm_stmt->no);
=2Eh: In function 'gimple_asm_set_input_op':
=2Eh:3274:3: error: unknown type name 'gimple_statement_asm'
gimple_statement_asm *asm_stmt =3D as_a <gimple_statement_asm> (gs);
=2Eh:3274:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3274:42: error: 'gimple_statement_asm' undeclared (first use in this=
function)
=2Eh:3275:47: error: request for member 'ni' in something not a structure=
or union
=2Eh:3277:38: error: request for member 'no' in something not a structure=
or union
gimple_set_op (gs, index + asm_stmt->no, in_op);
=2Eh: In function 'gimple_asm_output_op':
=2Eh:3286:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3287:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3287:11: error: expected expression before 'const'
=2Eh:3288:47: error: request for member 'no' in something not a structure=
or union
gcc_gimple_checking_assert (index < asm_stmt->no);
=2Eh: In function 'gimple_asm_output_op_ptr':
=2Eh:3297:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3298:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3298:11: error: expected expression before 'const'
=2Eh:3299:47: error: request for member 'no' in something not a structure=
or union
=2Eh: In function 'gimple_asm_set_output_op':
=2Eh:3309:3: error: unknown type name 'gimple_statement_asm'
=2Eh:3309:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3309:42: error: 'gimple_statement_asm' undeclared (first use in this=
function)
=2Eh:3310:47: error: request for member 'no' in something not a structure=
or union
=2Eh: In function 'gimple_asm_clobber_op':
=2Eh:3321:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3322:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3322:11: error: expected expression before 'const'
=2Eh:3323:47: error: request for member 'nc' in something not a structure=
or union
gcc_gimple_checking_assert (index < asm_stmt->nc);
=2Eh:3324:41: error: request for member 'ni' in something not a structure=
or union
return gimple_op (gs, index + asm_stmt->ni + asm_stmt->no);
=2Eh:3324:56: error: request for member 'no' in something not a structure=
or union
=2Eh: In function 'gimple_asm_set_clobber_op':
=2Eh:3333:3: error: unknown type name 'gimple_statement_asm'
=2Eh:3333:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3333:42: error: 'gimple_statement_asm' undeclared (first use in this=
function)
=2Eh:3334:47: error: request for member 'nc' in something not a structure=
or union
=2Eh:3336:38: error: request for member 'ni' in something not a structure=
or union
gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->no, clobber_op);
=2Eh:3336:53: error: request for member 'no' in something not a structure=
or union
=2Eh: In function 'gimple_asm_label_op':
=2Eh:3344:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3345:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3345:11: error: expected expression before 'const'
=2Eh:3346:47: error: request for member 'nl' in something not a structure=
or union
gcc_gimple_checking_assert (index < asm_stmt->nl);
=2Eh:3347:41: error: request for member 'ni' in something not a structure=
or union
return gimple_op (gs, index + asm_stmt->ni + asm_stmt->nc);
=2Eh:3347:56: error: request for member 'nc' in something not a structure=
or union
=2Eh: In function 'gimple_asm_set_label_op':
=2Eh:3355:3: error: unknown type name 'gimple_statement_asm'
=2Eh:3355:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3355:42: error: 'gimple_statement_asm' undeclared (first use in this=
function)
=2Eh:3356:47: error: request for member 'nl' in something not a structure=
or union
=2Eh:3358:38: error: request for member 'ni' in something not a structure=
or union
gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->nc, label_op);
=2Eh:3358:53: error: request for member 'nc' in something not a structure=
or union
=2Eh: In function 'gimple_asm_string':
=2Eh:3367:9: error: unknown type name 'gimple_statement_asm'
=2Eh:3368:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3368:11: error: expected expression before 'const'
=2Eh:3369:18: error: request for member 'string' in something not a struc=
ture or union
return asm_stmt->string;
=2Eh: In function 'gimple_catch_types':
=2Eh:3424:9: error: unknown type name 'gimple_statement_catch'
const gimple_statement_catch *catch_stmt =3D
=2Eh:3425:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_catch> (gs);
=2Eh:3425:11: error: expected expression before 'const'
=2Eh:3426:20: error: request for member 'types' in something not a struct=
ure or union
return catch_stmt->types;
=2Eh: In function 'gimple_catch_types_ptr':
=2Eh:3435:3: error: unknown type name 'gimple_statement_catch'
gimple_statement_catch *catch_stmt =3D as_a <gimple_statement_catch> (=
gs);
=2Eh:3435:40: error: 'as_a' undeclared (first use in this function)
gs);
=2Eh:3435:46: error: 'gimple_statement_catch' undeclared (first use in th=
is function)
gs);
=2Eh:3436:21: error: request for member 'types' in something not a struct=
ure or union
return &catch_stmt->types;
=2Eh: In function 'gimple_catch_handler_ptr':
=2Eh:3446:3: error: unknown type name 'gimple_statement_catch'
gs);
=2Eh:3446:40: error: 'as_a' undeclared (first use in this function)
gs);
=2Eh:3446:46: error: 'gimple_statement_catch' undeclared (first use in th=
is function)
gs);
=2Eh:3447:21: error: request for member 'handler' in something not a stru=
cture or union
return &catch_stmt->handler;
=2Eh: In function 'gimple_catch_set_types':
=2Eh:3466:3: error: unknown type name 'gimple_statement_catch'
gs);
=2Eh:3466:40: error: 'as_a' undeclared (first use in this function)
gs);
=2Eh:3466:46: error: 'gimple_statement_catch' undeclared (first use in th=
is function)
gs);
=2Eh:3467:13: error: request for member 'types' in something not a struct=
ure or union
catch_stmt->types =3D t;
=2Eh: In function 'gimple_catch_set_handler':
=2Eh:3476:3: error: unknown type name 'gimple_statement_catch'
gs);
=2Eh:3476:40: error: 'as_a' undeclared (first use in this function)
gs);
=2Eh:3476:46: error: 'gimple_statement_catch' undeclared (first use in th=
is function)
gs);
=2Eh:3477:13: error: request for member 'handler' in something not a stru=
cture or union
catch_stmt->handler =3D handler;
=2Eh: In function 'gimple_eh_filter_types':
=2Eh:3486:9: error: unknown type name 'gimple_statement_eh_filter'
const gimple_statement_eh_filter *eh_filter_stmt =3D
=2Eh:3487:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_eh_filter> (gs);
=2Eh:3487:11: error: expected expression before 'const'
=2Eh:3488:24: error: request for member 'types' in something not a struct=
ure or union
return eh_filter_stmt->types;
=2Eh: In function 'gimple_eh_filter_types_ptr':
=2Eh:3498:3: error: unknown type name 'gimple_statement_eh_filter'
=2Eh:3499:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_eh_filter> (gs);
=2Eh:3499:11: error: 'gimple_statement_eh_filter' undeclared (first use i=
n this function)
=2Eh:3500:25: error: request for member 'types' in something not a struct=
ure or union
return &eh_filter_stmt->types;
=2Eh: In function 'gimple_eh_filter_failure_ptr':
=2Eh:3510:3: error: unknown type name 'gimple_statement_eh_filter'
=2Eh:3511:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3511:11: error: 'gimple_statement_eh_filter' undeclared (first use i=
n this function)
=2Eh:3512:25: error: request for member 'failure' in something not a stru=
cture or union
return &eh_filter_stmt->failure;
=2Eh: In function 'gimple_eh_filter_set_types':
=2Eh:3531:3: error: unknown type name 'gimple_statement_eh_filter'
=2Eh:3532:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3532:11: error: 'gimple_statement_eh_filter' undeclared (first use i=
n this function)
=2Eh:3533:17: error: request for member 'types' in something not a struct=
ure or union
eh_filter_stmt->types =3D types;
=2Eh: In function 'gimple_eh_filter_set_failure':
=2Eh:3543:3: error: unknown type name 'gimple_statement_eh_filter'
=2Eh:3544:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3544:11: error: 'gimple_statement_eh_filter' undeclared (first use i=
n this function)
=2Eh:3545:17: error: request for member 'failure' in something not a stru=
cture or union
eh_filter_stmt->failure =3D failure;
=2Eh: In function 'gimple_eh_must_not_throw_fndecl':
=2Eh:3553:3: error: unknown type name 'gimple_statement_eh_mnt'
gimple_statement_eh_mnt *eh_mnt_stmt =3D as_a <gimple_statement_eh_mnt=
> (gs);
=2Eh:3553:42: error: 'as_a' undeclared (first use in this function)
> (gs);
=2Eh:3553:48: error: 'gimple_statement_eh_mnt' undeclared (first use in t=
his function)
> (gs);
=2Eh:3554:21: error: request for member 'fndecl' in something not a struc=
ture or union
return eh_mnt_stmt->fndecl;
=2Eh: In function 'gimple_eh_must_not_throw_set_fndecl':
=2Eh:3562:3: error: unknown type name 'gimple_statement_eh_mnt'
> (gs);
=2Eh:3562:42: error: 'as_a' undeclared (first use in this function)
> (gs);
=2Eh:3562:48: error: 'gimple_statement_eh_mnt' undeclared (first use in t=
his function)
> (gs);
=2Eh:3563:14: error: request for member 'fndecl' in something not a struc=
ture or union
eh_mnt_stmt->fndecl =3D decl;
=2Eh: In function 'gimple_eh_else_n_body_ptr':
=2Eh:3571:3: error: unknown type name 'gimple_statement_eh_else'
gimple_statement_eh_else *eh_else_stmt =3D
=2Eh:3572:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_eh_else> (gs);
=2Eh:3572:11: error: 'gimple_statement_eh_else' undeclared (first use in =
this function)
=2Eh:3573:23: error: request for member 'n_body' in something not a struc=
ture or union
return &eh_else_stmt->n_body;
=2Eh: In function 'gimple_eh_else_e_body_ptr':
=2Eh:3585:3: error: unknown type name 'gimple_statement_eh_else'
=2Eh:3586:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3586:11: error: 'gimple_statement_eh_else' undeclared (first use in =
this function)
=2Eh:3587:23: error: request for member 'e_body' in something not a struc=
ture or union
return &eh_else_stmt->e_body;
=2Eh: In function 'gimple_eh_else_set_n_body':
=2Eh:3599:3: error: unknown type name 'gimple_statement_eh_else'
=2Eh:3600:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3600:11: error: 'gimple_statement_eh_else' undeclared (first use in =
this function)
=2Eh:3601:15: error: request for member 'n_body' in something not a struc=
ture or union
eh_else_stmt->n_body =3D seq;
=2Eh: In function 'gimple_eh_else_set_e_body':
=2Eh:3607:3: error: unknown type name 'gimple_statement_eh_else'
=2Eh:3608:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3608:11: error: 'gimple_statement_eh_else' undeclared (first use in =
this function)
=2Eh:3609:15: error: request for member 'e_body' in something not a struc=
ture or union
eh_else_stmt->e_body =3D seq;
=2Eh: In function 'gimple_try_eval_ptr':
=2Eh:3654:3: error: unknown type name 'gimple_statement_try'
gimple_statement_try *try_stmt =3D as_a <gimple_statement_try> (gs);
=2Eh:3654:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3654:42: error: 'gimple_statement_try' undeclared (first use in this=
function)
=2Eh:3655:19: error: request for member 'eval' in something not a structu=
re or union
return &try_stmt->eval;
=2Eh: In function 'gimple_try_cleanup_ptr':
=2Eh:3674:3: error: unknown type name 'gimple_statement_try'
=2Eh:3674:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3674:42: error: 'gimple_statement_try' undeclared (first use in this=
function)
=2Eh:3675:19: error: request for member 'cleanup' in something not a stru=
cture or union
return &try_stmt->cleanup;
=2Eh: In function 'gimple_try_set_eval':
=2Eh:3708:3: error: unknown type name 'gimple_statement_try'
=2Eh:3708:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3708:42: error: 'gimple_statement_try' undeclared (first use in this=
function)
=2Eh:3709:11: error: request for member 'eval' in something not a structu=
re or union
try_stmt->eval =3D eval;
=2Eh: In function 'gimple_try_set_cleanup':
=2Eh:3719:3: error: unknown type name 'gimple_statement_try'
=2Eh:3719:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3719:42: error: 'gimple_statement_try' undeclared (first use in this=
function)
=2Eh:3720:11: error: request for member 'cleanup' in something not a stru=
cture or union
try_stmt->cleanup =3D cleanup;
=2Eh: In function 'gimple_wce_cleanup_ptr':
=2Eh:3729:3: error: unknown type name 'gimple_statement_wce'
gimple_statement_wce *wce_stmt =3D as_a <gimple_statement_wce> (gs);
=2Eh:3729:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3729:42: error: 'gimple_statement_wce' undeclared (first use in this=
function)
=2Eh:3730:19: error: request for member 'cleanup' in something not a stru=
cture or union
return &wce_stmt->cleanup;
=2Eh: In function 'gimple_wce_set_cleanup':
=2Eh:3748:3: error: unknown type name 'gimple_statement_wce'
=2Eh:3748:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3748:42: error: 'gimple_statement_wce' undeclared (first use in this=
function)
=2Eh:3749:11: error: request for member 'cleanup' in something not a stru=
cture or union
wce_stmt->cleanup =3D cleanup;
=2Eh: In function 'gimple_phi_capacity':
=2Eh:3778:9: error: unknown type name 'gimple_statement_phi'
const gimple_statement_phi *phi_stmt =3D
=2Eh:3779:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_phi> (gs);
=2Eh:3779:11: error: expected expression before 'const'
