Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU installation pkg-config
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] StarPU installation pkg-config
  • Date: Wed, 13 Nov 2019 13:32:04 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lucas.nesi@inf.ufrgs.br; spf=Pass smtp.mailfrom=lucas.nesi@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello, StarPU devs,
I got a minor problem when installing StarPU.
When installing StarPU with spack on a clean Debian image without the pkg-config package, I am getting the following error on the configure step:
==> Error: ProcessError: Command exited with status 1:
'/tmp/root/spack-stage/spack-stage-starpu-1.3.1-esro2o3erva6iv5cfpjzc4xhwbda7232/spack-src/configure' '--prefix=/scratch/spack/opt/spack/linux-debian10-broadwell/gcc-8.3.0/starpu-1.3.1-esro2o3erva6iv5cfpjzc4xhwbda7232' '--disable-build-doc' '--disable-starpu-top' '--enable-shared' '--disable-debug' '--disable-verbose' '--enable-fast' '--enable-build-tests' '--enable-build-examples' '--disable-fortran' '--enable-openmp' '--disable-opencl' '--disable-cuda' '--without-mpicc' '' '' '' '--with-hwloc=/scratch/spack/opt/spack/linux-debian10-broadwell/gcc-8.3.0/hwloc-1.11.11-l5dovmrefwukdtlbt3h44bleg4fzowpx' '--with-fxt=/scratch/spack/opt/spack/linux-debian10-broadwell/gcc-8.3.0/fxt-0.3.5-rkrqydleupiwvoggyqzo42r3mfedsoty' '--enable-paje-codelet-details'
1 error found in build log:
288 checking for OPENBLAS... checking for library containing sgemm_... no
289 checking which BLAS lib should be used... none
290 checking whether multiple linear regression models are disabled... no
291 checking for library containing dgels_... no
292 checking whether min-dgels is linked... no
293 checking min-dgels source... yes
>> 294 checking for FFTW... checking for FFTWF... checking for FFTWL... checking for HWLOC... configure: error: cannot find hwloc
Instead of warning about the missing pkg-config package, the warning misleads informing about hwloc. Installing pkg-config solves the problem.
Thank you,
Lucas Nesi
Haut de le page
