Archives de la liste
- From: Marcos Amarís González <marcos.amaris-gonzalez@inria.fr>
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Asking collaboration in PhD Research about Scheduling
- Date: Fri, 15 Jan 2016 13:16:18 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=marcos.amaris-gonzalez@inria.fr; spf=Pass smtp.mailfrom=marcos.amaris@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f51.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Samuel,
Thanks so much! I am going to follow your advice and I will use those applications!In case of other people want to collaborate with more applications I would appreciate a lot, and Obviously I should cite them in case of to be a published work!
Le ven. 15 janv. 2016 à 10:43, Samuel Thibault <samuel.thibault@inria.fr> a écrit :
Hello,
Marcos Amarís González, on Fri 15 Jan 2016 12:33:31 +0000, wrote:
> I mean the applications are not partitioned in Tasks, and we want to
> create our Scheduler with a set of applications with multiples or many
> tasks.
Yes, that's a common issue :)
> to request developed applications with a Task-based approach in StarPU
> to analyze them and to try to elaborate my research about Scheduling
> of task-based applications over Heterogeneous application (CPU + GPU).
You should probably have a look at the MORSE project, which has dense
linear algebra examples (Chameleon), sparse linear algebra (PaStiX),
fast multipole method (ScalFMM).
Samuel
- [Starpu-devel] Asking collaboration in PhD Research about Scheduling, Marcos Amarís González, 15/01/2016
- Re: [Starpu-devel] Asking collaboration in PhD Research about Scheduling, Samuel Thibault, 15/01/2016
- Re: [Starpu-devel] Asking collaboration in PhD Research about Scheduling, Marcos Amarís González, 15/01/2016
