Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Questions about StarPU worker recongnization
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Questions about StarPU worker recongnization
  • Date: Wed, 20 Jan 2016 14:47:30 +0100 (CET)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hpcfapix@hlrs.de; spf=None smtp.mailfrom=hpcfapix@hlrs.de; spf=None smtp.helo=postmaster@mail.hlrs.de
  • Dkim-filter: OpenDKIM Filter v2.9.2 mail.hlrs.de 590EF4279
  • Ironport-phdr: 9a23:hphglx34fPDVUMA9smDT+DRfVm0co7zxezQtwd8ZsegRIvad9pjvdHbS+e9qxAeQG96LtbQd07Od7/CocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0YLuj7n5p82bSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskz4RA6S639UbmUXmBNVBxSNuArzW4r8tm3mtut30TSeIeX3S6o1UHKs9fE4ZgXvjXIpPjg29GCfss042KJDqxyovx1v647QeprTOPcoLfCVRs8TWWcUBpUZbCdGGI7pKtJXV+c=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
For example, I have a parallel task (codelet with power model and performance
model), and I feed, in my application, energy consumption values to the task,
during calibrating period.
And then when the task is really executed (conf.calibrate = -1;), will the
scheduler (pheft) consider the consumption value to chose the number of
worker size?
In another word, as you said the parallel worker size is chosen by the
scheduler, I am interested in how the scheduler choose the worker size? Is it
only the all available workers, or could depend on some other values?
Besides, for a non-parallel task, I can simply get info about which cpu core
executed the task by looking at starpu_profiling_task_info : workerid.
But for parallel task, how could I get info about the combined workers? What
is the output of the starpu_profiling_task_info : workerid?
Best regards,
Fangli
----- Original Message -----
To: "Fangli Pi" <hpcfapix@hlrs.de>
Cc: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
Sent: Wednesday, January 20, 2016 1:11:54 PM
Hello,
Fangli Pi, on Wed 20 Jan 2016 13:09:21 +0100, wrote:
> For example of the "vector_scal_spmd.c". Inside the cpu function, number of
> available cpu cores are get by:
> int nb_workers = starpu_combined_worker_get_size();
> then how could i keep this number for later usage?
Which kind of usage are you thinking about? The parallel worker size
can be different for different tasks, chosen by the scheduler.
Samuel
High Performance Computing Center (HLRS)
University of Stuttgart
Nobelstr. 19
D-70569 Stuttgart, Germany
phone: ++49-711-685-60442
Haut de le page