=2Eh:3780:18: error: request for member 'capacity' in something not a str=
ucture or union
return phi_stmt->capacity;
=2Eh: In function 'gimple_phi_num_args':
=2Eh:3791:9: error: unknown type name 'gimple_statement_phi'
=2Eh:3792:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3792:11: error: expected expression before 'const'
=2Eh:3793:18: error: request for member 'nargs' in something not a struct=
ure or union
return phi_stmt->nargs;
=2Eh: In function 'gimple_phi_result':
=2Eh:3802:9: error: unknown type name 'gimple_statement_phi'
=2Eh:3803:5: error: 'as_a' undeclared (first use in this function)
=2Eh:3803:11: error: expected expression before 'const'
=2Eh:3804:18: error: request for member 'result' in something not a struc=
ture or union
return phi_stmt->result;
=2Eh: In function 'gimple_phi_result_ptr':
=2Eh:3812:3: error: unknown type name 'gimple_statement_phi'
gimple_statement_phi *phi_stmt =3D as_a <gimple_statement_phi> (gs);
=2Eh:3812:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3812:42: error: 'gimple_statement_phi' undeclared (first use in this=
function)
=2Eh:3813:19: error: request for member 'result' in something not a struc=
ture or union
return &phi_stmt->result;
=2Eh: In function 'gimple_phi_set_result':
=2Eh:3821:3: error: unknown type name 'gimple_statement_phi'
=2Eh:3821:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3821:42: error: 'gimple_statement_phi' undeclared (first use in this=
function)
=2Eh:3822:11: error: request for member 'result' in something not a struc=
ture or union
phi_stmt->result =3D result;
=2Eh: In function 'gimple_phi_arg':
=2Eh:3834:3: error: unknown type name 'gimple_statement_phi'
=2Eh:3834:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3834:42: error: 'gimple_statement_phi' undeclared (first use in this=
function)
=2Eh:3835:48: error: request for member 'capacity' in something not a str=
ucture or union
gcc_gimple_checking_assert (index <=3D phi_stmt->capacity);
=2Eh:3836:20: error: request for member 'args' in something not a structu=
re or union
return &(phi_stmt->args[index]);
=2Eh: In function 'gimple_phi_set_arg':
=2Eh:3845:3: error: unknown type name 'gimple_statement_phi'
=2Eh:3845:36: error: 'as_a' undeclared (first use in this function)
=2Eh:3845:42: error: 'gimple_statement_phi' undeclared (first use in this=
function)
=2Eh:3846:48: error: request for member 'nargs' in something not a struct=
ure or union
gcc_gimple_checking_assert (index <=3D phi_stmt->nargs);
=2Eh:3847:11: error: request for member 'args' in something not a structu=
re or union
phi_stmt->args[index] =3D *phiarg;
In file included from /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3=
from conftest.c:85:
=2Eh: In function 'phi_nodes':
=2Eh:3856:28: error: dereferencing pointer to incomplete type
=2Eh:3856:38: error: 'BB_RTL' undeclared (first use in this function)
=2Eh:3857:12: error: dereferencing pointer to incomplete type
return bb->il.gimple.phi_nodes;
from conftest.c:85:
=2Eh: In function 'phi_nodes_ptr':
=2Eh:3865:28: error: dereferencing pointer to incomplete type
=2Eh:3865:38: error: 'BB_RTL' undeclared (first use in this function)
=2Eh:3866:13: error: dereferencing pointer to incomplete type
return &bb->il.gimple.phi_nodes;
=2Eh: In function 'gimple_phi_arg_edge':
=2Eh:3891:3: warning: return makes pointer from integer without a cast
return EDGE_PRED (gimple_bb (gs), i);
=2Eh: In function 'gimple_phi_arg_location_from_edge':
=2Eh:3907:31: error: dereferencing pointer to incomplete type
return gimple_phi_arg (gs, e->dest_idx)->locus;
=2Eh: In function 'gimple_resx_region':
=2Eh:3932:9: error: unknown type name 'gimple_statement_resx'
const gimple_statement_resx *resx_stmt =3D
=2Eh:3933:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_resx> (gs);
=2Eh:3933:11: error: expected expression before 'const'
=2Eh:3934:19: error: request for member 'region' in something not a struc=
ture or union
return resx_stmt->region;
=2Eh: In function 'gimple_resx_set_region':
=2Eh:3942:3: error: unknown type name 'gimple_statement_resx'
gimple_statement_resx *resx_stmt =3D as_a <gimple_statement_resx> (gs)=
=2Eh:3942:38: error: 'as_a' undeclared (first use in this function)
=2Eh:3942:44: error: 'gimple_statement_resx' undeclared (first use in thi=
s function)
=2Eh:3943:12: error: request for member 'region' in something not a struc=
ture or union
resx_stmt->region =3D region;
=2Eh: In function 'gimple_eh_dispatch_region':
=2Eh:3951:9: error: unknown type name 'gimple_statement_eh_dispatch'
const gimple_statement_eh_dispatch *eh_dispatch_stmt =3D
=2Eh:3952:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_eh_dispatch> (gs);
=2Eh:3952:11: error: expected expression before 'const'
=2Eh:3953:26: error: request for member 'region' in something not a struc=
ture or union
return eh_dispatch_stmt->region;
=2Eh: In function 'gimple_eh_dispatch_set_region':
=2Eh:3961:3: error: unknown type name 'gimple_statement_eh_dispatch'
=2Eh:3962:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_eh_dispatch> (gs);
=2Eh:3962:11: error: 'gimple_statement_eh_dispatch' undeclared (first use=
in this function)
=2Eh:3963:19: error: request for member 'region' in something not a struc=
ture or union
eh_dispatch_stmt->region =3D region;
=2Eh: In function 'gimple_omp_body_ptr':
=2Eh:4248:11: error: 'static_cast' undeclared (first use in this function=
return &static_cast <gimple_statement_omp *> (gs)->body;
=2Eh:4248:24: error: 'gimple_statement_omp' undeclared (first use in this=
function)
=2Eh:4248:46: error: expected expression before '>' token
=2Eh: In function 'gimple_omp_set_body':
=2Eh:4264:3: error: 'static_cast' undeclared (first use in this function)=
static_cast <gimple_statement_omp *> (gs)->body =3D body;
=2Eh:4264:16: error: 'gimple_statement_omp' undeclared (first use in this=
function)
=2Eh:4264:38: error: expected expression before '>' token
=2Eh: In function 'gimple_omp_critical_name':
=2Eh:4273:9: error: unknown type name 'gimple_statement_omp_critical'
const gimple_statement_omp_critical *omp_critical_stmt =3D
=2Eh:4274:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_critical> (gs);
=2Eh:4274:11: error: expected expression before 'const'
=2Eh:4275:27: error: request for member 'name' in something not a structu=
re or union
return omp_critical_stmt->name;
=2Eh: In function 'gimple_omp_critical_name_ptr':
=2Eh:4284:3: error: unknown type name 'gimple_statement_omp_critical'
=2Eh:4285:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_critical> (gs);
=2Eh:4285:11: error: 'gimple_statement_omp_critical' undeclared (first us=
e in this function)
=2Eh:4286:28: error: request for member 'name' in something not a structu=
re or union
return &omp_critical_stmt->name;
=2Eh: In function 'gimple_omp_critical_set_name':
=2Eh:4295:3: error: unknown type name 'gimple_statement_omp_critical'
=2Eh:4296:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4296:11: error: 'gimple_statement_omp_critical' undeclared (first us=
e in this function)
=2Eh:4297:20: error: request for member 'name' in something not a structu=
re or union
omp_critical_stmt->name =3D name;
=2Eh: In function 'gimple_omp_for_clauses':
=2Eh:4377:9: error: unknown type name 'gimple_statement_omp_for'
const gimple_statement_omp_for *omp_for_stmt =3D
=2Eh:4378:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_for> (gs);
=2Eh:4378:11: error: expected expression before 'const'
=2Eh:4379:22: error: request for member 'clauses' in something not a stru=
cture or union
return omp_for_stmt->clauses;
=2Eh: In function 'gimple_omp_for_clauses_ptr':
=2Eh:4388:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4389:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_for> (gs);
=2Eh:4389:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4390:23: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_for_stmt->clauses;
=2Eh: In function 'gimple_omp_for_set_clauses':
=2Eh:4399:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4400:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4400:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4401:15: error: request for member 'clauses' in something not a stru=
cture or union
omp_for_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_for_collapse':
=2Eh:4410:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4411:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4411:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4412:22: error: request for member 'collapse' in something not a str=
ucture or union
return omp_for_stmt->collapse;
=2Eh: In function 'gimple_omp_for_index':
=2Eh:4421:9: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4422:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4422:11: error: expected expression before 'const'
=2Eh:4423:47: error: request for member 'collapse' in something not a str=
ucture or union
gcc_gimple_checking_assert (i < omp_for_stmt->collapse);
=2Eh:4424:22: error: request for member 'iter' in something not a structu=
re or union
return omp_for_stmt->iter[i].index;
=2Eh: In function 'gimple_omp_for_index_ptr':
=2Eh:4433:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4434:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4434:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4435:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4436:23: error: request for member 'iter' in something not a structu=
re or union
return &omp_for_stmt->iter[i].index;
=2Eh: In function 'gimple_omp_for_set_index':
=2Eh:4445:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4446:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4446:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4447:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4448:15: error: request for member 'iter' in something not a structu=
re or union
omp_for_stmt->iter[i].index =3D index;
=2Eh: In function 'gimple_omp_for_initial':
=2Eh:4457:9: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4458:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4458:11: error: expected expression before 'const'
=2Eh:4459:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4460:22: error: request for member 'iter' in something not a structu=
re or union
return omp_for_stmt->iter[i].initial;
=2Eh: In function 'gimple_omp_for_initial_ptr':
=2Eh:4469:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4470:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4470:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4471:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4472:23: error: request for member 'iter' in something not a structu=
re or union
return &omp_for_stmt->iter[i].initial;
=2Eh: In function 'gimple_omp_for_set_initial':
=2Eh:4481:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4482:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4482:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4483:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4484:15: error: request for member 'iter' in something not a structu=
re or union
omp_for_stmt->iter[i].initial =3D initial;
=2Eh: In function 'gimple_omp_for_final':
=2Eh:4493:9: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4494:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4494:11: error: expected expression before 'const'
=2Eh:4495:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4496:22: error: request for member 'iter' in something not a structu=
re or union
return omp_for_stmt->iter[i].final;
=2Eh: In function 'gimple_omp_for_final_ptr':
=2Eh:4505:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4506:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4506:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4507:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4508:23: error: request for member 'iter' in something not a structu=
re or union
return &omp_for_stmt->iter[i].final;
=2Eh: In function 'gimple_omp_for_set_final':
=2Eh:4517:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4518:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4518:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4519:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4520:15: error: request for member 'iter' in something not a structu=
re or union
omp_for_stmt->iter[i].final =3D final;
=2Eh: In function 'gimple_omp_for_incr':
=2Eh:4529:9: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4530:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4530:11: error: expected expression before 'const'
=2Eh:4531:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4532:22: error: request for member 'iter' in something not a structu=
re or union
return omp_for_stmt->iter[i].incr;
=2Eh: In function 'gimple_omp_for_incr_ptr':
=2Eh:4541:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4542:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4542:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4543:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4544:23: error: request for member 'iter' in something not a structu=
re or union
return &omp_for_stmt->iter[i].incr;
=2Eh: In function 'gimple_omp_for_set_incr':
