Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU multiple nodes in a cluster
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] StarPU multiple nodes in a cluster
  • Date: Tue, 20 Aug 2019 17:44:25 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jakub.homola@vsb.cz; spf=None smtp.mailfrom=jakub.homola@vsb.cz; spf=None smtp.helo=postmaster@smtp.vsb.cz
  • Importance: normal
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I am trying to use StarPU, so far I pretty much like it, the handbook is well-written, but I have a question about it.
First, I had a problem with an asynchronously partitioned temporary data buffer (that with home node -1) (more precisely with cleaning the partitioning and automatic unpartitioning), but then I looked through the StarPU code and found a FIXME note, so it seems like you already know about that. So I will just use classical data registration, no temp.
A more important thing, Id like to ask, how do I run/configure StarPU such that it uses more than one computational node in a cluster/supercomputer for the execution of tasks? Is it even supported? I wasnt able to find anything about it in the handbook.
Thanks in advance for an answer,
Jakub Homola
Haut de le page
