Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] BUG: Gantt Diagram generation
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Cc: luka.stanisic@mpcdf.mpg.de
  • Subject: [Starpu-devel] BUG: Gantt Diagram generation
  • Date: Wed, 26 Feb 2020 10:42:27 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=carlos.lopez@mpcdf.mpg.de; spf=Pass smtp.mailfrom=carlos.lopez@mpcdf.mpg.de; spf=None smtp.helo=postmaster@b1962.mx.srv.dfn.de
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear StarPU development team,
I have a toy program where computations are split into tasks using StarPU.
There is a bug with the generation of Gantt diagrams using the version 1.3.3 but not with the version 1.2.9.
Please find attached trace files.
Luka Stanisic (in CC) fixed this problem by adding the following lines after line 397 in the trace file:
7 1.747309000 t27380 UT UserThread27368 w0
7 1.747309000 t27381 UT UserThread27368 w1
7 1.747309000 t27382 UT UserThread27368 w2
7 1.747309000 t27383 UT UserThread27368 w3
7 1.747309000 t27384 UT UserThread27368 w4
7 1.747309000 t27385 UT UserThread27368 w5
If you need more information, do not hesitate to contact me.
Best Regards,
Carlos Lopez
%EventDef PajeDefineContainerType 1
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineEventType 2
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineStateType 3
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineVariableType 4
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineLinkType 5
% Alias string
% Type string
% StartContainerType string
% EndContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEntityValue 6
% Alias string
% Type string
% Name string
% Color color
%EndEventDef
%EventDef PajeCreateContainer 7
% Time date
% Alias string
% Type string
% Container string
% Name string
%EndEventDef
%EventDef PajeDestroyContainer 8
% Time date
% Name string
% Type string
%EndEventDef
%EventDef PajeNewEvent 9
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajeSetState 10
% Time date
% Container string
% Type string
% Value string
%EndEventDef
%EventDef PajePushState 11
% Time date
% Container string
% Type string
% Value string
%EndEventDef
%EventDef PajePopState 12
% Time date
% Container string
% Type string
%EndEventDef
%EventDef PajeSetVariable 13
% Time date
% Container string
% Type string
% Value double
%EndEventDef
%EventDef PajeAddVariable 14
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeSubVariable 15
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeStartLink 18
% Time date
% Type string
% Container string
% Value string
% StartContainer string
% Key string
%EndEventDef
%EventDef PajeEndLink 19
% Time date
% Type string
% Container string
% Value string
% EndContainer string
% Key string
%EndEventDef
%EventDef PajeSetState 20
% Time date
% Container string
% Type string
% Value string
%EndEventDef
1 MPIP 0 "MPI Program"
1 P MPIP "Program"
1 Mn P "Memory Node"
1 T Mn "Thread"
1 UT P "User Thread"
1 Mm Mn "Memory Manager"
1 W T "Worker"
1 MPICt P "MPI Communication Thread"
1 Sc P "Scheduler State"
2 prog_event P "program event type"
2 register P "data registration"
2 unregister P "data unregistration"
2 user_event P "user event type"
2 thread_event T "thread event type"
2 user_user_event UT "user event type"
2 user_thread_event UT "thread event type"
2 MPIev MPICt "MPI event type"
3 S T "Thread State"
3 CtS MPICt "Communication Thread State"
3 Ctx1 T "InCtx1"
3 Ctx2 T "InCtx2"
3 Ctx3 T "InCtx3"
3 Ctx4 T "InCtx4"
3 Ctx5 T "InCtx5"
3 Ctx6 T "InCtx6"
3 Ctx7 T "InCtx7"
3 Ctx8 T "InCtx8"
3 Ctx9 T "InCtx9"
2 invalidate Mm "data invalidation"
3 MS Mm "Memory Node State"
4 nsubmitted Sc "Number of Submitted Uncompleted Tasks"
4 nready Sc "Number of Ready Tasks"
4 gft Sc "Total GFlops"
4 use Mm "Used (MB)"
4 bwi Mm "Bandwidth In (MB/s)"
4 bwo Mm "Bandwidth Out (MB/s)"
4 gf W "GFlops"
6 I S Idle ".9 .1 .0"
6 In S Initializing "0.0 .7 1.0"
6 D S Deinitializing "0.0 .1 .7"
6 Fi S FetchingInput "1.0 .1 1.0"
6 Po S PushingOutput "0.1 1.0 1.0"
6 C S Callback ".0 .3 .8"
6 B S Overhead ".5 .18 .0"
6 E S Executing ".0 .6 .5"
6 Sc S Scheduling ".7 .36 .0"
6 Sl S Sleeping ".9 .1 .0"
6 P S Progressing ".1 .3 .1"
6 U S Unpartitioning ".0 .0 1.0"
6 H S Hypervisor ".5 .18 .0"
6 Bu S "Building task" ".5 .18 .0"
6 Su S "Submittings task" ".3 .09 .0"
6 Th S "Throttling task submission" ".8 .6 .6"
6 MD S "Decoding task for MPI" ".5 .18 .2"
6 MPr S "Preparing task for MPI" ".4 .14 .2"
6 MPo S "Post-processing task for MPI" ".3 .09 .2"
3 WS W "Worker State"
6 I WS Idle ".9 .1 .0"
6 In WS Initializing "0.0 .7 1.0"
6 D WS Deinitializing "0.0 .1 .7"
6 Fi WS FetchingInput "1.0 .1 1.0"
6 Po WS PushingOutput "0.1 1.0 1.0"
6 C WS Callback ".0 .3 .8"
6 B WS Overhead ".5 .18 .0"
6 E WS Executing ".0 .6 .5"
6 Sc WS Scheduling ".7 .36 .0"
6 Sl WS Sleeping ".9 .1 .0"
6 P WS Progressing ".1 .3 .1"
6 U WS Unpartitioning ".0 .0 1.0"
6 H WS Hypervisor ".5 .18 .0"
6 Bu WS "Building task" ".5 .18 .0"
6 Su WS "Submitting task" ".3 .09 .0"
6 Th WS "Throttling task submission" ".8 .6 .6"
3 US UT "User Thread State"
6 Bu US "Building task" ".5 .18 .0"
6 Su US "Submittings task" ".3 .09 .0"
6 C US "Callback" ".0 .3 .8"
6 Th US "Throttling task submission" ".8 .6 .6"
6 MD US "Decoding task for MPI" ".5 .18 .2"
6 MPr US "Preparing task for MPI" ".4 .14 .2"
6 MPo US "Post-processing task for MPI" ".3 .09 .2"
6 W US "Waiting task" ".9 .1 .0"
6 WA US "Waiting all tasks" ".9 .1 .0"
6 No US Nothing ".0 .0 .0"
6 P CtS Processing "0 0 0"
6 Sl CtS Sleeping ".9 .1 .0"
6 UT CtS UserTesting ".2 .1 .6"
6 UW CtS UserWaiting ".4 .1 .3"
6 SdS CtS SendSubmitted "1.0 .1 1.0"
6 RvS CtS RecieveSubmitted "0.1 1.0 1.0"
6 SdC CtS SendCompleted "1.0 .5 1.0"
6 RvC CtS ReceiveCompleted "0.5 1.0 1.0"
6 TD CtS "Testing Detached" ".0 .0 .6"
6 MT CtS "MPI Test" ".0 .0 .8"
6 Bu CtS "Building task" ".5 .18 .0"
6 Su CtS "Submittings task" ".3 .09 .0"
6 Th CtS "Throttling task submission" ".8 .6 .6"
6 C CtS "Callback" ".0 .3 .8"
6 I Ctx1 Idle ".9 .1 .0"
6 In Ctx1 Initializing "0.0 .7 1.0"
6 D Ctx1 Deinitializing "0.0 .1 .7"
6 Fi Ctx1 FetchingInput "1.0 .1 1.0"
6 Po Ctx1 PushingOutput "0.1 1.0 1.0"
6 C Ctx1 Callback ".0 .3 .8"
6 B Ctx1 Overhead ".5 .18 .0"
6 E Ctx1 Executing ".0 .6 .5"
6 Sc Ctx1 Scheduling ".7 .36 .0"
6 Sl Ctx1 Sleeping ".9 .1 .0"
6 P Ctx1 Progressing ".1 .3 .1"
6 U Ctx1 Unpartitioning ".0 .0 1.0"
6 I Ctx2 Idle ".9 .1 .0"
6 In Ctx2 Initializing "0.0 .7 1.0"
6 D Ctx2 Deinitializing "0.0 .1 .7"
6 Fi Ctx2 FetchingInput "1.0 .1 1.0"
6 Po Ctx2 PushingOutput "0.1 1.0 1.0"
6 C Ctx2 Callback ".0 .3 .8"
6 B Ctx2 Overhead ".5 .18 .0"
6 E Ctx2 Executing ".0 .6 .5"
6 Sc Ctx2 Scheduling ".7 .36 .0"
6 Sl Ctx2 Sleeping ".9 .1 .0"
6 P Ctx2 Progressing ".1 .3 .1"
6 U Ctx2 Unpartitioning ".0 .0 1.0"
6 I Ctx3 Idle ".9 .1 .0"
6 In Ctx3 Initializing "0.0 .7 1.0"
6 D Ctx3 Deinitializing "0.0 .1 .7"
6 Fi Ctx3 FetchingInput "1.0 .1 1.0"
6 Po Ctx3 PushingOutput "0.1 1.0 1.0"
6 C Ctx3 Callback ".0 .3 .8"
6 B Ctx3 Overhead ".5 .18 .0"
6 E Ctx3 Executing ".0 .6 .5"
6 Sc Ctx3 Scheduling ".7 .36 .0"
6 Sl Ctx3 Sleeping ".9 .1 .0"
6 P Ctx3 Progressing ".1 .3 .1"
6 U Ctx3 Unpartitioning ".0 .0 1.0"
6 I Ctx4 Idle ".9 .1 .0"
6 In Ctx4 Initializing "0.0 .7 1.0"
6 D Ctx4 Deinitializing "0.0 .1 .7"
6 Fi Ctx4 FetchingInput "1.0 .1 1.0"
6 Po Ctx4 PushingOutput "0.1 1.0 1.0"
6 C Ctx4 Callback ".0 .3 .8"
6 B Ctx4 Overhead ".5 .18 .0"
6 E Ctx4 Executing ".0 .6 .5"
6 Sc Ctx4 Scheduling ".7 .36 .0"
6 Sl Ctx4 Sleeping ".9 .1 .0"
6 P Ctx4 Progressing ".1 .3 .1"
6 U Ctx4 Unpartitioning ".0 .0 1.0"
6 I Ctx5 Idle ".9 .1 .0"
6 In Ctx5 Initializing "0.0 .7 1.0"
6 D Ctx5 Deinitializing "0.0 .1 .7"
6 Fi Ctx5 FetchingInput "1.0 .1 1.0"
6 Po Ctx5 PushingOutput "0.1 1.0 1.0"
6 C Ctx5 Callback ".0 .3 .8"
6 B Ctx5 Overhead ".5 .18 .0"
6 E Ctx5 Executing ".0 .6 .5"
6 Sc Ctx5 Scheduling ".7 .36 .0"
6 Sl Ctx5 Sleeping ".9 .1 .0"
6 P Ctx5 Progressing ".1 .3 .1"
6 U Ctx5 Unpartitioning ".0 .0 1.0"
6 I Ctx6 Idle ".9 .1 .0"
6 In Ctx6 Initializing "0.0 .7 1.0"
6 D Ctx6 Deinitializing "0.0 .1 .7"
6 Fi Ctx6 FetchingInput "1.0 .1 1.0"
6 Po Ctx6 PushingOutput "0.1 1.0 1.0"
6 C Ctx6 Callback ".0 .3 .8"
6 B Ctx6 Overhead ".5 .18 .0"
6 E Ctx6 Executing ".0 .6 .5"
6 Sc Ctx6 Scheduling ".7 .36 .0"
6 Sl Ctx6 Sleeping ".9 .1 .0"
6 P Ctx6 Progressing ".1 .3 .1"
6 U Ctx6 Unpartitioning ".0 .0 1.0"
6 I Ctx7 Idle ".9 .1 .0"
6 In Ctx7 Initializing "0.0 .7 1.0"
6 D Ctx7 Deinitializing "0.0 .1 .7"
6 Fi Ctx7 FetchingInput "1.0 .1 1.0"
6 Po Ctx7 PushingOutput "0.1 1.0 1.0"
6 C Ctx7 Callback ".0 .3 .8"
6 B Ctx7 Overhead ".5 .18 .0"
6 E Ctx7 Executing ".0 .6 .5"
6 Sc Ctx7 Scheduling ".7 .36 .0"
6 Sl Ctx7 Sleeping ".9 .1 .0"
6 P Ctx7 Progressing ".1 .3 .1"
6 U Ctx7 Unpartitioning ".0 .0 1.0"
6 I Ctx8 Idle ".9 .1 .0"
6 In Ctx8 Initializing "0.0 .7 1.0"
6 D Ctx8 Deinitializing "0.0 .1 .7"
6 Fi Ctx8 FetchingInput "1.0 .1 1.0"
6 Po Ctx8 PushingOutput "0.1 1.0 1.0"
6 C Ctx8 Callback ".0 .3 .8"
6 B Ctx8 Overhead ".5 .18 .0"
6 E Ctx8 Executing ".0 .6 .5"
6 Sc Ctx8 Scheduling ".7 .36 .0"
6 Sl Ctx8 Sleeping ".9 .1 .0"
6 P Ctx8 Progressing ".1 .3 .1"
6 U Ctx8 Unpartitioning ".0 .0 1.0"
6 I Ctx9 Idle ".9 .1 .0"
6 In Ctx9 Initializing "0.0 .7 1.0"
6 D Ctx9 Deinitializing "0.0 .1 .7"
6 Fi Ctx9 FetchingInput "1.0 .1 1.0"
6 Po Ctx9 PushingOutput "0.1 1.0 1.0"
6 C Ctx9 Callback ".0 .3 .8"
6 B Ctx9 Overhead ".5 .18 .0"
6 E Ctx9 Executing ".0 .6 .5"
6 Sc Ctx9 Scheduling ".7 .36 .0"
6 Sl Ctx9 Sleeping ".9 .1 .0"
6 P Ctx9 Progressing ".1 .3 .1"
6 U Ctx9 Unpartitioning ".0 .0 1.0"
6 A MS Allocating ".4 .1 .0"
6 Ar MS AllocatingReuse ".1 .1 .8"
6 F MS Freeing ".6 .3 .0"
6 W MS WritingBack ".0 .0 .5"
6 Wa MS WritingBackAsync ".0 .0 .4"
6 R MS Reclaiming ".0 .1 .6"
6 Co MS DriverCopy ".3 .5 .1"
6 CoA MS DriverCopyAsync ".1 .3 .1"
6 No MS Nothing ".0 .0 .0"
5 MPIL MPIP MPICt MPICt "MPI communication"
5 F P Mm Mm "Intra-node data Fetch"
5 PF P Mm Mm "Intra-node data PreFetch"
5 IF P Mm Mm "Intra-node data IdleFetch"
5 WSL P W W "Work steal"
7 0.0 MPIroot MPIP 0 root
7 0.0 p P MPIroot program
7 0.000000000 sched Sc p scheduler
13 0.0 sched nsubmitted 0.0
13 0.0 sched nready 0.0
13 0.0 sched gft 0.0
7 19.705859000 mn0 Mn p MEMNODE0
7 19.705859000 mm0 Mm mn0 MEMMANAGER0
13 0.000000000 mm0 use 0.0
13 0.000000000 mm0 bwi 0.0
13 0.000000000 mm0 bwo 0.0
7 19.851206000 t4821 T mn0 0
7 19.851206000 w0 W t4821 CPU0
13 0.000000000 w0 gf 0.0
7 19.949068000 t4822 T mn0 2
7 19.949068000 w1 W t4822 CPU1
13 0.000000000 w1 gf 0.0
7 20.067353000 t4823 T mn0 4
7 20.067353000 w2 W t4823 CPU2
13 0.000000000 w2 gf 0.0
7 20.146821000 t4824 T mn0 6
7 20.146821000 w3 W t4824 CPU3
13 0.000000000 w3 gf 0.0
7 20.230074000 t4825 T mn0 8
7 20.230074000 w4 W t4825 CPU4
13 0.000000000 w4 gf 0.0
7 20.301010000 t4826 T mn0 10
7 20.301010000 w5 W t4826 CPU5
13 0.000000000 w5 gf 0.0
9 20.367080000 register p 563c7aed79b0
9 20.368829000 register p 563c7aed7fa0
9 20.371297000 register p 563c7af3a2b0
9 20.372135000 register p 563c7af37820
9 20.372876000 register p 563c7af37380
9 20.373726000 register p 563c7af39df0
9 20.374483000 register p 563c7af37e70
9 20.375208000 register p 563c7af38880
9 20.376015000 register p 563c7aed4eb0
9 20.376827000 register p 563c7aed52f0
9 20.377565000 register p 563c7aecfd40
9 20.379512000 register p 563c7aed0180
9 20.380378000 register p 563c7af3a6e0
9 20.381130000 register p 563c7af3ab20
9 20.382080000 register p 563c7af3af60
9 20.383025000 register p 563c7af35d50
9 20.383688000 register p 563c7af361e0
9 20.384396000 register p 563c7af36670
9 20.385102000 register p 563c7af36b00
9 20.385963000 register p 563c7af32fe0
9 20.386665000 register p 563c7af33470
9 20.387439000 register p 563c7af33900
9 20.388129000 register p 563c7af33d90
9 20.388901000 register p 563c7af34220
9 20.389652000 register p 563c7af346b0
9 20.390501000 register p 563c7af30b10
9 20.391206000 register p 563c7af30f60
9 20.392037000 register p 563c7af313f0
9 20.392718000 register p 563c7af31880
9 20.393443000 register p 563c7af31d10
9 20.394134000 register p 563c7af321a0
9 20.394881000 register p 563c7af32630
9 20.395670000 register p 563c7af32ac0
9 20.396416000 register p 563c7aed1aa0
9 20.397116000 register p 563c7aed1f30
9 20.397848000 register p 563c7aed23c0
9 20.398527000 register p 563c7aed2850
9 20.399273000 register p 563c7aed2ce0
9 20.400340000 register p 563c7aed3170
9 20.401071000 register p 563c7aed3600
9 20.401823000 register p 563c7aed3a90
9 20.402683000 register p 563c7af3b2f0
9 20.403404000 register p 563c7af3b780
9 20.404264000 register p 563c7af3bc10
9 20.405041000 register p 563c7af3c0a0
9 20.405708000 register p 563c7af3c530
9 20.406423000 register p 563c7af3c9c0
9 20.407100000 register p 563c7af3ce50
9 20.407882000 register p 563c7af3d2e0
9 20.408575000 register p 563c7af3d770
9 20.409305000 register p 563c7af3dc00
9 20.410008000 register p 563c7af3e090
9 20.410751000 register p 563c7af3e520
9 20.411458000 register p 563c7af3e9b0
9 20.412194000 register p 563c7af3ee40
9 20.412902000 register p 563c7af3f2d0
9 20.413807000 register p 563c7af3f950
9 20.414475000 register p 563c7af3fde0
9 20.415223000 register p 563c7af40270
9 20.416017000 register p 563c7af40700
9 20.416763000 register p 563c7af40b90
9 20.417726000 register p 563c7af41020
9 20.418440000 register p 563c7af414b0
9 20.419156000 register p 563c7af41940
9 20.419883000 register p 563c7af41dd0
9 20.420631000 register p 563c7af42260
9 20.421428000 register p 563c7af426f0
9 20.422113000 register p 563c7af42b80
9 20.422844000 register p 563c7af43010
9 20.423756000 register p 563c7af434a0
9 20.424447000 register p 563c7af43930
9 20.425112000 register p 563c7af43dc0
9 20.425886000 register p 563c7af44250
9 20.426561000 register p 563c7af446e0
9 20.427325000 register p 563c7af44b70
9 20.428231000 register p 563c7af45000
9 20.428931000 register p 563c7af45490
9 20.429624000 register p 563c7af45920
9 20.430375000 register p 563c7af45db0
9 20.431063000 register p 563c7af46240
9 20.431819000 register p 563c7af466d0
9 20.432571000 register p 563c7af46b60
9 20.433317000 register p 563c7af46ff0
9 20.433994000 register p 563c7af47480
9 20.434720000 register p 563c7af47910
9 20.435406000 register p 563c7af47da0
9 20.436140000 register p 563c7af48230
9 20.436861000 register p 563c7af486c0
9 20.437567000 register p 563c7af48b50
9 20.438297000 register p 563c7af48fe0
9 20.439033000 register p 563c7af49470
9 20.439928000 register p 563c7af49900
9 20.440651000 register p 563c7af49d90
9 20.441394000 register p 563c7af4a220
9 20.442138000 register p 563c7af4a6b0
9 20.442916000 register p 563c7af4ab40
9 20.443621000 register p 563c7af4afd0
9 20.444386000 register p 563c7af4b460
9 20.445115000 register p 563c7af4b8f0
9 20.445924000 register p 563c7af4bd80
9 20.446598000 register p 563c7af4c210
9 20.447361000 register p 563c7af4c6a0
9 20.448055000 register p 563c7af4cb30
9 20.449110000 register p 563c7af4cfc0
9 20.449880000 register p 563c7af4d450
9 20.450648000 register p 563c7af4d8e0
9 20.451326000 register p 563c7af4dd70
9 20.452204000 register p 563c7af4e200
9 20.453067000 register p 563c7af4e690
9 20.453759000 register p 563c7af4eb20
9 20.454531000 register p 563c7af4efb0
9 20.455250000 register p 563c7af4f440
9 20.456035000 register p 563c7af4f8d0
9 20.456750000 register p 563c7af4fd60
9 20.457507000 register p 563c7af501f0
9 20.458227000 register p 563c7af50680
9 20.458995000 register p 563c7af50b10
9 20.459723000 register p 563c7af50fa0
9 20.460469000 register p 563c7af51430
9 20.461154000 register p 563c7af518c0
9 20.463544000 register p 563c7af51d50
9 20.464319000 register p 563c7af525f0
9 20.465118000 register p 563c7af52a80
9 20.465943000 register p 563c7af52f10
9 20.466667000 register p 563c7af533a0
9 20.467333000 register p 563c7af53830
9 20.468096000 register p 563c7af53cc0
9 20.468770000 register p 563c7af54150
9 20.469522000 register p 563c7af545e0
9 20.470614000 register p 563c7af54a70
9 20.471326000 register p 563c7af54f00
9 20.472114000 register p 563c7af55390
9 20.472790000 register p 563c7af55820
9 20.476121000 register p 563c7af55e00
9 20.477085000 register p 563c7af56140
9 20.478076000 register p 563c7af56480
9 20.478999000 register p 563c7af567c0
9 20.479886000 register p 563c7af56b00
9 20.481794000 register p 563c7af56e40
9 20.482828000 register p 563c7af57180
9 20.483674000 register p 563c7af574c0
9 20.484565000 register p 563c7af57800
9 20.485381000 register p 563c7af57b40
9 20.487517000 register p 563c7af57e80
9 20.488333000 register p 563c7af581c0
9 20.489178000 register p 563c7af58500
9 20.489927000 register p 563c7af58840
9 20.490746000 register p 563c7af58b80
9 20.492692000 register p 563c7af58ec0
9 20.493641000 register p 563c7af59200
9 20.494345000 register p 563c7af59540
9 20.495236000 register p 563c7af59880
9 20.495998000 register p 563c7af59bc0
9 20.497965000 register p 563c7af59f00
9 20.498734000 register p 563c7af5a240
9 20.499661000 register p 563c7af5a580
9 20.500352000 register p 563c7af5a8c0
9 20.501301000 register p 563c7af5ac00
9 20.503811000 register p 563c7af5af40
9 20.504743000 register p 563c7af5b280
9 20.505661000 register p 563c7af5b650
9 20.506366000 register p 563c7af5bae0
9 20.508230000 register p 563c7af5bf70
9 20.509063000 register p 563c7af5c400
9 20.509774000 register p 563c7af5c890
9 20.510640000 register p 563c7af5cd20
9 20.511625000 register p 563c7af5d1b0
9 20.512372000 register p 563c7af5d640
9 20.513119000 register p 563c7af5dad0
9 20.515937000 register p 563c7af5df60
9 20.516854000 register p 563c7af5e3f0
9 20.517745000 register p 563c7af5e880
9 20.519647000 register p 563c7af5ed10
9 20.520342000 register p 563c7af5f1a0
9 20.521103000 register p 563c7af5f630
9 20.521810000 register p 563c7af5fac0
9 20.523636000 register p 563c7af5ff50
9 20.524495000 register p 563c7af603e0
9 20.525201000 register p 563c7af60870
9 20.527075000 register p 563c7af60d00
9 20.527899000 register p 563c7af61190
9 20.528691000 register p 563c7af61620
9 20.529459000 register p 563c7af61ab0
9 20.531311000 register p 563c7af61f40
9 20.532102000 register p 563c7af623d0
9 20.532783000 register p 563c7af62860
9 20.534536000 register p 563c7af62cf0
9 20.535568000 register p 563c7af63180
9 20.536267000 register p 563c7af63610
9 20.537041000 register p 563c7af63aa0
9 20.538838000 register p 563c7af63f30
9 20.539525000 register p 563c7af643c0
9 20.540262000 register p 563c7af64850
9 20.540962000 register p 563c7af64ce0
9 20.541805000 register p 563c7af65170
9 20.542538000 register p 563c7af65600
9 20.543280000 register p 563c7af65a90
9 20.545045000 register p 563c7af65f20
9 20.545792000 register p 563c7af663b0
9 20.546485000 register p 563c7af66840
9 20.548280000 register p 563c7af66cd0
9 20.549047000 register p 563c7af67160
9 20.549734000 register p 563c7af675f0
9 20.550811000 register p 563c7af67a80
9 20.552619000 register p 563c7af67f10
9 20.553338000 register p 563c7af683a0
9 20.554116000 register p 563c7af68830
9 20.555911000 register p 563c7af68cc0
9 20.556766000 register p 563c7af69150
9 20.557494000 register p 563c7af695e0
9 20.558262000 register p 563c7af69a70
9 20.560120000 register p 563c7af69f00
9 20.560792000 register p 563c7af6a390
9 20.561558000 register p 563c7af6a820
9 20.563439000 register p 563c7af6acb0
9 20.564461000 register p 563c7af6b140
9 20.565216000 register p 563c7af6b5d0
9 20.566039000 register p 563c7af6ba60
9 20.567897000 register p 563c7af6bef0
9 20.568785000 register p 563c7af6c380
9 20.569565000 register p 563c7af6c810
9 20.570307000 register p 563c7af6cca0
9 20.571109000 register p 563c7af6d130
9 20.571823000 register p 563c7af6d5c0
9 20.572563000 register p 563c7af6da50
9 20.575233000 register p 563c7af6dee0
9 20.575927000 register p 563c7af6e370
9 20.576691000 register p 563c7af6e800
9 20.578500000 register p 563c7af6ec90
9 20.579258000 register p 563c7af6f120
9 20.580063000 register p 563c7af6f5b0
9 20.580812000 register p 563c7af6fa40
9 20.582753000 register p 563c7af6fed0
9 20.583541000 register p 563c7af70360
9 20.584267000 register p 563c7af707f0
9 20.586219000 register p 563c7af70c80
9 20.587014000 register p 563c7af71110
9 20.587908000 register p 563c7af715a0
9 20.588593000 register p 563c7af71a30
9 20.590351000 register p 563c7af71ec0
9 20.591166000 register p 563c7af72350
9 20.591866000 register p 563c7af727e0
9 20.593829000 register p 563c7af72c70
9 20.594604000 register p 563c7af73100
9 20.595351000 register p 563c7af73590
9 20.596053000 register p 563c7af73a20
9 20.597796000 register p 563c7af73eb0
9 20.598566000 register p 563c7af74340
9 20.599293000 register p 563c7af747d0
9 20.601181000 register p 563c7af74c60
9 20.601987000 register p 563c7af750f0
9 20.602761000 register p 563c7af75580
9 20.603578000 register p 563c7af75a10
9 20.607626000 register p 563c7af75ea0
9 20.608451000 register p 563c7af76330
9 20.609158000 register p 563c7af767c0
9 20.610954000 register p 563c7af76c50
9 20.611750000 register p 563c7af770e0
9 20.612454000 register p 563c7af77570
9 20.613231000 register p 563c7af77a00
9 20.615080000 register p 563c7af77e90
9 20.615892000 register p 563c7af78320
9 20.616602000 register p 563c7af787b0
9 20.618507000 register p 563c7af78c40
9 20.619276000 register p 563c7af790d0
9 20.620027000 register p 563c7af79560
9 20.621134000 register p 563c7af799f0
9 20.623955000 register p 563c7af79f20
9 20.624784000 register p 563c7af7a3b0
9 20.625667000 register p 563c7af7a840
9 20.627565000 register p 563c7af7acd0
9 20.628364000 register p 563c7af7b160
9 20.629055000 register p 563c7af7b5f0
9 20.629872000 register p 563c7af7ba80
9 20.632353000 register p 563c7af7bf10
9 20.633281000 register p 563c7af7c3a0
9 20.634098000 register p 563c7af7c830
9 20.636699000 register p 563c7af7ccc0
9 20.637456000 register p 563c7af7d150
9 20.638244000 register p 563c7af7d5e0
9 20.639029000 register p 563c7af7da70
9 20.640925000 register p 563c7af7df00
9 20.641590000 register p 563c7af7e390
9 20.642957000 register p 563c7af7e820
9 20.645089000 register p 563c7af7ed00
9 20.645890000 register p 563c7af7f190
9 20.646543000 register p 563c7af7f5d0
9 20.647379000 register p 563c7af7fa60
9 20.649313000 register p 563c7af7fef0
9 20.650184000 register p 563c7af80380
9 20.650847000 register p 563c7af80810
9 20.652809000 register p 563c7af80ca0
9 20.653532000 register p 563c7af81130
9 20.656150000 register p 563c7af81dd0
9 20.656933000 register p 563c7af82260
9 20.657713000 register p 563c7af826a0
9 20.658407000 register p 563c7af82b30
9 20.660220000 register p 563c7af82fc0
9 20.661046000 register p 563c7af83450
9 20.661796000 register p 563c7af838e0
9 20.663600000 register p 563c7af83d70
9 20.680040000 register p 563c7af84200
9 20.680762000 register p 563c7af84690
9 20.681755000 register p 563c7af84b20
9 20.683514000 register p 563c7af84fb0
9 20.684295000 register p 563c7af85440
9 20.684988000 register p 563c7af858d0
9 20.686745000 register p 563c7af85d60
9 20.687477000 register p 563c7af861f0
9 20.688361000 register p 563c7af86680
9 20.689078000 register p 563c7af86b10
9 20.690796000 register p 563c7af86fa0
9 20.691569000 register p 563c7af87430
9 20.692239000 register p 563c7af878c0
9 20.693953000 register p 563c7af87d50
9 20.694752000 register p 563c7af881e0
9 20.695443000 register p 563c7af88670
9 20.696149000 register p 563c7af88b00
9 20.697902000 register p 563c7af88f90
9 20.698701000 register p 563c7af89420
9 20.699420000 register p 563c7af898b0
9 20.701827000 register p 563c7af89d40
9 20.702557000 register p 563c7af8a1d0
9 20.703318000 register p 563c7af8a660
9 20.704050000 register p 563c7af8aaf0
9 20.706178000 register p 563c7af8af80
9 20.707017000 register p 563c7af8b410
9 20.707829000 register p 563c7af8b8a0
9 20.709597000 register p 563c7af8bd30
9 20.710262000 register p 563c7af8c1c0
9 20.711004000 register p 563c7af8c650
9 20.711713000 register p 563c7af8cae0
9 20.713518000 register p 563c7af8cf70
9 20.714205000 register p 563c7af8d400
9 20.714933000 register p 563c7af8d890
9 20.716696000 register p 563c7af8dd20
9 20.717390000 register p 563c7af8e1b0
9 20.718139000 register p 563c7af8e640
9 20.718893000 register p 563c7af8ead0
9 20.720718000 register p 563c7af8ef60
9 20.721468000 register p 563c7af8f3f0
9 20.722323000 register p 563c7af8f880
9 20.724182000 register p 563c7af8fd10
9 20.724871000 register p 563c7af901a0
9 20.725645000 register p 563c7af90630
9 20.726332000 register p 563c7af90ac0
9 20.728052000 register p 563c7af90f50
9 20.728747000 register p 563c7af913e0
9 20.729468000 register p 563c7af91870
9 20.731608000 register p 563c7af91d00
9 20.732281000 register p 563c7af92190
9 20.733115000 register p 563c7af92620
9 20.733921000 register p 563c7af92ab0
9 20.735656000 register p 563c7af92f40
9 20.736405000 register p 563c7af933d0
9 20.737179000 register p 563c7af93860
9 20.739007000 register p 563c7af93cf0
9 20.739870000 register p 563c7af94180
9 20.740614000 register p 563c7af94610
9 20.741402000 register p 563c7af94aa0
9 20.743098000 register p 563c7af94f30
9 20.743806000 register p 563c7af953c0
9 20.744545000 register p 563c7af95850
9 20.746343000 register p 563c7af95ce0
9 20.747060000 register p 563c7af96170
9 20.747789000 register p 563c7af96600
9 20.748515000 register p 563c7af96a90
9 20.751398000 register p 563c7af96f20
9 20.757976000 register p 563c7af973b0
9 20.758719000 register p 563c7af98050
9 20.759490000 register p 563c7af984e0
9 20.760149000 register p 563c7af98970
9 20.761976000 register p 563c7af98e00
9 20.762806000 register p 563c7af99290
9 20.763556000 register p 563c7af99720
9 20.765271000 register p 563c7af99bb0
9 20.765988000 register p 563c7af9a040
9 20.766795000 register p 563c7af9a4d0
9 20.767468000 register p 563c7af9a960
9 20.769140000 register p 563c7af9adf0
9 20.769930000 register p 563c7af9b280
9 20.770586000 register p 563c7af9b710
9 20.772866000 register p 563c7af9bba0
9 20.773571000 register p 563c7af9c030
9 20.774331000 register p 563c7af9c4c0
9 20.775057000 register p 563c7af9c950
9 20.776886000 register p 563c7af9cde0
9 20.777560000 register p 563c7af9d270
9 20.778324000 register p 563c7af9d700
9 20.780123000 register p 563c7af9db90
9 20.780838000 register p 563c7af9e020
9 20.781683000 register p 563c7af9e4b0
9 20.782353000 register p 563c7af9e940
9 20.784026000 register p 563c7af9edd0
9 20.784770000 register p 563c7af9f260
9 20.785467000 register p 563c7af9f6f0
9 20.787297000 register p 563c7af9fb80
9 20.788012000 register p 563c7afa0010
9 20.788746000 register p 563c7afa04a0
9 20.789420000 register p 563c7afa0930
9 20.791102000 register p 563c7afa0dc0
9 20.791874000 register p 563c7afa1250
9 20.792612000 register p 563c7afa16e0
9 20.793384000 register p 563c7afa1b70
9 20.795138000 register p 563c7afa2000
9 20.795948000 register p 563c7afa2490
9 20.796616000 register p 563c7afa2920
9 20.798334000 register p 563c7afa2db0
9 20.799055000 register p 563c7afa3240
9 20.799727000 register p 563c7afa36d0
9 20.800518000 register p 563c7afa3b60
9 20.802295000 register p 563c7afa3ff0
9 20.802987000 register p 563c7afa4480
9 20.803727000 register p 563c7afa4910
9 20.805498000 register p 563c7afa4da0
9 20.806202000 register p 563c7afa5230
9 20.806984000 register p 563c7afa56c0
9 20.807637000 register p 563c7afa5b50
9 20.809942000 register p 563c7afa5fe0
9 20.810637000 register p 563c7afa6470
9 20.811350000 register p 563c7afa6900
9 20.813150000 register p 563c7afa6d90
9 20.813897000 register p 563c7afa7220
9 20.814553000 register p 563c7afa76b0
9 20.815313000 register p 563c7afa7b40
9 20.817182000 register p 563c7afa7fd0
9 20.817936000 register p 563c7afa8460
9 20.818710000 register p 563c7afa88f0
9 20.820468000 register p 563c7afa8d80
9 20.821162000 register p 563c7afa9210
9 20.821870000 register p 563c7afa96a0
9 20.822575000 register p 563c7afa9b30
9 20.824390000 register p 563c7afa9fc0
9 20.825108000 register p 563c7afaa450
9 20.825871000 register p 563c7afaa8e0
9 20.827634000 register p 563c7afaad70
9 20.828329000 register p 563c7afab200
9 20.829130000 register p 563c7afab690
9 20.829804000 register p 563c7afabb20
9 20.831555000 register p 563c7afabfb0
9 20.832252000 register p 563c7afac440
9 20.833012000 register p 563c7afac8d0
9 20.834824000 register p 563c7afacd60
9 20.835550000 register p 563c7afad1f0
9 20.836288000 register p 563c7afad680
9 20.836983000 register p 563c7afadb10
9 20.839031000 register p 563c7afadfa0
9 20.839930000 register p 563c7afae430
9 20.840681000 register p 563c7afae8c0
9 20.842447000 register p 563c7afaed50
9 20.843137000 register p 563c7afaf1e0
9 20.843856000 register p 563c7afaf670
9 20.844599000 register p 563c7afafb00
9 20.846540000 register p 563c7afaff90
9 20.847235000 register p 563c7afb0420
9 20.847979000 register p 563c7afb08b0
9 20.849757000 register p 563c7afb0d40
9 20.850469000 register p 563c7afb11d0
9 20.851215000 register p 563c7afb1660
9 20.851905000 register p 563c7afb1af0
9 20.853630000 register p 563c7afb1f80
9 20.854389000 register p 563c7afb2410
9 20.855142000 register p 563c7afb28a0
9 20.856944000 register p 563c7afb2d30
9 20.857636000 register p 563c7afb31c0
9 20.858392000 register p 563c7afb3650
9 20.859123000 register p 563c7afb3ae0
9 20.861492000 register p 563c7afb3f70
9 20.862182000 register p 563c7afb4400
9 20.863034000 register p 563c7afb4890
9 20.864754000 register p 563c7afb4d20
9 20.865498000 register p 563c7afb51b0
9 20.866199000 register p 563c7afb5640
9 20.867004000 register p 563c7afb5ad0
9 20.868764000 register p 563c7afb5f60
9 20.869449000 register p 563c7afb63f0
9 20.870179000 register p 563c7afb6880
9 20.872304000 register p 563c7afb6d10
9 20.873061000 register p 563c7afb71a0
9 20.873744000 register p 563c7afb7630
9 20.874518000 register p 563c7afb7ac0
9 20.877239000 register p 563c7afb7f50
9 20.878025000 register p 563c7afb83e0
9 20.879085000 register p 563c7afb8870
9 20.880939000 register p 563c7afb8d00
9 20.881685000 register p 563c7afb9190
9 20.882464000 register p 563c7afb9620
9 20.883156000 register p 563c7afb9ab0
9 20.884904000 register p 563c7afb9f40
9 20.885632000 register p 563c7afba3d0
9 20.886388000 register p 563c7afba860
9 20.888998000 register p 563c7afbacf0
9 20.889771000 register p 563c7afbb180
9 20.890436000 register p 563c7afbb610
9 20.891187000 register p 563c7afbbaa0
9 20.892916000 register p 563c7afbbf30
9 20.893618000 register p 563c7afbc3c0
9 20.894306000 register p 563c7afbc850
9 20.896036000 register p 563c7afbcce0
9 20.896804000 register p 563c7afbd170
9 20.897496000 register p 563c7afbd600
9 20.898264000 register p 563c7afbda90
9 20.900092000 register p 563c7afbdf20
9 20.900851000 register p 563c7afbe3b0
9 20.901572000 register p 563c7afbe840
9 20.903704000 register p 563c7afbecd0
9 20.904558000 register p 563c7afbf160
9 20.905271000 register p 563c7afbf5f0
9 20.905982000 register p 563c7afbfa80
9 20.907706000 register p 563c7afbff10
9 20.908495000 register p 563c7afc03a0
9 20.909183000 register p 563c7afc0830
9 20.910919000 register p 563c7afc0cc0
9 20.911673000 register p 563c7afc1150
9 20.912357000 register p 563c7afc15e0
9 20.913119000 register p 563c7afc1a70
9 20.915475000 register p 563c7afc1f00
9 20.916410000 register p 563c7afc2390
9 20.917099000 register p 563c7afc2820
9 20.918962000 register p 563c7afc2cb0
9 20.919642000 register p 563c7afc3140
9 20.920401000 register p 563c7afc35d0
9 20.921082000 register p 563c7afc3a60
9 20.922740000 register p 563c7afc3ef0
9 20.923494000 register p 563c7afc4380
9 20.924186000 register p 563c7afc4810
9 20.925919000 register p 563c7afc4ca0
9 20.926701000 register p 563c7afc5130
9 20.927367000 register p 563c7afc55c0
9 20.928117000 register p 563c7afc5a50
9 20.929785000 register p 563c7afc5ee0
9 20.930489000 register p 563c7afc6370
9 20.931175000 register p 563c7afc6800
9 20.932983000 register p 563c7afc6c90
9 20.933790000 register p 563c7afc7120
9 20.934466000 register p 563c7afc75b0
9 20.935221000 register p 563c7afc7a40
9 20.937022000 register p 563c7afc7ed0
9 20.937725000 register p 563c7afc8360
9 20.938452000 register p 563c7afc87f0
9 20.940207000 register p 563c7afc8c80
9 20.940949000 register p 563c7afc9110
9 20.941658000 register p 563c7afc95a0
9 20.942328000 register p 563c7afc9a30
9 20.944128000 register p 563c7afc9ec0
9 20.944809000 register p 563c7afca350
9 20.945570000 register p 563c7afca7e0
9 20.947380000 register p 563c7afcac70
9 20.948044000 register p 563c7afcb100
9 21.333205000 register p 563c7b04e090
9 21.333974000 register p 563c7b04e4d0
9 21.334611000 register p 563c7b04e960
9 21.336394000 register p 563c7b04edf0
9 21.337133000 register p 563c7b04f280
9 21.338057000 register p 563c7b04f710
9 21.339807000 register p 563c7b04fba0
9 21.340497000 register p 563c7b050030
9 21.341239000 register p 563c7b0504c0
9 21.341893000 register p 563c7b050950
9 21.343727000 register p 563c7b050de0
9 21.344484000 register p 563c7b051270
9 21.345205000 register p 563c7b051700
9 21.346999000 register p 563c7b051b90
9 21.347743000 register p 563c7b052020
9 21.348456000 register p 563c7b0524b0
9 21.349127000 register p 563c7b052940
9 21.350846000 register p 563c7b052dd0
9 21.351571000 register p 563c7b053260
9 21.352284000 register p 563c7b0536f0
9 21.354018000 register p 563c7b053b80
9 21.354766000 register p 563c7b054010
9 21.355393000 register p 563c7b0544a0
9 21.356077000 register p 563c7b054930
9 21.362090000 prog_event p "start_profiling"
7 21.363923000 t4820 UT p UserThread4820
11 21.363923000 t4820 US Bu
12 21.367765000 t4820 US
11 21.372094000 t4820 US Su
13 21.374214000 sched nsubmitted 1.000000
13 21.384699000 sched nready 1.000000
12 21.392751000 t4820 US
13 21.393265000 sched nready 0.000000
13 21.393265000 sched nsubmitted 0.000000
11 21.393553000 t4820 US Bu
10 21.394450000 w1 WS "B"
12 21.394565000 t4820 US
10 21.395219000 w1 WS "B"
11 21.395369000 t4820 US Su
13 21.396033000 sched nsubmitted 1.000000
10 21.396243000 w1 WS "Fi"
10 21.398929000 w1 WS "B"
13 21.398978000 sched nready 1.000000
13 21.401130000 sched nready 0.000000
13 21.401130000 sched nsubmitted 0.000000
12 21.401190000 t4820 US
10 21.401707000 w0 WS "B"
11 21.401826000 t4820 US Bu
10 21.402198000 w0 WS "B"
12 21.402413000 t4820 US
10 21.402703000 w0 WS "Fi"
11 21.403176000 t4820 US Su
13 21.403723000 sched nsubmitted 1.000000
10 21.403890000 w0 WS "B"
6 send/recv:NW WS send/recv:NW "0.000000 0.600000 0.400000"
6 send/recv:NW_1 Ctx1 send/recv:NW "1.0 0.39 1.0"
6 send/recv:NW_2 Ctx2 send/recv:NW ".0 1.0 .0"
6 send/recv:NW_3 Ctx3 send/recv:NW "0.87 0.87 .0"
6 send/recv:NW_4 Ctx4 send/recv:NW ".0 0.95 1.0"
6 send/recv:NW_5 Ctx5 send/recv:NW ".0 .0 .0"
6 send/recv:NW_6 Ctx6 send/recv:NW ".0 .0 0.5"
6 send/recv:NW_7 Ctx7 send/recv:NW "0.41 0.41 0.41"
6 send/recv:NW_8 Ctx8 send/recv:NW "1.0 .0 1.0"
6 send/recv:NW_9 Ctx9 send/recv:NW ".0 .0 1.0"
10 21.404747000 w1 WS "send/recv:NW"
6 send/recv:NO WS send/recv:NO "0.000000 0.600000 0.400000"
6 send/recv:NO_1 Ctx1 send/recv:NO "1.0 0.39 1.0"
6 send/recv:NO_2 Ctx2 send/recv:NO ".0 1.0 .0"
6 send/recv:NO_3 Ctx3 send/recv:NO "0.87 0.87 .0"
6 send/recv:NO_4 Ctx4 send/recv:NO ".0 0.95 1.0"
6 send/recv:NO_5 Ctx5 send/recv:NO ".0 .0 .0"
6 send/recv:NO_6 Ctx6 send/recv:NO ".0 .0 0.5"
6 send/recv:NO_7 Ctx7 send/recv:NO "0.41 0.41 0.41"
6 send/recv:NO_8 Ctx8 send/recv:NO "1.0 .0 1.0"
6 send/recv:NO_9 Ctx9 send/recv:NO ".0 .0 1.0"
10 21.404926000 w0 WS "send/recv:NO"
13 21.405302000 sched nready 1.000000
12 21.406923000 t4820 US
11 21.407542000 t4820 US Bu
13 21.407858000 sched nready 0.000000
13 21.407858000 sched nsubmitted 0.000000
12 21.408112000 t4820 US
20 21.404747000 w1 WS send/recv:NW 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 1
0.000000 0 0 0 -1 -1
20 21.404926000 w0 WS send/recv:NO 537198640
M8194x1x8_M8194x8194x8 b582fff9 0000000000000000 2
10 21.408653000 w2 WS "B"
10 21.409172000 w2 WS "B"
10 21.409673000 w2 WS "Fi"
11 21.410325000 t4820 US Su
10 21.410709000 w2 WS "B"
13 21.410838000 sched nsubmitted 1.000000
6 send/recv:NE WS send/recv:NE "0.000000 0.600000 0.400000"
6 send/recv:NE_1 Ctx1 send/recv:NE "1.0 0.39 1.0"
6 send/recv:NE_2 Ctx2 send/recv:NE ".0 1.0 .0"
6 send/recv:NE_3 Ctx3 send/recv:NE "0.87 0.87 .0"
6 send/recv:NE_4 Ctx4 send/recv:NE ".0 0.95 1.0"
6 send/recv:NE_5 Ctx5 send/recv:NE ".0 .0 .0"
6 send/recv:NE_6 Ctx6 send/recv:NE ".0 .0 0.5"
6 send/recv:NE_7 Ctx7 send/recv:NE "0.41 0.41 0.41"
6 send/recv:NE_8 Ctx8 send/recv:NE "1.0 .0 1.0"
6 send/recv:NE_9 Ctx9 send/recv:NE ".0 .0 1.0"
10 21.411632000 w2 WS "send/recv:NE"
13 21.412208000 sched nready 1.000000
10 21.413566000 w1 WS "B"
13 21.404747000 w1 gf 0.000000
13 21.413566000 w1 gf 0.000000
13 21.404747000 sched gft 0.000000
12 21.413742000 t4820 US
11 21.414343000 t4820 US Bu
13 21.414571000 sched nready 0.000000
13 21.414571000 sched nsubmitted 0.000000
12 21.414921000 t4820 US
10 21.415038000 w1 WS "Po"
10 21.415247000 w3 WS "B"
11 21.415534000 t4820 US Su
20 21.411632000 w2 WS send/recv:NE 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 3
10 21.415788000 w3 WS "B"
13 21.416032000 sched nsubmitted 1.000000
10 21.416288000 w3 WS "Fi"
10 21.416933000 w1 WS "B"
10 21.417382000 w3 WS "B"
13 21.417484000 sched nready 1.000000
10 21.418293000 w2 WS "B"
13 21.411632000 w2 gf 0.000000
13 21.418293000 w2 gf 0.000000
10 21.418391000 w3 WS "send/recv:NW"
10 21.418973000 w2 WS "Po"
12 21.419146000 t4820 US
11 21.419704000 t4820 US Bu
10 21.419810000 w2 WS "B"
13 21.419972000 sched nready 0.000000
13 21.419972000 sched nsubmitted 0.000000
12 21.420270000 t4820 US
10 21.420656000 w4 WS "B"
11 21.420862000 t4820 US Su
10 21.421223000 w4 WS "B"
13 21.421465000 sched nsubmitted 1.000000
10 21.421782000 w4 WS "Fi"
20 21.418391000 w3 WS send/recv:NW 537198640
M1x8194x8_M8194x8194x8 bc5be9a3 0000000000000000 4
10 21.422876000 w4 WS "B"
13 21.422985000 sched nready 1.000000
10 21.423816000 w4 WS "send/recv:NW"
12 21.424615000 t4820 US
11 21.425198000 t4820 US Bu
10 21.425265000 w2 WS "P"
10 21.440212000 w1 WS "P"
10 21.440577000 w2 WS "Sc"
10 21.440900000 w1 WS "Sc"
13 21.441253000 sched nready 0.000000
13 21.441253000 sched nsubmitted 0.000000
10 21.441475000 w1 WS "Sl"
12 21.441594000 t4820 US
10 21.441717000 w2 WS "B"
11 21.442224000 t4820 US Su
10 21.442273000 w2 WS "B"
10 21.442732000 w2 WS "Fi"
13 21.442786000 sched nsubmitted 1.000000
20 21.423816000 w4 WS send/recv:NW 537198640
M1x8194x8_M8194x8194x8 bc5be9a3 0000000000000000 5
10 21.443539000 w2 WS "B"
10 21.444129000 w2 WS "send/recv:NE"
13 21.444394000 sched nready 1.000000
20 21.444129000 w2 WS send/recv:NE 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 6
12 21.446156000 t4820 US
10 21.446568000 w2 WS "B"
13 21.444129000 w2 gf 0.000000
13 21.446568000 w2 gf 0.000000
13 21.446994000 sched nready 0.000000
13 21.446994000 sched nsubmitted 0.000000
10 21.447111000 w2 WS "Po"
10 21.447610000 w1 WS "B"
10 21.447748000 w2 WS "B"
11 21.448011000 t4820 US Bu
10 21.448105000 w1 WS "B"
10 21.448593000 w1 WS "Fi"
12 21.448751000 t4820 US
10 21.449446000 w1 WS "B"
11 21.449483000 t4820 US Su
10 21.449808000 w2 WS "P"
13 21.450001000 sched nsubmitted 1.000000
10 21.450080000 w1 WS "send/recv:NO"
10 21.450378000 w2 WS "Sc"
10 21.451000000 w2 WS "Sl"
20 21.450080000 w1 WS send/recv:NO 537198640
M8194x1x8_M8194x8194x8 b582fff9 0000000000000000 7
13 21.451732000 sched nready 1.000000
12 21.453360000 t4820 US
11 21.454042000 t4820 US Bu
13 21.454758000 sched nready 0.000000
13 21.454758000 sched nsubmitted 0.000000
12 21.454894000 t4820 US
10 21.455628000 w5 WS "B"
11 21.455688000 t4820 US Su
10 21.456383000 w5 WS "B"
13 21.456735000 sched nsubmitted 1.000000
10 21.457163000 w5 WS "Fi"
10 21.458469000 w5 WS "B"
10 21.459453000 w5 WS "send/recv:NW"
13 21.459482000 sched nready 1.000000
12 21.461280000 t4820 US
11 21.461936000 t4820 US Bu
13 21.462015000 sched nready 0.000000
13 21.462015000 sched nsubmitted 0.000000
10 21.462077000 w0 WS "B"
13 21.404926000 w0 gf 0.000000
13 21.462077000 w0 gf 0.000000
13 21.404926000 sched gft 0.000000
13 21.411632000 sched gft 0.000000
13 21.413566000 sched gft 0.000000
13 21.418293000 sched gft 0.000000
10 21.462533000 w2 WS "B"
12 21.462724000 t4820 US
10 21.462855000 w0 WS "Po"
10 21.463011000 w2 WS "B"
11 21.463361000 t4820 US Su
10 21.463567000 w2 WS "Fi"
10 21.463735000 w0 WS "B"
13 21.463911000 sched nsubmitted 1.000000
10 21.464607000 w2 WS "B"
6 B11_nw WS B11_nw "0.000000 0.600000 0.400000"
6 B11_nw_1 Ctx1 B11_nw "1.0 0.39 1.0"
6 B11_nw_2 Ctx2 B11_nw ".0 1.0 .0"
6 B11_nw_3 Ctx3 B11_nw "0.87 0.87 .0"
6 B11_nw_4 Ctx4 B11_nw ".0 0.95 1.0"
6 B11_nw_5 Ctx5 B11_nw ".0 .0 .0"
6 B11_nw_6 Ctx6 B11_nw ".0 .0 0.5"
6 B11_nw_7 Ctx7 B11_nw "0.41 0.41 0.41"
6 B11_nw_8 Ctx8 B11_nw "1.0 .0 1.0"
6 B11_nw_9 Ctx9 B11_nw ".0 .0 1.0"
10 21.465120000 w2 WS "B11_nw"
20 21.459453000 w5 WS send/recv:NW 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 8
13 21.466366000 sched nready 1.000000
20 21.465120000 w2 WS B11_nw 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 9 0.000000 0 0
0 -1 -1
10 21.466837000 w0 WS "P"
10 21.467483000 w0 WS "Sc"
13 21.468196000 sched nready 0.000000
13 21.468196000 sched nsubmitted 0.000000
12 21.468336000 t4820 US
10 21.468665000 w0 WS "B"
10 21.468922000 w5 WS "B"
13 21.459453000 w5 gf 0.000000
13 21.468922000 w5 gf 0.000000
11 21.469026000 t4820 US Bu
10 21.469134000 w0 WS "B"
10 21.469269000 w2 WS "B"
13 21.465120000 w2 gf 0.000000
13 21.469269000 w2 gf 0.000000
10 21.469615000 w0 WS "Fi"
12 21.469827000 t4820 US
10 21.469894000 w2 WS "Po"
10 21.470247000 w5 WS "Po"
10 21.470535000 w0 WS "B"
10 21.470665000 w2 WS "B"
6 B11_no WS B11_no "0.000000 0.600000 0.400000"
6 B11_no_1 Ctx1 B11_no "1.0 0.39 1.0"
6 B11_no_2 Ctx2 B11_no ".0 1.0 .0"
6 B11_no_3 Ctx3 B11_no "0.87 0.87 .0"
6 B11_no_4 Ctx4 B11_no ".0 0.95 1.0"
6 B11_no_5 Ctx5 B11_no ".0 .0 .0"
6 B11_no_6 Ctx6 B11_no ".0 .0 0.5"
6 B11_no_7 Ctx7 B11_no "0.41 0.41 0.41"
6 B11_no_8 Ctx8 B11_no "1.0 .0 1.0"
6 B11_no_9 Ctx9 B11_no ".0 .0 1.0"
10 21.471045000 w0 WS "B11_no"
10 21.471242000 w5 WS "B"
11 21.472264000 t4820 US Su
20 21.471045000 w0 WS B11_no 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 10
13 21.472796000 sched nsubmitted 1.000000
10 21.472956000 w2 WS "P"
10 21.473546000 w2 WS "Sc"
10 21.474056000 w0 WS "B"
13 21.471045000 w0 gf 0.000000
13 21.474056000 w0 gf 0.000000
10 21.474134000 w2 WS "Sl"
10 21.474600000 w0 WS "Po"
10 21.475244000 w5 WS "P"
10 21.475364000 w0 WS "B"
10 21.475994000 w5 WS "Sc"
10 21.476640000 w5 WS "Sl"
12 21.477603000 t4820 US
10 21.477687000 w0 WS "P"
10 21.478264000 w0 WS "Sc"
11 21.478339000 t4820 US Bu
10 21.478788000 w0 WS "Sl"
12 21.478982000 t4820 US
11 21.479666000 t4820 US Su
13 21.480235000 sched nsubmitted 2.000000
13 21.481837000 sched nready 1.000000
12 21.483422000 t4820 US
13 21.483721000 sched nready 0.000000
13 21.483721000 sched nsubmitted 1.000000
11 21.484079000 t4820 US Bu
10 21.484238000 w2 WS "B"
10 21.484701000 w2 WS "B"
12 21.484853000 t4820 US
10 21.485133000 w2 WS "Fi"
11 21.485459000 t4820 US Su
10 21.485892000 w2 WS "B"
13 21.486166000 sched nsubmitted 2.000000
6 B11_aa WS B11_aa "0.000000 0.600000 0.400000"
6 B11_aa_1 Ctx1 B11_aa "1.0 0.39 1.0"
6 B11_aa_2 Ctx2 B11_aa ".0 1.0 .0"
6 B11_aa_3 Ctx3 B11_aa "0.87 0.87 .0"
6 B11_aa_4 Ctx4 B11_aa ".0 0.95 1.0"
6 B11_aa_5 Ctx5 B11_aa ".0 .0 .0"
6 B11_aa_6 Ctx6 B11_aa ".0 .0 0.5"
6 B11_aa_7 Ctx7 B11_aa "0.41 0.41 0.41"
6 B11_aa_8 Ctx8 B11_aa "1.0 .0 1.0"
6 B11_aa_9 Ctx9 B11_aa ".0 .0 1.0"
10 21.486389000 w2 WS "B11_aa"
20 21.486389000 w2 WS B11_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 12 0.000000 0 0
0 -1 -1
12 21.488959000 t4820 US
10 21.489011000 w2 WS "B"
13 21.486389000 w2 gf 0.000000
13 21.489011000 w2 gf 0.000000
10 21.489673000 w2 WS "Po"
11 21.489828000 t4820 US Bu
10 21.490434000 w2 WS "B"
12 21.490486000 t4820 US
10 21.490539000 w1 WS "B"
13 21.450080000 w1 gf 0.000000
13 21.490539000 w1 gf 0.000000
11 21.491099000 t4820 US Su
10 21.491150000 w1 WS "Po"
10 21.491876000 w1 WS "B"
13 21.491958000 sched nsubmitted 3.000000
10 21.493149000 w2 WS "P"
10 21.493690000 w2 WS "Sc"
13 21.493933000 sched nready 1.000000
10 21.494152000 w2 WS "Sl"
10 21.494346000 w1 WS "P"
10 21.494937000 w1 WS "Sc"
10 21.495497000 w1 WS "Sl"
12 21.495675000 t4820 US
13 21.495908000 sched nready 0.000000
13 21.495908000 sched nsubmitted 2.000000
10 21.496395000 w2 WS "B"
10 21.496830000 w2 WS "B"
10 21.497256000 w2 WS "Fi"
11 21.497488000 t4820 US Bu
12 21.498113000 t4820 US
10 21.498180000 w2 WS "B"
6 B12_no WS B12_no "0.000000 0.600000 0.400000"
6 B12_no_1 Ctx1 B12_no "1.0 0.39 1.0"
6 B12_no_2 Ctx2 B12_no ".0 1.0 .0"
6 B12_no_3 Ctx3 B12_no "0.87 0.87 .0"
6 B12_no_4 Ctx4 B12_no ".0 0.95 1.0"
6 B12_no_5 Ctx5 B12_no ".0 .0 .0"
6 B12_no_6 Ctx6 B12_no ".0 .0 0.5"
6 B12_no_7 Ctx7 B12_no "0.41 0.41 0.41"
6 B12_no_8 Ctx8 B12_no "1.0 .0 1.0"
6 B12_no_9 Ctx9 B12_no ".0 .0 1.0"
10 21.498702000 w2 WS "B12_no"
11 21.498837000 t4820 US Su
13 21.499435000 sched nsubmitted 3.000000
20 21.498702000 w2 WS B12_no 131160
M8192x1x8_M8194x1x8_M3x3x8 a5e481fd 0000000000000000 14
13 21.501077000 sched nready 1.000000
13 21.502501000 sched nready 0.000000
13 21.502501000 sched nsubmitted 2.000000
12 21.502686000 t4820 US
10 21.503027000 w1 WS "B"
11 21.503331000 t4820 US Bu
10 21.503481000 w1 WS "B"
10 21.503955000 w1 WS "Fi"
12 21.504103000 t4820 US
11 21.504814000 t4820 US Su
10 21.504883000 w1 WS "B"
6 B12_aa WS B12_aa "0.000000 0.600000 0.400000"
6 B12_aa_1 Ctx1 B12_aa "1.0 0.39 1.0"
6 B12_aa_2 Ctx2 B12_aa ".0 1.0 .0"
6 B12_aa_3 Ctx3 B12_aa "0.87 0.87 .0"
6 B12_aa_4 Ctx4 B12_aa ".0 0.95 1.0"
6 B12_aa_5 Ctx5 B12_aa ".0 .0 .0"
6 B12_aa_6 Ctx6 B12_aa ".0 .0 0.5"
6 B12_aa_7 Ctx7 B12_aa "0.41 0.41 0.41"
6 B12_aa_8 Ctx8 B12_aa "1.0 .0 1.0"
6 B12_aa_9 Ctx9 B12_aa ".0 .0 1.0"
10 21.505493000 w1 WS "B12_aa"
13 21.505605000 sched nsubmitted 3.000000
20 21.505493000 w1 WS B12_aa 196712
M8192x1x8_M8194x2x8_M3x3x8 5212cc39 0000000000000000 15
12 21.507649000 t4820 US
11 21.508304000 t4820 US Bu
12 21.508850000 t4820 US
11 21.509435000 t4820 US Su
13 21.509978000 sched nsubmitted 4.000000
13 21.511562000 sched nready 1.000000
12 21.513111000 t4820 US
13 21.513251000 sched nready 0.000000
13 21.513251000 sched nsubmitted 3.000000
11 21.513758000 t4820 US Bu
10 21.513841000 w0 WS "B"
10 21.514290000 w0 WS "B"
12 21.514562000 t4820 US
10 21.514746000 w0 WS "Fi"
10 21.515552000 w0 WS "B"
6 B13_no WS B13_no "0.000000 0.600000 0.400000"
6 B13_no_1 Ctx1 B13_no "1.0 0.39 1.0"
6 B13_no_2 Ctx2 B13_no ".0 1.0 .0"
6 B13_no_3 Ctx3 B13_no "0.87 0.87 .0"
6 B13_no_4 Ctx4 B13_no ".0 0.95 1.0"
6 B13_no_5 Ctx5 B13_no ".0 .0 .0"
6 B13_no_6 Ctx6 B13_no ".0 .0 0.5"
6 B13_no_7 Ctx7 B13_no "0.41 0.41 0.41"
6 B13_no_8 Ctx8 B13_no "1.0 .0 1.0"
6 B13_no_9 Ctx9 B13_no ".0 .0 1.0"
10 21.516023000 w0 WS "B13_no"
11 21.516530000 t4820 US Su
20 21.516023000 w0 WS B13_no 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 17
13 21.517224000 sched nsubmitted 4.000000
10 21.518729000 w0 WS "B"
13 21.516023000 w0 gf 0.000000
13 21.518729000 w0 gf 0.000000
13 21.519098000 sched nready 1.000000
10 21.519270000 w0 WS "Po"
10 21.519987000 w0 WS "B"
12 21.520724000 t4820 US
11 21.521378000 t4820 US Bu
13 21.521471000 sched nready 0.000000
13 21.521471000 sched nsubmitted 3.000000
10 21.522186000 w5 WS "B"
12 21.522234000 t4820 US
10 21.522289000 w0 WS "P"
10 21.522895000 w0 WS "Sc"
10 21.522991000 w5 WS "B"
11 21.523082000 t4820 US Su
10 21.523424000 w0 WS "Sl"
10 21.523704000 w5 WS "Fi"
13 21.524111000 sched nsubmitted 4.000000
10 21.524744000 w5 WS "B"
6 B13_ne WS B13_ne "0.000000 0.600000 0.400000"
6 B13_ne_1 Ctx1 B13_ne "1.0 0.39 1.0"
6 B13_ne_2 Ctx2 B13_ne ".0 1.0 .0"
6 B13_ne_3 Ctx3 B13_ne "0.87 0.87 .0"
6 B13_ne_4 Ctx4 B13_ne ".0 0.95 1.0"
6 B13_ne_5 Ctx5 B13_ne ".0 .0 .0"
6 B13_ne_6 Ctx6 B13_ne ".0 .0 0.5"
6 B13_ne_7 Ctx7 B13_ne "0.41 0.41 0.41"
6 B13_ne_8 Ctx8 B13_ne "1.0 .0 1.0"
6 B13_ne_9 Ctx9 B13_ne ".0 .0 1.0"
10 21.525598000 w5 WS "B13_ne"
12 21.525848000 t4820 US
11 21.526447000 t4820 US Bu
12 21.527052000 t4820 US
11 21.527616000 t4820 US Su
20 21.525598000 w5 WS B13_ne 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 18 0.000000 0 0
0 -1 -1
13 21.528102000 sched nsubmitted 5.000000
10 21.530135000 w5 WS "B"
13 21.525598000 w5 gf 0.000000
13 21.530135000 w5 gf 0.000000
13 21.530205000 sched nready 1.000000
10 21.530949000 w5 WS "Po"
10 21.532060000 w5 WS "B"
12 21.532119000 t4820 US
13 21.532892000 sched nready 0.000000
13 21.532892000 sched nsubmitted 4.000000
11 21.532966000 t4820 US Bu
10 21.533499000 w0 WS "B"
12 21.533801000 t4820 US
10 21.534007000 w0 WS "B"
10 21.534457000 w0 WS "Fi"
11 21.534662000 t4820 US Su
13 21.535202000 sched nsubmitted 5.000000
10 21.535555000 w5 WS "P"
10 21.535430000 w0 WS "B"
6 B13_aa WS B13_aa "0.000000 0.600000 0.400000"
6 B13_aa_1 Ctx1 B13_aa "1.0 0.39 1.0"
6 B13_aa_2 Ctx2 B13_aa ".0 1.0 .0"
6 B13_aa_3 Ctx3 B13_aa "0.87 0.87 .0"
6 B13_aa_4 Ctx4 B13_aa ".0 0.95 1.0"
6 B13_aa_5 Ctx5 B13_aa ".0 .0 .0"
6 B13_aa_6 Ctx6 B13_aa ".0 .0 0.5"
6 B13_aa_7 Ctx7 B13_aa "0.41 0.41 0.41"
6 B13_aa_8 Ctx8 B13_aa "1.0 .0 1.0"
6 B13_aa_9 Ctx9 B13_aa ".0 .0 1.0"
10 21.535935000 w0 WS "B13_aa"
10 21.536625000 w5 WS "Sc"
20 21.535935000 w0 WS B13_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 20 0.000000 0 0
0 -1 -1
10 21.537335000 w5 WS "Sl"
10 21.538661000 w0 WS "B"
13 21.535935000 w0 gf 0.000000
13 21.538661000 w0 gf 0.000000
12 21.538722000 t4820 US
10 21.539188000 w0 WS "Po"
10 21.539914000 w0 WS "B"
11 21.540769000 t4820 US Bu
12 21.541327000 t4820 US
11 21.541957000 t4820 US Su
10 21.542327000 w0 WS "P"
13 21.542500000 sched nsubmitted 6.000000
10 21.542873000 w0 WS "Sc"
10 21.543346000 w0 WS "Sl"
12 21.544188000 t4820 US
11 21.544730000 t4820 US Bu
12 21.545207000 t4820 US
11 21.545784000 t4820 US Su
13 21.546261000 sched nsubmitted 7.000000
13 21.547786000 sched nready 1.000000
12 21.550329000 t4820 US
13 21.550430000 sched nready 0.000000
13 21.550430000 sched nsubmitted 6.000000
10 21.551122000 w5 WS "B"
11 21.551134000 t4820 US Bu
10 21.551813000 w5 WS "B"
12 21.551874000 t4820 US
10 21.552464000 w5 WS "Fi"
11 21.552881000 t4820 US Su
13 21.553374000 sched nsubmitted 7.000000
10 21.553463000 w5 WS "B"
6 B21_aa WS B21_aa "0.000000 0.600000 0.400000"
6 B21_aa_1 Ctx1 B21_aa "1.0 0.39 1.0"
6 B21_aa_2 Ctx2 B21_aa ".0 1.0 .0"
6 B21_aa_3 Ctx3 B21_aa "0.87 0.87 .0"
6 B21_aa_4 Ctx4 B21_aa ".0 0.95 1.0"
6 B21_aa_5 Ctx5 B21_aa ".0 .0 .0"
6 B21_aa_6 Ctx6 B21_aa ".0 .0 0.5"
6 B21_aa_7 Ctx7 B21_aa "0.41 0.41 0.41"
6 B21_aa_8 Ctx8 B21_aa "1.0 .0 1.0"
6 B21_aa_9 Ctx9 B21_aa ".0 .0 1.0"
10 21.554228000 w5 WS "B21_aa"
12 21.555317000 t4820 US
20 21.554228000 w5 WS B21_aa 196712
M1x8192x8_M2x8194x8_M3x3x8 6ccb5ec1 0000000000000000 23
11 21.572652000 t4820 US Bu
12 21.573285000 t4820 US
11 21.575166000 t4820 US Su
13 21.575700000 sched nsubmitted 8.000000
13 21.577708000 sched nready 1.000000
12 21.579530000 t4820 US
13 21.580165000 sched nready 0.000000
13 21.580165000 sched nsubmitted 7.000000
10 21.580694000 w0 WS "B"
11 21.580745000 t4820 US Bu
10 21.581138000 w0 WS "B"
12 21.581283000 t4820 US
10 21.581581000 w0 WS "Fi"
11 21.581930000 t4820 US Su
10 21.582458000 w0 WS "B"
13 21.582512000 sched nsubmitted 8.000000
6 B22_0 WS B22_0 "0.000000 0.600000 0.400000"
6 B22_0_1 Ctx1 B22_0 "1.0 0.39 1.0"
6 B22_0_2 Ctx2 B22_0 ".0 1.0 .0"
6 B22_0_3 Ctx3 B22_0 "0.87 0.87 .0"
6 B22_0_4 Ctx4 B22_0 ".0 0.95 1.0"
6 B22_0_5 Ctx5 B22_0 ".0 .0 .0"
6 B22_0_6 Ctx6 B22_0 ".0 .0 0.5"
6 B22_0_7 Ctx7 B22_0 "0.41 0.41 0.41"
6 B22_0_8 Ctx8 B22_0 "1.0 .0 1.0"
6 B22_0_9 Ctx9 B22_0 ".0 .0 1.0"
10 21.583022000 w0 WS "B22_0"
20 21.583022000 w0 WS B22_0 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 25
13 21.584317000 sched nready 1.000000
12 21.585884000 t4820 US
11 21.586721000 t4820 US Bu
12 21.587241000 t4820 US
11 21.587832000 t4820 US Su
13 21.588337000 sched nsubmitted 9.000000
13 21.589854000 sched nready 2.000000
12 21.591381000 t4820 US
11 21.592157000 t4820 US Bu
12 21.592667000 t4820 US
11 21.593261000 t4820 US Su
13 21.593737000 sched nsubmitted 10.000000
13 21.595296000 sched nready 3.000000
12 21.596830000 t4820 US
11 21.598981000 t4820 US Bu
12 21.599515000 t4820 US
11 21.600091000 t4820 US Su
13 21.600566000 sched nsubmitted 11.000000
13 21.602241000 sched nready 4.000000
10 21.602404000 w2 WS "B"
13 21.498702000 w2 gf 0.000000
13 21.602404000 w2 gf 0.000000
10 21.602929000 w2 WS "Po"
10 21.603748000 w2 WS "B"
12 21.603899000 t4820 US
11 21.604862000 t4820 US Bu
12 21.605385000 t4820 US
10 21.606005000 w2 WS "P"
11 21.606077000 t4820 US Su
13 21.606611000 sched nsubmitted 12.000000
10 21.606680000 w2 WS "Sc"
13 21.607428000 sched nready 3.000000
13 21.607428000 sched nsubmitted 11.000000
10 21.607888000 w2 WS "B"
10 21.608323000 w2 WS "B"
13 21.608418000 sched nready 4.000000
10 21.608763000 w2 WS "Fi"
10 21.609610000 w2 WS "B"
6 B22_1 WS B22_1 "0.000000 0.600000 0.400000"
6 B22_1_1 Ctx1 B22_1 "1.0 0.39 1.0"
6 B22_1_2 Ctx2 B22_1 ".0 1.0 .0"
6 B22_1_3 Ctx3 B22_1 "0.87 0.87 .0"
6 B22_1_4 Ctx4 B22_1 ".0 0.95 1.0"
6 B22_1_5 Ctx5 B22_1 ".0 .0 .0"
6 B22_1_6 Ctx6 B22_1 ".0 .0 0.5"
6 B22_1_7 Ctx7 B22_1 "0.41 0.41 0.41"
6 B22_1_8 Ctx8 B22_1 "1.0 .0 1.0"
6 B22_1_9 Ctx9 B22_1 ".0 .0 1.0"
10 21.610141000 w2 WS "B22_1"
12 21.610210000 t4820 US
11 21.611113000 t4820 US Bu
20 21.610141000 w2 WS B22_1 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 26
12 21.611642000 t4820 US
11 21.612260000 t4820 US Su
13 21.612742000 sched nsubmitted 12.000000
13 21.614321000 sched nready 5.000000
12 21.615858000 t4820 US
11 21.616649000 t4820 US Bu
12 21.617169000 t4820 US
11 21.618998000 t4820 US Su
13 21.619484000 sched nsubmitted 13.000000
13 21.621034000 sched nready 6.000000
12 21.622548000 t4820 US
11 21.623397000 t4820 US Bu
12 21.623884000 t4820 US
11 21.624435000 t4820 US Su
13 21.624910000 sched nsubmitted 14.000000
13 21.626459000 sched nready 7.000000
12 21.627985000 t4820 US
11 21.628769000 t4820 US Bu
12 21.629276000 t4820 US
11 21.629834000 t4820 US Su
13 21.630305000 sched nsubmitted 15.000000
13 21.631804000 sched nready 8.000000
12 21.633305000 t4820 US
11 21.635334000 t4820 US Bu
12 21.635972000 t4820 US
11 21.636569000 t4820 US Su
13 21.637048000 sched nsubmitted 16.000000
13 21.638568000 sched nready 9.000000
12 21.640064000 t4820 US
11 21.640932000 t4820 US Bu
12 21.641423000 t4820 US
11 21.643272000 t4820 US Su
13 21.643787000 sched nsubmitted 17.000000
13 21.645336000 sched nready 10.000000
12 21.646871000 t4820 US
11 21.647737000 t4820 US Bu
12 21.648246000 t4820 US
11 21.648860000 t4820 US Su
13 21.649380000 sched nsubmitted 18.000000
13 21.650864000 sched nready 11.000000
12 21.652406000 t4820 US
11 21.653224000 t4820 US Bu
12 21.653737000 t4820 US
11 21.654318000 t4820 US Su
13 21.654787000 sched nsubmitted 19.000000
13 21.656229000 sched nready 12.000000
12 21.657710000 t4820 US
11 21.658542000 t4820 US Bu
12 21.659049000 t4820 US
11 21.659636000 t4820 US Su
13 21.660110000 sched nsubmitted 20.000000
13 21.661590000 sched nready 13.000000
12 21.663220000 t4820 US
11 21.664044000 t4820 US Bu
12 21.664566000 t4820 US
11 21.666369000 t4820 US Su
13 21.666864000 sched nsubmitted 21.000000
13 21.668395000 sched nready 14.000000
12 21.669948000 t4820 US
11 21.670855000 t4820 US Bu
12 21.671372000 t4820 US
11 21.671950000 t4820 US Su
13 21.672437000 sched nsubmitted 22.000000
13 21.674011000 sched nready 15.000000
12 21.675497000 t4820 US
11 21.676305000 t4820 US Bu
12 21.676807000 t4820 US
11 21.677381000 t4820 US Su
13 21.677852000 sched nsubmitted 23.000000
13 21.679339000 sched nready 16.000000
12 21.681062000 t4820 US
11 21.681885000 t4820 US Bu
12 21.682393000 t4820 US
11 21.682974000 t4820 US Su
13 21.683444000 sched nsubmitted 24.000000
13 21.684952000 sched nready 17.000000
12 21.686504000 t4820 US
11 21.688583000 t4820 US Bu
12 21.689112000 t4820 US
11 21.689717000 t4820 US Su
13 21.690194000 sched nsubmitted 25.000000
13 21.691850000 sched nready 18.000000
12 21.693404000 t4820 US
11 21.694279000 t4820 US Bu
12 21.694771000 t4820 US
11 21.695348000 t4820 US Su
13 21.695852000 sched nsubmitted 26.000000
13 21.697383000 sched nready 19.000000
12 21.698906000 t4820 US
11 21.699823000 t4820 US Bu
10 21.699890000 w1 WS "B"
13 21.505493000 w1 gf 0.000000
13 21.699890000 w1 gf 0.000000
12 21.700498000 t4820 US
10 21.700564000 w1 WS "Po"
11 21.701165000 t4820 US Su
10 21.701454000 w1 WS "B"
13 21.701677000 sched nsubmitted 27.000000
13 21.703342000 sched nready 20.000000
12 21.704898000 t4820 US
13 21.704997000 sched nready 21.000000
11 21.705671000 w1 WS Sc
11 21.705809000 t4820 US Bu
12 21.706408000 t4820 US
12 21.706520000 w1 WS
10 21.707836000 w1 WS "P"
11 21.708292000 t4820 US Su
10 21.708440000 w1 WS "Sc"
13 21.708832000 sched nsubmitted 28.000000
13 21.709095000 sched nready 20.000000
13 21.709095000 sched nsubmitted 27.000000
10 21.709569000 w1 WS "B"
10 21.710034000 w1 WS "B"
10 21.710477000 w1 WS "Fi"
13 21.710553000 sched nready 21.000000
10 21.711410000 w1 WS "B"
6 B22_2 WS B22_2 "0.000000 0.600000 0.400000"
6 B22_2_1 Ctx1 B22_2 "1.0 0.39 1.0"
6 B22_2_2 Ctx2 B22_2 ".0 1.0 .0"
6 B22_2_3 Ctx3 B22_2 "0.87 0.87 .0"
6 B22_2_4 Ctx4 B22_2 ".0 0.95 1.0"
6 B22_2_5 Ctx5 B22_2 ".0 .0 .0"
6 B22_2_6 Ctx6 B22_2 ".0 .0 0.5"
6 B22_2_7 Ctx7 B22_2 "0.41 0.41 0.41"
6 B22_2_8 Ctx8 B22_2 "1.0 .0 1.0"
6 B22_2_9 Ctx9 B22_2 ".0 .0 1.0"
10 21.711932000 w1 WS "B22_2"
12 21.712760000 t4820 US
20 21.711932000 w1 WS B22_2 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 27
11 21.713715000 t4820 US Bu
12 21.714289000 t4820 US
11 21.714904000 t4820 US Su
13 21.715392000 sched nsubmitted 28.000000
13 21.716943000 sched nready 22.000000
12 21.718499000 t4820 US
11 21.719311000 t4820 US Bu
12 21.719814000 t4820 US
11 21.720394000 t4820 US Su
13 21.720945000 sched nsubmitted 29.000000
13 21.722442000 sched nready 23.000000
12 21.723942000 t4820 US
11 21.724772000 t4820 US Bu
12 21.725273000 t4820 US
11 21.725838000 t4820 US Su
13 21.726307000 sched nsubmitted 30.000000
13 21.727813000 sched nready 24.000000
12 21.729295000 t4820 US
11 21.730180000 t4820 US Bu
12 21.730685000 t4820 US
11 21.732488000 t4820 US Su
13 21.732978000 sched nsubmitted 31.000000
13 21.734489000 sched nready 25.000000
12 21.736008000 t4820 US
11 21.736874000 t4820 US Bu
12 21.737378000 t4820 US
11 21.737958000 t4820 US Su
13 21.738420000 sched nsubmitted 32.000000
13 21.739947000 sched nready 26.000000
12 21.741499000 t4820 US
11 21.742311000 t4820 US Bu
12 21.742816000 t4820 US
11 21.743417000 t4820 US Su
13 21.743891000 sched nsubmitted 33.000000
13 21.745453000 sched nready 27.000000
12 21.747335000 t4820 US
11 21.748136000 t4820 US Bu
12 21.748674000 t4820 US
11 21.749268000 t4820 US Su
13 21.749734000 sched nsubmitted 34.000000
13 21.751223000 sched nready 28.000000
12 21.752744000 t4820 US
11 21.753525000 t4820 US Bu
12 21.754034000 t4820 US
11 21.755861000 t4820 US Su
13 21.756349000 sched nsubmitted 35.000000
13 21.757958000 sched nready 29.000000
12 21.759484000 t4820 US
11 21.760325000 t4820 US Bu
12 21.760830000 t4820 US
11 21.761413000 t4820 US Su
13 21.761890000 sched nsubmitted 36.000000
13 21.763420000 sched nready 30.000000
12 21.764938000 t4820 US
11 21.765760000 t4820 US Bu
12 21.766282000 t4820 US
11 21.766890000 t4820 US Su
13 21.767401000 sched nsubmitted 37.000000
13 21.769101000 sched nready 31.000000
12 21.770684000 t4820 US
11 21.771481000 t4820 US Bu
12 21.772015000 t4820 US
11 21.772691000 t4820 US Su
13 21.773174000 sched nsubmitted 38.000000
13 21.774693000 sched nready 32.000000
12 21.776253000 t4820 US
11 21.778349000 t4820 US Bu
12 21.778872000 t4820 US
11 21.779458000 t4820 US Su
13 21.779943000 sched nsubmitted 39.000000
13 21.781460000 sched nready 33.000000
12 21.782997000 t4820 US
11 21.784252000 t4820 US Bu
12 21.784758000 t4820 US
11 21.785375000 t4820 US Su
13 21.785849000 sched nsubmitted 40.000000
13 21.787324000 sched nready 34.000000
12 21.788963000 t4820 US
11 21.789780000 t4820 US Bu
12 21.790286000 t4820 US
11 21.790848000 t4820 US Su
13 21.791317000 sched nsubmitted 41.000000
13 21.792835000 sched nready 35.000000
12 21.794355000 t4820 US
11 21.795204000 t4820 US Bu
12 21.795706000 t4820 US
11 21.796328000 t4820 US Su
13 21.796815000 sched nsubmitted 42.000000
10 21.798075000 w4 WS "B"
13 21.423816000 w4 gf 0.000000
13 21.798075000 w4 gf 0.000000
10 21.798315000 w3 WS "B"
13 21.418391000 w3 gf 0.000000
13 21.798315000 w3 gf 0.000000
13 21.418391000 sched gft 0.000000
13 21.423816000 sched gft 0.000000
13 21.444129000 sched gft 0.000000
13 21.446568000 sched gft 0.000000
13 21.450080000 sched gft 0.000000
13 21.459453000 sched gft 0.000000
13 21.462077000 sched gft 0.000000
13 21.465120000 sched gft 0.000000
13 21.468922000 sched gft 0.000000
13 21.469269000 sched gft 0.000000
13 21.471045000 sched gft 0.000000
13 21.474056000 sched gft 0.000000
13 21.486389000 sched gft 0.000000
13 21.489011000 sched gft 0.000000
13 21.490539000 sched gft 0.000000
13 21.498702000 sched gft 0.000000
13 21.505493000 sched gft 0.000000
13 21.516023000 sched gft 0.000000
13 21.518729000 sched gft 0.000000
13 21.525598000 sched gft 0.000000
13 21.530135000 sched gft 0.000000
13 21.535935000 sched gft 0.000000
13 21.538661000 sched gft 0.000000
13 21.798389000 sched nready 36.000000
10 21.798869000 w4 WS "Po"
10 21.799096000 w3 WS "Po"
10 21.799816000 w4 WS "B"
10 21.800074000 w3 WS "B"
12 21.800423000 t4820 US
11 21.802502000 t4820 US Bu
12 21.803012000 t4820 US
13 21.803179000 sched nready 37.000000
13 21.803286000 sched nready 38.000000
11 21.803689000 t4820 US Su
11 21.803901000 w4 WS Sc
11 21.803960000 w3 WS Sc
13 21.804210000 sched nsubmitted 43.000000
12 21.805394000 w4 WS
13 21.805890000 sched nready 39.000000
12 21.806022000 w3 WS
10 21.807254000 w4 WS "P"
13 21.807677000 sched nready 40.000000
12 21.807739000 t4820 US
10 21.807966000 w4 WS "Sc"
11 21.808139000 w3 WS Sc
11 21.808716000 t4820 US Bu
12 21.809259000 t4820 US
13 21.809295000 sched nready 39.000000
13 21.809295000 sched nsubmitted 42.000000
12 21.809762000 w3 WS
10 21.809841000 w4 WS "B"
11 21.809958000 t4820 US Su
10 21.810317000 w4 WS "B"
13 21.810453000 sched nsubmitted 43.000000
10 21.810802000 w4 WS "Fi"
10 21.811626000 w3 WS "P"
10 21.811695000 w4 WS "B"
13 21.812151000 sched nready 40.000000
6 B22_3 WS B22_3 "0.000000 0.600000 0.400000"
6 B22_3_1 Ctx1 B22_3 "1.0 0.39 1.0"
6 B22_3_2 Ctx2 B22_3 ".0 1.0 .0"
6 B22_3_3 Ctx3 B22_3 "0.87 0.87 .0"
6 B22_3_4 Ctx4 B22_3 ".0 0.95 1.0"
6 B22_3_5 Ctx5 B22_3 ".0 .0 .0"
6 B22_3_6 Ctx6 B22_3 ".0 .0 0.5"
6 B22_3_7 Ctx7 B22_3 "0.41 0.41 0.41"
6 B22_3_8 Ctx8 B22_3 "1.0 .0 1.0"
6 B22_3_9 Ctx9 B22_3 ".0 .0 1.0"
10 21.812270000 w4 WS "B22_3"
10 21.812328000 w3 WS "Sc"
13 21.813013000 sched nready 39.000000
13 21.813013000 sched nsubmitted 42.000000
10 21.813598000 w3 WS "B"
20 21.812270000 w4 WS B22_3 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 28
10 21.814213000 w3 WS "B"
12 21.814263000 t4820 US
10 21.814647000 w3 WS "Fi"
11 21.815188000 t4820 US Bu
10 21.815418000 w3 WS "B"
12 21.815762000 t4820 US
6 B22_4 WS B22_4 "0.000000 0.600000 0.400000"
6 B22_4_1 Ctx1 B22_4 "1.0 0.39 1.0"
6 B22_4_2 Ctx2 B22_4 ".0 1.0 .0"
6 B22_4_3 Ctx3 B22_4 "0.87 0.87 .0"
6 B22_4_4 Ctx4 B22_4 ".0 0.95 1.0"
6 B22_4_5 Ctx5 B22_4 ".0 .0 .0"
6 B22_4_6 Ctx6 B22_4 ".0 .0 0.5"
6 B22_4_7 Ctx7 B22_4 "0.41 0.41 0.41"
6 B22_4_8 Ctx8 B22_4 "1.0 .0 1.0"
6 B22_4_9 Ctx9 B22_4 ".0 .0 1.0"
10 21.815939000 w3 WS "B22_4"
11 21.816437000 t4820 US Su
13 21.816985000 sched nsubmitted 43.000000
20 21.815939000 w3 WS B22_4 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 29
13 21.818587000 sched nready 40.000000
12 21.820103000 t4820 US
11 21.820953000 t4820 US Bu
12 21.821473000 t4820 US
11 21.823210000 t4820 US Su
13 21.823748000 sched nsubmitted 44.000000
13 21.825327000 sched nready 41.000000
12 21.826824000 t4820 US
11 21.827693000 t4820 US Bu
12 21.828198000 t4820 US
11 21.828759000 t4820 US Su
13 21.829248000 sched nsubmitted 45.000000
13 21.830785000 sched nready 42.000000
12 21.832340000 t4820 US
11 21.833185000 t4820 US Bu
12 21.833686000 t4820 US
11 21.834282000 t4820 US Su
13 21.834743000 sched nsubmitted 46.000000
13 21.836197000 sched nready 43.000000
12 21.837709000 t4820 US
11 21.838539000 t4820 US Bu
12 21.839046000 t4820 US
11 21.839625000 t4820 US Su
13 21.840122000 sched nsubmitted 47.000000
13 21.841602000 sched nready 44.000000