=2Eh:4553:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4554:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4554:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4555:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:4556:15: error: request for member 'iter' in something not a structu=
re or union
omp_for_stmt->iter[i].incr =3D incr;
=2Eh: In function 'gimple_omp_for_pre_body_ptr':
=2Eh:4566:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4567:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4567:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4568:23: error: request for member 'pre_body' in something not a str=
ucture or union
return &omp_for_stmt->pre_body;
=2Eh: In function 'gimple_omp_for_set_pre_body':
=2Eh:4588:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:4589:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4589:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
=2Eh:4590:15: error: request for member 'pre_body' in something not a str=
ucture or union
omp_for_stmt->pre_body =3D pre_body;
=2Eh: In function 'gimple_omp_parallel_clauses':
=2Eh:4599:9: error: unknown type name 'gimple_statement_omp_parallel'
const gimple_statement_omp_parallel *omp_parallel_stmt =3D
=2Eh:4600:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_parallel> (gs);
=2Eh:4600:11: error: expected expression before 'const'
=2Eh:4601:27: error: request for member 'clauses' in something not a stru=
cture or union
return omp_parallel_stmt->clauses;
=2Eh: In function 'gimple_omp_parallel_clauses_ptr':
=2Eh:4610:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4611:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_parallel> (gs);
=2Eh:4611:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4612:28: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_parallel_stmt->clauses;
=2Eh: In function 'gimple_omp_parallel_set_clauses':
=2Eh:4622:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4623:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4623:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4624:20: error: request for member 'clauses' in something not a stru=
cture or union
omp_parallel_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_parallel_child_fn':
=2Eh:4633:9: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4634:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4634:11: error: expected expression before 'const'
=2Eh:4635:27: error: request for member 'child_fn' in something not a str=
ucture or union
return omp_parallel_stmt->child_fn;
=2Eh: In function 'gimple_omp_parallel_child_fn_ptr':
=2Eh:4644:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4645:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4645:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4646:28: error: request for member 'child_fn' in something not a str=
ucture or union
return &omp_parallel_stmt->child_fn;
=2Eh: In function 'gimple_omp_parallel_set_child_fn':
=2Eh:4655:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4656:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4656:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4657:20: error: request for member 'child_fn' in something not a str=
ucture or union
omp_parallel_stmt->child_fn =3D child_fn;
=2Eh: In function 'gimple_omp_parallel_data_arg':
=2Eh:4667:9: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4668:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4668:11: error: expected expression before 'const'
=2Eh:4669:27: error: request for member 'data_arg' in something not a str=
ucture or union
return omp_parallel_stmt->data_arg;
=2Eh: In function 'gimple_omp_parallel_data_arg_ptr':
=2Eh:4678:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4679:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4679:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4680:28: error: request for member 'data_arg' in something not a str=
ucture or union
return &omp_parallel_stmt->data_arg;
=2Eh: In function 'gimple_omp_parallel_set_data_arg':
=2Eh:4689:3: error: unknown type name 'gimple_statement_omp_parallel'
=2Eh:4690:5: error: 'as_a' undeclared (first use in this function)
/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple=
=2Eh:4690:11: error: 'gimple_statement_omp_parallel' undeclared (first us=
e in this function)
=2Eh:4691:20: error: request for member 'data_arg' in something not a str=
ucture or union
omp_parallel_stmt->data_arg =3D data_arg;
=2Eh: In function 'gimple_omp_task_clauses':
=2Eh:4700:9: error: unknown type name 'gimple_statement_omp_task'
const gimple_statement_omp_task *omp_task_stmt =3D
=2Eh:4701:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_task> (gs);
=2Eh:4701:11: error: expected expression before 'const'
=2Eh:4702:23: error: request for member 'clauses' in something not a stru=
cture or union
return omp_task_stmt->clauses;
=2Eh: In function 'gimple_omp_task_clauses_ptr':
=2Eh:4711:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4712:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_task> (gs);
=2Eh:4712:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4713:24: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_task_stmt->clauses;
=2Eh: In function 'gimple_omp_task_set_clauses':
=2Eh:4723:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4724:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4724:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4725:16: error: request for member 'clauses' in something not a stru=
cture or union
omp_task_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_task_child_fn':
=2Eh:4734:9: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4735:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4735:11: error: expected expression before 'const'
=2Eh:4736:23: error: request for member 'child_fn' in something not a str=
ucture or union
return omp_task_stmt->child_fn;
=2Eh: In function 'gimple_omp_task_child_fn_ptr':
=2Eh:4745:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4746:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4746:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4747:24: error: request for member 'child_fn' in something not a str=
ucture or union
return &omp_task_stmt->child_fn;
=2Eh: In function 'gimple_omp_task_set_child_fn':
=2Eh:4756:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4757:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4757:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4758:16: error: request for member 'child_fn' in something not a str=
ucture or union
omp_task_stmt->child_fn =3D child_fn;
=2Eh: In function 'gimple_omp_task_data_arg':
=2Eh:4768:9: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4769:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4769:11: error: expected expression before 'const'
=2Eh:4770:23: error: request for member 'data_arg' in something not a str=
ucture or union
return omp_task_stmt->data_arg;
=2Eh: In function 'gimple_omp_task_data_arg_ptr':
=2Eh:4779:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4780:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4780:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4781:24: error: request for member 'data_arg' in something not a str=
ucture or union
return &omp_task_stmt->data_arg;
=2Eh: In function 'gimple_omp_task_set_data_arg':
=2Eh:4790:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4791:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4791:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4792:16: error: request for member 'data_arg' in something not a str=
ucture or union
omp_task_stmt->data_arg =3D data_arg;
=2Eh: In function 'gimple_omp_taskreg_clauses':
=2Eh:4801:9: error: unknown type name 'gimple_statement_omp_taskreg'
const gimple_statement_omp_taskreg *omp_taskreg_stmt =3D
=2Eh:4802:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_taskreg> (gs);
=2Eh:4802:11: error: expected expression before 'const'
=2Eh:4803:26: error: request for member 'clauses' in something not a stru=
cture or union
return omp_taskreg_stmt->clauses;
=2Eh: In function 'gimple_omp_taskreg_clauses_ptr':
=2Eh:4812:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4813:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_taskreg> (gs);
=2Eh:4813:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4814:27: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_taskreg_stmt->clauses;
=2Eh: In function 'gimple_omp_taskreg_set_clauses':
=2Eh:4824:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4825:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4825:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4826:19: error: request for member 'clauses' in something not a stru=
cture or union
omp_taskreg_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_taskreg_child_fn':
=2Eh:4835:9: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4836:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4836:11: error: expected expression before 'const'
=2Eh:4837:26: error: request for member 'child_fn' in something not a str=
ucture or union
return omp_taskreg_stmt->child_fn;
=2Eh: In function 'gimple_omp_taskreg_child_fn_ptr':
=2Eh:4846:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4847:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4847:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4848:27: error: request for member 'child_fn' in something not a str=
ucture or union
return &omp_taskreg_stmt->child_fn;
=2Eh: In function 'gimple_omp_taskreg_set_child_fn':
=2Eh:4857:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4858:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4858:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4859:19: error: request for member 'child_fn' in something not a str=
ucture or union
omp_taskreg_stmt->child_fn =3D child_fn;
=2Eh: In function 'gimple_omp_taskreg_data_arg':
=2Eh:4869:9: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4870:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4870:11: error: expected expression before 'const'
=2Eh:4871:26: error: request for member 'data_arg' in something not a str=
ucture or union
return omp_taskreg_stmt->data_arg;
=2Eh: In function 'gimple_omp_taskreg_data_arg_ptr':
=2Eh:4880:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4881:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4881:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4882:27: error: request for member 'data_arg' in something not a str=
ucture or union
return &omp_taskreg_stmt->data_arg;
=2Eh: In function 'gimple_omp_taskreg_set_data_arg':
=2Eh:4891:3: error: unknown type name 'gimple_statement_omp_taskreg'
=2Eh:4892:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4892:11: error: 'gimple_statement_omp_taskreg' undeclared (first use=
in this function)
=2Eh:4893:19: error: request for member 'data_arg' in something not a str=
ucture or union
omp_taskreg_stmt->data_arg =3D data_arg;
=2Eh: In function 'gimple_omp_task_copy_fn':
=2Eh:4902:9: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4903:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4903:11: error: expected expression before 'const'
=2Eh:4904:23: error: request for member 'copy_fn' in something not a stru=
cture or union
return omp_task_stmt->copy_fn;
=2Eh: In function 'gimple_omp_task_copy_fn_ptr':
=2Eh:4913:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4914:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4914:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4915:24: error: request for member 'copy_fn' in something not a stru=
cture or union
return &omp_task_stmt->copy_fn;
=2Eh: In function 'gimple_omp_task_set_copy_fn':
=2Eh:4924:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4925:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4925:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4926:16: error: request for member 'copy_fn' in something not a stru=
cture or union
omp_task_stmt->copy_fn =3D copy_fn;
=2Eh: In function 'gimple_omp_task_arg_size':
=2Eh:4935:9: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4936:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4936:11: error: expected expression before 'const'
=2Eh:4937:23: error: request for member 'arg_size' in something not a str=
ucture or union
return omp_task_stmt->arg_size;
=2Eh: In function 'gimple_omp_task_arg_size_ptr':
=2Eh:4946:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4947:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4947:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4948:24: error: request for member 'arg_size' in something not a str=
ucture or union
return &omp_task_stmt->arg_size;
=2Eh: In function 'gimple_omp_task_set_arg_size':
=2Eh:4957:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4958:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4958:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4959:16: error: request for member 'arg_size' in something not a str=
ucture or union
omp_task_stmt->arg_size =3D arg_size;
=2Eh: In function 'gimple_omp_task_arg_align':
=2Eh:4968:9: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4969:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4969:11: error: expected expression before 'const'
=2Eh:4970:23: error: request for member 'arg_align' in something not a st=
ructure or union
return omp_task_stmt->arg_align;
=2Eh: In function 'gimple_omp_task_arg_align_ptr':
