Archives de la liste
Re: [Starpu-devel] Moving Workers from One Context To Another in Real Time
Chronologique Discussions
- To: Andra Hugo <andra.hugo@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Moving Workers from One Context To Another in Real Time
- Date: Tue, 28 Mar 2017 11:51:32 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabrielgazolla@gmail.com; spf=Pass smtp.mailfrom=gabrielgazolla@gmail.com; spf=None smtp.helo=postmaster@mail-yw0-f175.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Andra,
Thanks for all information!
I have another final question for you (Consider that I am not using hypervisor):
Is it possible to make a task prefer a certain worker (inside a context of 3 workers for instance) ?
I would like to this task to use Worker 2 inside Context 1 which has 3 workers, since I know it will execute faster....but there`s no problem if the task is assigned to another worker inside this context, but it would be better...
Is there a way to set or do this ?
Best,
Joao Gabriel
On Tue, Mar 28, 2017 at 11:25 AM, Andra Hugo <andra.hugo@inria.fr> wrote:
Hi Gabriel,You should use the hypervisor in that case and use the idle strategy.In sc_hypervisor/examples you have a few examples of how to do that. Let me know if you need any help with that.Best,AndraDe: "Gabriel Gazolla" <gabrielgazolla@gmail.com>
À: "Andra Hugo" <andra.hugo@inria.fr>
Envoyé: Mardi 28 Mars 2017 14:50:12
Objet: Re: [Starpu-devel] Moving Workers from One Context To Another in Real TimeHello Andra,Thanks for your fast answer. Now i know that this function you indicated do this "adds dynamically the workers inworkerids_ctx:, thank you very much!
I hope you can help me in another question:1) How Can I test from time to time that Context 2 Queue Line of Tasks is Empty so I can move the workers back to Context 1 dinamically ? Notice that I already submitted all the tasks to both contexts and after that there`s the barrier starpu_task_wait_for_all(), is it anywhere between the submission and this barrier?Best,JoaoOn Tue, Mar 28, 2017 at 4:39 AM, Andra Hugo <andra.hugo@inria.fr> wrote:Hi Gabriel,You can call starpu_sched_ctx_add_workers and starpu_sched_ctx_remove_workers. If you call only starpu_sched_ctx_add_workers without removing the workers from the other context, the workers will be shared between the two contexts and do round robin when poping tasks.Does this answer your question?Best,AndraDe: "Gabriel Gazolla" <gabrielgazolla@gmail.com>
À: starpu-devel@lists.gforge.inria.fr
Envoyé: Mardi 28 Mars 2017 02:12:03
Objet: [Starpu-devel] Moving Workers from One Context To Another in Real Time_______________________________________________Hello StarPU Team,
I have an interesting question, I hope you can help me...Imagine this situation:I have two contexts: Context 1 (CPU1, CPU2, CPU3) and Context 2 (GPU1)With starPU paused i submit 900 tasks to Context 1 and 100 tasks to Context 2.After I submit all of them, I resume, so all the tasks can start to execute.i put the function starpu_task_wait_for_all(); to wait for all the tasks to finish.Now comes the tricky part:I already know that Context 2 is going to finish light years faster than Context 1, I would like to move all workers from Context 2 to the Context 1, so the workers on Context 2 can help Context 1 finish faster. Is it possible to do it ? or do I need to wait for the barrier starpu_task_wait_for_all(); ?===I tried to do this with starpu_sched_ctx_set_inheritor, starpu_sched_ctx_finished_submit() and starpu_sched_ctx_delete().....but I think it doesnt work on the described situation, since I need to wait for the barrier starpu_task_wait_for_all() to one context inherit the workers of another context, am I right? or is there a way how to do it like on the described situation in real time?Thanks for any help or commentaries!Best,
Joao
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel--
- [Starpu-devel] Moving Workers from One Context To Another in Real Time, Gabriel Gazolla, 28/03/2017
- Re: [Starpu-devel] Moving Workers from One Context To Another in Real Time, Andra Hugo, 28/03/2017
- Re: [Starpu-devel] Moving Workers from One Context To Another in Real Time, Gabriel Gazolla, 28/03/2017
