Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Weird error with HWLOC
Archives de la liste
Chronologique Discussions
  • To: "Hoque, Reazul" <rhoque@vols.utk.edu>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Weird error with HWLOC
  • Date: Wed, 5 Apr 2017 10:53:43 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Hoque, Reazul, on mar. 04 avril 2017 21:57:37 +0000, wrote:
> echo $PKG_CONFIG
> /cm/shared/apps/hwloc/1.9.1/lib/pkgconfig/
pkg-config does not read a PKG_CONFIG variable, only PKG_CONFIG_PATH
> echo $PKG_CONFIG_PATH
Is this variable really exported? Check for instance
printenv | grep PKG_CONFIG_PATH
And does /cm/shared/apps/hwloc/1.9.1/lib/pkgconfig/ contain hwloc.pc?
> The help of the ./configure does not specify how we are supposed to point to
> the hwloc directory.
The help can not cover every bits of detail of configuration, it would
then be thousands of lines long. It has to be a quick reminder only.
> How is a normal user supposed to know which env_variable
> to set?
Either the distribution or the module environment already provides the
correct environment variables (but it has to do so properly of course),
or the user uses --with-hwloc=... as you did, but again hwloc has to
have been installed properly of course.
> What is the actual problem here?
Apparently /cm/shared/apps/hwloc/1.9.1/lib/pkgconfig/ just does not
contain hwloc.pc, i.e. a problem in your system.
> I succeeded before with version 1.2.0.
Does it still work with 1.2.0 nowadays?
We have not changed the hwloc detection between 1.2.0 and the current
1.2 branch.
Samuel
Haut de le page