=2Eh:4979:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4980:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4980:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4981:24: error: request for member 'arg_align' in something not a st=
ructure or union
return &omp_task_stmt->arg_align;
=2Eh: In function 'gimple_omp_task_set_arg_align':
=2Eh:4990:3: error: unknown type name 'gimple_statement_omp_task'
=2Eh:4991:5: error: 'as_a' undeclared (first use in this function)
=2Eh:4991:11: error: 'gimple_statement_omp_task' undeclared (first use in=
this function)
=2Eh:4992:16: error: request for member 'arg_align' in something not a st=
ructure or union
omp_task_stmt->arg_align =3D arg_align;
=2Eh: In function 'gimple_omp_single_clauses':
=2Eh:5001:9: error: unknown type name 'gimple_statement_omp_single'
const gimple_statement_omp_single *omp_single_stmt =3D
=2Eh:5002:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_single> (gs);
=2Eh:5002:11: error: expected expression before 'const'
=2Eh:5003:25: error: request for member 'clauses' in something not a stru=
cture or union
return omp_single_stmt->clauses;
=2Eh: In function 'gimple_omp_single_clauses_ptr':
=2Eh:5012:3: error: unknown type name 'gimple_statement_omp_single'
=2Eh:5013:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_single> (gs);
=2Eh:5013:11: error: 'gimple_statement_omp_single' undeclared (first use =
in this function)
=2Eh:5014:26: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_single_stmt->clauses;
=2Eh: In function 'gimple_omp_single_set_clauses':
=2Eh:5023:3: error: unknown type name 'gimple_statement_omp_single'
=2Eh:5024:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5024:11: error: 'gimple_statement_omp_single' undeclared (first use =
in this function)
=2Eh:5025:18: error: request for member 'clauses' in something not a stru=
cture or union
omp_single_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_target_clauses':
=2Eh:5034:9: error: unknown type name 'gimple_statement_omp_target'
const gimple_statement_omp_target *omp_target_stmt =3D
=2Eh:5035:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_target> (gs);
=2Eh:5035:11: error: expected expression before 'const'
=2Eh:5036:25: error: request for member 'clauses' in something not a stru=
cture or union
return omp_target_stmt->clauses;
=2Eh: In function 'gimple_omp_target_clauses_ptr':
=2Eh:5045:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5046:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_target> (gs);
=2Eh:5046:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5047:26: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_target_stmt->clauses;
=2Eh: In function 'gimple_omp_target_set_clauses':
=2Eh:5056:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5057:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5057:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5058:18: error: request for member 'clauses' in something not a stru=
cture or union
omp_target_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_target_child_fn':
=2Eh:5088:9: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5089:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5089:11: error: expected expression before 'const'
=2Eh:5090:25: error: request for member 'child_fn' in something not a str=
ucture or union
return omp_target_stmt->child_fn;
=2Eh: In function 'gimple_omp_target_child_fn_ptr':
=2Eh:5099:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5100:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5100:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5101:26: error: request for member 'child_fn' in something not a str=
ucture or union
return &omp_target_stmt->child_fn;
=2Eh: In function 'gimple_omp_target_set_child_fn':
=2Eh:5110:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5111:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5111:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5112:18: error: request for member 'child_fn' in something not a str=
ucture or union
omp_target_stmt->child_fn =3D child_fn;
=2Eh: In function 'gimple_omp_target_data_arg':
=2Eh:5122:9: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5123:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5123:11: error: expected expression before 'const'
=2Eh:5124:25: error: request for member 'data_arg' in something not a str=
ucture or union
return omp_target_stmt->data_arg;
=2Eh: In function 'gimple_omp_target_data_arg_ptr':
=2Eh:5133:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5134:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5134:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5135:26: error: request for member 'data_arg' in something not a str=
ucture or union
return &omp_target_stmt->data_arg;
=2Eh: In function 'gimple_omp_target_set_data_arg':
=2Eh:5144:3: error: unknown type name 'gimple_statement_omp_target'
=2Eh:5145:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5145:11: error: 'gimple_statement_omp_target' undeclared (first use =
in this function)
=2Eh:5146:18: error: request for member 'data_arg' in something not a str=
ucture or union
omp_target_stmt->data_arg =3D data_arg;
=2Eh: In function 'gimple_omp_teams_clauses':
=2Eh:5155:9: error: unknown type name 'gimple_statement_omp_teams'
const gimple_statement_omp_teams *omp_teams_stmt =3D
=2Eh:5156:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_teams> (gs);
=2Eh:5156:11: error: expected expression before 'const'
=2Eh:5157:24: error: request for member 'clauses' in something not a stru=
cture or union
return omp_teams_stmt->clauses;
=2Eh: In function 'gimple_omp_teams_clauses_ptr':
=2Eh:5166:3: error: unknown type name 'gimple_statement_omp_teams'
=2Eh:5167:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_teams> (gs);
=2Eh:5167:11: error: 'gimple_statement_omp_teams' undeclared (first use i=
n this function)
=2Eh:5168:25: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_teams_stmt->clauses;
=2Eh: In function 'gimple_omp_teams_set_clauses':
=2Eh:5177:3: error: unknown type name 'gimple_statement_omp_teams'
=2Eh:5178:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5178:11: error: 'gimple_statement_omp_teams' undeclared (first use i=
n this function)
=2Eh:5179:17: error: request for member 'clauses' in something not a stru=
cture or union
omp_teams_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_sections_clauses':
=2Eh:5188:9: error: unknown type name 'gimple_statement_omp_sections'
const gimple_statement_omp_sections *omp_sections_stmt =3D
=2Eh:5189:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_sections> (gs);
=2Eh:5189:11: error: expected expression before 'const'
=2Eh:5190:27: error: request for member 'clauses' in something not a stru=
cture or union
return omp_sections_stmt->clauses;
=2Eh: In function 'gimple_omp_sections_clauses_ptr':
=2Eh:5199:3: error: unknown type name 'gimple_statement_omp_sections'
=2Eh:5200:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_sections> (gs);
=2Eh:5200:11: error: 'gimple_statement_omp_sections' undeclared (first us=
e in this function)
=2Eh:5201:28: error: request for member 'clauses' in something not a stru=
cture or union
return &omp_sections_stmt->clauses;
=2Eh: In function 'gimple_omp_sections_set_clauses':
=2Eh:5211:3: error: unknown type name 'gimple_statement_omp_sections'
=2Eh:5212:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5212:11: error: 'gimple_statement_omp_sections' undeclared (first us=
e in this function)
=2Eh:5213:20: error: request for member 'clauses' in something not a stru=
cture or union
omp_sections_stmt->clauses =3D clauses;
=2Eh: In function 'gimple_omp_sections_control':
=2Eh:5223:9: error: unknown type name 'gimple_statement_omp_sections'
=2Eh:5224:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5224:11: error: expected expression before 'const'
=2Eh:5225:27: error: request for member 'control' in something not a stru=
cture or union
return omp_sections_stmt->control;
=2Eh: In function 'gimple_omp_sections_control_ptr':
=2Eh:5235:3: error: unknown type name 'gimple_statement_omp_sections'
=2Eh:5236:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5236:11: error: 'gimple_statement_omp_sections' undeclared (first us=
e in this function)
=2Eh:5237:28: error: request for member 'control' in something not a stru=
cture or union
return &omp_sections_stmt->control;
=2Eh: In function 'gimple_omp_sections_set_control':
=2Eh:5247:3: error: unknown type name 'gimple_statement_omp_sections'
=2Eh:5248:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5248:11: error: 'gimple_statement_omp_sections' undeclared (first us=
e in this function)
=2Eh:5249:20: error: request for member 'control' in something not a stru=
cture or union
omp_sections_stmt->control =3D control;
=2Eh: In function 'gimple_omp_for_set_cond':
=2Eh:5258:3: error: unknown type name 'gimple_statement_omp_for'
=2Eh:5259:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5259:11: error: 'gimple_statement_omp_for' undeclared (first use in =
this function)
In file included from conftest.c:87:0:
=2Eh:5261:29: error: request for member 'collapse' in something not a str=
ucture or union
&& i < omp_for_stmt->collapse);
=2Eh:5262:15: error: request for member 'iter' in something not a structu=
re or union
omp_for_stmt->iter[i].cond =3D cond;
=2Eh: In function 'gimple_omp_for_cond':
=2Eh:5271:9: error: unknown type name 'gimple_statement_omp_for'
=2Eh:5272:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5272:11: error: expected expression before 'const'
=2Eh:5273:47: error: request for member 'collapse' in something not a str=
ucture or union
=2Eh:5274:22: error: request for member 'iter' in something not a structu=
re or union
return omp_for_stmt->iter[i].cond;
=2Eh: In function 'gimple_omp_atomic_store_set_val':
=2Eh:5283:3: error: unknown type name 'gimple_statement_omp_atomic_store'=
gimple_statement_omp_atomic_store *omp_atomic_store_stmt =3D
=2Eh:5284:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_atomic_store> (g);
=2Eh:5284:11: error: 'gimple_statement_omp_atomic_store' undeclared (firs=
=2Eh:5285:24: error: request for member 'val' in something not a structur=
e or union
omp_atomic_store_stmt->val =3D val;
=2Eh: In function 'gimple_omp_atomic_store_val':
=2Eh:5294:9: error: unknown type name 'gimple_statement_omp_atomic_store'=
const gimple_statement_omp_atomic_store *omp_atomic_store_stmt =3D
=2Eh:5295:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_atomic_store> (g);
=2Eh:5295:11: error: expected expression before 'const'
=2Eh:5296:31: error: request for member 'val' in something not a structur=
e or union
return omp_atomic_store_stmt->val;
=2Eh: In function 'gimple_omp_atomic_store_val_ptr':
=2Eh:5305:3: error: unknown type name 'gimple_statement_omp_atomic_store'=
=2Eh:5306:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5306:11: error: 'gimple_statement_omp_atomic_store' undeclared (firs=
=2Eh:5307:32: error: request for member 'val' in something not a structur=
e or union
return &omp_atomic_store_stmt->val;
=2Eh: In function 'gimple_omp_atomic_load_set_lhs':
=2Eh:5316:3: error: unknown type name 'gimple_statement_omp_atomic_load'
gimple_statement_omp_atomic_load *omp_atomic_load_stmt =3D
=2Eh:5317:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_atomic_load> (g);
=2Eh:5317:11: error: 'gimple_statement_omp_atomic_load' undeclared (first=
=2Eh:5318:23: error: request for member 'lhs' in something not a structur=
e or union
omp_atomic_load_stmt->lhs =3D lhs;
=2Eh: In function 'gimple_omp_atomic_load_lhs':
=2Eh:5327:9: error: unknown type name 'gimple_statement_omp_atomic_load'
const gimple_statement_omp_atomic_load *omp_atomic_load_stmt =3D
=2Eh:5328:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_atomic_load> (g);
=2Eh:5328:11: error: expected expression before 'const'
=2Eh:5329:30: error: request for member 'lhs' in something not a structur=
e or union
return omp_atomic_load_stmt->lhs;
=2Eh: In function 'gimple_omp_atomic_load_lhs_ptr':
=2Eh:5338:3: error: unknown type name 'gimple_statement_omp_atomic_load'
=2Eh:5339:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5339:11: error: 'gimple_statement_omp_atomic_load' undeclared (first=
=2Eh:5340:31: error: request for member 'lhs' in something not a structur=
e or union
return &omp_atomic_load_stmt->lhs;
=2Eh: In function 'gimple_omp_atomic_load_set_rhs':
=2Eh:5349:3: error: unknown type name 'gimple_statement_omp_atomic_load'
=2Eh:5350:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5350:11: error: 'gimple_statement_omp_atomic_load' undeclared (first=
=2Eh:5351:23: error: request for member 'rhs' in something not a structur=
e or union
omp_atomic_load_stmt->rhs =3D rhs;
=2Eh: In function 'gimple_omp_atomic_load_rhs':
=2Eh:5360:9: error: unknown type name 'gimple_statement_omp_atomic_load'
=2Eh:5361:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5361:11: error: expected expression before 'const'
=2Eh:5362:30: error: request for member 'rhs' in something not a structur=
e or union
return omp_atomic_load_stmt->rhs;
=2Eh: In function 'gimple_omp_atomic_load_rhs_ptr':
=2Eh:5371:3: error: unknown type name 'gimple_statement_omp_atomic_load'