12 21.843100000 t4820 US
11 21.843907000 t4820 US Bu
12 21.844431000 t4820 US
11 21.847012000 t4820 US Su
13 21.847505000 sched nsubmitted 48.000000
13 21.849070000 sched nready 45.000000
12 21.850613000 t4820 US
11 21.851520000 t4820 US Bu
12 21.852020000 t4820 US
11 21.852601000 t4820 US Su
13 21.853060000 sched nsubmitted 49.000000
13 21.854775000 sched nready 46.000000
12 21.856301000 t4820 US
11 21.857120000 t4820 US Bu
12 21.857618000 t4820 US
11 21.858178000 t4820 US Su
13 21.869826000 sched nsubmitted 50.000000
13 21.871714000 sched nready 47.000000
12 21.873380000 t4820 US
11 21.874588000 t4820 US Bu
12 21.875141000 t4820 US
11 21.875857000 t4820 US Su
13 21.876338000 sched nsubmitted 51.000000
13 21.877913000 sched nready 48.000000
12 21.879539000 t4820 US
11 21.881793000 t4820 US Bu
12 21.882314000 t4820 US
11 21.882905000 t4820 US Su
13 21.883477000 sched nsubmitted 52.000000
13 21.885019000 sched nready 49.000000
12 21.886537000 t4820 US
11 21.887403000 t4820 US Bu
12 21.887910000 t4820 US
11 21.888484000 t4820 US Su
13 21.888951000 sched nsubmitted 53.000000
13 21.890439000 sched nready 50.000000
12 21.891946000 t4820 US
11 21.892743000 t4820 US Bu
12 21.893241000 t4820 US
11 21.893806000 t4820 US Su
13 21.894271000 sched nsubmitted 54.000000
13 21.895756000 sched nready 51.000000
12 21.897273000 t4820 US
11 21.898045000 t4820 US Bu
12 21.898550000 t4820 US
11 21.899132000 t4820 US Su
13 21.899620000 sched nsubmitted 55.000000
13 21.901043000 sched nready 52.000000
12 21.902567000 t4820 US
11 21.904650000 t4820 US Bu
12 21.905196000 t4820 US
11 21.905790000 t4820 US Su
13 21.906267000 sched nsubmitted 56.000000
13 21.907821000 sched nready 53.000000
12 21.909449000 t4820 US
11 21.910289000 t4820 US Bu
12 21.910812000 t4820 US
11 21.911573000 t4820 US Su
13 21.912059000 sched nsubmitted 57.000000
13 21.913567000 sched nready 54.000000
12 21.915065000 t4820 US
11 21.915870000 t4820 US Bu
12 21.916397000 t4820 US
11 21.916974000 t4820 US Su
13 21.917445000 sched nsubmitted 58.000000
13 21.919018000 sched nready 55.000000
12 21.920577000 t4820 US
11 21.921360000 t4820 US Bu
12 21.921869000 t4820 US
11 21.923604000 t4820 US Su
13 21.924089000 sched nsubmitted 59.000000
13 21.925649000 sched nready 56.000000
12 21.927185000 t4820 US
11 21.928013000 t4820 US Bu
12 21.928516000 t4820 US
11 21.929084000 t4820 US Su
13 21.929550000 sched nsubmitted 60.000000
13 21.931130000 sched nready 57.000000
12 21.932641000 t4820 US
11 21.933471000 t4820 US Bu
12 21.933967000 t4820 US
11 21.934545000 t4820 US Su
13 21.935036000 sched nsubmitted 61.000000
13 21.936527000 sched nready 58.000000
12 21.938028000 t4820 US
11 21.938859000 t4820 US Bu
12 21.939373000 t4820 US
11 21.939961000 t4820 US Su
13 21.940444000 sched nsubmitted 62.000000
13 21.941950000 sched nready 59.000000
12 21.943449000 t4820 US
11 21.944265000 t4820 US Bu
12 21.944762000 t4820 US
11 21.948530000 t4820 US Su
13 21.949091000 sched nsubmitted 63.000000
13 21.950822000 sched nready 60.000000
12 21.952361000 t4820 US
11 21.953328000 t4820 US Bu
12 21.953864000 t4820 US
11 21.954468000 t4820 US Su
13 21.954932000 sched nsubmitted 64.000000
13 21.956430000 sched nready 61.000000
12 21.957969000 t4820 US
11 21.958805000 t4820 US Bu
12 21.959310000 t4820 US
11 21.959910000 t4820 US Su
13 21.960408000 sched nsubmitted 65.000000
13 21.961904000 sched nready 62.000000
12 21.963406000 t4820 US
11 21.964407000 t4820 US Bu
12 21.964910000 t4820 US
11 21.965499000 t4820 US Su
13 21.965989000 sched nsubmitted 66.000000
13 21.967523000 sched nready 63.000000
12 21.969067000 t4820 US
11 21.969917000 t4820 US Bu
12 21.970427000 t4820 US
11 21.972190000 t4820 US Su
13 21.972691000 sched nsubmitted 67.000000
13 21.974254000 sched nready 64.000000
12 21.975840000 t4820 US
11 21.976696000 t4820 US Bu
12 21.977195000 t4820 US
11 21.977765000 t4820 US Su
13 21.978251000 sched nsubmitted 68.000000
13 21.979787000 sched nready 65.000000
12 21.981313000 t4820 US
11 21.982127000 t4820 US Bu
12 21.982646000 t4820 US
11 21.983214000 t4820 US Su
13 21.983692000 sched nsubmitted 69.000000
13 21.985143000 sched nready 66.000000
12 21.986676000 t4820 US
11 21.987512000 t4820 US Bu
12 21.988013000 t4820 US
11 21.988576000 t4820 US Su
13 21.989077000 sched nsubmitted 70.000000
13 21.990558000 sched nready 67.000000
12 21.992153000 t4820 US
11 21.994123000 t4820 US Bu
12 21.994671000 t4820 US
11 21.995260000 t4820 US Su
13 21.995729000 sched nsubmitted 71.000000
13 21.997260000 sched nready 68.000000
12 21.998795000 t4820 US
11 21.999662000 t4820 US Bu
12 22.000198000 t4820 US
11 22.000746000 t4820 US Su
13 22.001217000 sched nsubmitted 72.000000
13 22.002718000 sched nready 69.000000
12 22.004279000 t4820 US
11 22.005126000 t4820 US Bu
12 22.005636000 t4820 US
11 22.006200000 t4820 US Su
13 22.006666000 sched nsubmitted 73.000000
13 22.008175000 sched nready 70.000000
12 22.009681000 t4820 US
11 22.010476000 t4820 US Bu
12 22.010976000 t4820 US
11 22.012827000 t4820 US Su
13 22.013332000 sched nsubmitted 74.000000
13 22.014917000 sched nready 71.000000
12 22.016548000 t4820 US
11 22.017410000 t4820 US Bu
12 22.017916000 t4820 US
11 22.018467000 t4820 US Su
13 22.019048000 sched nsubmitted 75.000000
13 22.020540000 sched nready 72.000000
12 22.022043000 t4820 US
11 22.022879000 t4820 US Bu
12 22.023418000 t4820 US
11 22.023979000 t4820 US Su
13 22.024448000 sched nsubmitted 76.000000
13 22.025909000 sched nready 73.000000
12 22.027398000 t4820 US
11 22.028205000 t4820 US Bu
12 22.028702000 t4820 US
11 22.029272000 t4820 US Su
13 22.029741000 sched nsubmitted 77.000000
13 22.031282000 sched nready 74.000000
12 22.032776000 t4820 US
11 22.033627000 t4820 US Bu
12 22.034129000 t4820 US
11 22.035907000 t4820 US Su
13 22.036384000 sched nsubmitted 78.000000
13 22.037903000 sched nready 75.000000
12 22.039406000 t4820 US
11 22.040290000 t4820 US Bu
12 22.040802000 t4820 US
11 22.041391000 t4820 US Su
13 22.041876000 sched nsubmitted 79.000000
13 22.043373000 sched nready 76.000000
12 22.044889000 t4820 US
11 22.045674000 t4820 US Bu
12 22.046221000 t4820 US
11 22.046794000 t4820 US Su
13 22.047250000 sched nsubmitted 80.000000
13 22.048716000 sched nready 77.000000
12 22.050235000 t4820 US
11 22.051037000 t4820 US Bu
12 22.051566000 t4820 US
11 22.052119000 t4820 US Su
13 22.052606000 sched nsubmitted 81.000000
13 22.054227000 sched nready 78.000000
12 22.055779000 t4820 US
11 22.056587000 t4820 US Bu
12 22.057096000 t4820 US
11 22.058854000 t4820 US Su
13 22.059368000 sched nsubmitted 82.000000
13 22.060957000 sched nready 79.000000
12 22.062496000 t4820 US
11 22.063388000 t4820 US Bu
12 22.063900000 t4820 US
11 22.064544000 t4820 US Su
13 22.065017000 sched nsubmitted 83.000000
13 22.066566000 sched nready 80.000000
12 22.068079000 t4820 US
11 22.068896000 t4820 US Bu
12 22.069424000 t4820 US
11 22.070013000 t4820 US Su
13 22.070486000 sched nsubmitted 84.000000
13 22.072027000 sched nready 81.000000
12 22.073548000 t4820 US
11 22.074365000 t4820 US Bu
12 22.074865000 t4820 US
11 22.075433000 t4820 US Su
13 22.075897000 sched nsubmitted 85.000000
13 22.077424000 sched nready 82.000000
12 22.078930000 t4820 US
11 22.080870000 t4820 US Bu
12 22.081405000 t4820 US
11 22.082019000 t4820 US Su
13 22.082487000 sched nsubmitted 86.000000
13 22.084013000 sched nready 83.000000
12 22.085535000 t4820 US
11 22.086397000 t4820 US Bu
12 22.086895000 t4820 US
11 22.087464000 t4820 US Su
13 22.087990000 sched nsubmitted 87.000000
13 22.089462000 sched nready 84.000000
12 22.090977000 t4820 US
11 22.091851000 t4820 US Bu
12 22.092342000 t4820 US
11 22.092901000 t4820 US Su
13 22.093361000 sched nsubmitted 88.000000
13 22.094832000 sched nready 85.000000
12 22.096344000 t4820 US
11 22.097148000 t4820 US Bu
12 22.097657000 t4820 US
11 22.100164000 t4820 US Su
13 22.100690000 sched nsubmitted 89.000000
13 22.102266000 sched nready 86.000000
12 22.103801000 t4820 US
11 22.104668000 t4820 US Bu
12 22.105208000 t4820 US
11 22.105772000 t4820 US Su
13 22.106289000 sched nsubmitted 90.000000
13 22.107774000 sched nready 87.000000
12 22.109281000 t4820 US
11 22.110115000 t4820 US Bu
12 22.110615000 t4820 US
11 22.111179000 t4820 US Su
13 22.111646000 sched nsubmitted 91.000000
13 22.113269000 sched nready 88.000000
12 22.114776000 t4820 US
11 22.115569000 t4820 US Bu
12 22.116084000 t4820 US
11 22.116679000 t4820 US Su
13 22.117154000 sched nsubmitted 92.000000
13 22.118697000 sched nready 89.000000
12 22.120213000 t4820 US
11 22.121016000 t4820 US Bu
12 22.121520000 t4820 US
11 22.123366000 t4820 US Su
13 22.123889000 sched nsubmitted 93.000000
13 22.125420000 sched nready 90.000000
12 22.126968000 t4820 US
11 22.127812000 t4820 US Bu
12 22.128320000 t4820 US
11 22.128887000 t4820 US Su
13 22.129366000 sched nsubmitted 94.000000
13 22.130862000 sched nready 91.000000
12 22.132411000 t4820 US
11 22.133210000 t4820 US Bu
12 22.133707000 t4820 US
11 22.134289000 t4820 US Su
13 22.134780000 sched nsubmitted 95.000000
13 22.136269000 sched nready 92.000000
12 22.137828000 t4820 US
11 22.138633000 t4820 US Bu
12 22.139131000 t4820 US
11 22.139712000 t4820 US Su
13 22.140180000 sched nsubmitted 96.000000
13 22.141751000 sched nready 93.000000
12 22.143296000 t4820 US
11 22.144133000 t4820 US Bu
12 22.144635000 t4820 US
11 22.146448000 t4820 US Su
13 22.146962000 sched nsubmitted 97.000000
13 22.148559000 sched nready 94.000000
12 22.150118000 t4820 US
11 22.151036000 t4820 US Bu
12 22.151573000 t4820 US
11 22.152150000 t4820 US Su
13 22.152635000 sched nsubmitted 98.000000
13 22.154214000 sched nready 95.000000
12 22.155752000 t4820 US
11 22.156618000 t4820 US Bu
12 22.157130000 t4820 US
11 22.157715000 t4820 US Su
13 22.158195000 sched nsubmitted 99.000000
13 22.159803000 sched nready 96.000000
12 22.161404000 t4820 US
11 22.162222000 t4820 US Bu
12 22.162731000 t4820 US
11 22.163292000 t4820 US Su
13 22.163768000 sched nsubmitted 100.000000
13 22.165376000 sched nready 97.000000
12 22.166908000 t4820 US
11 22.169810000 t4820 US Bu
12 22.170364000 t4820 US
11 22.170958000 t4820 US Su
13 22.171428000 sched nsubmitted 101.000000
13 22.173037000 sched nready 98.000000
12 22.174583000 t4820 US
11 22.175483000 t4820 US Bu
12 22.176003000 t4820 US
11 22.176560000 t4820 US Su
13 22.177047000 sched nsubmitted 102.000000
13 22.178656000 sched nready 99.000000
12 22.180176000 t4820 US
11 22.181018000 t4820 US Bu
12 22.181543000 t4820 US
11 22.182099000 t4820 US Su
13 22.182567000 sched nsubmitted 103.000000
13 22.184113000 sched nready 100.000000
12 22.185676000 t4820 US
11 22.186494000 t4820 US Bu
12 22.187083000 t4820 US
11 22.187660000 t4820 US Su
13 22.188131000 sched nsubmitted 104.000000
13 22.189670000 sched nready 101.000000
12 22.191191000 t4820 US
11 22.193170000 t4820 US Bu
12 22.193721000 t4820 US
11 22.194311000 t4820 US Su
13 22.194790000 sched nsubmitted 105.000000
13 22.196366000 sched nready 102.000000
12 22.197886000 t4820 US
11 22.198755000 t4820 US Bu
12 22.199288000 t4820 US
11 22.199863000 t4820 US Su
13 22.200458000 sched nsubmitted 106.000000
13 22.201910000 sched nready 103.000000
12 22.203461000 t4820 US
11 22.204346000 t4820 US Bu
12 22.204846000 t4820 US
11 22.205434000 t4820 US Su
13 22.205920000 sched nsubmitted 107.000000
13 22.207500000 sched nready 104.000000
12 22.209003000 t4820 US
11 22.209833000 t4820 US Bu
12 22.210337000 t4820 US
11 22.212114000 t4820 US Su
13 22.212616000 sched nsubmitted 108.000000
13 22.214102000 sched nready 105.000000
12 22.215622000 t4820 US
11 22.216444000 t4820 US Bu
12 22.216988000 t4820 US
11 22.217555000 t4820 US Su
13 22.218024000 sched nsubmitted 109.000000
13 22.219629000 sched nready 106.000000
12 22.221158000 t4820 US
11 22.221984000 t4820 US Bu
12 22.222511000 t4820 US
11 22.223093000 t4820 US Su
13 22.223566000 sched nsubmitted 110.000000
13 22.225172000 sched nready 107.000000
12 22.226760000 t4820 US
11 22.227570000 t4820 US Bu
12 22.228100000 t4820 US
11 22.228667000 t4820 US Su
13 22.229141000 sched nsubmitted 111.000000
13 22.230605000 sched nready 108.000000
12 22.232110000 t4820 US
11 22.232921000 t4820 US Bu
12 22.233401000 t4820 US
11 22.235250000 t4820 US Su
13 22.235745000 sched nsubmitted 112.000000
13 22.237314000 sched nready 109.000000
12 22.238826000 t4820 US
11 22.239685000 t4820 US Bu
12 22.240189000 t4820 US
11 22.240759000 t4820 US Su
13 22.241228000 sched nsubmitted 113.000000
13 22.242777000 sched nready 110.000000
12 22.244310000 t4820 US
11 22.245129000 t4820 US Bu
12 22.245708000 t4820 US
11 22.246303000 t4820 US Su
13 22.246800000 sched nsubmitted 114.000000
13 22.248505000 sched nready 111.000000
10 22.250023000 w5 WS "B"
13 21.554228000 w5 gf 0.000000
13 22.250023000 w5 gf 0.000000
13 21.554228000 sched gft 0.000000
12 22.250103000 t4820 US
10 22.250973000 w5 WS "Po"
11 22.251385000 t4820 US Bu
12 22.251895000 t4820 US
10 22.252246000 w5 WS "B"
11 22.252690000 t4820 US Su
13 22.253160000 sched nsubmitted 115.000000
13 22.255328000 sched nready 112.000000
10 22.256209000 w5 WS "P"
12 22.257068000 t4820 US
10 22.257407000 w5 WS "Sc"
13 22.258296000 sched nready 111.000000
13 22.258296000 sched nsubmitted 114.000000
10 22.258863000 w5 WS "B"
10 22.259377000 w5 WS "B"
10 22.260058000 w5 WS "Fi"
11 22.260066000 t4820 US Bu
12 22.260796000 t4820 US
10 22.261290000 w5 WS "B"
11 22.261635000 t4820 US Su
13 22.262120000 sched nsubmitted 115.000000
6 B22_5 WS B22_5 "0.000000 0.600000 0.400000"
6 B22_5_1 Ctx1 B22_5 "1.0 0.39 1.0"
6 B22_5_2 Ctx2 B22_5 ".0 1.0 .0"
6 B22_5_3 Ctx3 B22_5 "0.87 0.87 .0"
6 B22_5_4 Ctx4 B22_5 ".0 0.95 1.0"
6 B22_5_5 Ctx5 B22_5 ".0 .0 .0"
6 B22_5_6 Ctx6 B22_5 ".0 .0 0.5"
6 B22_5_7 Ctx7 B22_5 "0.41 0.41 0.41"
6 B22_5_8 Ctx8 B22_5 "1.0 .0 1.0"
6 B22_5_9 Ctx9 B22_5 ".0 .0 1.0"
10 22.262135000 w5 WS "B22_5"
13 22.263851000 sched nready 112.000000
20 22.262135000 w5 WS B22_5 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 30
12 22.265599000 t4820 US
11 22.266463000 t4820 US Bu
12 22.266974000 t4820 US
11 22.267555000 t4820 US Su
13 22.268039000 sched nsubmitted 116.000000
13 22.269600000 sched nready 113.000000
12 22.271132000 t4820 US
11 22.271934000 t4820 US Bu
12 22.272442000 t4820 US
11 22.272999000 t4820 US Su
13 22.273474000 sched nsubmitted 117.000000
13 22.274922000 sched nready 114.000000
12 22.276434000 t4820 US
11 22.277227000 t4820 US Bu
12 22.277747000 t4820 US
11 22.278318000 t4820 US Su
13 22.278791000 sched nsubmitted 118.000000
13 22.280349000 sched nready 115.000000
12 22.281877000 t4820 US
11 22.283876000 t4820 US Bu
12 22.284414000 t4820 US
11 22.285018000 t4820 US Su
13 22.285485000 sched nsubmitted 119.000000
13 22.287027000 sched nready 116.000000
12 22.288578000 t4820 US
11 22.289409000 t4820 US Bu
12 22.289920000 t4820 US
11 22.290480000 t4820 US Su
13 22.290955000 sched nsubmitted 120.000000
13 22.292568000 sched nready 117.000000
12 22.294083000 t4820 US
11 22.294886000 t4820 US Bu
12 22.295384000 t4820 US
11 22.295955000 t4820 US Su
13 22.296418000 sched nsubmitted 121.000000
13 22.297901000 sched nready 118.000000
12 22.299411000 t4820 US
11 22.300298000 t4820 US Bu
12 22.300797000 t4820 US
11 22.302480000 t4820 US Su
13 22.302979000 sched nsubmitted 122.000000
13 22.304475000 sched nready 119.000000
12 22.306006000 t4820 US
11 22.306882000 t4820 US Bu
12 22.307390000 t4820 US
11 22.307956000 t4820 US Su
13 22.308433000 sched nsubmitted 123.000000
13 22.309959000 sched nready 120.000000
12 22.311482000 t4820 US
11 22.312295000 t4820 US Bu
12 22.312805000 t4820 US
11 22.313357000 t4820 US Su
13 22.313824000 sched nsubmitted 124.000000
13 22.315382000 sched nready 121.000000
12 22.316897000 t4820 US
11 22.317727000 t4820 US Bu
12 22.318239000 t4820 US
11 22.318791000 t4820 US Su
13 22.319276000 sched nsubmitted 125.000000
13 22.320722000 sched nready 122.000000
12 22.322222000 t4820 US
11 22.323024000 t4820 US Bu
12 22.323534000 t4820 US
11 22.325262000 t4820 US Su
13 22.325759000 sched nsubmitted 126.000000
13 22.327254000 sched nready 123.000000
12 22.328801000 t4820 US
11 22.329628000 t4820 US Bu
12 22.330134000 t4820 US
11 22.330688000 t4820 US Su
13 22.331159000 sched nsubmitted 127.000000
13 22.332728000 sched nready 124.000000
12 22.334250000 t4820 US
11 22.335047000 t4820 US Bu
12 22.335554000 t4820 US
11 22.336098000 t4820 US Su
13 22.336577000 sched nsubmitted 128.000000
13 22.338074000 sched nready 125.000000
12 22.339599000 t4820 US
11 22.340390000 t4820 US Bu
12 22.340906000 t4820 US
11 22.341454000 t4820 US Su
13 22.341925000 sched nsubmitted 129.000000
13 22.343448000 sched nready 126.000000
12 22.344959000 t4820 US
11 22.345808000 t4820 US Bu
12 22.346328000 t4820 US
11 22.348068000 t4820 US Su
13 22.348557000 sched nsubmitted 130.000000
13 22.350122000 sched nready 127.000000
12 22.351658000 t4820 US
11 22.352486000 t4820 US Bu
12 22.353004000 t4820 US
11 22.353587000 t4820 US Su
13 22.354062000 sched nsubmitted 131.000000
13 22.355591000 sched nready 128.000000
12 22.357102000 t4820 US
11 22.357908000 t4820 US Bu
12 22.358418000 t4820 US
11 22.358976000 t4820 US Su
13 22.359444000 sched nsubmitted 132.000000
13 22.360904000 sched nready 129.000000
12 22.362418000 t4820 US
11 22.363220000 t4820 US Bu
12 22.363732000 t4820 US
11 22.364286000 t4820 US Su
13 22.364762000 sched nsubmitted 133.000000
13 22.366206000 sched nready 130.000000
12 22.367720000 t4820 US
11 22.369666000 t4820 US Bu
12 22.370203000 t4820 US
11 22.370774000 t4820 US Su
13 22.371252000 sched nsubmitted 134.000000
13 22.372975000 sched nready 131.000000
12 22.374516000 t4820 US
11 22.375333000 t4820 US Bu
12 22.375853000 t4820 US
11 22.376409000 t4820 US Su
13 22.376881000 sched nsubmitted 135.000000
13 22.378325000 sched nready 132.000000
12 22.379850000 t4820 US
11 22.380638000 t4820 US Bu
12 22.381143000 t4820 US
11 22.381695000 t4820 US Su
13 22.382161000 sched nsubmitted 136.000000
13 22.383625000 sched nready 133.000000
12 22.385159000 t4820 US
11 22.385964000 t4820 US Bu
12 22.386469000 t4820 US
11 22.388179000 t4820 US Su
13 22.388657000 sched nsubmitted 137.000000
13 22.390173000 sched nready 134.000000
12 22.391686000 t4820 US
11 22.392515000 t4820 US Bu
12 22.393024000 t4820 US
11 22.393581000 t4820 US Su
13 22.394045000 sched nsubmitted 138.000000
13 22.395505000 sched nready 135.000000
12 22.397015000 t4820 US
11 22.397804000 t4820 US Bu
12 22.398308000 t4820 US
11 22.398868000 t4820 US Su
13 22.399334000 sched nsubmitted 139.000000
13 22.400914000 sched nready 136.000000
12 22.402419000 t4820 US
11 22.403210000 t4820 US Bu
12 22.403711000 t4820 US
11 22.404270000 t4820 US Su
13 22.404737000 sched nsubmitted 140.000000
13 22.406195000 sched nready 137.000000
12 22.407724000 t4820 US
11 22.408532000 t4820 US Bu
12 22.409048000 t4820 US
11 22.410798000 t4820 US Su
13 22.411293000 sched nsubmitted 141.000000
13 22.412910000 sched nready 138.000000
12 22.414464000 t4820 US
11 22.415285000 t4820 US Bu
12 22.415805000 t4820 US
11 22.416365000 t4820 US Su
13 22.416834000 sched nsubmitted 142.000000
13 22.418289000 sched nready 139.000000
12 22.419793000 t4820 US
11 22.420608000 t4820 US Bu
12 22.421111000 t4820 US
11 22.421679000 t4820 US Su
13 22.422143000 sched nsubmitted 143.000000
13 22.423678000 sched nready 140.000000
12 22.425193000 t4820 US
11 22.426016000 t4820 US Bu
12 22.426530000 t4820 US
11 22.427094000 t4820 US Su
13 22.427562000 sched nsubmitted 144.000000
13 22.429162000 sched nready 141.000000
12 22.430667000 t4820 US
11 22.431445000 t4820 US Bu
12 22.431948000 t4820 US
11 22.433669000 t4820 US Su
13 22.434155000 sched nsubmitted 145.000000
13 22.435663000 sched nready 142.000000
12 22.437189000 t4820 US
11 22.438018000 t4820 US Bu
12 22.438527000 t4820 US
11 22.439082000 t4820 US Su
13 22.439549000 sched nsubmitted 146.000000
13 22.441242000 sched nready 143.000000
12 22.442740000 t4820 US
11 22.443528000 t4820 US Bu
12 22.444030000 t4820 US
11 22.444595000 t4820 US Su
13 22.445071000 sched nsubmitted 147.000000
13 22.446545000 sched nready 144.000000
12 22.448064000 t4820 US
11 22.448868000 t4820 US Bu
12 22.449383000 t4820 US
11 22.449938000 t4820 US Su
13 22.450413000 sched nsubmitted 148.000000
13 22.451927000 sched nready 145.000000
12 22.453441000 t4820 US
11 22.455382000 t4820 US Bu
12 22.455906000 t4820 US
11 22.456479000 t4820 US Su
13 22.456958000 sched nsubmitted 149.000000
13 22.458463000 sched nready 146.000000
12 22.459974000 t4820 US
11 22.460804000 t4820 US Bu
12 22.461314000 t4820 US
11 22.461890000 t4820 US Su
13 22.462361000 sched nsubmitted 150.000000
13 22.463811000 sched nready 147.000000
12 22.465311000 t4820 US
11 22.466122000 t4820 US Bu
12 22.466630000 t4820 US
11 22.467194000 t4820 US Su
13 22.467662000 sched nsubmitted 151.000000
13 22.469164000 sched nready 148.000000
12 22.470669000 t4820 US
11 22.471480000 t4820 US Bu
12 22.471991000 t4820 US
11 22.474487000 t4820 US Su
13 22.474974000 sched nsubmitted 152.000000
13 22.476450000 sched nready 149.000000
12 22.477985000 t4820 US
11 22.478838000 t4820 US Bu
12 22.479328000 t4820 US
11 22.479880000 t4820 US Su
13 22.480357000 sched nsubmitted 153.000000
13 22.482247000 sched nready 150.000000
12 22.483749000 t4820 US
11 22.484545000 t4820 US Bu
12 22.485049000 t4820 US
11 22.485605000 t4820 US Su
13 22.486071000 sched nsubmitted 154.000000
13 22.487527000 sched nready 151.000000
12 22.489051000 t4820 US
11 22.489856000 t4820 US Bu
12 22.490367000 t4820 US
11 22.490936000 t4820 US Su
13 22.491450000 sched nsubmitted 155.000000
13 22.492995000 sched nready 152.000000
12 22.494494000 t4820 US
11 22.495277000 t4820 US Bu
12 22.495783000 t4820 US
11 22.497502000 t4820 US Su
13 22.497998000 sched nsubmitted 156.000000
13 22.499471000 sched nready 153.000000
12 22.500998000 t4820 US
11 22.501823000 t4820 US Bu
12 22.502338000 t4820 US
11 22.502890000 t4820 US Su
13 22.503375000 sched nsubmitted 157.000000
13 22.504895000 sched nready 154.000000
12 22.506415000 t4820 US
11 22.507207000 t4820 US Bu
12 22.507714000 t4820 US
11 22.508275000 t4820 US Su
13 22.508746000 sched nsubmitted 158.000000
13 22.510266000 sched nready 155.000000
12 22.511785000 t4820 US
11 22.512586000 t4820 US Bu
12 22.513091000 t4820 US
11 22.513715000 t4820 US Su
13 22.514190000 sched nsubmitted 159.000000
13 22.515664000 sched nready 156.000000
12 22.517185000 t4820 US
11 22.518001000 t4820 US Bu
12 22.518509000 t4820 US
11 22.520230000 t4820 US Su
13 22.520727000 sched nsubmitted 160.000000
13 22.522321000 sched nready 157.000000
12 22.523842000 t4820 US
11 22.524654000 t4820 US Bu
12 22.525161000 t4820 US
11 22.525723000 t4820 US Su
13 22.526195000 sched nsubmitted 161.000000
13 22.527662000 sched nready 158.000000
12 22.529166000 t4820 US
11 22.529982000 t4820 US Bu
12 22.530475000 t4820 US
11 22.531040000 t4820 US Su
13 22.531514000 sched nsubmitted 162.000000
13 22.533103000 sched nready 159.000000
12 22.534623000 t4820 US
11 22.535403000 t4820 US Bu
12 22.535913000 t4820 US
11 22.536475000 t4820 US Su
13 22.536944000 sched nsubmitted 163.000000
13 22.554323000 sched nready 160.000000
12 22.555763000 t4820 US
11 22.557633000 t4820 US Bu
12 22.558125000 t4820 US
11 22.558663000 t4820 US Su
13 22.559114000 sched nsubmitted 164.000000
13 22.560644000 sched nready 161.000000
12 22.562081000 t4820 US
11 22.562861000 t4820 US Bu
12 22.563346000 t4820 US
11 22.563877000 t4820 US Su
13 22.564327000 sched nsubmitted 165.000000
13 22.565820000 sched nready 162.000000
12 22.567279000 t4820 US
11 22.568030000 t4820 US Bu
12 22.568504000 t4820 US
11 22.569040000 t4820 US Su
13 22.569487000 sched nsubmitted 166.000000
13 22.570901000 sched nready 163.000000
12 22.572349000 t4820 US
11 22.573128000 t4820 US Bu
12 22.573604000 t4820 US
11 22.574185000 t4820 US Su
13 22.574634000 sched nsubmitted 167.000000
13 22.576459000 sched nready 164.000000
12 22.577901000 t4820 US
11 22.579749000 t4820 US Bu
12 22.580253000 t4820 US
11 22.580811000 t4820 US Su
13 22.581258000 sched nsubmitted 168.000000
13 22.582802000 sched nready 165.000000
12 22.584249000 t4820 US
11 22.585031000 t4820 US Bu
12 22.585519000 t4820 US
11 22.586057000 t4820 US Su
13 22.586499000 sched nsubmitted 169.000000
13 22.587952000 sched nready 166.000000
12 22.589390000 t4820 US
11 22.590144000 t4820 US Bu
12 22.590639000 t4820 US
11 22.591189000 t4820 US Su
13 22.591632000 sched nsubmitted 170.000000
13 22.593076000 sched nready 167.000000
12 22.594519000 t4820 US
11 22.595276000 t4820 US Bu
12 22.595763000 t4820 US
11 22.597378000 t4820 US Su
13 22.597835000 sched nsubmitted 171.000000
13 22.599244000 sched nready 168.000000
12 22.600703000 t4820 US
11 22.601518000 t4820 US Bu
12 22.602001000 t4820 US
11 22.602539000 t4820 US Su
13 22.602984000 sched nsubmitted 172.000000
13 22.604445000 sched nready 169.000000
12 22.605891000 t4820 US
11 22.606649000 t4820 US Bu
12 22.607128000 t4820 US
11 22.607668000 t4820 US Su
13 22.608117000 sched nsubmitted 173.000000
13 22.609507000 sched nready 170.000000
12 22.610965000 t4820 US
11 22.611715000 t4820 US Bu
12 22.612202000 t4820 US
11 22.612736000 t4820 US Su
13 22.613176000 sched nsubmitted 174.000000
13 22.614999000 sched nready 171.000000
12 22.616432000 t4820 US
11 22.617194000 t4820 US Bu
12 22.617689000 t4820 US
11 22.619327000 t4820 US Su
13 22.619794000 sched nsubmitted 175.000000
13 22.621240000 sched nready 172.000000
12 22.622705000 t4820 US
11 22.623486000 t4820 US Bu
12 22.623970000 t4820 US
11 22.624505000 t4820 US Su
13 22.624952000 sched nsubmitted 176.000000
13 22.626437000 sched nready 173.000000
12 22.627883000 t4820 US
11 22.628664000 t4820 US Bu
12 22.629153000 t4820 US
11 22.629681000 t4820 US Su
13 22.630125000 sched nsubmitted 177.000000
13 22.631566000 sched nready 174.000000
12 22.633038000 t4820 US
11 22.633808000 t4820 US Bu
12 22.634291000 t4820 US
11 22.634829000 t4820 US Su
13 22.635276000 sched nsubmitted 178.000000
13 22.636689000 sched nready 175.000000
12 22.638131000 t4820 US
11 22.639971000 t4820 US Bu
12 22.640502000 t4820 US
11 22.641050000 t4820 US Su
13 22.641495000 sched nsubmitted 179.000000
13 22.642972000 sched nready 176.000000
12 22.644415000 t4820 US
11 22.645214000 t4820 US Bu
12 22.645688000 t4820 US
11 22.646227000 t4820 US Su
13 22.646676000 sched nsubmitted 180.000000
13 22.648072000 sched nready 177.000000
12 22.649514000 t4820 US
11 22.650265000 t4820 US Bu
12 22.650744000 t4820 US
11 22.651279000 t4820 US Su
13 22.651729000 sched nsubmitted 181.000000
13 22.653195000 sched nready 178.000000
12 22.654648000 t4820 US
11 22.655402000 t4820 US Bu
12 22.655884000 t4820 US
11 22.656439000 t4820 US Su
13 22.656885000 sched nsubmitted 182.000000
13 22.658297000 sched nready 179.000000
12 22.659728000 t4820 US
11 22.661823000 t4820 US Bu
12 22.662329000 t4820 US
11 22.662878000 t4820 US Su
13 22.663340000 sched nsubmitted 183.000000
13 22.664811000 sched nready 180.000000
12 22.666264000 t4820 US
11 22.667040000 t4820 US Bu
12 22.667530000 t4820 US
11 22.668114000 t4820 US Su
13 22.668575000 sched nsubmitted 184.000000
13 22.669958000 sched nready 181.000000
12 22.671401000 t4820 US
11 22.672157000 t4820 US Bu
12 22.672656000 t4820 US
11 22.673194000 t4820 US Su
13 22.673644000 sched nsubmitted 185.000000
13 22.675045000 sched nready 182.000000
12 22.676487000 t4820 US
11 22.677267000 t4820 US Bu
12 22.677749000 t4820 US
11 22.680678000 t4820 US Su
13 22.681163000 sched nsubmitted 186.000000
13 22.682795000 sched nready 183.000000
12 22.684270000 t4820 US
11 22.685154000 t4820 US Bu
12 22.685651000 t4820 US
11 22.686195000 t4820 US Su
13 22.686641000 sched nsubmitted 187.000000
13 22.688082000 sched nready 184.000000
12 22.689528000 t4820 US
11 22.690301000 t4820 US Bu
12 22.690780000 t4820 US
11 22.691333000 t4820 US Su
13 22.691782000 sched nsubmitted 188.000000
13 22.693236000 sched nready 185.000000
12 22.694678000 t4820 US
11 22.695442000 t4820 US Bu
12 22.695931000 t4820 US
11 22.696470000 t4820 US Su
13 22.696919000 sched nsubmitted 189.000000
13 22.698319000 sched nready 186.000000
12 22.699770000 t4820 US
11 22.700536000 t4820 US Bu
12 22.701017000 t4820 US
11 22.702607000 t4820 US Su
13 22.703082000 sched nsubmitted 190.000000
13 22.704587000 sched nready 187.000000
12 22.706032000 t4820 US
11 22.706873000 t4820 US Bu
12 22.707367000 t4820 US
11 22.707900000 t4820 US Su
13 22.708351000 sched nsubmitted 191.000000
13 22.709724000 sched nready 188.000000
12 22.711165000 t4820 US
11 22.711922000 t4820 US Bu
12 22.712400000 t4820 US
11 22.712929000 t4820 US Su
13 22.713372000 sched nsubmitted 192.000000
13 22.714803000 sched nready 189.000000
12 22.716252000 t4820 US
11 22.716997000 t4820 US Bu
12 22.717486000 t4820 US
11 22.718030000 t4820 US Su
13 22.718477000 sched nsubmitted 193.000000
13 22.719933000 sched nready 190.000000
12 22.721375000 t4820 US
11 22.722178000 t4820 US Bu
12 22.722661000 t4820 US
11 22.724354000 t4820 US Su
13 22.724820000 sched nsubmitted 194.000000
13 22.726318000 sched nready 191.000000
12 22.727782000 t4820 US
11 22.728558000 t4820 US Bu
12 22.729044000 t4820 US
11 22.729571000 t4820 US Su
13 22.730017000 sched nsubmitted 195.000000
13 22.731473000 sched nready 192.000000
12 22.732922000 t4820 US
11 22.733693000 t4820 US Bu
12 22.734168000 t4820 US
11 22.734697000 t4820 US Su
13 22.735145000 sched nsubmitted 196.000000
13 22.736608000 sched nready 193.000000
12 22.738058000 t4820 US
11 22.738823000 t4820 US Bu
12 22.739310000 t4820 US
11 22.739837000 t4820 US Su
13 22.740288000 sched nsubmitted 197.000000
13 22.741744000 sched nready 194.000000
12 22.743182000 t4820 US
11 22.745013000 t4820 US Bu
12 22.745519000 t4820 US
11 22.746074000 t4820 US Su
13 22.746519000 sched nsubmitted 198.000000
13 22.747988000 sched nready 195.000000
12 22.749453000 t4820 US
11 22.750224000 t4820 US Bu
12 22.750702000 t4820 US
11 22.751244000 t4820 US Su
13 22.751692000 sched nsubmitted 199.000000
13 22.753162000 sched nready 196.000000
12 22.754593000 t4820 US
11 22.755367000 t4820 US Bu
12 22.755850000 t4820 US
11 22.756382000 t4820 US Su
13 22.756826000 sched nsubmitted 200.000000
13 22.758274000 sched nready 197.000000
12 22.759719000 t4820 US
11 22.760483000 t4820 US Bu
12 22.760962000 t4820 US
11 22.762590000 t4820 US Su
13 22.763047000 sched nsubmitted 201.000000
13 22.764507000 sched nready 198.000000
12 22.765964000 t4820 US
11 22.766772000 t4820 US Bu
12 22.767254000 t4820 US
11 22.767789000 t4820 US Su
13 22.768236000 sched nsubmitted 202.000000
13 22.769777000 sched nready 199.000000
12 22.771275000 t4820 US
11 22.772030000 t4820 US Bu
12 22.772505000 t4820 US
11 22.773035000 t4820 US Su
13 22.773483000 sched nsubmitted 203.000000
13 22.774929000 sched nready 200.000000
12 22.776373000 t4820 US
11 22.777135000 t4820 US Bu
12 22.777618000 t4820 US
11 22.778152000 t4820 US Su
13 22.778595000 sched nsubmitted 204.000000
13 22.780174000 sched nready 201.000000
12 22.781623000 t4820 US
11 22.782383000 t4820 US Bu
12 22.782850000 t4820 US
11 22.786007000 t4820 US Su
13 22.786481000 sched nsubmitted 205.000000
13 22.787902000 sched nready 202.000000
12 22.789360000 t4820 US
11 22.790160000 t4820 US Bu
12 22.790641000 t4820 US
11 22.791180000 t4820 US Su
13 22.791628000 sched nsubmitted 206.000000
13 22.793096000 sched nready 203.000000
12 22.794540000 t4820 US
11 22.795298000 t4820 US Bu
12 22.795783000 t4820 US
11 22.796329000 t4820 US Su
13 22.796775000 sched nsubmitted 207.000000
13 22.798166000 sched nready 204.000000
12 22.799625000 t4820 US
11 22.800397000 t4820 US Bu
12 22.800859000 t4820 US
11 22.801395000 t4820 US Su
13 22.801840000 sched nsubmitted 208.000000
13 22.803331000 sched nready 205.000000
12 22.804770000 t4820 US
11 22.805541000 t4820 US Bu
12 22.806014000 t4820 US
11 22.807645000 t4820 US Su
13 22.808126000 sched nsubmitted 209.000000
13 22.809592000 sched nready 206.000000
12 22.811031000 t4820 US
11 22.811823000 t4820 US Bu
12 22.812303000 t4820 US
11 22.812834000 t4820 US Su
13 22.813281000 sched nsubmitted 210.000000
13 22.814736000 sched nready 207.000000
12 22.816172000 t4820 US
11 22.816945000 t4820 US Bu
12 22.817422000 t4820 US
11 22.817954000 t4820 US Su
13 22.818406000 sched nsubmitted 211.000000
13 22.819983000 sched nready 208.000000
12 22.821423000 t4820 US
11 22.822200000 t4820 US Bu
12 22.822677000 t4820 US
11 22.823211000 t4820 US Su
13 22.823656000 sched nsubmitted 212.000000
13 22.825108000 sched nready 209.000000
12 22.826556000 t4820 US
11 22.828411000 t4820 US Bu
12 22.828906000 t4820 US
11 22.829460000 t4820 US Su
13 22.829915000 sched nsubmitted 213.000000
13 22.831393000 sched nready 210.000000
12 22.832850000 t4820 US
11 22.833653000 t4820 US Bu
12 22.834137000 t4820 US
11 22.834683000 t4820 US Su
13 22.835139000 sched nsubmitted 214.000000
13 22.836581000 sched nready 211.000000
12 22.838119000 t4820 US
11 22.838893000 t4820 US Bu
12 22.839391000 t4820 US
11 22.839918000 t4820 US Su
13 22.840371000 sched nsubmitted 215.000000
13 22.841773000 sched nready 212.000000
12 22.843212000 t4820 US
11 22.843972000 t4820 US Bu
12 22.844458000 t4820 US
11 22.846107000 t4820 US Su
13 22.846564000 sched nsubmitted 216.000000
13 22.848076000 sched nready 213.000000
12 22.849529000 t4820 US
11 22.850301000 t4820 US Bu
12 22.850791000 t4820 US
11 22.851320000 t4820 US Su
13 22.851770000 sched nsubmitted 217.000000
13 22.853270000 sched nready 214.000000
12 22.854728000 t4820 US
11 22.855520000 t4820 US Bu
12 22.856006000 t4820 US
11 22.856541000 t4820 US Su
13 22.856993000 sched nsubmitted 218.000000
13 22.858439000 sched nready 215.000000
12 22.859876000 t4820 US
11 22.860645000 t4820 US Bu
12 22.861125000 t4820 US
11 22.861661000 t4820 US Su
13 22.862116000 sched nsubmitted 219.000000
13 22.863519000 sched nready 216.000000
12 22.864987000 t4820 US
11 22.865738000 t4820 US Bu
12 22.866232000 t4820 US
11 22.867867000 t4820 US Su
13 22.868333000 sched nsubmitted 220.000000
13 22.869803000 sched nready 217.000000
12 22.871274000 t4820 US
11 22.872036000 t4820 US Bu
12 22.872525000 t4820 US
11 22.873068000 t4820 US Su
13 22.873518000 sched nsubmitted 221.000000
13 22.874971000 sched nready 218.000000
12 22.876403000 t4820 US
11 22.877157000 t4820 US Bu
12 22.877642000 t4820 US
11 22.878177000 t4820 US Su
13 22.878626000 sched nsubmitted 222.000000
13 22.880119000 sched nready 219.000000
12 22.881558000 t4820 US
11 22.882320000 t4820 US Bu
12 22.882806000 t4820 US
11 22.883337000 t4820 US Su
13 22.883784000 sched nsubmitted 223.000000
13 22.885300000 sched nready 220.000000
12 22.886740000 t4820 US
11 22.887507000 t4820 US Bu
12 22.887995000 t4820 US
11 22.889613000 t4820 US Su
13 22.890079000 sched nsubmitted 224.000000
13 22.891494000 sched nready 221.000000
12 22.892952000 t4820 US
11 22.893754000 t4820 US Bu
12 22.894254000 t4820 US
11 22.894782000 t4820 US Su
13 22.895235000 sched nsubmitted 225.000000
13 22.896668000 sched nready 222.000000
12 22.898131000 t4820 US
11 22.898912000 t4820 US Bu
12 22.899401000 t4820 US
11 22.899937000 t4820 US Su
13 22.900390000 sched nsubmitted 226.000000
13 22.901833000 sched nready 223.000000
12 22.903300000 t4820 US
11 22.904070000 t4820 US Bu
12 22.904560000 t4820 US
11 22.905092000 t4820 US Su
13 22.905533000 sched nsubmitted 227.000000
13 22.906976000 sched nready 224.000000
12 22.908431000 t4820 US
11 22.910297000 t4820 US Bu
12 22.910796000 t4820 US
11 22.911345000 t4820 US Su
13 22.911795000 sched nsubmitted 228.000000
13 22.913202000 sched nready 225.000000
12 22.914645000 t4820 US
11 22.915463000 t4820 US Bu
12 22.915956000 t4820 US
11 22.916504000 t4820 US Su
13 22.916947000 sched nsubmitted 229.000000
13 22.918418000 sched nready 226.000000
12 22.919864000 t4820 US
11 22.920643000 t4820 US Bu
12 22.921144000 t4820 US
11 22.921681000 t4820 US Su
13 22.922126000 sched nsubmitted 230.000000
13 22.923634000 sched nready 227.000000
12 22.925077000 t4820 US
11 22.925834000 t4820 US Bu
12 22.926322000 t4820 US
11 22.926855000 t4820 US Su
13 22.927300000 sched nsubmitted 231.000000
13 22.928696000 sched nready 228.000000
12 22.930131000 t4820 US
11 22.931953000 t4820 US Bu
12 22.932440000 t4820 US
11 22.932979000 t4820 US Su
13 22.933424000 sched nsubmitted 232.000000
13 22.935227000 sched nready 229.000000
12 22.936679000 t4820 US
11 22.937456000 t4820 US Bu
12 22.937939000 t4820 US
11 22.938470000 t4820 US Su
13 22.938915000 sched nsubmitted 233.000000
13 22.940300000 sched nready 230.000000
12 22.941740000 t4820 US
11 22.942493000 t4820 US Bu
12 22.942986000 t4820 US
11 22.943519000 t4820 US Su
13 22.943963000 sched nsubmitted 234.000000
13 22.945436000 sched nready 231.000000
12 22.946881000 t4820 US
11 22.947650000 t4820 US Bu
12 22.948135000 t4820 US
11 22.949750000 t4820 US Su
13 22.950211000 sched nsubmitted 235.000000
13 22.951619000 sched nready 232.000000
12 22.953072000 t4820 US
11 22.953872000 t4820 US Bu
12 22.954364000 t4820 US
11 22.954896000 t4820 US Su
13 22.955341000 sched nsubmitted 236.000000
13 22.957135000 sched nready 233.000000
12 22.958584000 t4820 US
11 22.959358000 t4820 US Bu
12 22.959842000 t4820 US
11 22.960377000 t4820 US Su
13 22.960822000 sched nsubmitted 237.000000
13 22.962311000 sched nready 234.000000
12 22.963755000 t4820 US
11 22.964500000 t4820 US Bu
12 22.964988000 t4820 US
11 22.965520000 t4820 US Su
13 22.965971000 sched nsubmitted 238.000000
13 22.967546000 sched nready 235.000000
12 22.968989000 t4820 US
11 22.969733000 t4820 US Bu
12 22.970221000 t4820 US
11 22.971842000 t4820 US Su
13 22.972315000 sched nsubmitted 239.000000
13 22.973801000 sched nready 236.000000
12 22.975266000 t4820 US
11 22.976060000 t4820 US Bu
12 22.976549000 t4820 US
11 22.977086000 t4820 US Su
13 22.977540000 sched nsubmitted 240.000000
13 22.978923000 sched nready 237.000000
12 22.980366000 t4820 US
11 22.981124000 t4820 US Bu
12 22.981614000 t4820 US
11 22.982145000 t4820 US Su
13 22.982590000 sched nsubmitted 241.000000
13 22.984117000 sched nready 238.000000
12 22.985569000 t4820 US
11 22.986320000 t4820 US Bu
12 22.986819000 t4820 US
11 22.987371000 t4820 US Su
13 22.987825000 sched nsubmitted 242.000000
13 22.989203000 sched nready 239.000000
12 22.990640000 t4820 US
11 22.992517000 t4820 US Bu
12 22.993021000 t4820 US
11 22.993572000 t4820 US Su
13 22.994022000 sched nsubmitted 243.000000
13 22.995493000 sched nready 240.000000
12 22.996957000 t4820 US
11 22.997735000 t4820 US Bu
12 22.998227000 t4820 US
11 22.998768000 t4820 US Su
13 22.999215000 sched nsubmitted 244.000000
13 23.000646000 sched nready 241.000000
12 23.002077000 t4820 US
11 23.002835000 t4820 US Bu
12 23.003317000 t4820 US
11 23.003869000 t4820 US Su
13 23.004309000 sched nsubmitted 245.000000
13 23.005891000 sched nready 242.000000
12 23.007322000 t4820 US
11 23.008076000 t4820 US Bu
12 23.008564000 t4820 US
11 23.009095000 t4820 US Su
13 23.009549000 sched nsubmitted 246.000000
13 23.011021000 sched nready 243.000000
12 23.012454000 t4820 US
11 23.014291000 t4820 US Bu
12 23.014798000 t4820 US
11 23.015343000 t4820 US Su
13 23.015792000 sched nsubmitted 247.000000
13 23.017245000 sched nready 244.000000
12 23.018700000 t4820 US
11 23.019484000 t4820 US Bu
12 23.019969000 t4820 US
11 23.020515000 t4820 US Su
13 23.020968000 sched nsubmitted 248.000000
13 23.022496000 sched nready 245.000000
12 23.023951000 t4820 US
11 23.024722000 t4820 US Bu
12 23.025207000 t4820 US
11 23.025761000 t4820 US Su
13 23.026209000 sched nsubmitted 249.000000
13 23.027698000 sched nready 246.000000
12 23.029133000 t4820 US
11 23.029910000 t4820 US Bu
12 23.030400000 t4820 US
11 23.032034000 t4820 US Su
13 23.032486000 sched nsubmitted 250.000000
13 23.034062000 sched nready 247.000000
12 23.035538000 t4820 US
11 23.036310000 t4820 US Bu
12 23.036799000 t4820 US
11 23.037323000 t4820 US Su
13 23.037774000 sched nsubmitted 251.000000
13 23.039357000 sched nready 248.000000
12 23.040796000 t4820 US
11 23.041558000 t4820 US Bu
12 23.042043000 t4820 US
11 23.042574000 t4820 US Su
13 23.043025000 sched nsubmitted 252.000000
13 23.044490000 sched nready 249.000000
12 23.045926000 t4820 US
11 23.046691000 t4820 US Bu
12 23.047175000 t4820 US
11 23.047708000 t4820 US Su
13 23.048152000 sched nsubmitted 253.000000
13 23.049644000 sched nready 250.000000
12 23.051080000 t4820 US
11 23.051833000 t4820 US Bu
12 23.052318000 t4820 US
11 23.053969000 t4820 US Su
13 23.054440000 sched nsubmitted 254.000000
13 23.055953000 sched nready 251.000000
12 23.057412000 t4820 US
11 23.058187000 t4820 US Bu
12 23.058678000 t4820 US
11 23.059211000 t4820 US Su
13 23.059658000 sched nsubmitted 255.000000
13 23.061202000 sched nready 252.000000
12 23.062647000 t4820 US
11 23.063406000 t4820 US Bu
12 23.063892000 t4820 US
11 23.064443000 t4820 US Su
13 23.064891000 sched nsubmitted 256.000000
13 23.066275000 sched nready 253.000000
12 23.067719000 t4820 US
11 23.068486000 t4820 US Bu
12 23.068978000 t4820 US
11 23.069501000 t4820 US Su
13 23.069946000 sched nsubmitted 257.000000
13 23.071383000 sched nready 254.000000
12 23.072832000 t4820 US
11 23.073424000 t4820 US Bu
12 23.073961000 t4820 US
11 23.076327000 t4820 US Su
13 23.076874000 sched nsubmitted 258.000000
13 23.078456000 sched nready 255.000000
12 23.079913000 t4820 US
11 23.080481000 t4820 US Bu
12 23.081011000 t4820 US
11 23.081543000 t4820 US Su
13 23.082072000 sched nsubmitted 259.000000
13 23.083490000 sched nready 256.000000
12 23.084938000 t4820 US
11 23.085488000 t4820 US Bu
12 23.086011000 t4820 US
11 23.086543000 t4820 US Su
13 23.087067000 sched nsubmitted 260.000000
12 23.088896000 t4820 US
11 23.089420000 t4820 US Bu
12 23.089956000 t4820 US
11 23.091668000 t4820 US Su
13 23.092197000 sched nsubmitted 261.000000
13 23.093796000 sched nready 257.000000
12 23.095258000 t4820 US
11 23.095840000 t4820 US Bu
12 23.096376000 t4820 US
11 23.096943000 t4820 US Su
13 23.097467000 sched nsubmitted 262.000000
13 23.099079000 sched nready 258.000000
12 23.100535000 t4820 US
11 23.101087000 t4820 US Bu
12 23.101636000 t4820 US
11 23.102160000 t4820 US Su
13 23.102623000 sched nsubmitted 263.000000
13 23.104179000 sched nready 259.000000
12 23.105619000 t4820 US
11 23.106160000 t4820 US Bu
12 23.106831000 t4820 US
11 23.107337000 t4820 US Su
13 23.107877000 sched nsubmitted 264.000000
13 23.109369000 sched nready 260.000000
12 23.110847000 t4820 US
11 23.111409000 t4820 US Bu
12 23.111930000 t4820 US
11 23.113555000 t4820 US Su
13 23.114043000 sched nsubmitted 265.000000
12 23.116284000 t4820 US
11 23.116872000 t4820 US Bu
12 23.117423000 t4820 US
11 23.117966000 t4820 US Su
13 23.118522000 sched nsubmitted 266.000000
13 23.120027000 sched nready 261.000000
12 23.121498000 t4820 US
11 23.122045000 t4820 US Bu
12 23.122573000 t4820 US
11 23.123091000 t4820 US Su
13 23.123610000 sched nsubmitted 267.000000
13 23.125049000 sched nready 262.000000
12 23.126498000 t4820 US
11 23.127043000 t4820 US Bu
12 23.127523000 t4820 US
11 23.129135000 t4820 US Su
13 23.129621000 sched nsubmitted 268.000000
12 23.131257000 t4820 US
11 23.132206000 t4820 US Bu
12 23.132750000 t4820 US
11 23.133267000 t4820 US Su
13 23.133778000 sched nsubmitted 269.000000
13 23.135269000 sched nready 263.000000
12 23.136738000 t4820 US
11 23.137297000 t4820 US Bu
12 23.137816000 t4820 US
11 23.138345000 t4820 US Su
13 23.138794000 sched nsubmitted 270.000000
13 23.140350000 sched nready 264.000000
12 23.141810000 t4820 US
11 23.142372000 t4820 US Bu
12 23.142852000 t4820 US
11 23.143374000 t4820 US Su
13 23.143824000 sched nsubmitted 271.000000
13 23.145387000 sched nready 265.000000
12 23.146845000 t4820 US
11 23.148477000 t4820 US Bu
12 23.148964000 t4820 US
11 23.149481000 t4820 US Su
13 23.149941000 sched nsubmitted 272.000000
13 23.151398000 sched nready 266.000000
12 23.152868000 t4820 US
11 23.153439000 t4820 US Bu
12 23.153997000 t4820 US
11 23.154510000 t4820 US Su
13 23.154971000 sched nsubmitted 273.000000
12 23.157215000 t4820 US
11 23.161213000 t4820 US WA
10 29.317388000 w0 WS "B"
13 21.583022000 w0 gf 0.000000
13 29.317388000 w0 gf 0.000000
13 21.583022000 sched gft 0.000000
13 21.602404000 sched gft 0.000000
10 29.318316000 w0 WS "Po"
10 29.319220000 w0 WS "B"
10 29.322394000 w0 WS "P"
10 29.323484000 w0 WS "Sc"
13 29.324561000 sched nready 265.000000
13 29.324561000 sched nsubmitted 272.000000
10 29.325037000 w0 WS "B"
10 29.325454000 w0 WS "B"
10 29.325880000 w0 WS "Fi"
10 29.326740000 w0 WS "B"
6 B22_6 WS B22_6 "0.000000 0.600000 0.400000"
6 B22_6_1 Ctx1 B22_6 "1.0 0.39 1.0"
6 B22_6_2 Ctx2 B22_6 ".0 1.0 .0"
6 B22_6_3 Ctx3 B22_6 "0.87 0.87 .0"
6 B22_6_4 Ctx4 B22_6 ".0 0.95 1.0"
6 B22_6_5 Ctx5 B22_6 ".0 .0 .0"
6 B22_6_6 Ctx6 B22_6 ".0 .0 0.5"
6 B22_6_7 Ctx7 B22_6 "0.41 0.41 0.41"
6 B22_6_8 Ctx8 B22_6 "1.0 .0 1.0"
6 B22_6_9 Ctx9 B22_6 ".0 .0 1.0"
10 29.327398000 w0 WS "B22_6"
20 29.327398000 w0 WS B22_6 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 31
0.000000 0 0 0 -1 -1
10 29.385708000 w2 WS "B"
13 21.610141000 w2 gf 0.000000
13 29.385708000 w2 gf 0.000000
13 21.610141000 sched gft 0.000000
13 21.699890000 sched gft 0.000000
10 29.386329000 w2 WS "Po"
10 29.387065000 w2 WS "B"
10 29.389266000 w2 WS "P"
10 29.389858000 w2 WS "Sc"
13 29.390862000 sched nready 264.000000
13 29.390862000 sched nsubmitted 271.000000
10 29.391286000 w2 WS "B"
10 29.391699000 w2 WS "B"
10 29.392111000 w2 WS "Fi"
10 29.392840000 w2 WS "B"
6 B22_7 WS B22_7 "0.000000 0.600000 0.400000"
6 B22_7_1 Ctx1 B22_7 "1.0 0.39 1.0"
6 B22_7_2 Ctx2 B22_7 ".0 1.0 .0"
6 B22_7_3 Ctx3 B22_7 "0.87 0.87 .0"
6 B22_7_4 Ctx4 B22_7 ".0 0.95 1.0"
6 B22_7_5 Ctx5 B22_7 ".0 .0 .0"
6 B22_7_6 Ctx6 B22_7 ".0 .0 0.5"
6 B22_7_7 Ctx7 B22_7 "0.41 0.41 0.41"
6 B22_7_8 Ctx8 B22_7 "1.0 .0 1.0"
6 B22_7_9 Ctx9 B22_7 ".0 .0 1.0"
10 29.393316000 w2 WS "B22_7"
20 29.393316000 w2 WS B22_7 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 32
10 29.497933000 w1 WS "B"
13 21.711932000 w1 gf 0.000000
13 29.497933000 w1 gf 0.000000
13 21.711932000 sched gft 0.000000
13 21.798075000 sched gft 0.000000
13 21.798315000 sched gft 0.000000
10 29.498580000 w1 WS "Po"
10 29.499360000 w1 WS "B"
10 29.501635000 w1 WS "P"
10 29.501742000 w4 WS "B"
13 21.812270000 w4 gf 0.000000
13 29.501742000 w4 gf 0.000000
13 21.812270000 sched gft 0.000000
10 29.502294000 w1 WS "Sc"
10 29.502393000 w4 WS "Po"
13 29.503063000 sched nready 263.000000
13 29.503063000 sched nsubmitted 270.000000
10 29.503272000 w4 WS "B"
10 29.503580000 w1 WS "B"
10 29.504005000 w1 WS "B"
10 29.504433000 w1 WS "Fi"
10 29.505267000 w1 WS "B"
6 B22_8 WS B22_8 "0.000000 0.600000 0.400000"
6 B22_8_1 Ctx1 B22_8 "1.0 0.39 1.0"
6 B22_8_2 Ctx2 B22_8 ".0 1.0 .0"
6 B22_8_3 Ctx3 B22_8 "0.87 0.87 .0"
6 B22_8_4 Ctx4 B22_8 ".0 0.95 1.0"
6 B22_8_5 Ctx5 B22_8 ".0 .0 .0"
6 B22_8_6 Ctx6 B22_8 ".0 .0 0.5"
6 B22_8_7 Ctx7 B22_8 "0.41 0.41 0.41"
6 B22_8_8 Ctx8 B22_8 "1.0 .0 1.0"
6 B22_8_9 Ctx9 B22_8 ".0 .0 1.0"
10 29.505799000 w1 WS "B22_8"
10 29.505939000 w4 WS "P"
10 29.506570000 w4 WS "Sc"
20 29.505799000 w1 WS B22_8 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 33
13 29.507334000 sched nready 262.000000
13 29.507334000 sched nsubmitted 269.000000
10 29.507926000 w4 WS "B"
10 29.508337000 w4 WS "B"
10 29.508745000 w4 WS "Fi"
10 29.509580000 w4 WS "B"
6 B22_9 WS B22_9 "0.000000 0.600000 0.400000"
6 B22_9_1 Ctx1 B22_9 "1.0 0.39 1.0"
6 B22_9_2 Ctx2 B22_9 ".0 1.0 .0"
6 B22_9_3 Ctx3 B22_9 "0.87 0.87 .0"
6 B22_9_4 Ctx4 B22_9 ".0 0.95 1.0"
6 B22_9_5 Ctx5 B22_9 ".0 .0 .0"
6 B22_9_6 Ctx6 B22_9 ".0 .0 0.5"
6 B22_9_7 Ctx7 B22_9 "0.41 0.41 0.41"
6 B22_9_8 Ctx8 B22_9 "1.0 .0 1.0"
6 B22_9_9 Ctx9 B22_9 ".0 .0 1.0"
10 29.510071000 w4 WS "B22_9"
20 29.510071000 w4 WS B22_9 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 34
10 29.518700000 w3 WS "B"
13 21.815939000 w3 gf 0.000000
13 29.518700000 w3 gf 0.000000
13 21.815939000 sched gft 0.000000
13 22.250023000 sched gft 0.000000
10 29.519348000 w3 WS "Po"
10 29.520119000 w3 WS "B"
10 29.522545000 w3 WS "P"
10 29.523125000 w3 WS "Sc"
13 29.523779000 sched nready 261.000000
13 29.523779000 sched nsubmitted 268.000000
10 29.524264000 w3 WS "B"
10 29.524692000 w3 WS "B"
10 29.525098000 w3 WS "Fi"
10 29.525930000 w3 WS "B"
6 B22_10 WS B22_10 "0.000000 0.600000 0.400000"
6 B22_10_1 Ctx1 B22_10 "1.0 0.39 1.0"
6 B22_10_2 Ctx2 B22_10 ".0 1.0 .0"
6 B22_10_3 Ctx3 B22_10 "0.87 0.87 .0"
6 B22_10_4 Ctx4 B22_10 ".0 0.95 1.0"
6 B22_10_5 Ctx5 B22_10 ".0 .0 .0"
6 B22_10_6 Ctx6 B22_10 ".0 .0 0.5"
6 B22_10_7 Ctx7 B22_10 "0.41 0.41 0.41"
6 B22_10_8 Ctx8 B22_10 "1.0 .0 1.0"
6 B22_10_9 Ctx9 B22_10 ".0 .0 1.0"
10 29.526484000 w3 WS "B22_10"
20 29.526484000 w3 WS B22_10 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 35
10 30.485673000 w5 WS "B"
13 22.262135000 w5 gf 0.000000
13 30.485673000 w5 gf 0.000000
13 22.262135000 sched gft 0.000000
13 29.317388000 sched gft 0.000000
10 30.486360000 w5 WS "Po"
10 30.487187000 w5 WS "B"
10 30.489730000 w5 WS "P"
10 30.490424000 w5 WS "Sc"
13 30.491262000 sched nready 260.000000
13 30.491262000 sched nsubmitted 267.000000
10 30.507867000 w5 WS "B"
10 30.508343000 w5 WS "B"
10 30.508803000 w5 WS "Fi"
10 30.509670000 w5 WS "B"
6 B22_11 WS B22_11 "0.000000 0.600000 0.400000"
6 B22_11_1 Ctx1 B22_11 "1.0 0.39 1.0"
6 B22_11_2 Ctx2 B22_11 ".0 1.0 .0"
6 B22_11_3 Ctx3 B22_11 "0.87 0.87 .0"
6 B22_11_4 Ctx4 B22_11 ".0 0.95 1.0"
6 B22_11_5 Ctx5 B22_11 ".0 .0 .0"
6 B22_11_6 Ctx6 B22_11 ".0 .0 0.5"
6 B22_11_7 Ctx7 B22_11 "0.41 0.41 0.41"
6 B22_11_8 Ctx8 B22_11 "1.0 .0 1.0"
6 B22_11_9 Ctx9 B22_11 ".0 .0 1.0"
10 30.510311000 w5 WS "B22_11"
20 30.510311000 w5 WS B22_11 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 36
10 37.411196000 w2 WS "B"
13 29.393316000 w2 gf 0.000000
13 37.411196000 w2 gf 0.000000
10 37.412815000 w0 WS "B"
13 29.327398000 w0 gf 0.000000
13 37.412815000 w0 gf 0.000000
13 29.327398000 sched gft 0.000000
13 29.385708000 sched gft 0.000000
13 29.393316000 sched gft 0.000000
13 29.497933000 sched gft 0.000000
13 29.501742000 sched gft 0.000000
10 37.413314000 w2 WS "Po"
10 37.414192000 w0 WS "Po"
10 37.416375000 w2 WS "B"
10 37.416789000 w0 WS "B"
10 37.424154000 w0 WS "P"
10 37.424801000 w2 WS "P"
10 37.425897000 w2 WS "Sc"
10 37.425934000 w0 WS "Sc"
13 37.429366000 sched nready 259.000000
13 37.429366000 sched nsubmitted 266.000000
13 37.429774000 sched nready 258.000000
13 37.429774000 sched nsubmitted 265.000000
10 37.430989000 w0 WS "B"
10 37.431048000 w2 WS "B"
10 37.431738000 w2 WS "B"
10 37.431774000 w0 WS "B"
10 37.432522000 w0 WS "Fi"
10 37.432549000 w2 WS "Fi"
10 37.434299000 w1 WS "B"
13 29.505799000 w1 gf 0.000000
13 37.434299000 w1 gf 0.000000
13 29.505799000 sched gft 0.000000
10 37.434584000 w0 WS "B"
10 37.434624000 w2 WS "B"
10 37.435000000 w1 WS "Po"
6 B22_12 WS B22_12 "0.000000 0.600000 0.400000"
6 B22_12_1 Ctx1 B22_12 "1.0 0.39 1.0"
6 B22_12_2 Ctx2 B22_12 ".0 1.0 .0"
6 B22_12_3 Ctx3 B22_12 "0.87 0.87 .0"
6 B22_12_4 Ctx4 B22_12 ".0 0.95 1.0"
6 B22_12_5 Ctx5 B22_12 ".0 .0 .0"
6 B22_12_6 Ctx6 B22_12 ".0 .0 0.5"
6 B22_12_7 Ctx7 B22_12 "0.41 0.41 0.41"
6 B22_12_8 Ctx8 B22_12 "1.0 .0 1.0"
6 B22_12_9 Ctx9 B22_12 ".0 .0 1.0"
10 37.435906000 w2 WS "B22_12"
6 B22_13 WS B22_13 "0.000000 0.600000 0.400000"
6 B22_13_1 Ctx1 B22_13 "1.0 0.39 1.0"
6 B22_13_2 Ctx2 B22_13 ".0 1.0 .0"
6 B22_13_3 Ctx3 B22_13 "0.87 0.87 .0"
6 B22_13_4 Ctx4 B22_13 ".0 0.95 1.0"
6 B22_13_5 Ctx5 B22_13 ".0 .0 .0"
6 B22_13_6 Ctx6 B22_13 ".0 .0 0.5"
6 B22_13_7 Ctx7 B22_13 "0.41 0.41 0.41"
6 B22_13_8 Ctx8 B22_13 "1.0 .0 1.0"
6 B22_13_9 Ctx9 B22_13 ".0 .0 1.0"
10 37.435975000 w0 WS "B22_13"
10 37.436892000 w1 WS "B"
20 37.435975000 w0 WS B22_13 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 38
20 37.435906000 w2 WS B22_12 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 37
10 37.439842000 w1 WS "P"
10 37.440610000 w1 WS "Sc"
13 37.441677000 sched nready 257.000000
13 37.441677000 sched nsubmitted 264.000000
10 37.442450000 w1 WS "B"
10 37.442858000 w1 WS "B"
10 37.443300000 w1 WS "Fi"
10 37.445215000 w1 WS "B"
6 B22_14 WS B22_14 "0.000000 0.600000 0.400000"
6 B22_14_1 Ctx1 B22_14 "1.0 0.39 1.0"
6 B22_14_2 Ctx2 B22_14 ".0 1.0 .0"
6 B22_14_3 Ctx3 B22_14 "0.87 0.87 .0"
6 B22_14_4 Ctx4 B22_14 ".0 0.95 1.0"
6 B22_14_5 Ctx5 B22_14 ".0 .0 .0"
6 B22_14_6 Ctx6 B22_14 ".0 .0 0.5"
6 B22_14_7 Ctx7 B22_14 "0.41 0.41 0.41"
6 B22_14_8 Ctx8 B22_14 "1.0 .0 1.0"
6 B22_14_9 Ctx9 B22_14 ".0 .0 1.0"
10 37.446130000 w1 WS "B22_14"
20 37.446130000 w1 WS B22_14 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 39
10 37.521775000 w3 WS "B"
13 29.526484000 w3 gf 0.000000
13 37.521775000 w3 gf 0.000000
10 37.522439000 w3 WS "Po"
10 37.524796000 w3 WS "B"
10 37.527610000 w3 WS "P"
10 37.528191000 w3 WS "Sc"
13 37.529013000 sched nready 256.000000
13 37.529013000 sched nsubmitted 263.000000
10 37.529748000 w3 WS "B"
10 37.530167000 w3 WS "B"
10 37.531358000 w3 WS "Fi"
10 37.532723000 w3 WS "B"
6 B22_15 WS B22_15 "0.000000 0.600000 0.400000"
6 B22_15_1 Ctx1 B22_15 "1.0 0.39 1.0"
6 B22_15_2 Ctx2 B22_15 ".0 1.0 .0"
6 B22_15_3 Ctx3 B22_15 "0.87 0.87 .0"
6 B22_15_4 Ctx4 B22_15 ".0 0.95 1.0"
6 B22_15_5 Ctx5 B22_15 ".0 .0 .0"
6 B22_15_6 Ctx6 B22_15 ".0 .0 0.5"
6 B22_15_7 Ctx7 B22_15 "0.41 0.41 0.41"
6 B22_15_8 Ctx8 B22_15 "1.0 .0 1.0"
6 B22_15_9 Ctx9 B22_15 ".0 .0 1.0"
10 37.533309000 w3 WS "B22_15"
20 37.533309000 w3 WS B22_15 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 40
10 39.500697000 w4 WS "B"
13 29.510071000 w4 gf 0.000000
13 39.500697000 w4 gf 0.000000
13 29.510071000 sched gft 0.000000
13 29.518700000 sched gft 0.000000
13 29.526484000 sched gft 0.000000
13 30.485673000 sched gft 0.000000
10 39.501876000 w4 WS "Po"
10 39.503085000 w4 WS "B"
10 39.506202000 w4 WS "P"
10 39.507282000 w4 WS "Sc"
13 39.508583000 sched nready 255.000000
13 39.508583000 sched nsubmitted 262.000000
10 39.509226000 w4 WS "B"
10 39.509634000 w4 WS "B"
10 39.510200000 w4 WS "Fi"
10 39.511302000 w4 WS "B"
6 B22_16 WS B22_16 "0.000000 0.600000 0.400000"
6 B22_16_1 Ctx1 B22_16 "1.0 0.39 1.0"
6 B22_16_2 Ctx2 B22_16 ".0 1.0 .0"
6 B22_16_3 Ctx3 B22_16 "0.87 0.87 .0"
6 B22_16_4 Ctx4 B22_16 ".0 0.95 1.0"
6 B22_16_5 Ctx5 B22_16 ".0 .0 .0"
6 B22_16_6 Ctx6 B22_16 ".0 .0 0.5"
6 B22_16_7 Ctx7 B22_16 "0.41 0.41 0.41"
6 B22_16_8 Ctx8 B22_16 "1.0 .0 1.0"
6 B22_16_9 Ctx9 B22_16 ".0 .0 1.0"
10 39.512017000 w4 WS "B22_16"
20 39.512017000 w4 WS B22_16 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 41
10 39.667309000 w5 WS "B"
13 30.510311000 w5 gf 0.000000
13 39.667309000 w5 gf 0.000000
13 30.510311000 sched gft 0.000000
13 37.411196000 sched gft 0.000000
13 37.412815000 sched gft 0.000000
13 37.434299000 sched gft 0.000000
10 39.668169000 w5 WS "Po"
10 39.669254000 w5 WS "B"
10 39.672065000 w5 WS "P"
10 39.672925000 w5 WS "Sc"
13 39.673841000 sched nready 254.000000
13 39.673841000 sched nsubmitted 261.000000
10 39.674481000 w5 WS "B"
10 39.674892000 w5 WS "B"
10 39.675305000 w5 WS "Fi"
10 39.676237000 w5 WS "B"
6 B22_17 WS B22_17 "0.000000 0.600000 0.400000"
6 B22_17_1 Ctx1 B22_17 "1.0 0.39 1.0"
6 B22_17_2 Ctx2 B22_17 ".0 1.0 .0"
6 B22_17_3 Ctx3 B22_17 "0.87 0.87 .0"
6 B22_17_4 Ctx4 B22_17 ".0 0.95 1.0"
6 B22_17_5 Ctx5 B22_17 ".0 .0 .0"
6 B22_17_6 Ctx6 B22_17 ".0 .0 0.5"
6 B22_17_7 Ctx7 B22_17 "0.41 0.41 0.41"
6 B22_17_8 Ctx8 B22_17 "1.0 .0 1.0"
6 B22_17_9 Ctx9 B22_17 ".0 .0 1.0"
10 39.676849000 w5 WS "B22_17"
20 39.676849000 w5 WS B22_17 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 42
10 45.201527000 w2 WS "B"
13 37.435906000 w2 gf 0.000000
13 45.201527000 w2 gf 0.000000
13 37.435906000 sched gft 0.000000
10 45.202375000 w2 WS "Po"
10 45.203396000 w2 WS "B"
10 45.206151000 w2 WS "P"
10 45.206834000 w2 WS "Sc"
13 45.207606000 sched nready 253.000000
13 45.207606000 sched nsubmitted 260.000000
10 45.208181000 w2 WS "B"
10 45.208599000 w2 WS "B"
10 45.209085000 w2 WS "Fi"
10 45.210136000 w2 WS "B"
6 B22_18 WS B22_18 "0.000000 0.600000 0.400000"
6 B22_18_1 Ctx1 B22_18 "1.0 0.39 1.0"
6 B22_18_2 Ctx2 B22_18 ".0 1.0 .0"
6 B22_18_3 Ctx3 B22_18 "0.87 0.87 .0"
6 B22_18_4 Ctx4 B22_18 ".0 0.95 1.0"
6 B22_18_5 Ctx5 B22_18 ".0 .0 .0"
6 B22_18_6 Ctx6 B22_18 ".0 .0 0.5"
6 B22_18_7 Ctx7 B22_18 "0.41 0.41 0.41"
6 B22_18_8 Ctx8 B22_18 "1.0 .0 1.0"
6 B22_18_9 Ctx9 B22_18 ".0 .0 1.0"
10 45.210616000 w2 WS "B22_18"
20 45.210616000 w2 WS B22_18 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 43
10 45.235555000 w0 WS "B"
13 37.435975000 w0 gf 0.000000
13 45.235555000 w0 gf 0.000000
13 37.435975000 sched gft 0.000000
10 45.236346000 w0 WS "Po"
10 45.237276000 w0 WS "B"
10 45.239982000 w0 WS "P"
10 45.240640000 w0 WS "Sc"
13 45.241486000 sched nready 252.000000
13 45.241486000 sched nsubmitted 259.000000
10 45.241975000 w0 WS "B"
10 45.242391000 w0 WS "B"
10 45.242818000 w0 WS "Fi"
10 45.243802000 w0 WS "B"
6 B22_19 WS B22_19 "0.000000 0.600000 0.400000"
6 B22_19_1 Ctx1 B22_19 "1.0 0.39 1.0"
6 B22_19_2 Ctx2 B22_19 ".0 1.0 .0"
6 B22_19_3 Ctx3 B22_19 "0.87 0.87 .0"
6 B22_19_4 Ctx4 B22_19 ".0 0.95 1.0"
6 B22_19_5 Ctx5 B22_19 ".0 .0 .0"
6 B22_19_6 Ctx6 B22_19 ".0 .0 0.5"
6 B22_19_7 Ctx7 B22_19 "0.41 0.41 0.41"
6 B22_19_8 Ctx8 B22_19 "1.0 .0 1.0"
6 B22_19_9 Ctx9 B22_19 ".0 .0 1.0"
10 45.244369000 w0 WS "B22_19"
20 45.244369000 w0 WS B22_19 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 44
10 45.250647000 w3 WS "B"
13 37.533309000 w3 gf 0.000000
13 45.250647000 w3 gf 0.000000
10 45.251233000 w3 WS "Po"
10 45.252220000 w3 WS "B"
10 45.254487000 w3 WS "P"
10 45.255013000 w3 WS "Sc"
13 45.255888000 sched nready 251.000000
13 45.255888000 sched nsubmitted 258.000000
10 45.256408000 w3 WS "B"
10 45.256816000 w3 WS "B"
10 45.257223000 w3 WS "Fi"
10 45.258109000 w3 WS "B"
6 B22_20 WS B22_20 "0.000000 0.600000 0.400000"
6 B22_20_1 Ctx1 B22_20 "1.0 0.39 1.0"
6 B22_20_2 Ctx2 B22_20 ".0 1.0 .0"
6 B22_20_3 Ctx3 B22_20 "0.87 0.87 .0"
6 B22_20_4 Ctx4 B22_20 ".0 0.95 1.0"
6 B22_20_5 Ctx5 B22_20 ".0 .0 .0"
6 B22_20_6 Ctx6 B22_20 ".0 .0 0.5"
6 B22_20_7 Ctx7 B22_20 "0.41 0.41 0.41"
6 B22_20_8 Ctx8 B22_20 "1.0 .0 1.0"
6 B22_20_9 Ctx9 B22_20 ".0 .0 1.0"
10 45.258583000 w3 WS "B22_20"
20 45.258583000 w3 WS B22_20 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 45
10 45.417965000 w1 WS "B"
13 37.446130000 w1 gf 0.000000
13 45.417965000 w1 gf 0.000000
13 37.446130000 sched gft 0.000000
13 37.521775000 sched gft 0.000000
13 37.533309000 sched gft 0.000000
13 39.500697000 sched gft 0.000000
10 45.419164000 w1 WS "Po"
10 45.420277000 w1 WS "B"
10 45.423920000 w1 WS "P"
10 45.425162000 w1 WS "Sc"
13 45.426534000 sched nready 250.000000
13 45.426534000 sched nsubmitted 257.000000
10 45.427109000 w1 WS "B"
10 45.427609000 w1 WS "B"
10 45.428078000 w1 WS "Fi"
10 45.429501000 w1 WS "B"
6 B22_21 WS B22_21 "0.000000 0.600000 0.400000"
6 B22_21_1 Ctx1 B22_21 "1.0 0.39 1.0"
6 B22_21_2 Ctx2 B22_21 ".0 1.0 .0"
6 B22_21_3 Ctx3 B22_21 "0.87 0.87 .0"
6 B22_21_4 Ctx4 B22_21 ".0 0.95 1.0"
6 B22_21_5 Ctx5 B22_21 ".0 .0 .0"
6 B22_21_6 Ctx6 B22_21 ".0 .0 0.5"
6 B22_21_7 Ctx7 B22_21 "0.41 0.41 0.41"
6 B22_21_8 Ctx8 B22_21 "1.0 .0 1.0"
6 B22_21_9 Ctx9 B22_21 ".0 .0 1.0"
10 45.430448000 w1 WS "B22_21"
20 45.430448000 w1 WS B22_21 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 46
10 47.861270000 w4 WS "B"
13 39.512017000 w4 gf 0.000000
13 47.861270000 w4 gf 0.000000
13 39.512017000 sched gft 0.000000
13 39.667309000 sched gft 0.000000
10 47.864580000 w4 WS "Po"
10 47.885813000 w4 WS "B"
10 47.893368000 w4 WS "P"
10 47.894241000 w4 WS "Sc"
13 47.899411000 sched nready 249.000000
13 47.899411000 sched nsubmitted 256.000000
10 47.900850000 w4 WS "B"
10 47.901354000 w4 WS "B"
10 47.901777000 w4 WS "Fi"
10 47.905303000 w4 WS "B"
6 B12 WS B12 "0.000000 0.600000 0.400000"
6 B12_1 Ctx1 B12 "1.0 0.39 1.0"
6 B12_2 Ctx2 B12 ".0 1.0 .0"
6 B12_3 Ctx3 B12 "0.87 0.87 .0"
6 B12_4 Ctx4 B12 ".0 0.95 1.0"
6 B12_5 Ctx5 B12 ".0 .0 .0"
6 B12_6 Ctx6 B12 ".0 .0 0.5"
6 B12_7 Ctx7 B12 "0.41 0.41 0.41"
6 B12_8 Ctx8 B12 "1.0 .0 1.0"
6 B12_9 Ctx9 B12 ".0 .0 1.0"
10 47.907227000 w4 WS "B12"
20 47.907227000 w4 WS B12 196608
M8192x1x8_M8192x1x8_M8192x1x8 ec48135f 0000000000000000 16
10 48.034035000 w4 WS "B"
13 47.907227000 w4 gf 0.000000
13 48.034035000 w4 gf 0.000000
10 48.035568000 w4 WS "Po"
10 48.037800000 w4 WS "B"
10 48.041944000 w4 WS "P"
10 48.042803000 w4 WS "Sc"
13 48.044604000 sched nready 248.000000
13 48.044604000 sched nsubmitted 255.000000
10 48.046165000 w4 WS "B"
10 48.046625000 w4 WS "B"
10 48.047301000 w4 WS "Fi"
10 48.049668000 w4 WS "B"
6 B22_22 WS B22_22 "0.000000 0.600000 0.400000"
6 B22_22_1 Ctx1 B22_22 "1.0 0.39 1.0"
6 B22_22_2 Ctx2 B22_22 ".0 1.0 .0"
6 B22_22_3 Ctx3 B22_22 "0.87 0.87 .0"
6 B22_22_4 Ctx4 B22_22 ".0 0.95 1.0"
6 B22_22_5 Ctx5 B22_22 ".0 .0 .0"
6 B22_22_6 Ctx6 B22_22 ".0 .0 0.5"
6 B22_22_7 Ctx7 B22_22 "0.41 0.41 0.41"
6 B22_22_8 Ctx8 B22_22 "1.0 .0 1.0"
6 B22_22_9 Ctx9 B22_22 ".0 .0 1.0"
10 48.050346000 w4 WS "B22_22"
20 48.050346000 w4 WS B22_22 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 47
10 48.073068000 w5 WS "B"
13 39.676849000 w5 gf 0.000000
13 48.073068000 w5 gf 0.000000
13 39.676849000 sched gft 0.000000
13 45.201527000 sched gft 0.000000
10 48.075456000 w5 WS "Po"
10 48.078610000 w5 WS "B"
10 48.102727000 w5 WS "P"
10 48.104512000 w5 WS "Sc"
13 48.105635000 sched nready 247.000000
13 48.105635000 sched nsubmitted 254.000000
10 48.106686000 w5 WS "B"
10 48.107142000 w5 WS "B"
10 48.107590000 w5 WS "Fi"
10 48.109820000 w5 WS "B"
6 B22_23 WS B22_23 "0.000000 0.600000 0.400000"
6 B22_23_1 Ctx1 B22_23 "1.0 0.39 1.0"
6 B22_23_2 Ctx2 B22_23 ".0 1.0 .0"
6 B22_23_3 Ctx3 B22_23 "0.87 0.87 .0"
6 B22_23_4 Ctx4 B22_23 ".0 0.95 1.0"
6 B22_23_5 Ctx5 B22_23 ".0 .0 .0"
6 B22_23_6 Ctx6 B22_23 ".0 .0 0.5"
6 B22_23_7 Ctx7 B22_23 "0.41 0.41 0.41"
6 B22_23_8 Ctx8 B22_23 "1.0 .0 1.0"
6 B22_23_9 Ctx9 B22_23 ".0 .0 1.0"
10 48.111142000 w5 WS "B22_23"
20 48.111142000 w5 WS B22_23 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 48
10 55.999839000 w3 WS "B"
13 45.258583000 w3 gf 0.000000
13 55.999839000 w3 gf 0.000000
10 56.001466000 w3 WS "Po"
10 56.002782000 w3 WS "B"
10 56.027064000 w0 WS "B"
13 45.244369000 w0 gf 0.000000
13 56.027064000 w0 gf 0.000000
10 56.027370000 w3 WS "P"
10 56.027894000 w0 WS "Po"
10 56.028883000 w3 WS "Sc"
10 56.028986000 w0 WS "B"
13 56.031401000 sched nready 246.000000
13 56.031401000 sched nsubmitted 253.000000
10 56.032257000 w3 WS "B"
10 56.032765000 w0 WS "P"
10 56.032820000 w3 WS "B"
10 56.033359000 w3 WS "Fi"
10 56.033574000 w0 WS "Sc"
13 56.034423000 sched nready 245.000000
13 56.034423000 sched nsubmitted 252.000000
10 56.034900000 w3 WS "B"
10 56.035216000 w0 WS "B"
10 56.035685000 w0 WS "B"
6 B22_24 WS B22_24 "0.000000 0.600000 0.400000"
6 B22_24_1 Ctx1 B22_24 "1.0 0.39 1.0"
6 B22_24_2 Ctx2 B22_24 ".0 1.0 .0"
6 B22_24_3 Ctx3 B22_24 "0.87 0.87 .0"
6 B22_24_4 Ctx4 B22_24 ".0 0.95 1.0"
6 B22_24_5 Ctx5 B22_24 ".0 .0 .0"
6 B22_24_6 Ctx6 B22_24 ".0 .0 0.5"
6 B22_24_7 Ctx7 B22_24 "0.41 0.41 0.41"
6 B22_24_8 Ctx8 B22_24 "1.0 .0 1.0"
6 B22_24_9 Ctx9 B22_24 ".0 .0 1.0"
10 56.035826000 w3 WS "B22_24"
10 56.036137000 w0 WS "Fi"
10 56.037175000 w0 WS "B"
6 B22_25 WS B22_25 "0.000000 0.600000 0.400000"
6 B22_25_1 Ctx1 B22_25 "1.0 0.39 1.0"
6 B22_25_2 Ctx2 B22_25 ".0 1.0 .0"
6 B22_25_3 Ctx3 B22_25 "0.87 0.87 .0"
6 B22_25_4 Ctx4 B22_25 ".0 0.95 1.0"
6 B22_25_5 Ctx5 B22_25 ".0 .0 .0"
6 B22_25_6 Ctx6 B22_25 ".0 .0 0.5"
6 B22_25_7 Ctx7 B22_25 "0.41 0.41 0.41"
6 B22_25_8 Ctx8 B22_25 "1.0 .0 1.0"
6 B22_25_9 Ctx9 B22_25 ".0 .0 1.0"
10 56.037774000 w0 WS "B22_25"
20 56.035826000 w3 WS B22_24 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 49
20 56.037774000 w0 WS B22_25 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 50
10 56.155696000 w2 WS "B"
13 45.210616000 w2 gf 0.000000
13 56.155696000 w2 gf 0.000000
13 45.210616000 sched gft 0.000000
13 45.235555000 sched gft 0.000000
13 45.244369000 sched gft 0.000000
13 45.250647000 sched gft 0.000000
13 45.258583000 sched gft 0.000000
13 45.417965000 sched gft 0.000000
10 56.156362000 w2 WS "Po"
10 56.157475000 w2 WS "B"
10 56.160074000 w2 WS "P"
10 56.160704000 w2 WS "Sc"
13 56.161444000 sched nready 244.000000
13 56.161444000 sched nsubmitted 251.000000
10 56.161971000 w2 WS "B"
10 56.180949000 w2 WS "B"
10 56.181513000 w2 WS "Fi"
10 56.182475000 w2 WS "B"
6 B22_26 WS B22_26 "0.000000 0.600000 0.400000"
6 B22_26_1 Ctx1 B22_26 "1.0 0.39 1.0"
6 B22_26_2 Ctx2 B22_26 ".0 1.0 .0"
