Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [starpu_matrix_filter_block: obtain block sizes, asynchronous interface]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [starpu_matrix_filter_block: obtain block sizes, asynchronous interface]
  • Date: Fri, 24 Nov 2017 17:27:03 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f43.google.com
  • Ironport-phdr: 9a23:ifZD2RJPhnzrJYEJhtmcpTZWNBhigK39O0sv0rFitYgXIv3xwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uCUOEw/nKE95K/r4HqbWjt+rzKa99ZrJbAgOhTynYLo0Ig/lgx/Ws5wziJtjL+4YwBLNr31LfPoekWZhNVOW2R/278O9+p1k7Qxfvvsg84hLVqCsLPdwdqBREDlzazN938bsrxSWFQY=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear all,
I’m on a mission to implement a BLAS “daxpy" routine (https://developer.apple.com/documentation/accelerate/1513298-cblas_daxpy?language=objc) in order to learn the basics of StarPU. I have a few questions I would like to ask:
1) When I partition the data automatically using the “starpu_matrix_filter_block”, is there a way to obtain the block sizes via the StarPU API?
2) Do I understand correctly, that when I use asynchronous interface, i.e. plan and submit data partition via StarPU routines, there is no way to iterate via the blocks using “starpu_data_get_nb_children” and “starpu_data_get_child” from the Basic API (http://starpu.gforge.inria.fr/doc/html/group__API__Data__Partition.html)?
Please see the C source code of my StarPU daxpy routine attached. Thank you and have a good Friday!
Best wishes,
Maksims
Attachment: xpu.c
Description: Binary data
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ http://mabalenk.gitlab.io
Haut de le page
