Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] data_unregister_submit() does not flush data from GPU to CPU
Archives de la liste
Chronologique Discussions
  • To: Aleksandr Mikhalev <aleksandr.mikhalev@kaust.edu.sa>
  • Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] data_unregister_submit() does not flush data from GPU to CPU
  • Date: Tue, 24 Jul 2018 17:39:09 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Aleksandr Mikhalev, le mar. 24 juil. 2018 16:18:36 +0300, a ecrit:
> If I understood correctly, idea of “submit” functions is to hint StarPU to
> flush data from GPU to CPU,
No, "submit" means that it is asynchronous, i.e. it retuns immediately
without waiting for the result.
> StarPU does not copy output data from GPU to CPU if corresponding handle is
> destroyed by starpu_data_unregister_submit().
Well, yes, and that is what is documented.
I don't actually really see how it would be useful to copy output
back from GPU to CPU: since it is asynchronous, you have no way of
knowing when that will be effective. If you want to bring back data
to the CPU, either use starpu_data_acquire(STARPU_R) (synchronous) or
starpu_data_acquire_cb(STARPU_R) (asynchronous but with a callback
called when the data up to date on the CPU) and starpu_data_release()
> The same holds true for starpu_invalidate_data_submit().
Well, yes, invalidate_data_submit() is explicitly exactly meant to
discard the value of a data.
Samuel
Haut de le page
