Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Task start and end time in SPMD-mode
Archives de la liste
Chronologique Discussions
  • To: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Cc: Mahmoud Eljammaly <mjammaly@cs.umu.se>
  • Subject: [Starpu-devel] Task start and end time in SPMD-mode
  • Date: Thu, 23 Aug 2018 16:29:17 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23:dkVfiBUdhMaqgYyaj3W52I7xQ4rV8LGtZVwlr6E/grcLSJyIuqrYbBSDt8tkgFKBZ4jH8fUM07OQ7/i/HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba9wIRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KpwVhTmlDkIOCI48GHPi8x/kqRboA66pxdix4LYeZyZOOZicq/Ye94RWGhPUdtLVyFZDYyzc4QBAeQBM+hGsofzpFQPohWlCAmwBu7vyCNEimPs0KEk1ekqDAHI3BYnH9ILqHnaq9T1NL0RUeCy0aLGyjXCb/dS2Tb964jIdQshofKNXbltdsfRzEgvFxnGjlWXrIzoJC+a1v8Xv2iG6upgSPiji3U5pAxopDWk28QiipHRi44IxF3I6T91zJg7KNC8UkJ2bsKoHIFOuyyaL4d6XN8uT311tCs/y7AJooK3cS0Ux5kiyBPTd/OKf5SN7x/mVeucIjF1j29/dr2lnRa9602gx/X8Vsaq1FZKqTJIktzWuXAM0xzf8NSISuBn8ke83DaPyhrf6vpaLkwslKrbLYAuwqIom5YOv0nPAjX6lFv4gaKSbEkp9fSk5/75brjmvpOcMpV7igD6MqQggMy/BuE4PxALX2ia4+S817rj/UjiTbpWlf06iLTZsJXHJcgBva62HRdZ0pw/5BanEzemzNMYkGEcLFJZYh2HlZDpO0zXLP/lE/i/nUqjkDNwyvDCP73hGYnNLmPZnLfuc7Z97FRcyAUtwtxF5pJUDKsBIPPpVUPrutzYFExxDwvh+PruEs1gnq8TR2+LSvuCLKrIqULN6u8xLu2kYI4OpC27JPYi/fHjy34/g14UO6ezi8g5cne9S9FnOUaeKV/9htMQEmARvQt2GOnrkl6FVBZYfDCvWr96/TxtW9HuNpvKWo342O/J5yy8BJADIzkeUgndQ0etTJ2NXrI3UAzXJ8ZgljIeUr34Et0qzlezsRK80Lc1d7OIqB1djorq0Z1O38OWjQs7rGUmBN/bzmSQCXp5zDtRGm0GmZtnqEk48W+tlKh1h/sBS45W7vJNFAwhc4PZ0qphBoKqVw==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I would like to know how StarPU records task start and end times (starpu_profiling_task_info::start_time and starpu_profiling_task_info::end_time) in SPMD-mode.
It appears that each worker records the task start and end times separately on lines src/drivers/cpu/driver_cpu.c:93 and src/drivers/cpu/driver_cpu.c:122, respectively. Rank 0 later stores it's own timing information to the job-structure on line src/drivers/cpu/driver_cpu.c:155. My conclusion is that only the rank 0 gets recorded. Is this correct?
All line number are from StarPU 1.2.4.
Best Regards,
Mirko Myllykoski
Haut de le page