6 B22_26_3 Ctx3 B22_26 "0.87 0.87 .0"
6 B22_26_4 Ctx4 B22_26 ".0 0.95 1.0"
6 B22_26_5 Ctx5 B22_26 ".0 .0 .0"
6 B22_26_6 Ctx6 B22_26 ".0 .0 0.5"
6 B22_26_7 Ctx7 B22_26 "0.41 0.41 0.41"
6 B22_26_8 Ctx8 B22_26 "1.0 .0 1.0"
6 B22_26_9 Ctx9 B22_26 ".0 .0 1.0"
10 56.183082000 w2 WS "B22_26"
20 56.183082000 w2 WS B22_26 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 51
10 56.344431000 w1 WS "B"
13 45.430448000 w1 gf 0.000000
13 56.344431000 w1 gf 0.000000
13 45.430448000 sched gft 0.000000
13 47.861270000 sched gft 0.000000
13 47.907227000 sched gft 0.000000
13 48.034035000 sched gft 0.000000
10 56.345431000 w1 WS "Po"
10 56.346581000 w1 WS "B"
10 56.350221000 w1 WS "P"
10 56.351339000 w1 WS "Sc"
13 56.352457000 sched nready 243.000000
13 56.352457000 sched nsubmitted 250.000000
10 56.353206000 w1 WS "B"
10 56.353660000 w1 WS "B"
10 56.354123000 w1 WS "Fi"
10 56.355195000 w1 WS "B"
6 B22_27 WS B22_27 "0.000000 0.600000 0.400000"
6 B22_27_1 Ctx1 B22_27 "1.0 0.39 1.0"
6 B22_27_2 Ctx2 B22_27 ".0 1.0 .0"
6 B22_27_3 Ctx3 B22_27 "0.87 0.87 .0"
6 B22_27_4 Ctx4 B22_27 ".0 0.95 1.0"
6 B22_27_5 Ctx5 B22_27 ".0 .0 .0"
6 B22_27_6 Ctx6 B22_27 ".0 .0 0.5"
6 B22_27_7 Ctx7 B22_27 "0.41 0.41 0.41"
6 B22_27_8 Ctx8 B22_27 "1.0 .0 1.0"
6 B22_27_9 Ctx9 B22_27 ".0 .0 1.0"
10 56.356138000 w1 WS "B22_27"
20 56.356138000 w1 WS B22_27 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 52
10 57.961089000 w4 WS "B"
13 48.050346000 w4 gf 0.000000
13 57.961089000 w4 gf 0.000000
13 48.050346000 sched gft 0.000000
13 48.073068000 sched gft 0.000000
10 57.961920000 w4 WS "Po"
10 57.962971000 w4 WS "B"
10 57.965295000 w4 WS "P"
10 57.965816000 w4 WS "Sc"
13 57.966505000 sched nready 242.000000
13 57.966505000 sched nsubmitted 249.000000
10 57.967030000 w4 WS "B"
10 57.967443000 w4 WS "B"
10 57.967851000 w4 WS "Fi"
10 57.968735000 w4 WS "B"
6 B22_28 WS B22_28 "0.000000 0.600000 0.400000"
6 B22_28_1 Ctx1 B22_28 "1.0 0.39 1.0"
6 B22_28_2 Ctx2 B22_28 ".0 1.0 .0"
6 B22_28_3 Ctx3 B22_28 "0.87 0.87 .0"
6 B22_28_4 Ctx4 B22_28 ".0 0.95 1.0"
6 B22_28_5 Ctx5 B22_28 ".0 .0 .0"
6 B22_28_6 Ctx6 B22_28 ".0 .0 0.5"
6 B22_28_7 Ctx7 B22_28 "0.41 0.41 0.41"
6 B22_28_8 Ctx8 B22_28 "1.0 .0 1.0"
6 B22_28_9 Ctx9 B22_28 ".0 .0 1.0"
10 57.969228000 w4 WS "B22_28"
20 57.969228000 w4 WS B22_28 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 53
10 57.981807000 w5 WS "B"
13 48.111142000 w5 gf 0.000000
13 57.981807000 w5 gf 0.000000
13 48.111142000 sched gft 0.000000
13 55.999839000 sched gft 0.000000
13 56.027064000 sched gft 0.000000
10 57.982451000 w5 WS "Po"
10 57.983394000 w5 WS "B"
10 57.985817000 w5 WS "P"
10 57.986396000 w5 WS "Sc"
13 57.987055000 sched nready 241.000000
13 57.987055000 sched nsubmitted 248.000000
10 57.987530000 w5 WS "B"
10 57.987953000 w5 WS "B"
10 57.988366000 w5 WS "Fi"
10 57.989242000 w5 WS "B"
6 B22_29 WS B22_29 "0.000000 0.600000 0.400000"
6 B22_29_1 Ctx1 B22_29 "1.0 0.39 1.0"
6 B22_29_2 Ctx2 B22_29 ".0 1.0 .0"
6 B22_29_3 Ctx3 B22_29 "0.87 0.87 .0"
6 B22_29_4 Ctx4 B22_29 ".0 0.95 1.0"
6 B22_29_5 Ctx5 B22_29 ".0 .0 .0"
6 B22_29_6 Ctx6 B22_29 ".0 .0 0.5"
6 B22_29_7 Ctx7 B22_29 "0.41 0.41 0.41"
6 B22_29_8 Ctx8 B22_29 "1.0 .0 1.0"
6 B22_29_9 Ctx9 B22_29 ".0 .0 1.0"
10 57.989757000 w5 WS "B22_29"
20 57.989757000 w5 WS B22_29 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 54
10 63.881898000 w3 WS "B"
13 56.035826000 w3 gf 0.000000
13 63.881898000 w3 gf 0.000000
13 56.035826000 sched gft 0.000000
10 63.882739000 w3 WS "Po"
10 63.883918000 w3 WS "B"
10 63.886884000 w3 WS "P"
10 63.887066000 w0 WS "B"
13 56.037774000 w0 gf 0.000000
13 63.887066000 w0 gf 0.000000
13 56.037774000 sched gft 0.000000
13 56.155696000 sched gft 0.000000
10 63.887633000 w3 WS "Sc"
10 63.887740000 w0 WS "Po"
10 63.888536000 w0 WS "B"
13 63.888596000 sched nready 240.000000
13 63.888596000 sched nsubmitted 247.000000
10 63.889117000 w3 WS "B"
10 63.889688000 w3 WS "B"
10 63.890243000 w3 WS "Fi"
10 63.891372000 w0 WS "P"
10 63.891431000 w3 WS "B"
6 B22_30 WS B22_30 "0.000000 0.600000 0.400000"
6 B22_30_1 Ctx1 B22_30 "1.0 0.39 1.0"
6 B22_30_2 Ctx2 B22_30 ".0 1.0 .0"
6 B22_30_3 Ctx3 B22_30 "0.87 0.87 .0"
6 B22_30_4 Ctx4 B22_30 ".0 0.95 1.0"
6 B22_30_5 Ctx5 B22_30 ".0 .0 .0"
6 B22_30_6 Ctx6 B22_30 ".0 .0 0.5"
6 B22_30_7 Ctx7 B22_30 "0.41 0.41 0.41"
6 B22_30_8 Ctx8 B22_30 "1.0 .0 1.0"
6 B22_30_9 Ctx9 B22_30 ".0 .0 1.0"
10 63.891932000 w3 WS "B22_30"
10 63.892029000 w0 WS "Sc"
13 63.892848000 sched nready 239.000000
13 63.892848000 sched nsubmitted 246.000000
20 63.891932000 w3 WS B22_30 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 55
10 63.893379000 w0 WS "B"
10 63.893816000 w0 WS "B"
10 63.894244000 w0 WS "Fi"
10 63.895080000 w0 WS "B"
6 B22_31 WS B22_31 "0.000000 0.600000 0.400000"
6 B22_31_1 Ctx1 B22_31 "1.0 0.39 1.0"
6 B22_31_2 Ctx2 B22_31 ".0 1.0 .0"
6 B22_31_3 Ctx3 B22_31 "0.87 0.87 .0"
6 B22_31_4 Ctx4 B22_31 ".0 0.95 1.0"
6 B22_31_5 Ctx5 B22_31 ".0 .0 .0"
6 B22_31_6 Ctx6 B22_31 ".0 .0 0.5"
6 B22_31_7 Ctx7 B22_31 "0.41 0.41 0.41"
6 B22_31_8 Ctx8 B22_31 "1.0 .0 1.0"
6 B22_31_9 Ctx9 B22_31 ".0 .0 1.0"
10 63.895582000 w0 WS "B22_31"
20 63.895582000 w0 WS B22_31 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 56
10 63.938493000 w2 WS "B"
13 56.183082000 w2 gf 0.000000
13 63.938493000 w2 gf 0.000000
13 56.183082000 sched gft 0.000000
13 56.344431000 sched gft 0.000000
10 63.939121000 w2 WS "Po"
10 63.940006000 w2 WS "B"
10 63.942265000 w2 WS "P"
10 63.942783000 w2 WS "Sc"
13 63.943460000 sched nready 238.000000
13 63.943460000 sched nsubmitted 245.000000
10 63.943980000 w2 WS "B"
10 63.944396000 w2 WS "B"
10 63.944803000 w2 WS "Fi"
10 63.945541000 w2 WS "B"
6 B22_32 WS B22_32 "0.000000 0.600000 0.400000"
6 B22_32_1 Ctx1 B22_32 "1.0 0.39 1.0"
6 B22_32_2 Ctx2 B22_32 ".0 1.0 .0"
6 B22_32_3 Ctx3 B22_32 "0.87 0.87 .0"
6 B22_32_4 Ctx4 B22_32 ".0 0.95 1.0"
6 B22_32_5 Ctx5 B22_32 ".0 .0 .0"
6 B22_32_6 Ctx6 B22_32 ".0 .0 0.5"
6 B22_32_7 Ctx7 B22_32 "0.41 0.41 0.41"
6 B22_32_8 Ctx8 B22_32 "1.0 .0 1.0"
6 B22_32_9 Ctx9 B22_32 ".0 .0 1.0"
10 63.946002000 w2 WS "B22_32"
20 63.946002000 w2 WS B22_32 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 57
10 64.116106000 w1 WS "B"
13 56.356138000 w1 gf 0.000000
13 64.116106000 w1 gf 0.000000
13 56.356138000 sched gft 0.000000
13 57.961089000 sched gft 0.000000
10 64.116866000 w1 WS "Po"
10 64.117760000 w1 WS "B"
10 64.120406000 w1 WS "P"
10 64.121434000 w1 WS "Sc"
13 64.122178000 sched nready 237.000000
13 64.122178000 sched nsubmitted 244.000000
10 64.122683000 w1 WS "B"
10 64.123100000 w1 WS "B"
10 64.123522000 w1 WS "Fi"
10 64.124508000 w1 WS "B"
6 B22_33 WS B22_33 "0.000000 0.600000 0.400000"
6 B22_33_1 Ctx1 B22_33 "1.0 0.39 1.0"
6 B22_33_2 Ctx2 B22_33 ".0 1.0 .0"
6 B22_33_3 Ctx3 B22_33 "0.87 0.87 .0"
6 B22_33_4 Ctx4 B22_33 ".0 0.95 1.0"
6 B22_33_5 Ctx5 B22_33 ".0 .0 .0"
6 B22_33_6 Ctx6 B22_33 ".0 .0 0.5"
6 B22_33_7 Ctx7 B22_33 "0.41 0.41 0.41"
6 B22_33_8 Ctx8 B22_33 "1.0 .0 1.0"
6 B22_33_9 Ctx9 B22_33 ".0 .0 1.0"
10 64.125042000 w1 WS "B22_33"
20 64.125042000 w1 WS B22_33 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 58
10 65.645873000 w4 WS "B"
13 57.969228000 w4 gf 0.000000
13 65.645873000 w4 gf 0.000000
13 57.969228000 sched gft 0.000000
13 57.981807000 sched gft 0.000000
10 65.646468000 w4 WS "Po"
10 65.647392000 w4 WS "B"
10 65.649569000 w4 WS "P"
10 65.650177000 w4 WS "Sc"
13 65.650930000 sched nready 236.000000
13 65.650930000 sched nsubmitted 243.000000
10 65.651769000 w4 WS "B"
10 65.652182000 w4 WS "B"
10 65.652590000 w4 WS "Fi"
10 65.653442000 w4 WS "B"
6 B22_34 WS B22_34 "0.000000 0.600000 0.400000"
6 B22_34_1 Ctx1 B22_34 "1.0 0.39 1.0"
6 B22_34_2 Ctx2 B22_34 ".0 1.0 .0"
6 B22_34_3 Ctx3 B22_34 "0.87 0.87 .0"
6 B22_34_4 Ctx4 B22_34 ".0 0.95 1.0"
6 B22_34_5 Ctx5 B22_34 ".0 .0 .0"
6 B22_34_6 Ctx6 B22_34 ".0 .0 0.5"
6 B22_34_7 Ctx7 B22_34 "0.41 0.41 0.41"
6 B22_34_8 Ctx8 B22_34 "1.0 .0 1.0"
6 B22_34_9 Ctx9 B22_34 ".0 .0 1.0"
10 65.653930000 w4 WS "B22_34"
10 65.654820000 w5 WS "B"
13 57.989757000 w5 gf 0.000000
13 65.654820000 w5 gf 0.000000
13 57.989757000 sched gft 0.000000
13 63.881898000 sched gft 0.000000
13 63.887066000 sched gft 0.000000
20 65.653930000 w4 WS B22_34 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 59
10 65.655553000 w5 WS "Po"
10 65.656322000 w5 WS "B"
10 65.658493000 w5 WS "P"
10 65.659019000 w5 WS "Sc"
13 65.659807000 sched nready 235.000000
13 65.659807000 sched nsubmitted 242.000000
10 65.660317000 w5 WS "B"
10 65.660740000 w5 WS "B"
10 65.661151000 w5 WS "Fi"
10 65.662026000 w5 WS "B"
6 B22_35 WS B22_35 "0.000000 0.600000 0.400000"
6 B22_35_1 Ctx1 B22_35 "1.0 0.39 1.0"
6 B22_35_2 Ctx2 B22_35 ".0 1.0 .0"
6 B22_35_3 Ctx3 B22_35 "0.87 0.87 .0"
6 B22_35_4 Ctx4 B22_35 ".0 0.95 1.0"
6 B22_35_5 Ctx5 B22_35 ".0 .0 .0"
6 B22_35_6 Ctx6 B22_35 ".0 .0 0.5"
6 B22_35_7 Ctx7 B22_35 "0.41 0.41 0.41"
6 B22_35_8 Ctx8 B22_35 "1.0 .0 1.0"
6 B22_35_9 Ctx9 B22_35 ".0 .0 1.0"
10 65.662502000 w5 WS "B22_35"
20 65.662502000 w5 WS B22_35 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 60
10 71.609110000 w0 WS "B"
13 63.895582000 w0 gf 0.000000
13 71.609110000 w0 gf 0.000000
10 71.610111000 w0 WS "Po"
10 71.610733000 w3 WS "B"
13 63.891932000 w3 gf 0.000000
13 71.610733000 w3 gf 0.000000
13 63.891932000 sched gft 0.000000
13 63.895582000 sched gft 0.000000
13 63.938493000 sched gft 0.000000
10 71.611402000 w3 WS "Po"
10 71.611555000 w0 WS "B"
10 71.612236000 w3 WS "B"
10 71.616651000 w3 WS "P"
10 71.617016000 w0 WS "P"
10 71.617730000 w0 WS "Sc"
10 71.617789000 w3 WS "Sc"
13 71.619473000 sched nready 234.000000
13 71.619473000 sched nsubmitted 241.000000
10 71.620011000 w3 WS "B"
13 71.620104000 sched nready 233.000000
13 71.620104000 sched nsubmitted 240.000000
10 71.620424000 w3 WS "B"
10 71.620584000 w0 WS "B"
10 71.620894000 w3 WS "Fi"
10 71.621015000 w0 WS "B"
10 71.621445000 w0 WS "Fi"
10 71.621832000 w3 WS "B"
10 71.622332000 w0 WS "B"
6 B22_36 WS B22_36 "0.000000 0.600000 0.400000"
6 B22_36_1 Ctx1 B22_36 "1.0 0.39 1.0"
6 B22_36_2 Ctx2 B22_36 ".0 1.0 .0"
6 B22_36_3 Ctx3 B22_36 "0.87 0.87 .0"
6 B22_36_4 Ctx4 B22_36 ".0 0.95 1.0"
6 B22_36_5 Ctx5 B22_36 ".0 .0 .0"
6 B22_36_6 Ctx6 B22_36 ".0 .0 0.5"
6 B22_36_7 Ctx7 B22_36 "0.41 0.41 0.41"
6 B22_36_8 Ctx8 B22_36 "1.0 .0 1.0"
6 B22_36_9 Ctx9 B22_36 ".0 .0 1.0"
10 71.622521000 w3 WS "B22_36"
6 B22_37 WS B22_37 "0.000000 0.600000 0.400000"
6 B22_37_1 Ctx1 B22_37 "1.0 0.39 1.0"
6 B22_37_2 Ctx2 B22_37 ".0 1.0 .0"
6 B22_37_3 Ctx3 B22_37 "0.87 0.87 .0"
6 B22_37_4 Ctx4 B22_37 ".0 0.95 1.0"
6 B22_37_5 Ctx5 B22_37 ".0 .0 .0"
6 B22_37_6 Ctx6 B22_37 ".0 .0 0.5"
6 B22_37_7 Ctx7 B22_37 "0.41 0.41 0.41"
6 B22_37_8 Ctx8 B22_37 "1.0 .0 1.0"
6 B22_37_9 Ctx9 B22_37 ".0 .0 1.0"
10 71.622885000 w0 WS "B22_37"
20 71.622521000 w3 WS B22_36 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 61
20 71.622885000 w0 WS B22_37 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 62
10 71.661890000 w2 WS "B"
13 63.946002000 w2 gf 0.000000
13 71.661890000 w2 gf 0.000000
13 63.946002000 sched gft 0.000000
13 64.116106000 sched gft 0.000000
10 71.662424000 w2 WS "Po"
10 71.663291000 w2 WS "B"
10 71.665831000 w2 WS "P"
10 71.666391000 w2 WS "Sc"
13 71.667135000 sched nready 232.000000
13 71.667135000 sched nsubmitted 239.000000
10 71.667667000 w2 WS "B"
10 71.668116000 w2 WS "B"
10 71.668515000 w2 WS "Fi"
10 71.669389000 w2 WS "B"
6 B13_ea WS B13_ea "0.000000 0.600000 0.400000"
6 B13_ea_1 Ctx1 B13_ea "1.0 0.39 1.0"
6 B13_ea_2 Ctx2 B13_ea ".0 1.0 .0"
6 B13_ea_3 Ctx3 B13_ea "0.87 0.87 .0"
6 B13_ea_4 Ctx4 B13_ea ".0 0.95 1.0"
6 B13_ea_5 Ctx5 B13_ea ".0 .0 .0"
6 B13_ea_6 Ctx6 B13_ea ".0 .0 0.5"
6 B13_ea_7 Ctx7 B13_ea "0.41 0.41 0.41"
6 B13_ea_8 Ctx8 B13_ea "1.0 .0 1.0"
6 B13_ea_9 Ctx9 B13_ea ".0 .0 1.0"
10 71.670045000 w2 WS "B13_ea"
20 71.670045000 w2 WS B13_ea 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 19
10 71.672795000 w2 WS "B"
13 71.670045000 w2 gf 0.000000
13 71.672795000 w2 gf 0.000000
10 71.673238000 w2 WS "Po"
10 71.673989000 w2 WS "B"
13 71.677961000 sched nready 233.000000
11 71.678919000 w2 WS Sc
12 71.680063000 w2 WS
10 71.681132000 w2 WS "P"
10 71.681635000 w2 WS "Sc"
13 71.682218000 sched nready 232.000000
13 71.682218000 sched nsubmitted 238.000000
10 71.682683000 w2 WS "B"
10 71.683086000 w2 WS "B"
10 71.683482000 w2 WS "Fi"
10 71.684279000 w2 WS "B"
6 B11_we WS B11_we "0.000000 0.600000 0.400000"
6 B11_we_1 Ctx1 B11_we "1.0 0.39 1.0"
6 B11_we_2 Ctx2 B11_we ".0 1.0 .0"
6 B11_we_3 Ctx3 B11_we "0.87 0.87 .0"
6 B11_we_4 Ctx4 B11_we ".0 0.95 1.0"
6 B11_we_5 Ctx5 B11_we ".0 .0 .0"
6 B11_we_6 Ctx6 B11_we ".0 .0 0.5"
6 B11_we_7 Ctx7 B11_we "0.41 0.41 0.41"
6 B11_we_8 Ctx8 B11_we "1.0 .0 1.0"
6 B11_we_9 Ctx9 B11_we ".0 .0 1.0"
10 71.684771000 w2 WS "B11_we"
20 71.684771000 w2 WS B11_we 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 11
10 71.687085000 w2 WS "B"
13 71.684771000 w2 gf 0.000000
13 71.687085000 w2 gf 0.000000
10 71.687541000 w2 WS "Po"
10 71.688193000 w2 WS "B"
13 71.690151000 sched nready 233.000000
11 71.690549000 w2 WS Sc
12 71.691049000 w2 WS
10 71.692090000 w2 WS "P"
10 71.692572000 w2 WS "Sc"
13 71.693079000 sched nready 232.000000
13 71.693079000 sched nsubmitted 237.000000
10 71.693579000 w2 WS "B"
10 71.693976000 w2 WS "B"
10 71.694366000 w2 WS "Fi"
10 71.695541000 w2 WS "B"
6 B22_38 WS B22_38 "0.000000 0.600000 0.400000"
6 B22_38_1 Ctx1 B22_38 "1.0 0.39 1.0"
6 B22_38_2 Ctx2 B22_38 ".0 1.0 .0"
6 B22_38_3 Ctx3 B22_38 "0.87 0.87 .0"
6 B22_38_4 Ctx4 B22_38 ".0 0.95 1.0"
6 B22_38_5 Ctx5 B22_38 ".0 .0 .0"
6 B22_38_6 Ctx6 B22_38 ".0 .0 0.5"
6 B22_38_7 Ctx7 B22_38 "0.41 0.41 0.41"
6 B22_38_8 Ctx8 B22_38 "1.0 .0 1.0"
6 B22_38_9 Ctx9 B22_38 ".0 .0 1.0"
10 71.696023000 w2 WS "B22_38"
20 71.696023000 w2 WS B22_38 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 63
10 71.790417000 w1 WS "B"
13 64.125042000 w1 gf 0.000000
13 71.790417000 w1 gf 0.000000
13 64.125042000 sched gft 0.000000
13 65.645873000 sched gft 0.000000
10 71.790950000 w1 WS "Po"
10 71.792083000 w1 WS "B"
10 71.794146000 w1 WS "P"
10 71.794720000 w1 WS "Sc"
13 71.795519000 sched nready 231.000000
13 71.795519000 sched nsubmitted 236.000000
10 71.795977000 w1 WS "B"
10 71.796391000 w1 WS "B"
10 71.796800000 w1 WS "Fi"
10 71.797650000 w1 WS "B"
6 B21_we WS B21_we "0.000000 0.600000 0.400000"
6 B21_we_1 Ctx1 B21_we "1.0 0.39 1.0"
6 B21_we_2 Ctx2 B21_we ".0 1.0 .0"
6 B21_we_3 Ctx3 B21_we "0.87 0.87 .0"
6 B21_we_4 Ctx4 B21_we ".0 0.95 1.0"
6 B21_we_5 Ctx5 B21_we ".0 .0 .0"
6 B21_we_6 Ctx6 B21_we ".0 .0 0.5"
6 B21_we_7 Ctx7 B21_we "0.41 0.41 0.41"
6 B21_we_8 Ctx8 B21_we "1.0 .0 1.0"
6 B21_we_9 Ctx9 B21_we ".0 .0 1.0"
10 71.798187000 w1 WS "B21_we"
20 71.798187000 w1 WS B21_we 131160
M1x8192x8_M1x8194x8_M3x3x8 168cba74 0000000000000000 22
10 71.921386000 w1 WS "B"
13 71.798187000 w1 gf 0.000000
13 71.921386000 w1 gf 0.000000
10 71.921861000 w1 WS "Po"
10 71.922492000 w1 WS "B"
13 71.925321000 sched nready 232.000000
11 71.926053000 w1 WS Sc
12 71.926902000 w1 WS
10 71.928044000 w1 WS "P"
10 71.928549000 w1 WS "Sc"
13 71.929050000 sched nready 231.000000
13 71.929050000 sched nsubmitted 235.000000
10 71.929513000 w1 WS "B"
10 71.929926000 w1 WS "B"
10 71.930329000 w1 WS "Fi"
10 71.931169000 w1 WS "B"
6 B22_39 WS B22_39 "0.000000 0.600000 0.400000"
6 B22_39_1 Ctx1 B22_39 "1.0 0.39 1.0"
6 B22_39_2 Ctx2 B22_39 ".0 1.0 .0"
6 B22_39_3 Ctx3 B22_39 "0.87 0.87 .0"
6 B22_39_4 Ctx4 B22_39 ".0 0.95 1.0"
6 B22_39_5 Ctx5 B22_39 ".0 .0 .0"
6 B22_39_6 Ctx6 B22_39 ".0 .0 0.5"
6 B22_39_7 Ctx7 B22_39 "0.41 0.41 0.41"
6 B22_39_8 Ctx8 B22_39 "1.0 .0 1.0"
6 B22_39_9 Ctx9 B22_39 ".0 .0 1.0"
10 71.931620000 w1 WS "B22_39"
20 71.931620000 w1 WS B22_39 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 64
10 73.341040000 w4 WS "B"
13 65.653930000 w4 gf 0.000000
13 73.341040000 w4 gf 0.000000
13 65.653930000 sched gft 0.000000
13 65.654820000 sched gft 0.000000
10 73.341604000 w4 WS "Po"
10 73.342352000 w4 WS "B"
10 73.344874000 w4 WS "P"
10 73.345512000 w4 WS "Sc"
13 73.346261000 sched nready 230.000000
13 73.346261000 sched nsubmitted 234.000000
10 73.346880000 w4 WS "B"
10 73.347288000 w4 WS "B"
10 73.347692000 w4 WS "Fi"
10 73.348506000 w4 WS "B"
6 B22_40 WS B22_40 "0.000000 0.600000 0.400000"
6 B22_40_1 Ctx1 B22_40 "1.0 0.39 1.0"
6 B22_40_2 Ctx2 B22_40 ".0 1.0 .0"
6 B22_40_3 Ctx3 B22_40 "0.87 0.87 .0"
6 B22_40_4 Ctx4 B22_40 ".0 0.95 1.0"
6 B22_40_5 Ctx5 B22_40 ".0 .0 .0"
6 B22_40_6 Ctx6 B22_40 ".0 .0 0.5"
6 B22_40_7 Ctx7 B22_40 "0.41 0.41 0.41"
6 B22_40_8 Ctx8 B22_40 "1.0 .0 1.0"
6 B22_40_9 Ctx9 B22_40 ".0 .0 1.0"
10 73.349006000 w4 WS "B22_40"
20 73.349006000 w4 WS B22_40 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 65
10 73.366614000 w5 WS "B"
13 65.662502000 w5 gf 0.000000
13 73.366614000 w5 gf 0.000000
13 65.662502000 sched gft 0.000000
13 71.609110000 sched gft 0.000000
13 71.610733000 sched gft 0.000000
10 73.367335000 w5 WS "Po"
10 73.368118000 w5 WS "B"
10 73.370702000 w5 WS "P"
10 73.371352000 w5 WS "Sc"
13 73.372090000 sched nready 229.000000
13 73.372090000 sched nsubmitted 233.000000
10 73.372582000 w5 WS "B"
10 73.372998000 w5 WS "B"
10 73.373417000 w5 WS "Fi"
10 73.374292000 w5 WS "B"
6 B22_41 WS B22_41 "0.000000 0.600000 0.400000"
6 B22_41_1 Ctx1 B22_41 "1.0 0.39 1.0"
6 B22_41_2 Ctx2 B22_41 ".0 1.0 .0"
6 B22_41_3 Ctx3 B22_41 "0.87 0.87 .0"
6 B22_41_4 Ctx4 B22_41 ".0 0.95 1.0"
6 B22_41_5 Ctx5 B22_41 ".0 .0 .0"
6 B22_41_6 Ctx6 B22_41 ".0 .0 0.5"
6 B22_41_7 Ctx7 B22_41 "0.41 0.41 0.41"
6 B22_41_8 Ctx8 B22_41 "1.0 .0 1.0"
6 B22_41_9 Ctx9 B22_41 ".0 .0 1.0"
10 73.374827000 w5 WS "B22_41"
20 73.374827000 w5 WS B22_41 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 66
10 79.311013000 w3 WS "B"
13 71.622521000 w3 gf 0.000000
13 79.311013000 w3 gf 0.000000
13 71.622521000 sched gft 0.000000
10 79.311994000 w3 WS "Po"
10 79.313003000 w3 WS "B"
10 79.315918000 w3 WS "P"
10 79.316781000 w3 WS "Sc"
10 79.317329000 w0 WS "B"
13 71.622885000 w0 gf 0.000000
13 79.317329000 w0 gf 0.000000
13 71.622885000 sched gft 0.000000
13 71.661890000 sched gft 0.000000
13 71.670045000 sched gft 0.000000
13 71.672795000 sched gft 0.000000
13 71.684771000 sched gft 0.000000
13 71.687085000 sched gft 0.000000
13 79.317753000 sched nready 228.000000
13 79.317753000 sched nsubmitted 232.000000
10 79.318041000 w0 WS "Po"
10 79.318588000 w3 WS "B"
10 79.318979000 w0 WS "B"
10 79.319140000 w3 WS "B"
10 79.319558000 w3 WS "Fi"
10 79.321134000 w3 WS "B"
10 79.321508000 w0 WS "P"
6 B22_42 WS B22_42 "0.000000 0.600000 0.400000"
6 B22_42_1 Ctx1 B22_42 "1.0 0.39 1.0"
6 B22_42_2 Ctx2 B22_42 ".0 1.0 .0"
6 B22_42_3 Ctx3 B22_42 "0.87 0.87 .0"
6 B22_42_4 Ctx4 B22_42 ".0 0.95 1.0"
6 B22_42_5 Ctx5 B22_42 ".0 .0 .0"
6 B22_42_6 Ctx6 B22_42 ".0 .0 0.5"
6 B22_42_7 Ctx7 B22_42 "0.41 0.41 0.41"
6 B22_42_8 Ctx8 B22_42 "1.0 .0 1.0"
6 B22_42_9 Ctx9 B22_42 ".0 .0 1.0"
10 79.321724000 w3 WS "B22_42"
10 79.322133000 w0 WS "Sc"
13 79.322929000 sched nready 227.000000
13 79.322929000 sched nsubmitted 231.000000
20 79.321724000 w3 WS B22_42 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 67
10 79.323443000 w0 WS "B"
10 79.323866000 w0 WS "B"
10 79.324289000 w0 WS "Fi"
10 79.325128000 w0 WS "B"
6 B22_43 WS B22_43 "0.000000 0.600000 0.400000"
6 B22_43_1 Ctx1 B22_43 "1.0 0.39 1.0"
6 B22_43_2 Ctx2 B22_43 ".0 1.0 .0"
6 B22_43_3 Ctx3 B22_43 "0.87 0.87 .0"
6 B22_43_4 Ctx4 B22_43 ".0 0.95 1.0"
6 B22_43_5 Ctx5 B22_43 ".0 .0 .0"
6 B22_43_6 Ctx6 B22_43 ".0 .0 0.5"
6 B22_43_7 Ctx7 B22_43 "0.41 0.41 0.41"
6 B22_43_8 Ctx8 B22_43 "1.0 .0 1.0"
6 B22_43_9 Ctx9 B22_43 ".0 .0 1.0"
10 79.325633000 w0 WS "B22_43"
20 79.325633000 w0 WS B22_43 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 68
10 79.360046000 w2 WS "B"
13 71.696023000 w2 gf 0.000000
13 79.360046000 w2 gf 0.000000
13 71.696023000 sched gft 0.000000
13 71.790417000 sched gft 0.000000
13 71.798187000 sched gft 0.000000
13 71.921386000 sched gft 0.000000
10 79.360573000 w2 WS "Po"
10 79.361355000 w2 WS "B"
10 79.363465000 w2 WS "P"
10 79.363975000 w2 WS "Sc"
13 79.364574000 sched nready 226.000000
13 79.364574000 sched nsubmitted 230.000000
10 79.365079000 w2 WS "B"
10 79.365497000 w2 WS "B"
10 79.365902000 w2 WS "Fi"
10 79.366699000 w2 WS "B"
6 B22_44 WS B22_44 "0.000000 0.600000 0.400000"
6 B22_44_1 Ctx1 B22_44 "1.0 0.39 1.0"
6 B22_44_2 Ctx2 B22_44 ".0 1.0 .0"
6 B22_44_3 Ctx3 B22_44 "0.87 0.87 .0"
6 B22_44_4 Ctx4 B22_44 ".0 0.95 1.0"
6 B22_44_5 Ctx5 B22_44 ".0 .0 .0"
6 B22_44_6 Ctx6 B22_44 ".0 .0 0.5"
6 B22_44_7 Ctx7 B22_44 "0.41 0.41 0.41"
6 B22_44_8 Ctx8 B22_44 "1.0 .0 1.0"
6 B22_44_9 Ctx9 B22_44 ".0 .0 1.0"
10 79.367178000 w2 WS "B22_44"
20 79.367178000 w2 WS B22_44 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 69
10 79.586704000 w1 WS "B"
13 71.931620000 w1 gf 0.000000
13 79.586704000 w1 gf 0.000000
13 71.931620000 sched gft 0.000000
13 73.341040000 sched gft 0.000000
10 79.587313000 w1 WS "Po"
10 79.588190000 w1 WS "B"
10 79.590376000 w1 WS "P"
10 79.590913000 w1 WS "Sc"
13 79.591532000 sched nready 225.000000
13 79.591532000 sched nsubmitted 229.000000
10 79.592000000 w1 WS "B"
10 79.592421000 w1 WS "B"
10 79.592827000 w1 WS "Fi"
10 79.593722000 w1 WS "B"
6 B22_45 WS B22_45 "0.000000 0.600000 0.400000"
6 B22_45_1 Ctx1 B22_45 "1.0 0.39 1.0"
6 B22_45_2 Ctx2 B22_45 ".0 1.0 .0"
6 B22_45_3 Ctx3 B22_45 "0.87 0.87 .0"
6 B22_45_4 Ctx4 B22_45 ".0 0.95 1.0"
6 B22_45_5 Ctx5 B22_45 ".0 .0 .0"
6 B22_45_6 Ctx6 B22_45 ".0 .0 0.5"
6 B22_45_7 Ctx7 B22_45 "0.41 0.41 0.41"
6 B22_45_8 Ctx8 B22_45 "1.0 .0 1.0"
6 B22_45_9 Ctx9 B22_45 ".0 .0 1.0"
10 79.594200000 w1 WS "B22_45"
20 79.594200000 w1 WS B22_45 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 70
10 81.052080000 w5 WS "B"
13 73.374827000 w5 gf 0.000000
13 81.052080000 w5 gf 0.000000
10 81.052675000 w5 WS "Po"
10 81.053508000 w5 WS "B"
10 81.055604000 w5 WS "P"
10 81.056146000 w5 WS "Sc"
13 81.056805000 sched nready 224.000000
13 81.056805000 sched nsubmitted 228.000000
10 81.057334000 w5 WS "B"
10 81.057759000 w5 WS "B"
10 81.058163000 w5 WS "Fi"
10 81.059058000 w5 WS "B"
6 B22_46 WS B22_46 "0.000000 0.600000 0.400000"
6 B22_46_1 Ctx1 B22_46 "1.0 0.39 1.0"
6 B22_46_2 Ctx2 B22_46 ".0 1.0 .0"
6 B22_46_3 Ctx3 B22_46 "0.87 0.87 .0"
6 B22_46_4 Ctx4 B22_46 ".0 0.95 1.0"
6 B22_46_5 Ctx5 B22_46 ".0 .0 .0"
6 B22_46_6 Ctx6 B22_46 ".0 .0 0.5"
6 B22_46_7 Ctx7 B22_46 "0.41 0.41 0.41"
6 B22_46_8 Ctx8 B22_46 "1.0 .0 1.0"
6 B22_46_9 Ctx9 B22_46 ".0 .0 1.0"
10 81.059587000 w5 WS "B22_46"
20 81.059587000 w5 WS B22_46 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 71
10 81.135984000 w4 WS "B"
13 73.349006000 w4 gf 0.000000
13 81.135984000 w4 gf 0.000000
13 73.349006000 sched gft 0.000000
13 73.366614000 sched gft 0.000000
13 73.374827000 sched gft 0.000000
13 79.311013000 sched gft 0.000000
13 79.317329000 sched gft 0.000000
10 81.136556000 w4 WS "Po"
10 81.137390000 w4 WS "B"
10 81.139737000 w4 WS "P"
10 81.140395000 w4 WS "Sc"
13 81.141056000 sched nready 223.000000
13 81.141056000 sched nsubmitted 227.000000
10 81.141811000 w4 WS "B"
10 81.142222000 w4 WS "B"
10 81.142633000 w4 WS "Fi"
10 81.143421000 w4 WS "B"
6 B22_47 WS B22_47 "0.000000 0.600000 0.400000"
6 B22_47_1 Ctx1 B22_47 "1.0 0.39 1.0"
6 B22_47_2 Ctx2 B22_47 ".0 1.0 .0"
6 B22_47_3 Ctx3 B22_47 "0.87 0.87 .0"
6 B22_47_4 Ctx4 B22_47 ".0 0.95 1.0"
6 B22_47_5 Ctx5 B22_47 ".0 .0 .0"
6 B22_47_6 Ctx6 B22_47 ".0 .0 0.5"
6 B22_47_7 Ctx7 B22_47 "0.41 0.41 0.41"
6 B22_47_8 Ctx8 B22_47 "1.0 .0 1.0"
6 B22_47_9 Ctx9 B22_47 ".0 .0 1.0"
10 81.143931000 w4 WS "B22_47"
20 81.143931000 w4 WS B22_47 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 72
10 87.022598000 w2 WS "B"
13 79.367178000 w2 gf 0.000000
13 87.022598000 w2 gf 0.000000
10 87.022712000 w0 WS "B"
13 79.325633000 w0 gf 0.000000
13 87.022712000 w0 gf 0.000000
10 87.023310000 w2 WS "Po"
10 87.023452000 w0 WS "Po"
10 87.024242000 w2 WS "B"
10 87.024549000 w0 WS "B"
10 87.026743000 w2 WS "P"
10 87.027321000 w0 WS "P"
10 87.027509000 w2 WS "Sc"
10 87.028006000 w0 WS "Sc"
13 87.028302000 sched nready 222.000000
13 87.028302000 sched nsubmitted 226.000000
13 87.028761000 sched nready 221.000000
13 87.028761000 sched nsubmitted 225.000000
10 87.029261000 w2 WS "B"
10 87.029305000 w0 WS "B"
10 87.029676000 w2 WS "B"
10 87.029748000 w0 WS "B"
10 87.030243000 w2 WS "Fi"
10 87.030308000 w0 WS "Fi"
10 87.031401000 w2 WS "B"
10 87.031477000 w0 WS "B"
6 B22_48 WS B22_48 "0.000000 0.600000 0.400000"
6 B22_48_1 Ctx1 B22_48 "1.0 0.39 1.0"
6 B22_48_2 Ctx2 B22_48 ".0 1.0 .0"
6 B22_48_3 Ctx3 B22_48 "0.87 0.87 .0"
6 B22_48_4 Ctx4 B22_48 ".0 0.95 1.0"
6 B22_48_5 Ctx5 B22_48 ".0 .0 .0"
6 B22_48_6 Ctx6 B22_48 ".0 .0 0.5"
6 B22_48_7 Ctx7 B22_48 "0.41 0.41 0.41"
6 B22_48_8 Ctx8 B22_48 "1.0 .0 1.0"
6 B22_48_9 Ctx9 B22_48 ".0 .0 1.0"
10 87.032034000 w2 WS "B22_48"
6 B22_49 WS B22_49 "0.000000 0.600000 0.400000"
6 B22_49_1 Ctx1 B22_49 "1.0 0.39 1.0"
6 B22_49_2 Ctx2 B22_49 ".0 1.0 .0"
6 B22_49_3 Ctx3 B22_49 "0.87 0.87 .0"
6 B22_49_4 Ctx4 B22_49 ".0 0.95 1.0"
6 B22_49_5 Ctx5 B22_49 ".0 .0 .0"
6 B22_49_6 Ctx6 B22_49 ".0 .0 0.5"
6 B22_49_7 Ctx7 B22_49 "0.41 0.41 0.41"
6 B22_49_8 Ctx8 B22_49 "1.0 .0 1.0"
6 B22_49_9 Ctx9 B22_49 ".0 .0 1.0"
10 87.032102000 w0 WS "B22_49"
20 87.032034000 w2 WS B22_48 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 73
20 87.032102000 w0 WS B22_49 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 74
10 87.050806000 w3 WS "B"
13 79.321724000 w3 gf 0.000000
13 87.050806000 w3 gf 0.000000
13 79.321724000 sched gft 0.000000
13 79.325633000 sched gft 0.000000
13 79.360046000 sched gft 0.000000
13 79.367178000 sched gft 0.000000
13 79.586704000 sched gft 0.000000
10 87.051386000 w3 WS "Po"
10 87.052308000 w3 WS "B"
10 87.054543000 w3 WS "P"
10 87.055081000 w3 WS "Sc"
13 87.055767000 sched nready 220.000000
13 87.055767000 sched nsubmitted 224.000000
10 87.056413000 w3 WS "B"
10 87.056819000 w3 WS "B"
10 87.057224000 w3 WS "Fi"
10 87.058128000 w3 WS "B"
6 B22_50 WS B22_50 "0.000000 0.600000 0.400000"
6 B22_50_1 Ctx1 B22_50 "1.0 0.39 1.0"
6 B22_50_2 Ctx2 B22_50 ".0 1.0 .0"
6 B22_50_3 Ctx3 B22_50 "0.87 0.87 .0"
6 B22_50_4 Ctx4 B22_50 ".0 0.95 1.0"
6 B22_50_5 Ctx5 B22_50 ".0 .0 .0"
6 B22_50_6 Ctx6 B22_50 ".0 .0 0.5"
6 B22_50_7 Ctx7 B22_50 "0.41 0.41 0.41"
6 B22_50_8 Ctx8 B22_50 "1.0 .0 1.0"
6 B22_50_9 Ctx9 B22_50 ".0 .0 1.0"
10 87.058615000 w3 WS "B22_50"
20 87.058615000 w3 WS B22_50 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 75
10 87.246694000 w1 WS "B"
13 79.594200000 w1 gf 0.000000
13 87.246694000 w1 gf 0.000000
13 79.594200000 sched gft 0.000000
13 81.052080000 sched gft 0.000000
10 87.247606000 w1 WS "Po"
10 87.248432000 w1 WS "B"
10 87.250624000 w1 WS "P"
10 87.251155000 w1 WS "Sc"
13 87.251796000 sched nready 219.000000
13 87.251796000 sched nsubmitted 223.000000
10 87.252319000 w1 WS "B"
10 87.252733000 w1 WS "B"
10 87.253141000 w1 WS "Fi"
10 87.253927000 w1 WS "B"
6 B22_51 WS B22_51 "0.000000 0.600000 0.400000"
6 B22_51_1 Ctx1 B22_51 "1.0 0.39 1.0"
6 B22_51_2 Ctx2 B22_51 ".0 1.0 .0"
6 B22_51_3 Ctx3 B22_51 "0.87 0.87 .0"
6 B22_51_4 Ctx4 B22_51 ".0 0.95 1.0"
6 B22_51_5 Ctx5 B22_51 ".0 .0 .0"
6 B22_51_6 Ctx6 B22_51 ".0 .0 0.5"
6 B22_51_7 Ctx7 B22_51 "0.41 0.41 0.41"
6 B22_51_8 Ctx8 B22_51 "1.0 .0 1.0"
6 B22_51_9 Ctx9 B22_51 ".0 .0 1.0"
10 87.254404000 w1 WS "B22_51"
20 87.254404000 w1 WS B22_51 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 76
10 88.735665000 w5 WS "B"
13 81.059587000 w5 gf 0.000000
13 88.735665000 w5 gf 0.000000
13 81.059587000 sched gft 0.000000
13 81.135984000 sched gft 0.000000
10 88.736383000 w5 WS "Po"
10 88.737287000 w5 WS "B"
10 88.739502000 w5 WS "P"
10 88.740105000 w5 WS "Sc"
13 88.740765000 sched nready 218.000000
13 88.740765000 sched nsubmitted 222.000000
10 88.741260000 w5 WS "B"
10 88.741677000 w5 WS "B"
10 88.742079000 w5 WS "Fi"
10 88.742941000 w5 WS "B"
6 B22_52 WS B22_52 "0.000000 0.600000 0.400000"
6 B22_52_1 Ctx1 B22_52 "1.0 0.39 1.0"
6 B22_52_2 Ctx2 B22_52 ".0 1.0 .0"
6 B22_52_3 Ctx3 B22_52 "0.87 0.87 .0"
6 B22_52_4 Ctx4 B22_52 ".0 0.95 1.0"
6 B22_52_5 Ctx5 B22_52 ".0 .0 .0"
6 B22_52_6 Ctx6 B22_52 ".0 .0 0.5"
6 B22_52_7 Ctx7 B22_52 "0.41 0.41 0.41"
6 B22_52_8 Ctx8 B22_52 "1.0 .0 1.0"
6 B22_52_9 Ctx9 B22_52 ".0 .0 1.0"
10 88.743421000 w5 WS "B22_52"
20 88.743421000 w5 WS B22_52 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 77
10 88.797004000 w4 WS "B"
13 81.143931000 w4 gf 0.000000
13 88.797004000 w4 gf 0.000000
13 81.143931000 sched gft 0.000000
13 87.022598000 sched gft 0.000000
13 87.022712000 sched gft 0.000000
10 88.797635000 w4 WS "Po"
10 88.798404000 w4 WS "B"
10 88.800692000 w4 WS "P"
10 88.801266000 w4 WS "Sc"
13 88.801970000 sched nready 217.000000
13 88.801970000 sched nsubmitted 221.000000
10 88.802443000 w4 WS "B"
10 88.802856000 w4 WS "B"
10 88.803260000 w4 WS "Fi"
10 88.804138000 w4 WS "B"
6 B22_53 WS B22_53 "0.000000 0.600000 0.400000"
6 B22_53_1 Ctx1 B22_53 "1.0 0.39 1.0"
6 B22_53_2 Ctx2 B22_53 ".0 1.0 .0"
6 B22_53_3 Ctx3 B22_53 "0.87 0.87 .0"
6 B22_53_4 Ctx4 B22_53 ".0 0.95 1.0"
6 B22_53_5 Ctx5 B22_53 ".0 .0 .0"
6 B22_53_6 Ctx6 B22_53 ".0 .0 0.5"
6 B22_53_7 Ctx7 B22_53 "0.41 0.41 0.41"
6 B22_53_8 Ctx8 B22_53 "1.0 .0 1.0"
6 B22_53_9 Ctx9 B22_53 ".0 .0 1.0"
10 88.804631000 w4 WS "B22_53"
20 88.804631000 w4 WS B22_53 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 78
10 94.737128000 w2 WS "B"
13 87.032034000 w2 gf 0.000000
13 94.737128000 w2 gf 0.000000
13 87.032034000 sched gft 0.000000
10 94.737986000 w2 WS "Po"
10 94.738842000 w2 WS "B"
10 94.745725000 w0 WS "B"
13 87.032102000 w0 gf 0.000000
13 94.745725000 w0 gf 0.000000
13 87.032102000 sched gft 0.000000
13 87.050806000 sched gft 0.000000
10 94.746470000 w0 WS "Po"
10 94.747247000 w2 WS "P"
10 94.747326000 w0 WS "B"
10 94.748041000 w2 WS "Sc"
13 94.749045000 sched nready 216.000000
13 94.749045000 sched nsubmitted 220.000000
10 94.749633000 w2 WS "B"
10 94.749963000 w3 WS "B"
13 87.058615000 w3 gf 0.000000
13 94.749963000 w3 gf 0.000000
13 87.058615000 sched gft 0.000000
13 87.246694000 sched gft 0.000000
10 94.750015000 w0 WS "P"
10 94.750216000 w2 WS "B"
10 94.750649000 w3 WS "Po"
10 94.750697000 w0 WS "Sc"
10 94.750746000 w2 WS "Fi"
13 94.751454000 sched nready 215.000000
13 94.751454000 sched nsubmitted 219.000000
10 94.751638000 w3 WS "B"
10 94.752031000 w2 WS "B"
10 94.752108000 w0 WS "B"
10 94.752582000 w0 WS "B"
6 B22_54 WS B22_54 "0.000000 0.600000 0.400000"
6 B22_54_1 Ctx1 B22_54 "1.0 0.39 1.0"
6 B22_54_2 Ctx2 B22_54 ".0 1.0 .0"
6 B22_54_3 Ctx3 B22_54 "0.87 0.87 .0"
6 B22_54_4 Ctx4 B22_54 ".0 0.95 1.0"
6 B22_54_5 Ctx5 B22_54 ".0 .0 .0"
6 B22_54_6 Ctx6 B22_54 ".0 .0 0.5"
6 B22_54_7 Ctx7 B22_54 "0.41 0.41 0.41"
6 B22_54_8 Ctx8 B22_54 "1.0 .0 1.0"
6 B22_54_9 Ctx9 B22_54 ".0 .0 1.0"
10 94.752770000 w2 WS "B22_54"
10 94.753017000 w0 WS "Fi"
10 94.754089000 w0 WS "B"
10 94.754296000 w3 WS "P"
20 94.752770000 w2 WS B22_54 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 79
6 B22_55 WS B22_55 "0.000000 0.600000 0.400000"
6 B22_55_1 Ctx1 B22_55 "1.0 0.39 1.0"
6 B22_55_2 Ctx2 B22_55 ".0 1.0 .0"
6 B22_55_3 Ctx3 B22_55 "0.87 0.87 .0"
6 B22_55_4 Ctx4 B22_55 ".0 0.95 1.0"
6 B22_55_5 Ctx5 B22_55 ".0 .0 .0"
6 B22_55_6 Ctx6 B22_55 ".0 .0 0.5"
6 B22_55_7 Ctx7 B22_55 "0.41 0.41 0.41"
6 B22_55_8 Ctx8 B22_55 "1.0 .0 1.0"
6 B22_55_9 Ctx9 B22_55 ".0 .0 1.0"
10 94.754592000 w0 WS "B22_55"
10 94.754902000 w3 WS "Sc"
13 94.755675000 sched nready 214.000000
13 94.755675000 sched nsubmitted 218.000000
20 94.754592000 w0 WS B22_55 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 80
10 94.756244000 w3 WS "B"
10 94.756665000 w3 WS "B"
10 94.757068000 w3 WS "Fi"
10 94.758107000 w3 WS "B"
6 B22_56 WS B22_56 "0.000000 0.600000 0.400000"
6 B22_56_1 Ctx1 B22_56 "1.0 0.39 1.0"
6 B22_56_2 Ctx2 B22_56 ".0 1.0 .0"
6 B22_56_3 Ctx3 B22_56 "0.87 0.87 .0"
6 B22_56_4 Ctx4 B22_56 ".0 0.95 1.0"
6 B22_56_5 Ctx5 B22_56 ".0 .0 .0"
6 B22_56_6 Ctx6 B22_56 ".0 .0 0.5"
6 B22_56_7 Ctx7 B22_56 "0.41 0.41 0.41"
6 B22_56_8 Ctx8 B22_56 "1.0 .0 1.0"
6 B22_56_9 Ctx9 B22_56 ".0 .0 1.0"
10 94.758664000 w3 WS "B22_56"
20 94.758664000 w3 WS B22_56 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 81
10 94.934502000 w1 WS "B"
13 87.254404000 w1 gf 0.000000
13 94.934502000 w1 gf 0.000000
13 87.254404000 sched gft 0.000000
13 88.735665000 sched gft 0.000000
10 94.935067000 w1 WS "Po"
10 94.935848000 w1 WS "B"
10 94.937974000 w1 WS "P"
10 94.938533000 w1 WS "Sc"
13 94.939158000 sched nready 213.000000
13 94.939158000 sched nsubmitted 217.000000
10 94.939666000 w1 WS "B"
10 94.940086000 w1 WS "B"
10 94.940497000 w1 WS "Fi"
10 94.941664000 w1 WS "B"
6 B22_57 WS B22_57 "0.000000 0.600000 0.400000"
6 B22_57_1 Ctx1 B22_57 "1.0 0.39 1.0"
6 B22_57_2 Ctx2 B22_57 ".0 1.0 .0"
6 B22_57_3 Ctx3 B22_57 "0.87 0.87 .0"
6 B22_57_4 Ctx4 B22_57 ".0 0.95 1.0"
6 B22_57_5 Ctx5 B22_57 ".0 .0 .0"
6 B22_57_6 Ctx6 B22_57 ".0 .0 0.5"
6 B22_57_7 Ctx7 B22_57 "0.41 0.41 0.41"
6 B22_57_8 Ctx8 B22_57 "1.0 .0 1.0"
6 B22_57_9 Ctx9 B22_57 ".0 .0 1.0"
10 94.942181000 w1 WS "B22_57"
20 94.942181000 w1 WS B22_57 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 82
10 96.486492000 w5 WS "B"
13 88.743421000 w5 gf 0.000000
13 96.486492000 w5 gf 0.000000
13 88.743421000 sched gft 0.000000
13 88.797004000 sched gft 0.000000
10 96.487046000 w5 WS "Po"
10 96.487775000 w5 WS "B"
10 96.489940000 w5 WS "P"
10 96.490496000 w5 WS "Sc"
13 96.491177000 sched nready 212.000000
13 96.491177000 sched nsubmitted 216.000000
10 96.491708000 w5 WS "B"
10 96.492133000 w5 WS "B"
10 96.492534000 w5 WS "Fi"
10 96.493385000 w5 WS "B"
6 B22_58 WS B22_58 "0.000000 0.600000 0.400000"
6 B22_58_1 Ctx1 B22_58 "1.0 0.39 1.0"
6 B22_58_2 Ctx2 B22_58 ".0 1.0 .0"
6 B22_58_3 Ctx3 B22_58 "0.87 0.87 .0"
6 B22_58_4 Ctx4 B22_58 ".0 0.95 1.0"
6 B22_58_5 Ctx5 B22_58 ".0 .0 .0"
6 B22_58_6 Ctx6 B22_58 ".0 .0 0.5"
6 B22_58_7 Ctx7 B22_58 "0.41 0.41 0.41"
6 B22_58_8 Ctx8 B22_58 "1.0 .0 1.0"
6 B22_58_9 Ctx9 B22_58 ".0 .0 1.0"
10 96.493873000 w5 WS "B22_58"
20 96.493873000 w5 WS B22_58 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 83
10 96.521457000 w4 WS "B"
13 88.804631000 w4 gf 0.000000
13 96.521457000 w4 gf 0.000000
13 88.804631000 sched gft 0.000000
13 94.737128000 sched gft 0.000000
13 94.745725000 sched gft 0.000000
13 94.749963000 sched gft 0.000000
10 96.522011000 w4 WS "Po"
10 96.522727000 w4 WS "B"
10 96.525020000 w4 WS "P"
10 96.525556000 w4 WS "Sc"
13 96.526188000 sched nready 211.000000
13 96.526188000 sched nsubmitted 215.000000
10 96.526734000 w4 WS "B"
10 96.527145000 w4 WS "B"
10 96.527562000 w4 WS "Fi"
10 96.528413000 w4 WS "B"
6 B22_59 WS B22_59 "0.000000 0.600000 0.400000"
6 B22_59_1 Ctx1 B22_59 "1.0 0.39 1.0"
6 B22_59_2 Ctx2 B22_59 ".0 1.0 .0"
6 B22_59_3 Ctx3 B22_59 "0.87 0.87 .0"
6 B22_59_4 Ctx4 B22_59 ".0 0.95 1.0"
6 B22_59_5 Ctx5 B22_59 ".0 .0 .0"
6 B22_59_6 Ctx6 B22_59 ".0 .0 0.5"
6 B22_59_7 Ctx7 B22_59 "0.41 0.41 0.41"
6 B22_59_8 Ctx8 B22_59 "1.0 .0 1.0"
6 B22_59_9 Ctx9 B22_59 ".0 .0 1.0"
10 96.528886000 w4 WS "B22_59"
20 96.528886000 w4 WS B22_59 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 84
10 102.432591000 w2 WS "B"
13 94.752770000 w2 gf 0.000000
13 102.432591000 w2 gf 0.000000
13 94.752770000 sched gft 0.000000
10 102.433363000 w2 WS "Po"
10 102.434255000 w2 WS "B"
10 102.436925000 w2 WS "P"
10 102.437671000 w2 WS "Sc"
13 102.438805000 sched nready 210.000000
13 102.438805000 sched nsubmitted 214.000000
10 102.439338000 w2 WS "B"
10 102.439754000 w2 WS "B"
10 102.440245000 w2 WS "Fi"
10 102.441383000 w2 WS "B"
6 B22_60 WS B22_60 "0.000000 0.600000 0.400000"
6 B22_60_1 Ctx1 B22_60 "1.0 0.39 1.0"
6 B22_60_2 Ctx2 B22_60 ".0 1.0 .0"
6 B22_60_3 Ctx3 B22_60 "0.87 0.87 .0"
6 B22_60_4 Ctx4 B22_60 ".0 0.95 1.0"
6 B22_60_5 Ctx5 B22_60 ".0 .0 .0"
6 B22_60_6 Ctx6 B22_60 ".0 .0 0.5"
6 B22_60_7 Ctx7 B22_60 "0.41 0.41 0.41"
6 B22_60_8 Ctx8 B22_60 "1.0 .0 1.0"
6 B22_60_9 Ctx9 B22_60 ".0 .0 1.0"
10 102.441961000 w2 WS "B22_60"
20 102.441961000 w2 WS B22_60 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 85
10 102.450826000 w0 WS "B"
13 94.754592000 w0 gf 0.000000
13 102.450826000 w0 gf 0.000000
13 94.754592000 sched gft 0.000000
10 102.451514000 w0 WS "Po"
10 102.452295000 w0 WS "B"
10 102.454718000 w0 WS "P"
10 102.455303000 w0 WS "Sc"
13 102.456036000 sched nready 209.000000
13 102.456036000 sched nsubmitted 213.000000
10 102.456568000 w0 WS "B"
10 102.456992000 w0 WS "B"
10 102.457419000 w0 WS "Fi"
10 102.458262000 w0 WS "B"
6 B22_61 WS B22_61 "0.000000 0.600000 0.400000"
6 B22_61_1 Ctx1 B22_61 "1.0 0.39 1.0"
6 B22_61_2 Ctx2 B22_61 ".0 1.0 .0"
6 B22_61_3 Ctx3 B22_61 "0.87 0.87 .0"
6 B22_61_4 Ctx4 B22_61 ".0 0.95 1.0"
6 B22_61_5 Ctx5 B22_61 ".0 .0 .0"
6 B22_61_6 Ctx6 B22_61 ".0 .0 0.5"
6 B22_61_7 Ctx7 B22_61 "0.41 0.41 0.41"
6 B22_61_8 Ctx8 B22_61 "1.0 .0 1.0"
6 B22_61_9 Ctx9 B22_61 ".0 .0 1.0"
10 102.458759000 w0 WS "B22_61"
20 102.458759000 w0 WS B22_61 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 86
10 102.468615000 w3 WS "B"
13 94.758664000 w3 gf 0.000000
13 102.468615000 w3 gf 0.000000
13 94.758664000 sched gft 0.000000
13 94.934502000 sched gft 0.000000
10 102.469233000 w3 WS "Po"
10 102.469967000 w3 WS "B"
10 102.472087000 w3 WS "P"
10 102.472594000 w3 WS "Sc"
13 102.473206000 sched nready 208.000000
13 102.473206000 sched nsubmitted 212.000000
10 102.473710000 w3 WS "B"
10 102.474129000 w3 WS "B"
10 102.474535000 w3 WS "Fi"
10 102.475366000 w3 WS "B"
6 B22_62 WS B22_62 "0.000000 0.600000 0.400000"
6 B22_62_1 Ctx1 B22_62 "1.0 0.39 1.0"
6 B22_62_2 Ctx2 B22_62 ".0 1.0 .0"
6 B22_62_3 Ctx3 B22_62 "0.87 0.87 .0"
6 B22_62_4 Ctx4 B22_62 ".0 0.95 1.0"
6 B22_62_5 Ctx5 B22_62 ".0 .0 .0"
6 B22_62_6 Ctx6 B22_62 ".0 .0 0.5"
6 B22_62_7 Ctx7 B22_62 "0.41 0.41 0.41"
6 B22_62_8 Ctx8 B22_62 "1.0 .0 1.0"
6 B22_62_9 Ctx9 B22_62 ".0 .0 1.0"
10 102.475846000 w3 WS "B22_62"
20 102.475846000 w3 WS B22_62 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 87
10 102.603392000 w1 WS "B"
13 94.942181000 w1 gf 0.000000
13 102.603392000 w1 gf 0.000000
13 94.942181000 sched gft 0.000000
13 96.486492000 sched gft 0.000000
10 102.604045000 w1 WS "Po"
10 102.604841000 w1 WS "B"
10 102.607192000 w1 WS "P"
10 102.607786000 w1 WS "Sc"
13 102.608480000 sched nready 207.000000
13 102.608480000 sched nsubmitted 211.000000
10 102.608942000 w1 WS "B"
10 102.609347000 w1 WS "B"
10 102.609767000 w1 WS "Fi"
10 102.610761000 w1 WS "B"
6 B22_63 WS B22_63 "0.000000 0.600000 0.400000"
6 B22_63_1 Ctx1 B22_63 "1.0 0.39 1.0"
6 B22_63_2 Ctx2 B22_63 ".0 1.0 .0"
6 B22_63_3 Ctx3 B22_63 "0.87 0.87 .0"
6 B22_63_4 Ctx4 B22_63 ".0 0.95 1.0"
6 B22_63_5 Ctx5 B22_63 ".0 .0 .0"
6 B22_63_6 Ctx6 B22_63 ".0 .0 0.5"
6 B22_63_7 Ctx7 B22_63 "0.41 0.41 0.41"
6 B22_63_8 Ctx8 B22_63 "1.0 .0 1.0"
6 B22_63_9 Ctx9 B22_63 ".0 .0 1.0"
10 102.611265000 w1 WS "B22_63"
20 102.611265000 w1 WS B22_63 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 88
10 104.181982000 w5 WS "B"
13 96.493873000 w5 gf 0.000000
13 104.181982000 w5 gf 0.000000
13 96.493873000 sched gft 0.000000
13 96.521457000 sched gft 0.000000
10 104.182771000 w5 WS "Po"
10 104.183507000 w5 WS "B"
10 104.185719000 w5 WS "P"
10 104.186266000 w5 WS "Sc"
13 104.187012000 sched nready 206.000000
13 104.187012000 sched nsubmitted 210.000000
10 104.187484000 w5 WS "B"
10 104.187899000 w5 WS "B"
10 104.188320000 w5 WS "Fi"
10 104.189279000 w5 WS "B"
10 104.189863000 w4 WS "B"
13 96.528886000 w4 gf 0.000000
13 104.189863000 w4 gf 0.000000
13 96.528886000 sched gft 0.000000
13 102.432591000 sched gft 0.000000
6 B22_64 WS B22_64 "0.000000 0.600000 0.400000"
6 B22_64_1 Ctx1 B22_64 "1.0 0.39 1.0"
6 B22_64_2 Ctx2 B22_64 ".0 1.0 .0"
6 B22_64_3 Ctx3 B22_64 "0.87 0.87 .0"
6 B22_64_4 Ctx4 B22_64 ".0 0.95 1.0"
6 B22_64_5 Ctx5 B22_64 ".0 .0 .0"
6 B22_64_6 Ctx6 B22_64 ".0 .0 0.5"
6 B22_64_7 Ctx7 B22_64 "0.41 0.41 0.41"
6 B22_64_8 Ctx8 B22_64 "1.0 .0 1.0"
6 B22_64_9 Ctx9 B22_64 ".0 .0 1.0"
10 104.189927000 w5 WS "B22_64"
10 104.190462000 w4 WS "Po"
20 104.189927000 w5 WS B22_64 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 89
10 104.191288000 w4 WS "B"
10 104.193439000 w4 WS "P"
10 104.194008000 w4 WS "Sc"
13 104.194687000 sched nready 205.000000
13 104.194687000 sched nsubmitted 209.000000
10 104.195500000 w4 WS "B"
10 104.195908000 w4 WS "B"
10 104.196315000 w4 WS "Fi"
10 104.197212000 w4 WS "B"
6 B22_65 WS B22_65 "0.000000 0.600000 0.400000"
6 B22_65_1 Ctx1 B22_65 "1.0 0.39 1.0"
6 B22_65_2 Ctx2 B22_65 ".0 1.0 .0"
6 B22_65_3 Ctx3 B22_65 "0.87 0.87 .0"
6 B22_65_4 Ctx4 B22_65 ".0 0.95 1.0"
6 B22_65_5 Ctx5 B22_65 ".0 .0 .0"
6 B22_65_6 Ctx6 B22_65 ".0 .0 0.5"
6 B22_65_7 Ctx7 B22_65 "0.41 0.41 0.41"
6 B22_65_8 Ctx8 B22_65 "1.0 .0 1.0"
6 B22_65_9 Ctx9 B22_65 ".0 .0 1.0"
10 104.197711000 w4 WS "B22_65"
20 104.197711000 w4 WS B22_65 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 90
0.000000 0 0 0 -1 -1
10 110.155298000 w3 WS "B"
13 102.475846000 w3 gf 0.000000
13 110.155298000 w3 gf 0.000000
10 110.156285000 w3 WS "Po"
10 110.157290000 w3 WS "B"
10 110.159953000 w3 WS "P"
10 110.160614000 w3 WS "Sc"
13 110.161503000 sched nready 204.000000
13 110.161503000 sched nsubmitted 208.000000
10 110.162072000 w3 WS "B"
10 110.162473000 w3 WS "B"
10 110.162931000 w3 WS "Fi"
10 110.163817000 w3 WS "B"
6 B22_66 WS B22_66 "0.000000 0.600000 0.400000"
6 B22_66_1 Ctx1 B22_66 "1.0 0.39 1.0"
6 B22_66_2 Ctx2 B22_66 ".0 1.0 .0"
6 B22_66_3 Ctx3 B22_66 "0.87 0.87 .0"
6 B22_66_4 Ctx4 B22_66 ".0 0.95 1.0"
6 B22_66_5 Ctx5 B22_66 ".0 .0 .0"
6 B22_66_6 Ctx6 B22_66 ".0 .0 0.5"
6 B22_66_7 Ctx7 B22_66 "0.41 0.41 0.41"
6 B22_66_8 Ctx8 B22_66 "1.0 .0 1.0"
6 B22_66_9 Ctx9 B22_66 ".0 .0 1.0"
10 110.164377000 w3 WS "B22_66"
20 110.164377000 w3 WS B22_66 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 91
10 110.227622000 w0 WS "B"
13 102.458759000 w0 gf 0.000000
13 110.227622000 w0 gf 0.000000
10 110.228235000 w0 WS "Po"
10 110.229387000 w0 WS "B"
10 110.237244000 w0 WS "P"
10 110.237867000 w0 WS "Sc"
13 110.238591000 sched nready 203.000000
13 110.238591000 sched nsubmitted 207.000000
10 110.239071000 w0 WS "B"
10 110.239516000 w0 WS "B"
10 110.239927000 w0 WS "Fi"
10 110.240738000 w0 WS "B"
6 B22_67 WS B22_67 "0.000000 0.600000 0.400000"
6 B22_67_1 Ctx1 B22_67 "1.0 0.39 1.0"
6 B22_67_2 Ctx2 B22_67 ".0 1.0 .0"
6 B22_67_3 Ctx3 B22_67 "0.87 0.87 .0"
6 B22_67_4 Ctx4 B22_67 ".0 0.95 1.0"
6 B22_67_5 Ctx5 B22_67 ".0 .0 .0"
6 B22_67_6 Ctx6 B22_67 ".0 .0 0.5"
6 B22_67_7 Ctx7 B22_67 "0.41 0.41 0.41"
6 B22_67_8 Ctx8 B22_67 "1.0 .0 1.0"
6 B22_67_9 Ctx9 B22_67 ".0 .0 1.0"
10 110.241237000 w0 WS "B22_67"
20 110.241237000 w0 WS B22_67 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 92
10 110.247941000 w2 WS "B"
13 102.441961000 w2 gf 0.000000
13 110.247941000 w2 gf 0.000000
13 102.441961000 sched gft 0.000000
13 102.450826000 sched gft 0.000000
13 102.458759000 sched gft 0.000000
13 102.468615000 sched gft 0.000000
13 102.475846000 sched gft 0.000000
13 102.603392000 sched gft 0.000000
10 110.248494000 w2 WS "Po"
10 110.249470000 w2 WS "B"
10 110.251800000 w2 WS "P"
10 110.252321000 w2 WS "Sc"
13 110.252993000 sched nready 202.000000
13 110.252993000 sched nsubmitted 206.000000
10 110.253498000 w2 WS "B"
10 110.253911000 w2 WS "B"
10 110.254317000 w2 WS "Fi"
10 110.255164000 w2 WS "B"
6 B22_68 WS B22_68 "0.000000 0.600000 0.400000"
6 B22_68_1 Ctx1 B22_68 "1.0 0.39 1.0"
6 B22_68_2 Ctx2 B22_68 ".0 1.0 .0"
6 B22_68_3 Ctx3 B22_68 "0.87 0.87 .0"
6 B22_68_4 Ctx4 B22_68 ".0 0.95 1.0"
6 B22_68_5 Ctx5 B22_68 ".0 .0 .0"
6 B22_68_6 Ctx6 B22_68 ".0 .0 0.5"
6 B22_68_7 Ctx7 B22_68 "0.41 0.41 0.41"
6 B22_68_8 Ctx8 B22_68 "1.0 .0 1.0"
6 B22_68_9 Ctx9 B22_68 ".0 .0 1.0"
10 110.255633000 w2 WS "B22_68"
20 110.255633000 w2 WS B22_68 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 93
10 110.274391000 w1 WS "B"
13 102.611265000 w1 gf 0.000000
13 110.274391000 w1 gf 0.000000
13 102.611265000 sched gft 0.000000
13 104.181982000 sched gft 0.000000
13 104.189863000 sched gft 0.000000
10 110.274942000 w1 WS "Po"
10 110.275698000 w1 WS "B"
10 110.280486000 w1 WS "P"
10 110.281036000 w1 WS "Sc"
13 110.281717000 sched nready 201.000000
13 110.281717000 sched nsubmitted 205.000000
10 110.282190000 w1 WS "B"
10 110.282605000 w1 WS "B"
10 110.283001000 w1 WS "Fi"
10 110.283795000 w1 WS "B"
6 B22_69 WS B22_69 "0.000000 0.600000 0.400000"
6 B22_69_1 Ctx1 B22_69 "1.0 0.39 1.0"
6 B22_69_2 Ctx2 B22_69 ".0 1.0 .0"
6 B22_69_3 Ctx3 B22_69 "0.87 0.87 .0"
6 B22_69_4 Ctx4 B22_69 ".0 0.95 1.0"
6 B22_69_5 Ctx5 B22_69 ".0 .0 .0"
6 B22_69_6 Ctx6 B22_69 ".0 .0 0.5"
6 B22_69_7 Ctx7 B22_69 "0.41 0.41 0.41"
6 B22_69_8 Ctx8 B22_69 "1.0 .0 1.0"
6 B22_69_9 Ctx9 B22_69 ".0 .0 1.0"
10 110.284273000 w1 WS "B22_69"
20 110.284273000 w1 WS B22_69 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 94
10 111.888085000 w5 WS "B"
13 104.189927000 w5 gf 0.000000
13 111.888085000 w5 gf 0.000000
13 104.189927000 sched gft 0.000000
10 111.888834000 w5 WS "Po"
10 111.889785000 w5 WS "B"
10 111.891173000 w4 WS "B"
13 104.197711000 w4 gf 0.000000
13 111.891173000 w4 gf 0.000000
13 104.197711000 sched gft 0.000000
13 110.155298000 sched gft 0.000000
10 111.891883000 w4 WS "Po"
10 111.892084000 w5 WS "P"
10 111.892642000 w5 WS "Sc"
10 111.892803000 w4 WS "B"
13 111.893347000 sched nready 200.000000
13 111.893347000 sched nsubmitted 204.000000
10 111.893983000 w5 WS "B"
10 111.894426000 w5 WS "B"
10 111.894887000 w5 WS "Fi"
10 111.895344000 w4 WS "P"
10 111.895831000 w5 WS "B"
10 111.895978000 w4 WS "Sc"
6 B22_70 WS B22_70 "0.000000 0.600000 0.400000"
6 B22_70_1 Ctx1 B22_70 "1.0 0.39 1.0"
6 B22_70_2 Ctx2 B22_70 ".0 1.0 .0"
6 B22_70_3 Ctx3 B22_70 "0.87 0.87 .0"
6 B22_70_4 Ctx4 B22_70 ".0 0.95 1.0"
6 B22_70_5 Ctx5 B22_70 ".0 .0 .0"
6 B22_70_6 Ctx6 B22_70 ".0 .0 0.5"
6 B22_70_7 Ctx7 B22_70 "0.41 0.41 0.41"
6 B22_70_8 Ctx8 B22_70 "1.0 .0 1.0"
6 B22_70_9 Ctx9 B22_70 ".0 .0 1.0"
10 111.896342000 w5 WS "B22_70"
13 111.896679000 sched nready 199.000000
13 111.896679000 sched nsubmitted 203.000000
10 111.897142000 w4 WS "B"
10 111.897574000 w4 WS "B"
20 111.896342000 w5 WS B22_70 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 95
10 111.898006000 w4 WS "Fi"
10 111.898887000 w4 WS "B"
6 B22_71 WS B22_71 "0.000000 0.600000 0.400000"
6 B22_71_1 Ctx1 B22_71 "1.0 0.39 1.0"
6 B22_71_2 Ctx2 B22_71 ".0 1.0 .0"
6 B22_71_3 Ctx3 B22_71 "0.87 0.87 .0"
6 B22_71_4 Ctx4 B22_71 ".0 0.95 1.0"
6 B22_71_5 Ctx5 B22_71 ".0 .0 .0"
6 B22_71_6 Ctx6 B22_71 ".0 .0 0.5"
6 B22_71_7 Ctx7 B22_71 "0.41 0.41 0.41"
6 B22_71_8 Ctx8 B22_71 "1.0 .0 1.0"
6 B22_71_9 Ctx9 B22_71 ".0 .0 1.0"
10 111.899352000 w4 WS "B22_71"
20 111.899352000 w4 WS B22_71 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 96
10 117.840894000 w3 WS "B"
13 110.164377000 w3 gf 0.000000
13 117.840894000 w3 gf 0.000000
13 110.164377000 sched gft 0.000000
13 110.227622000 sched gft 0.000000
10 117.841816000 w3 WS "Po"
10 117.842824000 w3 WS "B"
10 117.845330000 w3 WS "P"
10 117.846089000 w3 WS "Sc"
13 117.846936000 sched nready 198.000000
13 117.846936000 sched nsubmitted 202.000000
10 117.847457000 w3 WS "B"
10 117.847876000 w3 WS "B"
10 117.848343000 w3 WS "Fi"
10 117.849773000 w3 WS "B"
6 B22_72 WS B22_72 "0.000000 0.600000 0.400000"
6 B22_72_1 Ctx1 B22_72 "1.0 0.39 1.0"
6 B22_72_2 Ctx2 B22_72 ".0 1.0 .0"
6 B22_72_3 Ctx3 B22_72 "0.87 0.87 .0"
6 B22_72_4 Ctx4 B22_72 ".0 0.95 1.0"
6 B22_72_5 Ctx5 B22_72 ".0 .0 .0"
6 B22_72_6 Ctx6 B22_72 ".0 .0 0.5"
6 B22_72_7 Ctx7 B22_72 "0.41 0.41 0.41"
6 B22_72_8 Ctx8 B22_72 "1.0 .0 1.0"
6 B22_72_9 Ctx9 B22_72 ".0 .0 1.0"
10 117.850418000 w3 WS "B22_72"
20 117.850418000 w3 WS B22_72 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 97
10 117.907309000 w2 WS "B"
13 110.255633000 w2 gf 0.000000
13 117.907309000 w2 gf 0.000000
10 117.907865000 w2 WS "Po"
10 117.909007000 w2 WS "B"
10 117.910948000 w2 WS "P"
10 117.911539000 w2 WS "Sc"
13 117.912169000 sched nready 197.000000
13 117.912169000 sched nsubmitted 201.000000
10 117.912689000 w2 WS "B"
10 117.913104000 w2 WS "B"
10 117.913508000 w2 WS "Fi"
10 117.913836000 w0 WS "B"
13 110.241237000 w0 gf 0.000000
13 117.913836000 w0 gf 0.000000
13 110.241237000 sched gft 0.000000
13 110.247941000 sched gft 0.000000
13 110.255633000 sched gft 0.000000
13 110.274391000 sched gft 0.000000
10 117.914400000 w2 WS "B"
10 117.914487000 w0 WS "Po"
6 B22_73 WS B22_73 "0.000000 0.600000 0.400000"
6 B22_73_1 Ctx1 B22_73 "1.0 0.39 1.0"
6 B22_73_2 Ctx2 B22_73 ".0 1.0 .0"
6 B22_73_3 Ctx3 B22_73 "0.87 0.87 .0"
6 B22_73_4 Ctx4 B22_73 ".0 0.95 1.0"
6 B22_73_5 Ctx5 B22_73 ".0 .0 .0"
6 B22_73_6 Ctx6 B22_73 ".0 .0 0.5"
6 B22_73_7 Ctx7 B22_73 "0.41 0.41 0.41"
6 B22_73_8 Ctx8 B22_73 "1.0 .0 1.0"
6 B22_73_9 Ctx9 B22_73 ".0 .0 1.0"
10 117.914948000 w2 WS "B22_73"
10 117.915381000 w0 WS "B"
20 117.914948000 w2 WS B22_73 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 98
10 117.917791000 w0 WS "P"
10 117.918333000 w0 WS "Sc"
13 117.919027000 sched nready 196.000000
13 117.919027000 sched nsubmitted 200.000000
10 117.919495000 w0 WS "B"
10 117.919917000 w0 WS "B"
10 117.920332000 w0 WS "Fi"
10 117.921148000 w0 WS "B"
6 B22_74 WS B22_74 "0.000000 0.600000 0.400000"
6 B22_74_1 Ctx1 B22_74 "1.0 0.39 1.0"
6 B22_74_2 Ctx2 B22_74 ".0 1.0 .0"
6 B22_74_3 Ctx3 B22_74 "0.87 0.87 .0"
6 B22_74_4 Ctx4 B22_74 ".0 0.95 1.0"
6 B22_74_5 Ctx5 B22_74 ".0 .0 .0"
6 B22_74_6 Ctx6 B22_74 ".0 .0 0.5"
6 B22_74_7 Ctx7 B22_74 "0.41 0.41 0.41"
6 B22_74_8 Ctx8 B22_74 "1.0 .0 1.0"
6 B22_74_9 Ctx9 B22_74 ".0 .0 1.0"
10 117.921696000 w0 WS "B22_74"
20 117.921696000 w0 WS B22_74 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 99
10 117.925556000 w1 WS "B"
13 110.284273000 w1 gf 0.000000
13 117.925556000 w1 gf 0.000000
13 110.284273000 sched gft 0.000000
13 111.888085000 sched gft 0.000000
13 111.891173000 sched gft 0.000000
10 117.926370000 w1 WS "Po"
10 117.927288000 w1 WS "B"
10 117.929492000 w1 WS "P"
10 117.930012000 w1 WS "Sc"
13 117.930650000 sched nready 195.000000
13 117.930650000 sched nsubmitted 199.000000
10 117.931128000 w1 WS "B"
10 117.931537000 w1 WS "B"
10 117.931934000 w1 WS "Fi"
10 117.932826000 w1 WS "B"
6 B22_75 WS B22_75 "0.000000 0.600000 0.400000"
6 B22_75_1 Ctx1 B22_75 "1.0 0.39 1.0"
6 B22_75_2 Ctx2 B22_75 ".0 1.0 .0"
6 B22_75_3 Ctx3 B22_75 "0.87 0.87 .0"
6 B22_75_4 Ctx4 B22_75 ".0 0.95 1.0"
6 B22_75_5 Ctx5 B22_75 ".0 .0 .0"
6 B22_75_6 Ctx6 B22_75 ".0 .0 0.5"
6 B22_75_7 Ctx7 B22_75 "0.41 0.41 0.41"
6 B22_75_8 Ctx8 B22_75 "1.0 .0 1.0"
6 B22_75_9 Ctx9 B22_75 ".0 .0 1.0"
10 117.933319000 w1 WS "B22_75"
20 117.933319000 w1 WS B22_75 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 100
10 119.579244000 w4 WS "B"
13 111.899352000 w4 gf 0.000000
13 119.579244000 w4 gf 0.000000
10 119.579924000 w4 WS "Po"
10 119.580695000 w4 WS "B"
10 119.587555000 w4 WS "P"
10 119.588114000 w4 WS "Sc"
13 119.588803000 sched nready 194.000000
13 119.588803000 sched nsubmitted 198.000000
10 119.589315000 w4 WS "B"
10 119.589712000 w4 WS "B"
10 119.590172000 w4 WS "Fi"
10 119.591221000 w4 WS "B"
6 B22_76 WS B22_76 "0.000000 0.600000 0.400000"
6 B22_76_1 Ctx1 B22_76 "1.0 0.39 1.0"
6 B22_76_2 Ctx2 B22_76 ".0 1.0 .0"
6 B22_76_3 Ctx3 B22_76 "0.87 0.87 .0"
6 B22_76_4 Ctx4 B22_76 ".0 0.95 1.0"
6 B22_76_5 Ctx5 B22_76 ".0 .0 .0"
6 B22_76_6 Ctx6 B22_76 ".0 .0 0.5"
6 B22_76_7 Ctx7 B22_76 "0.41 0.41 0.41"
6 B22_76_8 Ctx8 B22_76 "1.0 .0 1.0"
6 B22_76_9 Ctx9 B22_76 ".0 .0 1.0"
10 119.591698000 w4 WS "B22_76"
20 119.591698000 w4 WS B22_76 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 101
10 119.677794000 w5 WS "B"
13 111.896342000 w5 gf 0.000000
13 119.677794000 w5 gf 0.000000
13 111.896342000 sched gft 0.000000
13 111.899352000 sched gft 0.000000
13 117.840894000 sched gft 0.000000
10 119.678355000 w5 WS "Po"
10 119.679200000 w5 WS "B"
10 119.684239000 w5 WS "P"
10 119.684862000 w5 WS "Sc"
13 119.685736000 sched nready 193.000000
13 119.685736000 sched nsubmitted 197.000000
10 119.686212000 w5 WS "B"
10 119.686639000 w5 WS "B"
10 119.687049000 w5 WS "Fi"
10 119.687922000 w5 WS "B"
6 B22_77 WS B22_77 "0.000000 0.600000 0.400000"
6 B22_77_1 Ctx1 B22_77 "1.0 0.39 1.0"
6 B22_77_2 Ctx2 B22_77 ".0 1.0 .0"
6 B22_77_3 Ctx3 B22_77 "0.87 0.87 .0"
6 B22_77_4 Ctx4 B22_77 ".0 0.95 1.0"
6 B22_77_5 Ctx5 B22_77 ".0 .0 .0"
6 B22_77_6 Ctx6 B22_77 ".0 .0 0.5"
6 B22_77_7 Ctx7 B22_77 "0.41 0.41 0.41"
6 B22_77_8 Ctx8 B22_77 "1.0 .0 1.0"
6 B22_77_9 Ctx9 B22_77 ".0 .0 1.0"
10 119.688429000 w5 WS "B22_77"
20 119.688429000 w5 WS B22_77 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 102
10 125.537879000 w3 WS "B"
13 117.850418000 w3 gf 0.000000
13 125.537879000 w3 gf 0.000000
13 117.850418000 sched gft 0.000000
13 117.907309000 sched gft 0.000000
13 117.913836000 sched gft 0.000000
10 125.538658000 w3 WS "Po"
10 125.539478000 w3 WS "B"
10 125.545588000 w3 WS "P"
10 125.546313000 w3 WS "Sc"
13 125.547222000 sched nready 192.000000
13 125.547222000 sched nsubmitted 196.000000
10 125.547687000 w3 WS "B"
10 125.548099000 w3 WS "B"
10 125.548505000 w3 WS "Fi"
10 125.549533000 w3 WS "B"
6 B22_78 WS B22_78 "0.000000 0.600000 0.400000"
6 B22_78_1 Ctx1 B22_78 "1.0 0.39 1.0"
6 B22_78_2 Ctx2 B22_78 ".0 1.0 .0"
6 B22_78_3 Ctx3 B22_78 "0.87 0.87 .0"
6 B22_78_4 Ctx4 B22_78 ".0 0.95 1.0"
6 B22_78_5 Ctx5 B22_78 ".0 .0 .0"
6 B22_78_6 Ctx6 B22_78 ".0 .0 0.5"
6 B22_78_7 Ctx7 B22_78 "0.41 0.41 0.41"
6 B22_78_8 Ctx8 B22_78 "1.0 .0 1.0"
6 B22_78_9 Ctx9 B22_78 ".0 .0 1.0"
10 125.550119000 w3 WS "B22_78"
20 125.550119000 w3 WS B22_78 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 103
10 125.598514000 w0 WS "B"
13 117.921696000 w0 gf 0.000000
13 125.598514000 w0 gf 0.000000
10 125.599137000 w0 WS "Po"
10 125.599960000 w0 WS "B"
10 125.602359000 w0 WS "P"
10 125.602951000 w0 WS "Sc"
13 125.603613000 sched nready 191.000000
13 125.603613000 sched nsubmitted 195.000000
10 125.604089000 w0 WS "B"
10 125.604512000 w0 WS "B"
10 125.604921000 w0 WS "Fi"
10 125.605789000 w0 WS "B"
6 B22_79 WS B22_79 "0.000000 0.600000 0.400000"
6 B22_79_1 Ctx1 B22_79 "1.0 0.39 1.0"
6 B22_79_2 Ctx2 B22_79 ".0 1.0 .0"
6 B22_79_3 Ctx3 B22_79 "0.87 0.87 .0"
6 B22_79_4 Ctx4 B22_79 ".0 0.95 1.0"
6 B22_79_5 Ctx5 B22_79 ".0 .0 .0"
6 B22_79_6 Ctx6 B22_79 ".0 .0 0.5"
6 B22_79_7 Ctx7 B22_79 "0.41 0.41 0.41"
6 B22_79_8 Ctx8 B22_79 "1.0 .0 1.0"
6 B22_79_9 Ctx9 B22_79 ".0 .0 1.0"
10 125.606285000 w0 WS "B22_79"
20 125.606285000 w0 WS B22_79 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 104
10 125.626906000 w2 WS "B"
13 117.914948000 w2 gf 0.000000
13 125.626906000 w2 gf 0.000000
13 117.914948000 sched gft 0.000000
13 117.921696000 sched gft 0.000000
13 117.925556000 sched gft 0.000000
10 125.627775000 w2 WS "Po"
10 125.628545000 w2 WS "B"
10 125.630833000 w2 WS "P"
10 125.631392000 w2 WS "Sc"
13 125.632049000 sched nready 190.000000
13 125.632049000 sched nsubmitted 194.000000
10 125.632620000 w2 WS "B"
10 125.633031000 w2 WS "B"
10 125.633437000 w2 WS "Fi"
10 125.634213000 w2 WS "B"
6 B22_80 WS B22_80 "0.000000 0.600000 0.400000"
6 B22_80_1 Ctx1 B22_80 "1.0 0.39 1.0"
6 B22_80_2 Ctx2 B22_80 ".0 1.0 .0"
6 B22_80_3 Ctx3 B22_80 "0.87 0.87 .0"
6 B22_80_4 Ctx4 B22_80 ".0 0.95 1.0"
6 B22_80_5 Ctx5 B22_80 ".0 .0 .0"
6 B22_80_6 Ctx6 B22_80 ".0 .0 0.5"
6 B22_80_7 Ctx7 B22_80 "0.41 0.41 0.41"
6 B22_80_8 Ctx8 B22_80 "1.0 .0 1.0"
6 B22_80_9 Ctx9 B22_80 ".0 .0 1.0"
10 125.634675000 w2 WS "B22_80"
20 125.634675000 w2 WS B22_80 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 105
10 125.708380000 w1 WS "B"
13 117.933319000 w1 gf 0.000000
13 125.708380000 w1 gf 0.000000
13 117.933319000 sched gft 0.000000
13 119.579244000 sched gft 0.000000
10 125.708913000 w1 WS "Po"
10 125.709651000 w1 WS "B"
10 125.711737000 w1 WS "P"
10 125.712307000 w1 WS "Sc"
13 125.712966000 sched nready 189.000000
13 125.712966000 sched nsubmitted 193.000000
10 125.713537000 w1 WS "B"
10 125.713940000 w1 WS "B"
10 125.714338000 w1 WS "Fi"
10 125.715184000 w1 WS "B"
6 B22_81 WS B22_81 "0.000000 0.600000 0.400000"
6 B22_81_1 Ctx1 B22_81 "1.0 0.39 1.0"
6 B22_81_2 Ctx2 B22_81 ".0 1.0 .0"
6 B22_81_3 Ctx3 B22_81 "0.87 0.87 .0"
6 B22_81_4 Ctx4 B22_81 ".0 0.95 1.0"
6 B22_81_5 Ctx5 B22_81 ".0 .0 .0"
6 B22_81_6 Ctx6 B22_81 ".0 .0 0.5"
6 B22_81_7 Ctx7 B22_81 "0.41 0.41 0.41"
6 B22_81_8 Ctx8 B22_81 "1.0 .0 1.0"
6 B22_81_9 Ctx9 B22_81 ".0 .0 1.0"
10 125.715656000 w1 WS "B22_81"
20 125.715656000 w1 WS B22_81 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 106
10 127.284394000 w4 WS "B"
13 119.591698000 w4 gf 0.000000
13 127.284394000 w4 gf 0.000000
13 119.591698000 sched gft 0.000000
13 119.677794000 sched gft 0.000000
10 127.284944000 w4 WS "Po"
10 127.285841000 w4 WS "B"
10 127.288278000 w4 WS "P"
10 127.288866000 w4 WS "Sc"
13 127.289545000 sched nready 188.000000
13 127.289545000 sched nsubmitted 192.000000
10 127.290020000 w4 WS "B"
10 127.290427000 w4 WS "B"
10 127.290837000 w4 WS "Fi"
10 127.291699000 w4 WS "B"
6 B22_82 WS B22_82 "0.000000 0.600000 0.400000"
6 B22_82_1 Ctx1 B22_82 "1.0 0.39 1.0"
6 B22_82_2 Ctx2 B22_82 ".0 1.0 .0"
6 B22_82_3 Ctx3 B22_82 "0.87 0.87 .0"
6 B22_82_4 Ctx4 B22_82 ".0 0.95 1.0"
6 B22_82_5 Ctx5 B22_82 ".0 .0 .0"
6 B22_82_6 Ctx6 B22_82 ".0 .0 0.5"
6 B22_82_7 Ctx7 B22_82 "0.41 0.41 0.41"
6 B22_82_8 Ctx8 B22_82 "1.0 .0 1.0"
6 B22_82_9 Ctx9 B22_82 ".0 .0 1.0"
10 127.292222000 w4 WS "B22_82"
20 127.292222000 w4 WS B22_82 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 107
10 127.360007000 w5 WS "B"
13 119.688429000 w5 gf 0.000000
13 127.360007000 w5 gf 0.000000
13 119.688429000 sched gft 0.000000
13 125.537879000 sched gft 0.000000
10 127.360516000 w5 WS "Po"
10 127.361294000 w5 WS "B"
10 127.363450000 w5 WS "P"
10 127.364019000 w5 WS "Sc"
13 127.364684000 sched nready 187.000000
13 127.364684000 sched nsubmitted 191.000000
10 127.365149000 w5 WS "B"
10 127.365566000 w5 WS "B"
10 127.365967000 w5 WS "Fi"
10 127.366822000 w5 WS "B"
6 B22_83 WS B22_83 "0.000000 0.600000 0.400000"
6 B22_83_1 Ctx1 B22_83 "1.0 0.39 1.0"
6 B22_83_2 Ctx2 B22_83 ".0 1.0 .0"
6 B22_83_3 Ctx3 B22_83 "0.87 0.87 .0"
6 B22_83_4 Ctx4 B22_83 ".0 0.95 1.0"
6 B22_83_5 Ctx5 B22_83 ".0 .0 .0"
6 B22_83_6 Ctx6 B22_83 ".0 .0 0.5"
6 B22_83_7 Ctx7 B22_83 "0.41 0.41 0.41"
6 B22_83_8 Ctx8 B22_83 "1.0 .0 1.0"
6 B22_83_9 Ctx9 B22_83 ".0 .0 1.0"
10 127.367309000 w5 WS "B22_83"
20 127.367309000 w5 WS B22_83 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 108
10 133.248063000 w3 WS "B"
13 125.550119000 w3 gf 0.000000
13 133.248063000 w3 gf 0.000000
13 125.550119000 sched gft 0.000000
13 125.598514000 sched gft 0.000000
10 133.248849000 w3 WS "Po"
10 133.249819000 w3 WS "B"
10 133.252404000 w3 WS "P"
10 133.253111000 w3 WS "Sc"
13 133.254014000 sched nready 186.000000
13 133.254014000 sched nsubmitted 190.000000
10 133.254537000 w3 WS "B"
10 133.254947000 w3 WS "B"
10 133.255355000 w3 WS "Fi"
10 133.256435000 w3 WS "B"
6 B22_84 WS B22_84 "0.000000 0.600000 0.400000"
6 B22_84_1 Ctx1 B22_84 "1.0 0.39 1.0"
6 B22_84_2 Ctx2 B22_84 ".0 1.0 .0"
6 B22_84_3 Ctx3 B22_84 "0.87 0.87 .0"
6 B22_84_4 Ctx4 B22_84 ".0 0.95 1.0"
6 B22_84_5 Ctx5 B22_84 ".0 .0 .0"
6 B22_84_6 Ctx6 B22_84 ".0 .0 0.5"
6 B22_84_7 Ctx7 B22_84 "0.41 0.41 0.41"
6 B22_84_8 Ctx8 B22_84 "1.0 .0 1.0"
6 B22_84_9 Ctx9 B22_84 ".0 .0 1.0"
10 133.257029000 w3 WS "B22_84"
20 133.257029000 w3 WS B22_84 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 109
10 133.304321000 w0 WS "B"
13 125.606285000 w0 gf 0.000000
13 133.304321000 w0 gf 0.000000
13 125.606285000 sched gft 0.000000
13 125.626906000 sched gft 0.000000
10 133.305020000 w0 WS "Po"
10 133.305944000 w0 WS "B"
10 133.308554000 w0 WS "P"
10 133.309106000 w0 WS "Sc"
13 133.309881000 sched nready 185.000000
13 133.309881000 sched nsubmitted 189.000000
10 133.310391000 w0 WS "B"
10 133.310811000 w0 WS "B"
10 133.311222000 w0 WS "Fi"
10 133.312032000 w0 WS "B"
6 B22_85 WS B22_85 "0.000000 0.600000 0.400000"
6 B22_85_1 Ctx1 B22_85 "1.0 0.39 1.0"
6 B22_85_2 Ctx2 B22_85 ".0 1.0 .0"
6 B22_85_3 Ctx3 B22_85 "0.87 0.87 .0"
6 B22_85_4 Ctx4 B22_85 ".0 0.95 1.0"
6 B22_85_5 Ctx5 B22_85 ".0 .0 .0"
6 B22_85_6 Ctx6 B22_85 ".0 .0 0.5"
6 B22_85_7 Ctx7 B22_85 "0.41 0.41 0.41"
6 B22_85_8 Ctx8 B22_85 "1.0 .0 1.0"
6 B22_85_9 Ctx9 B22_85 ".0 .0 1.0"
10 133.312557000 w0 WS "B22_85"
20 133.312557000 w0 WS B22_85 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 110
10 133.348053000 w2 WS "B"
13 125.634675000 w2 gf 0.000000
13 133.348053000 w2 gf 0.000000
13 125.634675000 sched gft 0.000000
13 125.708380000 sched gft 0.000000
10 133.348661000 w2 WS "Po"
10 133.349901000 w2 WS "B"
10 133.352044000 w2 WS "P"
10 133.352638000 w2 WS "Sc"
13 133.353242000 sched nready 184.000000
13 133.353242000 sched nsubmitted 188.000000
10 133.353711000 w2 WS "B"
10 133.354131000 w2 WS "B"
10 133.354537000 w2 WS "Fi"
10 133.355288000 w2 WS "B"
6 B22_86 WS B22_86 "0.000000 0.600000 0.400000"
6 B22_86_1 Ctx1 B22_86 "1.0 0.39 1.0"
6 B22_86_2 Ctx2 B22_86 ".0 1.0 .0"
6 B22_86_3 Ctx3 B22_86 "0.87 0.87 .0"
6 B22_86_4 Ctx4 B22_86 ".0 0.95 1.0"
6 B22_86_5 Ctx5 B22_86 ".0 .0 .0"
6 B22_86_6 Ctx6 B22_86 ".0 .0 0.5"
6 B22_86_7 Ctx7 B22_86 "0.41 0.41 0.41"
6 B22_86_8 Ctx8 B22_86 "1.0 .0 1.0"
6 B22_86_9 Ctx9 B22_86 ".0 .0 1.0"
10 133.355838000 w2 WS "B22_86"
20 133.355838000 w2 WS B22_86 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 111
10 133.361588000 w1 WS "B"
13 125.715656000 w1 gf 0.000000
13 133.361588000 w1 gf 0.000000
13 125.715656000 sched gft 0.000000
13 127.284394000 sched gft 0.000000
10 133.362148000 w1 WS "Po"
10 133.362958000 w1 WS "B"
10 133.365164000 w1 WS "P"
10 133.365675000 w1 WS "Sc"
13 133.366366000 sched nready 183.000000
13 133.366366000 sched nsubmitted 187.000000
10 133.366831000 w1 WS "B"
10 133.367253000 w1 WS "B"
10 133.367651000 w1 WS "Fi"
10 133.368506000 w1 WS "B"
6 B22_87 WS B22_87 "0.000000 0.600000 0.400000"
6 B22_87_1 Ctx1 B22_87 "1.0 0.39 1.0"
6 B22_87_2 Ctx2 B22_87 ".0 1.0 .0"
6 B22_87_3 Ctx3 B22_87 "0.87 0.87 .0"
6 B22_87_4 Ctx4 B22_87 ".0 0.95 1.0"
6 B22_87_5 Ctx5 B22_87 ".0 .0 .0"
6 B22_87_6 Ctx6 B22_87 ".0 .0 0.5"
6 B22_87_7 Ctx7 B22_87 "0.41 0.41 0.41"
6 B22_87_8 Ctx8 B22_87 "1.0 .0 1.0"
6 B22_87_9 Ctx9 B22_87 ".0 .0 1.0"
10 133.368987000 w1 WS "B22_87"
20 133.368987000 w1 WS B22_87 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 112
10 135.032956000 w5 WS "B"
13 127.367309000 w5 gf 0.000000
13 135.032956000 w5 gf 0.000000
10 135.033529000 w5 WS "Po"
10 135.034501000 w5 WS "B"
10 135.036736000 w5 WS "P"
10 135.037304000 w5 WS "Sc"
13 135.037987000 sched nready 182.000000
13 135.037987000 sched nsubmitted 186.000000
10 135.038722000 w5 WS "B"
10 135.039137000 w5 WS "B"
10 135.039539000 w5 WS "Fi"
10 135.040363000 w5 WS "B"
6 B22_88 WS B22_88 "0.000000 0.600000 0.400000"
6 B22_88_1 Ctx1 B22_88 "1.0 0.39 1.0"
6 B22_88_2 Ctx2 B22_88 ".0 1.0 .0"
6 B22_88_3 Ctx3 B22_88 "0.87 0.87 .0"
6 B22_88_4 Ctx4 B22_88 ".0 0.95 1.0"
6 B22_88_5 Ctx5 B22_88 ".0 .0 .0"
6 B22_88_6 Ctx6 B22_88 ".0 .0 0.5"
6 B22_88_7 Ctx7 B22_88 "0.41 0.41 0.41"
6 B22_88_8 Ctx8 B22_88 "1.0 .0 1.0"
6 B22_88_9 Ctx9 B22_88 ".0 .0 1.0"
10 135.040881000 w5 WS "B22_88"
20 135.040881000 w5 WS B22_88 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 113
10 135.081424000 w4 WS "B"
13 127.292222000 w4 gf 0.000000
13 135.081424000 w4 gf 0.000000
13 127.292222000 sched gft 0.000000
13 127.360007000 sched gft 0.000000
13 127.367309000 sched gft 0.000000
13 133.248063000 sched gft 0.000000
10 135.081995000 w4 WS "Po"
10 135.082827000 w4 WS "B"
10 135.085135000 w4 WS "P"
10 135.085759000 w4 WS "Sc"
13 135.086548000 sched nready 181.000000
13 135.086548000 sched nsubmitted 185.000000
10 135.087100000 w4 WS "B"
10 135.087509000 w4 WS "B"
10 135.087916000 w4 WS "Fi"
10 135.088816000 w4 WS "B"
6 B22_89 WS B22_89 "0.000000 0.600000 0.400000"
6 B22_89_1 Ctx1 B22_89 "1.0 0.39 1.0"
6 B22_89_2 Ctx2 B22_89 ".0 1.0 .0"
6 B22_89_3 Ctx3 B22_89 "0.87 0.87 .0"
6 B22_89_4 Ctx4 B22_89 ".0 0.95 1.0"
6 B22_89_5 Ctx5 B22_89 ".0 .0 .0"
6 B22_89_6 Ctx6 B22_89 ".0 .0 0.5"
6 B22_89_7 Ctx7 B22_89 "0.41 0.41 0.41"
6 B22_89_8 Ctx8 B22_89 "1.0 .0 1.0"
6 B22_89_9 Ctx9 B22_89 ".0 .0 1.0"
10 135.089309000 w4 WS "B22_89"
20 135.089309000 w4 WS B22_89 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 114
10 141.000206000 w3 WS "B"
13 133.257029000 w3 gf 0.000000
13 141.000206000 w3 gf 0.000000
13 133.257029000 sched gft 0.000000
13 133.304321000 sched gft 0.000000
10 141.000987000 w3 WS "Po"
10 141.001819000 w3 WS "B"
10 141.004119000 w3 WS "P"
10 141.004695000 w0 WS "B"
13 133.312557000 w0 gf 0.000000
13 141.004695000 w0 gf 0.000000
13 133.312557000 sched gft 0.000000
