Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] nready traces starpu
Archives de la liste
Chronologique Discussions
  • To: Jean-Marie Couteyen <jean-marie.couteyen@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] nready traces starpu
  • Date: Wed, 9 Dec 2015 23:25:57 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=terry.cojean@gmail.com; spf=Pass smtp.mailfrom=terry.cojean@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f43.google.com
  • Ironport-phdr: 9a23:85+fHhMMgpwwdKRvlzgl6mtUPXoX/o7sNwtQ0KIMzox0KPX4rarrMEGX3/hxlliBBdydsKIazbOI+Pi5EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35rxjr75o8SbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskzhQAKJo14VSGQb2jFPHhTI/Rz8FsPzvyL88+90wiiXe8bxUKw5SDmkx6ZtUh7hzikdYW0X6mbS3/B9lrhK6DmmpRF2xcaAfIyPLus4daTfcNocbWVEV8dVESdGB9XvPMM0E+MdMLMA/MHGrFwUoE77XFH0CQ==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 09/Dec - 16:57, Jean-Marie Couteyen wrote:
> Thanks. I tried the trunk with my code.
> The values are back to normal when I use "classical" workers. It works
> with one context used as a parallel worker too.
> However, when I use parallel workers through the use of nested contexts
> (one main context contains several context that are "openmp workers",
> tasks are submitted to the main context), the nready counters is not
> decremented. But as far as I know, this never worked.
> Jean-Marie
Hello,
This should be fixed. It seems that it indeed wasn't decreased in that
case.
Regards,
Terry Cojean.
> Le 08/12/2015 11:19, Samuel Thibault a écrit :
> > Samuel Thibault, on Mon 07 Dec 2015 18:29:48 +0100, wrote:
> >> Jean-Marie Couteyen, on Thu 10 Sep 2015 16:48:23 +0200, wrote:
> >>> it seems that the nready counter on fxt traces does not display the same
> >>> information as it used to do (trunk, branches/1.1, branches/1.2). I
> >>> checked
> >>> with my code and some other codes.
> >>> Is this change spurious or the meaning of the counter changed ?
> >> It seems it got broken, I have a patch pending to fix it.
> > This is now fixed.
> > Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