=2Eh:5372:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5372:11: error: 'gimple_statement_omp_atomic_load' undeclared (first=
=2Eh:5373:31: error: request for member 'rhs' in something not a structur=
e or union
return &omp_atomic_load_stmt->rhs;
=2Eh: In function 'gimple_omp_continue_control_def':
=2Eh:5382:9: error: unknown type name 'gimple_statement_omp_continue'
const gimple_statement_omp_continue *omp_continue_stmt =3D
=2Eh:5383:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_omp_continue> (g);
=2Eh:5383:11: error: expected expression before 'const'
=2Eh:5384:27: error: request for member 'control_def' in something not a =
structure or union
return omp_continue_stmt->control_def;
=2Eh: In function 'gimple_omp_continue_control_def_ptr':
=2Eh:5392:3: error: unknown type name 'gimple_statement_omp_continue'
=2Eh:5393:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_omp_continue> (g);
=2Eh:5393:11: error: 'gimple_statement_omp_continue' undeclared (first us=
e in this function)
=2Eh:5394:28: error: request for member 'control_def' in something not a =
structure or union
return &omp_continue_stmt->control_def;
=2Eh: In function 'gimple_omp_continue_set_control_def':
=2Eh:5402:3: error: unknown type name 'gimple_statement_omp_continue'
=2Eh:5403:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5403:11: error: 'gimple_statement_omp_continue' undeclared (first us=
e in this function)
=2Eh:5404:20: error: request for member 'control_def' in something not a =
structure or union
omp_continue_stmt->control_def =3D def;
=2Eh: In function 'gimple_omp_continue_control_use':
=2Eh:5413:9: error: unknown type name 'gimple_statement_omp_continue'
=2Eh:5414:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5414:11: error: expected expression before 'const'
=2Eh:5415:27: error: request for member 'control_use' in something not a =
structure or union
return omp_continue_stmt->control_use;
=2Eh: In function 'gimple_omp_continue_control_use_ptr':
=2Eh:5424:3: error: unknown type name 'gimple_statement_omp_continue'
=2Eh:5425:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5425:11: error: 'gimple_statement_omp_continue' undeclared (first us=
e in this function)
=2Eh:5426:28: error: request for member 'control_use' in something not a =
structure or union
return &omp_continue_stmt->control_use;
=2Eh: In function 'gimple_omp_continue_set_control_use':
=2Eh:5435:3: error: unknown type name 'gimple_statement_omp_continue'
=2Eh:5436:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5436:11: error: 'gimple_statement_omp_continue' undeclared (first us=
e in this function)
=2Eh:5437:20: error: request for member 'control_use' in something not a =
structure or union
omp_continue_stmt->control_use =3D use;
=2Eh: In function 'gimple_transaction_body_ptr':
=2Eh:5445:3: error: unknown type name 'gimple_statement_transaction'
gimple_statement_transaction *transaction_stmt =3D
=2Eh:5446:5: error: 'as_a' undeclared (first use in this function)
as_a <gimple_statement_transaction> (gs);
=2Eh:5446:11: error: 'gimple_statement_transaction' undeclared (first use=
in this function)
=2Eh:5447:27: error: request for member 'body' in something not a structu=
re or union
return &transaction_stmt->body;
=2Eh: In function 'gimple_transaction_label':
=2Eh:5463:9: error: unknown type name 'gimple_statement_transaction'
const gimple_statement_transaction *transaction_stmt =3D
=2Eh:5464:5: error: 'as_a' undeclared (first use in this function)
as_a <const gimple_statement_transaction> (gs);
=2Eh:5464:11: error: expected expression before 'const'
=2Eh:5465:26: error: request for member 'label' in something not a struct=
ure or union
return transaction_stmt->label;
=2Eh: In function 'gimple_transaction_label_ptr':
=2Eh:5471:3: error: unknown type name 'gimple_statement_transaction'
=2Eh:5472:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5472:11: error: 'gimple_statement_transaction' undeclared (first use=
in this function)
=2Eh:5473:27: error: request for member 'label' in something not a struct=
ure or union
return &transaction_stmt->label;
=2Eh: In function 'gimple_transaction_set_body':
=2Eh:5490:3: error: unknown type name 'gimple_statement_transaction'
=2Eh:5491:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5491:11: error: 'gimple_statement_transaction' undeclared (first use=
in this function)
=2Eh:5492:19: error: request for member 'body' in something not a structu=
re or union
transaction_stmt->body =3D body;
=2Eh: In function 'gimple_transaction_set_label':
=2Eh:5500:3: error: unknown type name 'gimple_statement_transaction'
=2Eh:5501:5: error: 'as_a' undeclared (first use in this function)
=2Eh:5501:11: error: 'gimple_statement_transaction' undeclared (first use=
in this function)
=2Eh:5502:19: error: request for member 'label' in something not a struct=
ure or union
transaction_stmt->label =3D label;
=2Eh: At top level:
=2Eh:5598:1: error: return type is an incomplete type
gimple_predict_predictor (gimple gs)
=2Eh: In function 'gimple_predict_predictor':
=2Eh:5601:16: error: conversion to incomplete type
return (enum br_predictor) (gs->subcode & ~GF_PREDICT_TAKEN);
=2Eh:5601:3: warning: 'return' with a value, in function returning void
=2Eh: At top level:
=2Eh:5608:60: error: parameter 2 ('predictor') has incomplete type
gimple_predict_set_predictor (gimple gs, enum br_predictor predictor)
=2Eh:5619:1: error: return type is an incomplete type
gimple_predict_outcome (gimple gs)
=2Eh: In function 'gimple_predict_outcome':
=2Eh:5622:45: error: 'TAKEN' undeclared (first use in this function)
return (gs->subcode & GF_PREDICT_TAKEN) ? TAKEN : NOT_TAKEN;
=2Eh:5622:53: error: 'NOT_TAKEN' undeclared (first use in this function)
=2Eh:5622:3: warning: 'return' with a value, in function returning void
=2Eh: At top level:
=2Eh:5629:56: error: parameter 2 ('outcome') has incomplete type
gimple_predict_set_outcome (gimple gs, enum prediction outcome)
=2Eh: In function 'gimple_predict_set_outcome':
=2Eh:5632:18: error: 'TAKEN' undeclared (first use in this function)
if (outcome =3D=3D TAKEN)
=2Eh: In function 'gimple_expr_type':
=2Eh:5657:45: error: 'IFN_MASK_STORE' undeclared (first use in this funct=
ion)
&& gimple_call_internal_fn (stmt) =3D=3D IFN_MASK_STORE)
=2Eh:5657:8: error: void value not ignored as it ought to be
conftest.c: At top level:
conftest.c:90:45: warning: missing terminating ' character
Beware, this compiler is a fake. Don't use it.
conftest.c: In function 'foo':
conftest.c:101:10: warning: return makes pointer from integer without a c=
ast
return lookup_name (get_identifier ("puts"));
configure:31133: $? =3D 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.2.0rc4"
| #define PACKAGE_STRING "StarPU 1.2.0rc4"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 2
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.2.0rc4"
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/project/k1044/favergm/src/starpu-1.2.0rc4"
| #define STARPU_SRC_DIR "/lustre/project/k1044/favergm/src/starpu-1.2.0r=
c4/."
| #define HAVE_LIBPTHREAD 1
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #define STARPU_HAVE_LIBNUMA /**/
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #define STARPU_USE_MP 1
| #define STARPU_MAXMPKERNELS 10
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 4
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 64
| #define STARPU_NMAX_COMBINEDWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #define STARPU_HISTORYMAXERROR 50
| /* end confdefs.h. */
| #include <gcc-plugin.h>
| #include <tree.h>
| #include <gimple.h>
|=20
| #if defined __INTEL_COMPILER || defined __ICC
| #endif
|=20
| tree fndecl; gimple call;
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| discriminate it this way. */
| tree foo (void)
| fndecl =3D foo ();
| call =3D gimple_build_call (fndecl, 0);
| return 0;
configure:31149: result: no
configure:31433: WARNING: GCC plug-ins not supported; StarPU's GCC plug-i=
n will not be built
configure:31571: checking for OpenMP runtime support
configure:31588: result: no
configure:31605: checking for SOCL
configure:31620: result: no
configure:31669: checking for gdb
configure:31687: found /usr/bin/gdb
configure:31700: result: /usr/bin/gdb
configure:31912: checking whether OpenGL rendering is enabled
configure:31916: result: no
configure:31927: checking for X
configure:32066: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lX11 -lrt -lpthread >&5
configure:32066: $? =3D 0
configure:32116: result: libraries , headers=20
configure:32215: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lrt -lpthread -lX11 >&5
configure:32215: $? =3D 0
configure:32313: checking for gethostbyname
configure:32313: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lrt -lpthread >&5
configure:32313: $? =3D 0
configure:32313: result: yes
configure:32410: checking for connect
configure:32410: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
configure:32410: $? =3D 0
configure:32410: result: yes
configure:32459: checking for remove
configure:32459: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
configure:32459: $? =3D 0
configure:32459: result: yes
configure:32508: checking for shmat
configure:32508: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
configure:32508: $? =3D 0
configure:32508: result: yes
configure:32566: checking for IceConnectionNumber in -lICE
configure:32591: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c -lICE -lrt -lpthread >&5
configure:32591: $? =3D 0
configure:32600: result: yes
configure:33051: checking for library containing sgemm_
configure:33082: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE =
conftest.c >&5
configure:33082: $? =3D 0
configure:33099: result: none required
configure:33170: checking which BLAS lib should be used
configure:33172: result: system
configure:33196: checking for FFTW
configure:33204: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
to the PKG_CONFIG_PATH environment variable
No package 'fftw3' found
configure:33207: $? =3D 1
configure:33222: $PKG_CONFIG --exists --print-errors "fftw3"
configure:33225: $? =3D 1
configure:33253: result: no
configure:33283: checking for FFTWF
configure:33291: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:33294: $? =3D 1
configure:33309: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:33312: $? =3D 1
configure:33340: result: no
configure:33370: checking for FFTWL
configure:33378: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:33381: $? =3D 1
configure:33396: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:33399: $? =3D 1
configure:33427: result: no
configure:33523: checking for HWLOC
configure:33531: $PKG_CONFIG --exists --print-errors "hwloc"
configure:33534: $? =3D 0
configure:33549: $PKG_CONFIG --exists --print-errors "hwloc"
configure:33552: $? =3D 0
configure:33592: result: yes
configure:33671: checking whether hwloc_cuda_get_device_osdev_by_index is=
declared
configure:33671: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
In file included from conftest.c:89:0:
/usr/include/hwloc/cuda.h:24:18: fatal error: cuda.h: No such file or dir=
ectory
#include <cuda.h>
compilation terminated.
configure:33671: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_GDB_PATH "/usr/bin/gdb"
| #define STARPU_HAVE_X11 1
| #define STARPU_SYSTEM_BLAS 1
| #define STARPU_HAVE_HWLOC 1
| #include <hwloc/cuda.h>
|=20
| int
| main ()
| #ifndef hwloc_cuda_get_device_osdev_by_index
| #ifdef __cplusplus
| (void) hwloc_cuda_get_device_osdev_by_index;
| #else
| #endif
| #endif
|=20
| return 0;
configure:33671: result: no
configure:33693: checking whether hwloc should be used
configure:33695: result: yes
configure:33700: checking f77.h usability
configure:33700: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
conftest.c:123:17: fatal error: f77.h: No such file or directory
#include <f77.h>
configure:33700: $? =3D 1
| /* confdefs.h */
c4/."
| #define HAVE_DECL_HWLOC_CUDA_GET_DEVICE_OSDEV_BY_INDEX 0
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <f77.h>
configure:33700: result: no
configure:33700: checking f77.h presence
configure:33700: cc -E -D_GNU_SOURCE conftest.c
conftest.c:90:17: fatal error: f77.h: No such file or directory
#include <f77.h>
| /* confdefs.h */
c4/."
| #include <f77.h>
configure:33700: checking for f77.h
configure:33729: checking for icc
configure:33759: result: no
configure:33841: checking for help2man
configure:33871: result: no
configure:33892: checking for struct cudaDeviceProp.pciDomainID
configure:33892: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
conftest.c:91:30: fatal error: cuda_runtime_api.h: No such file or direct=
ory
#include <cuda_runtime_api.h>
configure:33892: $? =3D 1
| /* confdefs.h */
c4/."
| #define STARPU_HAVE_FC /**/
|=20
| int
| main ()
| static struct cudaDeviceProp ac_aggr;
| if (ac_aggr.pciDomainID)
| return 0;
| return 0;
=2Ec >&5
ory
| /* confdefs.h */
c4/."
|=20
| int
| main ()
| if (sizeof ac_aggr.pciDomainID)
| return 0;
| return 0;
configure:33892: result: no
configure:33901: checking for struct cudaDeviceProp.pciBusID
configure:33901: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest=
=2Ec >&5
ory
configure:33901: $? =3D 1
| /* confdefs.h */
c4/."
|=20
| int
| main ()
| if (ac_aggr.pciBusID)
| return 0;
| return 0;
=2Ec >&5
ory
| /* confdefs.h */
c4/."