13 133.348053000 sched gft 0.000000
10 141.004911000 w3 WS "Sc"
10 141.005404000 w0 WS "Po"
13 141.005651000 sched nready 180.000000
13 141.005651000 sched nsubmitted 184.000000
10 141.006256000 w0 WS "B"
10 141.006413000 w3 WS "B"
10 141.006837000 w3 WS "B"
10 141.007290000 w3 WS "Fi"
10 141.008291000 w3 WS "B"
10 141.008782000 w0 WS "P"
6 B22_90 WS B22_90 "0.000000 0.600000 0.400000"
6 B22_90_1 Ctx1 B22_90 "1.0 0.39 1.0"
6 B22_90_2 Ctx2 B22_90 ".0 1.0 .0"
6 B22_90_3 Ctx3 B22_90 "0.87 0.87 .0"
6 B22_90_4 Ctx4 B22_90 ".0 0.95 1.0"
6 B22_90_5 Ctx5 B22_90 ".0 .0 .0"
6 B22_90_6 Ctx6 B22_90 ".0 .0 0.5"
6 B22_90_7 Ctx7 B22_90 "0.41 0.41 0.41"
6 B22_90_8 Ctx8 B22_90 "1.0 .0 1.0"
6 B22_90_9 Ctx9 B22_90 ".0 .0 1.0"
10 141.008837000 w3 WS "B22_90"
10 141.009402000 w0 WS "Sc"
20 141.008837000 w3 WS B22_90 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 115
13 141.010180000 sched nready 179.000000
13 141.010180000 sched nsubmitted 183.000000
10 141.010668000 w0 WS "B"
10 141.011091000 w0 WS "B"
10 141.011543000 w0 WS "Fi"
10 141.011796000 w2 WS "B"
13 133.355838000 w2 gf 0.000000
13 141.011796000 w2 gf 0.000000
13 133.355838000 sched gft 0.000000
13 133.361588000 sched gft 0.000000
10 141.012437000 w2 WS "Po"
10 141.012567000 w0 WS "B"
6 B22_91 WS B22_91 "0.000000 0.600000 0.400000"
6 B22_91_1 Ctx1 B22_91 "1.0 0.39 1.0"
6 B22_91_2 Ctx2 B22_91 ".0 1.0 .0"
6 B22_91_3 Ctx3 B22_91 "0.87 0.87 .0"
6 B22_91_4 Ctx4 B22_91 ".0 0.95 1.0"
6 B22_91_5 Ctx5 B22_91 ".0 .0 .0"
6 B22_91_6 Ctx6 B22_91 ".0 .0 0.5"
6 B22_91_7 Ctx7 B22_91 "0.41 0.41 0.41"
6 B22_91_8 Ctx8 B22_91 "1.0 .0 1.0"
6 B22_91_9 Ctx9 B22_91 ".0 .0 1.0"
10 141.013072000 w0 WS "B22_91"
10 141.013364000 w2 WS "B"
20 141.013072000 w0 WS B22_91 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 116
10 141.015567000 w2 WS "P"
10 141.016113000 w2 WS "Sc"
13 141.016716000 sched nready 178.000000
13 141.016716000 sched nsubmitted 182.000000
10 141.017224000 w2 WS "B"
10 141.017637000 w2 WS "B"
10 141.018043000 w2 WS "Fi"
10 141.018837000 w2 WS "B"
6 B22_92 WS B22_92 "0.000000 0.600000 0.400000"
6 B22_92_1 Ctx1 B22_92 "1.0 0.39 1.0"
6 B22_92_2 Ctx2 B22_92 ".0 1.0 .0"
6 B22_92_3 Ctx3 B22_92 "0.87 0.87 .0"
6 B22_92_4 Ctx4 B22_92 ".0 0.95 1.0"
6 B22_92_5 Ctx5 B22_92 ".0 .0 .0"
6 B22_92_6 Ctx6 B22_92 ".0 .0 0.5"
6 B22_92_7 Ctx7 B22_92 "0.41 0.41 0.41"
6 B22_92_8 Ctx8 B22_92 "1.0 .0 1.0"
6 B22_92_9 Ctx9 B22_92 ".0 .0 1.0"
10 141.019367000 w2 WS "B22_92"
20 141.019367000 w2 WS B22_92 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 117
10 141.020641000 w1 WS "B"
13 133.368987000 w1 gf 0.000000
13 141.020641000 w1 gf 0.000000
13 133.368987000 sched gft 0.000000
13 135.032956000 sched gft 0.000000
10 141.021243000 w1 WS "Po"
10 141.022265000 w1 WS "B"
10 141.024445000 w1 WS "P"
10 141.024951000 w1 WS "Sc"
13 141.025563000 sched nready 177.000000
13 141.025563000 sched nsubmitted 181.000000
10 141.026055000 w1 WS "B"
10 141.026506000 w1 WS "B"
10 141.026912000 w1 WS "Fi"
10 141.027734000 w1 WS "B"
6 B22_93 WS B22_93 "0.000000 0.600000 0.400000"
6 B22_93_1 Ctx1 B22_93 "1.0 0.39 1.0"
6 B22_93_2 Ctx2 B22_93 ".0 1.0 .0"
6 B22_93_3 Ctx3 B22_93 "0.87 0.87 .0"
6 B22_93_4 Ctx4 B22_93 ".0 0.95 1.0"
6 B22_93_5 Ctx5 B22_93 ".0 .0 .0"
6 B22_93_6 Ctx6 B22_93 ".0 .0 0.5"
6 B22_93_7 Ctx7 B22_93 "0.41 0.41 0.41"
6 B22_93_8 Ctx8 B22_93 "1.0 .0 1.0"
6 B22_93_9 Ctx9 B22_93 ".0 .0 1.0"
10 141.028209000 w1 WS "B22_93"
20 141.028209000 w1 WS B22_93 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 118
10 142.726467000 w5 WS "B"
13 135.040881000 w5 gf 0.000000
13 142.726467000 w5 gf 0.000000
13 135.040881000 sched gft 0.000000
13 135.081424000 sched gft 0.000000
10 142.727204000 w5 WS "Po"
10 142.728072000 w5 WS "B"
10 142.730357000 w5 WS "P"
10 142.730875000 w5 WS "Sc"
13 142.731571000 sched nready 176.000000
13 142.731571000 sched nsubmitted 180.000000
10 142.732108000 w5 WS "B"
10 142.732529000 w5 WS "B"
10 142.732933000 w5 WS "Fi"
10 142.733850000 w4 WS "B"
13 135.089309000 w4 gf 0.000000
13 142.733850000 w4 gf 0.000000
13 135.089309000 sched gft 0.000000
13 141.000206000 sched gft 0.000000
13 141.004695000 sched gft 0.000000
10 142.733997000 w5 WS "B"
10 142.734413000 w4 WS "Po"
6 B22_94 WS B22_94 "0.000000 0.600000 0.400000"
6 B22_94_1 Ctx1 B22_94 "1.0 0.39 1.0"
6 B22_94_2 Ctx2 B22_94 ".0 1.0 .0"
6 B22_94_3 Ctx3 B22_94 "0.87 0.87 .0"
6 B22_94_4 Ctx4 B22_94 ".0 0.95 1.0"
6 B22_94_5 Ctx5 B22_94 ".0 .0 .0"
6 B22_94_6 Ctx6 B22_94 ".0 .0 0.5"
6 B22_94_7 Ctx7 B22_94 "0.41 0.41 0.41"
6 B22_94_8 Ctx8 B22_94 "1.0 .0 1.0"
6 B22_94_9 Ctx9 B22_94 ".0 .0 1.0"
10 142.734588000 w5 WS "B22_94"
10 142.735268000 w4 WS "B"
20 142.734588000 w5 WS B22_94 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 119
10 142.737597000 w4 WS "P"
10 142.738131000 w4 WS "Sc"
13 142.738858000 sched nready 175.000000
13 142.738858000 sched nsubmitted 179.000000
10 142.739320000 w4 WS "B"
10 142.739726000 w4 WS "B"
10 142.740137000 w4 WS "Fi"
10 142.741036000 w4 WS "B"
6 B22_95 WS B22_95 "0.000000 0.600000 0.400000"
6 B22_95_1 Ctx1 B22_95 "1.0 0.39 1.0"
6 B22_95_2 Ctx2 B22_95 ".0 1.0 .0"
6 B22_95_3 Ctx3 B22_95 "0.87 0.87 .0"
6 B22_95_4 Ctx4 B22_95 ".0 0.95 1.0"
6 B22_95_5 Ctx5 B22_95 ".0 .0 .0"
6 B22_95_6 Ctx6 B22_95 ".0 .0 0.5"
6 B22_95_7 Ctx7 B22_95 "0.41 0.41 0.41"
6 B22_95_8 Ctx8 B22_95 "1.0 .0 1.0"
6 B22_95_9 Ctx9 B22_95 ".0 .0 1.0"
10 142.741522000 w4 WS "B22_95"
20 142.741522000 w4 WS B22_95 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 120
10 148.700393000 w3 WS "B"
13 141.008837000 w3 gf 0.000000
13 148.700393000 w3 gf 0.000000
13 141.008837000 sched gft 0.000000
13 141.011796000 sched gft 0.000000
10 148.700461000 w2 WS "B"
13 141.019367000 w2 gf 0.000000
13 148.700461000 w2 gf 0.000000
10 148.701239000 w3 WS "Po"
10 148.701299000 w2 WS "Po"
10 148.702202000 w3 WS "B"
10 148.702515000 w2 WS "B"
10 148.704978000 w3 WS "P"
10 148.705582000 w3 WS "Sc"
10 148.706176000 w2 WS "P"
10 148.706785000 w2 WS "Sc"
13 148.706839000 sched nready 174.000000
13 148.706839000 sched nsubmitted 178.000000
10 148.707641000 w3 WS "B"
13 148.707751000 sched nready 173.000000
13 148.707751000 sched nsubmitted 177.000000
10 148.708095000 w3 WS "B"
10 148.708207000 w1 WS "B"
13 141.028209000 w1 gf 0.000000
13 148.708207000 w1 gf 0.000000
10 148.708266000 w2 WS "B"
10 148.708503000 w3 WS "Fi"
10 148.708700000 w2 WS "B"
10 148.708792000 w1 WS "Po"
10 148.709112000 w2 WS "Fi"
10 148.709405000 w3 WS "B"
10 148.709648000 w1 WS "B"
10 148.710024000 w2 WS "B"
6 B22_96 WS B22_96 "0.000000 0.600000 0.400000"
6 B22_96_1 Ctx1 B22_96 "1.0 0.39 1.0"
6 B22_96_2 Ctx2 B22_96 ".0 1.0 .0"
6 B22_96_3 Ctx3 B22_96 "0.87 0.87 .0"
6 B22_96_4 Ctx4 B22_96 ".0 0.95 1.0"
6 B22_96_5 Ctx5 B22_96 ".0 .0 .0"
6 B22_96_6 Ctx6 B22_96 ".0 .0 0.5"
6 B22_96_7 Ctx7 B22_96 "0.41 0.41 0.41"
6 B22_96_8 Ctx8 B22_96 "1.0 .0 1.0"
6 B22_96_9 Ctx9 B22_96 ".0 .0 1.0"
10 148.710102000 w3 WS "B22_96"
6 B22_97 WS B22_97 "0.000000 0.600000 0.400000"
6 B22_97_1 Ctx1 B22_97 "1.0 0.39 1.0"
6 B22_97_2 Ctx2 B22_97 ".0 1.0 .0"
6 B22_97_3 Ctx3 B22_97 "0.87 0.87 .0"
6 B22_97_4 Ctx4 B22_97 ".0 0.95 1.0"
6 B22_97_5 Ctx5 B22_97 ".0 .0 .0"
6 B22_97_6 Ctx6 B22_97 ".0 .0 0.5"
6 B22_97_7 Ctx7 B22_97 "0.41 0.41 0.41"
6 B22_97_8 Ctx8 B22_97 "1.0 .0 1.0"
6 B22_97_9 Ctx9 B22_97 ".0 .0 1.0"
10 148.710588000 w2 WS "B22_97"
20 148.710102000 w3 WS B22_96 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 121
10 148.711992000 w1 WS "P"
20 148.710588000 w2 WS B22_97 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 122
10 148.712613000 w1 WS "Sc"
13 148.713395000 sched nready 172.000000
13 148.713395000 sched nsubmitted 176.000000
10 148.713908000 w1 WS "B"
10 148.714326000 w1 WS "B"
10 148.714722000 w1 WS "Fi"
10 148.715615000 w1 WS "B"
6 B22_98 WS B22_98 "0.000000 0.600000 0.400000"
6 B22_98_1 Ctx1 B22_98 "1.0 0.39 1.0"
6 B22_98_2 Ctx2 B22_98 ".0 1.0 .0"
6 B22_98_3 Ctx3 B22_98 "0.87 0.87 .0"
6 B22_98_4 Ctx4 B22_98 ".0 0.95 1.0"
6 B22_98_5 Ctx5 B22_98 ".0 .0 .0"
6 B22_98_6 Ctx6 B22_98 ".0 .0 0.5"
6 B22_98_7 Ctx7 B22_98 "0.41 0.41 0.41"
6 B22_98_8 Ctx8 B22_98 "1.0 .0 1.0"
6 B22_98_9 Ctx9 B22_98 ".0 .0 1.0"
10 148.716102000 w1 WS "B22_98"
20 148.716102000 w1 WS B22_98 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 123
10 148.729927000 w0 WS "B"
13 141.013072000 w0 gf 0.000000
13 148.729927000 w0 gf 0.000000
13 141.013072000 sched gft 0.000000
13 141.019367000 sched gft 0.000000
13 141.020641000 sched gft 0.000000
13 141.028209000 sched gft 0.000000
13 142.726467000 sched gft 0.000000
13 142.733850000 sched gft 0.000000
10 148.730704000 w0 WS "Po"
10 148.731541000 w0 WS "B"
10 148.734076000 w0 WS "P"
10 148.734635000 w0 WS "Sc"
13 148.735401000 sched nready 171.000000
13 148.735401000 sched nsubmitted 175.000000
10 148.735915000 w0 WS "B"
10 148.736335000 w0 WS "B"
10 148.736745000 w0 WS "Fi"
10 148.737558000 w0 WS "B"
6 B22_99 WS B22_99 "0.000000 0.600000 0.400000"
6 B22_99_1 Ctx1 B22_99 "1.0 0.39 1.0"
6 B22_99_2 Ctx2 B22_99 ".0 1.0 .0"
6 B22_99_3 Ctx3 B22_99 "0.87 0.87 .0"
6 B22_99_4 Ctx4 B22_99 ".0 0.95 1.0"
6 B22_99_5 Ctx5 B22_99 ".0 .0 .0"
6 B22_99_6 Ctx6 B22_99 ".0 .0 0.5"
6 B22_99_7 Ctx7 B22_99 "0.41 0.41 0.41"
6 B22_99_8 Ctx8 B22_99 "1.0 .0 1.0"
6 B22_99_9 Ctx9 B22_99 ".0 .0 1.0"
10 148.738053000 w0 WS "B22_99"
20 148.738053000 w0 WS B22_99 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 124
10 150.410534000 w5 WS "B"
13 142.734588000 w5 gf 0.000000
13 150.410534000 w5 gf 0.000000
13 142.734588000 sched gft 0.000000
10 150.411142000 w5 WS "Po"
10 150.412041000 w5 WS "B"
10 150.414173000 w5 WS "P"
10 150.414695000 w5 WS "Sc"
13 150.415396000 sched nready 170.000000
13 150.415396000 sched nsubmitted 174.000000
10 150.415919000 w5 WS "B"
10 150.416347000 w5 WS "B"
10 150.416758000 w5 WS "Fi"
10 150.417667000 w5 WS "B"
6 B22_100 WS B22_100 "0.000000 0.600000 0.400000"
6 B22_100_1 Ctx1 B22_100 "1.0 0.39 1.0"
6 B22_100_2 Ctx2 B22_100 ".0 1.0 .0"
6 B22_100_3 Ctx3 B22_100 "0.87 0.87 .0"
6 B22_100_4 Ctx4 B22_100 ".0 0.95 1.0"
6 B22_100_5 Ctx5 B22_100 ".0 .0 .0"
6 B22_100_6 Ctx6 B22_100 ".0 .0 0.5"
6 B22_100_7 Ctx7 B22_100 "0.41 0.41 0.41"
6 B22_100_8 Ctx8 B22_100 "1.0 .0 1.0"
6 B22_100_9 Ctx9 B22_100 ".0 .0 1.0"
10 150.418178000 w5 WS "B22_100"
10 150.418241000 w4 WS "B"
13 142.741522000 w4 gf 0.000000
13 150.418241000 w4 gf 0.000000
13 142.741522000 sched gft 0.000000
13 148.700393000 sched gft 0.000000
13 148.700461000 sched gft 0.000000
13 148.708207000 sched gft 0.000000
10 150.418887000 w4 WS "Po"
20 150.418178000 w5 WS B22_100 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 125
10 150.419723000 w4 WS "B"
10 150.422092000 w4 WS "P"
10 150.422658000 w4 WS "Sc"
13 150.423363000 sched nready 169.000000
13 150.423363000 sched nsubmitted 173.000000
10 150.423825000 w4 WS "B"
10 150.424238000 w4 WS "B"
10 150.424647000 w4 WS "Fi"
10 150.425622000 w4 WS "B"
6 B22_101 WS B22_101 "0.000000 0.600000 0.400000"
6 B22_101_1 Ctx1 B22_101 "1.0 0.39 1.0"
6 B22_101_2 Ctx2 B22_101 ".0 1.0 .0"
6 B22_101_3 Ctx3 B22_101 "0.87 0.87 .0"
6 B22_101_4 Ctx4 B22_101 ".0 0.95 1.0"
6 B22_101_5 Ctx5 B22_101 ".0 .0 .0"
6 B22_101_6 Ctx6 B22_101 ".0 .0 0.5"
6 B22_101_7 Ctx7 B22_101 "0.41 0.41 0.41"
6 B22_101_8 Ctx8 B22_101 "1.0 .0 1.0"
6 B22_101_9 Ctx9 B22_101 ".0 .0 1.0"
10 150.426098000 w4 WS "B22_101"
20 150.426098000 w4 WS B22_101 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 126
10 156.389145000 w2 WS "B"
13 148.710588000 w2 gf 0.000000
13 156.389145000 w2 gf 0.000000
10 156.389850000 w2 WS "Po"
10 156.391004000 w2 WS "B"
10 156.393873000 w2 WS "P"
10 156.394588000 w2 WS "Sc"
10 156.395395000 w1 WS "B"
13 148.716102000 w1 gf 0.000000
13 156.395395000 w1 gf 0.000000
13 156.395475000 sched nready 168.000000
13 156.395475000 sched nsubmitted 172.000000
10 156.396039000 w1 WS "Po"
10 156.396167000 w2 WS "B"
10 156.396612000 w2 WS "B"
10 156.396897000 w1 WS "B"
10 156.397076000 w2 WS "Fi"
10 156.398462000 w2 WS "B"
6 B22_102 WS B22_102 "0.000000 0.600000 0.400000"
6 B22_102_1 Ctx1 B22_102 "1.0 0.39 1.0"
6 B22_102_2 Ctx2 B22_102 ".0 1.0 .0"
6 B22_102_3 Ctx3 B22_102 "0.87 0.87 .0"
6 B22_102_4 Ctx4 B22_102 ".0 0.95 1.0"
6 B22_102_5 Ctx5 B22_102 ".0 .0 .0"
6 B22_102_6 Ctx6 B22_102 ".0 .0 0.5"
6 B22_102_7 Ctx7 B22_102 "0.41 0.41 0.41"
6 B22_102_8 Ctx8 B22_102 "1.0 .0 1.0"
6 B22_102_9 Ctx9 B22_102 ".0 .0 1.0"
10 156.399111000 w2 WS "B22_102"
10 156.399194000 w1 WS "P"
10 156.399818000 w1 WS "Sc"
20 156.399111000 w2 WS B22_102 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 127
13 156.400569000 sched nready 167.000000
13 156.400569000 sched nsubmitted 171.000000
10 156.401086000 w1 WS "B"
10 156.401509000 w1 WS "B"
10 156.401907000 w1 WS "Fi"
10 156.402855000 w1 WS "B"
6 B22_103 WS B22_103 "0.000000 0.600000 0.400000"
6 B22_103_1 Ctx1 B22_103 "1.0 0.39 1.0"
6 B22_103_2 Ctx2 B22_103 ".0 1.0 .0"
6 B22_103_3 Ctx3 B22_103 "0.87 0.87 .0"
6 B22_103_4 Ctx4 B22_103 ".0 0.95 1.0"
6 B22_103_5 Ctx5 B22_103 ".0 .0 .0"
6 B22_103_6 Ctx6 B22_103 ".0 .0 0.5"
6 B22_103_7 Ctx7 B22_103 "0.41 0.41 0.41"
6 B22_103_8 Ctx8 B22_103 "1.0 .0 1.0"
6 B22_103_9 Ctx9 B22_103 ".0 .0 1.0"
10 156.403356000 w1 WS "B22_103"
20 156.403356000 w1 WS B22_103 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 128
10 156.411314000 w0 WS "B"
13 148.738053000 w0 gf 0.000000
13 156.411314000 w0 gf 0.000000
10 156.411932000 w0 WS "Po"
10 156.412815000 w0 WS "B"
10 156.415058000 w0 WS "P"
10 156.415665000 w0 WS "Sc"
13 156.416316000 sched nready 166.000000
13 156.416316000 sched nsubmitted 170.000000
10 156.416894000 w0 WS "B"
10 156.417315000 w0 WS "B"
10 156.417725000 w0 WS "Fi"
10 156.418564000 w0 WS "B"
6 B22_104 WS B22_104 "0.000000 0.600000 0.400000"
6 B22_104_1 Ctx1 B22_104 "1.0 0.39 1.0"
6 B22_104_2 Ctx2 B22_104 ".0 1.0 .0"
6 B22_104_3 Ctx3 B22_104 "0.87 0.87 .0"
6 B22_104_4 Ctx4 B22_104 ".0 0.95 1.0"
6 B22_104_5 Ctx5 B22_104 ".0 .0 .0"
6 B22_104_6 Ctx6 B22_104 ".0 .0 0.5"
6 B22_104_7 Ctx7 B22_104 "0.41 0.41 0.41"
6 B22_104_8 Ctx8 B22_104 "1.0 .0 1.0"
6 B22_104_9 Ctx9 B22_104 ".0 .0 1.0"
10 156.419047000 w0 WS "B22_104"
20 156.419047000 w0 WS B22_104 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 129
10 156.456155000 w3 WS "B"
13 148.710102000 w3 gf 0.000000
13 156.456155000 w3 gf 0.000000
13 148.710102000 sched gft 0.000000
13 148.710588000 sched gft 0.000000
13 148.716102000 sched gft 0.000000
13 148.729927000 sched gft 0.000000
13 148.738053000 sched gft 0.000000
13 150.410534000 sched gft 0.000000
10 156.456812000 w3 WS "Po"
10 156.457704000 w3 WS "B"
10 156.460056000 w3 WS "P"
10 156.460651000 w3 WS "Sc"
13 156.461308000 sched nready 165.000000
13 156.461308000 sched nsubmitted 169.000000
10 156.461814000 w3 WS "B"
10 156.462222000 w3 WS "B"
10 156.462826000 w3 WS "Fi"
10 156.463661000 w3 WS "B"
6 B22_105 WS B22_105 "0.000000 0.600000 0.400000"
6 B22_105_1 Ctx1 B22_105 "1.0 0.39 1.0"
6 B22_105_2 Ctx2 B22_105 ".0 1.0 .0"
6 B22_105_3 Ctx3 B22_105 "0.87 0.87 .0"
6 B22_105_4 Ctx4 B22_105 ".0 0.95 1.0"
6 B22_105_5 Ctx5 B22_105 ".0 .0 .0"
6 B22_105_6 Ctx6 B22_105 ".0 .0 0.5"
6 B22_105_7 Ctx7 B22_105 "0.41 0.41 0.41"
6 B22_105_8 Ctx8 B22_105 "1.0 .0 1.0"
6 B22_105_9 Ctx9 B22_105 ".0 .0 1.0"
10 156.464146000 w3 WS "B22_105"
20 156.464146000 w3 WS B22_105 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 130
10 158.109499000 w5 WS "B"
13 150.418178000 w5 gf 0.000000
13 158.109499000 w5 gf 0.000000
13 150.418178000 sched gft 0.000000
13 150.418241000 sched gft 0.000000
10 158.110176000 w5 WS "Po"
10 158.111056000 w5 WS "B"
10 158.113132000 w5 WS "P"
10 158.113697000 w5 WS "Sc"
13 158.114347000 sched nready 164.000000
13 158.114347000 sched nsubmitted 168.000000
10 158.115002000 w5 WS "B"
10 158.115425000 w5 WS "B"
10 158.115841000 w5 WS "Fi"
10 158.116475000 w4 WS "B"
13 150.426098000 w4 gf 0.000000
13 158.116475000 w4 gf 0.000000
13 150.426098000 sched gft 0.000000
13 156.389145000 sched gft 0.000000
13 156.395395000 sched gft 0.000000
10 158.116886000 w5 WS "B"
10 158.117068000 w4 WS "Po"
6 B22_106 WS B22_106 "0.000000 0.600000 0.400000"
6 B22_106_1 Ctx1 B22_106 "1.0 0.39 1.0"
6 B22_106_2 Ctx2 B22_106 ".0 1.0 .0"
6 B22_106_3 Ctx3 B22_106 "0.87 0.87 .0"
6 B22_106_4 Ctx4 B22_106 ".0 0.95 1.0"
6 B22_106_5 Ctx5 B22_106 ".0 .0 .0"
6 B22_106_6 Ctx6 B22_106 ".0 .0 0.5"
6 B22_106_7 Ctx7 B22_106 "0.41 0.41 0.41"
6 B22_106_8 Ctx8 B22_106 "1.0 .0 1.0"
6 B22_106_9 Ctx9 B22_106 ".0 .0 1.0"
10 158.117423000 w5 WS "B22_106"
10 158.117939000 w4 WS "B"
20 158.117423000 w5 WS B22_106 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 131
10 158.120276000 w4 WS "P"
10 158.120838000 w4 WS "Sc"
13 158.121588000 sched nready 163.000000
13 158.121588000 sched nsubmitted 167.000000
10 158.122153000 w4 WS "B"
10 158.122564000 w4 WS "B"
10 158.122971000 w4 WS "Fi"
10 158.123833000 w4 WS "B"
6 B22_107 WS B22_107 "0.000000 0.600000 0.400000"
6 B22_107_1 Ctx1 B22_107 "1.0 0.39 1.0"
6 B22_107_2 Ctx2 B22_107 ".0 1.0 .0"
6 B22_107_3 Ctx3 B22_107 "0.87 0.87 .0"
6 B22_107_4 Ctx4 B22_107 ".0 0.95 1.0"
6 B22_107_5 Ctx5 B22_107 ".0 .0 .0"
6 B22_107_6 Ctx6 B22_107 ".0 .0 0.5"
6 B22_107_7 Ctx7 B22_107 "0.41 0.41 0.41"
6 B22_107_8 Ctx8 B22_107 "1.0 .0 1.0"
6 B22_107_9 Ctx9 B22_107 ".0 .0 1.0"
10 158.124304000 w4 WS "B22_107"
20 158.124304000 w4 WS B22_107 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 132
10 164.137531000 w3 WS "B"
13 156.464146000 w3 gf 0.000000
13 164.137531000 w3 gf 0.000000
10 164.138221000 w3 WS "Po"
10 164.139141000 w3 WS "B"
10 164.141970000 w3 WS "P"
10 164.142599000 w3 WS "Sc"
13 164.143551000 sched nready 162.000000
13 164.143551000 sched nsubmitted 166.000000
10 164.144014000 w3 WS "B"
10 164.144423000 w3 WS "B"
10 164.144828000 w3 WS "Fi"
10 164.145751000 w3 WS "B"
6 B22_108 WS B22_108 "0.000000 0.600000 0.400000"
6 B22_108_1 Ctx1 B22_108 "1.0 0.39 1.0"
6 B22_108_2 Ctx2 B22_108 ".0 1.0 .0"
6 B22_108_3 Ctx3 B22_108 "0.87 0.87 .0"
6 B22_108_4 Ctx4 B22_108 ".0 0.95 1.0"
6 B22_108_5 Ctx5 B22_108 ".0 .0 .0"
6 B22_108_6 Ctx6 B22_108 ".0 .0 0.5"
6 B22_108_7 Ctx7 B22_108 "0.41 0.41 0.41"
6 B22_108_8 Ctx8 B22_108 "1.0 .0 1.0"
6 B22_108_9 Ctx9 B22_108 ".0 .0 1.0"
10 164.146365000 w3 WS "B22_108"
20 164.146365000 w3 WS B22_108 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 133
10 164.202415000 w2 WS "B"
13 156.399111000 w2 gf 0.000000
13 164.202415000 w2 gf 0.000000
13 156.399111000 sched gft 0.000000
10 164.202954000 w2 WS "Po"
10 164.203854000 w2 WS "B"
10 164.204887000 w1 WS "B"
13 156.403356000 w1 gf 0.000000
13 164.204887000 w1 gf 0.000000
13 156.403356000 sched gft 0.000000
13 156.411314000 sched gft 0.000000
10 164.205467000 w1 WS "Po"
10 164.205830000 w0 WS "B"
13 156.419047000 w0 gf 0.000000
13 164.205830000 w0 gf 0.000000
13 156.419047000 sched gft 0.000000
13 156.456155000 sched gft 0.000000
13 156.464146000 sched gft 0.000000
13 158.109499000 sched gft 0.000000
13 158.116475000 sched gft 0.000000
10 164.206339000 w1 WS "B"
10 164.206451000 w0 WS "Po"
10 164.206499000 w2 WS "P"
10 164.207060000 w2 WS "Sc"
10 164.207423000 w0 WS "B"
13 164.207889000 sched nready 161.000000
13 164.207889000 sched nsubmitted 165.000000
10 164.208434000 w2 WS "B"
10 164.208619000 w1 WS "P"
10 164.208874000 w2 WS "B"
10 164.209239000 w1 WS "Sc"
10 164.209312000 w2 WS "Fi"
10 164.210036000 w0 WS "P"
13 164.210095000 sched nready 160.000000
13 164.210095000 sched nsubmitted 164.000000
10 164.210318000 w2 WS "B"
10 164.210675000 w0 WS "Sc"
6 B22_109 WS B22_109 "0.000000 0.600000 0.400000"
6 B22_109_1 Ctx1 B22_109 "1.0 0.39 1.0"
6 B22_109_2 Ctx2 B22_109 ".0 1.0 .0"
6 B22_109_3 Ctx3 B22_109 "0.87 0.87 .0"
6 B22_109_4 Ctx4 B22_109 ".0 0.95 1.0"
6 B22_109_5 Ctx5 B22_109 ".0 .0 .0"
6 B22_109_6 Ctx6 B22_109 ".0 .0 0.5"
6 B22_109_7 Ctx7 B22_109 "0.41 0.41 0.41"
6 B22_109_8 Ctx8 B22_109 "1.0 .0 1.0"
6 B22_109_9 Ctx9 B22_109 ".0 .0 1.0"
10 164.210819000 w2 WS "B22_109"
10 164.210920000 w1 WS "B"
10 164.211369000 w1 WS "B"
13 164.211490000 sched nready 159.000000
13 164.211490000 sched nsubmitted 163.000000
10 164.211813000 w1 WS "Fi"
10 164.212024000 w0 WS "B"
20 164.210819000 w2 WS B22_109 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 134
10 164.212467000 w0 WS "B"
10 164.212800000 w1 WS "B"
10 164.212887000 w0 WS "Fi"
6 B22_110 WS B22_110 "0.000000 0.600000 0.400000"
6 B22_110_1 Ctx1 B22_110 "1.0 0.39 1.0"
6 B22_110_2 Ctx2 B22_110 ".0 1.0 .0"
6 B22_110_3 Ctx3 B22_110 "0.87 0.87 .0"
6 B22_110_4 Ctx4 B22_110 ".0 0.95 1.0"
6 B22_110_5 Ctx5 B22_110 ".0 .0 .0"
6 B22_110_6 Ctx6 B22_110 ".0 .0 0.5"
6 B22_110_7 Ctx7 B22_110 "0.41 0.41 0.41"
6 B22_110_8 Ctx8 B22_110 "1.0 .0 1.0"
6 B22_110_9 Ctx9 B22_110 ".0 .0 1.0"
10 164.213336000 w1 WS "B22_110"
10 164.213831000 w0 WS "B"
6 B22_111 WS B22_111 "0.000000 0.600000 0.400000"
6 B22_111_1 Ctx1 B22_111 "1.0 0.39 1.0"
6 B22_111_2 Ctx2 B22_111 ".0 1.0 .0"
6 B22_111_3 Ctx3 B22_111 "0.87 0.87 .0"
6 B22_111_4 Ctx4 B22_111 ".0 0.95 1.0"
6 B22_111_5 Ctx5 B22_111 ".0 .0 .0"
6 B22_111_6 Ctx6 B22_111 ".0 .0 0.5"
6 B22_111_7 Ctx7 B22_111 "0.41 0.41 0.41"
6 B22_111_8 Ctx8 B22_111 "1.0 .0 1.0"
6 B22_111_9 Ctx9 B22_111 ".0 .0 1.0"
10 164.214360000 w0 WS "B22_111"
20 164.213336000 w1 WS B22_110 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 135
20 164.214360000 w0 WS B22_111 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 136
10 165.786546000 w5 WS "B"
13 158.117423000 w5 gf 0.000000
13 165.786546000 w5 gf 0.000000
13 158.117423000 sched gft 0.000000
10 165.787063000 w5 WS "Po"
10 165.787816000 w5 WS "B"
10 165.790026000 w5 WS "P"
10 165.790559000 w5 WS "Sc"
13 165.791179000 sched nready 158.000000
13 165.791179000 sched nsubmitted 162.000000
10 165.791718000 w5 WS "B"
10 165.792133000 w5 WS "B"
10 165.792527000 w5 WS "Fi"
10 165.793378000 w5 WS "B"
6 B22_112 WS B22_112 "0.000000 0.600000 0.400000"
6 B22_112_1 Ctx1 B22_112 "1.0 0.39 1.0"
6 B22_112_2 Ctx2 B22_112 ".0 1.0 .0"
6 B22_112_3 Ctx3 B22_112 "0.87 0.87 .0"
6 B22_112_4 Ctx4 B22_112 ".0 0.95 1.0"
6 B22_112_5 Ctx5 B22_112 ".0 .0 .0"
6 B22_112_6 Ctx6 B22_112 ".0 .0 0.5"
6 B22_112_7 Ctx7 B22_112 "0.41 0.41 0.41"
6 B22_112_8 Ctx8 B22_112 "1.0 .0 1.0"
6 B22_112_9 Ctx9 B22_112 ".0 .0 1.0"
10 165.793878000 w5 WS "B22_112"
10 165.794465000 w4 WS "B"
13 158.124304000 w4 gf 0.000000
13 165.794465000 w4 gf 0.000000
13 158.124304000 sched gft 0.000000
13 164.137531000 sched gft 0.000000
20 165.793878000 w5 WS B22_112 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 137
10 165.795104000 w4 WS "Po"
10 165.795892000 w4 WS "B"
10 165.798122000 w4 WS "P"
10 165.798726000 w4 WS "Sc"
13 165.799377000 sched nready 157.000000
13 165.799377000 sched nsubmitted 161.000000
10 165.799844000 w4 WS "B"
10 165.800256000 w4 WS "B"
10 165.800665000 w4 WS "Fi"
10 165.801516000 w4 WS "B"
6 B22_113 WS B22_113 "0.000000 0.600000 0.400000"
6 B22_113_1 Ctx1 B22_113 "1.0 0.39 1.0"
6 B22_113_2 Ctx2 B22_113 ".0 1.0 .0"
6 B22_113_3 Ctx3 B22_113 "0.87 0.87 .0"
6 B22_113_4 Ctx4 B22_113 ".0 0.95 1.0"
6 B22_113_5 Ctx5 B22_113 ".0 .0 .0"
6 B22_113_6 Ctx6 B22_113 ".0 .0 0.5"
6 B22_113_7 Ctx7 B22_113 "0.41 0.41 0.41"
6 B22_113_8 Ctx8 B22_113 "1.0 .0 1.0"
6 B22_113_9 Ctx9 B22_113 ".0 .0 1.0"
10 165.801995000 w4 WS "B22_113"
20 165.801995000 w4 WS B22_113 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 138
10 171.833722000 w3 WS "B"
13 164.146365000 w3 gf 0.000000
13 171.833722000 w3 gf 0.000000
13 164.146365000 sched gft 0.000000
13 164.202415000 sched gft 0.000000
13 164.204887000 sched gft 0.000000
13 164.205830000 sched gft 0.000000
10 171.834805000 w3 WS "Po"
10 171.835727000 w3 WS "B"
10 171.838100000 w3 WS "P"
10 171.838893000 w3 WS "Sc"
13 171.839912000 sched nready 156.000000
13 171.839912000 sched nsubmitted 160.000000
10 171.840460000 w3 WS "B"
10 171.840979000 w3 WS "B"
10 171.841537000 w3 WS "Fi"
10 171.842539000 w3 WS "B"
6 B22_114 WS B22_114 "0.000000 0.600000 0.400000"
6 B22_114_1 Ctx1 B22_114 "1.0 0.39 1.0"
6 B22_114_2 Ctx2 B22_114 ".0 1.0 .0"
6 B22_114_3 Ctx3 B22_114 "0.87 0.87 .0"
6 B22_114_4 Ctx4 B22_114 ".0 0.95 1.0"
6 B22_114_5 Ctx5 B22_114 ".0 .0 .0"
6 B22_114_6 Ctx6 B22_114 ".0 .0 0.5"
6 B22_114_7 Ctx7 B22_114 "0.41 0.41 0.41"
6 B22_114_8 Ctx8 B22_114 "1.0 .0 1.0"
6 B22_114_9 Ctx9 B22_114 ".0 .0 1.0"
10 171.843235000 w3 WS "B22_114"
20 171.843235000 w3 WS B22_114 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 139
10 171.858148000 w2 WS "B"
13 164.210819000 w2 gf 0.000000
13 171.858148000 w2 gf 0.000000
13 164.210819000 sched gft 0.000000
10 171.858697000 w2 WS "Po"
10 171.859523000 w2 WS "B"
10 171.861724000 w2 WS "P"
10 171.862250000 w2 WS "Sc"
13 171.862897000 sched nready 155.000000
13 171.862897000 sched nsubmitted 159.000000
10 171.863415000 w2 WS "B"
10 171.863833000 w2 WS "B"
10 171.864238000 w2 WS "Fi"
10 171.865278000 w2 WS "B"
6 B22_115 WS B22_115 "0.000000 0.600000 0.400000"
6 B22_115_1 Ctx1 B22_115 "1.0 0.39 1.0"
6 B22_115_2 Ctx2 B22_115 ".0 1.0 .0"
6 B22_115_3 Ctx3 B22_115 "0.87 0.87 .0"
6 B22_115_4 Ctx4 B22_115 ".0 0.95 1.0"
6 B22_115_5 Ctx5 B22_115 ".0 .0 .0"
6 B22_115_6 Ctx6 B22_115 ".0 .0 0.5"
6 B22_115_7 Ctx7 B22_115 "0.41 0.41 0.41"
6 B22_115_8 Ctx8 B22_115 "1.0 .0 1.0"
6 B22_115_9 Ctx9 B22_115 ".0 .0 1.0"
10 171.865792000 w2 WS "B22_115"
20 171.865792000 w2 WS B22_115 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 140
10 171.867277000 w1 WS "B"
13 164.213336000 w1 gf 0.000000
13 171.867277000 w1 gf 0.000000
13 164.213336000 sched gft 0.000000
10 171.867799000 w1 WS "Po"
10 171.868530000 w1 WS "B"
10 171.870709000 w1 WS "P"
10 171.871265000 w1 WS "Sc"
13 171.871921000 sched nready 154.000000
13 171.871921000 sched nsubmitted 158.000000
10 171.872429000 w1 WS "B"
10 171.872842000 w1 WS "B"
10 171.873246000 w1 WS "Fi"
10 171.874028000 w1 WS "B"
6 B22_116 WS B22_116 "0.000000 0.600000 0.400000"
6 B22_116_1 Ctx1 B22_116 "1.0 0.39 1.0"
6 B22_116_2 Ctx2 B22_116 ".0 1.0 .0"
6 B22_116_3 Ctx3 B22_116 "0.87 0.87 .0"
6 B22_116_4 Ctx4 B22_116 ".0 0.95 1.0"
6 B22_116_5 Ctx5 B22_116 ".0 .0 .0"
6 B22_116_6 Ctx6 B22_116 ".0 .0 0.5"
6 B22_116_7 Ctx7 B22_116 "0.41 0.41 0.41"
6 B22_116_8 Ctx8 B22_116 "1.0 .0 1.0"
6 B22_116_9 Ctx9 B22_116 ".0 .0 1.0"
10 171.874503000 w1 WS "B22_116"
20 171.874503000 w1 WS B22_116 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 141
10 171.901371000 w0 WS "B"
13 164.214360000 w0 gf 0.000000
13 171.901371000 w0 gf 0.000000
13 164.214360000 sched gft 0.000000
13 165.786546000 sched gft 0.000000
10 171.901921000 w0 WS "Po"
10 171.902777000 w0 WS "B"
10 171.905324000 w0 WS "P"
10 171.905880000 w0 WS "Sc"
13 171.906592000 sched nready 153.000000
13 171.906592000 sched nsubmitted 157.000000
10 171.907107000 w0 WS "B"
10 171.907530000 w0 WS "B"
10 171.907941000 w0 WS "Fi"
10 171.908824000 w0 WS "B"
6 B22_117 WS B22_117 "0.000000 0.600000 0.400000"
6 B22_117_1 Ctx1 B22_117 "1.0 0.39 1.0"
6 B22_117_2 Ctx2 B22_117 ".0 1.0 .0"
6 B22_117_3 Ctx3 B22_117 "0.87 0.87 .0"
6 B22_117_4 Ctx4 B22_117 ".0 0.95 1.0"
6 B22_117_5 Ctx5 B22_117 ".0 .0 .0"
6 B22_117_6 Ctx6 B22_117 ".0 .0 0.5"
6 B22_117_7 Ctx7 B22_117 "0.41 0.41 0.41"
6 B22_117_8 Ctx8 B22_117 "1.0 .0 1.0"
6 B22_117_9 Ctx9 B22_117 ".0 .0 1.0"
10 171.909310000 w0 WS "B22_117"
20 171.909310000 w0 WS B22_117 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 142
10 173.484944000 w5 WS "B"
13 165.793878000 w5 gf 0.000000
13 173.484944000 w5 gf 0.000000
13 165.793878000 sched gft 0.000000
13 165.794465000 sched gft 0.000000
10 173.485586000 w5 WS "Po"
10 173.486384000 w5 WS "B"
10 173.488326000 w4 WS "B"
13 165.801995000 w4 gf 0.000000
13 173.488326000 w4 gf 0.000000
13 165.801995000 sched gft 0.000000
13 171.833722000 sched gft 0.000000
10 173.488632000 w5 WS "P"
10 173.488930000 w4 WS "Po"
10 173.489239000 w5 WS "Sc"
10 173.489691000 w4 WS "B"
13 173.489968000 sched nready 152.000000
13 173.489968000 sched nsubmitted 156.000000
10 173.490656000 w5 WS "B"
10 173.491105000 w5 WS "B"
10 173.491596000 w5 WS "Fi"
10 173.492399000 w4 WS "P"
10 173.492558000 w5 WS "B"
10 173.493016000 w4 WS "Sc"
6 B22_118 WS B22_118 "0.000000 0.600000 0.400000"
6 B22_118_1 Ctx1 B22_118 "1.0 0.39 1.0"
6 B22_118_2 Ctx2 B22_118 ".0 1.0 .0"
6 B22_118_3 Ctx3 B22_118 "0.87 0.87 .0"
6 B22_118_4 Ctx4 B22_118 ".0 0.95 1.0"
6 B22_118_5 Ctx5 B22_118 ".0 .0 .0"
6 B22_118_6 Ctx6 B22_118 ".0 .0 0.5"
6 B22_118_7 Ctx7 B22_118 "0.41 0.41 0.41"
6 B22_118_8 Ctx8 B22_118 "1.0 .0 1.0"
6 B22_118_9 Ctx9 B22_118 ".0 .0 1.0"
10 173.493096000 w5 WS "B22_118"
13 173.493757000 sched nready 151.000000
13 173.493757000 sched nsubmitted 155.000000
10 173.494247000 w4 WS "B"
20 173.493096000 w5 WS B22_118 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 143
10 173.494676000 w4 WS "B"
10 173.495096000 w4 WS "Fi"
10 173.495916000 w4 WS "B"
6 B22_119 WS B22_119 "0.000000 0.600000 0.400000"
6 B22_119_1 Ctx1 B22_119 "1.0 0.39 1.0"
6 B22_119_2 Ctx2 B22_119 ".0 1.0 .0"
6 B22_119_3 Ctx3 B22_119 "0.87 0.87 .0"
6 B22_119_4 Ctx4 B22_119 ".0 0.95 1.0"
6 B22_119_5 Ctx5 B22_119 ".0 .0 .0"
6 B22_119_6 Ctx6 B22_119 ".0 .0 0.5"
6 B22_119_7 Ctx7 B22_119 "0.41 0.41 0.41"
6 B22_119_8 Ctx8 B22_119 "1.0 .0 1.0"
6 B22_119_9 Ctx9 B22_119 ".0 .0 1.0"
10 173.496396000 w4 WS "B22_119"
20 173.496396000 w4 WS B22_119 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 144
10 179.523206000 w3 WS "B"
13 171.843235000 w3 gf 0.000000
13 179.523206000 w3 gf 0.000000
13 171.843235000 sched gft 0.000000
13 171.858148000 sched gft 0.000000
10 179.524105000 w3 WS "Po"
10 179.524967000 w3 WS "B"
10 179.527382000 w3 WS "P"
10 179.528119000 w3 WS "Sc"
13 179.528832000 sched nready 150.000000
13 179.528832000 sched nsubmitted 154.000000
10 179.529385000 w3 WS "B"
10 179.529793000 w3 WS "B"
10 179.530198000 w3 WS "Fi"
10 179.531087000 w3 WS "B"
6 B22_120 WS B22_120 "0.000000 0.600000 0.400000"
6 B22_120_1 Ctx1 B22_120 "1.0 0.39 1.0"
6 B22_120_2 Ctx2 B22_120 ".0 1.0 .0"
6 B22_120_3 Ctx3 B22_120 "0.87 0.87 .0"
6 B22_120_4 Ctx4 B22_120 ".0 0.95 1.0"
6 B22_120_5 Ctx5 B22_120 ".0 .0 .0"
6 B22_120_6 Ctx6 B22_120 ".0 .0 0.5"
6 B22_120_7 Ctx7 B22_120 "0.41 0.41 0.41"
6 B22_120_8 Ctx8 B22_120 "1.0 .0 1.0"
6 B22_120_9 Ctx9 B22_120 ".0 .0 1.0"
10 179.531609000 w3 WS "B22_120"
20 179.531609000 w3 WS B22_120 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 145
10 179.590488000 w2 WS "B"
13 171.865792000 w2 gf 0.000000
13 179.590488000 w2 gf 0.000000
13 171.865792000 sched gft 0.000000
13 171.867277000 sched gft 0.000000
10 179.591039000 w2 WS "Po"
10 179.591876000 w2 WS "B"
10 179.594314000 w2 WS "P"
10 179.594860000 w2 WS "Sc"
13 179.595573000 sched nready 149.000000
13 179.595573000 sched nsubmitted 153.000000
10 179.596118000 w2 WS "B"
10 179.596536000 w2 WS "B"
10 179.596940000 w2 WS "Fi"
10 179.597852000 w1 WS "B"
13 171.874503000 w1 gf 0.000000
13 179.597852000 w1 gf 0.000000
13 171.874503000 sched gft 0.000000
13 171.901371000 sched gft 0.000000
10 179.597904000 w2 WS "B"
6 B22_121 WS B22_121 "0.000000 0.600000 0.400000"
6 B22_121_1 Ctx1 B22_121 "1.0 0.39 1.0"
6 B22_121_2 Ctx2 B22_121 ".0 1.0 .0"
6 B22_121_3 Ctx3 B22_121 "0.87 0.87 .0"
6 B22_121_4 Ctx4 B22_121 ".0 0.95 1.0"
6 B22_121_5 Ctx5 B22_121 ".0 .0 .0"
6 B22_121_6 Ctx6 B22_121 ".0 .0 0.5"
6 B22_121_7 Ctx7 B22_121 "0.41 0.41 0.41"
6 B22_121_8 Ctx8 B22_121 "1.0 .0 1.0"
6 B22_121_9 Ctx9 B22_121 ".0 .0 1.0"
10 179.598424000 w2 WS "B22_121"
10 179.598489000 w1 WS "Po"
10 179.599455000 w1 WS "B"
20 179.598424000 w2 WS B22_121 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 146
10 179.601654000 w1 WS "P"
10 179.602184000 w1 WS "Sc"
13 179.602907000 sched nready 148.000000
13 179.602907000 sched nsubmitted 152.000000
10 179.603441000 w1 WS "B"
10 179.603851000 w1 WS "B"
10 179.604253000 w1 WS "Fi"
10 179.605097000 w1 WS "B"
6 B22_122 WS B22_122 "0.000000 0.600000 0.400000"
6 B22_122_1 Ctx1 B22_122 "1.0 0.39 1.0"
6 B22_122_2 Ctx2 B22_122 ".0 1.0 .0"
6 B22_122_3 Ctx3 B22_122 "0.87 0.87 .0"
6 B22_122_4 Ctx4 B22_122 ".0 0.95 1.0"
6 B22_122_5 Ctx5 B22_122 ".0 .0 .0"
6 B22_122_6 Ctx6 B22_122 ".0 .0 0.5"
6 B22_122_7 Ctx7 B22_122 "0.41 0.41 0.41"
6 B22_122_8 Ctx8 B22_122 "1.0 .0 1.0"
6 B22_122_9 Ctx9 B22_122 ".0 .0 1.0"
10 179.605572000 w1 WS "B22_122"
20 179.605572000 w1 WS B22_122 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 147
10 179.651648000 w0 WS "B"
13 171.909310000 w0 gf 0.000000
13 179.651648000 w0 gf 0.000000
13 171.909310000 sched gft 0.000000
13 173.484944000 sched gft 0.000000
13 173.488326000 sched gft 0.000000
10 179.652244000 w0 WS "Po"
10 179.653131000 w0 WS "B"
10 179.655519000 w0 WS "P"
10 179.656078000 w0 WS "Sc"
13 179.656745000 sched nready 147.000000
13 179.656745000 sched nsubmitted 151.000000
10 179.657394000 w0 WS "B"
10 179.657816000 w0 WS "B"
10 179.658226000 w0 WS "Fi"
10 179.659069000 w0 WS "B"
6 B22_123 WS B22_123 "0.000000 0.600000 0.400000"
6 B22_123_1 Ctx1 B22_123 "1.0 0.39 1.0"
6 B22_123_2 Ctx2 B22_123 ".0 1.0 .0"
6 B22_123_3 Ctx3 B22_123 "0.87 0.87 .0"
6 B22_123_4 Ctx4 B22_123 ".0 0.95 1.0"
6 B22_123_5 Ctx5 B22_123 ".0 .0 .0"
6 B22_123_6 Ctx6 B22_123 ".0 .0 0.5"
6 B22_123_7 Ctx7 B22_123 "0.41 0.41 0.41"
6 B22_123_8 Ctx8 B22_123 "1.0 .0 1.0"
6 B22_123_9 Ctx9 B22_123 ".0 .0 1.0"
10 179.659560000 w0 WS "B22_123"
20 179.659560000 w0 WS B22_123 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 148
10 181.161081000 w5 WS "B"
13 173.493096000 w5 gf 0.000000
13 181.161081000 w5 gf 0.000000
13 173.493096000 sched gft 0.000000
10 181.161806000 w5 WS "Po"
10 181.162714000 w5 WS "B"
10 181.164920000 w5 WS "P"
10 181.165477000 w5 WS "Sc"
13 181.166296000 sched nready 146.000000
13 181.166296000 sched nsubmitted 150.000000
10 181.166781000 w5 WS "B"
10 181.167202000 w5 WS "B"
10 181.167605000 w5 WS "Fi"
10 181.168540000 w4 WS "B"
13 173.496396000 w4 gf 0.000000
13 181.168540000 w4 gf 0.000000
13 173.496396000 sched gft 0.000000
13 179.523206000 sched gft 0.000000
10 181.168776000 w5 WS "B"
10 181.169127000 w4 WS "Po"
6 B22_124 WS B22_124 "0.000000 0.600000 0.400000"
6 B22_124_1 Ctx1 B22_124 "1.0 0.39 1.0"
6 B22_124_2 Ctx2 B22_124 ".0 1.0 .0"
6 B22_124_3 Ctx3 B22_124 "0.87 0.87 .0"
6 B22_124_4 Ctx4 B22_124 ".0 0.95 1.0"
6 B22_124_5 Ctx5 B22_124 ".0 .0 .0"
6 B22_124_6 Ctx6 B22_124 ".0 .0 0.5"
6 B22_124_7 Ctx7 B22_124 "0.41 0.41 0.41"
6 B22_124_8 Ctx8 B22_124 "1.0 .0 1.0"
6 B22_124_9 Ctx9 B22_124 ".0 .0 1.0"
10 181.169276000 w5 WS "B22_124"
10 181.169972000 w4 WS "B"
20 181.169276000 w5 WS B22_124 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 149
10 181.172362000 w4 WS "P"
10 181.172924000 w4 WS "Sc"
13 181.173636000 sched nready 145.000000
13 181.173636000 sched nsubmitted 149.000000
10 181.174283000 w4 WS "B"
10 181.174689000 w4 WS "B"
10 181.175095000 w4 WS "Fi"
10 181.176005000 w4 WS "B"
6 B22_125 WS B22_125 "0.000000 0.600000 0.400000"
6 B22_125_1 Ctx1 B22_125 "1.0 0.39 1.0"
6 B22_125_2 Ctx2 B22_125 ".0 1.0 .0"
6 B22_125_3 Ctx3 B22_125 "0.87 0.87 .0"
6 B22_125_4 Ctx4 B22_125 ".0 0.95 1.0"
6 B22_125_5 Ctx5 B22_125 ".0 .0 .0"
6 B22_125_6 Ctx6 B22_125 ".0 .0 0.5"
6 B22_125_7 Ctx7 B22_125 "0.41 0.41 0.41"
6 B22_125_8 Ctx8 B22_125 "1.0 .0 1.0"
6 B22_125_9 Ctx9 B22_125 ".0 .0 1.0"
10 181.176489000 w4 WS "B22_125"
20 181.176489000 w4 WS B22_125 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 150
10 187.217525000 w3 WS "B"
13 179.531609000 w3 gf 0.000000
13 187.217525000 w3 gf 0.000000
13 179.531609000 sched gft 0.000000
13 179.590488000 sched gft 0.000000
13 179.597852000 sched gft 0.000000
10 187.218286000 w3 WS "Po"
10 187.219592000 w3 WS "B"
10 187.222130000 w3 WS "P"
10 187.222829000 w3 WS "Sc"
13 187.223647000 sched nready 144.000000
13 187.223647000 sched nsubmitted 148.000000
10 187.224218000 w3 WS "B"
10 187.224761000 w3 WS "B"
10 187.225428000 w3 WS "Fi"
10 187.226402000 w3 WS "B"
6 B22_126 WS B22_126 "0.000000 0.600000 0.400000"
6 B22_126_1 Ctx1 B22_126 "1.0 0.39 1.0"
6 B22_126_2 Ctx2 B22_126 ".0 1.0 .0"
6 B22_126_3 Ctx3 B22_126 "0.87 0.87 .0"
6 B22_126_4 Ctx4 B22_126 ".0 0.95 1.0"
6 B22_126_5 Ctx5 B22_126 ".0 .0 .0"
6 B22_126_6 Ctx6 B22_126 ".0 .0 0.5"
6 B22_126_7 Ctx7 B22_126 "0.41 0.41 0.41"
6 B22_126_8 Ctx8 B22_126 "1.0 .0 1.0"
6 B22_126_9 Ctx9 B22_126 ".0 .0 1.0"
10 187.227194000 w3 WS "B22_126"
20 187.227194000 w3 WS B22_126 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 151
10 187.247075000 w2 WS "B"
13 179.598424000 w2 gf 0.000000
13 187.247075000 w2 gf 0.000000
13 179.598424000 sched gft 0.000000
10 187.247629000 w2 WS "Po"
10 187.248487000 w2 WS "B"
10 187.250741000 w2 WS "P"
10 187.251299000 w2 WS "Sc"
13 187.251971000 sched nready 143.000000
13 187.251971000 sched nsubmitted 147.000000
10 187.252433000 w2 WS "B"
10 187.252851000 w2 WS "B"
10 187.253252000 w2 WS "Fi"
10 187.254088000 w2 WS "B"
6 B22_127 WS B22_127 "0.000000 0.600000 0.400000"
6 B22_127_1 Ctx1 B22_127 "1.0 0.39 1.0"
6 B22_127_2 Ctx2 B22_127 ".0 1.0 .0"
6 B22_127_3 Ctx3 B22_127 "0.87 0.87 .0"
6 B22_127_4 Ctx4 B22_127 ".0 0.95 1.0"
6 B22_127_5 Ctx5 B22_127 ".0 .0 .0"
6 B22_127_6 Ctx6 B22_127 ".0 .0 0.5"
6 B22_127_7 Ctx7 B22_127 "0.41 0.41 0.41"
6 B22_127_8 Ctx8 B22_127 "1.0 .0 1.0"
6 B22_127_9 Ctx9 B22_127 ".0 .0 1.0"
10 187.254599000 w2 WS "B22_127"
20 187.254599000 w2 WS B22_127 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 152
0.000000 0 0 0 -1 -1
10 187.271139000 w1 WS "B"
13 179.605572000 w1 gf 0.000000
13 187.271139000 w1 gf 0.000000
13 179.605572000 sched gft 0.000000
13 179.651648000 sched gft 0.000000
10 187.271665000 w1 WS "Po"
10 187.272484000 w1 WS "B"
10 187.274517000 w1 WS "P"
10 187.275057000 w1 WS "Sc"
13 187.275689000 sched nready 142.000000
13 187.275689000 sched nsubmitted 146.000000
10 187.276173000 w1 WS "B"
10 187.276595000 w1 WS "B"
10 187.276993000 w1 WS "Fi"
10 187.277961000 w1 WS "B"
6 B22_128 WS B22_128 "0.000000 0.600000 0.400000"
6 B22_128_1 Ctx1 B22_128 "1.0 0.39 1.0"
6 B22_128_2 Ctx2 B22_128 ".0 1.0 .0"
6 B22_128_3 Ctx3 B22_128 "0.87 0.87 .0"
6 B22_128_4 Ctx4 B22_128 ".0 0.95 1.0"
6 B22_128_5 Ctx5 B22_128 ".0 .0 .0"
6 B22_128_6 Ctx6 B22_128 ".0 .0 0.5"
6 B22_128_7 Ctx7 B22_128 "0.41 0.41 0.41"
6 B22_128_8 Ctx8 B22_128 "1.0 .0 1.0"
6 B22_128_9 Ctx9 B22_128 ".0 .0 1.0"
10 187.278456000 w1 WS "B22_128"
20 187.278456000 w1 WS B22_128 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 153
10 187.342177000 w0 WS "B"
13 179.659560000 w0 gf 0.000000
13 187.342177000 w0 gf 0.000000
13 179.659560000 sched gft 0.000000
13 181.161081000 sched gft 0.000000
13 181.168540000 sched gft 0.000000
10 187.343055000 w0 WS "Po"
10 187.343847000 w0 WS "B"
10 187.346370000 w0 WS "P"
10 187.346915000 w0 WS "Sc"
13 187.347668000 sched nready 141.000000
13 187.347668000 sched nsubmitted 145.000000
10 187.348211000 w0 WS "B"
10 187.348633000 w0 WS "B"
10 187.349043000 w0 WS "Fi"
10 187.349821000 w0 WS "B"
6 B22_129 WS B22_129 "0.000000 0.600000 0.400000"
6 B22_129_1 Ctx1 B22_129 "1.0 0.39 1.0"
6 B22_129_2 Ctx2 B22_129 ".0 1.0 .0"
6 B22_129_3 Ctx3 B22_129 "0.87 0.87 .0"
6 B22_129_4 Ctx4 B22_129 ".0 0.95 1.0"
6 B22_129_5 Ctx5 B22_129 ".0 .0 .0"
6 B22_129_6 Ctx6 B22_129 ".0 .0 0.5"
6 B22_129_7 Ctx7 B22_129 "0.41 0.41 0.41"
6 B22_129_8 Ctx8 B22_129 "1.0 .0 1.0"
6 B22_129_9 Ctx9 B22_129 ".0 .0 1.0"
10 187.350307000 w0 WS "B22_129"
20 187.350307000 w0 WS B22_129 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 154
10 188.923050000 w5 WS "B"
13 181.169276000 w5 gf 0.000000
13 188.923050000 w5 gf 0.000000
13 181.169276000 sched gft 0.000000
10 188.923848000 w5 WS "Po"
10 188.924687000 w5 WS "B"
10 188.926905000 w5 WS "P"
10 188.927480000 w5 WS "Sc"
13 188.928087000 sched nready 140.000000
13 188.928087000 sched nsubmitted 144.000000
10 188.928631000 w5 WS "B"
10 188.929055000 w5 WS "B"
10 188.929177000 w4 WS "B"
13 181.176489000 w4 gf 0.000000
13 188.929177000 w4 gf 0.000000
13 181.176489000 sched gft 0.000000
13 187.217525000 sched gft 0.000000
10 188.929468000 w5 WS "Fi"
10 188.929686000 w4 WS "Po"
10 188.930412000 w5 WS "B"
10 188.930466000 w4 WS "B"
6 B22_130 WS B22_130 "0.000000 0.600000 0.400000"
6 B22_130_1 Ctx1 B22_130 "1.0 0.39 1.0"
6 B22_130_2 Ctx2 B22_130 ".0 1.0 .0"
6 B22_130_3 Ctx3 B22_130 "0.87 0.87 .0"
6 B22_130_4 Ctx4 B22_130 ".0 0.95 1.0"
6 B22_130_5 Ctx5 B22_130 ".0 .0 .0"
6 B22_130_6 Ctx6 B22_130 ".0 .0 0.5"
6 B22_130_7 Ctx7 B22_130 "0.41 0.41 0.41"
6 B22_130_8 Ctx8 B22_130 "1.0 .0 1.0"
6 B22_130_9 Ctx9 B22_130 ".0 .0 1.0"
10 188.930927000 w5 WS "B22_130"
20 188.930927000 w5 WS B22_130 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 155
10 188.933098000 w4 WS "P"
10 188.933645000 w4 WS "Sc"
13 188.934383000 sched nready 139.000000
13 188.934383000 sched nsubmitted 143.000000
10 188.934855000 w4 WS "B"
10 188.935267000 w4 WS "B"
10 188.935676000 w4 WS "Fi"
10 188.936538000 w4 WS "B"
6 B22_131 WS B22_131 "0.000000 0.600000 0.400000"
6 B22_131_1 Ctx1 B22_131 "1.0 0.39 1.0"
6 B22_131_2 Ctx2 B22_131 ".0 1.0 .0"
6 B22_131_3 Ctx3 B22_131 "0.87 0.87 .0"
6 B22_131_4 Ctx4 B22_131 ".0 0.95 1.0"
6 B22_131_5 Ctx5 B22_131 ".0 .0 .0"
6 B22_131_6 Ctx6 B22_131 ".0 .0 0.5"
6 B22_131_7 Ctx7 B22_131 "0.41 0.41 0.41"
6 B22_131_8 Ctx8 B22_131 "1.0 .0 1.0"
6 B22_131_9 Ctx9 B22_131 ".0 .0 1.0"
10 188.937018000 w4 WS "B22_131"
20 188.937018000 w4 WS B22_131 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 156
10 194.927899000 w2 WS "B"
13 187.254599000 w2 gf 0.000000
13 194.927899000 w2 gf 0.000000
10 194.928595000 w2 WS "Po"
10 194.929663000 w2 WS "B"
10 194.931984000 w2 WS "P"
10 194.932777000 w2 WS "Sc"
13 194.933558000 sched nready 138.000000
13 194.933558000 sched nsubmitted 142.000000
10 194.934158000 w2 WS "B"
10 194.934578000 w2 WS "B"
10 194.935033000 w2 WS "Fi"
10 194.935959000 w2 WS "B"
6 B22_132 WS B22_132 "0.000000 0.600000 0.400000"
6 B22_132_1 Ctx1 B22_132 "1.0 0.39 1.0"
6 B22_132_2 Ctx2 B22_132 ".0 1.0 .0"
6 B22_132_3 Ctx3 B22_132 "0.87 0.87 .0"
6 B22_132_4 Ctx4 B22_132 ".0 0.95 1.0"
6 B22_132_5 Ctx5 B22_132 ".0 .0 .0"
6 B22_132_6 Ctx6 B22_132 ".0 .0 0.5"
6 B22_132_7 Ctx7 B22_132 "0.41 0.41 0.41"
6 B22_132_8 Ctx8 B22_132 "1.0 .0 1.0"
6 B22_132_9 Ctx9 B22_132 ".0 .0 1.0"
10 194.936531000 w2 WS "B22_132"
20 194.936531000 w2 WS B22_132 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 157
10 194.988199000 w3 WS "B"
13 187.227194000 w3 gf 0.000000
13 194.988199000 w3 gf 0.000000
13 187.227194000 sched gft 0.000000
13 187.247075000 sched gft 0.000000
13 187.254599000 sched gft 0.000000
13 187.271139000 sched gft 0.000000
10 194.988895000 w3 WS "Po"
10 194.989754000 w3 WS "B"
10 194.990171000 w1 WS "B"
13 187.278456000 w1 gf 0.000000
13 194.990171000 w1 gf 0.000000
13 187.278456000 sched gft 0.000000
13 187.342177000 sched gft 0.000000
10 194.991174000 w1 WS "Po"
10 194.992107000 w3 WS "P"
10 194.992240000 w1 WS "B"
10 194.992721000 w3 WS "Sc"
13 194.993382000 sched nready 137.000000
13 194.993382000 sched nsubmitted 141.000000
10 194.993933000 w3 WS "B"
10 194.994357000 w3 WS "B"
10 194.994717000 w1 WS "P"
10 194.994768000 w3 WS "Fi"
10 194.995497000 w1 WS "Sc"
10 194.995645000 w3 WS "B"
6 B22_133 WS B22_133 "0.000000 0.600000 0.400000"
6 B22_133_1 Ctx1 B22_133 "1.0 0.39 1.0"
6 B22_133_2 Ctx2 B22_133 ".0 1.0 .0"
6 B22_133_3 Ctx3 B22_133 "0.87 0.87 .0"
6 B22_133_4 Ctx4 B22_133 ".0 0.95 1.0"
6 B22_133_5 Ctx5 B22_133 ".0 .0 .0"
6 B22_133_6 Ctx6 B22_133 ".0 .0 0.5"
6 B22_133_7 Ctx7 B22_133 "0.41 0.41 0.41"
6 B22_133_8 Ctx8 B22_133 "1.0 .0 1.0"
6 B22_133_9 Ctx9 B22_133 ".0 .0 1.0"
10 194.996129000 w3 WS "B22_133"
13 194.996380000 sched nready 136.000000
13 194.996380000 sched nsubmitted 140.000000
10 194.997148000 w1 WS "B"
20 194.996129000 w3 WS B22_133 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 158
10 194.997580000 w1 WS "B"
10 194.998022000 w1 WS "Fi"
10 194.999112000 w1 WS "B"
6 B22_134 WS B22_134 "0.000000 0.600000 0.400000"
6 B22_134_1 Ctx1 B22_134 "1.0 0.39 1.0"
6 B22_134_2 Ctx2 B22_134 ".0 1.0 .0"
6 B22_134_3 Ctx3 B22_134 "0.87 0.87 .0"
6 B22_134_4 Ctx4 B22_134 ".0 0.95 1.0"
6 B22_134_5 Ctx5 B22_134 ".0 .0 .0"
6 B22_134_6 Ctx6 B22_134 ".0 .0 0.5"
6 B22_134_7 Ctx7 B22_134 "0.41 0.41 0.41"
6 B22_134_8 Ctx8 B22_134 "1.0 .0 1.0"
6 B22_134_9 Ctx9 B22_134 ".0 .0 1.0"
10 194.999625000 w1 WS "B22_134"
20 194.999625000 w1 WS B22_134 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 159
10 195.041950000 w0 WS "B"
13 187.350307000 w0 gf 0.000000
13 195.041950000 w0 gf 0.000000
13 187.350307000 sched gft 0.000000
13 188.923050000 sched gft 0.000000
13 188.929177000 sched gft 0.000000
10 195.042718000 w0 WS "Po"
10 195.043618000 w0 WS "B"
10 195.046198000 w0 WS "P"
10 195.046793000 w0 WS "Sc"
13 195.047500000 sched nready 135.000000
13 195.047500000 sched nsubmitted 139.000000
10 195.048009000 w0 WS "B"
10 195.048444000 w0 WS "B"
10 195.048873000 w0 WS "Fi"
10 195.049729000 w0 WS "B"
6 B22_135 WS B22_135 "0.000000 0.600000 0.400000"
6 B22_135_1 Ctx1 B22_135 "1.0 0.39 1.0"
6 B22_135_2 Ctx2 B22_135 ".0 1.0 .0"
6 B22_135_3 Ctx3 B22_135 "0.87 0.87 .0"
6 B22_135_4 Ctx4 B22_135 ".0 0.95 1.0"
6 B22_135_5 Ctx5 B22_135 ".0 .0 .0"
6 B22_135_6 Ctx6 B22_135 ".0 .0 0.5"
6 B22_135_7 Ctx7 B22_135 "0.41 0.41 0.41"
6 B22_135_8 Ctx8 B22_135 "1.0 .0 1.0"
6 B22_135_9 Ctx9 B22_135 ".0 .0 1.0"
10 195.050234000 w0 WS "B22_135"
20 195.050234000 w0 WS B22_135 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 160
10 196.628469000 w5 WS "B"
13 188.930927000 w5 gf 0.000000
13 196.628469000 w5 gf 0.000000
13 188.930927000 sched gft 0.000000
10 196.629361000 w5 WS "Po"
10 196.630342000 w5 WS "B"
10 196.633184000 w5 WS "P"
10 196.633953000 w5 WS "Sc"
13 196.634794000 sched nready 134.000000
13 196.634794000 sched nsubmitted 138.000000
10 196.635380000 w5 WS "B"
10 196.635806000 w5 WS "B"
10 196.636224000 w5 WS "Fi"
10 196.637186000 w5 WS "B"
6 B22_136 WS B22_136 "0.000000 0.600000 0.400000"
6 B22_136_1 Ctx1 B22_136 "1.0 0.39 1.0"
6 B22_136_2 Ctx2 B22_136 ".0 1.0 .0"
6 B22_136_3 Ctx3 B22_136 "0.87 0.87 .0"
6 B22_136_4 Ctx4 B22_136 ".0 0.95 1.0"
6 B22_136_5 Ctx5 B22_136 ".0 .0 .0"
6 B22_136_6 Ctx6 B22_136 ".0 .0 0.5"
6 B22_136_7 Ctx7 B22_136 "0.41 0.41 0.41"
6 B22_136_8 Ctx8 B22_136 "1.0 .0 1.0"
6 B22_136_9 Ctx9 B22_136 ".0 .0 1.0"
10 196.637764000 w5 WS "B22_136"
20 196.637764000 w5 WS B22_136 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 161
10 196.649457000 w4 WS "B"
13 188.937018000 w4 gf 0.000000
13 196.649457000 w4 gf 0.000000
13 188.937018000 sched gft 0.000000
13 194.927899000 sched gft 0.000000
10 196.650266000 w4 WS "Po"
10 196.651184000 w4 WS "B"
10 196.654118000 w4 WS "P"
10 196.655262000 w4 WS "Sc"
13 196.656067000 sched nready 133.000000
13 196.656067000 sched nsubmitted 137.000000
10 196.656897000 w4 WS "B"
10 196.657306000 w4 WS "B"
10 196.657738000 w4 WS "Fi"
10 196.658718000 w4 WS "B"
6 B22_137 WS B22_137 "0.000000 0.600000 0.400000"
6 B22_137_1 Ctx1 B22_137 "1.0 0.39 1.0"
6 B22_137_2 Ctx2 B22_137 ".0 1.0 .0"
6 B22_137_3 Ctx3 B22_137 "0.87 0.87 .0"
6 B22_137_4 Ctx4 B22_137 ".0 0.95 1.0"
6 B22_137_5 Ctx5 B22_137 ".0 .0 .0"
6 B22_137_6 Ctx6 B22_137 ".0 .0 0.5"
6 B22_137_7 Ctx7 B22_137 "0.41 0.41 0.41"
6 B22_137_8 Ctx8 B22_137 "1.0 .0 1.0"
6 B22_137_9 Ctx9 B22_137 ".0 .0 1.0"
10 196.659340000 w4 WS "B22_137"
20 196.659340000 w4 WS B22_137 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 162
10 204.152697000 w3 WS "B"
13 194.996129000 w3 gf 0.000000
13 204.152697000 w3 gf 0.000000
10 204.155073000 w2 WS "B"
13 194.936531000 w2 gf 0.000000
13 204.155073000 w2 gf 0.000000
13 194.936531000 sched gft 0.000000
13 194.988199000 sched gft 0.000000
13 194.990171000 sched gft 0.000000
13 194.996129000 sched gft 0.000000
10 204.155506000 w3 WS "Po"
10 204.156091000 w2 WS "Po"
10 204.160089000 w3 WS "B"
10 204.160393000 w2 WS "B"
10 204.189452000 w3 WS "P"
10 204.191428000 w2 WS "P"
10 204.192694000 w2 WS "Sc"
10 204.192731000 w3 WS "Sc"
13 204.196439000 sched nready 132.000000
13 204.196439000 sched nsubmitted 136.000000
13 204.196841000 sched nready 131.000000
13 204.196841000 sched nsubmitted 135.000000
10 204.197684000 w2 WS "B"
10 204.197904000 w3 WS "B"
10 204.198365000 w2 WS "B"
10 204.198401000 w3 WS "B"
10 204.199808000 w2 WS "Fi"
10 204.199856000 w3 WS "Fi"
10 204.204491000 w2 WS "B"
10 204.204531000 w3 WS "B"
6 B22_138 WS B22_138 "0.000000 0.600000 0.400000"
6 B22_138_1 Ctx1 B22_138 "1.0 0.39 1.0"
6 B22_138_2 Ctx2 B22_138 ".0 1.0 .0"
6 B22_138_3 Ctx3 B22_138 "0.87 0.87 .0"
6 B22_138_4 Ctx4 B22_138 ".0 0.95 1.0"
6 B22_138_5 Ctx5 B22_138 ".0 .0 .0"
6 B22_138_6 Ctx6 B22_138 ".0 .0 0.5"
6 B22_138_7 Ctx7 B22_138 "0.41 0.41 0.41"
6 B22_138_8 Ctx8 B22_138 "1.0 .0 1.0"
6 B22_138_9 Ctx9 B22_138 ".0 .0 1.0"
10 204.205942000 w2 WS "B22_138"
6 B22_139 WS B22_139 "0.000000 0.600000 0.400000"
6 B22_139_1 Ctx1 B22_139 "1.0 0.39 1.0"
6 B22_139_2 Ctx2 B22_139 ".0 1.0 .0"
6 B22_139_3 Ctx3 B22_139 "0.87 0.87 .0"
6 B22_139_4 Ctx4 B22_139 ".0 0.95 1.0"
6 B22_139_5 Ctx5 B22_139 ".0 .0 .0"
6 B22_139_6 Ctx6 B22_139 ".0 .0 0.5"
6 B22_139_7 Ctx7 B22_139 "0.41 0.41 0.41"
6 B22_139_8 Ctx8 B22_139 "1.0 .0 1.0"
6 B22_139_9 Ctx9 B22_139 ".0 .0 1.0"
10 204.206000000 w3 WS "B22_139"
20 204.206000000 w3 WS B22_139 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 164
20 204.205942000 w2 WS B22_138 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 163
10 204.348451000 w0 WS "B"
13 195.050234000 w0 gf 0.000000
13 204.348451000 w0 gf 0.000000
10 204.351357000 w0 WS "Po"
10 204.353646000 w0 WS "B"
10 204.359141000 w0 WS "P"
10 204.359930000 w0 WS "Sc"
13 204.361890000 sched nready 130.000000
13 204.361890000 sched nsubmitted 134.000000
10 204.363189000 w0 WS "B"
10 204.363655000 w0 WS "B"
10 204.364110000 w0 WS "Fi"
10 204.384047000 w0 WS "B"
6 B22_140 WS B22_140 "0.000000 0.600000 0.400000"
6 B22_140_1 Ctx1 B22_140 "1.0 0.39 1.0"
6 B22_140_2 Ctx2 B22_140 ".0 1.0 .0"
6 B22_140_3 Ctx3 B22_140 "0.87 0.87 .0"
6 B22_140_4 Ctx4 B22_140 ".0 0.95 1.0"
6 B22_140_5 Ctx5 B22_140 ".0 .0 .0"
6 B22_140_6 Ctx6 B22_140 ".0 .0 0.5"
6 B22_140_7 Ctx7 B22_140 "0.41 0.41 0.41"
6 B22_140_8 Ctx8 B22_140 "1.0 .0 1.0"
6 B22_140_9 Ctx9 B22_140 ".0 .0 1.0"
10 204.384692000 w0 WS "B22_140"
20 204.384692000 w0 WS B22_140 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 165
10 204.739581000 w1 WS "B"
13 194.999625000 w1 gf 0.000000
13 204.739581000 w1 gf 0.000000
13 194.999625000 sched gft 0.000000
13 195.041950000 sched gft 0.000000
13 195.050234000 sched gft 0.000000
13 196.628469000 sched gft 0.000000
10 204.768399000 w1 WS "Po"
10 204.772477000 w1 WS "B"
10 204.780126000 w1 WS "P"
10 204.782219000 w1 WS "Sc"
13 204.785181000 sched nready 129.000000
13 204.785181000 sched nsubmitted 133.000000
10 204.786882000 w1 WS "B"
10 204.787504000 w1 WS "B"
10 204.788197000 w1 WS "Fi"
10 204.791827000 w1 WS "B"
6 B22_141 WS B22_141 "0.000000 0.600000 0.400000"
6 B22_141_1 Ctx1 B22_141 "1.0 0.39 1.0"
6 B22_141_2 Ctx2 B22_141 ".0 1.0 .0"
6 B22_141_3 Ctx3 B22_141 "0.87 0.87 .0"
6 B22_141_4 Ctx4 B22_141 ".0 0.95 1.0"
6 B22_141_5 Ctx5 B22_141 ".0 .0 .0"
6 B22_141_6 Ctx6 B22_141 ".0 .0 0.5"
6 B22_141_7 Ctx7 B22_141 "0.41 0.41 0.41"
6 B22_141_8 Ctx8 B22_141 "1.0 .0 1.0"
6 B22_141_9 Ctx9 B22_141 ".0 .0 1.0"
10 204.792955000 w1 WS "B22_141"
20 204.792955000 w1 WS B22_141 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 166
10 207.152677000 w4 WS "B"
13 196.659340000 w4 gf 0.000000
13 207.152677000 w4 gf 0.000000
10 207.175511000 w4 WS "Po"
10 207.180720000 w4 WS "B"
10 207.196709000 w4 WS "P"
10 207.202240000 w4 WS "Sc"
13 207.207666000 sched nready 128.000000
13 207.207666000 sched nsubmitted 132.000000
10 207.209128000 w4 WS "B"
10 207.210449000 w4 WS "B"
10 207.211562000 w4 WS "Fi"
10 207.216777000 w4 WS "B"
6 B22_142 WS B22_142 "0.000000 0.600000 0.400000"
6 B22_142_1 Ctx1 B22_142 "1.0 0.39 1.0"
6 B22_142_2 Ctx2 B22_142 ".0 1.0 .0"
6 B22_142_3 Ctx3 B22_142 "0.87 0.87 .0"
6 B22_142_4 Ctx4 B22_142 ".0 0.95 1.0"
6 B22_142_5 Ctx5 B22_142 ".0 .0 .0"
6 B22_142_6 Ctx6 B22_142 ".0 .0 0.5"
6 B22_142_7 Ctx7 B22_142 "0.41 0.41 0.41"
6 B22_142_8 Ctx8 B22_142 "1.0 .0 1.0"
6 B22_142_9 Ctx9 B22_142 ".0 .0 1.0"
10 207.219433000 w4 WS "B22_142"
20 207.219433000 w4 WS B22_142 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 167
10 207.345518000 w5 WS "B"
13 196.637764000 w5 gf 0.000000
13 207.345518000 w5 gf 0.000000
13 196.637764000 sched gft 0.000000
13 196.649457000 sched gft 0.000000
13 196.659340000 sched gft 0.000000
13 204.152697000 sched gft 0.000000
13 204.155073000 sched gft 0.000000
10 207.348244000 w5 WS "Po"
10 207.372112000 w5 WS "B"
10 207.381567000 w5 WS "P"
10 207.383741000 w5 WS "Sc"
13 207.386689000 sched nready 127.000000
13 207.386689000 sched nsubmitted 131.000000
10 207.389430000 w5 WS "B"
10 207.390105000 w5 WS "B"
10 207.391023000 w5 WS "Fi"
10 207.395644000 w5 WS "B"
6 B22_143 WS B22_143 "0.000000 0.600000 0.400000"
6 B22_143_1 Ctx1 B22_143 "1.0 0.39 1.0"
6 B22_143_2 Ctx2 B22_143 ".0 1.0 .0"
6 B22_143_3 Ctx3 B22_143 "0.87 0.87 .0"
6 B22_143_4 Ctx4 B22_143 ".0 0.95 1.0"
6 B22_143_5 Ctx5 B22_143 ".0 .0 .0"
6 B22_143_6 Ctx6 B22_143 ".0 .0 0.5"
6 B22_143_7 Ctx7 B22_143 "0.41 0.41 0.41"
6 B22_143_8 Ctx8 B22_143 "1.0 .0 1.0"
6 B22_143_9 Ctx9 B22_143 ".0 .0 1.0"
10 207.397283000 w5 WS "B22_143"
20 207.397283000 w5 WS B22_143 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 168
10 214.307107000 w3 WS "B"
13 204.206000000 w3 gf 0.000000
13 214.307107000 w3 gf 0.000000
10 214.308634000 w3 WS "Po"
10 214.308767000 w0 WS "B"
13 204.384692000 w0 gf 0.000000
13 214.308767000 w0 gf 0.000000
10 214.309443000 w0 WS "Po"
10 214.309989000 w3 WS "B"
10 214.310482000 w0 WS "B"
10 214.314148000 w3 WS "P"
10 214.314544000 w0 WS "P"
10 214.315216000 w0 WS "Sc"
10 214.315276000 w3 WS "Sc"
13 214.316962000 sched nready 126.000000
13 214.316962000 sched nsubmitted 130.000000
10 214.317617000 w0 WS "B"
10 214.318106000 w0 WS "B"
13 214.318163000 sched nready 125.000000
13 214.318163000 sched nsubmitted 129.000000
10 214.318625000 w0 WS "Fi"
10 214.318716000 w3 WS "B"
10 214.319150000 w3 WS "B"
10 214.319604000 w3 WS "Fi"
10 214.319808000 w0 WS "B"
6 B22_144 WS B22_144 "0.000000 0.600000 0.400000"
6 B22_144_1 Ctx1 B22_144 "1.0 0.39 1.0"
6 B22_144_2 Ctx2 B22_144 ".0 1.0 .0"
6 B22_144_3 Ctx3 B22_144 "0.87 0.87 .0"
6 B22_144_4 Ctx4 B22_144 ".0 0.95 1.0"
6 B22_144_5 Ctx5 B22_144 ".0 .0 .0"
6 B22_144_6 Ctx6 B22_144 ".0 .0 0.5"
6 B22_144_7 Ctx7 B22_144 "0.41 0.41 0.41"
6 B22_144_8 Ctx8 B22_144 "1.0 .0 1.0"
6 B22_144_9 Ctx9 B22_144 ".0 .0 1.0"
10 214.320461000 w0 WS "B22_144"
10 214.320612000 w3 WS "B"
6 B22_145 WS B22_145 "0.000000 0.600000 0.400000"
6 B22_145_1 Ctx1 B22_145 "1.0 0.39 1.0"
6 B22_145_2 Ctx2 B22_145 ".0 1.0 .0"
6 B22_145_3 Ctx3 B22_145 "0.87 0.87 .0"
6 B22_145_4 Ctx4 B22_145 ".0 0.95 1.0"
6 B22_145_5 Ctx5 B22_145 ".0 .0 .0"
6 B22_145_6 Ctx6 B22_145 ".0 .0 0.5"
6 B22_145_7 Ctx7 B22_145 "0.41 0.41 0.41"
6 B22_145_8 Ctx8 B22_145 "1.0 .0 1.0"
6 B22_145_9 Ctx9 B22_145 ".0 .0 1.0"
10 214.321207000 w3 WS "B22_145"
20 214.320461000 w0 WS B22_144 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 169
20 214.321207000 w3 WS B22_145 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 170
10 214.333670000 w2 WS "B"
13 204.205942000 w2 gf 0.000000
13 214.333670000 w2 gf 0.000000
13 204.205942000 sched gft 0.000000
13 204.206000000 sched gft 0.000000
13 204.348451000 sched gft 0.000000
13 204.384692000 sched gft 0.000000
13 204.739581000 sched gft 0.000000
10 214.334273000 w2 WS "Po"
10 214.335342000 w2 WS "B"
10 214.338036000 w2 WS "P"
10 214.338588000 w2 WS "Sc"
13 214.339283000 sched nready 124.000000
13 214.339283000 sched nsubmitted 128.000000
10 214.339775000 w2 WS "B"
10 214.340203000 w2 WS "B"
10 214.340630000 w2 WS "Fi"
10 214.341579000 w2 WS "B"
6 B22_146 WS B22_146 "0.000000 0.600000 0.400000"
6 B22_146_1 Ctx1 B22_146 "1.0 0.39 1.0"
6 B22_146_2 Ctx2 B22_146 ".0 1.0 .0"
6 B22_146_3 Ctx3 B22_146 "0.87 0.87 .0"
6 B22_146_4 Ctx4 B22_146 ".0 0.95 1.0"
6 B22_146_5 Ctx5 B22_146 ".0 .0 .0"
6 B22_146_6 Ctx6 B22_146 ".0 .0 0.5"
6 B22_146_7 Ctx7 B22_146 "0.41 0.41 0.41"
6 B22_146_8 Ctx8 B22_146 "1.0 .0 1.0"
6 B22_146_9 Ctx9 B22_146 ".0 .0 1.0"
10 214.342089000 w2 WS "B22_146"
20 214.342089000 w2 WS B22_146 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 171
10 214.504261000 w1 WS "B"
13 204.792955000 w1 gf 0.000000
13 214.504261000 w1 gf 0.000000
13 204.792955000 sched gft 0.000000
13 207.152677000 sched gft 0.000000
10 214.505121000 w1 WS "Po"
10 214.506009000 w1 WS "B"
10 214.508468000 w1 WS "P"
10 214.509122000 w1 WS "Sc"
13 214.509851000 sched nready 123.000000
13 214.509851000 sched nsubmitted 127.000000
10 214.510396000 w1 WS "B"
10 214.510824000 w1 WS "B"
10 214.511255000 w1 WS "Fi"
10 214.512122000 w1 WS "B"
6 B22_147 WS B22_147 "0.000000 0.600000 0.400000"
6 B22_147_1 Ctx1 B22_147 "1.0 0.39 1.0"
6 B22_147_2 Ctx2 B22_147 ".0 1.0 .0"
6 B22_147_3 Ctx3 B22_147 "0.87 0.87 .0"
6 B22_147_4 Ctx4 B22_147 ".0 0.95 1.0"
6 B22_147_5 Ctx5 B22_147 ".0 .0 .0"
6 B22_147_6 Ctx6 B22_147 ".0 .0 0.5"
6 B22_147_7 Ctx7 B22_147 "0.41 0.41 0.41"
6 B22_147_8 Ctx8 B22_147 "1.0 .0 1.0"
6 B22_147_9 Ctx9 B22_147 ".0 .0 1.0"
10 214.512648000 w1 WS "B22_147"
20 214.512648000 w1 WS B22_147 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 172
10 215.828629000 w4 WS "B"
13 207.219433000 w4 gf 0.000000
13 215.828629000 w4 gf 0.000000
13 207.219433000 sched gft 0.000000
13 207.345518000 sched gft 0.000000
10 215.829307000 w4 WS "Po"
10 215.830151000 w4 WS "B"
10 215.832331000 w4 WS "P"
10 215.832879000 w4 WS "Sc"
13 215.833620000 sched nready 122.000000
13 215.833620000 sched nsubmitted 126.000000
10 215.834478000 w4 WS "B"
10 215.834900000 w4 WS "B"
10 215.835343000 w4 WS "Fi"
10 215.836240000 w4 WS "B"
6 B22_148 WS B22_148 "0.000000 0.600000 0.400000"
6 B22_148_1 Ctx1 B22_148 "1.0 0.39 1.0"
6 B22_148_2 Ctx2 B22_148 ".0 1.0 .0"
6 B22_148_3 Ctx3 B22_148 "0.87 0.87 .0"
6 B22_148_4 Ctx4 B22_148 ".0 0.95 1.0"
6 B22_148_5 Ctx5 B22_148 ".0 .0 .0"
6 B22_148_6 Ctx6 B22_148 ".0 .0 0.5"
6 B22_148_7 Ctx7 B22_148 "0.41 0.41 0.41"
6 B22_148_8 Ctx8 B22_148 "1.0 .0 1.0"
6 B22_148_9 Ctx9 B22_148 ".0 .0 1.0"
10 215.836752000 w4 WS "B22_148"
10 215.837445000 w5 WS "B"
13 207.397283000 w5 gf 0.000000
13 215.837445000 w5 gf 0.000000
13 207.397283000 sched gft 0.000000
13 214.307107000 sched gft 0.000000
13 214.308767000 sched gft 0.000000
20 215.836752000 w4 WS B22_148 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 173
10 215.838057000 w5 WS "Po"
10 215.839004000 w5 WS "B"
10 215.841601000 w5 WS "P"
10 215.842163000 w5 WS "Sc"
13 215.842922000 sched nready 121.000000
13 215.842922000 sched nsubmitted 125.000000
10 215.843406000 w5 WS "B"
10 215.843840000 w5 WS "B"
10 215.844261000 w5 WS "Fi"
10 215.845158000 w5 WS "B"
6 B22_149 WS B22_149 "0.000000 0.600000 0.400000"
6 B22_149_1 Ctx1 B22_149 "1.0 0.39 1.0"
6 B22_149_2 Ctx2 B22_149 ".0 1.0 .0"
6 B22_149_3 Ctx3 B22_149 "0.87 0.87 .0"
6 B22_149_4 Ctx4 B22_149 ".0 0.95 1.0"
6 B22_149_5 Ctx5 B22_149 ".0 .0 .0"
6 B22_149_6 Ctx6 B22_149 ".0 .0 0.5"
6 B22_149_7 Ctx7 B22_149 "0.41 0.41 0.41"
6 B22_149_8 Ctx8 B22_149 "1.0 .0 1.0"
6 B22_149_9 Ctx9 B22_149 ".0 .0 1.0"
10 215.845677000 w5 WS "B22_149"
20 215.845677000 w5 WS B22_149 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 174
10 222.114707000 w2 WS "B"
13 214.342089000 w2 gf 0.000000
13 222.114707000 w2 gf 0.000000
10 222.115521000 w2 WS "Po"
10 222.116658000 w2 WS "B"
10 222.119734000 w2 WS "P"
10 222.120449000 w2 WS "Sc"
13 222.121607000 sched nready 120.000000
13 222.121607000 sched nsubmitted 124.000000
10 222.122068000 w2 WS "B"
10 222.122476000 w2 WS "B"
10 222.122882000 w2 WS "Fi"
10 222.123785000 w2 WS "B"
6 B22_150 WS B22_150 "0.000000 0.600000 0.400000"
6 B22_150_1 Ctx1 B22_150 "1.0 0.39 1.0"
6 B22_150_2 Ctx2 B22_150 ".0 1.0 .0"
6 B22_150_3 Ctx3 B22_150 "0.87 0.87 .0"
6 B22_150_4 Ctx4 B22_150 ".0 0.95 1.0"
6 B22_150_5 Ctx5 B22_150 ".0 .0 .0"
6 B22_150_6 Ctx6 B22_150 ".0 .0 0.5"
6 B22_150_7 Ctx7 B22_150 "0.41 0.41 0.41"
6 B22_150_8 Ctx8 B22_150 "1.0 .0 1.0"
6 B22_150_9 Ctx9 B22_150 ".0 .0 1.0"
10 222.124408000 w2 WS "B22_150"
20 222.124408000 w2 WS B22_150 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 175
10 222.130116000 w3 WS "B"
13 214.321207000 w3 gf 0.000000
13 222.130116000 w3 gf 0.000000
10 222.130782000 w3 WS "Po"
10 222.131770000 w3 WS "B"
10 222.133854000 w0 WS "B"
13 214.320461000 w0 gf 0.000000
13 222.133854000 w0 gf 0.000000
13 214.320461000 sched gft 0.000000
13 214.321207000 sched gft 0.000000
13 214.333670000 sched gft 0.000000
13 214.342089000 sched gft 0.000000
13 214.504261000 sched gft 0.000000
10 222.134463000 w3 WS "P"
10 222.134528000 w0 WS "Po"
10 222.135122000 w3 WS "Sc"
10 222.135536000 w0 WS "B"
13 222.135985000 sched nready 119.000000
13 222.135985000 sched nsubmitted 123.000000
10 222.136456000 w3 WS "B"
10 222.136893000 w3 WS "B"
10 222.137313000 w3 WS "Fi"
10 222.138402000 w3 WS "B"
10 222.138494000 w0 WS "P"
6 B22_151 WS B22_151 "0.000000 0.600000 0.400000"
6 B22_151_1 Ctx1 B22_151 "1.0 0.39 1.0"
6 B22_151_2 Ctx2 B22_151 ".0 1.0 .0"
6 B22_151_3 Ctx3 B22_151 "0.87 0.87 .0"
6 B22_151_4 Ctx4 B22_151 ".0 0.95 1.0"
6 B22_151_5 Ctx5 B22_151 ".0 .0 .0"
6 B22_151_6 Ctx6 B22_151 ".0 .0 0.5"
6 B22_151_7 Ctx7 B22_151 "0.41 0.41 0.41"
6 B22_151_8 Ctx8 B22_151 "1.0 .0 1.0"
6 B22_151_9 Ctx9 B22_151 ".0 .0 1.0"
10 222.138935000 w3 WS "B22_151"
10 222.139171000 w0 WS "Sc"
13 222.139977000 sched nready 118.000000
13 222.139977000 sched nsubmitted 122.000000
20 222.138935000 w3 WS B22_151 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 176
10 222.140508000 w0 WS "B"
10 222.140939000 w0 WS "B"
10 222.141366000 w0 WS "Fi"
10 222.142246000 w0 WS "B"
6 B22_152 WS B22_152 "0.000000 0.600000 0.400000"
6 B22_152_1 Ctx1 B22_152 "1.0 0.39 1.0"
6 B22_152_2 Ctx2 B22_152 ".0 1.0 .0"
6 B22_152_3 Ctx3 B22_152 "0.87 0.87 .0"
6 B22_152_4 Ctx4 B22_152 ".0 0.95 1.0"
6 B22_152_5 Ctx5 B22_152 ".0 .0 .0"
6 B22_152_6 Ctx6 B22_152 ".0 .0 0.5"
6 B22_152_7 Ctx7 B22_152 "0.41 0.41 0.41"
6 B22_152_8 Ctx8 B22_152 "1.0 .0 1.0"
6 B22_152_9 Ctx9 B22_152 ".0 .0 1.0"
10 222.142738000 w0 WS "B22_152"
20 222.142738000 w0 WS B22_152 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 177
10 222.293125000 w1 WS "B"
13 214.512648000 w1 gf 0.000000
13 222.293125000 w1 gf 0.000000
13 214.512648000 sched gft 0.000000
13 215.828629000 sched gft 0.000000
10 222.293936000 w1 WS "Po"
10 222.295219000 w1 WS "B"
10 222.297671000 w1 WS "P"
10 222.298284000 w1 WS "Sc"
13 222.299003000 sched nready 117.000000
13 222.299003000 sched nsubmitted 121.000000
10 222.299861000 w1 WS "B"
10 222.300270000 w1 WS "B"
10 222.300731000 w1 WS "Fi"
10 222.301594000 w1 WS "B"
6 B22_153 WS B22_153 "0.000000 0.600000 0.400000"
6 B22_153_1 Ctx1 B22_153 "1.0 0.39 1.0"
6 B22_153_2 Ctx2 B22_153 ".0 1.0 .0"
6 B22_153_3 Ctx3 B22_153 "0.87 0.87 .0"
6 B22_153_4 Ctx4 B22_153 ".0 0.95 1.0"
6 B22_153_5 Ctx5 B22_153 ".0 .0 .0"
6 B22_153_6 Ctx6 B22_153 ".0 .0 0.5"
6 B22_153_7 Ctx7 B22_153 "0.41 0.41 0.41"
6 B22_153_8 Ctx8 B22_153 "1.0 .0 1.0"
6 B22_153_9 Ctx9 B22_153 ".0 .0 1.0"
10 222.302134000 w1 WS "B22_153"
20 222.302134000 w1 WS B22_153 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 178
10 223.600869000 w4 WS "B"
13 215.836752000 w4 gf 0.000000
13 223.600869000 w4 gf 0.000000
13 215.836752000 sched gft 0.000000
13 215.837445000 sched gft 0.000000
10 223.601419000 w4 WS "Po"
10 223.602179000 w4 WS "B"
10 223.604373000 w4 WS "P"
10 223.604904000 w4 WS "Sc"
13 223.605969000 sched nready 116.000000
13 223.605969000 sched nsubmitted 120.000000
10 223.606449000 w4 WS "B"
10 223.606855000 w4 WS "B"
10 223.607259000 w4 WS "Fi"
10 223.608163000 w4 WS "B"
6 B22_154 WS B22_154 "0.000000 0.600000 0.400000"
6 B22_154_1 Ctx1 B22_154 "1.0 0.39 1.0"
6 B22_154_2 Ctx2 B22_154 ".0 1.0 .0"
6 B22_154_3 Ctx3 B22_154 "0.87 0.87 .0"
6 B22_154_4 Ctx4 B22_154 ".0 0.95 1.0"
6 B22_154_5 Ctx5 B22_154 ".0 .0 .0"
6 B22_154_6 Ctx6 B22_154 ".0 .0 0.5"
6 B22_154_7 Ctx7 B22_154 "0.41 0.41 0.41"
6 B22_154_8 Ctx8 B22_154 "1.0 .0 1.0"
6 B22_154_9 Ctx9 B22_154 ".0 .0 1.0"
10 223.608664000 w4 WS "B22_154"
20 223.608664000 w4 WS B22_154 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 179
10 223.617094000 w5 WS "B"
13 215.845677000 w5 gf 0.000000
13 223.617094000 w5 gf 0.000000
13 215.845677000 sched gft 0.000000
13 222.114707000 sched gft 0.000000
10 223.617741000 w5 WS "Po"
10 223.618598000 w5 WS "B"
10 223.621212000 w5 WS "P"
10 223.621881000 w5 WS "Sc"
13 223.622620000 sched nready 115.000000
13 223.622620000 sched nsubmitted 119.000000
10 223.623111000 w5 WS "B"
10 223.623526000 w5 WS "B"
10 223.623950000 w5 WS "Fi"
10 223.624901000 w5 WS "B"
6 B22_155 WS B22_155 "0.000000 0.600000 0.400000"
6 B22_155_1 Ctx1 B22_155 "1.0 0.39 1.0"
