Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Jakub Homola <jakub.homola@vsb.cz>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU mpi support installation
- Date: Tue, 19 Nov 2019 10:19:05 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Jakub,
You should try by setting the option
--with-mpicc=path_to_the_mpicc_executable when calling configure
If that still does not work, please
send your file config.log so that we can have more details on
what's failing.
Cheers,
Nathalie
On 19/11/2019 10:05, Jakub Homola
wrote:
Hello, I am trying to install StarPU with MPI support, however on my local notebook it always installs without starpu-mpi. I have read, that starpu-mpi is automatically installed when MPI is detected. I do have MPI installed on my computer (mpirun and mpiexec commands work properly), but starpu-mpi does not get installed. It fails already in the ./configure phase, there is a line saying that StarPU MPI is not enabled. I tried adding option –enable-mpi, but with no success. On remote cluster starpu-mpi is installed correctly. I think the problem is that the configure does not detect mpi. So what are the real requirements, what needs to be set so that mpi is detected and starpu-mpi installed? Or how should I install mpi? I got it using apt-get. I am using the starpu-1.3.3 version, downloaded as .tar.gz package. I would appreciate help with this. Thanks in advance, Jakub Homola
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux |
- [Starpu-devel] StarPU mpi support installation, Jakub Homola, 19/11/2019
- Re: [Starpu-devel] StarPU mpi support installation, Nathalie Furmento, 19/11/2019
