Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] infinite loop if HOME not defined
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] infinite loop if HOME not defined
  • Date: Thu, 19 Dec 2019 16:59:06 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
For info. there is a bug with an inifinite loop when HOME env. var. does not exist.
(gdb) bt full -10
#18705 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at common/utils.c:104
        olderrno = <optimized out>
        q = 0x19523f0 "//"
        sb = {st_dev = 140609003417672, st_ino = 140609010455696, st_nlink = 0, st_mode = 371167319, st_uid = 32738, st_gid = 10, __pad0 = 0, st_rdev = 140609003417672, st_size = 1,
          st_blksize = 0, st_blocks = 1, st_atim = {tv_sec = 140609010455696, tv_nsec = 140609009026322}, st_mtim = {tv_sec = 4294967320, tv_nsec = 140730273139136}, st_ctim = {
            tv_sec = 140730273139152, tv_nsec = 140609010456560}, __glibc_reserved = {0, 0, 0}}
#18706 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at common/utils.c:104
        q = 0x1952390 "//"
        sb = {st_dev = 0, st_ino = 140609010455696, st_nlink = 0, st_mode = 371167319, st_uid = 32738, st_gid = 1, __pad0 = 0, st_rdev = 0, st_size = 1, st_blksize = 0, st_blocks = 1,
          st_atim = {tv_sec = 140609010455696, tv_nsec = 140609009026300}, st_mtim = {tv_sec = 5669686216, tv_nsec = 140730273139584}, st_ctim = {tv_sec = 140730273139600,
            tv_nsec = 8102645832369450799}, __glibc_reserved = {7596570286555869045, 7022008425444958580, 13343047818178669}}
#18707 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at common/utils.c:104
        q = 0x1952330 "//"
        sb = {st_dev = 140730273139936, st_ino = 140609010633840, st_nlink = 2, st_mode = 14, st_uid = 2147483648, st_gid = 0, __pad0 = 0, st_rdev = 0, st_size = 0, st_blksize = 0,
          st_blocks = 0, st_atim = {tv_sec = 0, tv_nsec = 0}, st_mtim = {tv_sec = 140609010522259, tv_nsec = 1}, st_ctim = {tv_sec = 0, tv_nsec = 2676586395008836901}, __glibc_reserved = {
            2676586395008836901, -72057594037927936, 16777215}}
#18708 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at common/utils.c:104
        q = 0x19522d0 "//.starpu"
        sb = {st_dev = 140609006828192, st_ino = 140609006829552, st_nlink = 2, st_mode = 14, st_uid = 2147483648, st_gid = 0, __pad0 = 0, st_rdev = 0, st_size = 0, st_blksize = 0,
          st_blocks = 0, st_atim = {tv_sec = 0, tv_nsec = 0}, st_mtim = {tv_sec = 0, tv_nsec = 0}, st_ctim = {tv_sec = 0, tv_nsec = 0}, __glibc_reserved = {0, 0, 0}}
#18709 0x00007fe2160b1691 in _starpu_mkpath_and_check (path=0x1951e70 "//.starpu/sampling/", mode=mode@entry=448) at common/utils.c:141
        ret = <optimized out>
        __func__ = "_starpu_mkpath_and_check"
#18710 0x00007fe2160e8a4c in _starpu_create_sampling_directory_if_needed () at core/perfmodel/perfmodel.c:542
No locals.
#18711 0x00007fe2160e6396 in _starpu_load_bus_performance_files () at core/perfmodel/perfmodel_bus.c:2950
        config = <optimized out>
#18712 0x00007fe2160c378e in starpu_initialize (user_conf=user_conf@entry=0x0, argv=<optimized out>, argc=<optimized out>) at core/workers.c:1355
        is_a_sink = <optimized out>
        worker = <optimized out>
        main_thread_cpuid = <optimized out>
        main_thread_bind = <optimized out>
        main_thread_activity = <optimized out>
        p_ret = <optimized out>
        __ptrs = <optimized out>
        __n = <optimized out>
#18713 0x00007fe2160c4459 in starpu_initialize (user_conf=0x0, argc=<optimized out>, argv=<optimized out>) at core/workers.c:1194
Best,
Florent
Inria Bordeaux Sud-Ouest
Ingénieur Service d'Expérimentation et de Développement (SED)
Bureau B228
Tél. Bureau : 05 24 57 40 70
Courriel : florent.pruvost@inria.fr
Haut de le page
