Archives de la liste
Re: [Starpu-devel] StarPU - starpu_codelet_pack_arg doesn't exist anymore ?
Chronologique Discussions
- To: Jules Pénuchot <penuchot@lri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU - starpu_codelet_pack_arg doesn't exist anymore ?
- Date: Fri, 1 Jun 2018 10:18:19 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
Jules Pénuchot, le ven. 01 juin 2018 09:26:35 +0200, a ecrit:
> I've tried to use the starpu_codelet_pack_arg function as well as
> starpu_codelet_pack_arg_init and starpu_codelet_pack_arg_fini in a program,
> the functions are documented yet I keep getting an 'undeclared identifier'
> error when I try to use them.
Could you copy/paste the exact error along with the file that produce
them?
> Do these functions even still exist ?
Sure, we usually don't remove function, or else keep a #define
compatibility macro.
> Or could I find them in another header ?
They are in starpu_task_util.h which is included from starpu.h.
It is however available only since version 1.2.4, perhaps you are using
an older version?
Samuel
- [Starpu-devel] StarPU - starpu_codelet_pack_arg doesn't exist anymore ?, Jules Pénuchot, 01/06/2018
- Re: [Starpu-devel] StarPU - starpu_codelet_pack_arg doesn't exist anymore ?, Samuel Thibault, 01/06/2018