|=20
| int
| main ()
| if (sizeof ac_aggr.pciBusID)
| return 0;
| return 0;
configure:33901: result: no
configure:33935: checking for doxygen
configure:33953: found /usr/bin/doxygen
configure:33965: result: /usr/bin/doxygen
configure:33978: checking for pdflatex
configure:34011: result: no
configure:34021: checking for epstopdf
configure:34054: result: no
configure:34063: checking whether documentation should be compiled
configure:34065: result: no
configure:34240: checking that generated files are newer than configure
configure:34246: result: done
configure:34489: creating ./config.status
## Running config.status. ##
This file was extended by StarPU config.status 1.2.0rc4, which was
generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES =3D=20
CONFIG_HEADERS =3D=20
CONFIG_LINKS =3D=20
CONFIG_COMMANDS =3D=20
$ ./config.status=20
on nid00081
config.status:1630: creating tests/regression/regression.sh
config.status:1630: creating tests/regression/profiles
config.status:1630: creating tests/regression/profiles.build.only
config.status:1630: creating Makefile
config.status:1630: creating src/Makefile
config.status:1630: creating tools/Makefile
config.status:1630: creating tools/starpu_codelet_profile
config.status:1630: creating tools/starpu_codelet_histo_profile
config.status:1630: creating tools/starpu_workers_activity
config.status:1630: creating tools/starpu_paje_draw_histogram
config.status:1630: creating tools/starpu_paje_state_stats
config.status:1630: creating tools/starpu_paje_summary
config.status:1630: creating tools/starpu_paje_sort
config.status:1630: creating tools/starpu_smpirun
config.status:1630: creating socl/Makefile
config.status:1630: creating socl/src/Makefile
config.status:1630: creating socl/examples/Makefile
config.status:1630: creating socl/vendors/socl.icd
config.status:1630: creating socl/vendors/install/socl.icd
config.status:1630: creating libstarpu.pc
config.status:1630: creating starpu-1.0.pc
config.status:1630: creating starpu-1.1.pc
config.status:1630: creating starpu-1.2.pc
config.status:1630: creating mpi/libstarpumpi.pc
config.status:1630: creating mpi/starpumpi-1.0.pc
config.status:1630: creating mpi/starpumpi-1.1.pc
config.status:1630: creating mpi/starpumpi-1.2.pc
config.status:1630: creating starpufft/Makefile
config.status:1630: creating starpufft/src/Makefile
config.status:1630: creating starpufft/tests/Makefile
config.status:1630: creating starpufft/libstarpufft.pc
config.status:1630: creating starpufft/starpufft-1.0.pc
config.status:1630: creating starpufft/starpufft-1.1.pc
config.status:1630: creating starpufft/starpufft-1.2.pc
config.status:1630: creating examples/Makefile
config.status:1630: creating examples/stencil/Makefile
config.status:1630: creating tests/Makefile
config.status:1630: creating tests/loader-cross.sh
config.status:1630: creating mpi/Makefile
config.status:1630: creating mpi/src/Makefile
config.status:1630: creating mpi/tests/Makefile
config.status:1630: creating mpi/examples/Makefile
config.status:1630: creating starpu-top/StarPU-Top.pro
config.status:1630: creating starpu-top/StarPU-Top-qwt-embed.pri
config.status:1630: creating starpu-top/StarPU-Top-qwt-system.pri
config.status:1630: creating gcc-plugin/Makefile
config.status:1630: creating gcc-plugin/src/Makefile
config.status:1630: creating gcc-plugin/tests/Makefile
config.status:1630: creating gcc-plugin/tests/run-test
config.status:1630: creating gcc-plugin/examples/Makefile
config.status:1630: creating sc_hypervisor/Makefile
config.status:1630: creating sc_hypervisor/src/Makefile
config.status:1630: creating sc_hypervisor/examples/Makefile
config.status:1630: creating doc/Makefile
config.status:1630: creating doc/doxygen/Makefile
config.status:1630: creating doc/doxygen/doxygen-config.cfg
config.status:1630: creating doc/doxygen/doxygen_filter.sh
config.status:1630: creating tools/msvc/starpu_var.bat
config.status:1630: creating src/common/config.h
config.status:1630: creating include/starpu_config.h
config.status:1630: creating gcc-plugin/include/starpu-gcc/config.h
config.status:1630: creating starpu-top/config.h
config.status:1856: linking /etc/OpenCL/vendors/nvidia.icd to socl/vendor=
s/nvidia.icd
config.status:1875: executing depfiles commands
config.status:1875: executing libtool commands
config.status:1875: executing executable-scripts commands
configure:37570: WARNING: unrecognized options: --enable-mpi
configure:37622:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: no
SCC enabled: no
MIC enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
--enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 0
Maximum number of OpenCL devices: 0
Maximum number of SCC devices: 0
Maximum number of MIC threads: 0
Maximum number of memory nodes: 4
Maximum number of task buffers: 8
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: system
hwloc: yes
FxT trace enabled: no
StarPU-Top: no
Documentation: no
Examples: yes
StarPU Extensions:
MPI enabled: no
MPI test suite: no
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
OpenMP runtime support enabled: no
SOCL enabled: no
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: no
ayudame enabled: no
## Cache variables. ##
ac_cv_build=3Dx86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=3Dyes
ac_cv_c_restrict=3D__restrict
ac_cv_cxx_compiler_gnu=3Dyes
ac_cv_env_BLAS_LIBS_set=3D
ac_cv_env_BLAS_LIBS_value=3D
ac_cv_env_CCC_set=3D
ac_cv_env_CCC_value=3D
ac_cv_env_CC_set=3Dset
ac_cv_env_CC_value=3Dcc
ac_cv_env_CFLAGS_set=3D
ac_cv_env_CFLAGS_value=3D
ac_cv_env_CPPFLAGS_set=3D
ac_cv_env_CPPFLAGS_value=3D
ac_cv_env_CPP_set=3D
ac_cv_env_CPP_value=3D
ac_cv_env_CXXCPP_set=3D
ac_cv_env_CXXCPP_value=3D
ac_cv_env_CXXFLAGS_set=3D
ac_cv_env_CXXFLAGS_value=3D
ac_cv_env_CXX_set=3Dset
ac_cv_env_CXX_value=3DCC
ac_cv_env_F77_set=3D
ac_cv_env_F77_value=3D
ac_cv_env_FCFLAGS_set=3D
ac_cv_env_FCFLAGS_value=3D
ac_cv_env_FC_set=3Dset
ac_cv_env_FC_value=3Dftn
ac_cv_env_FFLAGS_set=3D
ac_cv_env_FFLAGS_value=3D
ac_cv_env_FFTWF_CFLAGS_set=3D
ac_cv_env_FFTWF_CFLAGS_value=3D
ac_cv_env_FFTWF_LIBS_set=3D
ac_cv_env_FFTWF_LIBS_value=3D
ac_cv_env_FFTWL_CFLAGS_set=3D
ac_cv_env_FFTWL_CFLAGS_value=3D
ac_cv_env_FFTWL_LIBS_set=3D
ac_cv_env_FFTWL_LIBS_value=3D
ac_cv_env_FFTW_CFLAGS_set=3D
ac_cv_env_FFTW_CFLAGS_value=3D
ac_cv_env_FFTW_LIBS_set=3D
ac_cv_env_FFTW_LIBS_value=3D
ac_cv_env_FXT_CFLAGS_set=3D
ac_cv_env_FXT_CFLAGS_value=3D
ac_cv_env_FXT_LDFLAGS_set=3D
ac_cv_env_FXT_LDFLAGS_value=3D
ac_cv_env_FXT_LIBS_set=3D
ac_cv_env_FXT_LIBS_value=3D
ac_cv_env_HWLOC_CFLAGS_set=3D
ac_cv_env_HWLOC_CFLAGS_value=3D
ac_cv_env_HWLOC_LIBS_set=3D
ac_cv_env_HWLOC_LIBS_value=3D
ac_cv_env_LDFLAGS_set=3D
ac_cv_env_LDFLAGS_value=3D
ac_cv_env_LIBS_set=3D
ac_cv_env_LIBS_value=3D
ac_cv_env_MAGMA_CFLAGS_set=3D
ac_cv_env_MAGMA_CFLAGS_value=3D
ac_cv_env_MAGMA_LIBS_set=3D
ac_cv_env_MAGMA_LIBS_value=3D
ac_cv_env_NVCCFLAGS_set=3D
ac_cv_env_NVCCFLAGS_value=3D
ac_cv_env_NVCC_set=3D
ac_cv_env_NVCC_value=3D
ac_cv_env_PKG_CONFIG_set=3D
ac_cv_env_PKG_CONFIG_value=3D
ac_cv_env_POTI_CFLAGS_set=3D
ac_cv_env_POTI_CFLAGS_value=3D
ac_cv_env_POTI_LIBS_set=3D
ac_cv_env_POTI_LIBS_value=3D
ac_cv_env_STARPU_MS_LIB_set=3D
ac_cv_env_STARPU_MS_LIB_value=3D
ac_cv_env_XMKMF_set=3D
ac_cv_env_XMKMF_value=3D
ac_cv_env_build_alias_set=3D
ac_cv_env_build_alias_value=3D
ac_cv_env_host_alias_set=3D
ac_cv_env_host_alias_value=3D
ac_cv_env_target_alias_set=3D
ac_cv_env_target_alias_value=3D
ac_cv_f77_compiler_gnu=3Dyes
ac_cv_fc_compiler_gnu=3Dyes
ac_cv_func_clock_gettime=3Dyes
ac_cv_func_connect=3Dyes
ac_cv_func_drand48=3Dyes
ac_cv_func_erand48_r=3Dyes
ac_cv_func_gethostbyname=3Dyes
ac_cv_func_memalign=3Dyes
ac_cv_func_mkostemp=3Dyes
ac_cv_func_nearbyintf=3Dyes
ac_cv_func_posix_memalign=3Dyes
ac_cv_func_pread=3Dyes
ac_cv_func_pthread_barrier_init=3Dyes
ac_cv_func_pthread_setaffinity_np=3Dyes
ac_cv_func_pthread_spin_lock=3Dyes
