Archives de la liste
- To: <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] A build error with SVN version 21927
- Date: Tue, 22 Aug 2017 12:36:59 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vedran.novakovic@stfc.ac.uk; spf=None smtp.mailfrom=vedran.novakovic@stfc.ac.uk; spf=None smtp.helo=postmaster@smtp-out4.electric.net
- Ironport-phdr: 9a23:KhCmcBbujiAEdLsfSQqfTGb/LSx+4OfEezUN459isYplN5qZpsqzbnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUCrLhZ8PPzoX4Lfkcmz/+Sz4IHIJQpGgyCybPVzKg+3pEPfrJ9Fr5FlL/Nl1BbFuHJOPeJR22prIkySlD7n+sm7updotTlT7aFyv/VcWLn3KvxrBYdTCy4rZjg4
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
If StarPU is configured *without* FxT, as
MAGMA_CFLAGS="-DADD_ -I.../magma-2.2.0/include"
MAGMA_LIBS="-L.../magma-2.2.0/lib -lmagma -L${CUDA_HOME}/lib64 -lcublas
-lcudart"
./configure
--prefix=...
--enable-dependency-tracking
--disable-mpi
--enable-long-check
--enable-new-check
--disable-valgrind
--disable-opencl
--enable-verbose=extra
--enable-model-debug
--enable-memory-stats
--enable-openmp
--enable-blas-lib=mkl
--disable-starpufft
--disable-build-doc
--with-gnu-ld
--with-mkl-cflags="-I${MKLROOT}/include"
--with-mkl-ldflags="-L${MKLROOT}/lib/intel64 -lmkl_gf_lp64
-lmkl_sequential -lmkl_core -lpthread -lm -ldl"
Then the build fails with an error:
CC libstarpu_1.3_la-jobs.lo
.../src/core/jobs.c: In function Œ_starpu_job_create¹:
.../src/core/jobs.c:94:17: error: implicit declaration of function
Œ_starpu_fxt_get_job_id¹ [-Werror=implicit-function-declaration]
job->job_id = _starpu_fxt_get_job_id();
cc1: some warnings being treated as errors
Makefile:1455: recipe for target 'libstarpu_1.3_la-jobs.lo' failed
make[2]: *** [libstarpu_1.3_la-jobs.lo] Error 1
If, on the contrary, StarPU is configured *with* FxT, it builds just fine.
Regards,
Vedran Novakovic
- [Starpu-devel] A build error with SVN version 21927, vedran.novakovic, 22/08/2017
- Re: [Starpu-devel] A build error with SVN version 21927, Samuel Thibault, 22/08/2017
- Re: [Starpu-devel] A build error with SVN version 21927, vedran.novakovic, 22/08/2017
