Archives de la liste
- To: anne caselli <anne.caselli@ensea.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Questionsur les dépendancesexplicites
- Date: Wed, 14 Mar 2018 09:15:46 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Bonjour,
Il vaut mieux toujours garder la liste en copie, pour éviter de se
retrouver sans réponse si jamais la seule personne à qui vous envoyez un
mail se retrouve partir en vacances...
anne caselli, on mar. 13 mars 2018 20:24:59 +0100, wrote:
> En effet il y a bien une inversion. Cependant, même après
> correction,l'affichage des id reste décroissant, alors que si les
> dépendances sont bien respectées l'affichage devrait être croissant non ?
Après correction j'obtiens bien un ordre croissant, cf pièce ci-jointe.
Samuel
#include <starpu.h> #define cont 10 #define TAG(i) ((starpu_tag_t) (i)) struct params { starpu_tag_t id; }; uint64_t clts[cont]; volatile int nc; void display (void * buffers[], void * cl_arg) { struct params *parametres = cl_arg; // int ret = starpu_tag_wait(parametres->id-1); // STARPU_CHECK_RETURN_VALUE(ret, "starpu_tag_wait"); int idx = nc++; //STARPU_ATOMIC_ADD(&nc, 1); clts[idx] = parametres->id; free(parametres); } struct starpu_codelet clt = { .cpu_funcs = { display }, .cpu_funcs_name = { "display" }, .modes = {STARPU_RW}, .nbuffers = 0, .model = NULL }; void spawn(starpu_tag_t tag, unsigned deps, starpu_tag_t dst) { struct starpu_task *task = starpu_task_create(); task->cl = &clt; /*Pointeur sur le codelet*/ task->use_tag = 1; task->tag_id = tag; struct params *parametres1 = malloc(sizeof(struct params)); parametres1->id = tag; /* Les paramètres sont arguments de la tâche*/ task->cl_arg = parametres1; task->cl_arg_size = sizeof(*parametres1); starpu_tag_declare_deps(tag, deps, dst); int ret = starpu_task_submit(task); /*submit the task to StarPU*/ STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit"); } int main(int argc, char **argv) { /*initialisation StarPU*/ int ret = starpu_init(NULL); STARPU_CHECK_RETURN_VALUE(ret, "starpu_init"); /*On boucle pour créer le nombre de tâche voulu*/ for (unsigned long i = cont-1; i>0; i--) //for (unsigned long i = 1; i< cont; i++) spawn( TAG(i), 1, TAG(i-1)); spawn(TAG(0),0,TAG(0)); starpu_task_wait_for_all(); for (int i = 0; i < cont; i++) { printf("%lu\t", clts[i]); } puts(""); /*terminate StarPU*/ starpu_shutdown(); return 0; }
- [Starpu-devel] Question sur les dépendances explicites, anne caselli, 13/03/2018
- Re: [Starpu-devel] Question sur les dépendances explicites, Samuel Thibault, 13/03/2018
- Re: [Starpu-devel] Questionsur les dépendancesexplicites, anne caselli, 14/03/2018
- Re: [Starpu-devel] Questionsur les dépendancesexplicites, Samuel Thibault, 14/03/2018