6 B22_155_2 Ctx2 B22_155 ".0 1.0 .0"
6 B22_155_3 Ctx3 B22_155 "0.87 0.87 .0"
6 B22_155_4 Ctx4 B22_155 ".0 0.95 1.0"
6 B22_155_5 Ctx5 B22_155 ".0 .0 .0"
6 B22_155_6 Ctx6 B22_155 ".0 .0 0.5"
6 B22_155_7 Ctx7 B22_155 "0.41 0.41 0.41"
6 B22_155_8 Ctx8 B22_155 "1.0 .0 1.0"
6 B22_155_9 Ctx9 B22_155 ".0 .0 1.0"
10 223.625406000 w5 WS "B22_155"
20 223.625406000 w5 WS B22_155 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 180
10 229.807701000 w2 WS "B"
13 222.124408000 w2 gf 0.000000
13 229.807701000 w2 gf 0.000000
13 222.124408000 sched gft 0.000000
13 222.130116000 sched gft 0.000000
13 222.133854000 sched gft 0.000000
10 229.808671000 w2 WS "Po"
10 229.809558000 w2 WS "B"
10 229.812433000 w2 WS "P"
10 229.812939000 w3 WS "B"
13 222.138935000 w3 gf 0.000000
13 229.812939000 w3 gf 0.000000
13 222.138935000 sched gft 0.000000
10 229.813294000 w2 WS "Sc"
10 229.813545000 w3 WS "Po"
13 229.814088000 sched nready 114.000000
13 229.814088000 sched nsubmitted 118.000000
10 229.814471000 w3 WS "B"
10 229.814664000 w2 WS "B"
10 229.815194000 w2 WS "B"
10 229.815665000 w2 WS "Fi"
10 229.816756000 w2 WS "B"
10 229.817175000 w3 WS "P"
6 B22_156 WS B22_156 "0.000000 0.600000 0.400000"
6 B22_156_1 Ctx1 B22_156 "1.0 0.39 1.0"
6 B22_156_2 Ctx2 B22_156 ".0 1.0 .0"
6 B22_156_3 Ctx3 B22_156 "0.87 0.87 .0"
6 B22_156_4 Ctx4 B22_156 ".0 0.95 1.0"
6 B22_156_5 Ctx5 B22_156 ".0 .0 .0"
6 B22_156_6 Ctx6 B22_156 ".0 .0 0.5"
6 B22_156_7 Ctx7 B22_156 "0.41 0.41 0.41"
6 B22_156_8 Ctx8 B22_156 "1.0 .0 1.0"
6 B22_156_9 Ctx9 B22_156 ".0 .0 1.0"
10 229.817363000 w2 WS "B22_156"
10 229.817978000 w3 WS "Sc"
20 229.817363000 w2 WS B22_156 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 181
13 229.818796000 sched nready 113.000000
13 229.818796000 sched nsubmitted 117.000000
10 229.819364000 w3 WS "B"
10 229.819560000 w0 WS "B"
13 222.142738000 w0 gf 0.000000
13 229.819560000 w0 gf 0.000000
13 222.142738000 sched gft 0.000000
13 222.293125000 sched gft 0.000000
10 229.819787000 w3 WS "B"
10 229.820163000 w0 WS "Po"
10 229.820233000 w3 WS "Fi"
10 229.821282000 w3 WS "B"
10 229.821394000 w0 WS "B"
6 B22_157 WS B22_157 "0.000000 0.600000 0.400000"
6 B22_157_1 Ctx1 B22_157 "1.0 0.39 1.0"
6 B22_157_2 Ctx2 B22_157 ".0 1.0 .0"
6 B22_157_3 Ctx3 B22_157 "0.87 0.87 .0"
6 B22_157_4 Ctx4 B22_157 ".0 0.95 1.0"
6 B22_157_5 Ctx5 B22_157 ".0 .0 .0"
6 B22_157_6 Ctx6 B22_157 ".0 .0 0.5"
6 B22_157_7 Ctx7 B22_157 "0.41 0.41 0.41"
6 B22_157_8 Ctx8 B22_157 "1.0 .0 1.0"
6 B22_157_9 Ctx9 B22_157 ".0 .0 1.0"
10 229.821808000 w3 WS "B22_157"
20 229.821808000 w3 WS B22_157 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 182
10 229.823918000 w0 WS "P"
10 229.824455000 w0 WS "Sc"
13 229.825217000 sched nready 112.000000
13 229.825217000 sched nsubmitted 116.000000
10 229.825707000 w0 WS "B"
10 229.826130000 w0 WS "B"
10 229.826539000 w0 WS "Fi"
10 229.827560000 w0 WS "B"
6 B22_158 WS B22_158 "0.000000 0.600000 0.400000"
6 B22_158_1 Ctx1 B22_158 "1.0 0.39 1.0"
6 B22_158_2 Ctx2 B22_158 ".0 1.0 .0"
6 B22_158_3 Ctx3 B22_158 "0.87 0.87 .0"
6 B22_158_4 Ctx4 B22_158 ".0 0.95 1.0"
6 B22_158_5 Ctx5 B22_158 ".0 .0 .0"
6 B22_158_6 Ctx6 B22_158 ".0 .0 0.5"
6 B22_158_7 Ctx7 B22_158 "0.41 0.41 0.41"
6 B22_158_8 Ctx8 B22_158 "1.0 .0 1.0"
6 B22_158_9 Ctx9 B22_158 ".0 .0 1.0"
10 229.828102000 w0 WS "B22_158"
20 229.828102000 w0 WS B22_158 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 183
10 229.958739000 w1 WS "B"
13 222.302134000 w1 gf 0.000000
13 229.958739000 w1 gf 0.000000
13 222.302134000 sched gft 0.000000
13 223.600869000 sched gft 0.000000
10 229.959306000 w1 WS "Po"
10 229.960087000 w1 WS "B"
10 229.962032000 w1 WS "P"
10 229.962576000 w1 WS "Sc"
13 229.963243000 sched nready 111.000000
13 229.963243000 sched nsubmitted 115.000000
10 229.963712000 w1 WS "B"
10 229.964121000 w1 WS "B"
10 229.964529000 w1 WS "Fi"
10 229.965366000 w1 WS "B"
6 B22_159 WS B22_159 "0.000000 0.600000 0.400000"
6 B22_159_1 Ctx1 B22_159 "1.0 0.39 1.0"
6 B22_159_2 Ctx2 B22_159 ".0 1.0 .0"
6 B22_159_3 Ctx3 B22_159 "0.87 0.87 .0"
6 B22_159_4 Ctx4 B22_159 ".0 0.95 1.0"
6 B22_159_5 Ctx5 B22_159 ".0 .0 .0"
6 B22_159_6 Ctx6 B22_159 ".0 .0 0.5"
6 B22_159_7 Ctx7 B22_159 "0.41 0.41 0.41"
6 B22_159_8 Ctx8 B22_159 "1.0 .0 1.0"
6 B22_159_9 Ctx9 B22_159 ".0 .0 1.0"
10 229.965895000 w1 WS "B22_159"
20 229.965895000 w1 WS B22_159 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 184
10 231.303469000 w5 WS "B"
13 223.625406000 w5 gf 0.000000
13 231.303469000 w5 gf 0.000000
10 231.304117000 w5 WS "Po"
10 231.305222000 w5 WS "B"
10 231.307352000 w5 WS "P"
10 231.307897000 w5 WS "Sc"
13 231.308609000 sched nready 110.000000
13 231.308609000 sched nsubmitted 114.000000
10 231.309152000 w5 WS "B"
10 231.309575000 w5 WS "B"
10 231.309985000 w5 WS "Fi"
10 231.310877000 w5 WS "B"
6 B22_160 WS B22_160 "0.000000 0.600000 0.400000"
6 B22_160_1 Ctx1 B22_160 "1.0 0.39 1.0"
6 B22_160_2 Ctx2 B22_160 ".0 1.0 .0"
6 B22_160_3 Ctx3 B22_160 "0.87 0.87 .0"
6 B22_160_4 Ctx4 B22_160 ".0 0.95 1.0"
6 B22_160_5 Ctx5 B22_160 ".0 .0 .0"
6 B22_160_6 Ctx6 B22_160 ".0 .0 0.5"
6 B22_160_7 Ctx7 B22_160 "0.41 0.41 0.41"
6 B22_160_8 Ctx8 B22_160 "1.0 .0 1.0"
6 B22_160_9 Ctx9 B22_160 ".0 .0 1.0"
10 231.311380000 w5 WS "B22_160"
20 231.311380000 w5 WS B22_160 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 185
10 231.389904000 w4 WS "B"
13 223.608664000 w4 gf 0.000000
13 231.389904000 w4 gf 0.000000
13 223.608664000 sched gft 0.000000
13 223.617094000 sched gft 0.000000
13 223.625406000 sched gft 0.000000
13 229.807701000 sched gft 0.000000
13 229.812939000 sched gft 0.000000
10 231.390737000 w4 WS "Po"
10 231.391548000 w4 WS "B"
10 231.393813000 w4 WS "P"
10 231.394356000 w4 WS "Sc"
13 231.395073000 sched nready 109.000000
13 231.395073000 sched nsubmitted 113.000000
10 231.395548000 w4 WS "B"
10 231.395959000 w4 WS "B"
10 231.396363000 w4 WS "Fi"
10 231.397198000 w4 WS "B"
6 B22_161 WS B22_161 "0.000000 0.600000 0.400000"
6 B22_161_1 Ctx1 B22_161 "1.0 0.39 1.0"
6 B22_161_2 Ctx2 B22_161 ".0 1.0 .0"
6 B22_161_3 Ctx3 B22_161 "0.87 0.87 .0"
6 B22_161_4 Ctx4 B22_161 ".0 0.95 1.0"
6 B22_161_5 Ctx5 B22_161 ".0 .0 .0"
6 B22_161_6 Ctx6 B22_161 ".0 .0 0.5"
6 B22_161_7 Ctx7 B22_161 "0.41 0.41 0.41"
6 B22_161_8 Ctx8 B22_161 "1.0 .0 1.0"
6 B22_161_9 Ctx9 B22_161 ".0 .0 1.0"
10 231.397691000 w4 WS "B22_161"
20 231.397691000 w4 WS B22_161 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 186
10 237.506901000 w2 WS "B"
13 229.817363000 w2 gf 0.000000
13 237.506901000 w2 gf 0.000000
13 229.817363000 sched gft 0.000000
13 229.819560000 sched gft 0.000000
10 237.507711000 w2 WS "Po"
10 237.508594000 w2 WS "B"
10 237.511269000 w2 WS "P"
10 237.511977000 w2 WS "Sc"
13 237.512827000 sched nready 108.000000
13 237.512827000 sched nsubmitted 112.000000
10 237.513324000 w3 WS "B"
13 229.821808000 w3 gf 0.000000
13 237.513324000 w3 gf 0.000000
13 229.821808000 sched gft 0.000000
10 237.513438000 w2 WS "B"
10 237.513854000 w2 WS "B"
10 237.513951000 w3 WS "Po"
10 237.514315000 w2 WS "Fi"
10 237.514884000 w3 WS "B"
10 237.515374000 w2 WS "B"
6 B22_162 WS B22_162 "0.000000 0.600000 0.400000"
6 B22_162_1 Ctx1 B22_162 "1.0 0.39 1.0"
6 B22_162_2 Ctx2 B22_162 ".0 1.0 .0"
6 B22_162_3 Ctx3 B22_162 "0.87 0.87 .0"
6 B22_162_4 Ctx4 B22_162 ".0 0.95 1.0"
6 B22_162_5 Ctx5 B22_162 ".0 .0 .0"
6 B22_162_6 Ctx6 B22_162 ".0 .0 0.5"
6 B22_162_7 Ctx7 B22_162 "0.41 0.41 0.41"
6 B22_162_8 Ctx8 B22_162 "1.0 .0 1.0"
6 B22_162_9 Ctx9 B22_162 ".0 .0 1.0"
10 237.516052000 w2 WS "B22_162"
20 237.516052000 w2 WS B22_162 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 187
10 237.517415000 w3 WS "P"
10 237.518027000 w3 WS "Sc"
13 237.518783000 sched nready 107.000000
13 237.518783000 sched nsubmitted 111.000000
10 237.519265000 w3 WS "B"
10 237.519685000 w3 WS "B"
10 237.520094000 w3 WS "Fi"
10 237.520502000 w0 WS "B"
13 229.828102000 w0 gf 0.000000
13 237.520502000 w0 gf 0.000000
13 229.828102000 sched gft 0.000000
13 229.958739000 sched gft 0.000000
10 237.521045000 w3 WS "B"
10 237.521147000 w0 WS "Po"
6 B22_163 WS B22_163 "0.000000 0.600000 0.400000"
6 B22_163_1 Ctx1 B22_163 "1.0 0.39 1.0"
6 B22_163_2 Ctx2 B22_163 ".0 1.0 .0"
6 B22_163_3 Ctx3 B22_163 "0.87 0.87 .0"
6 B22_163_4 Ctx4 B22_163 ".0 0.95 1.0"
6 B22_163_5 Ctx5 B22_163 ".0 .0 .0"
6 B22_163_6 Ctx6 B22_163 ".0 .0 0.5"
6 B22_163_7 Ctx7 B22_163 "0.41 0.41 0.41"
6 B22_163_8 Ctx8 B22_163 "1.0 .0 1.0"
6 B22_163_9 Ctx9 B22_163 ".0 .0 1.0"
10 237.521594000 w3 WS "B22_163"
10 237.522129000 w0 WS "B"
20 237.521594000 w3 WS B22_163 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 188
10 237.524888000 w0 WS "P"
10 237.525488000 w0 WS "Sc"
13 237.526193000 sched nready 106.000000
13 237.526193000 sched nsubmitted 110.000000
10 237.526691000 w0 WS "B"
10 237.527114000 w0 WS "B"
10 237.527524000 w0 WS "Fi"
10 237.528403000 w0 WS "B"
6 B22_164 WS B22_164 "0.000000 0.600000 0.400000"
6 B22_164_1 Ctx1 B22_164 "1.0 0.39 1.0"
6 B22_164_2 Ctx2 B22_164 ".0 1.0 .0"
6 B22_164_3 Ctx3 B22_164 "0.87 0.87 .0"
6 B22_164_4 Ctx4 B22_164 ".0 0.95 1.0"
6 B22_164_5 Ctx5 B22_164 ".0 .0 .0"
6 B22_164_6 Ctx6 B22_164 ".0 .0 0.5"
6 B22_164_7 Ctx7 B22_164 "0.41 0.41 0.41"
6 B22_164_8 Ctx8 B22_164 "1.0 .0 1.0"
6 B22_164_9 Ctx9 B22_164 ".0 .0 1.0"
10 237.528900000 w0 WS "B22_164"
20 237.528900000 w0 WS B22_164 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 189
10 237.608667000 w1 WS "B"
13 229.965895000 w1 gf 0.000000
13 237.608667000 w1 gf 0.000000
13 229.965895000 sched gft 0.000000
13 231.303469000 sched gft 0.000000
10 237.609188000 w1 WS "Po"
10 237.610029000 w1 WS "B"
10 237.612296000 w1 WS "P"
10 237.612910000 w1 WS "Sc"
13 237.613558000 sched nready 105.000000
13 237.613558000 sched nsubmitted 109.000000
10 237.614307000 w1 WS "B"
10 237.614713000 w1 WS "B"
10 237.615118000 w1 WS "Fi"
10 237.616055000 w1 WS "B"
6 B22_165 WS B22_165 "0.000000 0.600000 0.400000"
6 B22_165_1 Ctx1 B22_165 "1.0 0.39 1.0"
6 B22_165_2 Ctx2 B22_165 ".0 1.0 .0"
6 B22_165_3 Ctx3 B22_165 "0.87 0.87 .0"
6 B22_165_4 Ctx4 B22_165 ".0 0.95 1.0"
6 B22_165_5 Ctx5 B22_165 ".0 .0 .0"
6 B22_165_6 Ctx6 B22_165 ".0 .0 0.5"
6 B22_165_7 Ctx7 B22_165 "0.41 0.41 0.41"
6 B22_165_8 Ctx8 B22_165 "1.0 .0 1.0"
6 B22_165_9 Ctx9 B22_165 ".0 .0 1.0"
10 237.616542000 w1 WS "B22_165"
20 237.616542000 w1 WS B22_165 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 190
10 239.004547000 w5 WS "B"
13 231.311380000 w5 gf 0.000000
13 239.004547000 w5 gf 0.000000
13 231.311380000 sched gft 0.000000
13 231.389904000 sched gft 0.000000
10 239.005139000 w5 WS "Po"
10 239.006178000 w5 WS "B"
10 239.008654000 w5 WS "P"
10 239.009272000 w5 WS "Sc"
13 239.009930000 sched nready 104.000000
13 239.009930000 sched nsubmitted 108.000000
10 239.010476000 w5 WS "B"
10 239.010892000 w5 WS "B"
10 239.011302000 w5 WS "Fi"
10 239.012166000 w5 WS "B"
6 B22_166 WS B22_166 "0.000000 0.600000 0.400000"
6 B22_166_1 Ctx1 B22_166 "1.0 0.39 1.0"
6 B22_166_2 Ctx2 B22_166 ".0 1.0 .0"
6 B22_166_3 Ctx3 B22_166 "0.87 0.87 .0"
6 B22_166_4 Ctx4 B22_166 ".0 0.95 1.0"
6 B22_166_5 Ctx5 B22_166 ".0 .0 .0"
6 B22_166_6 Ctx6 B22_166 ".0 .0 0.5"
6 B22_166_7 Ctx7 B22_166 "0.41 0.41 0.41"
6 B22_166_8 Ctx8 B22_166 "1.0 .0 1.0"
6 B22_166_9 Ctx9 B22_166 ".0 .0 1.0"
10 239.012690000 w5 WS "B22_166"
20 239.012690000 w5 WS B22_166 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 191
10 239.058133000 w4 WS "B"
13 231.397691000 w4 gf 0.000000
13 239.058133000 w4 gf 0.000000
13 231.397691000 sched gft 0.000000
13 237.506901000 sched gft 0.000000
13 237.513324000 sched gft 0.000000
10 239.058709000 w4 WS "Po"
10 239.059480000 w4 WS "B"
10 239.062126000 w4 WS "P"
10 239.062716000 w4 WS "Sc"
13 239.063431000 sched nready 103.000000
13 239.063431000 sched nsubmitted 107.000000
10 239.063913000 w4 WS "B"
10 239.064318000 w4 WS "B"
10 239.064719000 w4 WS "Fi"
10 239.065536000 w4 WS "B"
6 B22_167 WS B22_167 "0.000000 0.600000 0.400000"
6 B22_167_1 Ctx1 B22_167 "1.0 0.39 1.0"
6 B22_167_2 Ctx2 B22_167 ".0 1.0 .0"
6 B22_167_3 Ctx3 B22_167 "0.87 0.87 .0"
6 B22_167_4 Ctx4 B22_167 ".0 0.95 1.0"
6 B22_167_5 Ctx5 B22_167 ".0 .0 .0"
6 B22_167_6 Ctx6 B22_167 ".0 .0 0.5"
6 B22_167_7 Ctx7 B22_167 "0.41 0.41 0.41"
6 B22_167_8 Ctx8 B22_167 "1.0 .0 1.0"
6 B22_167_9 Ctx9 B22_167 ".0 .0 1.0"
10 239.066005000 w4 WS "B22_167"
20 239.066005000 w4 WS B22_167 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 192
10 245.215232000 w2 WS "B"
13 237.516052000 w2 gf 0.000000
13 245.215232000 w2 gf 0.000000
13 237.516052000 sched gft 0.000000
13 237.520502000 sched gft 0.000000
10 245.216141000 w2 WS "Po"
10 245.217142000 w2 WS "B"
10 245.219643000 w2 WS "P"
10 245.220367000 w2 WS "Sc"
13 245.221247000 sched nready 102.000000
13 245.221247000 sched nsubmitted 106.000000
10 245.221864000 w2 WS "B"
10 245.222153000 w3 WS "B"
13 237.521594000 w3 gf 0.000000
13 245.222153000 w3 gf 0.000000
13 237.521594000 sched gft 0.000000
10 245.222424000 w2 WS "B"
10 245.222762000 w3 WS "Po"
10 245.222890000 w2 WS "Fi"
10 245.223595000 w3 WS "B"
10 245.223839000 w2 WS "B"
6 B22_168 WS B22_168 "0.000000 0.600000 0.400000"
6 B22_168_1 Ctx1 B22_168 "1.0 0.39 1.0"
6 B22_168_2 Ctx2 B22_168 ".0 1.0 .0"
6 B22_168_3 Ctx3 B22_168 "0.87 0.87 .0"
6 B22_168_4 Ctx4 B22_168 ".0 0.95 1.0"
6 B22_168_5 Ctx5 B22_168 ".0 .0 .0"
6 B22_168_6 Ctx6 B22_168 ".0 .0 0.5"
6 B22_168_7 Ctx7 B22_168 "0.41 0.41 0.41"
6 B22_168_8 Ctx8 B22_168 "1.0 .0 1.0"
6 B22_168_9 Ctx9 B22_168 ".0 .0 1.0"
10 245.224450000 w2 WS "B22_168"
20 245.224450000 w2 WS B22_168 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 193
10 245.226195000 w3 WS "P"
10 245.226859000 w3 WS "Sc"
13 245.227603000 sched nready 101.000000
13 245.227603000 sched nsubmitted 105.000000
10 245.228083000 w3 WS "B"
10 245.228500000 w3 WS "B"
10 245.228911000 w3 WS "Fi"
10 245.229013000 w0 WS "B"
13 237.528900000 w0 gf 0.000000
13 245.229013000 w0 gf 0.000000
13 237.528900000 sched gft 0.000000
13 237.608667000 sched gft 0.000000
10 245.229826000 w0 WS "Po"
10 245.229886000 w3 WS "B"
6 B22_169 WS B22_169 "0.000000 0.600000 0.400000"
6 B22_169_1 Ctx1 B22_169 "1.0 0.39 1.0"
6 B22_169_2 Ctx2 B22_169 ".0 1.0 .0"
6 B22_169_3 Ctx3 B22_169 "0.87 0.87 .0"
6 B22_169_4 Ctx4 B22_169 ".0 0.95 1.0"
6 B22_169_5 Ctx5 B22_169 ".0 .0 .0"
6 B22_169_6 Ctx6 B22_169 ".0 .0 0.5"
6 B22_169_7 Ctx7 B22_169 "0.41 0.41 0.41"
6 B22_169_8 Ctx8 B22_169 "1.0 .0 1.0"
6 B22_169_9 Ctx9 B22_169 ".0 .0 1.0"
10 245.230375000 w3 WS "B22_169"
10 245.230686000 w0 WS "B"
20 245.230375000 w3 WS B22_169 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 194
10 245.233128000 w0 WS "P"
10 245.233675000 w0 WS "Sc"
13 245.234443000 sched nready 100.000000
13 245.234443000 sched nsubmitted 104.000000
10 245.235008000 w0 WS "B"
10 245.235428000 w0 WS "B"
10 245.235842000 w0 WS "Fi"
10 245.237214000 w0 WS "B"
6 B22_170 WS B22_170 "0.000000 0.600000 0.400000"
6 B22_170_1 Ctx1 B22_170 "1.0 0.39 1.0"
6 B22_170_2 Ctx2 B22_170 ".0 1.0 .0"
6 B22_170_3 Ctx3 B22_170 "0.87 0.87 .0"
6 B22_170_4 Ctx4 B22_170 ".0 0.95 1.0"
6 B22_170_5 Ctx5 B22_170 ".0 .0 .0"
6 B22_170_6 Ctx6 B22_170 ".0 .0 0.5"
6 B22_170_7 Ctx7 B22_170 "0.41 0.41 0.41"
6 B22_170_8 Ctx8 B22_170 "1.0 .0 1.0"
6 B22_170_9 Ctx9 B22_170 ".0 .0 1.0"
10 245.237740000 w0 WS "B22_170"
20 245.237740000 w0 WS B22_170 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 195
10 245.279675000 w1 WS "B"
13 237.616542000 w1 gf 0.000000
13 245.279675000 w1 gf 0.000000
13 237.616542000 sched gft 0.000000
13 239.004547000 sched gft 0.000000
10 245.280239000 w1 WS "Po"
10 245.281067000 w1 WS "B"
10 245.283120000 w1 WS "P"
10 245.283628000 w1 WS "Sc"
13 245.284306000 sched nready 99.000000
13 245.284306000 sched nsubmitted 103.000000
10 245.284771000 w1 WS "B"
10 245.285182000 w1 WS "B"
10 245.285591000 w1 WS "Fi"
10 245.286411000 w1 WS "B"
6 B22_171 WS B22_171 "0.000000 0.600000 0.400000"
6 B22_171_1 Ctx1 B22_171 "1.0 0.39 1.0"
6 B22_171_2 Ctx2 B22_171 ".0 1.0 .0"
6 B22_171_3 Ctx3 B22_171 "0.87 0.87 .0"
6 B22_171_4 Ctx4 B22_171 ".0 0.95 1.0"
6 B22_171_5 Ctx5 B22_171 ".0 .0 .0"
6 B22_171_6 Ctx6 B22_171 ".0 .0 0.5"
6 B22_171_7 Ctx7 B22_171 "0.41 0.41 0.41"
6 B22_171_8 Ctx8 B22_171 "1.0 .0 1.0"
6 B22_171_9 Ctx9 B22_171 ".0 .0 1.0"
10 245.286900000 w1 WS "B22_171"
20 245.286900000 w1 WS B22_171 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 196
10 246.768267000 w5 WS "B"
13 239.012690000 w5 gf 0.000000
13 246.768267000 w5 gf 0.000000
13 239.012690000 sched gft 0.000000
13 239.058133000 sched gft 0.000000
10 246.768931000 w5 WS "Po"
10 246.769901000 w5 WS "B"
10 246.772305000 w5 WS "P"
10 246.772935000 w5 WS "Sc"
13 246.773611000 sched nready 98.000000
13 246.773611000 sched nsubmitted 102.000000
10 246.774098000 w5 WS "B"
10 246.774515000 w5 WS "B"
10 246.774976000 w5 WS "Fi"
10 246.775876000 w5 WS "B"
6 B22_172 WS B22_172 "0.000000 0.600000 0.400000"
6 B22_172_1 Ctx1 B22_172 "1.0 0.39 1.0"
6 B22_172_2 Ctx2 B22_172 ".0 1.0 .0"
6 B22_172_3 Ctx3 B22_172 "0.87 0.87 .0"
6 B22_172_4 Ctx4 B22_172 ".0 0.95 1.0"
6 B22_172_5 Ctx5 B22_172 ".0 .0 .0"
6 B22_172_6 Ctx6 B22_172 ".0 .0 0.5"
6 B22_172_7 Ctx7 B22_172 "0.41 0.41 0.41"
6 B22_172_8 Ctx8 B22_172 "1.0 .0 1.0"
6 B22_172_9 Ctx9 B22_172 ".0 .0 1.0"
10 246.776373000 w5 WS "B22_172"
20 246.776373000 w5 WS B22_172 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 197
10 246.782935000 w4 WS "B"
13 239.066005000 w4 gf 0.000000
13 246.782935000 w4 gf 0.000000
13 239.066005000 sched gft 0.000000
13 245.215232000 sched gft 0.000000
13 245.222153000 sched gft 0.000000
10 246.783456000 w4 WS "Po"
10 246.784247000 w4 WS "B"
10 246.786534000 w4 WS "P"
10 246.787082000 w4 WS "Sc"
13 246.787689000 sched nready 97.000000
13 246.787689000 sched nsubmitted 101.000000
10 246.788150000 w4 WS "B"
10 246.788563000 w4 WS "B"
10 246.788971000 w4 WS "Fi"
10 246.789846000 w4 WS "B"
6 B22_173 WS B22_173 "0.000000 0.600000 0.400000"
6 B22_173_1 Ctx1 B22_173 "1.0 0.39 1.0"
6 B22_173_2 Ctx2 B22_173 ".0 1.0 .0"
6 B22_173_3 Ctx3 B22_173 "0.87 0.87 .0"
6 B22_173_4 Ctx4 B22_173 ".0 0.95 1.0"
6 B22_173_5 Ctx5 B22_173 ".0 .0 .0"
6 B22_173_6 Ctx6 B22_173 ".0 .0 0.5"
6 B22_173_7 Ctx7 B22_173 "0.41 0.41 0.41"
6 B22_173_8 Ctx8 B22_173 "1.0 .0 1.0"
6 B22_173_9 Ctx9 B22_173 ".0 .0 1.0"
10 246.790330000 w4 WS "B22_173"
20 246.790330000 w4 WS B22_173 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 198
10 252.905489000 w2 WS "B"
13 245.224450000 w2 gf 0.000000
13 252.905489000 w2 gf 0.000000
13 245.224450000 sched gft 0.000000
13 245.229013000 sched gft 0.000000
10 252.906385000 w2 WS "Po"
10 252.907297000 w2 WS "B"
10 252.910373000 w2 WS "P"
10 252.911013000 w2 WS "Sc"
13 252.911801000 sched nready 96.000000
13 252.911801000 sched nsubmitted 100.000000
10 252.912377000 w2 WS "B"
10 252.912789000 w2 WS "B"
10 252.913246000 w2 WS "Fi"
10 252.914376000 w2 WS "B"
6 B22_174 WS B22_174 "0.000000 0.600000 0.400000"
6 B22_174_1 Ctx1 B22_174 "1.0 0.39 1.0"
6 B22_174_2 Ctx2 B22_174 ".0 1.0 .0"
6 B22_174_3 Ctx3 B22_174 "0.87 0.87 .0"
6 B22_174_4 Ctx4 B22_174 ".0 0.95 1.0"
6 B22_174_5 Ctx5 B22_174 ".0 .0 .0"
6 B22_174_6 Ctx6 B22_174 ".0 .0 0.5"
6 B22_174_7 Ctx7 B22_174 "0.41 0.41 0.41"
6 B22_174_8 Ctx8 B22_174 "1.0 .0 1.0"
6 B22_174_9 Ctx9 B22_174 ".0 .0 1.0"
10 252.914949000 w2 WS "B22_174"
20 252.914949000 w2 WS B22_174 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 199
10 252.934959000 w0 WS "B"
13 245.237740000 w0 gf 0.000000
13 252.934959000 w0 gf 0.000000
10 252.935617000 w0 WS "Po"
10 252.936482000 w0 WS "B"
10 252.938772000 w0 WS "P"
10 252.939336000 w0 WS "Sc"
13 252.940053000 sched nready 95.000000
13 252.940053000 sched nsubmitted 99.000000
10 252.940577000 w0 WS "B"
10 252.941009000 w0 WS "B"
10 252.941327000 w1 WS "B"
13 245.286900000 w1 gf 0.000000
13 252.941327000 w1 gf 0.000000
10 252.941429000 w0 WS "Fi"
10 252.941938000 w1 WS "Po"
10 252.942302000 w0 WS "B"
10 252.942848000 w1 WS "B"
6 B22_175 WS B22_175 "0.000000 0.600000 0.400000"
6 B22_175_1 Ctx1 B22_175 "1.0 0.39 1.0"
6 B22_175_2 Ctx2 B22_175 ".0 1.0 .0"
6 B22_175_3 Ctx3 B22_175 "0.87 0.87 .0"
6 B22_175_4 Ctx4 B22_175 ".0 0.95 1.0"
6 B22_175_5 Ctx5 B22_175 ".0 .0 .0"
6 B22_175_6 Ctx6 B22_175 ".0 .0 0.5"
6 B22_175_7 Ctx7 B22_175 "0.41 0.41 0.41"
6 B22_175_8 Ctx8 B22_175 "1.0 .0 1.0"
6 B22_175_9 Ctx9 B22_175 ".0 .0 1.0"
10 252.942922000 w0 WS "B22_175"
20 252.942922000 w0 WS B22_175 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 200
10 252.945141000 w1 WS "P"
10 252.945653000 w1 WS "Sc"
13 252.946277000 sched nready 94.000000
13 252.946277000 sched nsubmitted 98.000000
10 252.946754000 w1 WS "B"
10 252.947166000 w1 WS "B"
10 252.947573000 w1 WS "Fi"
10 252.948501000 w1 WS "B"
6 B22_176 WS B22_176 "0.000000 0.600000 0.400000"
6 B22_176_1 Ctx1 B22_176 "1.0 0.39 1.0"
6 B22_176_2 Ctx2 B22_176 ".0 1.0 .0"
6 B22_176_3 Ctx3 B22_176 "0.87 0.87 .0"
6 B22_176_4 Ctx4 B22_176 ".0 0.95 1.0"
6 B22_176_5 Ctx5 B22_176 ".0 .0 .0"
6 B22_176_6 Ctx6 B22_176 ".0 .0 0.5"
6 B22_176_7 Ctx7 B22_176 "0.41 0.41 0.41"
6 B22_176_8 Ctx8 B22_176 "1.0 .0 1.0"
6 B22_176_9 Ctx9 B22_176 ".0 .0 1.0"
10 252.948986000 w1 WS "B22_176"
20 252.948986000 w1 WS B22_176 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 201
10 253.000260000 w3 WS "B"
13 245.230375000 w3 gf 0.000000
13 253.000260000 w3 gf 0.000000
13 245.230375000 sched gft 0.000000
13 245.237740000 sched gft 0.000000
13 245.279675000 sched gft 0.000000
13 245.286900000 sched gft 0.000000
13 246.768267000 sched gft 0.000000
10 253.000850000 w3 WS "Po"
10 253.002161000 w3 WS "B"
10 253.004674000 w3 WS "P"
10 253.005263000 w3 WS "Sc"
13 253.005916000 sched nready 93.000000
13 253.005916000 sched nsubmitted 97.000000
10 253.006385000 w3 WS "B"
10 253.006799000 w3 WS "B"
10 253.007220000 w3 WS "Fi"
10 253.008197000 w3 WS "B"
6 B22_177 WS B22_177 "0.000000 0.600000 0.400000"
6 B22_177_1 Ctx1 B22_177 "1.0 0.39 1.0"
6 B22_177_2 Ctx2 B22_177 ".0 1.0 .0"
6 B22_177_3 Ctx3 B22_177 "0.87 0.87 .0"
6 B22_177_4 Ctx4 B22_177 ".0 0.95 1.0"
6 B22_177_5 Ctx5 B22_177 ".0 .0 .0"
6 B22_177_6 Ctx6 B22_177 ".0 .0 0.5"
6 B22_177_7 Ctx7 B22_177 "0.41 0.41 0.41"
6 B22_177_8 Ctx8 B22_177 "1.0 .0 1.0"
6 B22_177_9 Ctx9 B22_177 ".0 .0 1.0"
10 253.008713000 w3 WS "B22_177"
20 253.008713000 w3 WS B22_177 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 202
10 254.474540000 w5 WS "B"
13 246.776373000 w5 gf 0.000000
13 254.474540000 w5 gf 0.000000
13 246.776373000 sched gft 0.000000
13 246.782935000 sched gft 0.000000
10 254.475115000 w5 WS "Po"
10 254.476059000 w5 WS "B"
10 254.476753000 w4 WS "B"
13 246.790330000 w4 gf 0.000000
13 254.476753000 w4 gf 0.000000
13 246.790330000 sched gft 0.000000
13 252.905489000 sched gft 0.000000
10 254.477295000 w4 WS "Po"
10 254.478127000 w4 WS "B"
10 254.478375000 w5 WS "P"
10 254.478930000 w5 WS "Sc"
13 254.479671000 sched nready 92.000000
13 254.479671000 sched nsubmitted 96.000000
10 254.480256000 w5 WS "B"
10 254.480686000 w5 WS "B"
10 254.480952000 w4 WS "P"
10 254.481101000 w5 WS "Fi"
10 254.481585000 w4 WS "Sc"
10 254.482047000 w5 WS "B"
13 254.482339000 sched nready 91.000000
13 254.482339000 sched nsubmitted 95.000000
6 B22_178 WS B22_178 "0.000000 0.600000 0.400000"
6 B22_178_1 Ctx1 B22_178 "1.0 0.39 1.0"
6 B22_178_2 Ctx2 B22_178 ".0 1.0 .0"
6 B22_178_3 Ctx3 B22_178 "0.87 0.87 .0"
6 B22_178_4 Ctx4 B22_178 ".0 0.95 1.0"
6 B22_178_5 Ctx5 B22_178 ".0 .0 .0"
6 B22_178_6 Ctx6 B22_178 ".0 .0 0.5"
6 B22_178_7 Ctx7 B22_178 "0.41 0.41 0.41"
6 B22_178_8 Ctx8 B22_178 "1.0 .0 1.0"
6 B22_178_9 Ctx9 B22_178 ".0 .0 1.0"
10 254.482554000 w5 WS "B22_178"
10 254.482924000 w4 WS "B"
10 254.483362000 w4 WS "B"
20 254.482554000 w5 WS B22_178 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 203
10 254.483851000 w4 WS "Fi"
10 254.484777000 w4 WS "B"
6 B22_179 WS B22_179 "0.000000 0.600000 0.400000"
6 B22_179_1 Ctx1 B22_179 "1.0 0.39 1.0"
6 B22_179_2 Ctx2 B22_179 ".0 1.0 .0"
6 B22_179_3 Ctx3 B22_179 "0.87 0.87 .0"
6 B22_179_4 Ctx4 B22_179 ".0 0.95 1.0"
6 B22_179_5 Ctx5 B22_179 ".0 .0 .0"
6 B22_179_6 Ctx6 B22_179 ".0 .0 0.5"
6 B22_179_7 Ctx7 B22_179 "0.41 0.41 0.41"
6 B22_179_8 Ctx8 B22_179 "1.0 .0 1.0"
6 B22_179_9 Ctx9 B22_179 ".0 .0 1.0"
10 254.485261000 w4 WS "B22_179"
20 254.485261000 w4 WS B22_179 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 204
10 260.657565000 w1 WS "B"
13 252.948986000 w1 gf 0.000000
13 260.657565000 w1 gf 0.000000
10 260.658355000 w1 WS "Po"
10 260.659165000 w1 WS "B"
10 260.661680000 w1 WS "P"
10 260.662394000 w1 WS "Sc"
13 260.663309000 sched nready 90.000000
13 260.663309000 sched nsubmitted 94.000000
10 260.663895000 w1 WS "B"
10 260.664352000 w1 WS "B"
10 260.664805000 w1 WS "Fi"
10 260.665711000 w1 WS "B"
6 B22_180 WS B22_180 "0.000000 0.600000 0.400000"
6 B22_180_1 Ctx1 B22_180 "1.0 0.39 1.0"
6 B22_180_2 Ctx2 B22_180 ".0 1.0 .0"
6 B22_180_3 Ctx3 B22_180 "0.87 0.87 .0"
6 B22_180_4 Ctx4 B22_180 ".0 0.95 1.0"
6 B22_180_5 Ctx5 B22_180 ".0 .0 .0"
6 B22_180_6 Ctx6 B22_180 ".0 .0 0.5"
6 B22_180_7 Ctx7 B22_180 "0.41 0.41 0.41"
6 B22_180_8 Ctx8 B22_180 "1.0 .0 1.0"
6 B22_180_9 Ctx9 B22_180 ".0 .0 1.0"
10 260.666400000 w1 WS "B22_180"
20 260.666400000 w1 WS B22_180 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 205
10 260.687523000 w3 WS "B"
13 253.008713000 w3 gf 0.000000
13 260.687523000 w3 gf 0.000000
10 260.688078000 w3 WS "Po"
10 260.688820000 w3 WS "B"
10 260.691110000 w3 WS "P"
10 260.691663000 w3 WS "Sc"
13 260.692319000 sched nready 89.000000
13 260.692319000 sched nsubmitted 93.000000
10 260.692824000 w3 WS "B"
10 260.693222000 w3 WS "B"
10 260.693625000 w3 WS "Fi"
10 260.694525000 w3 WS "B"
6 B22_181 WS B22_181 "0.000000 0.600000 0.400000"
6 B22_181_1 Ctx1 B22_181 "1.0 0.39 1.0"
6 B22_181_2 Ctx2 B22_181 ".0 1.0 .0"
6 B22_181_3 Ctx3 B22_181 "0.87 0.87 .0"
6 B22_181_4 Ctx4 B22_181 ".0 0.95 1.0"
6 B22_181_5 Ctx5 B22_181 ".0 .0 .0"
6 B22_181_6 Ctx6 B22_181 ".0 .0 0.5"
6 B22_181_7 Ctx7 B22_181 "0.41 0.41 0.41"
6 B22_181_8 Ctx8 B22_181 "1.0 .0 1.0"
6 B22_181_9 Ctx9 B22_181 ".0 .0 1.0"
10 260.695009000 w3 WS "B22_181"
20 260.695009000 w3 WS B22_181 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 206
10 260.730462000 w0 WS "B"
13 252.942922000 w0 gf 0.000000
13 260.730462000 w0 gf 0.000000
10 260.731134000 w0 WS "Po"
10 260.731974000 w0 WS "B"
10 260.734509000 w0 WS "P"
10 260.735068000 w0 WS "Sc"
13 260.735770000 sched nready 88.000000
13 260.735770000 sched nsubmitted 92.000000
10 260.736338000 w0 WS "B"
10 260.736760000 w0 WS "B"
10 260.737170000 w0 WS "Fi"
10 260.738050000 w0 WS "B"
6 B22_182 WS B22_182 "0.000000 0.600000 0.400000"
6 B22_182_1 Ctx1 B22_182 "1.0 0.39 1.0"
6 B22_182_2 Ctx2 B22_182 ".0 1.0 .0"
6 B22_182_3 Ctx3 B22_182 "0.87 0.87 .0"
6 B22_182_4 Ctx4 B22_182 ".0 0.95 1.0"
6 B22_182_5 Ctx5 B22_182 ".0 .0 .0"
6 B22_182_6 Ctx6 B22_182 ".0 .0 0.5"
6 B22_182_7 Ctx7 B22_182 "0.41 0.41 0.41"
6 B22_182_8 Ctx8 B22_182 "1.0 .0 1.0"
6 B22_182_9 Ctx9 B22_182 ".0 .0 1.0"
10 260.738579000 w0 WS "B22_182"
20 260.738579000 w0 WS B22_182 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 207
10 260.750604000 w2 WS "B"
13 252.914949000 w2 gf 0.000000
13 260.750604000 w2 gf 0.000000
13 252.914949000 sched gft 0.000000
13 252.934959000 sched gft 0.000000
13 252.941327000 sched gft 0.000000
13 252.942922000 sched gft 0.000000
13 252.948986000 sched gft 0.000000
13 253.000260000 sched gft 0.000000
13 253.008713000 sched gft 0.000000
13 254.474540000 sched gft 0.000000
13 254.476753000 sched gft 0.000000
10 260.751193000 w2 WS "Po"
10 260.751950000 w2 WS "B"
10 260.754141000 w2 WS "P"
10 260.754659000 w2 WS "Sc"
13 260.755284000 sched nready 87.000000
13 260.755284000 sched nsubmitted 91.000000
10 260.755751000 w2 WS "B"
10 260.756173000 w2 WS "B"
10 260.756579000 w2 WS "Fi"
10 260.757387000 w2 WS "B"
6 B22_183 WS B22_183 "0.000000 0.600000 0.400000"
6 B22_183_1 Ctx1 B22_183 "1.0 0.39 1.0"
6 B22_183_2 Ctx2 B22_183 ".0 1.0 .0"
6 B22_183_3 Ctx3 B22_183 "0.87 0.87 .0"
6 B22_183_4 Ctx4 B22_183 ".0 0.95 1.0"
6 B22_183_5 Ctx5 B22_183 ".0 .0 .0"
6 B22_183_6 Ctx6 B22_183 ".0 .0 0.5"
6 B22_183_7 Ctx7 B22_183 "0.41 0.41 0.41"
6 B22_183_8 Ctx8 B22_183 "1.0 .0 1.0"
6 B22_183_9 Ctx9 B22_183 ".0 .0 1.0"
10 260.757864000 w2 WS "B22_183"
20 260.757864000 w2 WS B22_183 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 208
10 262.157807000 w5 WS "B"
13 254.482554000 w5 gf 0.000000
13 262.157807000 w5 gf 0.000000
13 254.482554000 sched gft 0.000000
10 262.158387000 w5 WS "Po"
10 262.159131000 w5 WS "B"
10 262.161201000 w5 WS "P"
10 262.161818000 w5 WS "Sc"
13 262.162438000 sched nready 86.000000
13 262.162438000 sched nsubmitted 90.000000
10 262.162924000 w5 WS "B"
10 262.163353000 w5 WS "B"
10 262.163760000 w5 WS "Fi"
10 262.164619000 w5 WS "B"
6 B22_184 WS B22_184 "0.000000 0.600000 0.400000"
6 B22_184_1 Ctx1 B22_184 "1.0 0.39 1.0"
6 B22_184_2 Ctx2 B22_184 ".0 1.0 .0"
6 B22_184_3 Ctx3 B22_184 "0.87 0.87 .0"
6 B22_184_4 Ctx4 B22_184 ".0 0.95 1.0"
6 B22_184_5 Ctx5 B22_184 ".0 .0 .0"
6 B22_184_6 Ctx6 B22_184 ".0 .0 0.5"
6 B22_184_7 Ctx7 B22_184 "0.41 0.41 0.41"
6 B22_184_8 Ctx8 B22_184 "1.0 .0 1.0"
6 B22_184_9 Ctx9 B22_184 ".0 .0 1.0"
10 262.165109000 w5 WS "B22_184"
10 262.165434000 w4 WS "B"
13 254.485261000 w4 gf 0.000000
13 262.165434000 w4 gf 0.000000
13 254.485261000 sched gft 0.000000
13 260.657565000 sched gft 0.000000
10 262.165971000 w4 WS "Po"
20 262.165109000 w5 WS B22_184 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 209
10 262.166722000 w4 WS "B"
10 262.169112000 w4 WS "P"
10 262.169673000 w4 WS "Sc"
13 262.170350000 sched nready 85.000000
13 262.170350000 sched nsubmitted 89.000000
10 262.170817000 w4 WS "B"
10 262.171227000 w4 WS "B"
10 262.171631000 w4 WS "Fi"
10 262.172478000 w4 WS "B"
6 B22_185 WS B22_185 "0.000000 0.600000 0.400000"
6 B22_185_1 Ctx1 B22_185 "1.0 0.39 1.0"
6 B22_185_2 Ctx2 B22_185 ".0 1.0 .0"
6 B22_185_3 Ctx3 B22_185 "0.87 0.87 .0"
6 B22_185_4 Ctx4 B22_185 ".0 0.95 1.0"
6 B22_185_5 Ctx5 B22_185 ".0 .0 .0"
6 B22_185_6 Ctx6 B22_185 ".0 .0 0.5"
6 B22_185_7 Ctx7 B22_185 "0.41 0.41 0.41"
6 B22_185_8 Ctx8 B22_185 "1.0 .0 1.0"
6 B22_185_9 Ctx9 B22_185 ".0 .0 1.0"
10 262.172950000 w4 WS "B22_185"
20 262.172950000 w4 WS B22_185 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 210
10 268.347743000 w1 WS "B"
13 260.666400000 w1 gf 0.000000
13 268.347743000 w1 gf 0.000000
13 260.666400000 sched gft 0.000000
13 260.687523000 sched gft 0.000000
10 268.348571000 w1 WS "Po"
10 268.349984000 w1 WS "B"
10 268.352744000 w1 WS "P"
10 268.353374000 w1 WS "Sc"
13 268.354261000 sched nready 84.000000
13 268.354261000 sched nsubmitted 88.000000
10 268.354927000 w1 WS "B"
10 268.355087000 w3 WS "B"
13 260.695009000 w3 gf 0.000000
13 268.355087000 w3 gf 0.000000
13 260.695009000 sched gft 0.000000
13 260.730462000 sched gft 0.000000
10 268.355345000 w1 WS "B"
10 268.355793000 w3 WS "Po"
10 268.355861000 w1 WS "Fi"
10 268.356839000 w3 WS "B"
10 268.357373000 w1 WS "B"
6 B22_186 WS B22_186 "0.000000 0.600000 0.400000"
6 B22_186_1 Ctx1 B22_186 "1.0 0.39 1.0"
6 B22_186_2 Ctx2 B22_186 ".0 1.0 .0"
6 B22_186_3 Ctx3 B22_186 "0.87 0.87 .0"
6 B22_186_4 Ctx4 B22_186 ".0 0.95 1.0"
6 B22_186_5 Ctx5 B22_186 ".0 .0 .0"
6 B22_186_6 Ctx6 B22_186 ".0 .0 0.5"
6 B22_186_7 Ctx7 B22_186 "0.41 0.41 0.41"
6 B22_186_8 Ctx8 B22_186 "1.0 .0 1.0"
6 B22_186_9 Ctx9 B22_186 ".0 .0 1.0"
10 268.358268000 w1 WS "B22_186"
10 268.359608000 w3 WS "P"
20 268.358268000 w1 WS B22_186 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 211
10 268.360282000 w3 WS "Sc"
13 268.360958000 sched nready 83.000000
13 268.360958000 sched nsubmitted 87.000000
10 268.361421000 w3 WS "B"
10 268.361839000 w3 WS "B"
10 268.362239000 w3 WS "Fi"
10 268.363311000 w3 WS "B"
6 B22_187 WS B22_187 "0.000000 0.600000 0.400000"
6 B22_187_1 Ctx1 B22_187 "1.0 0.39 1.0"
6 B22_187_2 Ctx2 B22_187 ".0 1.0 .0"
6 B22_187_3 Ctx3 B22_187 "0.87 0.87 .0"
6 B22_187_4 Ctx4 B22_187 ".0 0.95 1.0"
6 B22_187_5 Ctx5 B22_187 ".0 .0 .0"
6 B22_187_6 Ctx6 B22_187 ".0 .0 0.5"
6 B22_187_7 Ctx7 B22_187 "0.41 0.41 0.41"
6 B22_187_8 Ctx8 B22_187 "1.0 .0 1.0"
6 B22_187_9 Ctx9 B22_187 ".0 .0 1.0"
10 268.363782000 w3 WS "B22_187"
20 268.363782000 w3 WS B22_187 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 212
10 268.404865000 w0 WS "B"
13 260.738579000 w0 gf 0.000000
13 268.404865000 w0 gf 0.000000
13 260.738579000 sched gft 0.000000
13 260.750604000 sched gft 0.000000
10 268.405537000 w0 WS "Po"
10 268.406392000 w0 WS "B"
10 268.408696000 w0 WS "P"
10 268.409249000 w0 WS "Sc"
13 268.409966000 sched nready 82.000000
13 268.409966000 sched nsubmitted 86.000000
10 268.410458000 w0 WS "B"
10 268.410879000 w0 WS "B"
10 268.411297000 w0 WS "Fi"
10 268.412283000 w0 WS "B"
10 268.412460000 w2 WS "B"
13 260.757864000 w2 gf 0.000000
13 268.412460000 w2 gf 0.000000
13 260.757864000 sched gft 0.000000
13 262.157807000 sched gft 0.000000
6 B22_188 WS B22_188 "0.000000 0.600000 0.400000"
6 B22_188_1 Ctx1 B22_188 "1.0 0.39 1.0"
6 B22_188_2 Ctx2 B22_188 ".0 1.0 .0"
6 B22_188_3 Ctx3 B22_188 "0.87 0.87 .0"
6 B22_188_4 Ctx4 B22_188 ".0 0.95 1.0"
6 B22_188_5 Ctx5 B22_188 ".0 .0 .0"
6 B22_188_6 Ctx6 B22_188 ".0 .0 0.5"
6 B22_188_7 Ctx7 B22_188 "0.41 0.41 0.41"
6 B22_188_8 Ctx8 B22_188 "1.0 .0 1.0"
6 B22_188_9 Ctx9 B22_188 ".0 .0 1.0"
10 268.412769000 w0 WS "B22_188"
10 268.413105000 w2 WS "Po"
20 268.412769000 w0 WS B22_188 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 213
0.000000 0 0 0 -1 -1
10 268.414103000 w2 WS "B"
10 268.416642000 w2 WS "P"
10 268.417160000 w2 WS "Sc"
13 268.417813000 sched nready 81.000000
13 268.417813000 sched nsubmitted 85.000000
10 268.418285000 w2 WS "B"
10 268.418706000 w2 WS "B"
10 268.419109000 w2 WS "Fi"
10 268.420228000 w2 WS "B"
6 B22_189 WS B22_189 "0.000000 0.600000 0.400000"
6 B22_189_1 Ctx1 B22_189 "1.0 0.39 1.0"
6 B22_189_2 Ctx2 B22_189 ".0 1.0 .0"
6 B22_189_3 Ctx3 B22_189 "0.87 0.87 .0"
6 B22_189_4 Ctx4 B22_189 ".0 0.95 1.0"
6 B22_189_5 Ctx5 B22_189 ".0 .0 .0"
6 B22_189_6 Ctx6 B22_189 ".0 .0 0.5"
6 B22_189_7 Ctx7 B22_189 "0.41 0.41 0.41"
6 B22_189_8 Ctx8 B22_189 "1.0 .0 1.0"
6 B22_189_9 Ctx9 B22_189 ".0 .0 1.0"
10 268.420696000 w2 WS "B22_189"
20 268.420696000 w2 WS B22_189 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 214
10 269.837284000 w5 WS "B"
13 262.165109000 w5 gf 0.000000
13 269.837284000 w5 gf 0.000000
13 262.165109000 sched gft 0.000000
13 262.165434000 sched gft 0.000000
10 269.837857000 w5 WS "Po"
10 269.838732000 w5 WS "B"
10 269.840957000 w5 WS "P"
10 269.841564000 w5 WS "Sc"
13 269.842244000 sched nready 80.000000
13 269.842244000 sched nsubmitted 84.000000
10 269.842781000 w5 WS "B"
10 269.843194000 w5 WS "B"
10 269.843612000 w5 WS "Fi"
10 269.844440000 w5 WS "B"
6 B22_190 WS B22_190 "0.000000 0.600000 0.400000"
6 B22_190_1 Ctx1 B22_190 "1.0 0.39 1.0"
6 B22_190_2 Ctx2 B22_190 ".0 1.0 .0"
6 B22_190_3 Ctx3 B22_190 "0.87 0.87 .0"
6 B22_190_4 Ctx4 B22_190 ".0 0.95 1.0"
6 B22_190_5 Ctx5 B22_190 ".0 .0 .0"
6 B22_190_6 Ctx6 B22_190 ".0 .0 0.5"
6 B22_190_7 Ctx7 B22_190 "0.41 0.41 0.41"
6 B22_190_8 Ctx8 B22_190 "1.0 .0 1.0"
6 B22_190_9 Ctx9 B22_190 ".0 .0 1.0"
10 269.844949000 w5 WS "B22_190"
10 269.845324000 w4 WS "B"
13 262.172950000 w4 gf 0.000000
13 269.845324000 w4 gf 0.000000
13 262.172950000 sched gft 0.000000
13 268.347743000 sched gft 0.000000
13 268.355087000 sched gft 0.000000
10 269.845876000 w4 WS "Po"
20 269.844949000 w5 WS B22_190 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 215
10 269.846837000 w4 WS "B"
10 269.849095000 w4 WS "P"
10 269.849625000 w4 WS "Sc"
13 269.850582000 sched nready 79.000000
13 269.850582000 sched nsubmitted 83.000000
10 269.851066000 w4 WS "B"
10 269.851474000 w4 WS "B"
10 269.851886000 w4 WS "Fi"
10 269.852735000 w4 WS "B"
6 B22_191 WS B22_191 "0.000000 0.600000 0.400000"
6 B22_191_1 Ctx1 B22_191 "1.0 0.39 1.0"
6 B22_191_2 Ctx2 B22_191 ".0 1.0 .0"
6 B22_191_3 Ctx3 B22_191 "0.87 0.87 .0"
6 B22_191_4 Ctx4 B22_191 ".0 0.95 1.0"
6 B22_191_5 Ctx5 B22_191 ".0 .0 .0"
6 B22_191_6 Ctx6 B22_191 ".0 .0 0.5"
6 B22_191_7 Ctx7 B22_191 "0.41 0.41 0.41"
6 B22_191_8 Ctx8 B22_191 "1.0 .0 1.0"
6 B22_191_9 Ctx9 B22_191 ".0 .0 1.0"
10 269.853211000 w4 WS "B22_191"
20 269.853211000 w4 WS B22_191 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 216
10 276.045827000 w1 WS "B"
13 268.358268000 w1 gf 0.000000
13 276.045827000 w1 gf 0.000000
13 268.358268000 sched gft 0.000000
10 276.046482000 w1 WS "Po"
10 276.046713000 w3 WS "B"
13 268.363782000 w3 gf 0.000000
13 276.046713000 w3 gf 0.000000
13 268.363782000 sched gft 0.000000
13 268.404865000 sched gft 0.000000
13 268.412460000 sched gft 0.000000
10 276.047372000 w3 WS "Po"
10 276.047450000 w1 WS "B"
10 276.048275000 w3 WS "B"
10 276.050319000 w1 WS "P"
10 276.051105000 w3 WS "P"
10 276.051214000 w1 WS "Sc"
10 276.051711000 w3 WS "Sc"
13 276.052002000 sched nready 78.000000
13 276.052002000 sched nsubmitted 82.000000
13 276.052457000 sched nready 77.000000
13 276.052457000 sched nsubmitted 81.000000
10 276.052540000 w1 WS "B"
10 276.052986000 w3 WS "B"
10 276.053054000 w1 WS "B"
10 276.053420000 w3 WS "B"
10 276.053569000 w1 WS "Fi"
10 276.053861000 w3 WS "Fi"
10 276.054568000 w1 WS "B"
10 276.054880000 w3 WS "B"
6 B22_192 WS B22_192 "0.000000 0.600000 0.400000"
6 B22_192_1 Ctx1 B22_192 "1.0 0.39 1.0"
6 B22_192_2 Ctx2 B22_192 ".0 1.0 .0"
6 B22_192_3 Ctx3 B22_192 "0.87 0.87 .0"
6 B22_192_4 Ctx4 B22_192 ".0 0.95 1.0"
6 B22_192_5 Ctx5 B22_192 ".0 .0 .0"
6 B22_192_6 Ctx6 B22_192 ".0 .0 0.5"
6 B22_192_7 Ctx7 B22_192 "0.41 0.41 0.41"
6 B22_192_8 Ctx8 B22_192 "1.0 .0 1.0"
6 B22_192_9 Ctx9 B22_192 ".0 .0 1.0"
10 276.055173000 w1 WS "B22_192"
6 B22_193 WS B22_193 "0.000000 0.600000 0.400000"
6 B22_193_1 Ctx1 B22_193 "1.0 0.39 1.0"
6 B22_193_2 Ctx2 B22_193 ".0 1.0 .0"
6 B22_193_3 Ctx3 B22_193 "0.87 0.87 .0"
6 B22_193_4 Ctx4 B22_193 ".0 0.95 1.0"
6 B22_193_5 Ctx5 B22_193 ".0 .0 .0"
6 B22_193_6 Ctx6 B22_193 ".0 .0 0.5"
6 B22_193_7 Ctx7 B22_193 "0.41 0.41 0.41"
6 B22_193_8 Ctx8 B22_193 "1.0 .0 1.0"
6 B22_193_9 Ctx9 B22_193 ".0 .0 1.0"
10 276.055407000 w3 WS "B22_193"
20 276.055173000 w1 WS B22_192 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 217
20 276.055407000 w3 WS B22_193 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 218
10 276.086875000 w0 WS "B"
13 268.412769000 w0 gf 0.000000
13 276.086875000 w0 gf 0.000000
13 268.412769000 sched gft 0.000000
10 276.087471000 w0 WS "Po"
10 276.088312000 w0 WS "B"
10 276.090681000 w0 WS "P"
10 276.091227000 w0 WS "Sc"
13 276.091901000 sched nready 76.000000
13 276.091901000 sched nsubmitted 80.000000
10 276.092453000 w0 WS "B"
10 276.092872000 w0 WS "B"
10 276.093280000 w0 WS "Fi"
10 276.094108000 w0 WS "B"
6 B22_194 WS B22_194 "0.000000 0.600000 0.400000"
6 B22_194_1 Ctx1 B22_194 "1.0 0.39 1.0"
6 B22_194_2 Ctx2 B22_194 ".0 1.0 .0"
6 B22_194_3 Ctx3 B22_194 "0.87 0.87 .0"
6 B22_194_4 Ctx4 B22_194 ".0 0.95 1.0"
6 B22_194_5 Ctx5 B22_194 ".0 .0 .0"
6 B22_194_6 Ctx6 B22_194 ".0 .0 0.5"
6 B22_194_7 Ctx7 B22_194 "0.41 0.41 0.41"
6 B22_194_8 Ctx8 B22_194 "1.0 .0 1.0"
6 B22_194_9 Ctx9 B22_194 ".0 .0 1.0"
10 276.094615000 w0 WS "B22_194"
20 276.094615000 w0 WS B22_194 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 219
10 276.137412000 w2 WS "B"
13 268.420696000 w2 gf 0.000000
13 276.137412000 w2 gf 0.000000
13 268.420696000 sched gft 0.000000
13 269.837284000 sched gft 0.000000
10 276.137978000 w2 WS "Po"
10 276.138787000 w2 WS "B"
10 276.141027000 w2 WS "P"
10 276.141554000 w2 WS "Sc"
13 276.142187000 sched nready 75.000000
13 276.142187000 sched nsubmitted 79.000000
10 276.142653000 w2 WS "B"
10 276.143065000 w2 WS "B"
10 276.143468000 w2 WS "Fi"
10 276.144298000 w2 WS "B"
6 B22_195 WS B22_195 "0.000000 0.600000 0.400000"
6 B22_195_1 Ctx1 B22_195 "1.0 0.39 1.0"
6 B22_195_2 Ctx2 B22_195 ".0 1.0 .0"
6 B22_195_3 Ctx3 B22_195 "0.87 0.87 .0"
6 B22_195_4 Ctx4 B22_195 ".0 0.95 1.0"
6 B22_195_5 Ctx5 B22_195 ".0 .0 .0"
6 B22_195_6 Ctx6 B22_195 ".0 .0 0.5"
6 B22_195_7 Ctx7 B22_195 "0.41 0.41 0.41"
6 B22_195_8 Ctx8 B22_195 "1.0 .0 1.0"
6 B22_195_9 Ctx9 B22_195 ".0 .0 1.0"
10 276.144776000 w2 WS "B22_195"
20 276.144776000 w2 WS B22_195 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 220
10 277.525351000 w5 WS "B"
13 269.844949000 w5 gf 0.000000
13 277.525351000 w5 gf 0.000000
13 269.844949000 sched gft 0.000000
13 269.845324000 sched gft 0.000000
10 277.526000000 w5 WS "Po"
10 277.526741000 w5 WS "B"
10 277.528891000 w5 WS "P"
10 277.529493000 w5 WS "Sc"
13 277.530144000 sched nready 74.000000
13 277.530144000 sched nsubmitted 78.000000
10 277.530685000 w5 WS "B"
10 277.531100000 w5 WS "B"
10 277.531513000 w5 WS "Fi"
10 277.532460000 w5 WS "B"
6 B22_196 WS B22_196 "0.000000 0.600000 0.400000"
6 B22_196_1 Ctx1 B22_196 "1.0 0.39 1.0"
6 B22_196_2 Ctx2 B22_196 ".0 1.0 .0"
6 B22_196_3 Ctx3 B22_196 "0.87 0.87 .0"
6 B22_196_4 Ctx4 B22_196 ".0 0.95 1.0"
6 B22_196_5 Ctx5 B22_196 ".0 .0 .0"
6 B22_196_6 Ctx6 B22_196 ".0 .0 0.5"
6 B22_196_7 Ctx7 B22_196 "0.41 0.41 0.41"
6 B22_196_8 Ctx8 B22_196 "1.0 .0 1.0"
6 B22_196_9 Ctx9 B22_196 ".0 .0 1.0"
10 277.532936000 w5 WS "B22_196"
10 277.532993000 w4 WS "B"
13 269.853211000 w4 gf 0.000000
13 277.532993000 w4 gf 0.000000
13 269.853211000 sched gft 0.000000
13 276.045827000 sched gft 0.000000
13 276.046713000 sched gft 0.000000
10 277.533608000 w4 WS "Po"
20 277.532936000 w5 WS B22_196 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 221
10 277.534366000 w4 WS "B"
10 277.536566000 w4 WS "P"
10 277.537101000 w4 WS "Sc"
13 277.537837000 sched nready 73.000000
13 277.537837000 sched nsubmitted 77.000000
10 277.538347000 w4 WS "B"
10 277.538756000 w4 WS "B"
10 277.539151000 w4 WS "Fi"
10 277.539932000 w4 WS "B"
6 B22_197 WS B22_197 "0.000000 0.600000 0.400000"
6 B22_197_1 Ctx1 B22_197 "1.0 0.39 1.0"
6 B22_197_2 Ctx2 B22_197 ".0 1.0 .0"
6 B22_197_3 Ctx3 B22_197 "0.87 0.87 .0"
6 B22_197_4 Ctx4 B22_197 ".0 0.95 1.0"
6 B22_197_5 Ctx5 B22_197 ".0 .0 .0"
6 B22_197_6 Ctx6 B22_197 ".0 .0 0.5"
6 B22_197_7 Ctx7 B22_197 "0.41 0.41 0.41"
6 B22_197_8 Ctx8 B22_197 "1.0 .0 1.0"
6 B22_197_9 Ctx9 B22_197 ".0 .0 1.0"
10 277.540414000 w4 WS "B22_197"
20 277.540414000 w4 WS B22_197 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 222
10 283.738562000 w3 WS "B"
13 276.055407000 w3 gf 0.000000
13 283.738562000 w3 gf 0.000000
10 283.738611000 w1 WS "B"
13 276.055173000 w1 gf 0.000000
13 283.738611000 w1 gf 0.000000
13 276.055173000 sched gft 0.000000
13 276.055407000 sched gft 0.000000
13 276.086875000 sched gft 0.000000
10 283.739470000 w1 WS "Po"
10 283.739529000 w3 WS "Po"
10 283.740371000 w1 WS "B"
10 283.740677000 w3 WS "B"
10 283.743116000 w1 WS "P"
10 283.743537000 w3 WS "P"
10 283.743951000 w1 WS "Sc"
10 283.744171000 w3 WS "Sc"
13 283.744804000 sched nready 72.000000
13 283.744804000 sched nsubmitted 76.000000
13 283.744986000 sched nready 71.000000
13 283.744986000 sched nsubmitted 75.000000
10 283.745405000 w1 WS "B"
10 283.745511000 w3 WS "B"
10 283.745886000 w1 WS "B"
10 283.745962000 w3 WS "B"
10 283.746332000 w1 WS "Fi"
10 283.746397000 w3 WS "Fi"
10 283.747490000 w3 WS "B"
10 283.747541000 w1 WS "B"
6 B22_199 WS B22_199 "0.000000 0.600000 0.400000"
6 B22_199_1 Ctx1 B22_199 "1.0 0.39 1.0"
6 B22_199_2 Ctx2 B22_199 ".0 1.0 .0"
6 B22_199_3 Ctx3 B22_199 "0.87 0.87 .0"
6 B22_199_4 Ctx4 B22_199 ".0 0.95 1.0"
6 B22_199_5 Ctx5 B22_199 ".0 .0 .0"
6 B22_199_6 Ctx6 B22_199 ".0 .0 0.5"
6 B22_199_7 Ctx7 B22_199 "0.41 0.41 0.41"
6 B22_199_8 Ctx8 B22_199 "1.0 .0 1.0"
6 B22_199_9 Ctx9 B22_199 ".0 .0 1.0"
10 283.748013000 w3 WS "B22_199"
6 B22_198 WS B22_198 "0.000000 0.600000 0.400000"
6 B22_198_1 Ctx1 B22_198 "1.0 0.39 1.0"
6 B22_198_2 Ctx2 B22_198 ".0 1.0 .0"
6 B22_198_3 Ctx3 B22_198 "0.87 0.87 .0"
6 B22_198_4 Ctx4 B22_198 ".0 0.95 1.0"
6 B22_198_5 Ctx5 B22_198 ".0 .0 .0"
6 B22_198_6 Ctx6 B22_198 ".0 .0 0.5"
6 B22_198_7 Ctx7 B22_198 "0.41 0.41 0.41"
6 B22_198_8 Ctx8 B22_198 "1.0 .0 1.0"
6 B22_198_9 Ctx9 B22_198 ".0 .0 1.0"
10 283.748072000 w1 WS "B22_198"
20 283.748072000 w1 WS B22_198 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 223
20 283.748013000 w3 WS B22_199 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 224
10 283.769549000 w0 WS "B"
13 276.094615000 w0 gf 0.000000
13 283.769549000 w0 gf 0.000000
13 276.094615000 sched gft 0.000000
13 276.137412000 sched gft 0.000000
10 283.770242000 w0 WS "Po"
10 283.771106000 w0 WS "B"
10 283.773415000 w0 WS "P"
10 283.773995000 w0 WS "Sc"
13 283.774694000 sched nready 70.000000
13 283.774694000 sched nsubmitted 74.000000
10 283.775221000 w0 WS "B"
10 283.775637000 w0 WS "B"
10 283.776046000 w0 WS "Fi"
10 283.776911000 w0 WS "B"
6 B22_200 WS B22_200 "0.000000 0.600000 0.400000"
6 B22_200_1 Ctx1 B22_200 "1.0 0.39 1.0"
6 B22_200_2 Ctx2 B22_200 ".0 1.0 .0"
6 B22_200_3 Ctx3 B22_200 "0.87 0.87 .0"
6 B22_200_4 Ctx4 B22_200 ".0 0.95 1.0"
6 B22_200_5 Ctx5 B22_200 ".0 .0 .0"
6 B22_200_6 Ctx6 B22_200 ".0 .0 0.5"
6 B22_200_7 Ctx7 B22_200 "0.41 0.41 0.41"
6 B22_200_8 Ctx8 B22_200 "1.0 .0 1.0"
6 B22_200_9 Ctx9 B22_200 ".0 .0 1.0"
10 283.777404000 w0 WS "B22_200"
20 283.777404000 w0 WS B22_200 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 225
10 283.804940000 w2 WS "B"
13 276.144776000 w2 gf 0.000000
13 283.804940000 w2 gf 0.000000
13 276.144776000 sched gft 0.000000
13 277.525351000 sched gft 0.000000
10 283.805455000 w2 WS "Po"
10 283.806405000 w2 WS "B"
10 283.808612000 w2 WS "P"
10 283.809189000 w2 WS "Sc"
13 283.809812000 sched nready 69.000000
13 283.809812000 sched nsubmitted 73.000000
10 283.810273000 w2 WS "B"
10 283.810690000 w2 WS "B"
10 283.811096000 w2 WS "Fi"
10 283.812047000 w2 WS "B"
6 B22_201 WS B22_201 "0.000000 0.600000 0.400000"
6 B22_201_1 Ctx1 B22_201 "1.0 0.39 1.0"
6 B22_201_2 Ctx2 B22_201 ".0 1.0 .0"
6 B22_201_3 Ctx3 B22_201 "0.87 0.87 .0"
6 B22_201_4 Ctx4 B22_201 ".0 0.95 1.0"
6 B22_201_5 Ctx5 B22_201 ".0 .0 .0"
6 B22_201_6 Ctx6 B22_201 ".0 .0 0.5"
6 B22_201_7 Ctx7 B22_201 "0.41 0.41 0.41"
6 B22_201_8 Ctx8 B22_201 "1.0 .0 1.0"
6 B22_201_9 Ctx9 B22_201 ".0 .0 1.0"
10 283.812528000 w2 WS "B22_201"
20 283.812528000 w2 WS B22_201 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 226
10 285.266774000 w5 WS "B"
13 277.532936000 w5 gf 0.000000
13 285.266774000 w5 gf 0.000000
13 277.532936000 sched gft 0.000000
13 277.532993000 sched gft 0.000000
10 285.267335000 w5 WS "Po"
10 285.268487000 w5 WS "B"
10 285.270590000 w5 WS "P"
10 285.271138000 w5 WS "Sc"
13 285.271748000 sched nready 68.000000
13 285.271748000 sched nsubmitted 72.000000
10 285.272251000 w5 WS "B"
10 285.272672000 w5 WS "B"
10 285.273077000 w5 WS "Fi"
10 285.273943000 w5 WS "B"
6 B22_202 WS B22_202 "0.000000 0.600000 0.400000"
6 B22_202_1 Ctx1 B22_202 "1.0 0.39 1.0"
6 B22_202_2 Ctx2 B22_202 ".0 1.0 .0"
6 B22_202_3 Ctx3 B22_202 "0.87 0.87 .0"
6 B22_202_4 Ctx4 B22_202 ".0 0.95 1.0"
6 B22_202_5 Ctx5 B22_202 ".0 .0 .0"
6 B22_202_6 Ctx6 B22_202 ".0 .0 0.5"
6 B22_202_7 Ctx7 B22_202 "0.41 0.41 0.41"
6 B22_202_8 Ctx8 B22_202 "1.0 .0 1.0"
6 B22_202_9 Ctx9 B22_202 ".0 .0 1.0"
10 285.274574000 w5 WS "B22_202"
20 285.274574000 w5 WS B22_202 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 227
10 285.277371000 w4 WS "B"
13 277.540414000 w4 gf 0.000000
13 285.277371000 w4 gf 0.000000
13 277.540414000 sched gft 0.000000
13 283.738562000 sched gft 0.000000
13 283.738611000 sched gft 0.000000
10 285.277975000 w4 WS "Po"
10 285.278792000 w4 WS "B"
10 285.281072000 w4 WS "P"
10 285.281609000 w4 WS "Sc"
13 285.282234000 sched nready 67.000000
13 285.282234000 sched nsubmitted 71.000000
10 285.282693000 w4 WS "B"
10 285.283102000 w4 WS "B"
10 285.283501000 w4 WS "Fi"
10 285.284380000 w4 WS "B"
6 B22_203 WS B22_203 "0.000000 0.600000 0.400000"
6 B22_203_1 Ctx1 B22_203 "1.0 0.39 1.0"
6 B22_203_2 Ctx2 B22_203 ".0 1.0 .0"
6 B22_203_3 Ctx3 B22_203 "0.87 0.87 .0"
6 B22_203_4 Ctx4 B22_203 ".0 0.95 1.0"
6 B22_203_5 Ctx5 B22_203 ".0 .0 .0"
6 B22_203_6 Ctx6 B22_203 ".0 .0 0.5"
6 B22_203_7 Ctx7 B22_203 "0.41 0.41 0.41"
6 B22_203_8 Ctx8 B22_203 "1.0 .0 1.0"
6 B22_203_9 Ctx9 B22_203 ".0 .0 1.0"
10 285.284864000 w4 WS "B22_203"
20 285.284864000 w4 WS B22_203 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 228
10 291.425808000 w1 WS "B"
13 283.748072000 w1 gf 0.000000
13 291.425808000 w1 gf 0.000000
10 291.426462000 w1 WS "Po"
10 291.427535000 w1 WS "B"
10 291.430115000 w1 WS "P"
10 291.430281000 w3 WS "B"
13 283.748013000 w3 gf 0.000000
13 291.430281000 w3 gf 0.000000
13 283.748013000 sched gft 0.000000
13 283.748072000 sched gft 0.000000
13 283.769549000 sched gft 0.000000
10 291.430799000 w1 WS "Sc"
10 291.430975000 w3 WS "Po"
13 291.431574000 sched nready 66.000000
13 291.431574000 sched nsubmitted 70.000000
10 291.431824000 w3 WS "B"
10 291.432107000 w1 WS "B"
10 291.432532000 w1 WS "B"
10 291.432992000 w1 WS "Fi"
10 291.434075000 w3 WS "P"
10 291.434127000 w1 WS "B"
6 B22_204 WS B22_204 "0.000000 0.600000 0.400000"
6 B22_204_1 Ctx1 B22_204 "1.0 0.39 1.0"
6 B22_204_2 Ctx2 B22_204 ".0 1.0 .0"
6 B22_204_3 Ctx3 B22_204 "0.87 0.87 .0"
6 B22_204_4 Ctx4 B22_204 ".0 0.95 1.0"
6 B22_204_5 Ctx5 B22_204 ".0 .0 .0"
6 B22_204_6 Ctx6 B22_204 ".0 .0 0.5"
6 B22_204_7 Ctx7 B22_204 "0.41 0.41 0.41"
6 B22_204_8 Ctx8 B22_204 "1.0 .0 1.0"
6 B22_204_9 Ctx9 B22_204 ".0 .0 1.0"
10 291.434640000 w1 WS "B22_204"
10 291.434712000 w3 WS "Sc"
13 291.435419000 sched nready 65.000000
13 291.435419000 sched nsubmitted 69.000000
20 291.434640000 w1 WS B22_204 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 229
10 291.435930000 w3 WS "B"
10 291.436376000 w3 WS "B"
10 291.436814000 w3 WS "Fi"
10 291.437735000 w3 WS "B"
6 B22_205 WS B22_205 "0.000000 0.600000 0.400000"
6 B22_205_1 Ctx1 B22_205 "1.0 0.39 1.0"
6 B22_205_2 Ctx2 B22_205 ".0 1.0 .0"
6 B22_205_3 Ctx3 B22_205 "0.87 0.87 .0"
6 B22_205_4 Ctx4 B22_205 ".0 0.95 1.0"
6 B22_205_5 Ctx5 B22_205 ".0 .0 .0"
6 B22_205_6 Ctx6 B22_205 ".0 .0 0.5"
6 B22_205_7 Ctx7 B22_205 "0.41 0.41 0.41"
6 B22_205_8 Ctx8 B22_205 "1.0 .0 1.0"
6 B22_205_9 Ctx9 B22_205 ".0 .0 1.0"
10 291.438210000 w3 WS "B22_205"
20 291.438210000 w3 WS B22_205 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 230
10 291.449494000 w0 WS "B"
13 283.777404000 w0 gf 0.000000
13 291.449494000 w0 gf 0.000000
13 283.777404000 sched gft 0.000000
13 283.804940000 sched gft 0.000000
10 291.450113000 w0 WS "Po"
10 291.451012000 w0 WS "B"
10 291.453396000 w0 WS "P"
10 291.454033000 w0 WS "Sc"
13 291.454767000 sched nready 64.000000
13 291.454767000 sched nsubmitted 68.000000
10 291.455309000 w0 WS "B"
10 291.455727000 w0 WS "B"
10 291.456136000 w0 WS "Fi"
10 291.457002000 w0 WS "B"
6 B22_206 WS B22_206 "0.000000 0.600000 0.400000"
6 B22_206_1 Ctx1 B22_206 "1.0 0.39 1.0"
6 B22_206_2 Ctx2 B22_206 ".0 1.0 .0"
6 B22_206_3 Ctx3 B22_206 "0.87 0.87 .0"
6 B22_206_4 Ctx4 B22_206 ".0 0.95 1.0"
6 B22_206_5 Ctx5 B22_206 ".0 .0 .0"
6 B22_206_6 Ctx6 B22_206 ".0 .0 0.5"
6 B22_206_7 Ctx7 B22_206 "0.41 0.41 0.41"
6 B22_206_8 Ctx8 B22_206 "1.0 .0 1.0"
6 B22_206_9 Ctx9 B22_206 ".0 .0 1.0"
10 291.457500000 w0 WS "B22_206"
20 291.457500000 w0 WS B22_206 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 231
10 291.533672000 w2 WS "B"
13 283.812528000 w2 gf 0.000000
13 291.533672000 w2 gf 0.000000
13 283.812528000 sched gft 0.000000
13 285.266774000 sched gft 0.000000
10 291.534362000 w2 WS "Po"
10 291.535136000 w2 WS "B"
10 291.537296000 w2 WS "P"
10 291.537818000 w2 WS "Sc"
13 291.538425000 sched nready 63.000000
13 291.538425000 sched nsubmitted 67.000000
10 291.538891000 w2 WS "B"
10 291.539311000 w2 WS "B"
10 291.539718000 w2 WS "Fi"
10 291.540737000 w2 WS "B"
6 B22_207 WS B22_207 "0.000000 0.600000 0.400000"
6 B22_207_1 Ctx1 B22_207 "1.0 0.39 1.0"
6 B22_207_2 Ctx2 B22_207 ".0 1.0 .0"
6 B22_207_3 Ctx3 B22_207 "0.87 0.87 .0"
6 B22_207_4 Ctx4 B22_207 ".0 0.95 1.0"
6 B22_207_5 Ctx5 B22_207 ".0 .0 .0"
6 B22_207_6 Ctx6 B22_207 ".0 .0 0.5"
6 B22_207_7 Ctx7 B22_207 "0.41 0.41 0.41"
6 B22_207_8 Ctx8 B22_207 "1.0 .0 1.0"
6 B22_207_9 Ctx9 B22_207 ".0 .0 1.0"
10 291.541205000 w2 WS "B22_207"
20 291.541205000 w2 WS B22_207 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 232
10 292.952540000 w5 WS "B"
13 285.274574000 w5 gf 0.000000
13 292.952540000 w5 gf 0.000000
13 285.274574000 sched gft 0.000000
13 285.277371000 sched gft 0.000000
10 292.953074000 w5 WS "Po"
10 292.954086000 w5 WS "B"
10 292.956368000 w5 WS "P"
10 292.956938000 w5 WS "Sc"
13 292.957617000 sched nready 62.000000
13 292.957617000 sched nsubmitted 66.000000
10 292.958119000 w5 WS "B"
10 292.958596000 w5 WS "B"
10 292.959004000 w5 WS "Fi"
10 292.959284000 w4 WS "B"
13 285.284864000 w4 gf 0.000000
13 292.959284000 w4 gf 0.000000
13 285.284864000 sched gft 0.000000
13 291.425808000 sched gft 0.000000
13 291.430281000 sched gft 0.000000
10 292.959903000 w4 WS "Po"
10 292.959951000 w5 WS "B"
6 B22_208 WS B22_208 "0.000000 0.600000 0.400000"
6 B22_208_1 Ctx1 B22_208 "1.0 0.39 1.0"
6 B22_208_2 Ctx2 B22_208 ".0 1.0 .0"
6 B22_208_3 Ctx3 B22_208 "0.87 0.87 .0"
6 B22_208_4 Ctx4 B22_208 ".0 0.95 1.0"
6 B22_208_5 Ctx5 B22_208 ".0 .0 .0"
6 B22_208_6 Ctx6 B22_208 ".0 .0 0.5"
6 B22_208_7 Ctx7 B22_208 "0.41 0.41 0.41"
6 B22_208_8 Ctx8 B22_208 "1.0 .0 1.0"
6 B22_208_9 Ctx9 B22_208 ".0 .0 1.0"
10 292.960492000 w5 WS "B22_208"
10 292.960760000 w4 WS "B"
20 292.960492000 w5 WS B22_208 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 233
10 292.963012000 w4 WS "P"
10 292.963598000 w4 WS "Sc"
13 292.964278000 sched nready 61.000000
13 292.964278000 sched nsubmitted 65.000000
10 292.964739000 w4 WS "B"
10 292.965151000 w4 WS "B"
10 292.965549000 w4 WS "Fi"
10 292.966433000 w4 WS "B"
6 B22_209 WS B22_209 "0.000000 0.600000 0.400000"
6 B22_209_1 Ctx1 B22_209 "1.0 0.39 1.0"
6 B22_209_2 Ctx2 B22_209 ".0 1.0 .0"
6 B22_209_3 Ctx3 B22_209 "0.87 0.87 .0"
6 B22_209_4 Ctx4 B22_209 ".0 0.95 1.0"
6 B22_209_5 Ctx5 B22_209 ".0 .0 .0"
6 B22_209_6 Ctx6 B22_209 ".0 .0 0.5"
6 B22_209_7 Ctx7 B22_209 "0.41 0.41 0.41"
6 B22_209_8 Ctx8 B22_209 "1.0 .0 1.0"
6 B22_209_9 Ctx9 B22_209 ".0 .0 1.0"
10 292.966930000 w4 WS "B22_209"
20 292.966930000 w4 WS B22_209 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 234
10 299.123193000 w3 WS "B"
13 291.438210000 w3 gf 0.000000
13 299.123193000 w3 gf 0.000000
10 299.123844000 w3 WS "Po"
10 299.124918000 w3 WS "B"
10 299.127454000 w3 WS "P"
10 299.128161000 w3 WS "Sc"
13 299.128977000 sched nready 60.000000
13 299.128977000 sched nsubmitted 64.000000
10 299.129817000 w3 WS "B"
10 299.130226000 w3 WS "B"
10 299.130629000 w3 WS "Fi"
10 299.131490000 w3 WS "B"
6 B22_210 WS B22_210 "0.000000 0.600000 0.400000"
6 B22_210_1 Ctx1 B22_210 "1.0 0.39 1.0"
6 B22_210_2 Ctx2 B22_210 ".0 1.0 .0"
6 B22_210_3 Ctx3 B22_210 "0.87 0.87 .0"
6 B22_210_4 Ctx4 B22_210 ".0 0.95 1.0"
6 B22_210_5 Ctx5 B22_210 ".0 .0 .0"
6 B22_210_6 Ctx6 B22_210 ".0 .0 0.5"
6 B22_210_7 Ctx7 B22_210 "0.41 0.41 0.41"
6 B22_210_8 Ctx8 B22_210 "1.0 .0 1.0"
6 B22_210_9 Ctx9 B22_210 ".0 .0 1.0"
10 299.132111000 w3 WS "B22_210"
20 299.132111000 w3 WS B22_210 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 235
10 299.149689000 w0 WS "B"
13 291.457500000 w0 gf 0.000000
13 299.149689000 w0 gf 0.000000
10 299.150402000 w0 WS "Po"
10 299.151558000 w0 WS "B"
10 299.154053000 w0 WS "P"
10 299.154607000 w0 WS "Sc"
13 299.155372000 sched nready 59.000000
13 299.155372000 sched nsubmitted 63.000000
10 299.155897000 w0 WS "B"
10 299.156320000 w0 WS "B"
10 299.156737000 w0 WS "Fi"
10 299.157590000 w0 WS "B"
10 299.157950000 w1 WS "B"
13 291.434640000 w1 gf 0.000000
13 299.157950000 w1 gf 0.000000
13 291.434640000 sched gft 0.000000
13 291.438210000 sched gft 0.000000
13 291.449494000 sched gft 0.000000
13 291.457500000 sched gft 0.000000
13 291.533672000 sched gft 0.000000
6 B22_211 WS B22_211 "0.000000 0.600000 0.400000"
6 B22_211_1 Ctx1 B22_211 "1.0 0.39 1.0"
6 B22_211_2 Ctx2 B22_211 ".0 1.0 .0"
6 B22_211_3 Ctx3 B22_211 "0.87 0.87 .0"
6 B22_211_4 Ctx4 B22_211 ".0 0.95 1.0"
6 B22_211_5 Ctx5 B22_211 ".0 .0 .0"
6 B22_211_6 Ctx6 B22_211 ".0 .0 0.5"
6 B22_211_7 Ctx7 B22_211 "0.41 0.41 0.41"
6 B22_211_8 Ctx8 B22_211 "1.0 .0 1.0"
6 B22_211_9 Ctx9 B22_211 ".0 .0 1.0"
10 299.158101000 w0 WS "B22_211"
10 299.158512000 w1 WS "Po"
20 299.158101000 w0 WS B22_211 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 236
10 299.159516000 w1 WS "B"
10 299.161780000 w1 WS "P"
10 299.162407000 w1 WS "Sc"
13 299.163078000 sched nready 58.000000
13 299.163078000 sched nsubmitted 62.000000
10 299.163601000 w1 WS "B"
10 299.164013000 w1 WS "B"
10 299.164420000 w1 WS "Fi"
10 299.165258000 w1 WS "B"
6 B22_212 WS B22_212 "0.000000 0.600000 0.400000"
6 B22_212_1 Ctx1 B22_212 "1.0 0.39 1.0"
6 B22_212_2 Ctx2 B22_212 ".0 1.0 .0"
6 B22_212_3 Ctx3 B22_212 "0.87 0.87 .0"
6 B22_212_4 Ctx4 B22_212 ".0 0.95 1.0"
6 B22_212_5 Ctx5 B22_212 ".0 .0 .0"
6 B22_212_6 Ctx6 B22_212 ".0 .0 0.5"
6 B22_212_7 Ctx7 B22_212 "0.41 0.41 0.41"
6 B22_212_8 Ctx8 B22_212 "1.0 .0 1.0"
6 B22_212_9 Ctx9 B22_212 ".0 .0 1.0"
10 299.165739000 w1 WS "B22_212"
20 299.165739000 w1 WS B22_212 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 237
10 299.188882000 w2 WS "B"
13 291.541205000 w2 gf 0.000000
13 299.188882000 w2 gf 0.000000
13 291.541205000 sched gft 0.000000
13 292.952540000 sched gft 0.000000
13 292.959284000 sched gft 0.000000
10 299.189433000 w2 WS "Po"
10 299.190266000 w2 WS "B"
10 299.192575000 w2 WS "P"
10 299.193133000 w2 WS "Sc"
13 299.193779000 sched nready 57.000000
13 299.193779000 sched nsubmitted 61.000000
10 299.194232000 w2 WS "B"
10 299.194643000 w2 WS "B"
10 299.195048000 w2 WS "Fi"
10 299.195859000 w2 WS "B"
6 B22_213 WS B22_213 "0.000000 0.600000 0.400000"
6 B22_213_1 Ctx1 B22_213 "1.0 0.39 1.0"
6 B22_213_2 Ctx2 B22_213 ".0 1.0 .0"
6 B22_213_3 Ctx3 B22_213 "0.87 0.87 .0"
6 B22_213_4 Ctx4 B22_213 ".0 0.95 1.0"
6 B22_213_5 Ctx5 B22_213 ".0 .0 .0"
6 B22_213_6 Ctx6 B22_213 ".0 .0 0.5"
6 B22_213_7 Ctx7 B22_213 "0.41 0.41 0.41"
6 B22_213_8 Ctx8 B22_213 "1.0 .0 1.0"
6 B22_213_9 Ctx9 B22_213 ".0 .0 1.0"
10 299.196332000 w2 WS "B22_213"
20 299.196332000 w2 WS B22_213 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 238
10 300.712932000 w5 WS "B"
13 292.960492000 w5 gf 0.000000
13 300.712932000 w5 gf 0.000000
13 292.960492000 sched gft 0.000000
10 300.713637000 w5 WS "Po"
10 300.714667000 w5 WS "B"
10 300.714937000 w4 WS "B"
13 292.966930000 w4 gf 0.000000
13 300.714937000 w4 gf 0.000000
13 292.966930000 sched gft 0.000000
13 299.123193000 sched gft 0.000000
10 300.715464000 w4 WS "Po"
10 300.716289000 w4 WS "B"
10 300.717055000 w5 WS "P"
10 300.717649000 w5 WS "Sc"
13 300.718365000 sched nready 56.000000
13 300.718365000 sched nsubmitted 60.000000
10 300.718838000 w5 WS "B"
10 300.719017000 w4 WS "P"
10 300.719264000 w5 WS "B"
10 300.719607000 w4 WS "Sc"
10 300.719691000 w5 WS "Fi"
13 300.720351000 sched nready 55.000000
13 300.720351000 sched nsubmitted 59.000000
10 300.720798000 w5 WS "B"
10 300.720865000 w4 WS "B"
6 B22_214 WS B22_214 "0.000000 0.600000 0.400000"
6 B22_214_1 Ctx1 B22_214 "1.0 0.39 1.0"
6 B22_214_2 Ctx2 B22_214 ".0 1.0 .0"
6 B22_214_3 Ctx3 B22_214 "0.87 0.87 .0"
6 B22_214_4 Ctx4 B22_214 ".0 0.95 1.0"
6 B22_214_5 Ctx5 B22_214 ".0 .0 .0"
6 B22_214_6 Ctx6 B22_214 ".0 .0 0.5"
6 B22_214_7 Ctx7 B22_214 "0.41 0.41 0.41"
6 B22_214_8 Ctx8 B22_214 "1.0 .0 1.0"
6 B22_214_9 Ctx9 B22_214 ".0 .0 1.0"
10 300.721309000 w5 WS "B22_214"
10 300.721375000 w4 WS "B"
10 300.721791000 w4 WS "Fi"
20 300.721309000 w5 WS B22_214 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 239
10 300.722709000 w4 WS "B"
6 B22_215 WS B22_215 "0.000000 0.600000 0.400000"
6 B22_215_1 Ctx1 B22_215 "1.0 0.39 1.0"
6 B22_215_2 Ctx2 B22_215 ".0 1.0 .0"
6 B22_215_3 Ctx3 B22_215 "0.87 0.87 .0"
6 B22_215_4 Ctx4 B22_215 ".0 0.95 1.0"
6 B22_215_5 Ctx5 B22_215 ".0 .0 .0"
6 B22_215_6 Ctx6 B22_215 ".0 .0 0.5"
6 B22_215_7 Ctx7 B22_215 "0.41 0.41 0.41"
6 B22_215_8 Ctx8 B22_215 "1.0 .0 1.0"
6 B22_215_9 Ctx9 B22_215 ".0 .0 1.0"
10 300.723196000 w4 WS "B22_215"
20 300.723196000 w4 WS B22_215 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 240
10 306.839168000 w1 WS "B"
13 299.165739000 w1 gf 0.000000
13 306.839168000 w1 gf 0.000000
10 306.839933000 w1 WS "Po"
10 306.840988000 w1 WS "B"
10 306.843640000 w1 WS "P"
10 306.844377000 w1 WS "Sc"
13 306.845237000 sched nready 54.000000
13 306.845237000 sched nsubmitted 58.000000
10 306.845302000 w2 WS "B"
13 299.196332000 w2 gf 0.000000
13 306.845302000 w2 gf 0.000000
10 306.845803000 w1 WS "B"
10 306.845935000 w2 WS "Po"
10 306.846234000 w0 WS "B"
13 299.158101000 w0 gf 0.000000
13 306.846234000 w0 gf 0.000000
10 306.846293000 w1 WS "B"
10 306.846774000 w2 WS "B"
10 306.846841000 w1 WS "Fi"
10 306.846899000 w0 WS "Po"
10 306.847957000 w1 WS "B"
10 306.848412000 w0 WS "B"
6 B22_216 WS B22_216 "0.000000 0.600000 0.400000"
6 B22_216_1 Ctx1 B22_216 "1.0 0.39 1.0"
6 B22_216_2 Ctx2 B22_216 ".0 1.0 .0"
6 B22_216_3 Ctx3 B22_216 "0.87 0.87 .0"
6 B22_216_4 Ctx4 B22_216 ".0 0.95 1.0"
6 B22_216_5 Ctx5 B22_216 ".0 .0 .0"
6 B22_216_6 Ctx6 B22_216 ".0 .0 0.5"
6 B22_216_7 Ctx7 B22_216 "0.41 0.41 0.41"
6 B22_216_8 Ctx8 B22_216 "1.0 .0 1.0"
6 B22_216_9 Ctx9 B22_216 ".0 .0 1.0"
10 306.848550000 w1 WS "B22_216"
10 306.849493000 w2 WS "P"
20 306.848550000 w1 WS B22_216 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 241
10 306.850108000 w2 WS "Sc"
13 306.850874000 sched nready 53.000000
13 306.850874000 sched nsubmitted 57.000000
10 306.851032000 w0 WS "P"
10 306.851346000 w2 WS "B"
10 306.851609000 w0 WS "Sc"
10 306.851777000 w2 WS "B"
10 306.852198000 w2 WS "Fi"
13 306.852325000 sched nready 52.000000
13 306.852325000 sched nsubmitted 56.000000
10 306.852908000 w0 WS "B"
10 306.853130000 w2 WS "B"
10 306.853342000 w0 WS "B"
6 B22_217 WS B22_217 "0.000000 0.600000 0.400000"
6 B22_217_1 Ctx1 B22_217 "1.0 0.39 1.0"
6 B22_217_2 Ctx2 B22_217 ".0 1.0 .0"
6 B22_217_3 Ctx3 B22_217 "0.87 0.87 .0"
6 B22_217_4 Ctx4 B22_217 ".0 0.95 1.0"
6 B22_217_5 Ctx5 B22_217 ".0 .0 .0"
6 B22_217_6 Ctx6 B22_217 ".0 .0 0.5"
6 B22_217_7 Ctx7 B22_217 "0.41 0.41 0.41"
6 B22_217_8 Ctx8 B22_217 "1.0 .0 1.0"
6 B22_217_9 Ctx9 B22_217 ".0 .0 1.0"
10 306.853632000 w2 WS "B22_217"
10 306.853768000 w0 WS "Fi"
20 306.853632000 w2 WS B22_217 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 242
10 306.854856000 w0 WS "B"
6 B22_218 WS B22_218 "0.000000 0.600000 0.400000"
6 B22_218_1 Ctx1 B22_218 "1.0 0.39 1.0"
6 B22_218_2 Ctx2 B22_218 ".0 1.0 .0"
6 B22_218_3 Ctx3 B22_218 "0.87 0.87 .0"
6 B22_218_4 Ctx4 B22_218 ".0 0.95 1.0"
6 B22_218_5 Ctx5 B22_218 ".0 .0 .0"
6 B22_218_6 Ctx6 B22_218 ".0 .0 0.5"
6 B22_218_7 Ctx7 B22_218 "0.41 0.41 0.41"
6 B22_218_8 Ctx8 B22_218 "1.0 .0 1.0"
6 B22_218_9 Ctx9 B22_218 ".0 .0 1.0"
10 306.855402000 w0 WS "B22_218"
20 306.855402000 w0 WS B22_218 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 243
10 306.887108000 w3 WS "B"
13 299.132111000 w3 gf 0.000000
13 306.887108000 w3 gf 0.000000
13 299.132111000 sched gft 0.000000
13 299.149689000 sched gft 0.000000
13 299.157950000 sched gft 0.000000
13 299.158101000 sched gft 0.000000
13 299.165739000 sched gft 0.000000
13 299.188882000 sched gft 0.000000
13 299.196332000 sched gft 0.000000
13 300.712932000 sched gft 0.000000
13 300.714937000 sched gft 0.000000
10 306.887739000 w3 WS "Po"
10 306.888559000 w3 WS "B"
10 306.890763000 w3 WS "P"
10 306.891306000 w3 WS "Sc"
13 306.891946000 sched nready 51.000000
13 306.891946000 sched nsubmitted 55.000000
10 306.892439000 w3 WS "B"
10 306.892857000 w3 WS "B"
10 306.893492000 w3 WS "Fi"
10 306.894372000 w3 WS "B"
6 B22_219 WS B22_219 "0.000000 0.600000 0.400000"
6 B22_219_1 Ctx1 B22_219 "1.0 0.39 1.0"
6 B22_219_2 Ctx2 B22_219 ".0 1.0 .0"
6 B22_219_3 Ctx3 B22_219 "0.87 0.87 .0"
6 B22_219_4 Ctx4 B22_219 ".0 0.95 1.0"
6 B22_219_5 Ctx5 B22_219 ".0 .0 .0"
6 B22_219_6 Ctx6 B22_219 ".0 .0 0.5"
6 B22_219_7 Ctx7 B22_219 "0.41 0.41 0.41"
6 B22_219_8 Ctx8 B22_219 "1.0 .0 1.0"
6 B22_219_9 Ctx9 B22_219 ".0 .0 1.0"
10 306.894838000 w3 WS "B22_219"
20 306.894838000 w3 WS B22_219 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 244
10 308.404484000 w5 WS "B"
13 300.721309000 w5 gf 0.000000
13 308.404484000 w5 gf 0.000000
13 300.721309000 sched gft 0.000000
10 308.405140000 w5 WS "Po"
10 308.405925000 w5 WS "B"
10 308.407415000 w4 WS "B"
13 300.723196000 w4 gf 0.000000
13 308.407415000 w4 gf 0.000000
13 300.723196000 sched gft 0.000000
13 306.839168000 sched gft 0.000000
13 306.845302000 sched gft 0.000000
13 306.846234000 sched gft 0.000000
10 308.408140000 w4 WS "Po"
10 308.408349000 w5 WS "P"
10 308.408955000 w5 WS "Sc"
10 308.409056000 w4 WS "B"
13 308.409621000 sched nready 50.000000
