Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] LAPACK symbol conflict with StarPU 1.3
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] LAPACK symbol conflict with StarPU 1.3
  • Date: Tue, 30 Oct 2018 22:03:02 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Mirko Myllykoski, le mar. 30 oct. 2018 22:00:42 +0100, a ecrit:
> On 2018-10-30 13:31, Samuel Thibault wrote:
> > Ah, right, that comes from the mlr support. Either you manage to get
> > starpu's configure find your system-provided blas/lapack, or you can
> > just pass --disable-mlr to ./configure to disable the feature (which I
> > guess you don't use).
> I was thinking whether it is possible to hide the symbols or rename the BLAS
> and LAPACK functions in min-dgels directory so that they do not cause
> conflicts even when StarPU configuration file fails to detect system
> BLAS/LAPACK.
Yes, we'll need to do something like that. I was just proposing a
workaround for the time being.
Samuel
Haut de le page
