Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links
- Date: Mon, 9 May 2016 12:07:30 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
This is a multi-part message in MIME format. Hi,
I meet the following problem during the build of starpu on the 1.1 svn branch rev 17349:
make[3]: stat: microbenchs/tasks_size_overhead.gp: Too many levels of symbolic links
make[3]: *** No rule to make target `microbenchs/tasks_size_overhead.gp', needed by `all-am'. Stop.
I get this problem on a mac os x 10.9, I could not reproduce it with Linux.
The config.log is attached.
Thanks for the help.
Florent
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.1.5, which was generated by GNU Autoconf 2.69. Invocation command line was $ ./configure --prefix=/builds/spack/opt/spack/darwin-x86_64/gcc-5.1.0/starpu-svn-1.1-f4ikwjx67c62gqqydyimt6z5zra7tyag --disable-build-doc --without-mpicc --disable-cuda --disable-opencl --enable-openmp=no ## --------- ## ## Platform. ## ## --------- ## hostname = ciosx uname -m = x86_64 uname -r = 13.4.0 uname -s = Darwin uname -v = Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 /usr/bin/uname -p = i386 /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = Mach kernel version: Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 Kernel configured for up to 2 processors. 2 processors are physically available. 2 processors are logically available. Processor type: i486 (Intel 80486) Processors active: 0 1 Primary memory available: 2.00 gigabytes Default processor set: 99 tasks, 342 threads, 2 processors Load average: 2.36, Mach factor: 0.56 /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown
- [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links, Florent Pruvost, 09/05/2016
- Re: [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links, Nathalie Furmento, 09/05/2016
- Re: [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links, Florent Pruvost, 09/05/2016
- Re: [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links, Florent Pruvost, 17/05/2016
- Re: [Starpu-devel] compil mac os x starpu-1.1: too many symbolic links, Samuel Thibault, 11/05/2016