13 308.409621000 sched nsubmitted 54.000000
10 308.410230000 w5 WS "B"
10 308.410662000 w5 WS "B"
10 308.411080000 w5 WS "Fi"
10 308.411393000 w4 WS "P"
10 308.411972000 w4 WS "Sc"
10 308.412103000 w5 WS "B"
6 B22_220 WS B22_220 "0.000000 0.600000 0.400000"
6 B22_220_1 Ctx1 B22_220 "1.0 0.39 1.0"
6 B22_220_2 Ctx2 B22_220 ".0 1.0 .0"
6 B22_220_3 Ctx3 B22_220 "0.87 0.87 .0"
6 B22_220_4 Ctx4 B22_220 ".0 0.95 1.0"
6 B22_220_5 Ctx5 B22_220 ".0 .0 .0"
6 B22_220_6 Ctx6 B22_220 ".0 .0 0.5"
6 B22_220_7 Ctx7 B22_220 "0.41 0.41 0.41"
6 B22_220_8 Ctx8 B22_220 "1.0 .0 1.0"
6 B22_220_9 Ctx9 B22_220 ".0 .0 1.0"
10 308.412624000 w5 WS "B22_220"
13 308.412689000 sched nready 49.000000
13 308.412689000 sched nsubmitted 53.000000
10 308.413286000 w4 WS "B"
10 308.413734000 w4 WS "B"
20 308.412624000 w5 WS B22_220 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 245
10 308.414155000 w4 WS "Fi"
10 308.415002000 w4 WS "B"
6 B22_221 WS B22_221 "0.000000 0.600000 0.400000"
6 B22_221_1 Ctx1 B22_221 "1.0 0.39 1.0"
6 B22_221_2 Ctx2 B22_221 ".0 1.0 .0"
6 B22_221_3 Ctx3 B22_221 "0.87 0.87 .0"
6 B22_221_4 Ctx4 B22_221 ".0 0.95 1.0"
6 B22_221_5 Ctx5 B22_221 ".0 .0 .0"
6 B22_221_6 Ctx6 B22_221 ".0 .0 0.5"
6 B22_221_7 Ctx7 B22_221 "0.41 0.41 0.41"
6 B22_221_8 Ctx8 B22_221 "1.0 .0 1.0"
6 B22_221_9 Ctx9 B22_221 ".0 .0 1.0"
10 308.415475000 w4 WS "B22_221"
20 308.415475000 w4 WS B22_221 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 246
10 314.559155000 w2 WS "B"
13 306.853632000 w2 gf 0.000000
13 314.559155000 w2 gf 0.000000
10 314.559855000 w2 WS "Po"
10 314.560864000 w2 WS "B"
10 314.563703000 w2 WS "P"
10 314.564363000 w2 WS "Sc"
13 314.565364000 sched nready 48.000000
13 314.565364000 sched nsubmitted 52.000000
10 314.565884000 w2 WS "B"
10 314.566023000 w3 WS "B"
13 306.894838000 w3 gf 0.000000
13 314.566023000 w3 gf 0.000000
10 314.566304000 w2 WS "B"
10 314.566567000 w3 WS "Po"
10 314.566720000 w2 WS "Fi"
10 314.567417000 w3 WS "B"
10 314.567890000 w2 WS "B"
6 B22_222 WS B22_222 "0.000000 0.600000 0.400000"
6 B22_222_1 Ctx1 B22_222 "1.0 0.39 1.0"
6 B22_222_2 Ctx2 B22_222 ".0 1.0 .0"
6 B22_222_3 Ctx3 B22_222 "0.87 0.87 .0"
6 B22_222_4 Ctx4 B22_222 ".0 0.95 1.0"
6 B22_222_5 Ctx5 B22_222 ".0 .0 .0"
6 B22_222_6 Ctx6 B22_222 ".0 .0 0.5"
6 B22_222_7 Ctx7 B22_222 "0.41 0.41 0.41"
6 B22_222_8 Ctx8 B22_222 "1.0 .0 1.0"
6 B22_222_9 Ctx9 B22_222 ".0 .0 1.0"
10 314.568879000 w2 WS "B22_222"
20 314.568879000 w2 WS B22_222 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 247
10 314.570248000 w3 WS "P"
10 314.570809000 w3 WS "Sc"
13 314.571519000 sched nready 47.000000
13 314.571519000 sched nsubmitted 51.000000
10 314.571989000 w3 WS "B"
10 314.572405000 w3 WS "B"
10 314.572826000 w3 WS "Fi"
10 314.573712000 w3 WS "B"
6 B22_223 WS B22_223 "0.000000 0.600000 0.400000"
6 B22_223_1 Ctx1 B22_223 "1.0 0.39 1.0"
6 B22_223_2 Ctx2 B22_223 ".0 1.0 .0"
6 B22_223_3 Ctx3 B22_223 "0.87 0.87 .0"
6 B22_223_4 Ctx4 B22_223 ".0 0.95 1.0"
6 B22_223_5 Ctx5 B22_223 ".0 .0 .0"
6 B22_223_6 Ctx6 B22_223 ".0 .0 0.5"
6 B22_223_7 Ctx7 B22_223 "0.41 0.41 0.41"
6 B22_223_8 Ctx8 B22_223 "1.0 .0 1.0"
6 B22_223_9 Ctx9 B22_223 ".0 .0 1.0"
10 314.574193000 w3 WS "B22_223"
20 314.574193000 w3 WS B22_223 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 248
10 314.601112000 w1 WS "B"
13 306.848550000 w1 gf 0.000000
13 314.601112000 w1 gf 0.000000
13 306.848550000 sched gft 0.000000
13 306.853632000 sched gft 0.000000
10 314.602003000 w1 WS "Po"
10 314.602857000 w1 WS "B"
10 314.605281000 w1 WS "P"
10 314.605916000 w1 WS "Sc"
13 314.606601000 sched nready 46.000000
13 314.606601000 sched nsubmitted 50.000000
10 314.607136000 w1 WS "B"
10 314.607546000 w1 WS "B"
10 314.607955000 w1 WS "Fi"
10 314.608773000 w1 WS "B"
6 B22_224 WS B22_224 "0.000000 0.600000 0.400000"
6 B22_224_1 Ctx1 B22_224 "1.0 0.39 1.0"
6 B22_224_2 Ctx2 B22_224 ".0 1.0 .0"
6 B22_224_3 Ctx3 B22_224 "0.87 0.87 .0"
6 B22_224_4 Ctx4 B22_224 ".0 0.95 1.0"
6 B22_224_5 Ctx5 B22_224 ".0 .0 .0"
6 B22_224_6 Ctx6 B22_224 ".0 .0 0.5"
6 B22_224_7 Ctx7 B22_224 "0.41 0.41 0.41"
6 B22_224_8 Ctx8 B22_224 "1.0 .0 1.0"
6 B22_224_9 Ctx9 B22_224 ".0 .0 1.0"
10 314.609257000 w1 WS "B22_224"
20 314.609257000 w1 WS B22_224 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 249
10 314.695276000 w0 WS "B"
13 306.855402000 w0 gf 0.000000
13 314.695276000 w0 gf 0.000000
13 306.855402000 sched gft 0.000000
13 306.887108000 sched gft 0.000000
13 306.894838000 sched gft 0.000000
13 308.404484000 sched gft 0.000000
13 308.407415000 sched gft 0.000000
10 314.696212000 w0 WS "Po"
10 314.697290000 w0 WS "B"
10 314.700416000 w0 WS "P"
10 314.701219000 w0 WS "Sc"
13 314.702153000 sched nready 45.000000
13 314.702153000 sched nsubmitted 49.000000
10 314.702646000 w0 WS "B"
10 314.703051000 w0 WS "B"
10 314.703461000 w0 WS "Fi"
10 314.704655000 w0 WS "B"
6 B22_225 WS B22_225 "0.000000 0.600000 0.400000"
6 B22_225_1 Ctx1 B22_225 "1.0 0.39 1.0"
6 B22_225_2 Ctx2 B22_225 ".0 1.0 .0"
6 B22_225_3 Ctx3 B22_225 "0.87 0.87 .0"
6 B22_225_4 Ctx4 B22_225 ".0 0.95 1.0"
6 B22_225_5 Ctx5 B22_225 ".0 .0 .0"
6 B22_225_6 Ctx6 B22_225 ".0 .0 0.5"
6 B22_225_7 Ctx7 B22_225 "0.41 0.41 0.41"
6 B22_225_8 Ctx8 B22_225 "1.0 .0 1.0"
6 B22_225_9 Ctx9 B22_225 ".0 .0 1.0"
10 314.705278000 w0 WS "B22_225"
20 314.705278000 w0 WS B22_225 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 250
10 316.079987000 w5 WS "B"
13 308.412624000 w5 gf 0.000000
13 316.079987000 w5 gf 0.000000
13 308.412624000 sched gft 0.000000
10 316.080488000 w5 WS "Po"
10 316.081353000 w5 WS "B"
10 316.083560000 w5 WS "P"
10 316.084099000 w5 WS "Sc"
13 316.084734000 sched nready 44.000000
13 316.084734000 sched nsubmitted 48.000000
10 316.085228000 w5 WS "B"
10 316.085677000 w5 WS "B"
10 316.086109000 w5 WS "Fi"
10 316.086972000 w5 WS "B"
10 316.087065000 w4 WS "B"
13 308.415475000 w4 gf 0.000000
13 316.087065000 w4 gf 0.000000
13 308.415475000 sched gft 0.000000
13 314.559155000 sched gft 0.000000
13 314.566023000 sched gft 0.000000
6 B22_226 WS B22_226 "0.000000 0.600000 0.400000"
6 B22_226_1 Ctx1 B22_226 "1.0 0.39 1.0"
6 B22_226_2 Ctx2 B22_226 ".0 1.0 .0"
6 B22_226_3 Ctx3 B22_226 "0.87 0.87 .0"
6 B22_226_4 Ctx4 B22_226 ".0 0.95 1.0"
6 B22_226_5 Ctx5 B22_226 ".0 .0 .0"
6 B22_226_6 Ctx6 B22_226 ".0 .0 0.5"
6 B22_226_7 Ctx7 B22_226 "0.41 0.41 0.41"
6 B22_226_8 Ctx8 B22_226 "1.0 .0 1.0"
6 B22_226_9 Ctx9 B22_226 ".0 .0 1.0"
10 316.087458000 w5 WS "B22_226"
10 316.087633000 w4 WS "Po"
10 316.088482000 w4 WS "B"
20 316.087458000 w5 WS B22_226 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 251
10 316.090837000 w4 WS "P"
10 316.091406000 w4 WS "Sc"
13 316.092112000 sched nready 43.000000
13 316.092112000 sched nsubmitted 47.000000
10 316.092575000 w4 WS "B"
10 316.092987000 w4 WS "B"
10 316.093396000 w4 WS "Fi"
10 316.094232000 w4 WS "B"
6 B22_227 WS B22_227 "0.000000 0.600000 0.400000"
6 B22_227_1 Ctx1 B22_227 "1.0 0.39 1.0"
6 B22_227_2 Ctx2 B22_227 ".0 1.0 .0"
6 B22_227_3 Ctx3 B22_227 "0.87 0.87 .0"
6 B22_227_4 Ctx4 B22_227 ".0 0.95 1.0"
6 B22_227_5 Ctx5 B22_227 ".0 .0 .0"
6 B22_227_6 Ctx6 B22_227 ".0 .0 0.5"
6 B22_227_7 Ctx7 B22_227 "0.41 0.41 0.41"
6 B22_227_8 Ctx8 B22_227 "1.0 .0 1.0"
6 B22_227_9 Ctx9 B22_227 ".0 .0 1.0"
10 316.094711000 w4 WS "B22_227"
20 316.094711000 w4 WS B22_227 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 252
10 322.253163000 w2 WS "B"
13 314.568879000 w2 gf 0.000000
13 322.253163000 w2 gf 0.000000
13 314.568879000 sched gft 0.000000
10 322.254006000 w2 WS "Po"
10 322.254917000 w2 WS "B"
10 322.257891000 w2 WS "P"
10 322.258641000 w2 WS "Sc"
13 322.259463000 sched nready 42.000000
13 322.259463000 sched nsubmitted 46.000000
10 322.259748000 w3 WS "B"
13 314.574193000 w3 gf 0.000000
13 322.259748000 w3 gf 0.000000
13 314.574193000 sched gft 0.000000
13 314.601112000 sched gft 0.000000
10 322.260066000 w2 WS "B"
10 322.260381000 w3 WS "Po"
10 322.260495000 w2 WS "B"
10 322.261031000 w2 WS "Fi"
10 322.261240000 w3 WS "B"
10 322.262184000 w2 WS "B"
6 B22_228 WS B22_228 "0.000000 0.600000 0.400000"
6 B22_228_1 Ctx1 B22_228 "1.0 0.39 1.0"
6 B22_228_2 Ctx2 B22_228 ".0 1.0 .0"
6 B22_228_3 Ctx3 B22_228 "0.87 0.87 .0"
6 B22_228_4 Ctx4 B22_228 ".0 0.95 1.0"
6 B22_228_5 Ctx5 B22_228 ".0 .0 .0"
6 B22_228_6 Ctx6 B22_228 ".0 .0 0.5"
6 B22_228_7 Ctx7 B22_228 "0.41 0.41 0.41"
6 B22_228_8 Ctx8 B22_228 "1.0 .0 1.0"
6 B22_228_9 Ctx9 B22_228 ".0 .0 1.0"
10 322.262669000 w2 WS "B22_228"
10 322.263669000 w3 WS "P"
20 322.262669000 w2 WS B22_228 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 253
10 322.264258000 w3 WS "Sc"
13 322.264890000 sched nready 41.000000
13 322.264890000 sched nsubmitted 45.000000
10 322.265345000 w3 WS "B"
10 322.265760000 w3 WS "B"
10 322.266163000 w3 WS "Fi"
10 322.266968000 w3 WS "B"
6 B22_229 WS B22_229 "0.000000 0.600000 0.400000"
6 B22_229_1 Ctx1 B22_229 "1.0 0.39 1.0"
6 B22_229_2 Ctx2 B22_229 ".0 1.0 .0"
6 B22_229_3 Ctx3 B22_229 "0.87 0.87 .0"
6 B22_229_4 Ctx4 B22_229 ".0 0.95 1.0"
6 B22_229_5 Ctx5 B22_229 ".0 .0 .0"
6 B22_229_6 Ctx6 B22_229 ".0 .0 0.5"
6 B22_229_7 Ctx7 B22_229 "0.41 0.41 0.41"
6 B22_229_8 Ctx8 B22_229 "1.0 .0 1.0"
6 B22_229_9 Ctx9 B22_229 ".0 .0 1.0"
10 322.267449000 w3 WS "B22_229"
20 322.267449000 w3 WS B22_229 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 254
10 322.300619000 w1 WS "B"
13 314.609257000 w1 gf 0.000000
13 322.300619000 w1 gf 0.000000
13 314.609257000 sched gft 0.000000
13 314.695276000 sched gft 0.000000
10 322.301266000 w1 WS "Po"
10 322.302091000 w1 WS "B"
10 322.304293000 w1 WS "P"
10 322.304841000 w1 WS "Sc"
13 322.305531000 sched nready 40.000000
13 322.305531000 sched nsubmitted 44.000000
10 322.306073000 w1 WS "B"
10 322.306486000 w1 WS "B"
10 322.306904000 w1 WS "Fi"
10 322.307777000 w1 WS "B"
6 B22_230 WS B22_230 "0.000000 0.600000 0.400000"
6 B22_230_1 Ctx1 B22_230 "1.0 0.39 1.0"
6 B22_230_2 Ctx2 B22_230 ".0 1.0 .0"
6 B22_230_3 Ctx3 B22_230 "0.87 0.87 .0"
6 B22_230_4 Ctx4 B22_230 ".0 0.95 1.0"
6 B22_230_5 Ctx5 B22_230 ".0 .0 .0"
6 B22_230_6 Ctx6 B22_230 ".0 .0 0.5"
6 B22_230_7 Ctx7 B22_230 "0.41 0.41 0.41"
6 B22_230_8 Ctx8 B22_230 "1.0 .0 1.0"
6 B22_230_9 Ctx9 B22_230 ".0 .0 1.0"
10 322.308264000 w1 WS "B22_230"
20 322.308264000 w1 WS B22_230 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 255
10 322.380662000 w0 WS "B"
13 314.705278000 w0 gf 0.000000
13 322.380662000 w0 gf 0.000000
13 314.705278000 sched gft 0.000000
13 316.079987000 sched gft 0.000000
13 316.087065000 sched gft 0.000000
10 322.381349000 w0 WS "Po"
10 322.382209000 w0 WS "B"
10 322.384695000 w0 WS "P"
10 322.385317000 w0 WS "Sc"
13 322.386092000 sched nready 39.000000
13 322.386092000 sched nsubmitted 43.000000
10 322.386948000 w0 WS "B"
10 322.387363000 w0 WS "B"
10 322.387785000 w0 WS "Fi"
10 322.388675000 w0 WS "B"
6 B22_231 WS B22_231 "0.000000 0.600000 0.400000"
6 B22_231_1 Ctx1 B22_231 "1.0 0.39 1.0"
6 B22_231_2 Ctx2 B22_231 ".0 1.0 .0"
6 B22_231_3 Ctx3 B22_231 "0.87 0.87 .0"
6 B22_231_4 Ctx4 B22_231 ".0 0.95 1.0"
6 B22_231_5 Ctx5 B22_231 ".0 .0 .0"
6 B22_231_6 Ctx6 B22_231 ".0 .0 0.5"
6 B22_231_7 Ctx7 B22_231 "0.41 0.41 0.41"
6 B22_231_8 Ctx8 B22_231 "1.0 .0 1.0"
6 B22_231_9 Ctx9 B22_231 ".0 .0 1.0"
10 322.389173000 w0 WS "B22_231"
20 322.389173000 w0 WS B22_231 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 256
10 323.760431000 w5 WS "B"
13 316.087458000 w5 gf 0.000000
13 323.760431000 w5 gf 0.000000
13 316.087458000 sched gft 0.000000
10 323.761052000 w5 WS "Po"
10 323.761860000 w5 WS "B"
10 323.763949000 w5 WS "P"
10 323.764505000 w5 WS "Sc"
13 323.765165000 sched nready 38.000000
13 323.765165000 sched nsubmitted 42.000000
10 323.765695000 w5 WS "B"
10 323.766110000 w5 WS "B"
10 323.766521000 w5 WS "Fi"
10 323.767442000 w5 WS "B"
6 B22_232 WS B22_232 "0.000000 0.600000 0.400000"
6 B22_232_1 Ctx1 B22_232 "1.0 0.39 1.0"
6 B22_232_2 Ctx2 B22_232 ".0 1.0 .0"
6 B22_232_3 Ctx3 B22_232 "0.87 0.87 .0"
6 B22_232_4 Ctx4 B22_232 ".0 0.95 1.0"
6 B22_232_5 Ctx5 B22_232 ".0 .0 .0"
6 B22_232_6 Ctx6 B22_232 ".0 .0 0.5"
6 B22_232_7 Ctx7 B22_232 "0.41 0.41 0.41"
6 B22_232_8 Ctx8 B22_232 "1.0 .0 1.0"
6 B22_232_9 Ctx9 B22_232 ".0 .0 1.0"
10 323.767949000 w5 WS "B22_232"
10 323.768590000 w4 WS "B"
13 316.094711000 w4 gf 0.000000
13 323.768590000 w4 gf 0.000000
13 316.094711000 sched gft 0.000000
13 322.253163000 sched gft 0.000000
13 322.259748000 sched gft 0.000000
20 323.767949000 w5 WS B22_232 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 257
10 323.769220000 w4 WS "Po"
10 323.770026000 w4 WS "B"
10 323.772744000 w4 WS "P"
10 323.773301000 w4 WS "Sc"
13 323.773999000 sched nready 37.000000
13 323.773999000 sched nsubmitted 41.000000
10 323.774492000 w4 WS "B"
10 323.774901000 w4 WS "B"
10 323.775308000 w4 WS "Fi"
10 323.776093000 w4 WS "B"
6 B22_233 WS B22_233 "0.000000 0.600000 0.400000"
6 B22_233_1 Ctx1 B22_233 "1.0 0.39 1.0"
6 B22_233_2 Ctx2 B22_233 ".0 1.0 .0"
6 B22_233_3 Ctx3 B22_233 "0.87 0.87 .0"
6 B22_233_4 Ctx4 B22_233 ".0 0.95 1.0"
6 B22_233_5 Ctx5 B22_233 ".0 .0 .0"
6 B22_233_6 Ctx6 B22_233 ".0 .0 0.5"
6 B22_233_7 Ctx7 B22_233 "0.41 0.41 0.41"
6 B22_233_8 Ctx8 B22_233 "1.0 .0 1.0"
6 B22_233_9 Ctx9 B22_233 ".0 .0 1.0"
10 323.776583000 w4 WS "B22_233"
20 323.776583000 w4 WS B22_233 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 258
10 329.946870000 w2 WS "B"
13 322.262669000 w2 gf 0.000000
13 329.946870000 w2 gf 0.000000
13 322.262669000 sched gft 0.000000
10 329.948015000 w2 WS "Po"
10 329.948926000 w2 WS "B"
10 329.949018000 w3 WS "B"
13 322.267449000 w3 gf 0.000000
13 329.949018000 w3 gf 0.000000
13 322.267449000 sched gft 0.000000
13 322.300619000 sched gft 0.000000
10 329.949644000 w3 WS "Po"
10 329.950586000 w3 WS "B"
10 329.951692000 w2 WS "P"
10 329.952489000 w2 WS "Sc"
10 329.952876000 w3 WS "P"
13 329.953427000 sched nready 36.000000
13 329.953427000 sched nsubmitted 40.000000
10 329.953521000 w3 WS "Sc"
10 329.953988000 w2 WS "B"
13 329.954211000 sched nready 35.000000
13 329.954211000 sched nsubmitted 39.000000
10 329.954402000 w2 WS "B"
10 329.954812000 w2 WS "Fi"
10 329.955042000 w3 WS "B"
10 329.955460000 w3 WS "B"
10 329.955723000 w2 WS "B"
10 329.955891000 w3 WS "Fi"
6 B22_234 WS B22_234 "0.000000 0.600000 0.400000"
6 B22_234_1 Ctx1 B22_234 "1.0 0.39 1.0"
6 B22_234_2 Ctx2 B22_234 ".0 1.0 .0"
6 B22_234_3 Ctx3 B22_234 "0.87 0.87 .0"
6 B22_234_4 Ctx4 B22_234 ".0 0.95 1.0"
6 B22_234_5 Ctx5 B22_234 ".0 .0 .0"
6 B22_234_6 Ctx6 B22_234 ".0 .0 0.5"
6 B22_234_7 Ctx7 B22_234 "0.41 0.41 0.41"
6 B22_234_8 Ctx8 B22_234 "1.0 .0 1.0"
6 B22_234_9 Ctx9 B22_234 ".0 .0 1.0"
10 329.956329000 w2 WS "B22_234"
10 329.956820000 w3 WS "B"
6 B22_235 WS B22_235 "0.000000 0.600000 0.400000"
6 B22_235_1 Ctx1 B22_235 "1.0 0.39 1.0"
6 B22_235_2 Ctx2 B22_235 ".0 1.0 .0"
6 B22_235_3 Ctx3 B22_235 "0.87 0.87 .0"
6 B22_235_4 Ctx4 B22_235 ".0 0.95 1.0"
6 B22_235_5 Ctx5 B22_235 ".0 .0 .0"
6 B22_235_6 Ctx6 B22_235 ".0 .0 0.5"
6 B22_235_7 Ctx7 B22_235 "0.41 0.41 0.41"
6 B22_235_8 Ctx8 B22_235 "1.0 .0 1.0"
6 B22_235_9 Ctx9 B22_235 ".0 .0 1.0"
10 329.957379000 w3 WS "B22_235"
20 329.956329000 w2 WS B22_234 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 259
20 329.957379000 w3 WS B22_235 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 260
10 330.022446000 w1 WS "B"
13 322.308264000 w1 gf 0.000000
13 330.022446000 w1 gf 0.000000
13 322.308264000 sched gft 0.000000
13 322.380662000 sched gft 0.000000
10 330.022993000 w1 WS "Po"
10 330.023842000 w1 WS "B"
10 330.025866000 w1 WS "P"
10 330.026383000 w1 WS "Sc"
13 330.027080000 sched nready 34.000000
13 330.027080000 sched nsubmitted 38.000000
10 330.027583000 w1 WS "B"
10 330.027994000 w1 WS "B"
10 330.028395000 w1 WS "Fi"
10 330.029166000 w1 WS "B"
6 B22_236 WS B22_236 "0.000000 0.600000 0.400000"
6 B22_236_1 Ctx1 B22_236 "1.0 0.39 1.0"
6 B22_236_2 Ctx2 B22_236 ".0 1.0 .0"
6 B22_236_3 Ctx3 B22_236 "0.87 0.87 .0"
6 B22_236_4 Ctx4 B22_236 ".0 0.95 1.0"
6 B22_236_5 Ctx5 B22_236 ".0 .0 .0"
6 B22_236_6 Ctx6 B22_236 ".0 .0 0.5"
6 B22_236_7 Ctx7 B22_236 "0.41 0.41 0.41"
6 B22_236_8 Ctx8 B22_236 "1.0 .0 1.0"
6 B22_236_9 Ctx9 B22_236 ".0 .0 1.0"
10 330.029685000 w1 WS "B22_236"
20 330.029685000 w1 WS B22_236 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 261
10 330.130678000 w0 WS "B"
13 322.389173000 w0 gf 0.000000
13 330.130678000 w0 gf 0.000000
13 322.389173000 sched gft 0.000000
13 323.760431000 sched gft 0.000000
10 330.131380000 w0 WS "Po"
10 330.132123000 w0 WS "B"
10 330.134707000 w0 WS "P"
10 330.135317000 w0 WS "Sc"
13 330.136038000 sched nready 33.000000
13 330.136038000 sched nsubmitted 37.000000
10 330.136519000 w0 WS "B"
10 330.136939000 w0 WS "B"
10 330.137434000 w0 WS "Fi"
10 330.138393000 w0 WS "B"
6 B22_237 WS B22_237 "0.000000 0.600000 0.400000"
6 B22_237_1 Ctx1 B22_237 "1.0 0.39 1.0"
6 B22_237_2 Ctx2 B22_237 ".0 1.0 .0"
6 B22_237_3 Ctx3 B22_237 "0.87 0.87 .0"
6 B22_237_4 Ctx4 B22_237 ".0 0.95 1.0"
6 B22_237_5 Ctx5 B22_237 ".0 .0 .0"
6 B22_237_6 Ctx6 B22_237 ".0 .0 0.5"
6 B22_237_7 Ctx7 B22_237 "0.41 0.41 0.41"
6 B22_237_8 Ctx8 B22_237 "1.0 .0 1.0"
6 B22_237_9 Ctx9 B22_237 ".0 .0 1.0"
10 330.138914000 w0 WS "B22_237"
20 330.138914000 w0 WS B22_237 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 262
10 331.441857000 w5 WS "B"
13 323.767949000 w5 gf 0.000000
13 331.441857000 w5 gf 0.000000
13 323.767949000 sched gft 0.000000
13 323.768590000 sched gft 0.000000
10 331.442542000 w5 WS "Po"
10 331.443292000 w5 WS "B"
10 331.445583000 w5 WS "P"
10 331.446185000 w5 WS "Sc"
13 331.446881000 sched nready 32.000000
13 331.446881000 sched nsubmitted 36.000000
10 331.447417000 w5 WS "B"
10 331.447901000 w5 WS "B"
10 331.448316000 w5 WS "Fi"
10 331.449262000 w5 WS "B"
10 331.449373000 w4 WS "B"
13 323.776583000 w4 gf 0.000000
13 331.449373000 w4 gf 0.000000
13 323.776583000 sched gft 0.000000
13 329.946870000 sched gft 0.000000
13 329.949018000 sched gft 0.000000
6 B22_238 WS B22_238 "0.000000 0.600000 0.400000"
6 B22_238_1 Ctx1 B22_238 "1.0 0.39 1.0"
6 B22_238_2 Ctx2 B22_238 ".0 1.0 .0"
6 B22_238_3 Ctx3 B22_238 "0.87 0.87 .0"
6 B22_238_4 Ctx4 B22_238 ".0 0.95 1.0"
6 B22_238_5 Ctx5 B22_238 ".0 .0 .0"
6 B22_238_6 Ctx6 B22_238 ".0 .0 0.5"
6 B22_238_7 Ctx7 B22_238 "0.41 0.41 0.41"
6 B22_238_8 Ctx8 B22_238 "1.0 .0 1.0"
6 B22_238_9 Ctx9 B22_238 ".0 .0 1.0"
10 331.449845000 w5 WS "B22_238"
10 331.449935000 w4 WS "Po"
10 331.450774000 w4 WS "B"
20 331.449845000 w5 WS B22_238 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 263
10 331.453041000 w4 WS "P"
10 331.453558000 w4 WS "Sc"
13 331.454270000 sched nready 31.000000
13 331.454270000 sched nsubmitted 35.000000
10 331.454748000 w4 WS "B"
10 331.455154000 w4 WS "B"
10 331.455558000 w4 WS "Fi"
10 331.456376000 w4 WS "B"
6 B22_239 WS B22_239 "0.000000 0.600000 0.400000"
6 B22_239_1 Ctx1 B22_239 "1.0 0.39 1.0"
6 B22_239_2 Ctx2 B22_239 ".0 1.0 .0"
6 B22_239_3 Ctx3 B22_239 "0.87 0.87 .0"
6 B22_239_4 Ctx4 B22_239 ".0 0.95 1.0"
6 B22_239_5 Ctx5 B22_239 ".0 .0 .0"
6 B22_239_6 Ctx6 B22_239 ".0 .0 0.5"
6 B22_239_7 Ctx7 B22_239 "0.41 0.41 0.41"
6 B22_239_8 Ctx8 B22_239 "1.0 .0 1.0"
6 B22_239_9 Ctx9 B22_239 ".0 .0 1.0"
10 331.456863000 w4 WS "B22_239"
20 331.456863000 w4 WS B22_239 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 264
10 337.633830000 w2 WS "B"
13 329.956329000 w2 gf 0.000000
13 337.633830000 w2 gf 0.000000
13 329.956329000 sched gft 0.000000
10 337.634726000 w2 WS "Po"
10 337.635495000 w2 WS "B"
10 337.638130000 w2 WS "P"
10 337.638770000 w2 WS "Sc"
13 337.639669000 sched nready 30.000000
13 337.639669000 sched nsubmitted 34.000000
10 337.640035000 w3 WS "B"
13 329.957379000 w3 gf 0.000000
13 337.640035000 w3 gf 0.000000
13 329.957379000 sched gft 0.000000
13 330.022446000 sched gft 0.000000
10 337.640489000 w2 WS "B"
10 337.640620000 w3 WS "Po"
10 337.641060000 w2 WS "B"
10 337.641366000 w3 WS "B"
10 337.641504000 w2 WS "Fi"
10 337.642352000 w2 WS "B"
6 B22_240 WS B22_240 "0.000000 0.600000 0.400000"
6 B22_240_1 Ctx1 B22_240 "1.0 0.39 1.0"
6 B22_240_2 Ctx2 B22_240 ".0 1.0 .0"
6 B22_240_3 Ctx3 B22_240 "0.87 0.87 .0"
6 B22_240_4 Ctx4 B22_240 ".0 0.95 1.0"
6 B22_240_5 Ctx5 B22_240 ".0 .0 .0"
6 B22_240_6 Ctx6 B22_240 ".0 .0 0.5"
6 B22_240_7 Ctx7 B22_240 "0.41 0.41 0.41"
6 B22_240_8 Ctx8 B22_240 "1.0 .0 1.0"
6 B22_240_9 Ctx9 B22_240 ".0 .0 1.0"
10 337.642943000 w2 WS "B22_240"
10 337.643831000 w3 WS "P"
20 337.642943000 w2 WS B22_240 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 265
10 337.644464000 w3 WS "Sc"
13 337.645155000 sched nready 29.000000
13 337.645155000 sched nsubmitted 33.000000
10 337.645630000 w3 WS "B"
10 337.646047000 w3 WS "B"
10 337.646441000 w3 WS "Fi"
10 337.647346000 w3 WS "B"
6 B22_241 WS B22_241 "0.000000 0.600000 0.400000"
6 B22_241_1 Ctx1 B22_241 "1.0 0.39 1.0"
6 B22_241_2 Ctx2 B22_241 ".0 1.0 .0"
6 B22_241_3 Ctx3 B22_241 "0.87 0.87 .0"
6 B22_241_4 Ctx4 B22_241 ".0 0.95 1.0"
6 B22_241_5 Ctx5 B22_241 ".0 .0 .0"
6 B22_241_6 Ctx6 B22_241 ".0 .0 0.5"
6 B22_241_7 Ctx7 B22_241 "0.41 0.41 0.41"
6 B22_241_8 Ctx8 B22_241 "1.0 .0 1.0"
6 B22_241_9 Ctx9 B22_241 ".0 .0 1.0"
10 337.647827000 w3 WS "B22_241"
20 337.647827000 w3 WS B22_241 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 266
10 337.690947000 w1 WS "B"
13 330.029685000 w1 gf 0.000000
13 337.690947000 w1 gf 0.000000
13 330.029685000 sched gft 0.000000
13 330.130678000 sched gft 0.000000
10 337.691489000 w1 WS "Po"
10 337.692253000 w1 WS "B"
10 337.694385000 w1 WS "P"
10 337.694918000 w1 WS "Sc"
13 337.695518000 sched nready 28.000000
13 337.695518000 sched nsubmitted 32.000000
10 337.696020000 w1 WS "B"
10 337.696429000 w1 WS "B"
10 337.696834000 w1 WS "Fi"
10 337.697771000 w1 WS "B"
6 B22_242 WS B22_242 "0.000000 0.600000 0.400000"
6 B22_242_1 Ctx1 B22_242 "1.0 0.39 1.0"
6 B22_242_2 Ctx2 B22_242 ".0 1.0 .0"
6 B22_242_3 Ctx3 B22_242 "0.87 0.87 .0"
6 B22_242_4 Ctx4 B22_242 ".0 0.95 1.0"
6 B22_242_5 Ctx5 B22_242 ".0 .0 .0"
6 B22_242_6 Ctx6 B22_242 ".0 .0 0.5"
6 B22_242_7 Ctx7 B22_242 "0.41 0.41 0.41"
6 B22_242_8 Ctx8 B22_242 "1.0 .0 1.0"
6 B22_242_9 Ctx9 B22_242 ".0 .0 1.0"
10 337.698251000 w1 WS "B22_242"
20 337.698251000 w1 WS B22_242 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 267
10 337.804430000 w0 WS "B"
13 330.138914000 w0 gf 0.000000
13 337.804430000 w0 gf 0.000000
13 330.138914000 sched gft 0.000000
13 331.441857000 sched gft 0.000000
13 331.449373000 sched gft 0.000000
10 337.805378000 w0 WS "Po"
10 337.806269000 w0 WS "B"
10 337.808741000 w0 WS "P"
10 337.809279000 w0 WS "Sc"
13 337.809997000 sched nready 27.000000
13 337.809997000 sched nsubmitted 31.000000
10 337.810577000 w0 WS "B"
10 337.810999000 w0 WS "B"
10 337.811422000 w0 WS "Fi"
10 337.812261000 w0 WS "B"
6 B22_243 WS B22_243 "0.000000 0.600000 0.400000"
6 B22_243_1 Ctx1 B22_243 "1.0 0.39 1.0"
6 B22_243_2 Ctx2 B22_243 ".0 1.0 .0"
6 B22_243_3 Ctx3 B22_243 "0.87 0.87 .0"
6 B22_243_4 Ctx4 B22_243 ".0 0.95 1.0"
6 B22_243_5 Ctx5 B22_243 ".0 .0 .0"
6 B22_243_6 Ctx6 B22_243 ".0 .0 0.5"
6 B22_243_7 Ctx7 B22_243 "0.41 0.41 0.41"
6 B22_243_8 Ctx8 B22_243 "1.0 .0 1.0"
6 B22_243_9 Ctx9 B22_243 ".0 .0 1.0"
10 337.812767000 w0 WS "B22_243"
20 337.812767000 w0 WS B22_243 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 268
10 339.233655000 w5 WS "B"
13 331.449845000 w5 gf 0.000000
13 339.233655000 w5 gf 0.000000
13 331.449845000 sched gft 0.000000
10 339.234231000 w5 WS "Po"
10 339.235028000 w5 WS "B"
10 339.237562000 w5 WS "P"
10 339.238152000 w5 WS "Sc"
13 339.238770000 sched nready 26.000000
13 339.238770000 sched nsubmitted 30.000000
10 339.239256000 w5 WS "B"
10 339.239677000 w5 WS "B"
10 339.240078000 w5 WS "Fi"
10 339.240908000 w5 WS "B"
6 B22_244 WS B22_244 "0.000000 0.600000 0.400000"
6 B22_244_1 Ctx1 B22_244 "1.0 0.39 1.0"
6 B22_244_2 Ctx2 B22_244 ".0 1.0 .0"
6 B22_244_3 Ctx3 B22_244 "0.87 0.87 .0"
6 B22_244_4 Ctx4 B22_244 ".0 0.95 1.0"
6 B22_244_5 Ctx5 B22_244 ".0 .0 .0"
6 B22_244_6 Ctx6 B22_244 ".0 .0 0.5"
6 B22_244_7 Ctx7 B22_244 "0.41 0.41 0.41"
6 B22_244_8 Ctx8 B22_244 "1.0 .0 1.0"
6 B22_244_9 Ctx9 B22_244 ".0 .0 1.0"
10 339.241413000 w5 WS "B22_244"
20 339.241413000 w5 WS B22_244 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 269
10 339.246123000 w4 WS "B"
13 331.456863000 w4 gf 0.000000
13 339.246123000 w4 gf 0.000000
13 331.456863000 sched gft 0.000000
13 337.633830000 sched gft 0.000000
13 337.640035000 sched gft 0.000000
10 339.246762000 w4 WS "Po"
10 339.247552000 w4 WS "B"
10 339.249996000 w4 WS "P"
10 339.250550000 w4 WS "Sc"
13 339.251460000 sched nready 25.000000
13 339.251460000 sched nsubmitted 29.000000
10 339.252001000 w4 WS "B"
10 339.252414000 w4 WS "B"
10 339.252820000 w4 WS "Fi"
10 339.253707000 w4 WS "B"
6 B22_245 WS B22_245 "0.000000 0.600000 0.400000"
6 B22_245_1 Ctx1 B22_245 "1.0 0.39 1.0"
6 B22_245_2 Ctx2 B22_245 ".0 1.0 .0"
6 B22_245_3 Ctx3 B22_245 "0.87 0.87 .0"
6 B22_245_4 Ctx4 B22_245 ".0 0.95 1.0"
6 B22_245_5 Ctx5 B22_245 ".0 .0 .0"
6 B22_245_6 Ctx6 B22_245 ".0 .0 0.5"
6 B22_245_7 Ctx7 B22_245 "0.41 0.41 0.41"
6 B22_245_8 Ctx8 B22_245 "1.0 .0 1.0"
6 B22_245_9 Ctx9 B22_245 ".0 .0 1.0"
10 339.254210000 w4 WS "B22_245"
20 339.254210000 w4 WS B22_245 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 270
10 345.357105000 w2 WS "B"
13 337.642943000 w2 gf 0.000000
13 345.357105000 w2 gf 0.000000
13 337.642943000 sched gft 0.000000
10 345.357856000 w2 WS "Po"
10 345.358716000 w2 WS "B"
10 345.361076000 w2 WS "P"
10 345.361918000 w2 WS "Sc"
13 345.362701000 sched nready 24.000000
13 345.362701000 sched nsubmitted 28.000000
10 345.363233000 w2 WS "B"
10 345.363538000 w3 WS "B"
13 337.647827000 w3 gf 0.000000
13 345.363538000 w3 gf 0.000000
13 337.647827000 sched gft 0.000000
13 337.690947000 sched gft 0.000000
10 345.363650000 w2 WS "B"
10 345.364141000 w3 WS "Po"
10 345.364207000 w2 WS "Fi"
10 345.364989000 w3 WS "B"
10 345.365473000 w2 WS "B"
6 B22_246 WS B22_246 "0.000000 0.600000 0.400000"
6 B22_246_1 Ctx1 B22_246 "1.0 0.39 1.0"
6 B22_246_2 Ctx2 B22_246 ".0 1.0 .0"
6 B22_246_3 Ctx3 B22_246 "0.87 0.87 .0"
6 B22_246_4 Ctx4 B22_246 ".0 0.95 1.0"
6 B22_246_5 Ctx5 B22_246 ".0 .0 .0"
6 B22_246_6 Ctx6 B22_246 ".0 .0 0.5"
6 B22_246_7 Ctx7 B22_246 "0.41 0.41 0.41"
6 B22_246_8 Ctx8 B22_246 "1.0 .0 1.0"
6 B22_246_9 Ctx9 B22_246 ".0 .0 1.0"
10 345.366099000 w2 WS "B22_246"
10 345.367227000 w3 WS "P"
20 345.366099000 w2 WS B22_246 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 271
10 345.367819000 w3 WS "Sc"
13 345.368487000 sched nready 23.000000
13 345.368487000 sched nsubmitted 27.000000
10 345.368946000 w3 WS "B"
10 345.369350000 w3 WS "B"
10 345.369757000 w3 WS "Fi"
10 345.370621000 w3 WS "B"
6 B22_247 WS B22_247 "0.000000 0.600000 0.400000"
6 B22_247_1 Ctx1 B22_247 "1.0 0.39 1.0"
6 B22_247_2 Ctx2 B22_247 ".0 1.0 .0"
6 B22_247_3 Ctx3 B22_247 "0.87 0.87 .0"
6 B22_247_4 Ctx4 B22_247 ".0 0.95 1.0"
6 B22_247_5 Ctx5 B22_247 ".0 .0 .0"
6 B22_247_6 Ctx6 B22_247 ".0 .0 0.5"
6 B22_247_7 Ctx7 B22_247 "0.41 0.41 0.41"
6 B22_247_8 Ctx8 B22_247 "1.0 .0 1.0"
6 B22_247_9 Ctx9 B22_247 ".0 .0 1.0"
10 345.371100000 w3 WS "B22_247"
20 345.371100000 w3 WS B22_247 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 272
10 345.384958000 w1 WS "B"
13 337.698251000 w1 gf 0.000000
13 345.384958000 w1 gf 0.000000
13 337.698251000 sched gft 0.000000
13 337.804430000 sched gft 0.000000
10 345.385546000 w1 WS "Po"
10 345.386354000 w1 WS "B"
10 345.388937000 w1 WS "P"
10 345.389462000 w1 WS "Sc"
13 345.390448000 sched nready 22.000000
13 345.390448000 sched nsubmitted 26.000000
10 345.390921000 w1 WS "B"
10 345.391331000 w1 WS "B"
10 345.391740000 w1 WS "Fi"
10 345.392556000 w1 WS "B"
6 B22_248 WS B22_248 "0.000000 0.600000 0.400000"
6 B22_248_1 Ctx1 B22_248 "1.0 0.39 1.0"
6 B22_248_2 Ctx2 B22_248 ".0 1.0 .0"
6 B22_248_3 Ctx3 B22_248 "0.87 0.87 .0"
6 B22_248_4 Ctx4 B22_248 ".0 0.95 1.0"
6 B22_248_5 Ctx5 B22_248 ".0 .0 .0"
6 B22_248_6 Ctx6 B22_248 ".0 .0 0.5"
6 B22_248_7 Ctx7 B22_248 "0.41 0.41 0.41"
6 B22_248_8 Ctx8 B22_248 "1.0 .0 1.0"
6 B22_248_9 Ctx9 B22_248 ".0 .0 1.0"
10 345.393032000 w1 WS "B22_248"
20 345.393032000 w1 WS B22_248 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 273
10 345.523631000 w0 WS "B"
13 337.812767000 w0 gf 0.000000
13 345.523631000 w0 gf 0.000000
13 337.812767000 sched gft 0.000000
13 339.233655000 sched gft 0.000000
10 345.524232000 w0 WS "Po"
10 345.525002000 w0 WS "B"
10 345.527627000 w0 WS "P"
10 345.528252000 w0 WS "Sc"
13 345.528974000 sched nready 21.000000
13 345.528974000 sched nsubmitted 25.000000
10 345.529470000 w0 WS "B"
10 345.529890000 w0 WS "B"
10 345.530309000 w0 WS "Fi"
10 345.531172000 w0 WS "B"
6 B22_249 WS B22_249 "0.000000 0.600000 0.400000"
6 B22_249_1 Ctx1 B22_249 "1.0 0.39 1.0"
6 B22_249_2 Ctx2 B22_249 ".0 1.0 .0"
6 B22_249_3 Ctx3 B22_249 "0.87 0.87 .0"
6 B22_249_4 Ctx4 B22_249 ".0 0.95 1.0"
6 B22_249_5 Ctx5 B22_249 ".0 .0 .0"
6 B22_249_6 Ctx6 B22_249 ".0 .0 0.5"
6 B22_249_7 Ctx7 B22_249 "0.41 0.41 0.41"
6 B22_249_8 Ctx8 B22_249 "1.0 .0 1.0"
6 B22_249_9 Ctx9 B22_249 ".0 .0 1.0"
10 345.531710000 w0 WS "B22_249"
20 345.531710000 w0 WS B22_249 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 274
0.000000 0 0 0 -1 -1
10 346.906403000 w5 WS "B"
13 339.241413000 w5 gf 0.000000
13 346.906403000 w5 gf 0.000000
13 339.241413000 sched gft 0.000000
13 339.246123000 sched gft 0.000000
10 346.906991000 w5 WS "Po"
10 346.907830000 w5 WS "B"
10 346.910103000 w5 WS "P"
10 346.910768000 w5 WS "Sc"
13 346.911510000 sched nready 20.000000
13 346.911510000 sched nsubmitted 24.000000
10 346.912044000 w5 WS "B"
10 346.912454000 w5 WS "B"
10 346.912870000 w5 WS "Fi"
10 346.913403000 w4 WS "B"
13 339.254210000 w4 gf 0.000000
13 346.913403000 w4 gf 0.000000
13 339.254210000 sched gft 0.000000
13 345.357105000 sched gft 0.000000
13 345.363538000 sched gft 0.000000
10 346.913755000 w5 WS "B"
10 346.913975000 w4 WS "Po"
6 B22_250 WS B22_250 "0.000000 0.600000 0.400000"
6 B22_250_1 Ctx1 B22_250 "1.0 0.39 1.0"
6 B22_250_2 Ctx2 B22_250 ".0 1.0 .0"
6 B22_250_3 Ctx3 B22_250 "0.87 0.87 .0"
6 B22_250_4 Ctx4 B22_250 ".0 0.95 1.0"
6 B22_250_5 Ctx5 B22_250 ".0 .0 .0"
6 B22_250_6 Ctx6 B22_250 ".0 .0 0.5"
6 B22_250_7 Ctx7 B22_250 "0.41 0.41 0.41"
6 B22_250_8 Ctx8 B22_250 "1.0 .0 1.0"
6 B22_250_9 Ctx9 B22_250 ".0 .0 1.0"
10 346.914325000 w5 WS "B22_250"
10 346.914786000 w4 WS "B"
20 346.914325000 w5 WS B22_250 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 275
10 346.917120000 w4 WS "P"
10 346.917686000 w4 WS "Sc"
13 346.918322000 sched nready 19.000000
13 346.918322000 sched nsubmitted 23.000000
10 346.918785000 w4 WS "B"
10 346.919194000 w4 WS "B"
10 346.919594000 w4 WS "Fi"
10 346.920428000 w4 WS "B"
6 B22_251 WS B22_251 "0.000000 0.600000 0.400000"
6 B22_251_1 Ctx1 B22_251 "1.0 0.39 1.0"
6 B22_251_2 Ctx2 B22_251 ".0 1.0 .0"
6 B22_251_3 Ctx3 B22_251 "0.87 0.87 .0"
6 B22_251_4 Ctx4 B22_251 ".0 0.95 1.0"
6 B22_251_5 Ctx5 B22_251 ".0 .0 .0"
6 B22_251_6 Ctx6 B22_251 ".0 .0 0.5"
6 B22_251_7 Ctx7 B22_251 "0.41 0.41 0.41"
6 B22_251_8 Ctx8 B22_251 "1.0 .0 1.0"
6 B22_251_9 Ctx9 B22_251 ".0 .0 1.0"
10 346.920921000 w4 WS "B22_251"
20 346.920921000 w4 WS B22_251 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 276
10 353.043016000 w2 WS "B"
13 345.366099000 w2 gf 0.000000
13 353.043016000 w2 gf 0.000000
13 345.366099000 sched gft 0.000000
10 353.044097000 w2 WS "Po"
10 353.045328000 w2 WS "B"
10 353.048133000 w2 WS "P"
10 353.048655000 w3 WS "B"
13 345.371100000 w3 gf 0.000000
13 353.048655000 w3 gf 0.000000
13 345.371100000 sched gft 0.000000
13 345.384958000 sched gft 0.000000
10 353.048835000 w2 WS "Sc"
10 353.049200000 w3 WS "Po"
13 353.049796000 sched nready 18.000000
13 353.049796000 sched nsubmitted 22.000000
10 353.050087000 w3 WS "B"
10 353.050322000 w2 WS "B"
10 353.050744000 w2 WS "B"
10 353.051202000 w2 WS "Fi"
10 353.052177000 w2 WS "B"
10 353.052403000 w3 WS "P"
10 353.052994000 w3 WS "Sc"
6 B22_252 WS B22_252 "0.000000 0.600000 0.400000"
6 B22_252_1 Ctx1 B22_252 "1.0 0.39 1.0"
6 B22_252_2 Ctx2 B22_252 ".0 1.0 .0"
6 B22_252_3 Ctx3 B22_252 "0.87 0.87 .0"
6 B22_252_4 Ctx4 B22_252 ".0 0.95 1.0"
6 B22_252_5 Ctx5 B22_252 ".0 .0 .0"
6 B22_252_6 Ctx6 B22_252 ".0 .0 0.5"
6 B22_252_7 Ctx7 B22_252 "0.41 0.41 0.41"
6 B22_252_8 Ctx8 B22_252 "1.0 .0 1.0"
6 B22_252_9 Ctx9 B22_252 ".0 .0 1.0"
10 353.053069000 w2 WS "B22_252"
13 353.053812000 sched nready 17.000000
13 353.053812000 sched nsubmitted 21.000000
10 353.054315000 w1 WS "B"
13 345.393032000 w1 gf 0.000000
13 353.054315000 w1 gf 0.000000
13 345.393032000 sched gft 0.000000
13 345.523631000 sched gft 0.000000
10 353.054396000 w3 WS "B"
10 353.054828000 w3 WS "B"
20 353.053069000 w2 WS B22_252 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 277
10 353.054985000 w1 WS "Po"
10 353.055263000 w3 WS "Fi"
10 353.055833000 w1 WS "B"
10 353.056307000 w3 WS "B"
6 B22_253 WS B22_253 "0.000000 0.600000 0.400000"
6 B22_253_1 Ctx1 B22_253 "1.0 0.39 1.0"
6 B22_253_2 Ctx2 B22_253 ".0 1.0 .0"
6 B22_253_3 Ctx3 B22_253 "0.87 0.87 .0"
6 B22_253_4 Ctx4 B22_253 ".0 0.95 1.0"
6 B22_253_5 Ctx5 B22_253 ".0 .0 .0"
6 B22_253_6 Ctx6 B22_253 ".0 .0 0.5"
6 B22_253_7 Ctx7 B22_253 "0.41 0.41 0.41"
6 B22_253_8 Ctx8 B22_253 "1.0 .0 1.0"
6 B22_253_9 Ctx9 B22_253 ".0 .0 1.0"
10 353.056824000 w3 WS "B22_253"
20 353.056824000 w3 WS B22_253 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 278
10 353.058222000 w1 WS "P"
10 353.058772000 w1 WS "Sc"
13 353.059448000 sched nready 16.000000
13 353.059448000 sched nsubmitted 20.000000
10 353.059993000 w1 WS "B"
10 353.060400000 w1 WS "B"
10 353.060808000 w1 WS "Fi"
10 353.061699000 w1 WS "B"
6 B22_254 WS B22_254 "0.000000 0.600000 0.400000"
6 B22_254_1 Ctx1 B22_254 "1.0 0.39 1.0"
6 B22_254_2 Ctx2 B22_254 ".0 1.0 .0"
6 B22_254_3 Ctx3 B22_254 "0.87 0.87 .0"
6 B22_254_4 Ctx4 B22_254 ".0 0.95 1.0"
6 B22_254_5 Ctx5 B22_254 ".0 .0 .0"
6 B22_254_6 Ctx6 B22_254 ".0 .0 0.5"
6 B22_254_7 Ctx7 B22_254 "0.41 0.41 0.41"
6 B22_254_8 Ctx8 B22_254 "1.0 .0 1.0"
6 B22_254_9 Ctx9 B22_254 ".0 .0 1.0"
10 353.062226000 w1 WS "B22_254"
20 353.062226000 w1 WS B22_254 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 279
10 353.224138000 w0 WS "B"
13 345.531710000 w0 gf 0.000000
13 353.224138000 w0 gf 0.000000
13 345.531710000 sched gft 0.000000
13 346.906403000 sched gft 0.000000
13 346.913403000 sched gft 0.000000
10 353.224813000 w0 WS "Po"
10 353.225637000 w0 WS "B"
10 353.228303000 w0 WS "P"
10 353.228918000 w0 WS "Sc"
13 353.229638000 sched nready 15.000000
13 353.229638000 sched nsubmitted 19.000000
10 353.230114000 w0 WS "B"
10 353.230534000 w0 WS "B"
10 353.230954000 w0 WS "Fi"
10 353.231796000 w0 WS "B"
6 B22_255 WS B22_255 "0.000000 0.600000 0.400000"
6 B22_255_1 Ctx1 B22_255 "1.0 0.39 1.0"
6 B22_255_2 Ctx2 B22_255 ".0 1.0 .0"
6 B22_255_3 Ctx3 B22_255 "0.87 0.87 .0"
6 B22_255_4 Ctx4 B22_255 ".0 0.95 1.0"
6 B22_255_5 Ctx5 B22_255 ".0 .0 .0"
6 B22_255_6 Ctx6 B22_255 ".0 .0 0.5"
6 B22_255_7 Ctx7 B22_255 "0.41 0.41 0.41"
6 B22_255_8 Ctx8 B22_255 "1.0 .0 1.0"
6 B22_255_9 Ctx9 B22_255 ".0 .0 1.0"
10 353.232330000 w0 WS "B22_255"
20 353.232330000 w0 WS B22_255 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 280
10 354.581197000 w5 WS "B"
13 346.914325000 w5 gf 0.000000
13 354.581197000 w5 gf 0.000000
13 346.914325000 sched gft 0.000000
10 354.581723000 w5 WS "Po"
10 354.582558000 w5 WS "B"
10 354.584589000 w5 WS "P"
10 354.585146000 w5 WS "Sc"
13 354.585911000 sched nready 14.000000
13 354.585911000 sched nsubmitted 18.000000
10 354.586380000 w5 WS "B"
10 354.586806000 w5 WS "B"
10 354.587216000 w5 WS "Fi"
10 354.588166000 w5 WS "B"
10 354.588609000 w4 WS "B"
13 346.920921000 w4 gf 0.000000
13 354.588609000 w4 gf 0.000000
13 346.920921000 sched gft 0.000000
13 353.043016000 sched gft 0.000000
13 353.048655000 sched gft 0.000000
6 B23_ea WS B23_ea "0.000000 0.600000 0.400000"
6 B23_ea_1 Ctx1 B23_ea "1.0 0.39 1.0"
6 B23_ea_2 Ctx2 B23_ea ".0 1.0 .0"
6 B23_ea_3 Ctx3 B23_ea "0.87 0.87 .0"
6 B23_ea_4 Ctx4 B23_ea ".0 0.95 1.0"
6 B23_ea_5 Ctx5 B23_ea ".0 .0 .0"
6 B23_ea_6 Ctx6 B23_ea ".0 .0 0.5"
6 B23_ea_7 Ctx7 B23_ea "0.41 0.41 0.41"
6 B23_ea_8 Ctx8 B23_ea "1.0 .0 1.0"
6 B23_ea_9 Ctx9 B23_ea ".0 .0 1.0"
10 354.588787000 w5 WS "B23_ea"
10 354.589187000 w4 WS "Po"
10 354.590029000 w4 WS "B"
20 354.588787000 w5 WS B23_ea 131160
M1x8192x8_M1x8194x8_M3x3x8 168cba74 0000000000000000 281
10 354.592402000 w4 WS "P"
10 354.592968000 w4 WS "Sc"
13 354.593779000 sched nready 13.000000
13 354.593779000 sched nsubmitted 17.000000
10 354.594279000 w4 WS "B"
10 354.594692000 w4 WS "B"
10 354.595093000 w4 WS "Fi"
10 354.595871000 w4 WS "B"
6 B23_aa WS B23_aa "0.000000 0.600000 0.400000"
6 B23_aa_1 Ctx1 B23_aa "1.0 0.39 1.0"
6 B23_aa_2 Ctx2 B23_aa ".0 1.0 .0"
6 B23_aa_3 Ctx3 B23_aa "0.87 0.87 .0"
6 B23_aa_4 Ctx4 B23_aa ".0 0.95 1.0"
6 B23_aa_5 Ctx5 B23_aa ".0 .0 .0"
6 B23_aa_6 Ctx6 B23_aa ".0 .0 0.5"
6 B23_aa_7 Ctx7 B23_aa "0.41 0.41 0.41"
6 B23_aa_8 Ctx8 B23_aa "1.0 .0 1.0"
6 B23_aa_9 Ctx9 B23_aa ".0 .0 1.0"
10 354.596396000 w4 WS "B23_aa"
20 354.596396000 w4 WS B23_aa 196712
M1x8192x8_M2x8194x8_M3x3x8 6ccb5ec1 0000000000000000 282
10 354.708857000 w5 WS "B"
13 354.588787000 w5 gf 0.000000
13 354.708857000 w5 gf 0.000000
10 354.709391000 w5 WS "Po"
10 354.710139000 w5 WS "B"
10 354.712536000 w5 WS "P"
10 354.713033000 w5 WS "Sc"
13 354.713915000 sched nready 12.000000
13 354.713915000 sched nsubmitted 16.000000
10 354.714377000 w5 WS "B"
10 354.714787000 w5 WS "B"
10 354.715192000 w5 WS "Fi"
10 354.716068000 w5 WS "B"
6 B31_we WS B31_we "0.000000 0.600000 0.400000"
6 B31_we_1 Ctx1 B31_we "1.0 0.39 1.0"
6 B31_we_2 Ctx2 B31_we ".0 1.0 .0"
6 B31_we_3 Ctx3 B31_we "0.87 0.87 .0"
6 B31_we_4 Ctx4 B31_we ".0 0.95 1.0"
6 B31_we_5 Ctx5 B31_we ".0 .0 .0"
6 B31_we_6 Ctx6 B31_we ".0 .0 0.5"
6 B31_we_7 Ctx7 B31_we "0.41 0.41 0.41"
6 B31_we_8 Ctx8 B31_we "1.0 .0 1.0"
6 B31_we_9 Ctx9 B31_we ".0 .0 1.0"
10 354.716554000 w5 WS "B31_we"
20 354.716554000 w5 WS B31_we 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 284
10 354.718880000 w5 WS "B"
13 354.716554000 w5 gf 0.000000
13 354.718880000 w5 gf 0.000000
10 354.719335000 w5 WS "Po"
10 354.719941000 w5 WS "B"
10 354.721934000 w5 WS "P"
10 354.722420000 w5 WS "Sc"
13 354.723060000 sched nready 11.000000
13 354.723060000 sched nsubmitted 15.000000
10 354.723556000 w5 WS "B"
10 354.723958000 w5 WS "B"
10 354.724355000 w5 WS "Fi"
10 354.725508000 w5 WS "B"
6 B31_sw WS B31_sw "0.000000 0.600000 0.400000"
6 B31_sw_1 Ctx1 B31_sw "1.0 0.39 1.0"
6 B31_sw_2 Ctx2 B31_sw ".0 1.0 .0"
6 B31_sw_3 Ctx3 B31_sw "0.87 0.87 .0"
6 B31_sw_4 Ctx4 B31_sw ".0 0.95 1.0"
6 B31_sw_5 Ctx5 B31_sw ".0 .0 .0"
6 B31_sw_6 Ctx6 B31_sw ".0 .0 0.5"
6 B31_sw_7 Ctx7 B31_sw "0.41 0.41 0.41"
6 B31_sw_8 Ctx8 B31_sw "1.0 .0 1.0"
6 B31_sw_9 Ctx9 B31_sw ".0 .0 1.0"
10 354.725990000 w5 WS "B31_sw"
20 354.725990000 w5 WS B31_sw 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 285 0.000000 0 0
0 -1 -1
10 354.728052000 w5 WS "B"
13 354.725990000 w5 gf 0.000000
13 354.728052000 w5 gf 0.000000
10 354.728501000 w5 WS "Po"
10 354.729113000 w5 WS "B"
10 354.731071000 w5 WS "P"
10 354.731573000 w5 WS "Sc"
13 354.732166000 sched nready 10.000000
13 354.732166000 sched nsubmitted 14.000000
10 354.732620000 w5 WS "B"
10 354.733021000 w5 WS "B"
10 354.733415000 w5 WS "Fi"
10 354.734083000 w5 WS "B"
6 B31_so WS B31_so "0.000000 0.600000 0.400000"
6 B31_so_1 Ctx1 B31_so "1.0 0.39 1.0"
6 B31_so_2 Ctx2 B31_so ".0 1.0 .0"
6 B31_so_3 Ctx3 B31_so "0.87 0.87 .0"
6 B31_so_4 Ctx4 B31_so ".0 0.95 1.0"
6 B31_so_5 Ctx5 B31_so ".0 .0 .0"
6 B31_so_6 Ctx6 B31_so ".0 .0 0.5"
6 B31_so_7 Ctx7 B31_so "0.41 0.41 0.41"
6 B31_so_8 Ctx8 B31_so "1.0 .0 1.0"
6 B31_so_9 Ctx9 B31_so ".0 .0 1.0"
10 354.734571000 w5 WS "B31_so"
20 354.734571000 w5 WS B31_so 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 286
10 354.736743000 w5 WS "B"
13 354.734571000 w5 gf 0.000000
13 354.736743000 w5 gf 0.000000
10 354.737243000 w5 WS "Po"
10 354.737846000 w5 WS "B"
10 354.739560000 w5 WS "P"
10 354.740046000 w5 WS "Sc"
13 354.740502000 sched nready 9.000000
13 354.740502000 sched nsubmitted 13.000000
10 354.741003000 w5 WS "B"
10 354.741408000 w5 WS "B"
10 354.741803000 w5 WS "Fi"
10 354.742565000 w5 WS "B"
6 B31_aa WS B31_aa "0.000000 0.600000 0.400000"
6 B31_aa_1 Ctx1 B31_aa "1.0 0.39 1.0"
6 B31_aa_2 Ctx2 B31_aa ".0 1.0 .0"
6 B31_aa_3 Ctx3 B31_aa "0.87 0.87 .0"
6 B31_aa_4 Ctx4 B31_aa ".0 0.95 1.0"
6 B31_aa_5 Ctx5 B31_aa ".0 .0 .0"
6 B31_aa_6 Ctx6 B31_aa ".0 .0 0.5"
6 B31_aa_7 Ctx7 B31_aa "0.41 0.41 0.41"
6 B31_aa_8 Ctx8 B31_aa "1.0 .0 1.0"
6 B31_aa_9 Ctx9 B31_aa ".0 .0 1.0"
10 354.742999000 w5 WS "B31_aa"
20 354.742999000 w5 WS B31_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 287 0.000000 0 0
0 -1 -1
10 354.745075000 w5 WS "B"
13 354.742999000 w5 gf 0.000000
13 354.745075000 w5 gf 0.000000
10 354.745524000 w5 WS "Po"
10 354.746214000 w5 WS "B"
13 354.750711000 sched nready 10.000000
11 354.751810000 w5 WS Sc
12 354.753139000 w5 WS
10 354.754242000 w5 WS "P"
10 354.754741000 w5 WS "Sc"
13 354.755272000 sched nready 9.000000
13 354.755272000 sched nsubmitted 12.000000
10 354.755908000 w5 WS "B"
10 354.756309000 w5 WS "B"
10 354.756711000 w5 WS "Fi"
10 354.757391000 w5 WS "B"
6 B32_so WS B32_so "0.000000 0.600000 0.400000"
6 B32_so_1 Ctx1 B32_so "1.0 0.39 1.0"
6 B32_so_2 Ctx2 B32_so ".0 1.0 .0"
6 B32_so_3 Ctx3 B32_so "0.87 0.87 .0"
6 B32_so_4 Ctx4 B32_so ".0 0.95 1.0"
6 B32_so_5 Ctx5 B32_so ".0 .0 .0"
6 B32_so_6 Ctx6 B32_so ".0 .0 0.5"
6 B32_so_7 Ctx7 B32_so "0.41 0.41 0.41"
6 B32_so_8 Ctx8 B32_so "1.0 .0 1.0"
6 B32_so_9 Ctx9 B32_so ".0 .0 1.0"
10 354.757866000 w5 WS "B32_so"
20 354.757866000 w5 WS B32_so 131160
M8192x1x8_M8194x1x8_M3x3x8 a5e481fd 0000000000000000 289
10 354.860399000 w5 WS "B"
13 354.757866000 w5 gf 0.000000
13 354.860399000 w5 gf 0.000000
10 354.860886000 w5 WS "Po"
10 354.862788000 w5 WS "B"
10 354.867778000 w5 WS "P"
10 354.868282000 w5 WS "Sc"
13 354.869787000 sched nready 8.000000
13 354.869787000 sched nsubmitted 11.000000
10 354.871413000 w5 WS "B"
10 354.871862000 w5 WS "B"
10 354.872267000 w5 WS "Fi"
10 354.873814000 w5 WS "B"
6 B32_aa WS B32_aa "0.000000 0.600000 0.400000"
6 B32_aa_1 Ctx1 B32_aa "1.0 0.39 1.0"
6 B32_aa_2 Ctx2 B32_aa ".0 1.0 .0"
6 B32_aa_3 Ctx3 B32_aa "0.87 0.87 .0"
6 B32_aa_4 Ctx4 B32_aa ".0 0.95 1.0"
6 B32_aa_5 Ctx5 B32_aa ".0 .0 .0"
6 B32_aa_6 Ctx6 B32_aa ".0 .0 0.5"
6 B32_aa_7 Ctx7 B32_aa "0.41 0.41 0.41"
6 B32_aa_8 Ctx8 B32_aa "1.0 .0 1.0"
6 B32_aa_9 Ctx9 B32_aa ".0 .0 1.0"
10 354.874302000 w5 WS "B32_aa"
20 354.874302000 w5 WS B32_aa 196712
M8192x1x8_M8194x2x8_M3x3x8 5212cc39 0000000000000000 290
10 355.059721000 w5 WS "B"
13 354.874302000 w5 gf 0.000000
13 355.059721000 w5 gf 0.000000
10 355.060221000 w5 WS "Po"
10 355.060969000 w5 WS "B"
13 355.062947000 sched nready 9.000000
11 355.063433000 w5 WS Sc
12 355.064026000 w5 WS
10 355.065183000 w5 WS "P"
10 355.065685000 w5 WS "Sc"
13 355.066238000 sched nready 8.000000
13 355.066238000 sched nsubmitted 10.000000
10 355.066725000 w5 WS "B"
10 355.067134000 w5 WS "B"
10 355.067548000 w5 WS "Fi"
10 355.068426000 w5 WS "B"
6 B33_ea WS B33_ea "0.000000 0.600000 0.400000"
6 B33_ea_1 Ctx1 B33_ea "1.0 0.39 1.0"
6 B33_ea_2 Ctx2 B33_ea ".0 1.0 .0"
6 B33_ea_3 Ctx3 B33_ea "0.87 0.87 .0"
6 B33_ea_4 Ctx4 B33_ea ".0 0.95 1.0"
6 B33_ea_5 Ctx5 B33_ea ".0 .0 .0"
6 B33_ea_6 Ctx6 B33_ea ".0 .0 0.5"
6 B33_ea_7 Ctx7 B33_ea "0.41 0.41 0.41"
6 B33_ea_8 Ctx8 B33_ea "1.0 .0 1.0"
6 B33_ea_9 Ctx9 B33_ea ".0 .0 1.0"
10 355.068964000 w5 WS "B33_ea"
20 355.068964000 w5 WS B33_ea 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 292
10 355.071132000 w5 WS "B"
13 355.068964000 w5 gf 0.000000
13 355.071132000 w5 gf 0.000000
10 355.071597000 w5 WS "Po"
10 355.072147000 w5 WS "B"
10 355.074250000 w5 WS "P"
10 355.074737000 w5 WS "Sc"
13 355.075286000 sched nready 7.000000
13 355.075286000 sched nsubmitted 9.000000
10 355.075775000 w5 WS "B"
10 355.076176000 w5 WS "B"
10 355.076569000 w5 WS "Fi"
10 355.077540000 w5 WS "B"
6 B33_so WS B33_so "0.000000 0.600000 0.400000"
6 B33_so_1 Ctx1 B33_so "1.0 0.39 1.0"
6 B33_so_2 Ctx2 B33_so ".0 1.0 .0"
6 B33_so_3 Ctx3 B33_so "0.87 0.87 .0"
6 B33_so_4 Ctx4 B33_so ".0 0.95 1.0"
6 B33_so_5 Ctx5 B33_so ".0 .0 .0"
6 B33_so_6 Ctx6 B33_so ".0 .0 0.5"
6 B33_so_7 Ctx7 B33_so "0.41 0.41 0.41"
6 B33_so_8 Ctx8 B33_so "1.0 .0 1.0"
6 B33_so_9 Ctx9 B33_so ".0 .0 1.0"
10 355.078020000 w5 WS "B33_so"
20 355.078020000 w5 WS B33_so 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 293
10 355.079983000 w5 WS "B"
13 355.078020000 w5 gf 0.000000
13 355.079983000 w5 gf 0.000000
10 355.080435000 w5 WS "Po"
10 355.081038000 w5 WS "B"
10 355.082882000 w5 WS "P"
10 355.083366000 w5 WS "Sc"
13 355.083899000 sched nready 6.000000
13 355.083899000 sched nsubmitted 8.000000
10 355.084372000 w5 WS "B"
10 355.084772000 w5 WS "B"
10 355.085166000 w5 WS "Fi"
10 355.086316000 w5 WS "B"
6 B33_se WS B33_se "0.000000 0.600000 0.400000"
6 B33_se_1 Ctx1 B33_se "1.0 0.39 1.0"
6 B33_se_2 Ctx2 B33_se ".0 1.0 .0"
6 B33_se_3 Ctx3 B33_se "0.87 0.87 .0"
6 B33_se_4 Ctx4 B33_se ".0 0.95 1.0"
6 B33_se_5 Ctx5 B33_se ".0 .0 .0"
6 B33_se_6 Ctx6 B33_se ".0 .0 0.5"
6 B33_se_7 Ctx7 B33_se "0.41 0.41 0.41"
6 B33_se_8 Ctx8 B33_se "1.0 .0 1.0"
6 B33_se_9 Ctx9 B33_se ".0 .0 1.0"
10 355.086803000 w5 WS "B33_se"
20 355.086803000 w5 WS B33_se 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 294 0.000000 0 0
0 -1 -1
10 355.089046000 w5 WS "B"
13 355.086803000 w5 gf 0.000000
13 355.089046000 w5 gf 0.000000
10 355.089507000 w5 WS "Po"
10 355.090105000 w5 WS "B"
10 355.091850000 w5 WS "P"
10 355.092339000 w5 WS "Sc"
13 355.092859000 sched nready 5.000000
13 355.092859000 sched nsubmitted 7.000000
10 355.093392000 w5 WS "B"
10 355.093795000 w5 WS "B"
10 355.094192000 w5 WS "Fi"
10 355.094879000 w5 WS "B"
6 B33_aa WS B33_aa "0.000000 0.600000 0.400000"
6 B33_aa_1 Ctx1 B33_aa "1.0 0.39 1.0"
6 B33_aa_2 Ctx2 B33_aa ".0 1.0 .0"
6 B33_aa_3 Ctx3 B33_aa "0.87 0.87 .0"
6 B33_aa_4 Ctx4 B33_aa ".0 0.95 1.0"
6 B33_aa_5 Ctx5 B33_aa ".0 .0 .0"
6 B33_aa_6 Ctx6 B33_aa ".0 .0 0.5"
6 B33_aa_7 Ctx7 B33_aa "0.41 0.41 0.41"
6 B33_aa_8 Ctx8 B33_aa "1.0 .0 1.0"
6 B33_aa_9 Ctx9 B33_aa ".0 .0 1.0"
10 355.095303000 w5 WS "B33_aa"
20 355.095303000 w5 WS B33_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 295 0.000000 0 0
0 -1 -1
10 355.097243000 w5 WS "B"
13 355.095303000 w5 gf 0.000000
13 355.097243000 w5 gf 0.000000
10 355.097694000 w5 WS "Po"
10 355.098318000 w5 WS "B"
13 355.100059000 sched nready 6.000000
11 355.100459000 w5 WS Sc
12 355.100936000 w5 WS
10 355.102019000 w5 WS "P"
10 355.102537000 w5 WS "Sc"
13 355.103064000 sched nready 5.000000
13 355.103064000 sched nsubmitted 6.000000
10 355.103593000 w5 WS "B"
10 355.104053000 w5 WS "B"
10 355.104457000 w5 WS "Fi"
10 355.105818000 w5 WS "B"
6 B13 WS B13 "0.000000 0.600000 0.400000"
6 B13_1 Ctx1 B13 "1.0 0.39 1.0"
6 B13_2 Ctx2 B13 ".0 1.0 .0"
6 B13_3 Ctx3 B13 "0.87 0.87 .0"
6 B13_4 Ctx4 B13 ".0 0.95 1.0"
6 B13_5 Ctx5 B13 ".0 .0 .0"
6 B13_6 Ctx6 B13 ".0 .0 0.5"
6 B13_7 Ctx7 B13 "0.41 0.41 0.41"
6 B13_8 Ctx8 B13 "1.0 .0 1.0"
6 B13_9 Ctx9 B13 ".0 .0 1.0"
10 355.106417000 w5 WS "B13"
20 355.106417000 w5 WS B13 40
M1x1x8_M1x1x8_M1x1x8_M1x1x8_M1x1x8 ac71c29d 0000000000000000
21 0.000000 0 0 0 -1 -1
10 355.109806000 w5 WS "B"
13 355.106417000 w5 gf 0.000000
13 355.109806000 w5 gf 0.000000
10 355.110263000 w5 WS "Po"
10 355.111152000 w5 WS "B"
10 355.113351000 w5 WS "P"
10 355.113837000 w5 WS "Sc"
13 355.114424000 sched nready 4.000000
13 355.114424000 sched nsubmitted 5.000000
10 355.114947000 w5 WS "B"
10 355.115402000 w5 WS "B"
10 355.115796000 w5 WS "Fi"
10 355.117147000 w5 WS "B"
6 B11 WS B11 "0.000000 0.600000 0.400000"
6 B11_1 Ctx1 B11 "1.0 0.39 1.0"
6 B11_2 Ctx2 B11 ".0 1.0 .0"
6 B11_3 Ctx3 B11 "0.87 0.87 .0"
6 B11_4 Ctx4 B11 ".0 0.95 1.0"
6 B11_5 Ctx5 B11 ".0 .0 .0"
6 B11_6 Ctx6 B11 ".0 .0 0.5"
6 B11_7 Ctx7 B11 "0.41 0.41 0.41"
6 B11_8 Ctx8 B11 "1.0 .0 1.0"
6 B11_9 Ctx9 B11 ".0 .0 1.0"
10 355.117638000 w5 WS "B11"
20 355.117638000 w5 WS B11 40
13 0.000000 0 0 0 -1 -1
10 355.120107000 w5 WS "B"
13 355.117638000 w5 gf 0.000000
13 355.120107000 w5 gf 0.000000
10 355.120558000 w5 WS "Po"
10 355.121393000 w5 WS "B"
10 355.123428000 w5 WS "P"
10 355.123922000 w5 WS "Sc"
13 355.124520000 sched nready 3.000000
13 355.124520000 sched nsubmitted 4.000000
10 355.125199000 w5 WS "B"
10 355.125599000 w5 WS "B"
10 355.125993000 w5 WS "Fi"
10 355.126925000 w5 WS "B"
10 355.127354000 w5 WS "B12"
20 355.127354000 w5 WS B12 196608
M1x8192x8_M1x8192x8_M1x8192x8 5511c035 0000000000000000 24
10 355.389470000 w5 WS "B"
13 355.127354000 w5 gf 0.000000
13 355.389470000 w5 gf 0.000000
10 355.390009000 w5 WS "Po"
10 355.391139000 w5 WS "B"
10 355.393272000 w5 WS "P"
10 355.393802000 w5 WS "Sc"
13 355.394451000 sched nready 2.000000
13 355.394451000 sched nsubmitted 3.000000
10 355.395266000 w5 WS "B"
10 355.395678000 w5 WS "B"
10 355.396089000 w5 WS "Fi"
10 355.397341000 w5 WS "B"
10 355.397791000 w5 WS "B13"
20 355.397791000 w5 WS B13 40
288 0.000000 0 0 0 -1 -1
10 355.400386000 w5 WS "B"
13 355.397791000 w5 gf 0.000000
13 355.400386000 w5 gf 0.000000
10 355.400832000 w5 WS "Po"
10 355.401681000 w5 WS "B"
10 355.409624000 w5 WS "P"
10 355.410132000 w5 WS "Sc"
13 355.410677000 sched nready 1.000000
13 355.410677000 sched nsubmitted 2.000000
10 355.411130000 w5 WS "B"
10 355.411530000 w5 WS "B"
10 355.411942000 w5 WS "Fi"
10 355.412766000 w5 WS "B"
10 355.413207000 w5 WS "B12"
20 355.413207000 w5 WS B12 196608
M8192x1x8_M8192x1x8_M8192x1x8 ec48135f 0000000000000000 291
10 355.438326000 w5 WS "B"
13 355.413207000 w5 gf 0.000000
13 355.438326000 w5 gf 0.000000
10 355.438819000 w5 WS "Po"
10 355.439656000 w5 WS "B"
10 355.441439000 w5 WS "P"
10 355.441943000 w5 WS "Sc"
13 355.442522000 sched nready 0.000000
13 355.442522000 sched nsubmitted 1.000000
10 355.443044000 w5 WS "B"
10 355.443450000 w5 WS "B"
10 355.443862000 w5 WS "Fi"
10 355.444962000 w5 WS "B"
10 355.445397000 w5 WS "B13"
20 355.445397000 w5 WS B13 40
296 0.000000 0 0 0 -1 -1
10 355.447911000 w5 WS "B"
13 355.445397000 w5 gf 0.000000
13 355.447911000 w5 gf 0.000000
10 355.448359000 w5 WS "Po"
10 355.449104000 w5 WS "B"
10 355.451005000 w5 WS "P"
10 355.451503000 w5 WS "Sc"
10 355.452125000 w5 WS "Sl"
10 355.546223000 w4 WS "B"
13 354.596396000 w4 gf 0.000000
13 355.546223000 w4 gf 0.000000
10 355.546825000 w4 WS "Po"
10 355.547771000 w4 WS "B"
13 355.550617000 sched nready 1.000000
11 355.551344000 w4 WS Sc
12 355.552242000 w4 WS
13 355.553143000 sched nready 0.000000
13 355.553143000 sched nsubmitted 0.000000
10 355.553556000 w4 WS "P"
10 355.553733000 w5 WS "B"
10 355.554175000 w4 WS "Sc"
10 355.554267000 w5 WS "B"
10 355.554686000 w5 WS "Fi"
10 355.554779000 w4 WS "Sl"
10 355.555487000 w5 WS "B"
10 355.555947000 w5 WS "B12"
20 355.555947000 w5 WS B12 196608
M1x8192x8_M1x8192x8_M1x8192x8 5511c035 0000000000000000 283
10 355.738948000 w5 WS "B"
13 355.555947000 w5 gf 0.000000
13 355.738948000 w5 gf 0.000000
10 355.739496000 w5 WS "Po"
10 355.740140000 w5 WS "B"
10 355.742164000 w5 WS "P"
10 355.742715000 w5 WS "Sc"
10 355.743261000 w5 WS "Sl"
10 360.736093000 w2 WS "B"
13 353.053069000 w2 gf 0.000000
13 360.736093000 w2 gf 0.000000
13 353.053069000 sched gft 0.000000
13 353.054315000 sched gft 0.000000
10 360.736726000 w2 WS "Po"
10 360.738017000 w2 WS "B"
10 360.738750000 w3 WS "B"
13 353.056824000 w3 gf 0.000000
13 360.738750000 w3 gf 0.000000
13 353.056824000 sched gft 0.000000
10 360.739445000 w3 WS "Po"
10 360.740276000 w3 WS "B"
10 360.740965000 w2 WS "P"
10 360.741654000 w2 WS "Sc"
10 360.742224000 w2 WS "Sl"
10 360.742648000 w3 WS "P"
10 360.743291000 w3 WS "Sc"
10 360.743971000 w3 WS "Sl"
10 360.744493000 w1 WS "B"
13 353.062226000 w1 gf 0.000000
13 360.744493000 w1 gf 0.000000
13 353.062226000 sched gft 0.000000
13 353.224138000 sched gft 0.000000
10 360.745209000 w1 WS "Po"
10 360.746046000 w1 WS "B"
10 360.748189000 w1 WS "P"
10 360.748731000 w1 WS "Sc"
10 360.749306000 w1 WS "Sl"
10 360.920084000 w0 WS "B"
13 353.232330000 w0 gf 0.000000
13 360.920084000 w0 gf 0.000000
13 353.232330000 sched gft 0.000000
13 354.581197000 sched gft 0.000000
13 354.588609000 sched gft 0.000000
13 354.588787000 sched gft 0.000000
13 354.596396000 sched gft 0.000000
13 354.708857000 sched gft 0.000000
13 354.716554000 sched gft 0.000000
13 354.718880000 sched gft 0.000000
13 354.725990000 sched gft 0.000000
13 354.728052000 sched gft 0.000000
13 354.734571000 sched gft 0.000000
13 354.736743000 sched gft 0.000000
13 354.742999000 sched gft 0.000000
13 354.745075000 sched gft 0.000000
13 354.757866000 sched gft 0.000000
13 354.860399000 sched gft 0.000000
13 354.874302000 sched gft 0.000000
13 355.059721000 sched gft 0.000000
13 355.068964000 sched gft 0.000000
13 355.071132000 sched gft 0.000000
13 355.078020000 sched gft 0.000000
13 355.079983000 sched gft 0.000000
13 355.086803000 sched gft 0.000000
13 355.089046000 sched gft 0.000000
13 355.095303000 sched gft 0.000000
13 355.097243000 sched gft 0.000000
13 355.106417000 sched gft 0.000000
13 355.109806000 sched gft 0.000000
13 355.117638000 sched gft 0.000000
13 355.120107000 sched gft 0.000000
13 355.127354000 sched gft 0.000000
13 355.389470000 sched gft 0.000000
13 355.397791000 sched gft 0.000000
13 355.400386000 sched gft 0.000000
13 355.413207000 sched gft 0.000000
13 355.438326000 sched gft 0.000000
13 355.445397000 sched gft 0.000000
13 355.447911000 sched gft 0.000000
13 355.546223000 sched gft 0.000000
13 355.555947000 sched gft 0.000000
13 355.738948000 sched gft 0.000000
13 360.736093000 sched gft 0.000000
13 360.738750000 sched gft 0.000000
13 360.744493000 sched gft 0.000000
13 360.920084000 sched gft 0.000000
10 360.920725000 w0 WS "Po"
10 360.921503000 w0 WS "B"
10 360.927702000 w0 WS "P"
10 360.928305000 w0 WS "Sc"
10 360.928892000 w0 WS "Sl"
12 360.934304000 t4820 US
9 360.935796000 prog_event p "stop_profiling"
%EventDef PajeDefineContainerType 1
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineEventType 2
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineStateType 3
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineVariableType 4
% Alias string
% Type string
% Name string
%EndEventDef
%EventDef PajeDefineLinkType 5
% Alias string
% Type string
% StartContainerType string
% EndContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEntityValue 6
% Alias string
% Type string
% Name string
% Color color
%EndEventDef
%EventDef PajeCreateContainer 7
% Time date
% Alias string
% Type string
% Container string
% Name string
%EndEventDef
%EventDef PajeDestroyContainer 8
% Time date
% Name string
% Type string
%EndEventDef
%EventDef PajeNewEvent 9
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajeSetState 10
% Time date
% Container string
% Type string
% Value string
%EndEventDef
%EventDef PajePushState 11
% Time date
% Container string
% Type string
% Value string
%EndEventDef
%EventDef PajePopState 12
% Time date
% Container string
% Type string
%EndEventDef
%EventDef PajeSetVariable 13
% Time date
% Container string
% Type string
% Value double
%EndEventDef
%EventDef PajeAddVariable 14
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeSubVariable 15
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeStartLink 18
% Time date
% Type string
% Container string
% Value string
% StartContainer string
% Key string
%EndEventDef
%EventDef PajeEndLink 19
% Time date
% Type string
% Container string
% Value string
% EndContainer string
% Key string
%EndEventDef
%EventDef PajeSetState 20
% Time date
% Container string
% Type string
% Value string
% Size string
% Params string
% Footprint string
% Tag string
% JobId string
% SubmitOrder string
% GFlop string
% X string
% Y string
% Iteration string
% Subiteration string
%EndEventDef
%EventDef PajeSetState 21
% Time date
% Container string
% Type string
% Value string
% Size string
% Params string
% Footprint string
% Tag string
% JobId string
%EndEventDef
1 MPIP 0 "MPI Program"
1 P MPIP "Program"
1 Mn P "Memory Node"
1 T Mn "Thread"
1 UT P "User Thread"
1 Mm Mn "Memory Manager"
1 W T "Worker"
1 MPICt P "MPI Communication Thread"
1 Sc P "Scheduler State"
2 prog_event P "program event type"
2 pu P "Task Push"
2 po P "Task Pop"
2 register P "data registration"
2 unregister P "data unregistration"
2 user_event P "user event type"
2 thread_event T "thread event type"
2 user_user_event UT "user event type"
2 user_thread_event UT "thread event type"
2 MPIev MPICt "MPI event type"
3 S T "Thread State"
3 CtS MPICt "Communication Thread State"
3 Ctx1 W "InCtx1"
3 Ctx2 W "InCtx2"
3 Ctx3 W "InCtx3"
3 Ctx4 W "InCtx4"
3 Ctx5 W "InCtx5"
3 Ctx6 W "InCtx6"
3 Ctx7 W "InCtx7"
3 Ctx8 W "InCtx8"
3 Ctx9 W "InCtx9"
2 SI Mm "data state invalid"
2 SS Mm "data state shared"
2 SO Mm "data state owner"
2 WU Mm "data wont use"
2 Al Mm "Allocating Start"
2 rc Mm "Request Created"
2 AlE Mm "Allocating End"
2 Alr Mm "Allocating Async Start"
2 AlrE Mm "Allocating Async End"
2 Fe Mm "Free Start"
2 FeE Mm "Free End"
2 Wb Mm "WritingBack Start"
2 WbE Mm "WritingBack End"
2 DCo Mm "DriverCopy Start"
2 DCoE Mm "DriverCopy End"
2 DCoA Mm "DriverCopyAsync Start"
2 DCoAE Mm "DriverCopyAsync End"
3 MS Mm "Memory Node State"
4 nsubmitted Sc "Number of Submitted Uncompleted Tasks"
4 nready Sc "Number of Ready Tasks"
4 gft Sc "Total GFlops"
4 use Mm "Used (MB)"
4 bwi_mm Mm "Bandwidth In (MB/s)"
4 bwo_mm Mm "Bandwidth Out (MB/s)"
4 bwi_mpi MPICt "Bandwidth In (MB/s)"
4 bwo_mpi MPICt "Bandwidth Out (MB/s)"
4 gf W "GFlops"
6 I S Idle ".9 .1 .0"
6 In S Initializing "0.0 .7 1.0"
6 D S Deinitializing "0.0 .1 .7"
6 Fi S FetchingInput "1.0 .1 1.0"
6 Po S PushingOutput "0.1 1.0 1.0"
6 C S Callback ".0 .3 .8"
6 B S Overhead ".5 .18 .0"
6 E S Executing ".0 .6 .5"
6 Sc S Scheduling ".7 .36 .0"
6 Sl S Sleeping ".9 .1 .0"
6 P S Progressing ".1 .3 .1"
6 U S Unpartitioning ".0 .0 1.0"
6 H S Hypervisor ".5 .18 .0"
6 Bu S "Building task" ".5 .18 .0"
6 Su S "Submitting task" ".3 .09 .0"
6 Th S "Throttling task submission" ".8 .6 .6"
6 MD S "Decoding task for MPI" ".5 .18 .2"
6 MPr S "Preparing task for MPI" ".4 .14 .2"
6 MPo S "Post-processing task for MPI" ".3 .09 .2"
3 WS W "Worker State"
6 I WS Idle ".9 .1 .0"
6 In WS Initializing "0.0 .7 1.0"
6 D WS Deinitializing "0.0 .1 .7"
6 Fi WS FetchingInput "1.0 .1 1.0"
6 Po WS PushingOutput "0.1 1.0 1.0"
6 C WS Callback ".0 .3 .8"
6 B WS Overhead ".5 .18 .0"
6 E WS Executing ".0 .6 .5"
6 Sc WS Scheduling ".7 .36 .0"
6 Sl WS Sleeping ".9 .1 .0"
6 P WS Progressing ".1 .3 .1"
6 U WS Unpartitioning ".0 .0 1.0"
6 H WS Hypervisor ".5 .18 .0"
6 Bu WS "Building task" ".5 .18 .0"
6 Su WS "Submitting task" ".3 .09 .0"
6 Th WS "Throttling task submission" ".8 .6 .6"
3 US UT "User Thread State"
6 Bu US "Building task" ".5 .18 .0"
6 Su US "Submitting task" ".3 .09 .0"
6 C US "Callback" ".0 .3 .8"
6 Th US "Throttling task submission" ".8 .6 .6"
6 MD US "Decoding task for MPI" ".5 .18 .2"
6 MPr US "Preparing task for MPI" ".4 .14 .2"
6 MPo US "Post-processing task for MPI" ".3 .09 .2"
6 W US "Waiting task" ".9 .1 .0"
6 WA US "Waiting all tasks" ".9 .1 .0"
6 No US Nothing ".0 .0 .0"
6 P CtS Processing "0 0 0"
6 Pl CtS Polling "1.0 .5 0"
6 Dr CtS DriverRun ".1 .1 1.0"
6 Sl CtS Sleeping ".9 .1 .0"
6 UT CtS UserTesting ".2 .1 .6"
6 UW CtS UserWaiting ".4 .1 .3"
6 SdS CtS SendSubmitted "1.0 .1 1.0"
6 RvS CtS ReceiveSubmitted "0.1 1.0 1.0"
6 SdC CtS SendCompleted "1.0 .5 1.0"
6 RvC CtS ReceiveCompleted "0.5 1.0 1.0"
6 TD CtS "Testing Detached" ".0 .0 .6"
6 MT CtS "MPI Test" ".0 .0 .8"
6 Bu CtS "Building task" ".5 .18 .0"
6 Su CtS "Submitting task" ".3 .09 .0"
6 Th CtS "Throttling task submission" ".8 .6 .6"
6 C CtS "Callback" ".0 .3 .8"
6 I Ctx1 Idle ".9 .1 .0"
6 In Ctx1 Initializing "0.0 .7 1.0"
6 D Ctx1 Deinitializing "0.0 .1 .7"
6 Fi Ctx1 FetchingInput "1.0 .1 1.0"
6 Po Ctx1 PushingOutput "0.1 1.0 1.0"
6 C Ctx1 Callback ".0 .3 .8"
6 B Ctx1 Overhead ".5 .18 .0"
6 E Ctx1 Executing ".0 .6 .5"
6 Sc Ctx1 Scheduling ".7 .36 .0"
6 Sl Ctx1 Sleeping ".9 .1 .0"
6 P Ctx1 Progressing ".1 .3 .1"
6 U Ctx1 Unpartitioning ".0 .0 1.0"
6 H Ctx1 Hypervisor ".5 .18 .0"
6 I Ctx2 Idle ".9 .1 .0"
6 In Ctx2 Initializing "0.0 .7 1.0"
6 D Ctx2 Deinitializing "0.0 .1 .7"
6 Fi Ctx2 FetchingInput "1.0 .1 1.0"
6 Po Ctx2 PushingOutput "0.1 1.0 1.0"
6 C Ctx2 Callback ".0 .3 .8"
6 B Ctx2 Overhead ".5 .18 .0"
6 E Ctx2 Executing ".0 .6 .5"
6 Sc Ctx2 Scheduling ".7 .36 .0"
6 Sl Ctx2 Sleeping ".9 .1 .0"
6 P Ctx2 Progressing ".1 .3 .1"
6 U Ctx2 Unpartitioning ".0 .0 1.0"
6 H Ctx2 Hypervisor ".5 .18 .0"
6 I Ctx3 Idle ".9 .1 .0"
6 In Ctx3 Initializing "0.0 .7 1.0"
6 D Ctx3 Deinitializing "0.0 .1 .7"
6 Fi Ctx3 FetchingInput "1.0 .1 1.0"
6 Po Ctx3 PushingOutput "0.1 1.0 1.0"
6 C Ctx3 Callback ".0 .3 .8"
6 B Ctx3 Overhead ".5 .18 .0"
6 E Ctx3 Executing ".0 .6 .5"
6 Sc Ctx3 Scheduling ".7 .36 .0"
6 Sl Ctx3 Sleeping ".9 .1 .0"
6 P Ctx3 Progressing ".1 .3 .1"
6 U Ctx3 Unpartitioning ".0 .0 1.0"
6 H Ctx3 Hypervisor ".5 .18 .0"
6 I Ctx4 Idle ".9 .1 .0"
6 In Ctx4 Initializing "0.0 .7 1.0"
6 D Ctx4 Deinitializing "0.0 .1 .7"
6 Fi Ctx4 FetchingInput "1.0 .1 1.0"
6 Po Ctx4 PushingOutput "0.1 1.0 1.0"
6 C Ctx4 Callback ".0 .3 .8"
6 B Ctx4 Overhead ".5 .18 .0"
6 E Ctx4 Executing ".0 .6 .5"
6 Sc Ctx4 Scheduling ".7 .36 .0"
6 Sl Ctx4 Sleeping ".9 .1 .0"
6 P Ctx4 Progressing ".1 .3 .1"
6 U Ctx4 Unpartitioning ".0 .0 1.0"
6 H Ctx4 Hypervisor ".5 .18 .0"
6 I Ctx5 Idle ".9 .1 .0"
6 In Ctx5 Initializing "0.0 .7 1.0"
6 D Ctx5 Deinitializing "0.0 .1 .7"
6 Fi Ctx5 FetchingInput "1.0 .1 1.0"
6 Po Ctx5 PushingOutput "0.1 1.0 1.0"
6 C Ctx5 Callback ".0 .3 .8"
6 B Ctx5 Overhead ".5 .18 .0"
6 E Ctx5 Executing ".0 .6 .5"
6 Sc Ctx5 Scheduling ".7 .36 .0"
6 Sl Ctx5 Sleeping ".9 .1 .0"
6 P Ctx5 Progressing ".1 .3 .1"
6 U Ctx5 Unpartitioning ".0 .0 1.0"
6 H Ctx5 Hypervisor ".5 .18 .0"
6 I Ctx6 Idle ".9 .1 .0"
6 In Ctx6 Initializing "0.0 .7 1.0"
6 D Ctx6 Deinitializing "0.0 .1 .7"
6 Fi Ctx6 FetchingInput "1.0 .1 1.0"
6 Po Ctx6 PushingOutput "0.1 1.0 1.0"
6 C Ctx6 Callback ".0 .3 .8"
6 B Ctx6 Overhead ".5 .18 .0"
6 E Ctx6 Executing ".0 .6 .5"
6 Sc Ctx6 Scheduling ".7 .36 .0"
6 Sl Ctx6 Sleeping ".9 .1 .0"
6 P Ctx6 Progressing ".1 .3 .1"
6 U Ctx6 Unpartitioning ".0 .0 1.0"
6 H Ctx6 Hypervisor ".5 .18 .0"
6 I Ctx7 Idle ".9 .1 .0"
6 In Ctx7 Initializing "0.0 .7 1.0"
6 D Ctx7 Deinitializing "0.0 .1 .7"
6 Fi Ctx7 FetchingInput "1.0 .1 1.0"
6 Po Ctx7 PushingOutput "0.1 1.0 1.0"
6 C Ctx7 Callback ".0 .3 .8"
6 B Ctx7 Overhead ".5 .18 .0"
6 E Ctx7 Executing ".0 .6 .5"
6 Sc Ctx7 Scheduling ".7 .36 .0"
6 Sl Ctx7 Sleeping ".9 .1 .0"
6 P Ctx7 Progressing ".1 .3 .1"
6 U Ctx7 Unpartitioning ".0 .0 1.0"
6 H Ctx7 Hypervisor ".5 .18 .0"
6 I Ctx8 Idle ".9 .1 .0"
6 In Ctx8 Initializing "0.0 .7 1.0"
6 D Ctx8 Deinitializing "0.0 .1 .7"
6 Fi Ctx8 FetchingInput "1.0 .1 1.0"
6 Po Ctx8 PushingOutput "0.1 1.0 1.0"
6 C Ctx8 Callback ".0 .3 .8"
6 B Ctx8 Overhead ".5 .18 .0"
6 E Ctx8 Executing ".0 .6 .5"
6 Sc Ctx8 Scheduling ".7 .36 .0"
6 Sl Ctx8 Sleeping ".9 .1 .0"
6 P Ctx8 Progressing ".1 .3 .1"
6 U Ctx8 Unpartitioning ".0 .0 1.0"
6 H Ctx8 Hypervisor ".5 .18 .0"
6 I Ctx9 Idle ".9 .1 .0"
6 In Ctx9 Initializing "0.0 .7 1.0"
6 D Ctx9 Deinitializing "0.0 .1 .7"
6 Fi Ctx9 FetchingInput "1.0 .1 1.0"
6 Po Ctx9 PushingOutput "0.1 1.0 1.0"
6 C Ctx9 Callback ".0 .3 .8"
6 B Ctx9 Overhead ".5 .18 .0"
6 E Ctx9 Executing ".0 .6 .5"
6 Sc Ctx9 Scheduling ".7 .36 .0"
6 Sl Ctx9 Sleeping ".9 .1 .0"
6 P Ctx9 Progressing ".1 .3 .1"
6 U Ctx9 Unpartitioning ".0 .0 1.0"
6 H Ctx9 Hypervisor ".5 .18 .0"
6 A MS Allocating ".4 .1 .0"
6 Ar MS AllocatingReuse ".1 .1 .8"
6 F MS Freeing ".6 .3 .0"
6 W MS WritingBack ".0 .0 .5"
6 Wa MS WritingBackAsync ".0 .0 .4"
6 R MS Reclaiming ".0 .1 .6"
6 Co MS DriverCopy ".3 .5 .1"
6 CoA MS DriverCopyAsync ".1 .3 .1"
6 No MS Nothing ".0 .0 .0"
5 MPIL MPIP MPICt MPICt "MPI communication"
5 F P Mm Mm "Intra-node data Fetch"
5 PF P Mm Mm "Intra-node data PreFetch"
5 IF P Mm Mm "Intra-node data IdleFetch"
5 WSL P W W "Work steal"
7 0.0 MPIroot MPIP 0 root
7 0.0 p P MPIroot program
7 0.0 sched Sc p scheduler
13 0.0 sched nsubmitted 0.0
13 0.0 sched nready 0.0
13 0.0 sched gft 0.0
7 0.000000000 mn0 Mn p MEMNODE0
7 0.000000000 mm0 Mm mn0 MEMMANAGER0
13 0.000000000 mm0 use 0.0
13 0.000000000 mm0 bwi_mm 0.0
13 0.000000000 mm0 bwo_mm 0.0
9 1.713816000 prog_event p "start_profiling"
7 1.719079000 t4900 UT p UserThread4900
11 1.719079000 t4900 US Bu
12 1.723778000 t4900 US
