Archives de la liste
- From: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- To: Samuel Thibault <samuel.thibault@inria.fr>, Samuel Pitoiset <samuel.pitoiset@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] 1.2.0rc5 problem with -lGL
- Date: Tue, 5 Jan 2016 19:07:07 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=malcolm.i.w.roberts@gmail.com; spf=Pass smtp.mailfrom=malcolm.i.w.roberts@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f41.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Sorry for not responding earlier. I've actually managed to build with
--disable-starpu-top --disable-opengl-render
configure options. I'm now in the process of getting my OpenCL application to work with SOCL. Most of the tests pass, but there are some segfaults which I don't understand.
Thanks for your help with the configuration!
Best,
~Malcolm
On 2016-01-05 06:40 PM, Samuel Thibault wrote:
Hello,
Malcolm Roberts, on Fri 18 Dec 2015 15:20:38 +0100, wrote:
Thanks for the response. I ran the command
rm -rf starpu-1.2.0rc && tar -xvf starpu-1.2.0rc5.tar.gz && cd
starpu-1.2.0rc5 && ./configure --prefix=$HOME/starpu --disable-opengl-render
&& make && cd ..
and I still get the error
/usr/bin/ld: cannot find -lGL
As said before, please provide full build logs, otherwise we have to
guess a lot of things.
Perhaps it's the starpu-top part of the build which poses problem? You
can use --disable-starpu-top to avoid it.
Samuel
http://malcolmiwroberts.com/
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Samuel Thibault, 05/01/2016
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Malcolm Roberts, 05/01/2016
