Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-announce@lists.gforge.inria.fr
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] StarPU v1.3.3 available
- Date: Thu, 24 Oct 2019 16:42:07 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
All, The release 1.3.3 of StarPU is available, with the following changes New features: * New semantic for starpu_task_insert() and alike parameters STARPU_CALLBACK_ARG, STARPU_PROLOGUE_CALLBACK_ARG, and STARPU_PROLOGUE_CALLBACK_POP_ARG which set respectively starpu_task::callback_arg_free, starpu_task::prologue_callback_arg_free and starpu_task::prologue_callback_pop_arg_free to 1 when used. New parameters STARPU_CALLBACK_ARG_NFREE, STARPU_CALLBACK_WITH_ARG_NFREE, STARPU_PROLOGUE_CALLBACK_ARG_NFREE, and STARPU_PROLOGUE_CALLBACK_POP_ARG_NFREE which set the corresponding fields of starpu_task to 0. * starpufft: Support 3D. * New modular-eager-prio scheduler. * Add 'ready' heuristic to modular schedulers. * New modular-heteroprio scheduler. * Add STARPU_TASK_SCHED_DATA * Add support for staging schedulers. * New modular-heteroprio-heft scheduler. * New dmdap "data-aware performance model (priority)" scheduler Changes: * Modification in the Native Fortran interface of the functions fstarpu_mpi_task_insert, fstarpu_mpi_task_build and fstarpu_mpi_task_post_build to only take 1 parameter being the MPI communicator, the codelet and the various parameters for the task. Small features: * New starpu_task_insert() and alike parameter STARPU_TASK_WORKERIDS allowing to set the fields starpu_task::workerids_len and starpu_task::workerids * New starpu_task_insert() and alike parameters STARPU_SEQUENTIAL_CONSISTENCY, STARPU_TASK_NO_SUBMITORDER and STARPU_TASK_PROFILING_INFO * New function starpu_create_callback_task() which creates and submits an empty task with the specified callback * Use the S4U interface of Simgrid instead of xbt and MSG. Small changes: * Default modular worker queues to 2 tasks unless it's an heft scheduler * Separate out STATUS_SLEEPING_SCHEDULING state from STATUS_SLEEPING state When running the scheduler while being idle, workers do not go in the STATUS_SCHEDULING state, so that that time is considered as idle time instead of overhead. The 1.3 release serie brings among other functionalities - a MPI master-slave support, - a tool to replay execution through SimGrid, - a HDF5 implementation of the Out-of-core, - a new implementation of StarPU-MPI on top of NewMadeleine, - implicit support for asynchronous partition planning, - a resource management module to share processor cores and accelerator devices with other parallel runtime systems, ... The tarball along with the md5sum file and the OpenPGP signature are available as usual on the starpu web site http://starpu.gforge.inria.fr/files/ or directly on the Gforge web site https://gforge.inria.fr/frs/?group_id=1570 Nathalie, for the StarPU team. |
- [Starpu-devel] StarPU v1.3.3 available, Nathalie Furmento, 24/10/2019