ac_cv_func_pwrite=3Dyes
ac_cv_func_remove=3Dyes
ac_cv_func_rintf=3Dyes
ac_cv_func_sched_yield=3Dyes
ac_cv_func_setenv=3Dyes
ac_cv_func_shmat=3Dyes
ac_cv_func_strerror_r=3Dyes
ac_cv_func_sysconf=3Dyes
ac_cv_func_unsetenv=3Dyes
ac_cv_have_decl_hwloc_cuda_get_device_osdev_by_index=3Dno
ac_cv_have_gcc_plugins=3Dno
ac_cv_have_sync_bool_compare_and_swap=3Dyes
ac_cv_have_sync_fetch_and_add=3Dyes
ac_cv_have_sync_fetch_and_or=3Dyes
ac_cv_have_sync_lock_test_and_set=3Dyes
ac_cv_have_sync_synchronize=3Dyes
ac_cv_have_sync_val_compare_and_swap=3Dyes
ac_cv_have_x=3D'have_x=3Dyes ac_x_includes=3D'\'''\''
ac_x_libraries=3D'\=
ac_cv_header_Ayudame_h=3Dno
ac_cv_header_RCCE_h=3Dno
ac_cv_header_aio_h=3Dyes
ac_cv_header_dlfcn_h=3Dyes
ac_cv_header_f77_h=3Dno
ac_cv_header_glpk_h=3Dno
ac_cv_header_inttypes_h=3Dyes
ac_cv_header_leveldb_db_h=3Dno
ac_cv_header_malloc_h=3Dyes
ac_cv_header_memory_h=3Dyes
ac_cv_header_stdc=3Dyes
ac_cv_header_stdint_h=3Dyes
ac_cv_header_stdlib_h=3Dyes
ac_cv_header_string_h=3Dyes
ac_cv_header_strings_h=3Dyes
ac_cv_header_sys_stat_h=3Dyes
ac_cv_header_sys_types_h=3Dyes
ac_cv_header_unistd_h=3Dyes
ac_cv_header_valgrind_helgrind_h=3Dno
ac_cv_header_valgrind_memcheck_h=3Dno
ac_cv_header_valgrind_valgrind_h=3Dno
ac_cv_host=3Dx86_64-unknown-linux-gnu
ac_cv_lib_ICE_IceConnectionNumber=3Dyes
ac_cv_lib_RCCE_bigflags_nongory_nopwrmgmt_RCCE_init=3Dno
ac_cv_lib_glpk_main=3Dno
ac_cv_lib_leveldb_main=3Dno
ac_cv_lib_pthread_pthread_create=3Dyes
ac_cv_lib_rt_clock_gettime=3Dyes
ac_cv_lib_ws2_32=3Dac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=3Dno
ac_cv_member_struct_cudaDeviceProp_pciBusID=3Dno
ac_cv_member_struct_cudaDeviceProp_pciDomainID=3Dno
ac_cv_objext=3Do
ac_cv_path_EGREP=3D'/usr/bin/grep -E'
ac_cv_path_FGREP=3D'/usr/bin/grep -F'
ac_cv_path_GDB=3D/usr/bin/gdb
ac_cv_path_GREP=3D/usr/bin/grep
ac_cv_path_QMAKE=3D/usr/bin/qmake
ac_cv_path_SED=3D/usr/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=3D/usr/bin/pkg-config
ac_cv_path_doxygencommand=3D/usr/bin/doxygen
ac_cv_path_install=3D'/usr/bin/install -c'
ac_cv_path_mkdir=3D/bin/mkdir
ac_cv_path_mpiexec_path=3D/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiex=
ec
ac_cv_path_svncommand=3D/usr/bin/svn
ac_cv_path_svnversioncommand=3D/usr/bin/svnversion
ac_cv_prog_AWK=3Dgawk
ac_cv_prog_BASH=3D/bin/sh
ac_cv_prog_CPP=3D'cc -E'
ac_cv_prog_CXXCPP=3D'CC -E'
ac_cv_prog_PROG_DATE=3Ddate
ac_cv_prog_PROG_STAT=3Dstat
ac_cv_prog_ac_ct_AR=3Dar
ac_cv_prog_ac_ct_CC=3Dcc
ac_cv_prog_ac_ct_F77=3Dgfortran
ac_cv_prog_ac_ct_MANIFEST_TOOL=3Dmt
ac_cv_prog_ac_ct_OBJDUMP=3Dobjdump
ac_cv_prog_ac_ct_RANLIB=3Dranlib
ac_cv_prog_ac_ct_STRIP=3Dstrip
ac_cv_prog_cc_c89=3D
ac_cv_prog_cc_g=3Dyes
ac_cv_prog_cxx_g=3Dyes
ac_cv_prog_f77_g=3Dyes
ac_cv_prog_fc_g=3Dyes
ac_cv_prog_make_make_set=3Dyes
ac_cv_search_set_mempolicy=3D-lnuma
ac_cv_search_sgemm_=3D'none required'
ac_cv_search_sqrt=3D'none required'
ac_cv_sizeof_void_p=3D8
ac_cv_target=3Dx86_64-unknown-linux-gnu
ac_cv_type_cufftDoubleComplex=3Dno
ac_cv_type_struct_timespec=3Dyes
am_cv_CC_dependencies_compiler_type=3Dgcc3
am_cv_CXX_dependencies_compiler_type=3Dgcc3
am_cv_ar_interface=3Dar
am_cv_make_support_nested_variables=3Dyes
am_cv_prog_cc_c_o=3Dyes
lt_cv_ar_at_file=3D@
lt_cv_archive_cmds_need_lc=3Dno
lt_cv_deplibs_check_method=3Dpass_all
lt_cv_file_magic_cmd=3D'$MAGIC_CMD'
lt_cv_file_magic_test_file=3D
lt_cv_ld_reload_flag=3D-r
lt_cv_nm_interface=3D'BSD nm'
lt_cv_objdir=3D.libs
lt_cv_path_LD=3D/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld
lt_cv_path_LDCXX=3D'/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m elf_x=
86_64'
lt_cv_path_NM=3D'/usr/bin/nm -B'
lt_cv_path_mainfest_tool=3Dno
lt_cv_prog_compiler_c_o=3Dyes
lt_cv_prog_compiler_c_o_CXX=3Dyes
lt_cv_prog_compiler_c_o_F77=3Dyes
lt_cv_prog_compiler_c_o_FC=3Dyes
lt_cv_prog_compiler_pic=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=3D-fPIC
lt_cv_prog_compiler_pic_FC=3D-fPIC
lt_cv_prog_compiler_pic_works=3Dyes
lt_cv_prog_compiler_pic_works_CXX=3Dyes
lt_cv_prog_compiler_pic_works_F77=3Dyes
lt_cv_prog_compiler_pic_works_FC=3Dyes
lt_cv_prog_compiler_rtti_exceptions=3Dno
lt_cv_prog_compiler_static_works=3Dyes
lt_cv_prog_compiler_static_works_CXX=3Dyes
lt_cv_prog_compiler_static_works_F77=3Dyes
lt_cv_prog_compiler_static_works_FC=3Dyes
lt_cv_prog_gnu_ld=3Dyes
lt_cv_prog_gnu_ldcxx=3Dyes
lt_cv_sharedlib_from_linklib_cmd=3D'printf %s\n'
lt_cv_shlibpath_overrides_runpath=3Dyes
lt_cv_sys_global_symbol_pipe=3D'sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABC=
DGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed
/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address=3D'sed -n -e '\''s/^: \([^ ]*\)=
[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([=
^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix=3D'sed -n -e '\''s/^=
: \([^ ]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \(=
[^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRST=
W]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl=3D'sed -n -e '\''s/^T .* \(.*\)$/extern =
int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''=
lt_cv_sys_max_cmd_len=3D1572864
lt_cv_to_host_file_cmd=3Dfunc_convert_file_noop
lt_cv_to_tool_file_cmd=3Dfunc_convert_file_noop
pkg_cv_HWLOC_CFLAGS=3D'-I/project/k1044/favergm/opt-gcc/hwloc-1.11.1/incl=
ude '
pkg_cv_HWLOC_LIBS=3D'-L/project/k1044/favergm/opt-gcc/hwloc-1.11.1/lib -l=
hwloc '
## Output variables. ##
ACLOCAL=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/=
missing aclocal-1.14'
AMDEPBACKSLASH=3D'\'
AMDEP_FALSE=3D'#'
AMDEP_TRUE=3D''
AMTAR=3D'$${TAR-tar}'
AM_BACKSLASH=3D'\'
AM_DEFAULT_V=3D'$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY=3D'0'
AM_V=3D'$(V)'
AR=3D'ar'
AS=3D'as'
ATLASDIR=3D''
ATLAS_BLAS_LIB_FALSE=3D''
ATLAS_BLAS_LIB_TRUE=3D'#'
AUTOCONF=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux=
/missing autoconf'
AUTOHEADER=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-a=
ux/missing autoheader'
AUTOMAKE=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux=
/missing automake-1.14'
AWK=3D'gawk'
BASH=3D'/bin/sh'
BLAS_LIB=3D'system'
BLAS_LIBS=3D''
BUILD_DOC_FALSE=3D''
BUILD_DOC_TRUE=3D'#'
BUILD_EXAMPLES_FALSE=3D'#'
BUILD_EXAMPLES_TRUE=3D''
BUILD_GCC_PLUGIN_FALSE=3D''
BUILD_GCC_PLUGIN_TRUE=3D'#'
BUILD_SOCL_FALSE=3D''
BUILD_SOCL_TRUE=3D'#'
BUILD_STARPUFFT_EXAMPLES_FALSE=3D''
BUILD_STARPUFFT_EXAMPLES_TRUE=3D'#'
BUILD_STARPUFFT_FALSE=3D''
BUILD_STARPUFFT_TRUE=3D'#'
BUILD_STARPU_TOP_FALSE=3D''
BUILD_STARPU_TOP_TRUE=3D'#'
CC=3D'cc'
CCDEPMODE=3D'depmode=3Dgcc3'
CC_OR_MPICC=3D'cc'
CFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
COVERAGE=3D'no'
CPP=3D'cc -E'
CPPFLAGS=3D' -D_GNU_SOURCE '
CXX=3D'CC'
CXXCPP=3D'CC -E'
CXXDEPMODE=3D'depmode=3Dgcc3'
CXXFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
CYGPATH_W=3D'echo'
DEFS=3D'-DHAVE_CONFIG_H'
DEPDIR=3D'.deps'
DLLTOOL=3D'false'
DSYMUTIL=3D''
DUMPBIN=3D''
ECHO_C=3D''
ECHO_N=3D'-n'
ECHO_T=3D''
EXEEXT=3D''
F77=3D'gfortran'
FC=3D'ftn'
FCFLAGS=3D'-g -O2'
FFLAGS=3D'-g -O2'
FFTWF_CFLAGS=3D''
FFTWF_LIBS=3D''
FFTWL_CFLAGS=3D''
FFTWL_LIBS=3D''
FFTW_CFLAGS=3D''
FFTW_LIBS=3D''
FXTDIR=3D''
FXT_CFLAGS=3D''
FXT_LDFLAGS=3D''
FXT_LIBS=3D''
GCC_FOR_PLUGIN=3D''
GCC_FOR_PLUGIN_LIBTOOL_TAG=3D''
GCC_PLUGIN_DIR_PKGCONFIG=3D''
GCC_PLUGIN_INCLUDE_DIR=3D'/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4=
=2E9.3/plugin/include'
GCC_PLUGIN_PKGCONFIG=3D''
GDB=3D'/usr/bin/gdb'
GLOBAL_AM_CFLAGS=3D' -Wall -Werror=3Dimplicit -Werror=3Dimplicit-function=
-declaration'
GOTODIR=3D''
GOTO_BLAS_LIB_FALSE=3D''
GOTO_BLAS_LIB_TRUE=3D'#'
GREP=3D'/usr/bin/grep'
GUILE=3D''
HAVE_FFTWFL=3D''
HAVE_OPENGL_FALSE=3D''
HAVE_OPENGL_TRUE=3D'#'
HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=3D''
HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE=3D'#'
HAVE_X11_FALSE=3D'#'
HAVE_X11_TRUE=3D''
HELP2MAN=3D''
HWLOC_CFLAGS=3D'-I/project/k1044/favergm/opt-gcc/hwloc-1.11.1/include '
