Archives de la liste
- From: Gabriel Piscoya Davila <gpiscoya2013@hotmail.com>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Problem with Opencl and starpu
- Date: Sat, 5 Nov 2016 00:38:02 +0000
- Accept-language: es-PE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gpiscoya2013@hotmail.com; spf=Pass smtp.mailfrom=gpiscoya2013@hotmail.com; spf=None smtp.helo=postmaster@BAY004-OMC2S23.hotmail.com
- Ironport-phdr: 9a23:0j0BkB0oNZ38l2q5smDT+DRfVm0co7zxezQtwd8ZsekWKvad9pjvdHbS+e9qxAeQG96KsbQV06GM7OjJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbWvXN+KxJ7on8mJuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT4r9Zf9HEaoO4o7dZdFKn3Yak8ZbhZFyg9dW8749fkuF/CSxGO7z0SSC9exgFUChLd8VT2U4n8tgP+t/Fhw2+VM8rsQr1yWDK47q4tRgW+2wkdMDts32jdkM19iOpjoQmqoA12i6LdfoCRPbIqcbvcZtgdVGMbBp8KfyxGHoa1bo9JBO0Ea7UL57LhrkcD+EPtTTKnA/nin2dF
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hello
Starpu is not recognizing my Acelerator. I had the same problem last week and "solve it " installing the hwloc and starpu again, i tryed this again but doesn't work.
I made this:
./configure -enable-maxbufers=50 -enable-stats -enable-verbose
make
make install
after the configure command:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: yes
SCC enabled: no
MIC enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
--enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 0
Maximum number of OpenCL devices: 8
Maximum number of SCC devices: 0
Maximum number of MIC threads: 0
Maximum number of memory nodes: 16
Maximum number of task buffers: 50
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: none
hwloc: yes
FxT trace enabled: no
StarPU-Top: no
Documentation: no
Examples: yes
StarPU Extensions:
MPI enabled: yes
MPI test suite: no
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
OpenMP runtime support enabled: no
SOCL enabled: yes
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: no
ayudame enabled: no
Native fortran support: no
Native MPI fortran support:
lstopo shows this:
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyMachine (6917MB)
Package L#0
L2 L#0 (2048KB) + L1i L#0 (96KB)
L1d L#0 (16KB) + Core L#0 + PU L#0 (P#0)
L1d L#1 (16KB) + Core L#1 + PU L#1 (P#1)
L2 L#1 (2048KB) + L1i L#1 (96KB)
L1d L#2 (16KB) + Core L#2 + PU L#2 (P#2)
L1d L#3 (16KB) + Core L#3 + PU L#3 (P#3)
HostBridge L#0
PCI 1002:130f
PCI 1022:7801
Block(Disk) L#0 "sda"
PCIBridge
PCI 10ec:8168
Net L#1 "eth1"
Package L#0
HostBridge L#0
PCI 1002:130f
PCI 1022:7801
PCIBridge
PCI 10ec:8168
Net L#1 "eth1"
starpu_machine_display shows :
StarPU has found :
4 CPU threads
CPU 0
CPU 1
CPU 2
CPU 3
0 CUDA devices
0 OpenCL devices
4 CPU threads
CPU 0
CPU 1
CPU 2
CPU 3
0 CUDA devices
0 OpenCL devices
Somebody knows what could be the problem ? I'm installing starpu via ssh in another machine(i dont know if this affect in something)
Gabriel
- [Starpu-devel] Problem with Opencl and starpu, Gabriel Piscoya Davila, 05/11/2016
- Re: [Starpu-devel] Problem with Opencl and starpu, Samuel Thibault, 07/11/2016
