Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [Passing an array to StarPU task]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [Passing an array to StarPU task]
  • Date: Wed, 24 Jan 2018 17:28:34 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f53.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear all,
I would like to pass an array to a StarPU task with the “starpu_task_insert()” routine, but I would __not__ like to set any data dependencies on this array. Is that possible? At the moment I’m using the following construct, where “arr” is an integer array of length “n":
starpu_task_insert(
STARPU_VALUE, &arr, n*sizeof(int),
0);
But the code crashes as soon as I attempt to access any element of the array.
Best wishes,
Maxim
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ http://mabalenk.gitlab.io
Haut de le page
