Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU 1.3 RC1 + peager problem
Archives de la liste
Chronologique Discussions
  • To: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] StarPU 1.3 RC1 + peager problem
  • Date: Thu, 07 Feb 2019 14:03:46 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I have been experiencing some problems with the new StarPU 1.3.0 release candidate and the peager scheduler. I have reported similar/related problems earlier but I am quite sure that this problem did not exists with the older StarPU 1.3 nightly snapshots. StarPU 1.2.6 works just fine.
The problem can reproduced with the following code:
#include <unistd.h>
#include <unistd.h>
#include <starpu.h>
static void kernel(void *buffers[], void *cl_args)
sleep(1);
static struct starpu_codelet codelet = {
.cpu_funcs = { kernel },
.type = STARPU_FORKJOIN,
.max_parallelism = INT_MAX
int main()
struct starpu_conf conf;
starpu_conf_init(&conf);
conf.ncuda = 0;
if (starpu_init(&conf) != 0)
return 1;
int worker_ids[STARPU_NMAXWORKERS];
int worker_count = starpu_worker_get_ids_by_type(
STARPU_CPU_WORKER, worker_ids, STARPU_NMAXWORKERS);
int parallel_ctx_size = worker_count/2;
int other_ctx_size = worker_count - parallel_ctx_size;
unsigned parallel_ctx = starpu_sched_ctx_create(
worker_ids, parallel_ctx_size, "parallel_cxt",
STARPU_SCHED_CTX_POLICY_NAME, "peager", 0);
unsigned other_ctx = starpu_sched_ctx_create(
worker_ids+parallel_ctx_size, other_ctx_size, "other_ctx",
STARPU_SCHED_CTX_POLICY_NAME, "eager", 0);
for (int i = 0; i < 10; i++)
starpu_task_insert(&codelet, STARPU_SCHED_CTX, parallel_ctx, 0);
starpu_task_insert(&codelet, STARPU_SCHED_CTX, other_ctx, 0);
starpu_task_wait_for_all_in_ctx(parallel_ctx);
starpu_task_wait_for_all_in_ctx(other_ctx);
starpu_sched_ctx_delete(parallel_ctx);
starpu_sched_ctx_delete(other_ctx);
starpu_shutdown();
return 0;
GDB outputs the following:
Thread 8 "CPU 1" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffcce69700 (LWP 29747)]
0x00007ffff7927082 in pop_task_peager_policy (sched_ctx_id=<optimized out>) at sched_policies/parallel_eager.c:280
280 sched_policies/parallel_eager.c: No such file or directory.
(gdb) bt
#0 0x00007ffff7927082 in pop_task_peager_policy (sched_ctx_id=<optimized out>) at sched_policies/parallel_eager.c:280
#1 0x00007ffff7911596 in _starpu_pop_task (worker=worker@entry=0x7ffff7ba4790 <_starpu_config+3120>) at core/sched_policy.c:880
#2 0x00007ffff792cb1f in _starpu_get_worker_task (worker=worker@entry=0x7ffff7ba4790 <_starpu_config+3120>, workerid=workerid@entry=1, memnode=memnode@entry=0)
at drivers/driver_common/driver_common.c:377
#3 0x00007ffff7968926 in _starpu_cpu_driver_run_once (cpu_worker=cpu_worker@entry=0x7ffff7ba4790 <_starpu_config+3120>) at drivers/cpu/driver_cpu.c:304
#4 0x00007ffff7968b4d in _starpu_cpu_worker (arg=0x7ffff7ba4790 <_starpu_config+3120>) at drivers/cpu/driver_cpu.c:408
#5 0x00007ffff70a36db in start_thread (arg=0x7fffcce69700) at pthread_create.c:463
#6 0x00007ffff75e088f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
(gdb) frame 0
280 in sched_policies/parallel_eager.c
(gdb) print common_data
$1 = (struct _starpu_peager_common_data *) 0x0
Best Regards,
Mirko Myllykoski
Haut de le page
