Archives de la liste
- From: "helluy@math.unistra.fr" <helluy@math.unistra.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Malcolm Roberts <squidgyhead@gmail.com>
- Subject: [Starpu-devel] StarPU does not accept too long opencl kernel sources
- Date: Tue, 8 Dec 2015 15:57:22 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=helluy@math.unistra.fr; spf=None smtp.mailfrom=helluy@math.unistra.fr; spf=None smtp.helo=postmaster@mailhost.u-strasbg.fr
- Ironport-phdr: 9a23:pjO6Vx9TAhVFxv9uRHKM819IXTAuvvDOBiVQ1KB91escTK2v8tzYMVDF4r011RmSDduds6oMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EleKKtQsb7tIee6aObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wJk26DhZoeo8ssJNT6j+V6A5VqBDSjsoNHo66YvqswPCRE2B/CgySGITx1BIDgzB8QDSW57tsm3nsOtmxDOTe8PsB/hgWTmm67p6YBrhlCdBKjg4633Ng4p+lvQI81qauxVjztuMM8muP/1kc/aFcA==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
StarPU does not accept too long kernel sources.
I have made a simple modification for my purposes:
Index: src/drivers/opencl/driver_opencl_utils.c
--- src/drivers/opencl/driver_opencl_utils.c (révision 16654)
+++ src/drivers/opencl/driver_opencl_utils.c (copie de travail)
@@ -364,7 +364,7 @@
char located_file_name[1024];
char located_dir_name[1024];
char new_build_options[1024];
- char opencl_program_source[16384];
+ char opencl_program_source[131072];
// Do not try to load and compile the file if there is no devices
nb_devices = starpu_opencl_worker_get_count();
But I think that it would be better to implement a more general solution with a malloc.
Best regards
PH
- [Starpu-devel] StarPU does not accept too long opencl kernel sources, helluy@math.unistra.fr, 08/12/2015
- Re: [Starpu-devel] StarPU does not accept too long opencl kernel sources, Nathalie Furmento, 08/12/2015
