Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] A possible bug in StarPU 1.3.xx
Archives de la liste
Chronologique Discussions
  • To: Olivier Aumage <olivier.aumage@inria.fr>
  • Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] A possible bug in StarPU 1.3.xx
  • Date: Fri, 28 Sep 2018 09:42:15 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Should I consider parallel task policies to be a deprecated feature of StarPU? If so, what is the recommended way to implement parallel tasks? I read about "clustering" but the documentation of that feature appears to be very limited.
- Mirko
On 2018-09-28 09:29, Olivier Aumage wrote:
Hi Mirko,
The issue is actually the "pheft" policy selected for the sched
context being created. The "pheft" policy has always been experimental
and has not received much work for quite a long time.
The "peager" policy is also experimental but in a reasonably stable
state. When replacing the "pheft" policy by "peager" (or one of the
sequential task policies) the program completes for me.
Best regards,
Olivier Aumage
Le 27 sept. 2018 à 14:45, Mirko Myllykoski <mirkom@cs.umu.se> a écrit :
Hi,
I believe that I have found a bug from StarPU 1.3.xx. I am
trying to create a scheduling context that contains a set of
CPU and CUDA workers. The code functions perfectly with
StarPU 1.2.6 but leads to a segmentation fault with StarPU
1.3.xx. I have isolated the problem to the following code
lines:
========== CODE BEGINS ==========
#include <starpu.h>
int main()
if (starpu_init(NULL) != 0)
abort();
// get CPU workers
int cpu_worker_ids[STARPU_NMAXWORKERS];
int cpu_worker_count = starpu_worker_get_ids_by_type(
STARPU_CPU_WORKER, cpu_worker_ids, STARPU_NMAXWORKERS);
// get CUDA workers
int gpu_worker_ids[STARPU_NMAXWORKERS];
int gpu_worker_count = starpu_worker_get_ids_by_type(
STARPU_CUDA_WORKER, gpu_worker_ids, STARPU_NMAXWORKERS);
// create a parallel scheduling context and add all CPU
// workers to it
unsigned parallel_ctx = starpu_sched_ctx_create(
cpu_worker_ids, cpu_worker_count, "parallel_cxt",
STARPU_SCHED_CTX_POLICY_NAME, "pheft", 0);
// add CUDA workers, if any, to the parallel scheduling
// context
if (0 < gpu_worker_count)
starpu_sched_ctx_add_workers( // <=== *** LINE 21 ***
gpu_worker_ids, gpu_worker_count, parallel_ctx);
starpu_sched_ctx_delete(parallel_ctx);
starpu_shutdown();
========== CODE ENDS ==========
GDB backtrace:
========== GDB BEGINS ==========
(gdb) bt
#0 0x00007ffff7846d29 in lws_select_victim (ws=0x555555a14250, sched_ctx_id=0, workerid=3) at sched_policies/work_stealing_policy.c:773
#1 0x00007ffff7845ff8 in ws_pop_task (sched_ctx_id=0) at sched_policies/work_stealing_policy.c:567
#2 0x00007ffff782a2f0 in _starpu_pop_task (worker=0x7ffff7ba31c8 <_starpu_config+5640>) at core/sched_policy.c:871
#3 0x00007ffff78629aa in _starpu_get_worker_task (worker=0x7ffff7ba31c8 <_starpu_config+5640>, workerid=3, memnode=0) at drivers/driver_common/driver_common.c:377
#4 0x00007ffff7915750 in _starpu_cpu_driver_run_once (cpu_worker=0x7ffff7ba31c8 <_starpu_config+5640>) at drivers/cpu/driver_cpu.c:303
#5 0x00007ffff7915dd8 in _starpu_cpu_worker (arg=0x7ffff7ba31c8 <_starpu_config+5640>) at drivers/cpu/driver_cpu.c:407
#6 0x00007ffff6f756db in start_thread (arg=0x7fffbbfff700) at pthread_create.c:463
#7 0x00007ffff74b288f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
========== GDB ENDS ==========
Or, if I set STARPU_SCHED=prio, I get:
(gdb) bt
#0 0x00007ffff783c59e in _starpu_sched_ctx_list_remove_elt (list=0x7ffff7ba25f8 <_starpu_config+2616>, rm=0x5555558979c0) at core/sched_ctx_list.c:262
#1 0x00007ffff783c6ad in _starpu_sched_ctx_list_move (list=0x7ffff7ba25f8 <_starpu_config+2616>, sched_ctx=1, prio_to=1) at core/sched_ctx_list.c:293
#2 0x00007ffff78390d3 in set_priority_on_notified_workers (workers=0x7fffffffd9b0, nworkers=1, sched_ctx_id=1, priority=1) at core/sched_ctx.c:2099
#3 0x00007ffff78356d9 in add_notified_workers (workerids=0x7fffffffd9b0, nworkers=1, sched_ctx_id=1) at core/sched_ctx.c:1228
#4 0x00007ffff7835fe7 in starpu_sched_ctx_add_workers (workers_to_add=0x7fffffffd9b0, nworkers_to_add=1, sched_ctx_id=1) at core/sched_ctx.c:1316
#5 0x0000555555554a54 in main () at main.c:21
Best Regards,
Mirko Myllykoski
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