11 1.727375000 t4900 US Su
13 1.729802000 sched nsubmitted 1.000000
13 1.741090000 sched nready 1.000000
9 1.741090000 pu p 1
12 1.750031000 t4900 US
11 1.750928000 t4900 US Bu
12 1.751715000 t4900 US
11 1.753905000 t4900 US Su
13 1.754454000 sched nsubmitted 2.000000
13 1.755969000 sched nready 0.000000
13 1.755969000 sched nsubmitted 1.000000
9 1.755969000 po p 1
13 1.756568000 sched nready 1.000000
9 1.756568000 pu p 2
10 1.758845000 w1 WS "Fi"
12 1.759259000 t4900 US
13 1.759619000 sched nready 0.000000
13 1.759619000 sched nsubmitted 0.000000
9 1.759619000 po p 2
11 1.759822000 t4900 US Bu
12 1.760432000 t4900 US
10 1.761243000 w2 WS "Fi"
11 1.761286000 t4900 US Su
13 1.761890000 sched nsubmitted 1.000000
13 1.763725000 sched nready 1.000000
9 1.763725000 pu p 3
6 send/recv:NO WS send/recv:NO "0.000000 0.600000 0.400000"
6 send/recv:NO_1 Ctx1 send/recv:NO "1.0 0.39 1.0"
6 send/recv:NO_2 Ctx2 send/recv:NO ".0 1.0 .0"
6 send/recv:NO_3 Ctx3 send/recv:NO "0.87 0.87 .0"
6 send/recv:NO_4 Ctx4 send/recv:NO ".0 0.95 1.0"
6 send/recv:NO_5 Ctx5 send/recv:NO ".0 .0 .0"
6 send/recv:NO_6 Ctx6 send/recv:NO ".0 .0 0.5"
6 send/recv:NO_7 Ctx7 send/recv:NO "0.41 0.41 0.41"
6 send/recv:NO_8 Ctx8 send/recv:NO "1.0 .0 1.0"
6 send/recv:NO_9 Ctx9 send/recv:NO ".0 .0 1.0"
10 1.769699000 w2 WS "send/recv:NO"
6 send/recv:NW WS send/recv:NW "0.000000 0.600000 0.400000"
6 send/recv:NW_1 Ctx1 send/recv:NW "1.0 0.39 1.0"
6 send/recv:NW_2 Ctx2 send/recv:NW ".0 1.0 .0"
6 send/recv:NW_3 Ctx3 send/recv:NW "0.87 0.87 .0"
6 send/recv:NW_4 Ctx4 send/recv:NW ".0 0.95 1.0"
6 send/recv:NW_5 Ctx5 send/recv:NW ".0 .0 .0"
6 send/recv:NW_6 Ctx6 send/recv:NW ".0 .0 0.5"
6 send/recv:NW_7 Ctx7 send/recv:NW "0.41 0.41 0.41"
6 send/recv:NW_8 Ctx8 send/recv:NW "1.0 .0 1.0"
6 send/recv:NW_9 Ctx9 send/recv:NW ".0 .0 1.0"
10 1.769754000 w1 WS "send/recv:NW"
12 1.770605000 t4900 US
13 1.770847000 sched nready 0.000000
13 1.770847000 sched nsubmitted 0.000000
9 1.770847000 po p 3
11 1.771282000 t4900 US Bu
12 1.771992000 t4900 US
10 1.772503000 w3 WS "Fi"
11 1.772747000 t4900 US Su
13 1.773407000 sched nsubmitted 1.000000
20 1.769699000 w2 WS send/recv:NO 537198640
M8194x1x8_M8194x8194x8 b582fff9 0000000000000000 2 2
0.000000 0 0 -1 -1
20 1.769754000 w1 WS send/recv:NW 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 1 1
0.000000 0 0 -1 -1
10 1.774174000 t4914 S E
10 1.774301000 t4913 S E
13 1.775128000 sched nready 1.000000
9 1.775128000 pu p 4
10 1.775444000 t4913 S B
6 send/recv:NE WS send/recv:NE "0.000000 0.600000 0.400000"
6 send/recv:NE_1 Ctx1 send/recv:NE "1.0 0.39 1.0"
6 send/recv:NE_2 Ctx2 send/recv:NE ".0 1.0 .0"
6 send/recv:NE_3 Ctx3 send/recv:NE "0.87 0.87 .0"
6 send/recv:NE_4 Ctx4 send/recv:NE ".0 0.95 1.0"
6 send/recv:NE_5 Ctx5 send/recv:NE ".0 .0 .0"
6 send/recv:NE_6 Ctx6 send/recv:NE ".0 .0 0.5"
6 send/recv:NE_7 Ctx7 send/recv:NE "0.41 0.41 0.41"
6 send/recv:NE_8 Ctx8 send/recv:NE "1.0 .0 1.0"
6 send/recv:NE_9 Ctx9 send/recv:NE ".0 .0 1.0"
10 1.775562000 w3 WS "send/recv:NE"
20 1.775562000 w3 WS send/recv:NE 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 3 3
0.000000 0 0 -1 -1
10 1.792279000 t4915 S E
10 1.793134000 t4915 S B
10 1.793454000 w1 WS "I"
13 1.769754000 w1 gf 0.000000
12 1.793609000 t4900 US
11 1.794453000 t4900 US Bu
13 1.794648000 sched nready 0.000000
13 1.794648000 sched nsubmitted 0.000000
9 1.794648000 po p 4
10 1.794933000 w3 WS "I"
13 1.775562000 w3 gf 0.000000
12 1.795120000 t4900 US
10 1.796334000 w4 WS "Fi"
11 1.797298000 t4900 US Su
13 1.797815000 sched nsubmitted 1.000000
13 1.799501000 sched nready 1.000000
9 1.799501000 pu p 5
10 1.799553000 w4 WS "send/recv:NW"
12 1.801543000 t4900 US
20 1.799553000 w4 WS send/recv:NW 537198640
M1x8194x8_M8194x8194x8 bc5be9a3 0000000000000000 4 4
0.000000 0 0 -1 -1
10 1.801763000 t4916 S E
11 1.802162000 t4900 US Bu
12 1.802792000 t4900 US
13 1.802831000 sched nready 0.000000
13 1.802831000 sched nsubmitted 0.000000
9 1.802831000 po p 5
11 1.803629000 t4900 US Su
13 1.804321000 sched nsubmitted 1.000000
10 1.805175000 w5 WS "Fi"
13 1.807013000 sched nready 1.000000
9 1.807013000 pu p 6
10 1.809603000 w5 WS "send/recv:NW"
20 1.809603000 w5 WS send/recv:NW 537198640
M1x8194x8_M8194x8194x8 bc5be9a3 0000000000000000 5 5
0.000000 0 0 -1 -1
10 1.812872000 t4917 S E
13 1.813596000 sched nready 0.000000
13 1.813596000 sched nsubmitted 0.000000
9 1.813596000 po p 6
12 1.814178000 t4900 US
11 1.814962000 t4900 US Bu
10 1.815408000 w0 WS "Fi"
12 1.815858000 t4900 US
11 1.816502000 t4900 US Su
13 1.816996000 sched nsubmitted 1.000000
13 1.818596000 sched nready 1.000000
9 1.818596000 pu p 7
10 1.818766000 w0 WS "send/recv:NE"
20 1.818766000 w0 WS send/recv:NE 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 6 6
0.000000 0 0 -1 -1
10 1.821184000 t4912 S E
10 1.821948000 t4912 S B
10 1.823618000 w0 WS "I"
13 1.818766000 w0 gf 0.000000
13 1.824027000 sched nready 0.000000
13 1.824027000 sched nsubmitted 0.000000
9 1.824027000 po p 7
12 1.824935000 t4900 US
10 1.825513000 t4914 S B
10 1.825608000 w1 WS "Fi"
11 1.825852000 t4900 US Bu
12 1.826532000 t4900 US
10 1.827588000 w2 WS "I"
13 1.769699000 w2 gf 0.000000
13 0.000000000 sched gft 0.000000
13 1.769699000 sched gft 0.000000
13 1.769754000 sched gft 0.000000
13 1.775562000 sched gft 0.000000
10 1.828021000 w1 WS "send/recv:NO"
11 1.828863000 t4900 US Su
13 1.829446000 sched nsubmitted 1.000000
20 1.828021000 w1 WS send/recv:NO 537198640
M8194x1x8_M8194x8194x8 b582fff9 0000000000000000 7 7
0.000000 0 0 -1 -1
10 1.829798000 t4913 S E
13 1.831413000 sched nready 1.000000
9 1.831413000 pu p 8
12 1.833700000 t4900 US
13 1.834392000 sched nready 0.000000
13 1.834392000 sched nsubmitted 0.000000
9 1.834392000 po p 8
11 1.834633000 t4900 US Bu
12 1.835440000 t4900 US
10 1.835810000 w2 WS "Fi"
11 1.836089000 t4900 US Su
13 1.837064000 sched nsubmitted 1.000000
10 1.838309000 w2 WS "send/recv:NW"
20 1.838309000 w2 WS send/recv:NW 537133096
M1x1x8_M8194x8194x8 23e6d946 0000000000000000 8 8
0.000000 0 0 -1 -1
10 1.839602000 t4914 S E
13 1.839907000 sched nready 1.000000
9 1.839907000 pu p 9
10 1.840141000 t4914 S B
10 1.841194000 w2 WS "I"
13 1.827588000 w2 gf 0.000000
13 1.845898000 sched nready 0.000000
13 1.845898000 sched nsubmitted 0.000000
9 1.845898000 po p 9
12 1.846009000 t4900 US
11 1.846723000 t4900 US Bu
10 1.847266000 w3 WS "Fi"
12 1.847574000 t4900 US
11 1.848273000 t4900 US Su
13 1.848828000 sched nsubmitted 1.000000
6 B11_nw WS B11_nw "0.000000 0.600000 0.400000"
6 B11_nw_1 Ctx1 B11_nw "1.0 0.39 1.0"
6 B11_nw_2 Ctx2 B11_nw ".0 1.0 .0"
6 B11_nw_3 Ctx3 B11_nw "0.87 0.87 .0"
6 B11_nw_4 Ctx4 B11_nw ".0 0.95 1.0"
6 B11_nw_5 Ctx5 B11_nw ".0 .0 .0"
6 B11_nw_6 Ctx6 B11_nw ".0 .0 0.5"
6 B11_nw_7 Ctx7 B11_nw "0.41 0.41 0.41"
6 B11_nw_8 Ctx8 B11_nw "1.0 .0 1.0"
6 B11_nw_9 Ctx9 B11_nw ".0 .0 1.0"
10 1.849628000 w3 WS "B11_nw"
13 1.851043000 sched nready 1.000000
9 1.851043000 pu p 10
20 1.849628000 w3 WS B11_nw 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 9 9 0.000000 0
0 -1 -1
10 1.851441000 t4915 S E
10 1.852327000 t4915 S B
12 1.852868000 t4900 US
18 1.853049000 WSL p 0 w4 steal_0
19 1.853049001 WSL p 0 w2 steal_0
10 1.853468000 w3 WS "I"
13 1.794933000 w3 gf 0.000000
13 1.849628000 w3 gf 0.000000
11 1.853565000 t4900 US Bu
13 1.853634000 sched nready 0.000000
13 1.853634000 sched nsubmitted 0.000000
9 1.853634000 po p 10
12 1.854325000 t4900 US
10 1.855289000 w2 WS "Fi"
11 1.856591000 t4900 US Su
13 1.857233000 sched nsubmitted 1.000000
6 B11_no WS B11_no "0.000000 0.600000 0.400000"
6 B11_no_1 Ctx1 B11_no "1.0 0.39 1.0"
6 B11_no_2 Ctx2 B11_no ".0 1.0 .0"
6 B11_no_3 Ctx3 B11_no "0.87 0.87 .0"
6 B11_no_4 Ctx4 B11_no ".0 0.95 1.0"
6 B11_no_5 Ctx5 B11_no ".0 .0 .0"
6 B11_no_6 Ctx6 B11_no ".0 .0 0.5"
6 B11_no_7 Ctx7 B11_no "0.41 0.41 0.41"
6 B11_no_8 Ctx8 B11_no "1.0 .0 1.0"
6 B11_no_9 Ctx9 B11_no ".0 .0 1.0"
10 1.857648000 w2 WS "B11_no"
20 1.857648000 w2 WS B11_no 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 10 10
0.000000 0 0 -1 -1
10 1.859243000 t4914 S E
10 1.859801000 t4914 S B
10 1.860794000 w2 WS "I"
13 1.841194000 w2 gf 0.000000
13 1.857648000 w2 gf 0.000000
12 1.861547000 t4900 US
11 1.862304000 t4900 US Bu
12 1.862907000 t4900 US
11 1.863755000 t4900 US Su
13 1.864288000 sched nsubmitted 2.000000
13 1.866188000 sched nready 1.000000
9 1.866188000 pu p 12
18 1.867867000 WSL p 0 w5 steal_1
19 1.867867001 WSL p 0 w2 steal_1
10 1.867964000 t4913 S B
12 1.868039000 t4900 US
13 1.868109000 sched nready 0.000000
13 1.868109000 sched nsubmitted 1.000000
9 1.868109000 po p 12
11 1.868837000 t4900 US Bu
10 1.869405000 w1 WS "I"
13 1.793454000 w1 gf 0.000000
13 1.793454000 sched gft 0.000000
12 1.869568000 t4900 US
10 1.869620000 w2 WS "Fi"
11 1.870330000 t4900 US Su
13 1.870934000 sched nsubmitted 2.000000
6 B11_aa WS B11_aa "0.000000 0.600000 0.400000"
6 B11_aa_1 Ctx1 B11_aa "1.0 0.39 1.0"
6 B11_aa_2 Ctx2 B11_aa ".0 1.0 .0"
6 B11_aa_3 Ctx3 B11_aa "0.87 0.87 .0"
6 B11_aa_4 Ctx4 B11_aa ".0 0.95 1.0"
6 B11_aa_5 Ctx5 B11_aa ".0 .0 .0"
6 B11_aa_6 Ctx6 B11_aa ".0 .0 0.5"
6 B11_aa_7 Ctx7 B11_aa "0.41 0.41 0.41"
6 B11_aa_8 Ctx8 B11_aa "1.0 .0 1.0"
6 B11_aa_9 Ctx9 B11_aa ".0 .0 1.0"
10 1.872051000 w2 WS "B11_aa"
20 1.872051000 w2 WS B11_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 12 12 0.000000 0
0 -1 -1
10 1.873738000 t4914 S E
10 1.874429000 t4914 S B
12 1.874484000 t4900 US
11 1.875155000 t4900 US Bu
10 1.875375000 w2 WS "I"
13 1.860794000 w2 gf 0.000000
13 1.872051000 w2 gf 0.000000
12 1.875837000 t4900 US
11 1.878075000 t4900 US Su
13 1.878944000 sched nsubmitted 3.000000
13 1.881567000 sched nready 1.000000
9 1.881567000 pu p 14
12 1.883286000 t4900 US
11 1.883968000 t4900 US Bu
13 1.884278000 sched nready 0.000000
13 1.884278000 sched nsubmitted 2.000000
9 1.884278000 po p 14
12 1.900269000 t4900 US
10 1.900817000 w0 WS "Fi"
11 1.901040000 t4900 US Su
13 1.901587000 sched nsubmitted 3.000000
6 B12_no WS B12_no "0.000000 0.600000 0.400000"
6 B12_no_1 Ctx1 B12_no "1.0 0.39 1.0"
6 B12_no_2 Ctx2 B12_no ".0 1.0 .0"
6 B12_no_3 Ctx3 B12_no "0.87 0.87 .0"
6 B12_no_4 Ctx4 B12_no ".0 0.95 1.0"
6 B12_no_5 Ctx5 B12_no ".0 .0 .0"
6 B12_no_6 Ctx6 B12_no ".0 .0 0.5"
6 B12_no_7 Ctx7 B12_no "0.41 0.41 0.41"
6 B12_no_8 Ctx8 B12_no "1.0 .0 1.0"
6 B12_no_9 Ctx9 B12_no ".0 .0 1.0"
10 1.903227000 w0 WS "B12_no"
13 1.903413000 sched nready 1.000000
9 1.903413000 pu p 15
20 1.903227000 w0 WS B12_no 131160
M8192x1x8_M8194x1x8_M3x3x8 a5e481fd 0000000000000000 14
14 0.000000 0 0 -1 -1
10 1.904988000 t4912 S E
12 1.905813000 t4900 US
13 1.905977000 sched nready 0.000000
13 1.905977000 sched nsubmitted 2.000000
9 1.905977000 po p 15
11 1.906565000 t4900 US Bu
12 1.907188000 t4900 US
10 1.907427000 w1 WS "Fi"
11 1.907899000 t4900 US Su
13 1.908665000 sched nsubmitted 3.000000
6 B12_aa WS B12_aa "0.000000 0.600000 0.400000"
6 B12_aa_1 Ctx1 B12_aa "1.0 0.39 1.0"
6 B12_aa_2 Ctx2 B12_aa ".0 1.0 .0"
6 B12_aa_3 Ctx3 B12_aa "0.87 0.87 .0"
6 B12_aa_4 Ctx4 B12_aa ".0 0.95 1.0"
6 B12_aa_5 Ctx5 B12_aa ".0 .0 .0"
6 B12_aa_6 Ctx6 B12_aa ".0 .0 0.5"
6 B12_aa_7 Ctx7 B12_aa "0.41 0.41 0.41"
6 B12_aa_8 Ctx8 B12_aa "1.0 .0 1.0"
6 B12_aa_9 Ctx9 B12_aa ".0 .0 1.0"
10 1.910070000 w1 WS "B12_aa"
12 1.911238000 t4900 US
20 1.910070000 w1 WS B12_aa 196712
M8192x1x8_M8194x2x8_M3x3x8 5212cc39 0000000000000000 15
15 0.000000 0 0 -1 -1
10 1.911713000 t4913 S E
11 1.911918000 t4900 US Bu
12 1.912539000 t4900 US
11 1.914447000 t4900 US Su
13 1.915309000 sched nsubmitted 4.000000
13 1.917333000 sched nready 1.000000
9 1.917333000 pu p 17
12 1.919127000 t4900 US
13 1.919540000 sched nready 0.000000
13 1.919540000 sched nsubmitted 3.000000
9 1.919540000 po p 17
11 1.920138000 t4900 US Bu
12 1.920753000 t4900 US
10 1.920936000 w2 WS "Fi"
11 1.921523000 t4900 US Su
13 1.921999000 sched nsubmitted 4.000000
6 B13_no WS B13_no "0.000000 0.600000 0.400000"
6 B13_no_1 Ctx1 B13_no "1.0 0.39 1.0"
6 B13_no_2 Ctx2 B13_no ".0 1.0 .0"
6 B13_no_3 Ctx3 B13_no "0.87 0.87 .0"
6 B13_no_4 Ctx4 B13_no ".0 0.95 1.0"
6 B13_no_5 Ctx5 B13_no ".0 .0 .0"
6 B13_no_6 Ctx6 B13_no ".0 .0 0.5"
6 B13_no_7 Ctx7 B13_no "0.41 0.41 0.41"
6 B13_no_8 Ctx8 B13_no "1.0 .0 1.0"
6 B13_no_9 Ctx9 B13_no ".0 .0 1.0"
10 1.923242000 w2 WS "B13_no"
13 1.924093000 sched nready 1.000000
9 1.924093000 pu p 18
20 1.923242000 w2 WS B13_no 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 17 17
0.000000 0 0 -1 -1
10 1.924797000 t4914 S E
10 1.925622000 t4914 S B
12 1.925781000 t4900 US
11 1.926450000 t4900 US Bu
10 1.926593000 w2 WS "I"
13 1.875375000 w2 gf 0.000000
13 1.923242000 w2 gf 0.000000
13 1.926653000 sched nready 0.000000
13 1.926653000 sched nsubmitted 3.000000
9 1.926653000 po p 18
12 1.927232000 t4900 US
11 1.927874000 t4900 US Su
10 1.928057000 w3 WS "Fi"
13 1.928620000 sched nsubmitted 4.000000
6 B13_ne WS B13_ne "0.000000 0.600000 0.400000"
6 B13_ne_1 Ctx1 B13_ne "1.0 0.39 1.0"
6 B13_ne_2 Ctx2 B13_ne ".0 1.0 .0"
6 B13_ne_3 Ctx3 B13_ne "0.87 0.87 .0"
6 B13_ne_4 Ctx4 B13_ne ".0 0.95 1.0"
6 B13_ne_5 Ctx5 B13_ne ".0 .0 .0"
6 B13_ne_6 Ctx6 B13_ne ".0 .0 0.5"
6 B13_ne_7 Ctx7 B13_ne "0.41 0.41 0.41"
6 B13_ne_8 Ctx8 B13_ne "1.0 .0 1.0"
6 B13_ne_9 Ctx9 B13_ne ".0 .0 1.0"
10 1.930316000 w3 WS "B13_ne"
12 1.930905000 t4900 US
11 1.931528000 t4900 US Bu
20 1.930316000 w3 WS B13_ne 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 18 18 0.000000 0
0 -1 -1
10 1.931911000 t4915 S E
12 1.932151000 t4900 US
10 1.932488000 t4915 S B
11 1.932816000 t4900 US Su
10 1.933446000 w3 WS "I"
13 1.853468000 w3 gf 0.000000
13 1.930316000 w3 gf 0.000000
13 1.933500000 sched nsubmitted 5.000000
13 1.935249000 sched nready 1.000000
9 1.935249000 pu p 20
12 1.937203000 t4900 US
18 1.938112000 WSL p 0 w4 steal_2
19 1.938112001 WSL p 0 w2 steal_2
13 1.938313000 sched nready 0.000000
13 1.938313000 sched nsubmitted 4.000000
9 1.938313000 po p 20
11 1.939133000 t4900 US Bu
10 1.939786000 w2 WS "Fi"
12 1.939896000 t4900 US
11 1.940590000 t4900 US Su
13 1.941109000 sched nsubmitted 5.000000
6 B13_aa WS B13_aa "0.000000 0.600000 0.400000"
6 B13_aa_1 Ctx1 B13_aa "1.0 0.39 1.0"
6 B13_aa_2 Ctx2 B13_aa ".0 1.0 .0"
6 B13_aa_3 Ctx3 B13_aa "0.87 0.87 .0"
6 B13_aa_4 Ctx4 B13_aa ".0 0.95 1.0"
6 B13_aa_5 Ctx5 B13_aa ".0 .0 .0"
6 B13_aa_6 Ctx6 B13_aa ".0 .0 0.5"
6 B13_aa_7 Ctx7 B13_aa "0.41 0.41 0.41"
6 B13_aa_8 Ctx8 B13_aa "1.0 .0 1.0"
6 B13_aa_9 Ctx9 B13_aa ".0 .0 1.0"
10 1.941937000 w2 WS "B13_aa"
20 1.941937000 w2 WS B13_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 20 20 0.000000 0
0 -1 -1
10 1.943444000 t4914 S E
10 1.944166000 t4914 S B
12 1.944263000 t4900 US
11 1.944982000 t4900 US Bu
10 1.945125000 w2 WS "I"
13 1.926593000 w2 gf 0.000000
13 1.941937000 w2 gf 0.000000
12 1.945625000 t4900 US
11 1.946285000 t4900 US Su
13 1.946854000 sched nsubmitted 6.000000
12 1.948918000 t4900 US
11 1.949545000 t4900 US Bu
12 1.950069000 t4900 US
11 1.950707000 t4900 US Su
13 1.951215000 sched nsubmitted 7.000000
13 1.953070000 sched nready 1.000000
9 1.953070000 pu p 23
12 1.954772000 t4900 US
18 1.954826000 WSL p 0 w5 steal_3
19 1.954826001 WSL p 0 w2 steal_3
13 1.954959000 sched nready 0.000000
13 1.954959000 sched nsubmitted 6.000000
9 1.954959000 po p 23
10 1.956313000 w2 WS "Fi"
11 1.956940000 t4900 US Bu
12 1.957474000 t4900 US
11 1.958277000 t4900 US Su
6 B21_aa WS B21_aa "0.000000 0.600000 0.400000"
6 B21_aa_1 Ctx1 B21_aa "1.0 0.39 1.0"
6 B21_aa_2 Ctx2 B21_aa ".0 1.0 .0"
6 B21_aa_3 Ctx3 B21_aa "0.87 0.87 .0"
6 B21_aa_4 Ctx4 B21_aa ".0 0.95 1.0"
6 B21_aa_5 Ctx5 B21_aa ".0 .0 .0"
6 B21_aa_6 Ctx6 B21_aa ".0 .0 0.5"
6 B21_aa_7 Ctx7 B21_aa "0.41 0.41 0.41"
6 B21_aa_8 Ctx8 B21_aa "1.0 .0 1.0"
6 B21_aa_9 Ctx9 B21_aa ".0 .0 1.0"
10 1.958496000 w2 WS "B21_aa"
13 1.959248000 sched nsubmitted 7.000000
20 1.958496000 w2 WS B21_aa 196712
M1x8192x8_M2x8194x8_M3x3x8 6ccb5ec1 0000000000000000 23
23 0.000000 0 0 -1 -1
10 1.959864000 t4914 S E
12 1.961784000 t4900 US
11 1.978573000 t4900 US Bu
12 1.979297000 t4900 US
11 1.980136000 t4900 US Su
13 1.980663000 sched nsubmitted 8.000000
13 1.982787000 sched nready 1.000000
9 1.982787000 pu p 25
12 1.984477000 t4900 US
18 1.985522000 WSL p 0 w0 steal_4
19 1.985522001 WSL p 0 w3 steal_4
13 1.985730000 sched nready 0.000000
13 1.985730000 sched nsubmitted 7.000000
9 1.985730000 po p 25
11 1.985889000 t4900 US Bu
12 1.986708000 t4900 US
10 1.987216000 w3 WS "Fi"
11 1.987385000 t4900 US Su
13 1.987947000 sched nsubmitted 8.000000
6 B22_0 WS B22_0 "0.000000 0.600000 0.400000"
6 B22_0_1 Ctx1 B22_0 "1.0 0.39 1.0"
6 B22_0_2 Ctx2 B22_0 ".0 1.0 .0"
6 B22_0_3 Ctx3 B22_0 "0.87 0.87 .0"
6 B22_0_4 Ctx4 B22_0 ".0 0.95 1.0"
6 B22_0_5 Ctx5 B22_0 ".0 .0 .0"
6 B22_0_6 Ctx6 B22_0 ".0 .0 0.5"
6 B22_0_7 Ctx7 B22_0 "0.41 0.41 0.41"
6 B22_0_8 Ctx8 B22_0 "1.0 .0 1.0"
6 B22_0_9 Ctx9 B22_0 ".0 .0 1.0"
10 1.989453000 w3 WS "B22_0"
13 1.989925000 sched nready 1.000000
9 1.989925000 pu p 26
20 1.989453000 w3 WS B22_0 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 25
25 0.000000 0 0 -1 -1
10 1.990971000 t4915 S E
12 1.991911000 t4900 US
11 1.994181000 t4900 US Bu
12 1.994700000 t4900 US
11 1.995294000 t4900 US Su
13 1.995762000 sched nsubmitted 9.000000
13 1.997404000 sched nready 2.000000
9 1.997404000 pu p 27
12 1.998899000 t4900 US
11 1.999896000 t4900 US Bu
12 2.000385000 t4900 US
11 2.000982000 t4900 US Su
13 2.001572000 sched nsubmitted 10.000000
13 2.003125000 sched nready 3.000000
9 2.003125000 pu p 28
12 2.004688000 t4900 US
11 2.005565000 t4900 US Bu
12 2.006167000 t4900 US
11 2.006716000 t4900 US Su
10 2.007124000 t4912 S B
13 2.007207000 sched nsubmitted 11.000000
10 2.008564000 w0 WS "I"
13 1.823618000 w0 gf 0.000000
13 1.903227000 w0 gf 0.000000
13 2.008852000 sched nready 4.000000
9 2.008852000 pu p 29
12 2.010538000 t4900 US
11 2.011770000 t4900 US Bu
12 2.012312000 t4900 US
18 2.013897000 WSL p 0 w1 steal_5
19 2.013897001 WSL p 0 w0 steal_5
13 2.014226000 sched nready 3.000000
13 2.014226000 sched nsubmitted 10.000000
9 2.014226000 po p 26
11 2.015224000 t4900 US Su
10 2.015587000 w0 WS "Fi"
13 2.015712000 sched nsubmitted 11.000000
13 2.017515000 sched nready 4.000000
9 2.017515000 pu p 30
6 B22_1 WS B22_1 "0.000000 0.600000 0.400000"
6 B22_1_1 Ctx1 B22_1 "1.0 0.39 1.0"
6 B22_1_2 Ctx2 B22_1 ".0 1.0 .0"
6 B22_1_3 Ctx3 B22_1 "0.87 0.87 .0"
6 B22_1_4 Ctx4 B22_1 ".0 0.95 1.0"
6 B22_1_5 Ctx5 B22_1 ".0 .0 .0"
6 B22_1_6 Ctx6 B22_1 ".0 .0 0.5"
6 B22_1_7 Ctx7 B22_1 "0.41 0.41 0.41"
6 B22_1_8 Ctx8 B22_1 "1.0 .0 1.0"
6 B22_1_9 Ctx9 B22_1 ".0 .0 1.0"
10 2.017791000 w0 WS "B22_1"
12 2.019265000 t4900 US
20 2.017791000 w0 WS B22_1 4210792
26 0.000000 0 0 -1 -1
10 2.019396000 t4912 S E
11 2.020338000 t4900 US Bu
12 2.020844000 t4900 US
11 2.021493000 t4900 US Su
13 2.021970000 sched nsubmitted 12.000000
13 2.023650000 sched nready 5.000000
9 2.023650000 pu p 31
12 2.025554000 t4900 US
11 2.026425000 t4900 US Bu
12 2.026955000 t4900 US
11 2.027548000 t4900 US Su
13 2.028105000 sched nsubmitted 13.000000
13 2.029604000 sched nready 6.000000
9 2.029604000 pu p 32
12 2.031122000 t4900 US
11 2.032193000 t4900 US Bu
12 2.032713000 t4900 US
11 2.034701000 t4900 US Su
13 2.035221000 sched nsubmitted 14.000000
13 2.036805000 sched nready 7.000000
9 2.036805000 pu p 33
12 2.038395000 t4900 US
11 2.039660000 t4900 US Bu
12 2.040257000 t4900 US
11 2.040951000 t4900 US Su
13 2.041460000 sched nsubmitted 15.000000
13 2.043294000 sched nready 8.000000
9 2.043294000 pu p 34
12 2.045092000 t4900 US
11 2.047535000 t4900 US Bu
12 2.048180000 t4900 US
11 2.048794000 t4900 US Su
13 2.049248000 sched nsubmitted 16.000000
13 2.050764000 sched nready 9.000000
9 2.050764000 pu p 35
12 2.052277000 t4900 US
11 2.053347000 t4900 US Bu
12 2.053884000 t4900 US
11 2.054435000 t4900 US Su
13 2.054937000 sched nsubmitted 17.000000
13 2.056517000 sched nready 10.000000
9 2.056517000 pu p 36
12 2.058019000 t4900 US
11 2.060337000 t4900 US Bu
12 2.060921000 t4900 US
11 2.061577000 t4900 US Su
13 2.062037000 sched nsubmitted 18.000000
13 2.064047000 sched nready 11.000000
9 2.064047000 pu p 37
12 2.065567000 t4900 US
11 2.066629000 t4900 US Bu
12 2.067206000 t4900 US
11 2.067762000 t4900 US Su
13 2.068298000 sched nsubmitted 19.000000
13 2.069814000 sched nready 12.000000
9 2.069814000 pu p 38
12 2.071489000 t4900 US
11 2.072417000 t4900 US Bu
12 2.072946000 t4900 US
11 2.073476000 t4900 US Su
13 2.073951000 sched nsubmitted 20.000000
13 2.075437000 sched nready 13.000000
9 2.075437000 pu p 39
12 2.076894000 t4900 US
11 2.077805000 t4900 US Bu
12 2.078325000 t4900 US
11 2.080305000 t4900 US Su
13 2.081218000 sched nsubmitted 21.000000
13 2.082771000 sched nready 14.000000
9 2.082771000 pu p 40
12 2.084331000 t4900 US
11 2.085343000 t4900 US Bu
12 2.085967000 t4900 US
11 2.086581000 t4900 US Su
13 2.087056000 sched nsubmitted 22.000000
13 2.088802000 sched nready 15.000000
9 2.088802000 pu p 41
12 2.090603000 t4900 US
11 2.091653000 t4900 US Bu
12 2.092181000 t4900 US
11 2.092744000 t4900 US Su
13 2.093216000 sched nsubmitted 23.000000
13 2.094837000 sched nready 16.000000
9 2.094837000 pu p 42
12 2.096798000 t4900 US
11 2.097760000 t4900 US Bu
12 2.098359000 t4900 US
11 2.100209000 t4900 US Su
13 2.100682000 sched nsubmitted 24.000000
10 2.102444000 t4913 S B
13 2.102498000 sched nready 17.000000
9 2.102498000 pu p 43
10 2.103798000 w1 WS "I"
13 1.869405000 w1 gf 0.000000
12 2.104068000 t4900 US
11 2.105266000 t4900 US Bu
12 2.105817000 t4900 US
11 2.106430000 t4900 US Su
13 2.106945000 sched nsubmitted 25.000000
13 2.108073000 sched nready 18.000000
9 2.108073000 pu p 16
13 2.108681000 sched nready 19.000000
9 2.108681000 pu p 44
13 2.115753000 sched nready 18.000000
13 2.115753000 sched nsubmitted 24.000000
9 2.115753000 po p 32
12 2.116310000 t4900 US
10 2.117169000 w1 WS "Fi"
11 2.117699000 t4900 US Bu
12 2.118435000 t4900 US
11 2.119259000 t4900 US Su
6 B22_7 WS B22_7 "0.000000 0.600000 0.400000"
6 B22_7_1 Ctx1 B22_7 "1.0 0.39 1.0"
6 B22_7_2 Ctx2 B22_7 ".0 1.0 .0"
6 B22_7_3 Ctx3 B22_7 "0.87 0.87 .0"
6 B22_7_4 Ctx4 B22_7 ".0 0.95 1.0"
6 B22_7_5 Ctx5 B22_7 ".0 .0 .0"
6 B22_7_6 Ctx6 B22_7 ".0 .0 0.5"
6 B22_7_7 Ctx7 B22_7 "0.41 0.41 0.41"
6 B22_7_8 Ctx8 B22_7 "1.0 .0 1.0"
6 B22_7_9 Ctx9 B22_7 ".0 .0 1.0"
10 2.119423000 w1 WS "B22_7"
13 2.119782000 sched nsubmitted 25.000000
20 2.119423000 w1 WS B22_7 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 32
32 0.000000 0 0 -1 -1
10 2.121022000 t4913 S E
13 2.121798000 sched nready 19.000000
9 2.121798000 pu p 45
12 2.123413000 t4900 US
11 2.124358000 t4900 US Bu
12 2.124851000 t4900 US
11 2.125407000 t4900 US Su
13 2.125898000 sched nsubmitted 26.000000
13 2.127385000 sched nready 20.000000
9 2.127385000 pu p 46
12 2.129129000 t4900 US
11 2.131451000 t4900 US Bu
12 2.131997000 t4900 US
11 2.132570000 t4900 US Su
13 2.133055000 sched nsubmitted 27.000000
13 2.134707000 sched nready 21.000000
9 2.134707000 pu p 47
12 2.136250000 t4900 US
11 2.137255000 t4900 US Bu
12 2.137762000 t4900 US
11 2.138343000 t4900 US Su
13 2.138838000 sched nsubmitted 28.000000
13 2.140665000 sched nready 22.000000
9 2.140665000 pu p 48
12 2.142333000 t4900 US
11 2.143349000 t4900 US Bu
12 2.143872000 t4900 US
11 2.144507000 t4900 US Su
13 2.144996000 sched nsubmitted 29.000000
13 2.146476000 sched nready 23.000000
9 2.146476000 pu p 49
12 2.148110000 t4900 US
11 2.149142000 t4900 US Bu
12 2.149647000 t4900 US
11 2.151683000 t4900 US Su
13 2.152320000 sched nsubmitted 30.000000
13 2.154014000 sched nready 24.000000
9 2.154014000 pu p 50
12 2.155533000 t4900 US
11 2.156614000 t4900 US Bu
12 2.157168000 t4900 US
11 2.157741000 t4900 US Su
13 2.158203000 sched nsubmitted 31.000000
13 2.159915000 sched nready 25.000000
9 2.159915000 pu p 51
12 2.161470000 t4900 US
11 2.162396000 t4900 US Bu
12 2.163032000 t4900 US
11 2.163588000 t4900 US Su
13 2.164075000 sched nsubmitted 32.000000
13 2.165958000 sched nready 26.000000
9 2.165958000 pu p 52
12 2.167848000 t4900 US
11 2.168819000 t4900 US Bu
12 2.169430000 t4900 US
11 2.169987000 t4900 US Su
13 2.170468000 sched nsubmitted 33.000000
13 2.172339000 sched nready 27.000000
9 2.172339000 pu p 53
12 2.174001000 t4900 US
11 2.176489000 t4900 US Bu
12 2.177095000 t4900 US
11 2.177763000 t4900 US Su
13 2.178271000 sched nsubmitted 34.000000
13 2.179910000 sched nready 28.000000
9 2.179910000 pu p 54
12 2.181545000 t4900 US
11 2.182513000 t4900 US Bu
12 2.183044000 t4900 US
11 2.183657000 t4900 US Su
13 2.184229000 sched nsubmitted 35.000000
13 2.185761000 sched nready 29.000000
9 2.185761000 pu p 55
12 2.187262000 t4900 US
11 2.188189000 t4900 US Bu
12 2.188720000 t4900 US
11 2.189349000 t4900 US Su
13 2.190053000 sched nsubmitted 36.000000
13 2.191625000 sched nready 30.000000
9 2.191625000 pu p 56
12 2.193229000 t4900 US
11 2.194201000 t4900 US Bu
12 2.194738000 t4900 US
11 2.196520000 t4900 US Su
13 2.197015000 sched nsubmitted 37.000000
13 2.198750000 sched nready 31.000000
9 2.198750000 pu p 57
12 2.200325000 t4900 US
11 2.201280000 t4900 US Bu
12 2.201875000 t4900 US
11 2.202461000 t4900 US Su
13 2.203096000 sched nsubmitted 38.000000
13 2.205151000 sched nready 32.000000
9 2.205151000 pu p 58
12 2.206906000 t4900 US
11 2.207765000 t4900 US Bu
12 2.208278000 t4900 US
11 2.208999000 t4900 US Su
13 2.209459000 sched nsubmitted 39.000000
13 2.210993000 sched nready 33.000000
9 2.210993000 pu p 59
12 2.212771000 t4900 US
11 2.213676000 t4900 US Bu
12 2.214194000 t4900 US
11 2.216120000 t4900 US Su
13 2.216759000 sched nsubmitted 40.000000
13 2.218404000 sched nready 34.000000
9 2.218404000 pu p 60
10 2.218561000 t4916 S B
10 2.218797000 t4917 S B
12 2.220156000 t4900 US
10 2.221050000 w4 WS "I"
13 1.799553000 w4 gf 0.000000
13 1.794933000 sched gft 0.000000
11 2.221328000 t4900 US Bu
12 2.221920000 t4900 US
10 2.222486000 w5 WS "I"
13 1.809603000 w5 gf 0.000000
13 1.799553000 sched gft 0.000000
13 1.809603000 sched gft 0.000000
13 1.818766000 sched gft 0.000000
13 1.823618000 sched gft 0.000000
13 1.827588000 sched gft 0.000000
13 1.841194000 sched gft 0.000000
13 1.849628000 sched gft 0.000000
13 1.853468000 sched gft 0.000000
13 1.857648000 sched gft 0.000000
13 1.860794000 sched gft 0.000000
13 1.869405000 sched gft 0.000000
13 1.872051000 sched gft 0.000000
13 1.875375000 sched gft 0.000000
13 1.903227000 sched gft 0.000000
13 1.923242000 sched gft 0.000000
13 1.926593000 sched gft 0.000000
13 1.930316000 sched gft 0.000000
13 1.933446000 sched gft 0.000000
13 1.941937000 sched gft 0.000000
11 2.222581000 t4900 US Su
13 2.223239000 sched nsubmitted 41.000000
13 2.225396000 sched nready 35.000000
9 2.225396000 pu p 11
13 2.225797000 sched nready 36.000000
9 2.225797000 pu p 61
12 2.227614000 t4900 US
13 2.228028000 sched nready 37.000000
9 2.228028000 pu p 22
13 2.228459000 sched nready 38.000000
9 2.228459000 pu p 19
11 2.228994000 t4900 US Bu
12 2.229819000 t4900 US
11 2.230490000 t4900 US Su
13 2.231158000 sched nsubmitted 42.000000
13 2.232200000 sched nready 37.000000
13 2.232200000 sched nsubmitted 41.000000
9 2.232200000 po p 29
13 2.233213000 sched nready 38.000000
9 2.233213000 pu p 62
10 2.233598000 w4 WS "Fi"
12 2.235379000 t4900 US
13 2.235975000 sched nready 37.000000
13 2.235975000 sched nsubmitted 40.000000
9 2.235975000 po p 30
6 B22_4 WS B22_4 "0.000000 0.600000 0.400000"
6 B22_4_1 Ctx1 B22_4 "1.0 0.39 1.0"
6 B22_4_2 Ctx2 B22_4 ".0 1.0 .0"
6 B22_4_3 Ctx3 B22_4 "0.87 0.87 .0"
6 B22_4_4 Ctx4 B22_4 ".0 0.95 1.0"
6 B22_4_5 Ctx5 B22_4 ".0 .0 .0"
6 B22_4_6 Ctx6 B22_4 ".0 .0 0.5"
6 B22_4_7 Ctx7 B22_4 "0.41 0.41 0.41"
6 B22_4_8 Ctx8 B22_4 "1.0 .0 1.0"
6 B22_4_9 Ctx9 B22_4 ".0 .0 1.0"
10 2.236117000 w4 WS "B22_4"
11 2.236997000 t4900 US Bu
20 2.236117000 w4 WS B22_4 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 29
29 0.000000 0 0 -1 -1
12 2.237899000 t4900 US
10 2.237987000 t4916 S E
10 2.238053000 w5 WS "Fi"
11 2.238552000 t4900 US Su
13 2.239058000 sched nsubmitted 41.000000
13 2.241220000 sched nready 38.000000
9 2.241220000 pu p 63
6 B22_5 WS B22_5 "0.000000 0.600000 0.400000"
6 B22_5_1 Ctx1 B22_5 "1.0 0.39 1.0"
6 B22_5_2 Ctx2 B22_5 ".0 1.0 .0"
6 B22_5_3 Ctx3 B22_5 "0.87 0.87 .0"
6 B22_5_4 Ctx4 B22_5 ".0 0.95 1.0"
6 B22_5_5 Ctx5 B22_5 ".0 .0 .0"
6 B22_5_6 Ctx6 B22_5 ".0 .0 0.5"
6 B22_5_7 Ctx7 B22_5 "0.41 0.41 0.41"
6 B22_5_8 Ctx8 B22_5 "1.0 .0 1.0"
6 B22_5_9 Ctx9 B22_5 ".0 .0 1.0"
10 2.241805000 w5 WS "B22_5"
12 2.242733000 t4900 US
20 2.241805000 w5 WS B22_5 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 30
30 0.000000 0 0 -1 -1
10 2.244638000 t4917 S E
11 2.245385000 t4900 US Bu
12 2.245883000 t4900 US
11 2.246492000 t4900 US Su
13 2.246974000 sched nsubmitted 42.000000
13 2.248574000 sched nready 39.000000
9 2.248574000 pu p 64
12 2.250051000 t4900 US
11 2.251058000 t4900 US Bu
12 2.251580000 t4900 US
11 2.252149000 t4900 US Su
13 2.252621000 sched nsubmitted 43.000000
13 2.254244000 sched nready 40.000000
9 2.254244000 pu p 65
12 2.255810000 t4900 US
11 2.256717000 t4900 US Bu
12 2.257225000 t4900 US
11 2.257797000 t4900 US Su
13 2.258270000 sched nsubmitted 44.000000
13 2.259885000 sched nready 41.000000
9 2.259885000 pu p 66
12 2.261363000 t4900 US
11 2.262299000 t4900 US Bu
12 2.262818000 t4900 US
11 2.264660000 t4900 US Su
13 2.265168000 sched nsubmitted 45.000000
13 2.266744000 sched nready 42.000000
9 2.266744000 pu p 67
12 2.268205000 t4900 US
11 2.269159000 t4900 US Bu
12 2.269675000 t4900 US
11 2.270263000 t4900 US Su
13 2.270729000 sched nsubmitted 46.000000
13 2.272272000 sched nready 43.000000
9 2.272272000 pu p 68
12 2.273735000 t4900 US
11 2.274668000 t4900 US Bu
12 2.275187000 t4900 US
11 2.275753000 t4900 US Su
13 2.276227000 sched nsubmitted 47.000000
13 2.277814000 sched nready 44.000000
9 2.277814000 pu p 69
12 2.279333000 t4900 US
11 2.280236000 t4900 US Bu
12 2.280755000 t4900 US
11 2.282625000 t4900 US Su
13 2.283153000 sched nsubmitted 48.000000
13 2.284697000 sched nready 45.000000
9 2.284697000 pu p 70
12 2.286154000 t4900 US
11 2.287116000 t4900 US Bu
12 2.287626000 t4900 US
11 2.288207000 t4900 US Su
13 2.288684000 sched nsubmitted 49.000000
13 2.290271000 sched nready 46.000000
9 2.290271000 pu p 71
12 2.291729000 t4900 US
11 2.292637000 t4900 US Bu
12 2.293150000 t4900 US
11 2.293711000 t4900 US Su
13 2.294183000 sched nsubmitted 50.000000
13 2.295695000 sched nready 47.000000
9 2.295695000 pu p 72
12 2.297136000 t4900 US
11 2.298065000 t4900 US Bu
12 2.298574000 t4900 US
11 2.299139000 t4900 US Su
13 2.299610000 sched nsubmitted 51.000000
10 2.300717000 t4914 S B
13 2.301172000 sched nready 48.000000
9 2.301172000 pu p 73
10 2.302305000 w2 WS "I"
13 1.945125000 w2 gf 0.000000
13 1.958496000 w2 gf 0.000000
13 1.945125000 sched gft 0.000000
12 2.302660000 t4900 US
11 2.306797000 t4900 US Bu
13 2.306965000 sched nready 47.000000
13 2.306965000 sched nsubmitted 50.000000
9 2.306965000 po p 27
12 2.307353000 t4900 US
11 2.308119000 t4900 US Su
10 2.308358000 w2 WS "Fi"
13 2.308649000 sched nsubmitted 51.000000
13 2.310457000 sched nready 48.000000
9 2.310457000 pu p 74
6 B22_2 WS B22_2 "0.000000 0.600000 0.400000"
6 B22_2_1 Ctx1 B22_2 "1.0 0.39 1.0"
6 B22_2_2 Ctx2 B22_2 ".0 1.0 .0"
6 B22_2_3 Ctx3 B22_2 "0.87 0.87 .0"
6 B22_2_4 Ctx4 B22_2 ".0 0.95 1.0"
6 B22_2_5 Ctx5 B22_2 ".0 .0 .0"
6 B22_2_6 Ctx6 B22_2 ".0 .0 0.5"
6 B22_2_7 Ctx7 B22_2 "0.41 0.41 0.41"
6 B22_2_8 Ctx8 B22_2 "1.0 .0 1.0"
6 B22_2_9 Ctx9 B22_2 ".0 .0 1.0"
10 2.310561000 w2 WS "B22_2"
20 2.310561000 w2 WS B22_2 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 27
27 0.000000 0 0 -1 -1
10 2.311929000 t4914 S E
12 2.312022000 t4900 US
11 2.313055000 t4900 US Bu
12 2.313567000 t4900 US
11 2.314175000 t4900 US Su
13 2.314660000 sched nsubmitted 52.000000
13 2.316235000 sched nready 49.000000
9 2.316235000 pu p 75
12 2.317754000 t4900 US
11 2.318686000 t4900 US Bu
12 2.319218000 t4900 US
11 2.319789000 t4900 US Su
13 2.320274000 sched nsubmitted 53.000000
13 2.321789000 sched nready 50.000000
9 2.321789000 pu p 76
12 2.323279000 t4900 US
11 2.324182000 t4900 US Bu
12 2.324701000 t4900 US
11 2.327460000 t4900 US Su
13 2.327976000 sched nsubmitted 54.000000
13 2.329571000 sched nready 51.000000
9 2.329571000 pu p 77
12 2.331059000 t4900 US
11 2.332025000 t4900 US Bu
12 2.332559000 t4900 US
11 2.333143000 t4900 US Su
13 2.333620000 sched nsubmitted 55.000000
13 2.335252000 sched nready 52.000000
9 2.335252000 pu p 78
12 2.336706000 t4900 US
11 2.337640000 t4900 US Bu
12 2.338148000 t4900 US
11 2.338730000 t4900 US Su
13 2.339202000 sched nsubmitted 56.000000
13 2.340719000 sched nready 53.000000
9 2.340719000 pu p 79
12 2.342167000 t4900 US
11 2.343067000 t4900 US Bu
12 2.343587000 t4900 US
11 2.344159000 t4900 US Su
13 2.344630000 sched nsubmitted 57.000000
13 2.346179000 sched nready 54.000000
9 2.346179000 pu p 80
12 2.347638000 t4900 US
11 2.350593000 t4900 US Bu
12 2.351143000 t4900 US
11 2.351722000 t4900 US Su
13 2.352198000 sched nsubmitted 58.000000
13 2.353958000 sched nready 55.000000
9 2.353958000 pu p 81
12 2.355439000 t4900 US
11 2.356409000 t4900 US Bu
12 2.356946000 t4900 US
11 2.357528000 t4900 US Su
13 2.358005000 sched nsubmitted 59.000000
13 2.359532000 sched nready 56.000000
9 2.359532000 pu p 82
12 2.361005000 t4900 US
11 2.361928000 t4900 US Bu
12 2.362456000 t4900 US
11 2.363029000 t4900 US Su
13 2.363505000 sched nsubmitted 60.000000
13 2.365034000 sched nready 57.000000
9 2.365034000 pu p 83
12 2.366494000 t4900 US
11 2.368586000 t4900 US Bu
12 2.369111000 t4900 US
11 2.369700000 t4900 US Su
13 2.370178000 sched nsubmitted 61.000000
13 2.371807000 sched nready 58.000000
9 2.371807000 pu p 84
12 2.373283000 t4900 US
11 2.374212000 t4900 US Bu
12 2.374723000 t4900 US
11 2.375300000 t4900 US Su
13 2.375766000 sched nsubmitted 62.000000
13 2.377397000 sched nready 59.000000
9 2.377397000 pu p 85
12 2.378855000 t4900 US
11 2.379761000 t4900 US Bu
12 2.380274000 t4900 US
11 2.380850000 t4900 US Su
13 2.381321000 sched nsubmitted 63.000000
13 2.382836000 sched nready 60.000000
9 2.382836000 pu p 86
12 2.384307000 t4900 US
11 2.385233000 t4900 US Bu
12 2.385749000 t4900 US
11 2.387607000 t4900 US Su
13 2.388140000 sched nsubmitted 64.000000
13 2.389692000 sched nready 61.000000
9 2.389692000 pu p 87
12 2.391179000 t4900 US
11 2.392162000 t4900 US Bu
12 2.392686000 t4900 US
11 2.393261000 t4900 US Su
13 2.393734000 sched nsubmitted 65.000000
13 2.395324000 sched nready 62.000000
9 2.395324000 pu p 88
12 2.396829000 t4900 US
11 2.397759000 t4900 US Bu
12 2.398273000 t4900 US
11 2.398855000 t4900 US Su
13 2.399327000 sched nsubmitted 66.000000
13 2.400869000 sched nready 63.000000
9 2.400869000 pu p 89
12 2.402327000 t4900 US
11 2.403238000 t4900 US Bu
12 2.403756000 t4900 US
11 2.404334000 t4900 US Su
13 2.404806000 sched nsubmitted 67.000000
13 2.406324000 sched nready 64.000000
9 2.406324000 pu p 90
12 2.407797000 t4900 US
11 2.409940000 t4900 US Bu
12 2.410457000 t4900 US
11 2.411038000 t4900 US Su
13 2.411515000 sched nsubmitted 68.000000
13 2.413177000 sched nready 65.000000
9 2.413177000 pu p 91
12 2.414671000 t4900 US
11 2.415642000 t4900 US Bu
12 2.416147000 t4900 US
11 2.416729000 t4900 US Su
13 2.417205000 sched nsubmitted 69.000000
13 2.418774000 sched nready 66.000000
9 2.418774000 pu p 92
12 2.420230000 t4900 US
11 2.421166000 t4900 US Bu
12 2.421670000 t4900 US
11 2.422256000 t4900 US Su
13 2.422724000 sched nsubmitted 70.000000
13 2.424280000 sched nready 67.000000
9 2.424280000 pu p 93
12 2.425749000 t4900 US
11 2.426673000 t4900 US Bu
12 2.427196000 t4900 US
11 2.429013000 t4900 US Su
13 2.429525000 sched nsubmitted 71.000000
13 2.431196000 sched nready 68.000000
9 2.431196000 pu p 94
12 2.432660000 t4900 US
11 2.433593000 t4900 US Bu
12 2.434113000 t4900 US
11 2.434695000 t4900 US Su
13 2.435172000 sched nsubmitted 72.000000
13 2.436711000 sched nready 69.000000
9 2.436711000 pu p 95
12 2.438172000 t4900 US
11 2.439106000 t4900 US Bu
12 2.439632000 t4900 US
11 2.440212000 t4900 US Su
13 2.440680000 sched nsubmitted 73.000000
13 2.442238000 sched nready 70.000000
9 2.442238000 pu p 96
12 2.443708000 t4900 US
11 2.444612000 t4900 US Bu
12 2.445118000 t4900 US
11 2.446949000 t4900 US Su
13 2.447461000 sched nsubmitted 74.000000
13 2.449064000 sched nready 71.000000
9 2.449064000 pu p 97
12 2.450543000 t4900 US
11 2.451517000 t4900 US Bu
12 2.452047000 t4900 US
11 2.452641000 t4900 US Su
13 2.453108000 sched nsubmitted 75.000000
13 2.454627000 sched nready 72.000000
9 2.454627000 pu p 98
12 2.456097000 t4900 US
11 2.457019000 t4900 US Bu
12 2.457541000 t4900 US
11 2.458124000 t4900 US Su
13 2.458586000 sched nsubmitted 76.000000
13 2.460175000 sched nready 73.000000
9 2.460175000 pu p 99
12 2.461646000 t4900 US
11 2.462572000 t4900 US Bu
12 2.463097000 t4900 US
11 2.463679000 t4900 US Su
13 2.464193000 sched nsubmitted 77.000000
13 2.465732000 sched nready 74.000000
9 2.465732000 pu p 100
12 2.467207000 t4900 US
11 2.469322000 t4900 US Bu
12 2.469867000 t4900 US
11 2.470458000 t4900 US Su
13 2.470933000 sched nsubmitted 78.000000
13 2.472964000 sched nready 75.000000
9 2.472964000 pu p 101
12 2.474444000 t4900 US
11 2.475441000 t4900 US Bu
12 2.475968000 t4900 US
11 2.476556000 t4900 US Su
13 2.477029000 sched nsubmitted 79.000000
13 2.478549000 sched nready 76.000000
9 2.478549000 pu p 102
12 2.480003000 t4900 US
11 2.480914000 t4900 US Bu
12 2.481424000 t4900 US
11 2.481995000 t4900 US Su
13 2.482462000 sched nsubmitted 80.000000
13 2.483977000 sched nready 77.000000
9 2.483977000 pu p 103
12 2.485437000 t4900 US
11 2.486362000 t4900 US Bu
12 2.486874000 t4900 US
11 2.488692000 t4900 US Su
13 2.489211000 sched nsubmitted 81.000000
13 2.490780000 sched nready 78.000000
9 2.490780000 pu p 104
12 2.492267000 t4900 US
11 2.493251000 t4900 US Bu
12 2.493876000 t4900 US
11 2.494466000 t4900 US Su
13 2.494948000 sched nsubmitted 82.000000
13 2.496495000 sched nready 79.000000
9 2.496495000 pu p 105
12 2.497969000 t4900 US
11 2.498924000 t4900 US Bu
12 2.499438000 t4900 US
11 2.500010000 t4900 US Su
13 2.500477000 sched nsubmitted 83.000000
13 2.502019000 sched nready 80.000000
9 2.502019000 pu p 106
12 2.503484000 t4900 US
11 2.504388000 t4900 US Bu
12 2.504897000 t4900 US
11 2.506696000 t4900 US Su
13 2.507202000 sched nsubmitted 84.000000
13 2.508886000 sched nready 81.000000
9 2.508886000 pu p 107
12 2.510361000 t4900 US
11 2.511299000 t4900 US Bu
12 2.511816000 t4900 US
11 2.512400000 t4900 US Su
13 2.512872000 sched nsubmitted 85.000000
13 2.514421000 sched nready 82.000000
9 2.514421000 pu p 108
12 2.515887000 t4900 US
11 2.516828000 t4900 US Bu
12 2.517344000 t4900 US
11 2.517916000 t4900 US Su
13 2.518390000 sched nsubmitted 86.000000
13 2.519907000 sched nready 83.000000
9 2.519907000 pu p 109
12 2.521349000 t4900 US
11 2.522266000 t4900 US Bu
12 2.522777000 t4900 US
11 2.523346000 t4900 US Su
13 2.523811000 sched nsubmitted 87.000000
13 2.525614000 sched nready 84.000000
9 2.525614000 pu p 110
12 2.527070000 t4900 US
11 2.529160000 t4900 US Bu
12 2.529685000 t4900 US
11 2.530265000 t4900 US Su
13 2.530743000 sched nsubmitted 88.000000
13 2.532364000 sched nready 85.000000
9 2.532364000 pu p 111
12 2.534146000 t4900 US
11 2.535141000 t4900 US Bu
12 2.535667000 t4900 US
11 2.536246000 t4900 US Su
13 2.536719000 sched nsubmitted 89.000000
13 2.538246000 sched nready 86.000000
9 2.538246000 pu p 112
12 2.539706000 t4900 US
11 2.540636000 t4900 US Bu
12 2.541139000 t4900 US
11 2.541715000 t4900 US Su
13 2.542183000 sched nsubmitted 90.000000
13 2.543732000 sched nready 87.000000
9 2.543732000 pu p 113
12 2.545182000 t4900 US
11 2.546103000 t4900 US Bu
12 2.546617000 t4900 US
11 2.548423000 t4900 US Su
13 2.548939000 sched nsubmitted 91.000000
13 2.550631000 sched nready 88.000000
9 2.550631000 pu p 114
12 2.552100000 t4900 US
11 2.553052000 t4900 US Bu
12 2.553565000 t4900 US
11 2.554143000 t4900 US Su
13 2.554613000 sched nsubmitted 92.000000
13 2.556169000 sched nready 89.000000
9 2.556169000 pu p 115
12 2.557625000 t4900 US
11 2.558548000 t4900 US Bu
12 2.559059000 t4900 US
11 2.559644000 t4900 US Su
13 2.560112000 sched nsubmitted 93.000000
13 2.561673000 sched nready 90.000000
9 2.561673000 pu p 116
12 2.563131000 t4900 US
11 2.564069000 t4900 US Bu
12 2.564574000 t4900 US
11 2.565155000 t4900 US Su
13 2.565610000 sched nsubmitted 94.000000
13 2.567165000 sched nready 91.000000
9 2.567165000 pu p 117
12 2.568645000 t4900 US
11 2.570755000 t4900 US Bu
12 2.571292000 t4900 US
11 2.571861000 t4900 US Su
13 2.572347000 sched nsubmitted 95.000000
13 2.573931000 sched nready 92.000000
9 2.573931000 pu p 118
12 2.575408000 t4900 US
11 2.576374000 t4900 US Bu
12 2.576893000 t4900 US
11 2.577456000 t4900 US Su
13 2.577940000 sched nsubmitted 96.000000
13 2.579532000 sched nready 93.000000
9 2.579532000 pu p 119
12 2.580999000 t4900 US
11 2.581940000 t4900 US Bu
12 2.582450000 t4900 US
11 2.583022000 t4900 US Su
13 2.583491000 sched nsubmitted 97.000000
13 2.585068000 sched nready 94.000000
9 2.585068000 pu p 120
12 2.586522000 t4900 US
11 2.587423000 t4900 US Bu
12 2.587935000 t4900 US
11 2.589787000 t4900 US Su
13 2.590310000 sched nsubmitted 98.000000
13 2.591895000 sched nready 95.000000
9 2.591895000 pu p 121
12 2.593375000 t4900 US
11 2.594303000 t4900 US Bu
12 2.594816000 t4900 US
11 2.595408000 t4900 US Su
13 2.595886000 sched nsubmitted 99.000000
13 2.597421000 sched nready 96.000000
9 2.597421000 pu p 122
12 2.598885000 t4900 US
11 2.599799000 t4900 US Bu
12 2.600306000 t4900 US
11 2.600880000 t4900 US Su
13 2.601358000 sched nsubmitted 100.000000
13 2.603379000 sched nready 97.000000
9 2.603379000 pu p 123
12 2.604873000 t4900 US
11 2.605771000 t4900 US Bu
12 2.606282000 t4900 US
11 2.608923000 t4900 US Su
13 2.609447000 sched nsubmitted 101.000000
13 2.611002000 sched nready 98.000000
9 2.611002000 pu p 124
12 2.612489000 t4900 US
11 2.613480000 t4900 US Bu
12 2.613988000 t4900 US
11 2.614558000 t4900 US Su
13 2.615037000 sched nsubmitted 102.000000
13 2.616583000 sched nready 99.000000
9 2.616583000 pu p 125
12 2.618057000 t4900 US
11 2.618946000 t4900 US Bu
12 2.619456000 t4900 US
11 2.620019000 t4900 US Su
13 2.620495000 sched nsubmitted 103.000000
13 2.622153000 sched nready 100.000000
9 2.622153000 pu p 126
12 2.623623000 t4900 US
11 2.624497000 t4900 US Bu
12 2.625006000 t4900 US
11 2.625579000 t4900 US Su
13 2.626050000 sched nsubmitted 104.000000
13 2.627567000 sched nready 101.000000
9 2.627567000 pu p 127
12 2.629025000 t4900 US
11 2.631132000 t4900 US Bu
12 2.631667000 t4900 US
11 2.632253000 t4900 US Su
13 2.632721000 sched nsubmitted 105.000000
13 2.634280000 sched nready 102.000000
9 2.634280000 pu p 128
12 2.635764000 t4900 US
11 2.636692000 t4900 US Bu
12 2.637208000 t4900 US
11 2.637772000 t4900 US Su
13 2.638251000 sched nsubmitted 106.000000
13 2.639788000 sched nready 103.000000
9 2.639788000 pu p 129
12 2.641258000 t4900 US
11 2.642165000 t4900 US Bu
12 2.642675000 t4900 US
11 2.643245000 t4900 US Su
13 2.643711000 sched nsubmitted 107.000000
13 2.645266000 sched nready 104.000000
9 2.645266000 pu p 130
12 2.646729000 t4900 US
11 2.647640000 t4900 US Bu
12 2.648151000 t4900 US
11 2.649948000 t4900 US Su
13 2.650459000 sched nsubmitted 108.000000
13 2.652006000 sched nready 105.000000
9 2.652006000 pu p 131
12 2.653454000 t4900 US
11 2.654377000 t4900 US Bu
12 2.654909000 t4900 US
11 2.655481000 t4900 US Su
13 2.655957000 sched nsubmitted 109.000000
13 2.657507000 sched nready 106.000000
9 2.657507000 pu p 132
12 2.658961000 t4900 US
11 2.659867000 t4900 US Bu
12 2.660373000 t4900 US
11 2.660941000 t4900 US Su
13 2.661419000 sched nsubmitted 110.000000
13 2.663015000 sched nready 107.000000
9 2.663015000 pu p 133
12 2.664531000 t4900 US
11 2.665425000 t4900 US Bu
12 2.665948000 t4900 US
11 2.667732000 t4900 US Su
13 2.668243000 sched nsubmitted 111.000000
13 2.669856000 sched nready 108.000000
9 2.669856000 pu p 134
12 2.671325000 t4900 US
11 2.672239000 t4900 US Bu
12 2.672753000 t4900 US
11 2.673330000 t4900 US Su
13 2.673806000 sched nsubmitted 112.000000
13 2.675319000 sched nready 109.000000
9 2.675319000 pu p 135
12 2.676799000 t4900 US
11 2.677702000 t4900 US Bu
12 2.678209000 t4900 US
11 2.678784000 t4900 US Su
13 2.679262000 sched nsubmitted 113.000000
13 2.680889000 sched nready 110.000000
9 2.680889000 pu p 136
12 2.682358000 t4900 US
11 2.683266000 t4900 US Bu
12 2.683786000 t4900 US
11 2.684351000 t4900 US Su
13 2.684823000 sched nsubmitted 114.000000
13 2.686363000 sched nready 111.000000
9 2.686363000 pu p 137
12 2.687825000 t4900 US
11 2.689900000 t4900 US Bu
12 2.690435000 t4900 US
11 2.691012000 t4900 US Su
13 2.691488000 sched nsubmitted 115.000000
13 2.693063000 sched nready 112.000000
9 2.693063000 pu p 138
12 2.694525000 t4900 US
11 2.695472000 t4900 US Bu
12 2.695988000 t4900 US
11 2.696563000 t4900 US Su
13 2.697043000 sched nsubmitted 116.000000
13 2.698728000 sched nready 113.000000
9 2.698728000 pu p 139
12 2.700184000 t4900 US
11 2.701075000 t4900 US Bu
12 2.701583000 t4900 US
11 2.702150000 t4900 US Su
13 2.702628000 sched nsubmitted 117.000000
13 2.704131000 sched nready 114.000000
9 2.704131000 pu p 140
12 2.705585000 t4900 US
11 2.706480000 t4900 US Bu
12 2.706985000 t4900 US
11 2.708821000 t4900 US Su
13 2.709332000 sched nsubmitted 118.000000
13 2.710865000 sched nready 115.000000
9 2.710865000 pu p 141
12 2.712353000 t4900 US
11 2.713274000 t4900 US Bu
12 2.713795000 t4900 US
11 2.714376000 t4900 US Su
13 2.714855000 sched nsubmitted 119.000000
13 2.716395000 sched nready 116.000000
9 2.716395000 pu p 142
12 2.717874000 t4900 US
11 2.718785000 t4900 US Bu
12 2.719299000 t4900 US
11 2.719869000 t4900 US Su
13 2.720340000 sched nsubmitted 120.000000
13 2.721913000 sched nready 117.000000
9 2.721913000 pu p 143
12 2.723375000 t4900 US
11 2.724282000 t4900 US Bu
12 2.724797000 t4900 US
11 2.725362000 t4900 US Su
13 2.725844000 sched nsubmitted 121.000000
13 2.727429000 sched nready 118.000000
9 2.727429000 pu p 144
12 2.728878000 t4900 US
11 2.730962000 t4900 US Bu
12 2.731502000 t4900 US
11 2.732086000 t4900 US Su
13 2.732561000 sched nsubmitted 122.000000
13 2.734109000 sched nready 119.000000
9 2.734109000 pu p 145
12 2.735621000 t4900 US
11 2.736574000 t4900 US Bu
12 2.737089000 t4900 US
11 2.737676000 t4900 US Su
13 2.738150000 sched nsubmitted 123.000000
13 2.739785000 sched nready 120.000000
9 2.739785000 pu p 146
12 2.741248000 t4900 US
11 2.742155000 t4900 US Bu
12 2.742670000 t4900 US
11 2.743237000 t4900 US Su
13 2.743707000 sched nsubmitted 124.000000
13 2.745253000 sched nready 121.000000
9 2.745253000 pu p 147
12 2.746746000 t4900 US
11 2.748831000 t4900 US Bu
12 2.749376000 t4900 US
11 2.749959000 t4900 US Su
13 2.750429000 sched nsubmitted 125.000000
13 2.751970000 sched nready 122.000000
9 2.751970000 pu p 148
12 2.753451000 t4900 US
11 2.754374000 t4900 US Bu
12 2.754887000 t4900 US
11 2.755461000 t4900 US Su
13 2.755926000 sched nsubmitted 126.000000
13 2.757666000 sched nready 123.000000
9 2.757666000 pu p 149
12 2.759135000 t4900 US
11 2.760040000 t4900 US Bu
12 2.760553000 t4900 US
11 2.761128000 t4900 US Su
13 2.761599000 sched nsubmitted 127.000000
13 2.763121000 sched nready 124.000000
9 2.763121000 pu p 150
12 2.764564000 t4900 US
11 2.765455000 t4900 US Bu
12 2.765969000 t4900 US
11 2.767754000 t4900 US Su
13 2.768264000 sched nsubmitted 128.000000
13 2.769804000 sched nready 125.000000
9 2.769804000 pu p 151
12 2.771277000 t4900 US
11 2.772218000 t4900 US Bu
12 2.772734000 t4900 US
11 2.773302000 t4900 US Su
13 2.773774000 sched nsubmitted 129.000000
13 2.775436000 sched nready 126.000000
9 2.775436000 pu p 152
12 2.776906000 t4900 US
11 2.777820000 t4900 US Bu
12 2.778333000 t4900 US
11 2.778903000 t4900 US Su
13 2.779372000 sched nsubmitted 130.000000
13 2.780910000 sched nready 127.000000
9 2.780910000 pu p 153
12 2.782383000 t4900 US
11 2.783285000 t4900 US Bu
12 2.783800000 t4900 US
11 2.784379000 t4900 US Su
13 2.784847000 sched nsubmitted 131.000000
13 2.786429000 sched nready 128.000000
9 2.786429000 pu p 154
12 2.787879000 t4900 US
11 2.789984000 t4900 US Bu
12 2.790535000 t4900 US
11 2.791126000 t4900 US Su
13 2.791596000 sched nsubmitted 132.000000
13 2.793142000 sched nready 129.000000
9 2.793142000 pu p 155
12 2.794615000 t4900 US
11 2.795572000 t4900 US Bu
12 2.796077000 t4900 US
11 2.796645000 t4900 US Su
13 2.797112000 sched nsubmitted 133.000000
13 2.798701000 sched nready 130.000000
9 2.798701000 pu p 156
12 2.800171000 t4900 US
11 2.801053000 t4900 US Bu
12 2.801566000 t4900 US
11 2.802181000 t4900 US Su
13 2.802655000 sched nsubmitted 134.000000
13 2.804196000 sched nready 131.000000
9 2.804196000 pu p 157
12 2.805650000 t4900 US
11 2.806537000 t4900 US Bu
12 2.807046000 t4900 US
11 2.808826000 t4900 US Su
13 2.809336000 sched nsubmitted 135.000000
13 2.810962000 sched nready 132.000000
9 2.810962000 pu p 158
12 2.812438000 t4900 US
11 2.813375000 t4900 US Bu
12 2.813900000 t4900 US
11 2.814489000 t4900 US Su
13 2.814958000 sched nsubmitted 136.000000
13 2.816561000 sched nready 133.000000
9 2.816561000 pu p 159
12 2.818036000 t4900 US
11 2.818936000 t4900 US Bu
12 2.819443000 t4900 US
11 2.820010000 t4900 US Su
13 2.820486000 sched nsubmitted 137.000000
13 2.822015000 sched nready 134.000000
9 2.822015000 pu p 160
12 2.823472000 t4900 US
11 2.824361000 t4900 US Bu
12 2.824885000 t4900 US
11 2.826688000 t4900 US Su
13 2.827188000 sched nsubmitted 138.000000
13 2.828731000 sched nready 135.000000
9 2.828731000 pu p 161
12 2.830205000 t4900 US
11 2.831127000 t4900 US Bu
12 2.831646000 t4900 US
11 2.832219000 t4900 US Su
13 2.832690000 sched nsubmitted 139.000000
13 2.834430000 sched nready 136.000000
9 2.834430000 pu p 162
12 2.835895000 t4900 US
11 2.836818000 t4900 US Bu
12 2.837334000 t4900 US
11 2.837911000 t4900 US Su
13 2.838380000 sched nsubmitted 140.000000
13 2.840296000 sched nready 137.000000
9 2.840296000 pu p 163
12 2.841743000 t4900 US
11 2.842646000 t4900 US Bu
12 2.843161000 t4900 US
11 2.843734000 t4900 US Su
13 2.844203000 sched nsubmitted 141.000000
13 2.845745000 sched nready 138.000000
9 2.845745000 pu p 164
12 2.847204000 t4900 US
11 2.849272000 t4900 US Bu
12 2.849805000 t4900 US
11 2.850389000 t4900 US Su
13 2.850866000 sched nsubmitted 142.000000
13 2.852491000 sched nready 139.000000
9 2.852491000 pu p 165
12 2.853962000 t4900 US
11 2.854922000 t4900 US Bu
12 2.855427000 t4900 US
11 2.856008000 t4900 US Su
13 2.856489000 sched nsubmitted 143.000000
13 2.858065000 sched nready 140.000000
9 2.858065000 pu p 166
12 2.859518000 t4900 US
11 2.860404000 t4900 US Bu
12 2.860913000 t4900 US
11 2.861485000 t4900 US Su
13 2.861956000 sched nsubmitted 144.000000
13 2.863465000 sched nready 141.000000
9 2.863465000 pu p 167
12 2.864909000 t4900 US
11 2.865812000 t4900 US Bu
12 2.866322000 t4900 US
11 2.868197000 t4900 US Su
13 2.868710000 sched nsubmitted 145.000000
13 2.870317000 sched nready 142.000000
9 2.870317000 pu p 168
12 2.871794000 t4900 US
11 2.872750000 t4900 US Bu
12 2.873261000 t4900 US
11 2.873844000 t4900 US Su
13 2.874326000 sched nsubmitted 146.000000
13 2.875963000 sched nready 143.000000
9 2.875963000 pu p 169
12 2.877423000 t4900 US
11 2.878344000 t4900 US Bu
12 2.878855000 t4900 US
11 2.879426000 t4900 US Su
13 2.879900000 sched nsubmitted 147.000000
13 2.881474000 sched nready 144.000000
9 2.881474000 pu p 170
12 2.882940000 t4900 US
11 2.883845000 t4900 US Bu
12 2.884358000 t4900 US
11 2.886996000 t4900 US Su
13 2.887536000 sched nsubmitted 148.000000
13 2.889104000 sched nready 145.000000
9 2.889104000 pu p 171
12 2.890582000 t4900 US
11 2.891545000 t4900 US Bu
12 2.892066000 t4900 US
11 2.892650000 t4900 US Su
13 2.893119000 sched nsubmitted 149.000000
13 2.895056000 sched nready 146.000000
9 2.895056000 pu p 172
12 2.896514000 t4900 US
11 2.897408000 t4900 US Bu
12 2.897915000 t4900 US
11 2.898505000 t4900 US Su
13 2.898972000 sched nsubmitted 150.000000
13 2.900465000 sched nready 147.000000
9 2.900465000 pu p 173
12 2.901909000 t4900 US
11 2.902803000 t4900 US Bu
12 2.903319000 t4900 US
11 2.903890000 t4900 US Su
13 2.904359000 sched nsubmitted 151.000000
13 2.905893000 sched nready 148.000000
9 2.905893000 pu p 174
12 2.907343000 t4900 US
11 2.909428000 t4900 US Bu
12 2.909963000 t4900 US
11 2.910540000 t4900 US Su
13 2.911010000 sched nsubmitted 152.000000
13 2.912652000 sched nready 149.000000
9 2.912652000 pu p 175
12 2.914143000 t4900 US
11 2.915067000 t4900 US Bu
12 2.915577000 t4900 US
11 2.916154000 t4900 US Su
13 2.916621000 sched nsubmitted 153.000000
13 2.918143000 sched nready 150.000000
9 2.918143000 pu p 176
12 2.919614000 t4900 US
11 2.920532000 t4900 US Bu
12 2.921046000 t4900 US
11 2.921613000 t4900 US Su
13 2.922082000 sched nsubmitted 154.000000
13 2.923536000 sched nready 151.000000
9 2.923536000 pu p 177
12 2.925000000 t4900 US
11 2.925916000 t4900 US Bu
12 2.926425000 t4900 US
11 2.928263000 t4900 US Su
13 2.928772000 sched nsubmitted 155.000000
13 2.930429000 sched nready 152.000000
9 2.930429000 pu p 178
12 2.931920000 t4900 US
11 2.932882000 t4900 US Bu
12 2.933412000 t4900 US
11 2.933994000 t4900 US Su
13 2.934464000 sched nsubmitted 156.000000
13 2.935984000 sched nready 153.000000
9 2.935984000 pu p 179
12 2.937492000 t4900 US
11 2.938397000 t4900 US Bu
12 2.938910000 t4900 US
11 2.939473000 t4900 US Su
13 2.939949000 sched nsubmitted 157.000000
13 2.941516000 sched nready 154.000000
9 2.941516000 pu p 180
12 2.942983000 t4900 US
11 2.943893000 t4900 US Bu
12 2.944394000 t4900 US
11 2.944960000 t4900 US Su
13 2.945432000 sched nsubmitted 158.000000
13 2.947196000 sched nready 155.000000
9 2.947196000 pu p 181
12 2.948656000 t4900 US
11 2.950751000 t4900 US Bu
12 2.951282000 t4900 US
11 2.951863000 t4900 US Su
13 2.952339000 sched nsubmitted 159.000000
13 2.953956000 sched nready 156.000000
9 2.953956000 pu p 182
12 2.955430000 t4900 US
11 2.956355000 t4900 US Bu
12 2.956861000 t4900 US
11 2.957441000 t4900 US Su
13 2.957922000 sched nsubmitted 160.000000
13 2.959432000 sched nready 157.000000
9 2.959432000 pu p 183
12 2.960887000 t4900 US
11 2.961797000 t4900 US Bu
12 2.962319000 t4900 US
11 2.962910000 t4900 US Su
13 2.963377000 sched nsubmitted 161.000000
13 2.964898000 sched nready 158.000000
9 2.964898000 pu p 184
12 2.966349000 t4900 US
11 2.967249000 t4900 US Bu
12 2.967768000 t4900 US
11 2.971699000 t4900 US Su
13 2.972231000 sched nsubmitted 162.000000
13 2.974090000 sched nready 159.000000
9 2.974090000 pu p 185
12 2.975601000 t4900 US
11 2.976620000 t4900 US Bu
12 2.977165000 t4900 US
11 2.977760000 t4900 US Su
13 2.978233000 sched nsubmitted 163.000000
13 2.979820000 sched nready 160.000000
9 2.979820000 pu p 186
12 2.981301000 t4900 US
11 2.982215000 t4900 US Bu
12 2.982730000 t4900 US
11 2.983316000 t4900 US Su
13 2.983785000 sched nsubmitted 164.000000
13 2.985376000 sched nready 161.000000
9 2.985376000 pu p 187
12 2.986838000 t4900 US
11 2.987736000 t4900 US Bu
12 2.988253000 t4900 US
11 2.990031000 t4900 US Su
13 2.990545000 sched nsubmitted 165.000000
13 2.992265000 sched nready 162.000000
9 2.992265000 pu p 188
12 2.993730000 t4900 US
11 2.994755000 t4900 US Bu
12 2.995282000 t4900 US
11 2.995864000 t4900 US Su
13 2.996350000 sched nsubmitted 166.000000
13 2.997852000 sched nready 163.000000
9 2.997852000 pu p 189
12 2.999309000 t4900 US
11 3.000222000 t4900 US Bu
12 3.000738000 t4900 US
11 3.001318000 t4900 US Su
13 3.001791000 sched nsubmitted 167.000000
13 3.003302000 sched nready 164.000000
9 3.003302000 pu p 190
12 3.004761000 t4900 US
11 3.005653000 t4900 US Bu
12 3.006177000 t4900 US
11 3.006747000 t4900 US Su
13 3.007245000 sched nsubmitted 168.000000
13 3.008950000 sched nready 165.000000
9 3.008950000 pu p 191
12 3.010418000 t4900 US
11 3.012534000 t4900 US Bu
12 3.013064000 t4900 US
11 3.013637000 t4900 US Su
13 3.014116000 sched nsubmitted 169.000000
13 3.015835000 sched nready 166.000000
9 3.015835000 pu p 192
12 3.017300000 t4900 US
11 3.018252000 t4900 US Bu
12 3.018760000 t4900 US
11 3.019324000 t4900 US Su
13 3.019796000 sched nsubmitted 170.000000
13 3.021310000 sched nready 167.000000
9 3.021310000 pu p 193
12 3.022762000 t4900 US
11 3.023651000 t4900 US Bu
12 3.024157000 t4900 US
11 3.024722000 t4900 US Su
13 3.025195000 sched nsubmitted 171.000000
13 3.026864000 sched nready 168.000000
9 3.026864000 pu p 194
12 3.028324000 t4900 US
11 3.029227000 t4900 US Bu
12 3.029743000 t4900 US
11 3.031545000 t4900 US Su
13 3.032056000 sched nsubmitted 172.000000
13 3.033720000 sched nready 169.000000
9 3.033720000 pu p 195
12 3.035191000 t4900 US
11 3.036145000 t4900 US Bu
12 3.036702000 t4900 US
11 3.037278000 t4900 US Su
13 3.037768000 sched nsubmitted 173.000000
13 3.039311000 sched nready 170.000000
9 3.039311000 pu p 196
12 3.040782000 t4900 US
11 3.041694000 t4900 US Bu
12 3.042212000 t4900 US
11 3.042780000 t4900 US Su
13 3.043247000 sched nsubmitted 174.000000
13 3.044765000 sched nready 171.000000
9 3.044765000 pu p 197
12 3.046219000 t4900 US
11 3.047112000 t4900 US Bu
12 3.047625000 t4900 US
11 3.049423000 t4900 US Su
13 3.049923000 sched nsubmitted 175.000000
13 3.051623000 sched nready 172.000000
9 3.051623000 pu p 198
12 3.053095000 t4900 US
11 3.054048000 t4900 US Bu
12 3.054562000 t4900 US
11 3.055138000 t4900 US Su
13 3.055614000 sched nsubmitted 176.000000
13 3.057245000 sched nready 173.000000
9 3.057245000 pu p 199
12 3.058715000 t4900 US
11 3.059594000 t4900 US Bu
12 3.060116000 t4900 US
11 3.060692000 t4900 US Su
13 3.061172000 sched nsubmitted 177.000000
13 3.062692000 sched nready 174.000000
9 3.062692000 pu p 200
12 3.064167000 t4900 US
11 3.065078000 t4900 US Bu
12 3.065585000 t4900 US
11 3.066145000 t4900 US Su
13 3.066618000 sched nsubmitted 178.000000
13 3.068385000 sched nready 175.000000
9 3.068385000 pu p 201
12 3.069839000 t4900 US
11 3.071923000 t4900 US Bu
12 3.072457000 t4900 US
11 3.073060000 t4900 US Su
13 3.073544000 sched nsubmitted 179.000000
13 3.075191000 sched nready 176.000000
9 3.075191000 pu p 202
12 3.076719000 t4900 US
11 3.077685000 t4900 US Bu
12 3.078198000 t4900 US
11 3.078781000 t4900 US Su
13 3.079255000 sched nsubmitted 180.000000
13 3.080779000 sched nready 177.000000
9 3.080779000 pu p 203
12 3.082235000 t4900 US
11 3.083137000 t4900 US Bu
12 3.083647000 t4900 US
11 3.084221000 t4900 US Su
13 3.084690000 sched nsubmitted 181.000000
13 3.086484000 sched nready 178.000000
9 3.086484000 pu p 204
12 3.087935000 t4900 US
11 3.088824000 t4900 US Bu
12 3.089330000 t4900 US
11 3.091131000 t4900 US Su
13 3.091634000 sched nsubmitted 182.000000
13 3.093195000 sched nready 179.000000
9 3.093195000 pu p 205
12 3.094664000 t4900 US
11 3.095642000 t4900 US Bu
12 3.096165000 t4900 US
11 3.096740000 t4900 US Su
13 3.097209000 sched nsubmitted 183.000000
13 3.098715000 sched nready 180.000000
9 3.098715000 pu p 206
12 3.100188000 t4900 US
11 3.101109000 t4900 US Bu
12 3.101634000 t4900 US
11 3.102208000 t4900 US Su
13 3.102684000 sched nsubmitted 184.000000
13 3.104260000 sched nready 181.000000
9 3.104260000 pu p 207
12 3.105719000 t4900 US
11 3.106646000 t4900 US Bu
12 3.107169000 t4900 US
11 3.107739000 t4900 US Su
13 3.108216000 sched nsubmitted 185.000000
13 3.109857000 sched nready 182.000000
9 3.109857000 pu p 208
12 3.111325000 t4900 US
11 3.113457000 t4900 US Bu
12 3.114000000 t4900 US
11 3.114595000 t4900 US Su
13 3.115066000 sched nsubmitted 186.000000
13 3.116613000 sched nready 183.000000
9 3.116613000 pu p 209
12 3.118092000 t4900 US
11 3.119044000 t4900 US Bu
12 3.119577000 t4900 US
11 3.120154000 t4900 US Su
13 3.120620000 sched nsubmitted 187.000000
13 3.122145000 sched nready 184.000000
9 3.122145000 pu p 210
12 3.123595000 t4900 US
11 3.124478000 t4900 US Bu
12 3.124982000 t4900 US
11 3.125554000 t4900 US Su
13 3.126024000 sched nsubmitted 188.000000
13 3.127553000 sched nready 185.000000
9 3.127553000 pu p 211
12 3.129017000 t4900 US
11 3.131083000 t4900 US Bu
12 3.131619000 t4900 US
11 3.132193000 t4900 US Su
13 3.132667000 sched nsubmitted 189.000000
13 3.134273000 sched nready 186.000000
9 3.134273000 pu p 212
12 3.135743000 t4900 US
11 3.136669000 t4900 US Bu
12 3.137226000 t4900 US
11 3.137803000 t4900 US Su
13 3.138279000 sched nsubmitted 190.000000
13 3.139813000 sched nready 187.000000
9 3.139813000 pu p 213
12 3.141275000 t4900 US
11 3.142194000 t4900 US Bu
12 3.142784000 t4900 US
11 3.143361000 t4900 US Su
13 3.143830000 sched nsubmitted 191.000000
13 3.145587000 sched nready 188.000000
9 3.145587000 pu p 214
12 3.147063000 t4900 US
11 3.147999000 t4900 US Bu
12 3.148514000 t4900 US
11 3.150341000 t4900 US Su
13 3.150845000 sched nsubmitted 192.000000
13 3.152457000 sched nready 189.000000
9 3.152457000 pu p 215
12 3.153933000 t4900 US
11 3.154904000 t4900 US Bu
12 3.155425000 t4900 US
11 3.156013000 t4900 US Su
13 3.156478000 sched nsubmitted 193.000000
13 3.157994000 sched nready 190.000000
9 3.157994000 pu p 216
12 3.159468000 t4900 US
11 3.160391000 t4900 US Bu
12 3.160911000 t4900 US
11 3.161486000 t4900 US Su
13 3.161959000 sched nsubmitted 194.000000
13 3.163560000 sched nready 191.000000
9 3.163560000 pu p 217
12 3.165032000 t4900 US
11 3.165950000 t4900 US Bu
12 3.166468000 t4900 US
11 3.167032000 t4900 US Su
13 3.167506000 sched nsubmitted 195.000000
13 3.169050000 sched nready 192.000000
9 3.169050000 pu p 218
12 3.170526000 t4900 US
11 3.173490000 t4900 US Bu
12 3.174043000 t4900 US
11 3.174639000 t4900 US Su
13 3.175133000 sched nsubmitted 196.000000
13 3.177003000 sched nready 193.000000
9 3.177003000 pu p 219
12 3.178480000 t4900 US
11 3.179447000 t4900 US Bu
12 3.179954000 t4900 US
11 3.180527000 t4900 US Su
13 3.181008000 sched nsubmitted 197.000000
13 3.182636000 sched nready 194.000000
9 3.182636000 pu p 220
12 3.184088000 t4900 US
11 3.184981000 t4900 US Bu
12 3.185495000 t4900 US
11 3.186059000 t4900 US Su
13 3.186534000 sched nsubmitted 198.000000
13 3.188082000 sched nready 195.000000
9 3.188082000 pu p 221
12 3.189559000 t4900 US
11 3.190453000 t4900 US Bu
12 3.190963000 t4900 US
11 3.192807000 t4900 US Su
13 3.193297000 sched nsubmitted 199.000000
13 3.194825000 sched nready 196.000000
9 3.194825000 pu p 222
12 3.196307000 t4900 US
11 3.197245000 t4900 US Bu
12 3.197770000 t4900 US
11 3.198351000 t4900 US Su
13 3.198826000 sched nsubmitted 200.000000
13 3.200345000 sched nready 197.000000
9 3.200345000 pu p 223
12 3.201828000 t4900 US
11 3.202745000 t4900 US Bu
12 3.203263000 t4900 US
11 3.203833000 t4900 US Su
13 3.204305000 sched nsubmitted 201.000000
13 3.205876000 sched nready 198.000000
9 3.205876000 pu p 224
12 3.207347000 t4900 US
11 3.208243000 t4900 US Bu
12 3.208758000 t4900 US
11 3.210599000 t4900 US Su
13 3.211105000 sched nsubmitted 202.000000
13 3.212628000 sched nready 199.000000
9 3.212628000 pu p 225
12 3.214093000 t4900 US
11 3.215039000 t4900 US Bu
12 3.215550000 t4900 US
11 3.216138000 t4900 US Su
13 3.216607000 sched nsubmitted 203.000000
13 3.218107000 sched nready 200.000000
9 3.218107000 pu p 226
12 3.219557000 t4900 US
11 3.220457000 t4900 US Bu
12 3.220960000 t4900 US
11 3.221538000 t4900 US Su
13 3.222007000 sched nsubmitted 204.000000
13 3.223716000 sched nready 201.000000
9 3.223716000 pu p 227
12 3.225162000 t4900 US
11 3.226046000 t4900 US Bu
12 3.226562000 t4900 US
11 3.227129000 t4900 US Su
13 3.227601000 sched nsubmitted 205.000000
13 3.229110000 sched nready 202.000000
9 3.229110000 pu p 228
12 3.230555000 t4900 US
11 3.232667000 t4900 US Bu
12 3.233221000 t4900 US
11 3.233799000 t4900 US Su
13 3.234273000 sched nsubmitted 206.000000
13 3.235843000 sched nready 203.000000
9 3.235843000 pu p 229
12 3.237315000 t4900 US
11 3.238243000 t4900 US Bu
12 3.238766000 t4900 US
11 3.239338000 t4900 US Su
13 3.239810000 sched nsubmitted 207.000000
13 3.241425000 sched nready 204.000000
9 3.241425000 pu p 230
12 3.242875000 t4900 US
11 3.243772000 t4900 US Bu
12 3.244525000 t4900 US
11 3.245103000 t4900 US Su
13 3.245584000 sched nsubmitted 208.000000
13 3.247125000 sched nready 205.000000
9 3.247125000 pu p 231
12 3.248574000 t4900 US
11 3.249486000 t4900 US Bu
12 3.250005000 t4900 US
11 3.251812000 t4900 US Su
13 3.252313000 sched nsubmitted 209.000000
13 3.253904000 sched nready 206.000000
9 3.253904000 pu p 232
12 3.255362000 t4900 US
11 3.256317000 t4900 US Bu
12 3.256834000 t4900 US
11 3.257404000 t4900 US Su
13 3.257872000 sched nsubmitted 210.000000