HWLOC_LIBS=3D'-L/project/k1044/favergm/opt-gcc/hwloc-1.11.1/lib -lhwloc '=
HWLOC_REQUIRES=3D'hwloc'
ICC=3D''
INSTALL_DATA=3D'${INSTALL} -m 644'
INSTALL_PROGRAM=3D'${INSTALL}'
INSTALL_SCRIPT=3D'${INSTALL}'
INSTALL_STRIP_PROGRAM=3D'$(install_sh) -c -s'
LD=3D'/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m elf_x86_64'
LDFLAGS=3D''
LIBOBJS=3D''
LIBS=3D'-lrt -lpthread '
LIBSOCL_INTERFACE_AGE=3D'0'
LIBSOCL_INTERFACE_CURRENT=3D'0'
LIBSOCL_INTERFACE_REVISION=3D'0'
LIBSTARPUFFT_INTERFACE_AGE=3D'0'
LIBSTARPUFFT_INTERFACE_CURRENT=3D'0'
LIBSTARPUFFT_INTERFACE_REVISION=3D'0'
LIBSTARPUMPI_INTERFACE_AGE=3D'0'
LIBSTARPUMPI_INTERFACE_CURRENT=3D'1'
LIBSTARPUMPI_INTERFACE_REVISION=3D'1'
LIBSTARPU_INTERFACE_AGE=3D'0'
LIBSTARPU_INTERFACE_CURRENT=3D'3'
LIBSTARPU_INTERFACE_REVISION=3D'0'
LIBSTARPU_LDFLAGS=3D' '
LIBSTARPU_LINK=3D'libstarpu-1.2.la'
LIBTOOL=3D'$(SHELL) $(top_builddir)/libtool'
LIPO=3D''
LN_S=3D'ln -s'
LTLIBOBJS=3D''
MAGMA_CFLAGS=3D''
MAGMA_LIBS=3D''
MAKEINFO=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux=
/missing makeinfo'
MANIFEST_TOOL=3D':'
MKDIR_P=3D'/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=3D''
MKL_BLAS_LIB_TRUE=3D'#'
MPICC=3D'cc'
MPICC_LDFLAGS=3D''
MPIEXEC=3D''
NMEDIT=3D''
NO_BLAS_LIB_FALSE=3D''
NO_BLAS_LIB_TRUE=3D'#'
NVCC=3D''
NVCCFLAGS=3D''
OBJDUMP=3D'objdump'
OBJEXT=3D'o'
OTOOL64=3D''
OTOOL=3D''
PACKAGE=3D'starpu'
PACKAGE_BUGREPORT=3D'starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME=3D'StarPU'
PACKAGE_STRING=3D'StarPU 1.2.0rc4'
PACKAGE_TARNAME=3D'starpu'
PACKAGE_URL=3D'http://runtime.bordeaux.inria.fr/StarPU/'
PACKAGE_VERSION=3D'1.2.0rc4'
PATH_SEPARATOR=3D':'
PKG_CONFIG=3D'/usr/bin/pkg-config'
POTI_CFLAGS=3D''
POTI_LIBS=3D''
PROG_DATE=3D'date'
PROG_STAT=3D'stat'
QMAKE=3D'/usr/bin/qmake'
QWT_PRI=3D'embed'
RANLIB=3D'ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=3D''
RUN_GCC_PLUGIN_TESTS_TRUE=3D'#'
SED=3D'/usr/bin/sed'
SET_MAKE=3D''
SHELL=3D'/bin/sh'
SIMGRID_CFLAGS=3D''
SIMGRID_LIBS=3D''
SOCL_OCL_LIB_OPENCL_DIR=3D''
SOCL_VENDORS=3D'vendors/install/socl.icd vendors/nvidia.icd'
STARPU_BLAS_LDFLAGS=3D' '
STARPU_BUILD_DIR=3D'/project/k1044/favergm/src/starpu-1.2.0rc4'
STARPU_BUILD_SC_HYPERVISOR_FALSE=3D''
STARPU_BUILD_SC_HYPERVISOR_TRUE=3D'#'
STARPU_COI_CPPFLAGS=3D''
STARPU_COI_LDFLAGS=3D''
STARPU_COVERAGE_ENABLED_FALSE=3D''
STARPU_COVERAGE_ENABLED_TRUE=3D'#'
STARPU_CROSS_COMPILING_FALSE=3D''
STARPU_CROSS_COMPILING_TRUE=3D'#'
STARPU_CUDA_CPPFLAGS=3D''
STARPU_CUDA_FORTRAN_LDFLAGS=3D''
STARPU_CUDA_LDFLAGS=3D''
STARPU_CUFFT_LDFLAGS=3D''
STARPU_CURAND_LDFLAGS=3D''
STARPU_DEVEL_FALSE=3D''
STARPU_DEVEL_TRUE=3D'#'
STARPU_EFFECTIVE_VERSION=3D'1.2'
STARPU_ENABLE_STATS=3D'no'
STARPU_EXPORT_DYNAMIC=3D'-rdynamic'
STARPU_GCC_VERSION_MAJOR=3D''
STARPU_GCC_VERSION_MINOR=3D''
STARPU_GLPK_LDFLAGS=3D' '
STARPU_HAVE_AM111_FALSE=3D'#'
STARPU_HAVE_AM111_TRUE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE=3D'#'
STARPU_HAVE_F77_H=3D'no'
STARPU_HAVE_F77_H_FALSE=3D''
STARPU_HAVE_F77_H_TRUE=3D'#'
STARPU_HAVE_FC_FALSE=3D'#'
STARPU_HAVE_FC_TRUE=3D''
STARPU_HAVE_FFTW=3D''
STARPU_HAVE_FFTWF=3D''
STARPU_HAVE_FFTWF_FALSE=3D''
STARPU_HAVE_FFTWF_TRUE=3D'#'
STARPU_HAVE_FFTWL_FALSE=3D''
STARPU_HAVE_FFTWL_TRUE=3D'#'
STARPU_HAVE_FFTW_FALSE=3D''
STARPU_HAVE_FFTW_TRUE=3D'#'
STARPU_HAVE_HELP2MAN_FALSE=3D''
STARPU_HAVE_HELP2MAN_TRUE=3D'#'
STARPU_HAVE_HWLOC=3D'1'
STARPU_HAVE_ICC_FALSE=3D''
STARPU_HAVE_ICC_TRUE=3D'#'
STARPU_HAVE_LEVELDB_FALSE=3D''
STARPU_HAVE_LEVELDB_TRUE=3D'#'
STARPU_HAVE_MAGMA=3D''
STARPU_HAVE_MAGMA_FALSE=3D''
STARPU_HAVE_MAGMA_TRUE=3D'#'
STARPU_HAVE_MS_LIB_FALSE=3D''
STARPU_HAVE_MS_LIB_TRUE=3D'#'
STARPU_HAVE_WINDOWS_FALSE=3D''
STARPU_HAVE_WINDOWS_TRUE=3D'#'
STARPU_LEVELDB_LDFLAGS=3D' '
STARPU_LIBNUMA_LDFLAGS=3D' -lnuma '
STARPU_LINUX_SYS_FALSE=3D'#'
STARPU_LINUX_SYS_TRUE=3D''
STARPU_LONG_CHECK_FALSE=3D''
STARPU_LONG_CHECK_TRUE=3D'#'
STARPU_MAJOR_VERSION=3D'1'
STARPU_MINOR_VERSION=3D'2'
STARPU_MPI_CHECK_FALSE=3D''
STARPU_MPI_CHECK_TRUE=3D'#'
STARPU_MS_LIB=3D''
STARPU_MS_LIB_ARCH=3D'X64'
STARPU_NEW_CHECK_FALSE=3D''
STARPU_NEW_CHECK_TRUE=3D'#'
STARPU_OPENCL_CPPFLAGS=3D''
STARPU_OPENCL_DATAdir=3D''
STARPU_OPENCL_LDFLAGS=3D''
STARPU_OPENGL_RENDER=3D'no'
STARPU_OPENGL_RENDER_LDFLAGS=3D''
STARPU_OPENMP_FALSE=3D''
STARPU_OPENMP_TRUE=3D'#'
STARPU_PERF_DEBUG=3D'no'
STARPU_QUICK_CHECK_FALSE=3D''
STARPU_QUICK_CHECK_TRUE=3D'#'
STARPU_QWT_INCLUDE=3D''
STARPU_QWT_LDFLAGS=3D''
STARPU_RCCE_CFLAGS=3D''
STARPU_RCCE_CPPFLAGS=3D''
STARPU_RCCE_LDFLAGS=3D''
STARPU_RELEASE_VERSION=3D'0'
STARPU_SANITIZE_FALSE=3D''
STARPU_SANITIZE_TRUE=3D'#'
STARPU_SCIF_CPPFLAGS=3D''
STARPU_SCIF_LDFLAGS=3D''
STARPU_SC_HYPERVISOR=3D''
STARPU_SC_HYPERVISOR_DEBUG=3D'no'
STARPU_SC_HYPERVISOR_DEBUG_FALSE=3D''
STARPU_SC_HYPERVISOR_DEBUG_TRUE=3D'#'
STARPU_SIMGRID_FALSE=3D''
STARPU_SIMGRID_TRUE=3D'#'
STARPU_SRC_DIR=3D'/lustre/project/k1044/favergm/src/starpu-1.2.0rc4/.'
STARPU_USE_CPU=3D'yes'
STARPU_USE_CPU_FALSE=3D'#'
STARPU_USE_CPU_TRUE=3D''
STARPU_USE_CUDA=3D'no'
STARPU_USE_CUDA_FALSE=3D''
STARPU_USE_CUDA_TRUE=3D'#'
STARPU_USE_FXT=3D'no'
STARPU_USE_FXT_FALSE=3D''
STARPU_USE_FXT_TRUE=3D'#'
STARPU_USE_MIC_FALSE=3D''
STARPU_USE_MIC_TRUE=3D'#'
STARPU_USE_MP_FALSE=3D'#'
STARPU_USE_MP_TRUE=3D''
STARPU_USE_OPENCL=3D'no'
STARPU_USE_OPENCL_FALSE=3D''
STARPU_USE_OPENCL_TRUE=3D'#'
STARPU_USE_SCC_FALSE=3D''
STARPU_USE_SCC_TRUE=3D'#'
STARPU_USE_SC_HYPERVISOR_FALSE=3D''
STARPU_USE_SC_HYPERVISOR_TRUE=3D'#'
STARPU_USE_SOCL_FALSE=3D''
STARPU_USE_SOCL_TRUE=3D'#'
STARPU_USE_TOP=3D'no'
STATS=3D'no'
STRIP=3D'strip'
SYSTEM_BLAS_LIB_FALSE=3D'#'
SYSTEM_BLAS_LIB_TRUE=3D''
USE_MPI=3D'no'
USE_MPI_FALSE=3D''
USE_MPI_TRUE=3D'#'
XMKMF=3D''
X_CFLAGS=3D''
X_EXTRA_LIBS=3D''
X_LIBS=3D''
X_PRE_LIBS=3D' -lSM -lICE'
YACC=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/mis=
sing bison'
ac_ct_AR=3D'ar'
ac_ct_CC=3D'cc'
ac_ct_CXX=3D''
ac_ct_DUMPBIN=3D''
ac_ct_F77=3D'gfortran'
ac_ct_FC=3D''
am__EXEEXT_FALSE=3D''
am__EXEEXT_TRUE=3D'#'
am__fastdepCC_FALSE=3D'#'
am__fastdepCC_TRUE=3D''
am__fastdepCXX_FALSE=3D'#'
am__fastdepCXX_TRUE=3D''
am__include=3D'include'
am__isrc=3D' -I$(srcdir)'
am__leading_dot=3D'.'
am__nodep=3D'_no'
am__quote=3D''
am__tar=3D'$${TAR-tar} chof - "$$tardir"'
am__untar=3D'$${TAR-tar} xf -'
bindir=3D'${exec_prefix}/bin'
build=3D'x86_64-unknown-linux-gnu'
build_alias=3D''
build_cpu=3D'x86_64'
build_os=3D'linux-gnu'
build_vendor=3D'unknown'
datadir=3D'${datarootdir}'
datarootdir=3D'${prefix}/share'
docdir=3D'${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=3D'/usr/bin/doxygen'
dvidir=3D'${docdir}'
epstopdfcommand=3D''
exec_prefix=3D'${prefix}'
gccplugindir=3D''
host=3D'x86_64-unknown-linux-gnu'
host_alias=3D''
host_cpu=3D'x86_64'
host_os=3D'linux-gnu'
host_vendor=3D'unknown'
htmldir=3D'${docdir}'
includedir=3D'${prefix}/include'
infodir=3D'${datarootdir}/info'
install_sh=3D'${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-a=
ux/install-sh'
libdir=3D'${exec_prefix}/lib'
libexecdir=3D'${exec_prefix}/libexec'
localedir=3D'${datarootdir}/locale'
localstatedir=3D'${prefix}/var'
mandir=3D'${datarootdir}/man'
mkdir_p=3D'$(MKDIR_P)'
mpicc_path=3D'cc'
mpiexec_path=3D'/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec'
oldincludedir=3D'/usr/include'
pdfdir=3D'${docdir}'
pdflatexcommand=3D''
pkglibdir=3D'${libdir}/starpu'
prefix=3D'/project/k1044/favergm/opt-gcc/starpu-1.2.0rc4'
program_transform_name=3D's,x,x,'
psdir=3D'${docdir}'
sbindir=3D'${exec_prefix}/sbin'
sharedstatedir=3D'${prefix}/com'
smpirun_path=3D''
svncommand=3D'/usr/bin/svn'
svnversioncommand=3D'/usr/bin/svnversion'
sysconfdir=3D'${prefix}/etc'
target=3D'x86_64-unknown-linux-gnu'
target_alias=3D''
target_cpu=3D'x86_64'
target_os=3D'linux-gnu'
target_vendor=3D'unknown'
## confdefs.h. ##
/* confdefs.h */
#define STARPU_SRC_DIR "/lustre/project/k1044/favergm/src/starpu-1.2.0rc4=
configure: exit 0
--------------070002010505060703070106--
  • [no subject], Unknown, 16/12/2020
Haut de le page
