Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Implementation question regarding output type
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Johan Mazel <johan.mazel@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Implementation question regarding output type
  • Date: Fri, 20 Dec 2019 18:34:58 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=johan.mazel@gmail.com; spf=Pass smtp.mailfrom=johan.mazel@gmail.com; spf=None smtp.helo=postmaster@mail-wm1-f42.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Is there any example or code snippet that uses STARPU_MATRIX_SET_NX(), STARPU_MATRIX_SET_NY(), and STARPU_MATRIX_SET_LD()?
Thank you very much for your time.
Best regards,
Johan
Le ven. 20 déc. 2019 à 18:00, Samuel Thibault <samuel.thibault@inria.fr> a écrit :
Johan Mazel, le ven. 20 déc. 2019 17:46:42 +0100, a ecrit:
> Is this new section called "7.1.7 Data Interface with Variable Size" in the 3rd
> chapter in [1]http://starpu.gforge.inria.fr/doc/starpu.pdf?
Uh, I didn't realize that it was already documented...
You can follow that, yes.
Samuel
Haut de le page
