Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [segfault debugging]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [segfault debugging]
  • Date: Mon, 29 Jan 2018 12:28:20 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wr0-f172.google.com
  • Ironport-phdr: 9a23:GWQdShatAaBWg/n+74Pchnr/LSx+4OfEezUN459isYplN5qZr8u/bnLW6fgltlLVR4KTs6sC17KP9fi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCagbb9oMBm6sRjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjm58axlVAHnhzsGNz4h8WHYlMpwjL5AoBm8oxBz2pPYbJ2JOPZ7eK7WYNEUSndbXstJVyJOHoyzYZYMAeQPI+hWqJLwqEESoRu7HwSsBP/jxz1Oi3Tr3aM6yeMhEQTe0QInBd0Pv3XUrNDoP6oOSu+61q3IwivFb/NV3jf99pXDfxckof6WUrNwcM/RxVM1GAzelFqQrZLqPzWW1uQKrWiW9OVgVee1hG4mrwF9uCSgxsApioTQgI8e117K9SJ8wIkvJN24TlZ2YdGlEJtMsyGVLZB5TtkjQ2Fvvisx174IuYajcSQU1JgqwwTTZv+HfoSS/x7vSuWcLS1liH9nZr6znwu+/Ea8xuHmVcS500xGojRKn9XQrHwA1h3e586aQfVn5EihwyyA1wXL5+FEP080ka3bJoYkwrEql5oTtV3PHyHsmEnqlaOWeFgo9+q25+j9bbXmoZicN4Bwig7gKKghhsu/AeEgPggPWWiU5/i82aX98UHlRLhGlP47n6nDvJzHO8gWpbS1DxJX34o98xq/Ci2p0NUcnXkJNlJFfxeHgpDsO17UL/H4DPK/j062nzhw3f/GOqPuApPOLnjEjrfsZrl960tGxwoyydBT/Y5bCrYEIP7rQE/+qMTYDgMlMwyz2+vnE8l92ZkEWWKXH6+VKb7dvkGW5u0xJ+mBf4sVuDfmK/g5/P7il3A5mVEafamz0psYdmq0HvVgI0WDYHrjmM0NEWkQvll2cOu/k0GLSyZOInq/Qa84zjU6E569S4jNQZqijfqA2j26F9tYfDNoEFeJRFLhZ4SBE94GYSafJMxmjHRQULGxSopn3BunsAL8yL15BuXR8ywc85nk0Y4mtKXoiRgu+GksXIym2GaXQjQxxztQHm5k7OVEuUV4j2y7/+19iv1cG8ZU4qoQAAg/PJ/Yied9DoKrA16TTpKyUF+jB+6eL3QpVNtomo0BZk98H5OpiRWRh3P3UY9QrKSCAdkPyoyZ33X1IJwjmXPP1a1kkEN+B8UWajfgial4+AzeQYXOlhfBmg==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Samuel,
I hope all is well with you. I am struggling to debug a segmentation fault in my code. The gdb output is as follows:
Thread 4 "CPU 2" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffee2c4700 (LWP 3228)]
0x00007ffff736b039 in _starpu_notify_cg_list (successors=0x555555a2ec50) at core/dependencies/cg.c:262
262 unsigned cg_type = cg->cg_type;
(gdb) bt
#0  0x00007ffff736b039 in _starpu_notify_cg_list (successors=0x555555a2ec50) at core/dependencies/cg.c:262
#1  0x00007ffff73735ff in _starpu_notify_task_dependencies (j=0x555555a2ea90) at core/dependencies/task_deps.c:57
#2  0x00007ffff736b386 in _starpu_notify_dependencies (j=0x555555a2ea90) at core/dependencies/dependencies.c:33
#3  0x00007ffff735368c in _starpu_handle_job_termination (j=0x555555a2ea90) at core/jobs.c:375
#4  0x00007ffff744592d in _starpu_cpu_driver_run_once (cpu_worker=0x7ffff76d39d0 <_starpu_config+3376>) at drivers/cpu/driver_cpu.c:328
#5  0x00007ffff74459ef in _starpu_cpu_worker (arg=0x7ffff76d39d0 <_starpu_config+3376>) at drivers/cpu/driver_cpu.c:361
#6  0x00007ffff355808c in start_thread () from /usr/lib/libpthread.so.0
#7  0x00007ffff328fe7f in clone () from /usr/lib/libc.so.6
As I understand, something is wrong with the worker’s task dependencies. But I would like to find the line of __my__ code that is causing the trouble. Do you possibly know, how to find that out? The “backtrace (bt)” command is not helpful in this case. Thank you!
Best wishes,
Maxim
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ http://mabalenk.gitlab.io
Haut de le page
