Archives de la liste
- To: Alfredo Buttari <alfredo.buttari@enseeiht.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] segfault in StarPU memory allocator
- Date: Mon, 2 Jul 2018 23:20:27 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Alfredo Buttari, le lun. 02 juil. 2018 16:57:27 +0200, a ecrit:
> Unfortunately valgrind does not like CUDA code:
> ==1292== Memcheck, a memory error detector
> ==1292== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
> ==1292== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
> ==1292== Command: ./dqrm_test
> ==1292==
> vex amd64->IR: unhandled instruction bytes: 0xF 0xAE 0x64 0x24 0x40
> 0x48 0x8B 0x73
> vex amd64->IR: REX=0 REX.W=0 REX.R=0 REX.X=0 REX.B=0
> vex amd64->IR: VEX=0 VEX.L=0 VEX.nVVVV=0x0 ESC=0F
> vex amd64->IR: PFX.66=0 PFX.F2=0 PFX.F3=0
> ==1292== valgrind: Unrecognised instruction at address 0x4015f48.
> ==1292== at 0x4015F48: _dl_runtime_resolve_xsave (in
> /usr/lib64/ld-2.17.so)
> [cut]
Mmm, it's not CUDA that it doesn't like, but the glibc itself. Valgrind
3.10 is indeed quite old, you need to upgrade it to get it to work with
recent glibc.
Samuel
- [Starpu-devel] segfault in StarPU memory allocator, Alfredo Buttari, 02/07/2018
- Re: [Starpu-devel] segfault in StarPU memory allocator, Samuel Thibault, 02/07/2018
- Re: [Starpu-devel] segfault in StarPU memory allocator, Alfredo Buttari, 05/07/2018