13 3.259875000 sched nready 207.000000
9 3.259875000 pu p 233
12 3.261342000 t4900 US
11 3.262225000 t4900 US Bu
12 3.262735000 t4900 US
11 3.263301000 t4900 US Su
13 3.263777000 sched nsubmitted 211.000000
13 3.265335000 sched nready 208.000000
9 3.265335000 pu p 234
12 3.266796000 t4900 US
11 3.267674000 t4900 US Bu
12 3.268185000 t4900 US
11 3.269960000 t4900 US Su
13 3.270468000 sched nsubmitted 212.000000
13 3.271997000 sched nready 209.000000
9 3.271997000 pu p 235
12 3.273462000 t4900 US
11 3.274396000 t4900 US Bu
12 3.274905000 t4900 US
11 3.275475000 t4900 US Su
13 3.275941000 sched nsubmitted 213.000000
13 3.277483000 sched nready 210.000000
9 3.277483000 pu p 236
12 3.278979000 t4900 US
11 3.279880000 t4900 US Bu
12 3.280391000 t4900 US
11 3.280960000 t4900 US Su
13 3.281429000 sched nsubmitted 214.000000
13 3.283033000 sched nready 211.000000
9 3.283033000 pu p 237
12 3.284490000 t4900 US
11 3.285392000 t4900 US Bu
12 3.285896000 t4900 US
11 3.286465000 t4900 US Su
13 3.286931000 sched nsubmitted 215.000000
13 3.288446000 sched nready 212.000000
9 3.288446000 pu p 238
12 3.289897000 t4900 US
11 3.291989000 t4900 US Bu
12 3.292508000 t4900 US
11 3.293091000 t4900 US Su
13 3.293558000 sched nsubmitted 216.000000
13 3.295107000 sched nready 213.000000
9 3.295107000 pu p 239
12 3.296595000 t4900 US
11 3.297555000 t4900 US Bu
12 3.298071000 t4900 US
11 3.298637000 t4900 US Su
13 3.299118000 sched nsubmitted 217.000000
13 3.300706000 sched nready 214.000000
9 3.300706000 pu p 240
12 3.302168000 t4900 US
11 3.303069000 t4900 US Bu
12 3.303579000 t4900 US
11 3.304156000 t4900 US Su
13 3.304625000 sched nsubmitted 218.000000
13 3.306202000 sched nready 215.000000
9 3.306202000 pu p 241
12 3.307656000 t4900 US
11 3.308541000 t4900 US Bu
12 3.309052000 t4900 US
11 3.310903000 t4900 US Su
13 3.311425000 sched nsubmitted 219.000000
13 3.313024000 sched nready 216.000000
9 3.313024000 pu p 242
12 3.314491000 t4900 US
11 3.315423000 t4900 US Bu
12 3.315925000 t4900 US
11 3.316507000 t4900 US Su
13 3.316984000 sched nsubmitted 220.000000
13 3.318522000 sched nready 217.000000
9 3.318522000 pu p 243
12 3.319988000 t4900 US
11 3.320894000 t4900 US Bu
12 3.321406000 t4900 US
11 3.321982000 t4900 US Su
13 3.322459000 sched nsubmitted 221.000000
13 3.324055000 sched nready 218.000000
9 3.324055000 pu p 244
12 3.325517000 t4900 US
11 3.326425000 t4900 US Bu
12 3.326933000 t4900 US
11 3.327506000 t4900 US Su
13 3.327971000 sched nsubmitted 222.000000
13 3.329511000 sched nready 219.000000
9 3.329511000 pu p 245
12 3.330968000 t4900 US
11 3.333062000 t4900 US Bu
12 3.333606000 t4900 US
11 3.334190000 t4900 US Su
13 3.334658000 sched nsubmitted 223.000000
13 3.336325000 sched nready 220.000000
9 3.336325000 pu p 246
12 3.337803000 t4900 US
11 3.338742000 t4900 US Bu
12 3.339256000 t4900 US
11 3.339830000 t4900 US Su
13 3.340312000 sched nsubmitted 224.000000
13 3.341918000 sched nready 221.000000
9 3.341918000 pu p 247
12 3.343379000 t4900 US
11 3.344303000 t4900 US Bu
12 3.344815000 t4900 US
11 3.345421000 t4900 US Su
13 3.345891000 sched nsubmitted 225.000000
13 3.347462000 sched nready 222.000000
9 3.347462000 pu p 248
12 3.348915000 t4900 US
11 3.349840000 t4900 US Bu
12 3.350355000 t4900 US
11 3.352176000 t4900 US Su
13 3.352679000 sched nsubmitted 226.000000
13 3.354237000 sched nready 223.000000
9 3.354237000 pu p 249
12 3.355709000 t4900 US
11 3.356625000 t4900 US Bu
12 3.357154000 t4900 US
11 3.357732000 t4900 US Su
13 3.358205000 sched nsubmitted 227.000000
13 3.359810000 sched nready 224.000000
9 3.359810000 pu p 250
12 3.361268000 t4900 US
11 3.362168000 t4900 US Bu
12 3.362671000 t4900 US
11 3.363239000 t4900 US Su
13 3.363707000 sched nsubmitted 228.000000
13 3.365334000 sched nready 225.000000
9 3.365334000 pu p 251
12 3.366788000 t4900 US
11 3.367679000 t4900 US Bu
12 3.368196000 t4900 US
11 3.370001000 t4900 US Su
13 3.370516000 sched nsubmitted 229.000000
13 3.372063000 sched nready 226.000000
9 3.372063000 pu p 252
12 3.373538000 t4900 US
11 3.374469000 t4900 US Bu
12 3.374994000 t4900 US
11 3.375570000 t4900 US Su
13 3.376036000 sched nsubmitted 230.000000
13 3.377886000 sched nready 227.000000
9 3.377886000 pu p 253
12 3.379349000 t4900 US
11 3.380252000 t4900 US Bu
12 3.380758000 t4900 US
11 3.381336000 t4900 US Su
13 3.381807000 sched nsubmitted 231.000000
13 3.383344000 sched nready 228.000000
9 3.383344000 pu p 254
12 3.384808000 t4900 US
11 3.385708000 t4900 US Bu
12 3.386237000 t4900 US
11 3.386816000 t4900 US Su
13 3.387279000 sched nsubmitted 232.000000
13 3.388899000 sched nready 229.000000
9 3.388899000 pu p 255
12 3.390369000 t4900 US
11 3.392488000 t4900 US Bu
12 3.393015000 t4900 US
11 3.393596000 t4900 US Su
13 3.394069000 sched nsubmitted 233.000000
13 3.395832000 sched nready 230.000000
9 3.395832000 pu p 256
12 3.397316000 t4900 US
11 3.398273000 t4900 US Bu
12 3.398786000 t4900 US
11 3.399368000 t4900 US Su
13 3.399839000 sched nsubmitted 234.000000
13 3.401408000 sched nready 231.000000
9 3.401408000 pu p 257
12 3.402875000 t4900 US
11 3.403761000 t4900 US Bu
12 3.404265000 t4900 US
11 3.404834000 t4900 US Su
13 3.405309000 sched nsubmitted 235.000000
13 3.406825000 sched nready 232.000000
9 3.406825000 pu p 258
12 3.408283000 t4900 US
11 3.409177000 t4900 US Bu
12 3.409692000 t4900 US
11 3.411500000 t4900 US Su
13 3.412011000 sched nsubmitted 236.000000
13 3.413739000 sched nready 233.000000
9 3.413739000 pu p 259
12 3.415207000 t4900 US
11 3.416170000 t4900 US Bu
12 3.416675000 t4900 US
11 3.417235000 t4900 US Su
13 3.417702000 sched nsubmitted 237.000000
13 3.419253000 sched nready 234.000000
9 3.419253000 pu p 260
12 3.420722000 t4900 US
11 3.421634000 t4900 US Bu
12 3.422145000 t4900 US
11 3.422719000 t4900 US Su
13 3.423194000 sched nsubmitted 238.000000
13 3.424723000 sched nready 235.000000
9 3.424723000 pu p 261
12 3.426201000 t4900 US
11 3.427123000 t4900 US Bu
12 3.427633000 t4900 US
11 3.429398000 t4900 US Su
13 3.429899000 sched nsubmitted 239.000000
13 3.431451000 sched nready 236.000000
9 3.431451000 pu p 262
12 3.432934000 t4900 US
11 3.433877000 t4900 US Bu
12 3.434390000 t4900 US
11 3.434965000 t4900 US Su
13 3.435440000 sched nsubmitted 240.000000
13 3.437005000 sched nready 237.000000
9 3.437005000 pu p 263
12 3.438465000 t4900 US
11 3.439367000 t4900 US Bu
12 3.439874000 t4900 US
11 3.440431000 t4900 US Su
13 3.440894000 sched nsubmitted 241.000000
13 3.442420000 sched nready 238.000000
9 3.442420000 pu p 264
12 3.443882000 t4900 US
11 3.444799000 t4900 US Bu
12 3.445303000 t4900 US
11 3.445866000 t4900 US Su
13 3.446335000 sched nsubmitted 242.000000
13 3.447881000 sched nready 239.000000
9 3.447881000 pu p 265
12 3.449393000 t4900 US
11 3.452347000 t4900 US Bu
12 3.452883000 t4900 US
11 3.453467000 t4900 US Su
13 3.453946000 sched nsubmitted 243.000000
13 3.455880000 sched nready 240.000000
9 3.455880000 pu p 266
12 3.457368000 t4900 US
11 3.458338000 t4900 US Bu
12 3.458849000 t4900 US
11 3.459428000 t4900 US Su
13 3.459907000 sched nsubmitted 244.000000
13 3.461444000 sched nready 241.000000
9 3.461444000 pu p 267
12 3.462907000 t4900 US
11 3.463823000 t4900 US Bu
12 3.464344000 t4900 US
11 3.464920000 t4900 US Su
13 3.465390000 sched nsubmitted 245.000000
13 3.466924000 sched nready 242.000000
9 3.466924000 pu p 268
12 3.468374000 t4900 US
11 3.469289000 t4900 US Bu
12 3.469812000 t4900 US
11 3.471581000 t4900 US Su
13 3.472091000 sched nsubmitted 246.000000
13 3.473736000 sched nready 243.000000
9 3.473736000 pu p 269
12 3.475210000 t4900 US
11 3.476138000 t4900 US Bu
12 3.476667000 t4900 US
11 3.477233000 t4900 US Su
13 3.477701000 sched nsubmitted 247.000000
13 3.479450000 sched nready 244.000000
9 3.479450000 pu p 270
12 3.480957000 t4900 US
11 3.481870000 t4900 US Bu
12 3.482386000 t4900 US
11 3.482950000 t4900 US Su
13 3.483422000 sched nsubmitted 248.000000
13 3.484981000 sched nready 245.000000
9 3.484981000 pu p 271
12 3.486455000 t4900 US
11 3.487351000 t4900 US Bu
12 3.487860000 t4900 US
11 3.488422000 t4900 US Su
13 3.488901000 sched nsubmitted 249.000000
13 3.490524000 sched nready 246.000000
9 3.490524000 pu p 272
12 3.491993000 t4900 US
11 3.494075000 t4900 US Bu
12 3.494596000 t4900 US
11 3.495176000 t4900 US Su
13 3.495646000 sched nsubmitted 250.000000
13 3.497248000 sched nready 247.000000
9 3.497248000 pu p 273
12 3.498729000 t4900 US
11 3.499701000 t4900 US Bu
12 3.500221000 t4900 US
11 3.500791000 t4900 US Su
13 3.501261000 sched nsubmitted 251.000000
13 3.502786000 sched nready 248.000000
9 3.502786000 pu p 274
12 3.504248000 t4900 US
11 3.505144000 t4900 US Bu
12 3.505659000 t4900 US
11 3.506213000 t4900 US Su
13 3.506677000 sched nsubmitted 252.000000
13 3.508258000 sched nready 249.000000
9 3.508258000 pu p 275
12 3.509692000 t4900 US
11 3.511839000 t4900 US Bu
12 3.512376000 t4900 US
11 3.512937000 t4900 US Su
13 3.513415000 sched nsubmitted 253.000000
13 3.515011000 sched nready 250.000000
9 3.515011000 pu p 276
12 3.516501000 t4900 US
11 3.517447000 t4900 US Bu
12 3.517964000 t4900 US
11 3.518533000 t4900 US Su
13 3.519005000 sched nsubmitted 254.000000
13 3.520554000 sched nready 251.000000
9 3.520554000 pu p 277
12 3.522008000 t4900 US
11 3.522916000 t4900 US Bu
12 3.523424000 t4900 US
11 3.524000000 t4900 US Su
13 3.524470000 sched nsubmitted 255.000000
13 3.525980000 sched nready 252.000000
9 3.525980000 pu p 278
12 3.527436000 t4900 US
11 3.528352000 t4900 US Bu
12 3.528872000 t4900 US
11 3.530660000 t4900 US Su
13 3.531170000 sched nsubmitted 256.000000
13 3.532791000 sched nready 253.000000
9 3.532791000 pu p 279
12 3.534257000 t4900 US
11 3.535219000 t4900 US Bu
12 3.535737000 t4900 US
11 3.536294000 t4900 US Su
13 3.536766000 sched nsubmitted 257.000000
13 3.538323000 sched nready 254.000000
9 3.538323000 pu p 280
12 3.539778000 t4900 US
11 3.540414000 t4900 US Bu
12 3.541056000 t4900 US
11 3.541619000 t4900 US Su
13 3.542186000 sched nsubmitted 258.000000
13 3.544121000 sched nready 255.000000
9 3.544121000 pu p 281
12 3.545575000 t4900 US
11 3.546156000 t4900 US Bu
12 3.546708000 t4900 US
11 3.547348000 t4900 US Su
13 3.547882000 sched nsubmitted 259.000000
13 3.549527000 sched nready 256.000000
9 3.549527000 pu p 282
12 3.550971000 t4900 US
11 3.552741000 t4900 US Bu
12 3.553266000 t4900 US
11 3.553925000 t4900 US Su
13 3.554440000 sched nsubmitted 260.000000
12 3.556546000 t4900 US
11 3.557175000 t4900 US Bu
12 3.557721000 t4900 US
11 3.558289000 t4900 US Su
13 3.558784000 sched nsubmitted 261.000000
13 3.560407000 sched nready 257.000000
9 3.560407000 pu p 284
12 3.561914000 t4900 US
11 3.562504000 t4900 US Bu
12 3.563055000 t4900 US
11 3.563618000 t4900 US Su
13 3.564161000 sched nsubmitted 262.000000
13 3.565993000 sched nready 258.000000
9 3.565993000 pu p 285
12 3.567464000 t4900 US
11 3.569255000 t4900 US Bu
12 3.569789000 t4900 US
11 3.570451000 t4900 US Su
13 3.570963000 sched nsubmitted 263.000000
13 3.572843000 sched nready 259.000000
9 3.572843000 pu p 286
12 3.574315000 t4900 US
11 3.574900000 t4900 US Bu
12 3.575464000 t4900 US
11 3.576031000 t4900 US Su
13 3.576560000 sched nsubmitted 264.000000
13 3.578224000 sched nready 260.000000
9 3.578224000 pu p 287
12 3.579707000 t4900 US
11 3.580350000 t4900 US Bu
12 3.580898000 t4900 US
11 3.581459000 t4900 US Su
13 3.581942000 sched nsubmitted 265.000000
12 3.586224000 t4900 US
11 3.586855000 t4900 US Bu
12 3.587420000 t4900 US
11 3.587976000 t4900 US Su
13 3.588528000 sched nsubmitted 266.000000
13 3.590205000 sched nready 261.000000
9 3.590205000 pu p 289
12 3.591676000 t4900 US
11 3.592256000 t4900 US Bu
12 3.592804000 t4900 US
11 3.593353000 t4900 US Su
13 3.593878000 sched nsubmitted 267.000000
13 3.595469000 sched nready 262.000000
9 3.595469000 pu p 290
12 3.596921000 t4900 US
11 3.597501000 t4900 US Bu
12 3.598010000 t4900 US
11 3.598572000 t4900 US Su
13 3.599059000 sched nsubmitted 268.000000
12 3.600892000 t4900 US
11 3.602750000 t4900 US Bu
12 3.603316000 t4900 US
11 3.603918000 t4900 US Su
13 3.604498000 sched nsubmitted 269.000000
13 3.606109000 sched nready 263.000000
9 3.606109000 pu p 292
12 3.607596000 t4900 US
11 3.608202000 t4900 US Bu
12 3.608704000 t4900 US
11 3.609267000 t4900 US Su
13 3.609739000 sched nsubmitted 270.000000
13 3.611298000 sched nready 264.000000
9 3.611298000 pu p 293
12 3.612756000 t4900 US
11 3.613349000 t4900 US Bu
12 3.613861000 t4900 US
11 3.614425000 t4900 US Su
13 3.614894000 sched nsubmitted 271.000000
13 3.616661000 sched nready 265.000000
9 3.616661000 pu p 294
12 3.618109000 t4900 US
11 3.618711000 t4900 US Bu
12 3.619221000 t4900 US
11 3.622190000 t4900 US Su
13 3.622779000 sched nsubmitted 272.000000
13 3.624371000 sched nready 266.000000
9 3.624371000 pu p 295
12 3.625873000 t4900 US
11 3.626503000 t4900 US Bu
12 3.627051000 t4900 US
11 3.627623000 t4900 US Su
13 3.628099000 sched nsubmitted 273.000000
12 3.630585000 t4900 US
11 3.634878000 t4900 US WA
10 9.913635000 t4912 S B
10 9.919040000 w0 WS "I"
13 2.008564000 w0 gf 0.000000
13 9.927638000 sched nready 265.000000
13 9.927638000 sched nsubmitted 272.000000
9 9.927638000 po p 31
10 9.929356000 w0 WS "Fi"
6 B22_6 WS B22_6 "0.000000 0.600000 0.400000"
6 B22_6_1 Ctx1 B22_6 "1.0 0.39 1.0"
6 B22_6_2 Ctx2 B22_6 ".0 1.0 .0"
6 B22_6_3 Ctx3 B22_6 "0.87 0.87 .0"
6 B22_6_4 Ctx4 B22_6 ".0 0.95 1.0"
6 B22_6_5 Ctx5 B22_6 ".0 .0 .0"
6 B22_6_6 Ctx6 B22_6 ".0 .0 0.5"
6 B22_6_7 Ctx7 B22_6 "0.41 0.41 0.41"
6 B22_6_8 Ctx8 B22_6 "1.0 .0 1.0"
6 B22_6_9 Ctx9 B22_6 ".0 .0 1.0"
10 9.931628000 w0 WS "B22_6"
20 9.931628000 w0 WS B22_6 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 31
31 0.000000 0 0 -1 -1
10 9.933489000 t4912 S E
10 9.946582000 t4915 S B
10 9.948883000 w3 WS "I"
13 1.933446000 w3 gf 0.000000
13 1.989453000 w3 gf 0.000000
13 1.958496000 sched gft 0.000000
13 1.989453000 sched gft 0.000000
13 2.008564000 sched gft 0.000000
13 9.953940000 sched nready 264.000000
13 9.953940000 sched nsubmitted 271.000000
9 9.953940000 po p 28
10 9.955269000 w3 WS "Fi"
6 B22_3 WS B22_3 "0.000000 0.600000 0.400000"
6 B22_3_1 Ctx1 B22_3 "1.0 0.39 1.0"
6 B22_3_2 Ctx2 B22_3 ".0 1.0 .0"
6 B22_3_3 Ctx3 B22_3 "0.87 0.87 .0"
6 B22_3_4 Ctx4 B22_3 ".0 0.95 1.0"
6 B22_3_5 Ctx5 B22_3 ".0 .0 .0"
6 B22_3_6 Ctx6 B22_3 ".0 .0 0.5"
6 B22_3_7 Ctx7 B22_3 "0.41 0.41 0.41"
6 B22_3_8 Ctx8 B22_3 "1.0 .0 1.0"
6 B22_3_9 Ctx9 B22_3 ".0 .0 1.0"
10 9.957328000 w3 WS "B22_3"
20 9.957328000 w3 WS B22_3 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 28
28 0.000000 0 0 -1 -1
10 9.958757000 t4915 S E
10 10.029244000 t4913 S B
10 10.031270000 w1 WS "I"
13 2.103798000 w1 gf 0.000000
13 2.103798000 sched gft 0.000000
13 10.036317000 sched nready 263.000000
13 10.036317000 sched nsubmitted 270.000000
9 10.036317000 po p 38
10 10.037626000 w1 WS "Fi"
6 B22_13 WS B22_13 "0.000000 0.600000 0.400000"
6 B22_13_1 Ctx1 B22_13 "1.0 0.39 1.0"
6 B22_13_2 Ctx2 B22_13 ".0 1.0 .0"
6 B22_13_3 Ctx3 B22_13 "0.87 0.87 .0"
6 B22_13_4 Ctx4 B22_13 ".0 0.95 1.0"
6 B22_13_5 Ctx5 B22_13 ".0 .0 .0"
6 B22_13_6 Ctx6 B22_13 ".0 .0 0.5"
6 B22_13_7 Ctx7 B22_13 "0.41 0.41 0.41"
6 B22_13_8 Ctx8 B22_13 "1.0 .0 1.0"
6 B22_13_9 Ctx9 B22_13 ".0 .0 1.0"
10 10.039683000 w1 WS "B22_13"
20 10.039683000 w1 WS B22_13 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 38
38 0.000000 0 0 -1 -1
10 10.041130000 t4913 S E
10 10.119399000 t4916 S B
10 10.121852000 w4 WS "I"
13 2.221050000 w4 gf 0.000000
13 2.221050000 sched gft 0.000000
13 10.126892000 sched nready 262.000000
13 10.126892000 sched nsubmitted 269.000000
9 10.126892000 po p 35
10 10.128137000 w4 WS "Fi"
6 B22_10 WS B22_10 "0.000000 0.600000 0.400000"
6 B22_10_1 Ctx1 B22_10 "1.0 0.39 1.0"
6 B22_10_2 Ctx2 B22_10 ".0 1.0 .0"
6 B22_10_3 Ctx3 B22_10 "0.87 0.87 .0"
6 B22_10_4 Ctx4 B22_10 ".0 0.95 1.0"
6 B22_10_5 Ctx5 B22_10 ".0 .0 .0"
6 B22_10_6 Ctx6 B22_10 ".0 .0 0.5"
6 B22_10_7 Ctx7 B22_10 "0.41 0.41 0.41"
6 B22_10_8 Ctx8 B22_10 "1.0 .0 1.0"
6 B22_10_9 Ctx9 B22_10 ".0 .0 1.0"
10 10.130178000 w4 WS "B22_10"
20 10.130178000 w4 WS B22_10 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 35
35 0.000000 0 0 -1 -1
10 10.131514000 t4916 S E
10 10.275011000 t4914 S B
10 10.277017000 w2 WS "I"
13 2.302305000 w2 gf 0.000000
13 10.282243000 sched nready 261.000000
13 10.282243000 sched nsubmitted 268.000000
9 10.282243000 po p 33
10 10.298120000 w2 WS "Fi"
6 B22_8 WS B22_8 "0.000000 0.600000 0.400000"
6 B22_8_1 Ctx1 B22_8 "1.0 0.39 1.0"
6 B22_8_2 Ctx2 B22_8 ".0 1.0 .0"
6 B22_8_3 Ctx3 B22_8 "0.87 0.87 .0"
6 B22_8_4 Ctx4 B22_8 ".0 0.95 1.0"
6 B22_8_5 Ctx5 B22_8 ".0 .0 .0"
6 B22_8_6 Ctx6 B22_8 ".0 .0 0.5"
6 B22_8_7 Ctx7 B22_8 "0.41 0.41 0.41"
6 B22_8_8 Ctx8 B22_8 "1.0 .0 1.0"
6 B22_8_9 Ctx9 B22_8 ".0 .0 1.0"
10 10.300147000 w2 WS "B22_8"
20 10.300147000 w2 WS B22_8 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 33
33 0.000000 0 0 -1 -1
10 10.301468000 t4914 S E
10 10.884150000 t4917 S B
10 10.887011000 w5 WS "I"
13 2.222486000 w5 gf 0.000000
13 2.222486000 sched gft 0.000000
13 2.302305000 sched gft 0.000000
13 10.893131000 sched nready 260.000000
13 10.893131000 sched nsubmitted 267.000000
9 10.893131000 po p 36
10 10.894450000 w5 WS "Fi"
6 B22_11 WS B22_11 "0.000000 0.600000 0.400000"
6 B22_11_1 Ctx1 B22_11 "1.0 0.39 1.0"
6 B22_11_2 Ctx2 B22_11 ".0 1.0 .0"
6 B22_11_3 Ctx3 B22_11 "0.87 0.87 .0"
6 B22_11_4 Ctx4 B22_11 ".0 0.95 1.0"
6 B22_11_5 Ctx5 B22_11 ".0 .0 .0"
6 B22_11_6 Ctx6 B22_11 ".0 .0 0.5"
6 B22_11_7 Ctx7 B22_11 "0.41 0.41 0.41"
6 B22_11_8 Ctx8 B22_11 "1.0 .0 1.0"
6 B22_11_9 Ctx9 B22_11 ".0 .0 1.0"
10 10.896629000 w5 WS "B22_11"
20 10.896629000 w5 WS B22_11 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 36
36 0.000000 0 0 -1 -1
10 10.898137000 t4917 S E
10 18.093152000 t4915 S B
10 18.105201000 w3 WS "I"
13 9.948883000 w3 gf 0.000000
13 18.121854000 sched nready 259.000000
13 18.121854000 sched nsubmitted 266.000000
9 18.121854000 po p 34
10 18.123821000 w3 WS "Fi"
6 B22_9 WS B22_9 "0.000000 0.600000 0.400000"
6 B22_9_1 Ctx1 B22_9 "1.0 0.39 1.0"
6 B22_9_2 Ctx2 B22_9 ".0 1.0 .0"
6 B22_9_3 Ctx3 B22_9 "0.87 0.87 .0"
6 B22_9_4 Ctx4 B22_9 ".0 0.95 1.0"
6 B22_9_5 Ctx5 B22_9 ".0 .0 .0"
6 B22_9_6 Ctx6 B22_9 ".0 .0 0.5"
6 B22_9_7 Ctx7 B22_9 "0.41 0.41 0.41"
6 B22_9_8 Ctx8 B22_9 "1.0 .0 1.0"
6 B22_9_9 Ctx9 B22_9 ".0 .0 1.0"
10 18.127858000 w3 WS "B22_9"
20 18.127858000 w3 WS B22_9 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 34
34 0.000000 0 0 -1 -1
10 18.131837000 t4915 S E
10 18.207800000 t4916 S B
10 18.212072000 w4 WS "I"
13 10.121852000 w4 gf 0.000000
13 18.220242000 sched nready 258.000000
13 18.220242000 sched nsubmitted 265.000000
9 18.220242000 po p 41
10 18.221602000 w4 WS "Fi"
6 B22_16 WS B22_16 "0.000000 0.600000 0.400000"
6 B22_16_1 Ctx1 B22_16 "1.0 0.39 1.0"
6 B22_16_2 Ctx2 B22_16 ".0 1.0 .0"
6 B22_16_3 Ctx3 B22_16 "0.87 0.87 .0"
6 B22_16_4 Ctx4 B22_16 ".0 0.95 1.0"
6 B22_16_5 Ctx5 B22_16 ".0 .0 .0"
6 B22_16_6 Ctx6 B22_16 ".0 .0 0.5"
6 B22_16_7 Ctx7 B22_16 "0.41 0.41 0.41"
6 B22_16_8 Ctx8 B22_16 "1.0 .0 1.0"
6 B22_16_9 Ctx9 B22_16 ".0 .0 1.0"
10 18.224435000 w4 WS "B22_16"
20 18.224435000 w4 WS B22_16 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 41
41 0.000000 0 0 -1 -1
10 18.226057000 t4916 S E
10 18.297147000 t4914 S B
10 18.300508000 w2 WS "I"
13 10.277017000 w2 gf 0.000000
13 18.310105000 sched nready 257.000000
13 18.310105000 sched nsubmitted 264.000000
9 18.310105000 po p 39
10 18.311452000 w2 WS "Fi"
6 B22_14 WS B22_14 "0.000000 0.600000 0.400000"
6 B22_14_1 Ctx1 B22_14 "1.0 0.39 1.0"
6 B22_14_2 Ctx2 B22_14 ".0 1.0 .0"
6 B22_14_3 Ctx3 B22_14 "0.87 0.87 .0"
6 B22_14_4 Ctx4 B22_14 ".0 0.95 1.0"
6 B22_14_5 Ctx5 B22_14 ".0 .0 .0"
6 B22_14_6 Ctx6 B22_14 ".0 .0 0.5"
6 B22_14_7 Ctx7 B22_14 "0.41 0.41 0.41"
6 B22_14_8 Ctx8 B22_14 "1.0 .0 1.0"
6 B22_14_9 Ctx9 B22_14 ".0 .0 1.0"
10 18.315235000 w2 WS "B22_14"
20 18.315235000 w2 WS B22_14 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 39
39 0.000000 0 0 -1 -1
10 18.317751000 t4914 S E
10 18.623502000 t4913 S B
10 18.628242000 w1 WS "I"
13 10.031270000 w1 gf 0.000000
13 18.639495000 sched nready 256.000000
13 18.639495000 sched nsubmitted 263.000000
9 18.639495000 po p 16
10 18.641583000 w1 WS "Fi"
6 B12 WS B12 "0.000000 0.600000 0.400000"
6 B12_1 Ctx1 B12 "1.0 0.39 1.0"
6 B12_2 Ctx2 B12 ".0 1.0 .0"
6 B12_3 Ctx3 B12 "0.87 0.87 .0"
6 B12_4 Ctx4 B12 ".0 0.95 1.0"
6 B12_5 Ctx5 B12 ".0 .0 .0"
6 B12_6 Ctx6 B12 ".0 .0 0.5"
6 B12_7 Ctx7 B12 "0.41 0.41 0.41"
6 B12_8 Ctx8 B12 "1.0 .0 1.0"
6 B12_9 Ctx9 B12 ".0 .0 1.0"
10 18.646411000 w1 WS "B12"
20 18.646411000 w1 WS B12 196608
M8192x1x8_M8192x1x8_M8192x1x8 ec48135f 0000000000000000 16
16 0.000000 0 0 -1 -1
10 18.649068000 t4913 S E
10 18.718136000 t4913 S B
10 18.719807000 w1 WS "I"
13 18.628242000 w1 gf 0.000000
13 18.727366000 sched nready 255.000000
13 18.727366000 sched nsubmitted 262.000000
9 18.727366000 po p 44
10 18.728844000 w1 WS "Fi"
6 B22_19 WS B22_19 "0.000000 0.600000 0.400000"
6 B22_19_1 Ctx1 B22_19 "1.0 0.39 1.0"
6 B22_19_2 Ctx2 B22_19 ".0 1.0 .0"
6 B22_19_3 Ctx3 B22_19 "0.87 0.87 .0"
6 B22_19_4 Ctx4 B22_19 ".0 0.95 1.0"
6 B22_19_5 Ctx5 B22_19 ".0 .0 .0"
6 B22_19_6 Ctx6 B22_19 ".0 .0 0.5"
6 B22_19_7 Ctx7 B22_19 "0.41 0.41 0.41"
6 B22_19_8 Ctx8 B22_19 "1.0 .0 1.0"
6 B22_19_9 Ctx9 B22_19 ".0 .0 1.0"
10 18.731400000 w1 WS "B22_19"
20 18.731400000 w1 WS B22_19 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 44
44 0.000000 0 0 -1 -1
10 18.733334000 t4913 S E
10 18.981872000 t4917 S B
10 18.985491000 w5 WS "I"
13 10.887011000 w5 gf 0.000000
13 18.993312000 sched nready 254.000000
13 18.993312000 sched nsubmitted 261.000000
9 18.993312000 po p 42
10 18.994968000 w5 WS "Fi"
6 B22_17 WS B22_17 "0.000000 0.600000 0.400000"
6 B22_17_1 Ctx1 B22_17 "1.0 0.39 1.0"
6 B22_17_2 Ctx2 B22_17 ".0 1.0 .0"
6 B22_17_3 Ctx3 B22_17 "0.87 0.87 .0"
6 B22_17_4 Ctx4 B22_17 ".0 0.95 1.0"
6 B22_17_5 Ctx5 B22_17 ".0 .0 .0"
6 B22_17_6 Ctx6 B22_17 ".0 .0 0.5"
6 B22_17_7 Ctx7 B22_17 "0.41 0.41 0.41"
6 B22_17_8 Ctx8 B22_17 "1.0 .0 1.0"
6 B22_17_9 Ctx9 B22_17 ".0 .0 1.0"
10 18.997784000 w5 WS "B22_17"
20 18.997784000 w5 WS B22_17 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 42
42 0.000000 0 0 -1 -1
10 18.999326000 t4917 S E
10 20.216749000 t4912 S B
10 20.221139000 w0 WS "I"
13 9.919040000 w0 gf 0.000000
13 9.919040000 sched gft 0.000000
13 9.948883000 sched gft 0.000000
13 10.031270000 sched gft 0.000000
13 10.121852000 sched gft 0.000000
13 10.277017000 sched gft 0.000000
13 10.887011000 sched gft 0.000000
13 20.229172000 sched nready 253.000000
13 20.229172000 sched nsubmitted 260.000000
9 20.229172000 po p 37
10 20.230561000 w0 WS "Fi"
6 B22_12 WS B22_12 "0.000000 0.600000 0.400000"
6 B22_12_1 Ctx1 B22_12 "1.0 0.39 1.0"
6 B22_12_2 Ctx2 B22_12 ".0 1.0 .0"
6 B22_12_3 Ctx3 B22_12 "0.87 0.87 .0"
6 B22_12_4 Ctx4 B22_12 ".0 0.95 1.0"
6 B22_12_5 Ctx5 B22_12 ".0 .0 .0"
6 B22_12_6 Ctx6 B22_12 ".0 .0 0.5"
6 B22_12_7 Ctx7 B22_12 "0.41 0.41 0.41"
6 B22_12_8 Ctx8 B22_12 "1.0 .0 1.0"
6 B22_12_9 Ctx9 B22_12 ".0 .0 1.0"
10 20.233465000 w0 WS "B22_12"
20 20.233465000 w0 WS B22_12 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 37
37 0.000000 0 0 -1 -1
10 20.235263000 t4912 S E
10 25.972460000 t4915 S B
10 25.979449000 w3 WS "I"
13 18.105201000 w3 gf 0.000000
13 18.105201000 sched gft 0.000000
13 25.990545000 sched nready 252.000000
13 25.990545000 sched nsubmitted 259.000000
9 25.990545000 po p 40
10 25.992060000 w3 WS "Fi"
6 B22_15 WS B22_15 "0.000000 0.600000 0.400000"
6 B22_15_1 Ctx1 B22_15 "1.0 0.39 1.0"
6 B22_15_2 Ctx2 B22_15 ".0 1.0 .0"
6 B22_15_3 Ctx3 B22_15 "0.87 0.87 .0"
6 B22_15_4 Ctx4 B22_15 ".0 0.95 1.0"
6 B22_15_5 Ctx5 B22_15 ".0 .0 .0"
6 B22_15_6 Ctx6 B22_15 ".0 .0 0.5"
6 B22_15_7 Ctx7 B22_15 "0.41 0.41 0.41"
6 B22_15_8 Ctx8 B22_15 "1.0 .0 1.0"
6 B22_15_9 Ctx9 B22_15 ".0 .0 1.0"
10 25.995183000 w3 WS "B22_15"
20 25.995183000 w3 WS B22_15 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 40
40 0.000000 0 0 -1 -1
10 25.997135000 t4915 S E
10 26.051883000 t4916 S B
10 26.053877000 w4 WS "I"
13 18.212072000 w4 gf 0.000000
13 18.212072000 sched gft 0.000000
13 26.058995000 sched nready 251.000000
13 26.058995000 sched nsubmitted 258.000000
9 26.058995000 po p 47
10 26.060560000 w4 WS "Fi"
6 B22_22 WS B22_22 "0.000000 0.600000 0.400000"
6 B22_22_1 Ctx1 B22_22 "1.0 0.39 1.0"
6 B22_22_2 Ctx2 B22_22 ".0 1.0 .0"
6 B22_22_3 Ctx3 B22_22 "0.87 0.87 .0"
6 B22_22_4 Ctx4 B22_22 ".0 0.95 1.0"
6 B22_22_5 Ctx5 B22_22 ".0 .0 .0"
6 B22_22_6 Ctx6 B22_22 ".0 .0 0.5"
6 B22_22_7 Ctx7 B22_22 "0.41 0.41 0.41"
6 B22_22_8 Ctx8 B22_22 "1.0 .0 1.0"
6 B22_22_9 Ctx9 B22_22 ".0 .0 1.0"
10 26.062767000 w4 WS "B22_22"
20 26.062767000 w4 WS B22_22 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 47
47 0.000000 0 0 -1 -1
10 26.064062000 t4916 S E
10 26.091565000 t4914 S B
10 26.094836000 w2 WS "I"
13 18.300508000 w2 gf 0.000000
13 18.300508000 sched gft 0.000000
13 18.628242000 sched gft 0.000000
13 26.102285000 sched nready 250.000000
13 26.102285000 sched nsubmitted 257.000000
9 26.102285000 po p 45
10 26.103660000 w2 WS "Fi"
6 B22_20 WS B22_20 "0.000000 0.600000 0.400000"
6 B22_20_1 Ctx1 B22_20 "1.0 0.39 1.0"
6 B22_20_2 Ctx2 B22_20 ".0 1.0 .0"
6 B22_20_3 Ctx3 B22_20 "0.87 0.87 .0"
6 B22_20_4 Ctx4 B22_20 ".0 0.95 1.0"
6 B22_20_5 Ctx5 B22_20 ".0 .0 .0"
6 B22_20_6 Ctx6 B22_20 ".0 .0 0.5"
6 B22_20_7 Ctx7 B22_20 "0.41 0.41 0.41"
6 B22_20_8 Ctx8 B22_20 "1.0 .0 1.0"
6 B22_20_9 Ctx9 B22_20 ".0 .0 1.0"
10 26.105990000 w2 WS "B22_20"
20 26.105990000 w2 WS B22_20 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 45
45 0.000000 0 0 -1 -1
10 26.107208000 t4914 S E
10 26.751150000 t4917 S B
10 26.753415000 w5 WS "I"
13 18.985491000 w5 gf 0.000000
13 26.758493000 sched nready 249.000000
13 26.758493000 sched nsubmitted 256.000000
9 26.758493000 po p 48
10 26.759806000 w5 WS "Fi"
6 B22_23 WS B22_23 "0.000000 0.600000 0.400000"
6 B22_23_1 Ctx1 B22_23 "1.0 0.39 1.0"
6 B22_23_2 Ctx2 B22_23 ".0 1.0 .0"
6 B22_23_3 Ctx3 B22_23 "0.87 0.87 .0"
6 B22_23_4 Ctx4 B22_23 ".0 0.95 1.0"
6 B22_23_5 Ctx5 B22_23 ".0 .0 .0"
6 B22_23_6 Ctx6 B22_23 ".0 .0 0.5"
6 B22_23_7 Ctx7 B22_23 "0.41 0.41 0.41"
6 B22_23_8 Ctx8 B22_23 "1.0 .0 1.0"
6 B22_23_9 Ctx9 B22_23 ".0 .0 1.0"
10 26.761985000 w5 WS "B22_23"
20 26.761985000 w5 WS B22_23 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 48
48 0.000000 0 0 -1 -1
10 26.763282000 t4917 S E
10 27.202996000 t4913 S B
10 27.206268000 w1 WS "I"
13 18.719807000 w1 gf 0.000000
13 18.719807000 sched gft 0.000000
13 18.985491000 sched gft 0.000000
13 27.231166000 sched nready 248.000000
13 27.231166000 sched nsubmitted 255.000000
9 27.231166000 po p 50
10 27.232700000 w1 WS "Fi"
6 B22_25 WS B22_25 "0.000000 0.600000 0.400000"
6 B22_25_1 Ctx1 B22_25 "1.0 0.39 1.0"
6 B22_25_2 Ctx2 B22_25 ".0 1.0 .0"
6 B22_25_3 Ctx3 B22_25 "0.87 0.87 .0"
6 B22_25_4 Ctx4 B22_25 ".0 0.95 1.0"
6 B22_25_5 Ctx5 B22_25 ".0 .0 .0"
6 B22_25_6 Ctx6 B22_25 ".0 .0 0.5"
6 B22_25_7 Ctx7 B22_25 "0.41 0.41 0.41"
6 B22_25_8 Ctx8 B22_25 "1.0 .0 1.0"
6 B22_25_9 Ctx9 B22_25 ".0 .0 1.0"
10 27.235283000 w1 WS "B22_25"
20 27.235283000 w1 WS B22_25 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 50
50 0.000000 0 0 -1 -1
10 27.236806000 t4913 S E
10 28.489201000 t4912 S B
10 28.502436000 w0 WS "I"
13 20.221139000 w0 gf 0.000000
13 20.221139000 sched gft 0.000000
13 28.541281000 sched nready 247.000000
13 28.541281000 sched nsubmitted 254.000000
9 28.541281000 po p 43
10 28.562423000 w0 WS "Fi"
6 B22_18 WS B22_18 "0.000000 0.600000 0.400000"
6 B22_18_1 Ctx1 B22_18 "1.0 0.39 1.0"
6 B22_18_2 Ctx2 B22_18 ".0 1.0 .0"
6 B22_18_3 Ctx3 B22_18 "0.87 0.87 .0"
6 B22_18_4 Ctx4 B22_18 ".0 0.95 1.0"
6 B22_18_5 Ctx5 B22_18 ".0 .0 .0"
6 B22_18_6 Ctx6 B22_18 ".0 .0 0.5"
6 B22_18_7 Ctx7 B22_18 "0.41 0.41 0.41"
6 B22_18_8 Ctx8 B22_18 "1.0 .0 1.0"
6 B22_18_9 Ctx9 B22_18 ".0 .0 1.0"
10 28.568671000 w0 WS "B22_18"
20 28.568671000 w0 WS B22_18 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 43
43 0.000000 0 0 -1 -1
10 28.571918000 t4912 S E
10 38.282991000 t4915 S B
10 38.294407000 w3 WS "I"
13 25.979449000 w3 gf 0.000000
13 25.979449000 sched gft 0.000000
13 38.310870000 sched nready 246.000000
13 38.310870000 sched nsubmitted 253.000000
9 38.310870000 po p 46
10 38.312495000 w3 WS "Fi"
6 B22_21 WS B22_21 "0.000000 0.600000 0.400000"
6 B22_21_1 Ctx1 B22_21 "1.0 0.39 1.0"
6 B22_21_2 Ctx2 B22_21 ".0 1.0 .0"
6 B22_21_3 Ctx3 B22_21 "0.87 0.87 .0"
6 B22_21_4 Ctx4 B22_21 ".0 0.95 1.0"
6 B22_21_5 Ctx5 B22_21 ".0 .0 .0"
6 B22_21_6 Ctx6 B22_21 ".0 .0 0.5"
6 B22_21_7 Ctx7 B22_21 "0.41 0.41 0.41"
6 B22_21_8 Ctx8 B22_21 "1.0 .0 1.0"
6 B22_21_9 Ctx9 B22_21 ".0 .0 1.0"
10 38.316119000 w3 WS "B22_21"
20 38.316119000 w3 WS B22_21 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 46
46 0.000000 0 0 -1 -1
10 38.318185000 t4915 S E
10 38.418634000 t4916 S B
10 38.421575000 w4 WS "I"
13 26.053877000 w4 gf 0.000000
13 26.053877000 sched gft 0.000000
13 38.427445000 sched nready 245.000000
13 38.427445000 sched nsubmitted 252.000000
9 38.427445000 po p 53
10 38.429019000 w4 WS "Fi"
6 B22_28 WS B22_28 "0.000000 0.600000 0.400000"
6 B22_28_1 Ctx1 B22_28 "1.0 0.39 1.0"
6 B22_28_2 Ctx2 B22_28 ".0 1.0 .0"
6 B22_28_3 Ctx3 B22_28 "0.87 0.87 .0"
6 B22_28_4 Ctx4 B22_28 ".0 0.95 1.0"
6 B22_28_5 Ctx5 B22_28 ".0 .0 .0"
6 B22_28_6 Ctx6 B22_28 ".0 .0 0.5"
6 B22_28_7 Ctx7 B22_28 "0.41 0.41 0.41"
6 B22_28_8 Ctx8 B22_28 "1.0 .0 1.0"
6 B22_28_9 Ctx9 B22_28 ".0 .0 1.0"
10 38.431264000 w4 WS "B22_28"
20 38.431264000 w4 WS B22_28 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 53
53 0.000000 0 0 -1 -1
10 38.432614000 t4916 S E
10 38.439584000 t4914 S B
10 38.442033000 w2 WS "I"
13 26.094836000 w2 gf 0.000000
13 26.094836000 sched gft 0.000000
13 38.447954000 sched nready 244.000000
13 38.447954000 sched nsubmitted 251.000000
9 38.447954000 po p 51
10 38.449297000 w2 WS "Fi"
6 B22_26 WS B22_26 "0.000000 0.600000 0.400000"
6 B22_26_1 Ctx1 B22_26 "1.0 0.39 1.0"
6 B22_26_2 Ctx2 B22_26 ".0 1.0 .0"
6 B22_26_3 Ctx3 B22_26 "0.87 0.87 .0"
6 B22_26_4 Ctx4 B22_26 ".0 0.95 1.0"
6 B22_26_5 Ctx5 B22_26 ".0 .0 .0"
6 B22_26_6 Ctx6 B22_26 ".0 .0 0.5"
6 B22_26_7 Ctx7 B22_26 "0.41 0.41 0.41"
6 B22_26_8 Ctx8 B22_26 "1.0 .0 1.0"
6 B22_26_9 Ctx9 B22_26 ".0 .0 1.0"
10 38.451505000 w2 WS "B22_26"
20 38.451505000 w2 WS B22_26 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 51
51 0.000000 0 0 -1 -1
10 38.452797000 t4914 S E
10 39.151548000 t4917 S B
10 39.154164000 w5 WS "I"
13 26.753415000 w5 gf 0.000000
13 26.753415000 sched gft 0.000000
13 39.160106000 sched nready 243.000000
13 39.160106000 sched nsubmitted 250.000000
9 39.160106000 po p 54
10 39.161503000 w5 WS "Fi"
6 B22_29 WS B22_29 "0.000000 0.600000 0.400000"
6 B22_29_1 Ctx1 B22_29 "1.0 0.39 1.0"
6 B22_29_2 Ctx2 B22_29 ".0 1.0 .0"
6 B22_29_3 Ctx3 B22_29 "0.87 0.87 .0"
6 B22_29_4 Ctx4 B22_29 ".0 0.95 1.0"
6 B22_29_5 Ctx5 B22_29 ".0 .0 .0"
6 B22_29_6 Ctx6 B22_29 ".0 .0 0.5"
6 B22_29_7 Ctx7 B22_29 "0.41 0.41 0.41"
6 B22_29_8 Ctx8 B22_29 "1.0 .0 1.0"
6 B22_29_9 Ctx9 B22_29 ".0 .0 1.0"
10 39.163767000 w5 WS "B22_29"
20 39.163767000 w5 WS B22_29 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 54
54 0.000000 0 0 -1 -1
10 39.165211000 t4917 S E
10 39.622385000 t4913 S B
10 39.626486000 w1 WS "I"
13 27.206268000 w1 gf 0.000000
13 27.206268000 sched gft 0.000000
13 39.633692000 sched nready 242.000000
13 39.633692000 sched nsubmitted 249.000000
9 39.633692000 po p 56
10 39.635076000 w1 WS "Fi"
6 B22_31 WS B22_31 "0.000000 0.600000 0.400000"
6 B22_31_1 Ctx1 B22_31 "1.0 0.39 1.0"
6 B22_31_2 Ctx2 B22_31 ".0 1.0 .0"
6 B22_31_3 Ctx3 B22_31 "0.87 0.87 .0"
6 B22_31_4 Ctx4 B22_31 ".0 0.95 1.0"
6 B22_31_5 Ctx5 B22_31 ".0 .0 .0"
6 B22_31_6 Ctx6 B22_31 ".0 .0 0.5"
6 B22_31_7 Ctx7 B22_31 "0.41 0.41 0.41"
6 B22_31_8 Ctx8 B22_31 "1.0 .0 1.0"
6 B22_31_9 Ctx9 B22_31 ".0 .0 1.0"
10 39.637620000 w1 WS "B22_31"
20 39.637620000 w1 WS B22_31 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 56
56 0.000000 0 0 -1 -1
10 39.639263000 t4913 S E
10 40.167984000 t4912 S B
10 40.171118000 w0 WS "I"
13 28.502436000 w0 gf 0.000000
13 28.502436000 sched gft 0.000000
13 40.177810000 sched nready 241.000000
13 40.177810000 sched nsubmitted 248.000000
9 40.177810000 po p 49
10 40.179171000 w0 WS "Fi"
6 B22_24 WS B22_24 "0.000000 0.600000 0.400000"
6 B22_24_1 Ctx1 B22_24 "1.0 0.39 1.0"
6 B22_24_2 Ctx2 B22_24 ".0 1.0 .0"
6 B22_24_3 Ctx3 B22_24 "0.87 0.87 .0"
6 B22_24_4 Ctx4 B22_24 ".0 0.95 1.0"
6 B22_24_5 Ctx5 B22_24 ".0 .0 .0"
6 B22_24_6 Ctx6 B22_24 ".0 .0 0.5"
6 B22_24_7 Ctx7 B22_24 "0.41 0.41 0.41"
6 B22_24_8 Ctx8 B22_24 "1.0 .0 1.0"
6 B22_24_9 Ctx9 B22_24 ".0 .0 1.0"
10 40.181564000 w0 WS "B22_24"
20 40.181564000 w0 WS B22_24 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 49
49 0.000000 0 0 -1 -1
10 40.183227000 t4912 S E
10 48.477923000 t4916 S B
10 48.536397000 t4914 S B
10 48.540755000 w4 WS "I"
13 38.421575000 w4 gf 0.000000
10 48.546028000 w2 WS "I"
13 38.442033000 w2 gf 0.000000
13 48.598411000 sched nready 240.000000
13 48.598411000 sched nsubmitted 247.000000
9 48.598411000 po p 59
13 48.598694000 sched nready 239.000000
13 48.598694000 sched nsubmitted 246.000000
9 48.598694000 po p 57
10 48.602501000 w2 WS "Fi"
10 48.602582000 w4 WS "Fi"
6 B22_34 WS B22_34 "0.000000 0.600000 0.400000"
6 B22_34_1 Ctx1 B22_34 "1.0 0.39 1.0"
6 B22_34_2 Ctx2 B22_34 ".0 1.0 .0"
6 B22_34_3 Ctx3 B22_34 "0.87 0.87 .0"
6 B22_34_4 Ctx4 B22_34 ".0 0.95 1.0"
6 B22_34_5 Ctx5 B22_34 ".0 .0 .0"
6 B22_34_6 Ctx6 B22_34 ".0 .0 0.5"
6 B22_34_7 Ctx7 B22_34 "0.41 0.41 0.41"
6 B22_34_8 Ctx8 B22_34 "1.0 .0 1.0"
6 B22_34_9 Ctx9 B22_34 ".0 .0 1.0"
10 48.614747000 w4 WS "B22_34"
6 B22_32 WS B22_32 "0.000000 0.600000 0.400000"
6 B22_32_1 Ctx1 B22_32 "1.0 0.39 1.0"
6 B22_32_2 Ctx2 B22_32 ".0 1.0 .0"
6 B22_32_3 Ctx3 B22_32 "0.87 0.87 .0"
6 B22_32_4 Ctx4 B22_32 ".0 0.95 1.0"
6 B22_32_5 Ctx5 B22_32 ".0 .0 .0"
6 B22_32_6 Ctx6 B22_32 ".0 .0 0.5"
6 B22_32_7 Ctx7 B22_32 "0.41 0.41 0.41"
6 B22_32_8 Ctx8 B22_32 "1.0 .0 1.0"
6 B22_32_9 Ctx9 B22_32 ".0 .0 1.0"
10 48.615531000 w2 WS "B22_32"
20 48.615531000 w2 WS B22_32 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 57
57 0.000000 0 0 -1 -1
20 48.614747000 w4 WS B22_34 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 59
59 0.000000 0 0 -1 -1
10 48.624588000 t4916 S E
10 48.624943000 t4914 S E
10 48.935150000 t4915 S B
10 48.952545000 w3 WS "I"
13 38.294407000 w3 gf 0.000000
13 38.294407000 sched gft 0.000000
13 38.421575000 sched gft 0.000000
13 38.442033000 sched gft 0.000000
13 49.003458000 sched nready 238.000000
13 49.003458000 sched nsubmitted 245.000000
9 49.003458000 po p 52
10 49.007118000 w3 WS "Fi"
6 B22_27 WS B22_27 "0.000000 0.600000 0.400000"
6 B22_27_1 Ctx1 B22_27 "1.0 0.39 1.0"
6 B22_27_2 Ctx2 B22_27 ".0 1.0 .0"
6 B22_27_3 Ctx3 B22_27 "0.87 0.87 .0"
6 B22_27_4 Ctx4 B22_27 ".0 0.95 1.0"
6 B22_27_5 Ctx5 B22_27 ".0 .0 .0"
6 B22_27_6 Ctx6 B22_27 ".0 .0 0.5"
6 B22_27_7 Ctx7 B22_27 "0.41 0.41 0.41"
6 B22_27_8 Ctx8 B22_27 "1.0 .0 1.0"
6 B22_27_9 Ctx9 B22_27 ".0 .0 1.0"
10 49.016029000 w3 WS "B22_27"
20 49.016029000 w3 WS B22_27 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 52
52 0.000000 0 0 -1 -1
10 49.019840000 t4915 S E
10 50.264130000 t4917 S B
10 50.276364000 w5 WS "I"
13 39.154164000 w5 gf 0.000000
13 39.154164000 sched gft 0.000000
13 50.326967000 sched nready 237.000000
13 50.326967000 sched nsubmitted 244.000000
9 50.326967000 po p 60
10 50.343978000 w5 WS "Fi"
6 B22_35 WS B22_35 "0.000000 0.600000 0.400000"
6 B22_35_1 Ctx1 B22_35 "1.0 0.39 1.0"
6 B22_35_2 Ctx2 B22_35 ".0 1.0 .0"
6 B22_35_3 Ctx3 B22_35 "0.87 0.87 .0"
6 B22_35_4 Ctx4 B22_35 ".0 0.95 1.0"
6 B22_35_5 Ctx5 B22_35 ".0 .0 .0"
6 B22_35_6 Ctx6 B22_35 ".0 .0 0.5"
6 B22_35_7 Ctx7 B22_35 "0.41 0.41 0.41"
6 B22_35_8 Ctx8 B22_35 "1.0 .0 1.0"
6 B22_35_9 Ctx9 B22_35 ".0 .0 1.0"
10 50.354293000 w5 WS "B22_35"
20 50.354293000 w5 WS B22_35 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 60
60 0.000000 0 0 -1 -1
10 50.359031000 t4917 S E
10 51.604032000 t4913 S B
10 51.643802000 w1 WS "I"
13 39.626486000 w1 gf 0.000000
13 39.626486000 sched gft 0.000000
13 51.681234000 sched nready 236.000000
13 51.681234000 sched nsubmitted 243.000000
9 51.681234000 po p 62
10 51.684286000 w1 WS "Fi"
6 B22_37 WS B22_37 "0.000000 0.600000 0.400000"
6 B22_37_1 Ctx1 B22_37 "1.0 0.39 1.0"
6 B22_37_2 Ctx2 B22_37 ".0 1.0 .0"
6 B22_37_3 Ctx3 B22_37 "0.87 0.87 .0"
6 B22_37_4 Ctx4 B22_37 ".0 0.95 1.0"
6 B22_37_5 Ctx5 B22_37 ".0 .0 .0"
6 B22_37_6 Ctx6 B22_37 ".0 .0 0.5"
6 B22_37_7 Ctx7 B22_37 "0.41 0.41 0.41"
6 B22_37_8 Ctx8 B22_37 "1.0 .0 1.0"
6 B22_37_9 Ctx9 B22_37 ".0 .0 1.0"
10 51.692850000 w1 WS "B22_37"
20 51.692850000 w1 WS B22_37 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 62
62 0.000000 0 0 -1 -1
10 51.699225000 t4913 S E
10 52.258645000 t4912 S B
10 52.271082000 w0 WS "I"
13 40.171118000 w0 gf 0.000000
13 40.171118000 sched gft 0.000000
13 52.309029000 sched nready 235.000000
13 52.309029000 sched nsubmitted 242.000000
9 52.309029000 po p 55
10 52.311612000 w0 WS "Fi"
6 B22_30 WS B22_30 "0.000000 0.600000 0.400000"
6 B22_30_1 Ctx1 B22_30 "1.0 0.39 1.0"
6 B22_30_2 Ctx2 B22_30 ".0 1.0 .0"
6 B22_30_3 Ctx3 B22_30 "0.87 0.87 .0"
6 B22_30_4 Ctx4 B22_30 ".0 0.95 1.0"
6 B22_30_5 Ctx5 B22_30 ".0 .0 .0"
6 B22_30_6 Ctx6 B22_30 ".0 .0 0.5"
6 B22_30_7 Ctx7 B22_30 "0.41 0.41 0.41"
6 B22_30_8 Ctx8 B22_30 "1.0 .0 1.0"
6 B22_30_9 Ctx9 B22_30 ".0 .0 1.0"
10 52.321247000 w0 WS "B22_30"
20 52.321247000 w0 WS B22_30 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 55
55 0.000000 0 0 -1 -1
10 52.327194000 t4912 S E
10 58.702710000 t4914 S B
10 58.704381000 t4916 S B
10 58.709068000 w4 WS "I"
13 48.540755000 w4 gf 0.000000
13 48.540755000 sched gft 0.000000
10 58.709130000 w2 WS "I"
13 48.546028000 w2 gf 0.000000
13 48.546028000 sched gft 0.000000
13 58.719592000 sched nready 234.000000
13 58.719592000 sched nsubmitted 241.000000
9 58.719592000 po p 11
13 58.720037000 sched nready 233.000000
13 58.720037000 sched nsubmitted 240.000000
9 58.720037000 po p 63
10 58.721217000 w4 WS "Fi"
10 58.721514000 w2 WS "Fi"
6 B22_38 WS B22_38 "0.000000 0.600000 0.400000"
6 B22_38_1 Ctx1 B22_38 "1.0 0.39 1.0"
6 B22_38_2 Ctx2 B22_38 ".0 1.0 .0"
6 B22_38_3 Ctx3 B22_38 "0.87 0.87 .0"
6 B22_38_4 Ctx4 B22_38 ".0 0.95 1.0"
6 B22_38_5 Ctx5 B22_38 ".0 .0 .0"
6 B22_38_6 Ctx6 B22_38 ".0 .0 0.5"
6 B22_38_7 Ctx7 B22_38 "0.41 0.41 0.41"
6 B22_38_8 Ctx8 B22_38 "1.0 .0 1.0"
6 B22_38_9 Ctx9 B22_38 ".0 .0 1.0"
10 58.724673000 w2 WS "B22_38"
6 B11_we WS B11_we "0.000000 0.600000 0.400000"
6 B11_we_1 Ctx1 B11_we "1.0 0.39 1.0"
6 B11_we_2 Ctx2 B11_we ".0 1.0 .0"
6 B11_we_3 Ctx3 B11_we "0.87 0.87 .0"
6 B11_we_4 Ctx4 B11_we ".0 0.95 1.0"
6 B11_we_5 Ctx5 B11_we ".0 .0 .0"
6 B11_we_6 Ctx6 B11_we ".0 .0 0.5"
6 B11_we_7 Ctx7 B11_we "0.41 0.41 0.41"
6 B11_we_8 Ctx8 B11_we "1.0 .0 1.0"
6 B11_we_9 Ctx9 B11_we ".0 .0 1.0"
10 58.724796000 w4 WS "B11_we"
20 58.724796000 w4 WS B11_we 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 11 11
0.000000 0 0 -1 -1
20 58.724673000 w2 WS B22_38 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 63
63 0.000000 0 0 -1 -1
10 58.727087000 t4914 S E
10 58.727136000 t4916 S E
10 58.728259000 t4916 S B
10 58.729083000 w4 WS "I"
13 58.709068000 w4 gf 0.000000
13 58.733516000 sched nready 234.000000
9 58.733516000 pu p 13
13 58.738198000 sched nready 233.000000
13 58.738198000 sched nsubmitted 239.000000
9 58.738198000 po p 22
10 58.739533000 w4 WS "Fi"
6 B21_we WS B21_we "0.000000 0.600000 0.400000"
6 B21_we_1 Ctx1 B21_we "1.0 0.39 1.0"
6 B21_we_2 Ctx2 B21_we ".0 1.0 .0"
6 B21_we_3 Ctx3 B21_we "0.87 0.87 .0"
6 B21_we_4 Ctx4 B21_we ".0 0.95 1.0"
6 B21_we_5 Ctx5 B21_we ".0 .0 .0"
6 B21_we_6 Ctx6 B21_we ".0 .0 0.5"
6 B21_we_7 Ctx7 B21_we "0.41 0.41 0.41"
6 B21_we_8 Ctx8 B21_we "1.0 .0 1.0"
6 B21_we_9 Ctx9 B21_we ".0 .0 1.0"
10 58.741585000 w4 WS "B21_we"
20 58.741585000 w4 WS B21_we 131160
M1x8192x8_M1x8194x8_M3x3x8 168cba74 0000000000000000 22
22 0.000000 0 0 -1 -1
10 58.742651000 t4916 S E
10 58.864100000 t4916 S B
10 58.865374000 w4 WS "I"
13 58.729083000 w4 gf 0.000000
13 58.741585000 w4 gf 0.000000
13 58.868217000 sched nready 234.000000
9 58.868217000 pu p 24
13 58.871213000 sched nready 233.000000
13 58.871213000 sched nsubmitted 238.000000
9 58.871213000 po p 65
10 58.872486000 w4 WS "Fi"
6 B22_40 WS B22_40 "0.000000 0.600000 0.400000"
6 B22_40_1 Ctx1 B22_40 "1.0 0.39 1.0"
6 B22_40_2 Ctx2 B22_40 ".0 1.0 .0"
6 B22_40_3 Ctx3 B22_40 "0.87 0.87 .0"
6 B22_40_4 Ctx4 B22_40 ".0 0.95 1.0"
6 B22_40_5 Ctx5 B22_40 ".0 .0 .0"
6 B22_40_6 Ctx6 B22_40 ".0 .0 0.5"
6 B22_40_7 Ctx7 B22_40 "0.41 0.41 0.41"
6 B22_40_8 Ctx8 B22_40 "1.0 .0 1.0"
6 B22_40_9 Ctx9 B22_40 ".0 .0 1.0"
10 58.874656000 w4 WS "B22_40"
20 58.874656000 w4 WS B22_40 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 65
65 0.000000 0 0 -1 -1
10 58.875744000 t4916 S E
10 58.991711000 t4915 S B
10 58.995286000 w3 WS "I"
13 48.952545000 w3 gf 0.000000
13 48.952545000 sched gft 0.000000
13 59.002655000 sched nready 232.000000
13 59.002655000 sched nsubmitted 237.000000
9 59.002655000 po p 58
10 59.004024000 w3 WS "Fi"
6 B22_33 WS B22_33 "0.000000 0.600000 0.400000"
6 B22_33_1 Ctx1 B22_33 "1.0 0.39 1.0"
6 B22_33_2 Ctx2 B22_33 ".0 1.0 .0"
6 B22_33_3 Ctx3 B22_33 "0.87 0.87 .0"
6 B22_33_4 Ctx4 B22_33 ".0 0.95 1.0"
6 B22_33_5 Ctx5 B22_33 ".0 .0 .0"
6 B22_33_6 Ctx6 B22_33 ".0 .0 0.5"
6 B22_33_7 Ctx7 B22_33 "0.41 0.41 0.41"
6 B22_33_8 Ctx8 B22_33 "1.0 .0 1.0"
6 B22_33_9 Ctx9 B22_33 ".0 .0 1.0"
10 59.006461000 w3 WS "B22_33"
20 59.006461000 w3 WS B22_33 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 58
58 0.000000 0 0 -1 -1
10 59.008348000 t4915 S E
10 59.443734000 t4917 S B
10 59.446069000 w5 WS "I"
13 50.276364000 w5 gf 0.000000
13 50.276364000 sched gft 0.000000
13 59.451428000 sched nready 231.000000
13 59.451428000 sched nsubmitted 236.000000
9 59.451428000 po p 19
10 59.452801000 w5 WS "Fi"
6 B13_ea WS B13_ea "0.000000 0.600000 0.400000"
6 B13_ea_1 Ctx1 B13_ea "1.0 0.39 1.0"
6 B13_ea_2 Ctx2 B13_ea ".0 1.0 .0"
6 B13_ea_3 Ctx3 B13_ea "0.87 0.87 .0"
6 B13_ea_4 Ctx4 B13_ea ".0 0.95 1.0"
6 B13_ea_5 Ctx5 B13_ea ".0 .0 .0"
6 B13_ea_6 Ctx6 B13_ea ".0 .0 0.5"
6 B13_ea_7 Ctx7 B13_ea "0.41 0.41 0.41"
6 B13_ea_8 Ctx8 B13_ea "1.0 .0 1.0"
6 B13_ea_9 Ctx9 B13_ea ".0 .0 1.0"
10 59.455116000 w5 WS "B13_ea"
20 59.455116000 w5 WS B13_ea 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 19 19
0.000000 0 0 -1 -1
10 59.456434000 t4917 S E
10 59.457433000 t4917 S B
10 59.458273000 w5 WS "I"
13 59.446069000 w5 gf 0.000000
13 59.461701000 sched nready 232.000000
9 59.461701000 pu p 21
13 59.465447000 sched nready 231.000000
13 59.465447000 sched nsubmitted 235.000000
9 59.465447000 po p 66
10 59.466744000 w5 WS "Fi"
6 B22_41 WS B22_41 "0.000000 0.600000 0.400000"
6 B22_41_1 Ctx1 B22_41 "1.0 0.39 1.0"
6 B22_41_2 Ctx2 B22_41 ".0 1.0 .0"
6 B22_41_3 Ctx3 B22_41 "0.87 0.87 .0"
6 B22_41_4 Ctx4 B22_41 ".0 0.95 1.0"
6 B22_41_5 Ctx5 B22_41 ".0 .0 .0"
6 B22_41_6 Ctx6 B22_41 ".0 .0 0.5"
6 B22_41_7 Ctx7 B22_41 "0.41 0.41 0.41"
6 B22_41_8 Ctx8 B22_41 "1.0 .0 1.0"
6 B22_41_9 Ctx9 B22_41 ".0 .0 1.0"
10 59.468880000 w5 WS "B22_41"
20 59.468880000 w5 WS B22_41 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 66
66 0.000000 0 0 -1 -1
10 59.469938000 t4917 S E
10 60.020286000 t4913 S B
10 60.022677000 w1 WS "I"
13 51.643802000 w1 gf 0.000000
13 51.643802000 sched gft 0.000000
13 60.028247000 sched nready 230.000000
13 60.028247000 sched nsubmitted 234.000000
9 60.028247000 po p 68
10 60.029568000 w1 WS "Fi"
6 B22_43 WS B22_43 "0.000000 0.600000 0.400000"
6 B22_43_1 Ctx1 B22_43 "1.0 0.39 1.0"
6 B22_43_2 Ctx2 B22_43 ".0 1.0 .0"
6 B22_43_3 Ctx3 B22_43 "0.87 0.87 .0"
6 B22_43_4 Ctx4 B22_43 ".0 0.95 1.0"
6 B22_43_5 Ctx5 B22_43 ".0 .0 .0"
6 B22_43_6 Ctx6 B22_43 ".0 .0 0.5"
6 B22_43_7 Ctx7 B22_43 "0.41 0.41 0.41"
6 B22_43_8 Ctx8 B22_43 "1.0 .0 1.0"
6 B22_43_9 Ctx9 B22_43 ".0 .0 1.0"
10 60.031754000 w1 WS "B22_43"
20 60.031754000 w1 WS B22_43 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 68
68 0.000000 0 0 -1 -1
10 60.033231000 t4913 S E
10 60.338181000 t4912 S B
10 60.340587000 w0 WS "I"
13 52.271082000 w0 gf 0.000000
13 52.271082000 sched gft 0.000000
13 58.709068000 sched gft 0.000000
13 60.346392000 sched nready 229.000000
13 60.346392000 sched nsubmitted 233.000000
9 60.346392000 po p 61
10 60.347718000 w0 WS "Fi"
6 B22_36 WS B22_36 "0.000000 0.600000 0.400000"
6 B22_36_1 Ctx1 B22_36 "1.0 0.39 1.0"
6 B22_36_2 Ctx2 B22_36 ".0 1.0 .0"
6 B22_36_3 Ctx3 B22_36 "0.87 0.87 .0"
6 B22_36_4 Ctx4 B22_36 ".0 0.95 1.0"
6 B22_36_5 Ctx5 B22_36 ".0 .0 .0"
6 B22_36_6 Ctx6 B22_36 ".0 .0 0.5"
6 B22_36_7 Ctx7 B22_36 "0.41 0.41 0.41"
6 B22_36_8 Ctx8 B22_36 "1.0 .0 1.0"
6 B22_36_9 Ctx9 B22_36 ".0 .0 1.0"
10 60.350202000 w0 WS "B22_36"
20 60.350202000 w0 WS B22_36 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 61
61 0.000000 0 0 -1 -1
10 60.351600000 t4912 S E
10 66.422330000 t4914 S B
10 66.425327000 w2 WS "I"
13 58.709130000 w2 gf 0.000000
13 58.709130000 sched gft 0.000000
13 58.729083000 sched gft 0.000000
13 58.741585000 sched gft 0.000000
13 66.432678000 sched nready 228.000000
13 66.432678000 sched nsubmitted 232.000000
9 66.432678000 po p 69
10 66.434026000 w2 WS "Fi"
6 B22_44 WS B22_44 "0.000000 0.600000 0.400000"
6 B22_44_1 Ctx1 B22_44 "1.0 0.39 1.0"
6 B22_44_2 Ctx2 B22_44 ".0 1.0 .0"
6 B22_44_3 Ctx3 B22_44 "0.87 0.87 .0"
6 B22_44_4 Ctx4 B22_44 ".0 0.95 1.0"
6 B22_44_5 Ctx5 B22_44 ".0 .0 .0"
6 B22_44_6 Ctx6 B22_44 ".0 .0 0.5"
6 B22_44_7 Ctx7 B22_44 "0.41 0.41 0.41"
6 B22_44_8 Ctx8 B22_44 "1.0 .0 1.0"
6 B22_44_9 Ctx9 B22_44 ".0 .0 1.0"
10 66.436728000 w2 WS "B22_44"
20 66.436728000 w2 WS B22_44 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 69
69 0.000000 0 0 -1 -1
10 66.438286000 t4914 S E
10 66.579211000 t4916 S B
10 66.581558000 w4 WS "I"
13 58.865374000 w4 gf 0.000000
13 58.865374000 sched gft 0.000000
13 66.587401000 sched nready 227.000000
13 66.587401000 sched nsubmitted 231.000000
9 66.587401000 po p 71
10 66.588807000 w4 WS "Fi"
6 B22_46 WS B22_46 "0.000000 0.600000 0.400000"
6 B22_46_1 Ctx1 B22_46 "1.0 0.39 1.0"
6 B22_46_2 Ctx2 B22_46 ".0 1.0 .0"
6 B22_46_3 Ctx3 B22_46 "0.87 0.87 .0"
6 B22_46_4 Ctx4 B22_46 ".0 0.95 1.0"
6 B22_46_5 Ctx5 B22_46 ".0 .0 .0"
6 B22_46_6 Ctx6 B22_46 ".0 .0 0.5"
6 B22_46_7 Ctx7 B22_46 "0.41 0.41 0.41"
6 B22_46_8 Ctx8 B22_46 "1.0 .0 1.0"
6 B22_46_9 Ctx9 B22_46 ".0 .0 1.0"
10 66.590963000 w4 WS "B22_46"
20 66.590963000 w4 WS B22_46 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 71
71 0.000000 0 0 -1 -1
10 66.592389000 t4916 S E
10 66.725832000 t4915 S B
10 66.728428000 w3 WS "I"
13 58.995286000 w3 gf 0.000000
13 58.995286000 sched gft 0.000000
13 59.446069000 sched gft 0.000000
13 66.734583000 sched nready 226.000000
13 66.734583000 sched nsubmitted 230.000000
9 66.734583000 po p 64
10 66.735902000 w3 WS "Fi"
6 B22_39 WS B22_39 "0.000000 0.600000 0.400000"
6 B22_39_1 Ctx1 B22_39 "1.0 0.39 1.0"
6 B22_39_2 Ctx2 B22_39 ".0 1.0 .0"
6 B22_39_3 Ctx3 B22_39 "0.87 0.87 .0"
6 B22_39_4 Ctx4 B22_39 ".0 0.95 1.0"
6 B22_39_5 Ctx5 B22_39 ".0 .0 .0"
6 B22_39_6 Ctx6 B22_39 ".0 .0 0.5"
6 B22_39_7 Ctx7 B22_39 "0.41 0.41 0.41"
6 B22_39_8 Ctx8 B22_39 "1.0 .0 1.0"
6 B22_39_9 Ctx9 B22_39 ".0 .0 1.0"
10 66.738070000 w3 WS "B22_39"
20 66.738070000 w3 WS B22_39 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 64
64 0.000000 0 0 -1 -1
10 66.739321000 t4915 S E
10 67.284176000 t4917 S B
10 67.286210000 w5 WS "I"
13 59.458273000 w5 gf 0.000000
13 59.468880000 w5 gf 0.000000
13 59.458273000 sched gft 0.000000
13 59.468880000 sched gft 0.000000
13 67.291177000 sched nready 225.000000
13 67.291177000 sched nsubmitted 229.000000
9 67.291177000 po p 72
10 67.292521000 w5 WS "Fi"
6 B22_47 WS B22_47 "0.000000 0.600000 0.400000"
6 B22_47_1 Ctx1 B22_47 "1.0 0.39 1.0"
6 B22_47_2 Ctx2 B22_47 ".0 1.0 .0"
6 B22_47_3 Ctx3 B22_47 "0.87 0.87 .0"
6 B22_47_4 Ctx4 B22_47 ".0 0.95 1.0"
6 B22_47_5 Ctx5 B22_47 ".0 .0 .0"
6 B22_47_6 Ctx6 B22_47 ".0 .0 0.5"
6 B22_47_7 Ctx7 B22_47 "0.41 0.41 0.41"
6 B22_47_8 Ctx8 B22_47 "1.0 .0 1.0"
6 B22_47_9 Ctx9 B22_47 ".0 .0 1.0"
10 67.294983000 w5 WS "B22_47"
20 67.294983000 w5 WS B22_47 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 72
72 0.000000 0 0 -1 -1
10 67.296256000 t4917 S E
10 67.769865000 t4913 S B
10 67.772679000 w1 WS "I"
13 60.022677000 w1 gf 0.000000
13 60.022677000 sched gft 0.000000
13 67.778326000 sched nready 224.000000
13 67.778326000 sched nsubmitted 228.000000
9 67.778326000 po p 74
10 67.779728000 w1 WS "Fi"
6 B22_49 WS B22_49 "0.000000 0.600000 0.400000"
6 B22_49_1 Ctx1 B22_49 "1.0 0.39 1.0"
6 B22_49_2 Ctx2 B22_49 ".0 1.0 .0"
6 B22_49_3 Ctx3 B22_49 "0.87 0.87 .0"
6 B22_49_4 Ctx4 B22_49 ".0 0.95 1.0"
6 B22_49_5 Ctx5 B22_49 ".0 .0 .0"
6 B22_49_6 Ctx6 B22_49 ".0 .0 0.5"
6 B22_49_7 Ctx7 B22_49 "0.41 0.41 0.41"
6 B22_49_8 Ctx8 B22_49 "1.0 .0 1.0"
6 B22_49_9 Ctx9 B22_49 ".0 .0 1.0"
10 67.781926000 w1 WS "B22_49"
20 67.781926000 w1 WS B22_49 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 74
74 0.000000 0 0 -1 -1
10 67.783397000 t4913 S E
10 68.089981000 t4912 S B
10 68.092431000 w0 WS "I"
13 60.340587000 w0 gf 0.000000
13 60.340587000 sched gft 0.000000
13 68.097632000 sched nready 223.000000
13 68.097632000 sched nsubmitted 227.000000
9 68.097632000 po p 67
10 68.098974000 w0 WS "Fi"
6 B22_42 WS B22_42 "0.000000 0.600000 0.400000"
6 B22_42_1 Ctx1 B22_42 "1.0 0.39 1.0"
6 B22_42_2 Ctx2 B22_42 ".0 1.0 .0"
6 B22_42_3 Ctx3 B22_42 "0.87 0.87 .0"
6 B22_42_4 Ctx4 B22_42 ".0 0.95 1.0"
6 B22_42_5 Ctx5 B22_42 ".0 .0 .0"
6 B22_42_6 Ctx6 B22_42 ".0 .0 0.5"
6 B22_42_7 Ctx7 B22_42 "0.41 0.41 0.41"
6 B22_42_8 Ctx8 B22_42 "1.0 .0 1.0"
6 B22_42_9 Ctx9 B22_42 ".0 .0 1.0"
10 68.101399000 w0 WS "B22_42"
20 68.101399000 w0 WS B22_42 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 67
67 0.000000 0 0 -1 -1
10 68.102732000 t4912 S E
10 74.161292000 t4914 S B
10 74.166092000 w2 WS "I"
13 66.425327000 w2 gf 0.000000
13 66.425327000 sched gft 0.000000
13 74.173717000 sched nready 222.000000
13 74.173717000 sched nsubmitted 226.000000
9 74.173717000 po p 75
10 74.175389000 w2 WS "Fi"
6 B22_50 WS B22_50 "0.000000 0.600000 0.400000"
6 B22_50_1 Ctx1 B22_50 "1.0 0.39 1.0"
6 B22_50_2 Ctx2 B22_50 ".0 1.0 .0"
6 B22_50_3 Ctx3 B22_50 "0.87 0.87 .0"
6 B22_50_4 Ctx4 B22_50 ".0 0.95 1.0"
6 B22_50_5 Ctx5 B22_50 ".0 .0 .0"
6 B22_50_6 Ctx6 B22_50 ".0 .0 0.5"
6 B22_50_7 Ctx7 B22_50 "0.41 0.41 0.41"
6 B22_50_8 Ctx8 B22_50 "1.0 .0 1.0"
6 B22_50_9 Ctx9 B22_50 ".0 .0 1.0"
10 74.177962000 w2 WS "B22_50"
20 74.177962000 w2 WS B22_50 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 75
75 0.000000 0 0 -1 -1
10 74.179481000 t4914 S E
10 74.313514000 t4916 S B
10 74.316201000 w4 WS "I"
13 66.581558000 w4 gf 0.000000
13 66.581558000 sched gft 0.000000
13 74.321713000 sched nready 221.000000
13 74.321713000 sched nsubmitted 225.000000
9 74.321713000 po p 77
10 74.323032000 w4 WS "Fi"
6 B22_52 WS B22_52 "0.000000 0.600000 0.400000"
6 B22_52_1 Ctx1 B22_52 "1.0 0.39 1.0"
6 B22_52_2 Ctx2 B22_52 ".0 1.0 .0"
6 B22_52_3 Ctx3 B22_52 "0.87 0.87 .0"
6 B22_52_4 Ctx4 B22_52 ".0 0.95 1.0"
6 B22_52_5 Ctx5 B22_52 ".0 .0 .0"
6 B22_52_6 Ctx6 B22_52 ".0 .0 0.5"
6 B22_52_7 Ctx7 B22_52 "0.41 0.41 0.41"
6 B22_52_8 Ctx8 B22_52 "1.0 .0 1.0"
6 B22_52_9 Ctx9 B22_52 ".0 .0 1.0"
10 74.325221000 w4 WS "B22_52"
20 74.325221000 w4 WS B22_52 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 77
77 0.000000 0 0 -1 -1
10 74.326657000 t4916 S E
10 74.470187000 t4915 S B
10 74.472784000 w3 WS "I"
13 66.728428000 w3 gf 0.000000
13 66.728428000 sched gft 0.000000
13 74.478628000 sched nready 220.000000
13 74.478628000 sched nsubmitted 224.000000
9 74.478628000 po p 70
10 74.479919000 w3 WS "Fi"
6 B22_45 WS B22_45 "0.000000 0.600000 0.400000"
6 B22_45_1 Ctx1 B22_45 "1.0 0.39 1.0"
6 B22_45_2 Ctx2 B22_45 ".0 1.0 .0"
6 B22_45_3 Ctx3 B22_45 "0.87 0.87 .0"
6 B22_45_4 Ctx4 B22_45 ".0 0.95 1.0"
6 B22_45_5 Ctx5 B22_45 ".0 .0 .0"
6 B22_45_6 Ctx6 B22_45 ".0 .0 0.5"
6 B22_45_7 Ctx7 B22_45 "0.41 0.41 0.41"
6 B22_45_8 Ctx8 B22_45 "1.0 .0 1.0"
6 B22_45_9 Ctx9 B22_45 ".0 .0 1.0"
10 74.481995000 w3 WS "B22_45"
20 74.481995000 w3 WS B22_45 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 70
70 0.000000 0 0 -1 -1
10 74.483194000 t4915 S E
10 74.969382000 t4917 S B
10 74.970966000 w5 WS "I"
13 67.286210000 w5 gf 0.000000
13 67.286210000 sched gft 0.000000
13 74.976076000 sched nready 219.000000
13 74.976076000 sched nsubmitted 223.000000
9 74.976076000 po p 78
10 74.977730000 w5 WS "Fi"
6 B22_53 WS B22_53 "0.000000 0.600000 0.400000"
6 B22_53_1 Ctx1 B22_53 "1.0 0.39 1.0"
6 B22_53_2 Ctx2 B22_53 ".0 1.0 .0"
6 B22_53_3 Ctx3 B22_53 "0.87 0.87 .0"
6 B22_53_4 Ctx4 B22_53 ".0 0.95 1.0"
6 B22_53_5 Ctx5 B22_53 ".0 .0 .0"
6 B22_53_6 Ctx6 B22_53 ".0 .0 0.5"
6 B22_53_7 Ctx7 B22_53 "0.41 0.41 0.41"
6 B22_53_8 Ctx8 B22_53 "1.0 .0 1.0"
6 B22_53_9 Ctx9 B22_53 ".0 .0 1.0"
10 74.979805000 w5 WS "B22_53"
20 74.979805000 w5 WS B22_53 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 78
78 0.000000 0 0 -1 -1
10 74.981212000 t4917 S E
10 75.506544000 t4913 S B
10 75.509091000 w1 WS "I"
13 67.772679000 w1 gf 0.000000
13 67.772679000 sched gft 0.000000
13 75.514585000 sched nready 218.000000
13 75.514585000 sched nsubmitted 222.000000
9 75.514585000 po p 80
10 75.515903000 w1 WS "Fi"
6 B22_55 WS B22_55 "0.000000 0.600000 0.400000"
6 B22_55_1 Ctx1 B22_55 "1.0 0.39 1.0"
6 B22_55_2 Ctx2 B22_55 ".0 1.0 .0"
6 B22_55_3 Ctx3 B22_55 "0.87 0.87 .0"
6 B22_55_4 Ctx4 B22_55 ".0 0.95 1.0"
6 B22_55_5 Ctx5 B22_55 ".0 .0 .0"
6 B22_55_6 Ctx6 B22_55 ".0 .0 0.5"
6 B22_55_7 Ctx7 B22_55 "0.41 0.41 0.41"
6 B22_55_8 Ctx8 B22_55 "1.0 .0 1.0"
6 B22_55_9 Ctx9 B22_55 ".0 .0 1.0"
10 75.518149000 w1 WS "B22_55"
20 75.518149000 w1 WS B22_55 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 80
80 0.000000 0 0 -1 -1
10 75.519481000 t4913 S E
10 75.821367000 t4912 S B
10 75.823813000 w0 WS "I"
13 68.092431000 w0 gf 0.000000
13 68.092431000 sched gft 0.000000
13 75.829805000 sched nready 217.000000
13 75.829805000 sched nsubmitted 221.000000
9 75.829805000 po p 73
10 75.831104000 w0 WS "Fi"
6 B22_48 WS B22_48 "0.000000 0.600000 0.400000"
6 B22_48_1 Ctx1 B22_48 "1.0 0.39 1.0"
6 B22_48_2 Ctx2 B22_48 ".0 1.0 .0"
6 B22_48_3 Ctx3 B22_48 "0.87 0.87 .0"
6 B22_48_4 Ctx4 B22_48 ".0 0.95 1.0"
6 B22_48_5 Ctx5 B22_48 ".0 .0 .0"
6 B22_48_6 Ctx6 B22_48 ".0 .0 0.5"
6 B22_48_7 Ctx7 B22_48 "0.41 0.41 0.41"
6 B22_48_8 Ctx8 B22_48 "1.0 .0 1.0"
6 B22_48_9 Ctx9 B22_48 ".0 .0 1.0"
10 75.833299000 w0 WS "B22_48"
20 75.833299000 w0 WS B22_48 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 73
73 0.000000 0 0 -1 -1
10 75.834616000 t4912 S E
10 81.888039000 t4914 S B
10 81.892149000 w2 WS "I"
13 74.166092000 w2 gf 0.000000
13 74.166092000 sched gft 0.000000
13 81.905573000 sched nready 216.000000
13 81.905573000 sched nsubmitted 220.000000
9 81.905573000 po p 81
10 81.906939000 w2 WS "Fi"
6 B22_56 WS B22_56 "0.000000 0.600000 0.400000"
6 B22_56_1 Ctx1 B22_56 "1.0 0.39 1.0"
6 B22_56_2 Ctx2 B22_56 ".0 1.0 .0"
6 B22_56_3 Ctx3 B22_56 "0.87 0.87 .0"
6 B22_56_4 Ctx4 B22_56 ".0 0.95 1.0"
6 B22_56_5 Ctx5 B22_56 ".0 .0 .0"
6 B22_56_6 Ctx6 B22_56 ".0 .0 0.5"
6 B22_56_7 Ctx7 B22_56 "0.41 0.41 0.41"
6 B22_56_8 Ctx8 B22_56 "1.0 .0 1.0"
6 B22_56_9 Ctx9 B22_56 ".0 .0 1.0"
10 81.909722000 w2 WS "B22_56"
20 81.909722000 w2 WS B22_56 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 81
81 0.000000 0 0 -1 -1
10 81.911178000 t4914 S E
10 82.024338000 t4916 S B
10 82.026472000 w4 WS "I"
13 74.316201000 w4 gf 0.000000
13 74.316201000 sched gft 0.000000
13 82.032379000 sched nready 215.000000
13 82.032379000 sched nsubmitted 219.000000
9 82.032379000 po p 83
10 82.033704000 w4 WS "Fi"
6 B22_58 WS B22_58 "0.000000 0.600000 0.400000"
6 B22_58_1 Ctx1 B22_58 "1.0 0.39 1.0"
6 B22_58_2 Ctx2 B22_58 ".0 1.0 .0"
6 B22_58_3 Ctx3 B22_58 "0.87 0.87 .0"
6 B22_58_4 Ctx4 B22_58 ".0 0.95 1.0"
6 B22_58_5 Ctx5 B22_58 ".0 .0 .0"
6 B22_58_6 Ctx6 B22_58 ".0 .0 0.5"
6 B22_58_7 Ctx7 B22_58 "0.41 0.41 0.41"
6 B22_58_8 Ctx8 B22_58 "1.0 .0 1.0"
6 B22_58_9 Ctx9 B22_58 ".0 .0 1.0"
10 82.035766000 w4 WS "B22_58"
20 82.035766000 w4 WS B22_58 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 83
83 0.000000 0 0 -1 -1
10 82.037045000 t4916 S E
10 82.186927000 t4915 S B
10 82.189528000 w3 WS "I"
13 74.472784000 w3 gf 0.000000
13 74.472784000 sched gft 0.000000
13 82.195647000 sched nready 214.000000
13 82.195647000 sched nsubmitted 218.000000
9 82.195647000 po p 76
10 82.196930000 w3 WS "Fi"
6 B22_51 WS B22_51 "0.000000 0.600000 0.400000"
6 B22_51_1 Ctx1 B22_51 "1.0 0.39 1.0"
6 B22_51_2 Ctx2 B22_51 ".0 1.0 .0"
6 B22_51_3 Ctx3 B22_51 "0.87 0.87 .0"
6 B22_51_4 Ctx4 B22_51 ".0 0.95 1.0"
6 B22_51_5 Ctx5 B22_51 ".0 .0 .0"
6 B22_51_6 Ctx6 B22_51 ".0 .0 0.5"
6 B22_51_7 Ctx7 B22_51 "0.41 0.41 0.41"
6 B22_51_8 Ctx8 B22_51 "1.0 .0 1.0"
6 B22_51_9 Ctx9 B22_51 ".0 .0 1.0"
10 82.198996000 w3 WS "B22_51"
20 82.198996000 w3 WS B22_51 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 76
76 0.000000 0 0 -1 -1
10 82.200216000 t4915 S E
10 82.649958000 t4917 S B
10 82.651815000 w5 WS "I"
13 74.970966000 w5 gf 0.000000
13 74.970966000 sched gft 0.000000
13 82.657557000 sched nready 213.000000
13 82.657557000 sched nsubmitted 217.000000
9 82.657557000 po p 84
10 82.658875000 w5 WS "Fi"
6 B22_59 WS B22_59 "0.000000 0.600000 0.400000"
6 B22_59_1 Ctx1 B22_59 "1.0 0.39 1.0"
6 B22_59_2 Ctx2 B22_59 ".0 1.0 .0"
6 B22_59_3 Ctx3 B22_59 "0.87 0.87 .0"
6 B22_59_4 Ctx4 B22_59 ".0 0.95 1.0"
6 B22_59_5 Ctx5 B22_59 ".0 .0 .0"
6 B22_59_6 Ctx6 B22_59 ".0 .0 0.5"
6 B22_59_7 Ctx7 B22_59 "0.41 0.41 0.41"
6 B22_59_8 Ctx8 B22_59 "1.0 .0 1.0"
6 B22_59_9 Ctx9 B22_59 ".0 .0 1.0"
10 82.660978000 w5 WS "B22_59"
20 82.660978000 w5 WS B22_59 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 84
84 0.000000 0 0 -1 -1
10 82.662232000 t4917 S E
10 83.214986000 t4913 S B
10 83.217322000 w1 WS "I"
13 75.509091000 w1 gf 0.000000
13 75.509091000 sched gft 0.000000
13 83.222729000 sched nready 212.000000
13 83.222729000 sched nsubmitted 216.000000
9 83.222729000 po p 86
10 83.224038000 w1 WS "Fi"
6 B22_61 WS B22_61 "0.000000 0.600000 0.400000"
6 B22_61_1 Ctx1 B22_61 "1.0 0.39 1.0"
6 B22_61_2 Ctx2 B22_61 ".0 1.0 .0"
6 B22_61_3 Ctx3 B22_61 "0.87 0.87 .0"
6 B22_61_4 Ctx4 B22_61 ".0 0.95 1.0"
6 B22_61_5 Ctx5 B22_61 ".0 .0 .0"
6 B22_61_6 Ctx6 B22_61 ".0 .0 0.5"
6 B22_61_7 Ctx7 B22_61 "0.41 0.41 0.41"
6 B22_61_8 Ctx8 B22_61 "1.0 .0 1.0"
6 B22_61_9 Ctx9 B22_61 ".0 .0 1.0"
10 83.226254000 w1 WS "B22_61"
20 83.226254000 w1 WS B22_61 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 86
86 0.000000 0 0 -1 -1
10 83.227683000 t4913 S E
10 83.552764000 t4912 S B
10 83.555043000 w0 WS "I"
13 75.823813000 w0 gf 0.000000
13 75.823813000 sched gft 0.000000
13 83.560267000 sched nready 211.000000
13 83.560267000 sched nsubmitted 215.000000
9 83.560267000 po p 79
10 83.561555000 w0 WS "Fi"
6 B22_54 WS B22_54 "0.000000 0.600000 0.400000"
6 B22_54_1 Ctx1 B22_54 "1.0 0.39 1.0"
6 B22_54_2 Ctx2 B22_54 ".0 1.0 .0"
6 B22_54_3 Ctx3 B22_54 "0.87 0.87 .0"
6 B22_54_4 Ctx4 B22_54 ".0 0.95 1.0"
6 B22_54_5 Ctx5 B22_54 ".0 .0 .0"
6 B22_54_6 Ctx6 B22_54 ".0 .0 0.5"
6 B22_54_7 Ctx7 B22_54 "0.41 0.41 0.41"
6 B22_54_8 Ctx8 B22_54 "1.0 .0 1.0"
6 B22_54_9 Ctx9 B22_54 ".0 .0 1.0"
10 83.563937000 w0 WS "B22_54"
20 83.563937000 w0 WS B22_54 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 79
79 0.000000 0 0 -1 -1
10 83.565376000 t4912 S E
10 89.620300000 t4914 S B
10 89.623950000 w2 WS "I"
13 81.892149000 w2 gf 0.000000
13 81.892149000 sched gft 0.000000
13 89.630563000 sched nready 210.000000
13 89.630563000 sched nsubmitted 214.000000
9 89.630563000 po p 87
10 89.631917000 w2 WS "Fi"
6 B22_62 WS B22_62 "0.000000 0.600000 0.400000"
6 B22_62_1 Ctx1 B22_62 "1.0 0.39 1.0"
6 B22_62_2 Ctx2 B22_62 ".0 1.0 .0"
6 B22_62_3 Ctx3 B22_62 "0.87 0.87 .0"
6 B22_62_4 Ctx4 B22_62 ".0 0.95 1.0"
6 B22_62_5 Ctx5 B22_62 ".0 .0 .0"
6 B22_62_6 Ctx6 B22_62 ".0 .0 0.5"
6 B22_62_7 Ctx7 B22_62 "0.41 0.41 0.41"
6 B22_62_8 Ctx8 B22_62 "1.0 .0 1.0"
6 B22_62_9 Ctx9 B22_62 ".0 .0 1.0"
10 89.634473000 w2 WS "B22_62"
20 89.634473000 w2 WS B22_62 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 87
87 0.000000 0 0 -1 -1
10 89.635886000 t4914 S E
10 89.743862000 t4916 S B
10 89.746645000 w4 WS "I"
13 82.026472000 w4 gf 0.000000
13 82.026472000 sched gft 0.000000
13 89.752103000 sched nready 209.000000
13 89.752103000 sched nsubmitted 213.000000
9 89.752103000 po p 89
10 89.753386000 w4 WS "Fi"
6 B22_64 WS B22_64 "0.000000 0.600000 0.400000"
6 B22_64_1 Ctx1 B22_64 "1.0 0.39 1.0"
6 B22_64_2 Ctx2 B22_64 ".0 1.0 .0"
6 B22_64_3 Ctx3 B22_64 "0.87 0.87 .0"
6 B22_64_4 Ctx4 B22_64 ".0 0.95 1.0"
6 B22_64_5 Ctx5 B22_64 ".0 .0 .0"
6 B22_64_6 Ctx6 B22_64 ".0 .0 0.5"
6 B22_64_7 Ctx7 B22_64 "0.41 0.41 0.41"
6 B22_64_8 Ctx8 B22_64 "1.0 .0 1.0"
6 B22_64_9 Ctx9 B22_64 ".0 .0 1.0"
10 89.755535000 w4 WS "B22_64"
20 89.755535000 w4 WS B22_64 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 89
89 0.000000 0 0 -1 -1
10 89.756861000 t4916 S E
10 89.925585000 t4915 S B
10 89.928177000 w3 WS "I"
13 82.189528000 w3 gf 0.000000
13 82.189528000 sched gft 0.000000
13 89.933635000 sched nready 208.000000
13 89.933635000 sched nsubmitted 212.000000
9 89.933635000 po p 82
10 89.934936000 w3 WS "Fi"
6 B22_57 WS B22_57 "0.000000 0.600000 0.400000"
6 B22_57_1 Ctx1 B22_57 "1.0 0.39 1.0"
6 B22_57_2 Ctx2 B22_57 ".0 1.0 .0"
6 B22_57_3 Ctx3 B22_57 "0.87 0.87 .0"
6 B22_57_4 Ctx4 B22_57 ".0 0.95 1.0"
6 B22_57_5 Ctx5 B22_57 ".0 .0 .0"
6 B22_57_6 Ctx6 B22_57 ".0 .0 0.5"
6 B22_57_7 Ctx7 B22_57 "0.41 0.41 0.41"
6 B22_57_8 Ctx8 B22_57 "1.0 .0 1.0"
6 B22_57_9 Ctx9 B22_57 ".0 .0 1.0"
10 89.937017000 w3 WS "B22_57"
20 89.937017000 w3 WS B22_57 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 82
82 0.000000 0 0 -1 -1
10 89.938333000 t4915 S E
10 90.346224000 t4917 S B
10 90.348401000 w5 WS "I"
13 82.651815000 w5 gf 0.000000
13 82.651815000 sched gft 0.000000
13 90.353265000 sched nready 207.000000
13 90.353265000 sched nsubmitted 211.000000
9 90.353265000 po p 90
10 90.354573000 w5 WS "Fi"
6 B22_65 WS B22_65 "0.000000 0.600000 0.400000"
6 B22_65_1 Ctx1 B22_65 "1.0 0.39 1.0"
6 B22_65_2 Ctx2 B22_65 ".0 1.0 .0"
6 B22_65_3 Ctx3 B22_65 "0.87 0.87 .0"
6 B22_65_4 Ctx4 B22_65 ".0 0.95 1.0"
6 B22_65_5 Ctx5 B22_65 ".0 .0 .0"
6 B22_65_6 Ctx6 B22_65 ".0 .0 0.5"
6 B22_65_7 Ctx7 B22_65 "0.41 0.41 0.41"
6 B22_65_8 Ctx8 B22_65 "1.0 .0 1.0"
6 B22_65_9 Ctx9 B22_65 ".0 .0 1.0"
10 90.356750000 w5 WS "B22_65"
20 90.356750000 w5 WS B22_65 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 90
90 0.000000 0 0 -1 -1
10 90.357982000 t4917 S E
10 91.060238000 t4913 S B
10 91.062728000 w1 WS "I"
13 83.217322000 w1 gf 0.000000
13 83.217322000 sched gft 0.000000
13 91.074244000 sched nready 206.000000
13 91.074244000 sched nsubmitted 210.000000
9 91.074244000 po p 92
10 91.075565000 w1 WS "Fi"
6 B22_67 WS B22_67 "0.000000 0.600000 0.400000"
6 B22_67_1 Ctx1 B22_67 "1.0 0.39 1.0"
6 B22_67_2 Ctx2 B22_67 ".0 1.0 .0"
6 B22_67_3 Ctx3 B22_67 "0.87 0.87 .0"
6 B22_67_4 Ctx4 B22_67 ".0 0.95 1.0"
6 B22_67_5 Ctx5 B22_67 ".0 .0 .0"
6 B22_67_6 Ctx6 B22_67 ".0 .0 0.5"
6 B22_67_7 Ctx7 B22_67 "0.41 0.41 0.41"
6 B22_67_8 Ctx8 B22_67 "1.0 .0 1.0"
6 B22_67_9 Ctx9 B22_67 ".0 .0 1.0"
10 91.077990000 w1 WS "B22_67"
20 91.077990000 w1 WS B22_67 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 92
92 0.000000 0 0 -1 -1
10 91.079254000 t4913 S E
10 91.291823000 t4912 S B
10 91.294147000 w0 WS "I"
13 83.555043000 w0 gf 0.000000
13 83.555043000 sched gft 0.000000
13 91.299360000 sched nready 205.000000
13 91.299360000 sched nsubmitted 209.000000
9 91.299360000 po p 85
10 91.300697000 w0 WS "Fi"
6 B22_60 WS B22_60 "0.000000 0.600000 0.400000"
6 B22_60_1 Ctx1 B22_60 "1.0 0.39 1.0"
6 B22_60_2 Ctx2 B22_60 ".0 1.0 .0"
6 B22_60_3 Ctx3 B22_60 "0.87 0.87 .0"
6 B22_60_4 Ctx4 B22_60 ".0 0.95 1.0"
6 B22_60_5 Ctx5 B22_60 ".0 .0 .0"
6 B22_60_6 Ctx6 B22_60 ".0 .0 0.5"
6 B22_60_7 Ctx7 B22_60 "0.41 0.41 0.41"
6 B22_60_8 Ctx8 B22_60 "1.0 .0 1.0"
6 B22_60_9 Ctx9 B22_60 ".0 .0 1.0"
10 91.303045000 w0 WS "B22_60"
20 91.303045000 w0 WS B22_60 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 85
85 0.000000 0 0 -1 -1
10 91.304376000 t4912 S E
10 97.323404000 t4914 S B
10 97.326575000 w2 WS "I"
13 89.623950000 w2 gf 0.000000
13 89.623950000 sched gft 0.000000
13 97.332652000 sched nready 204.000000
13 97.332652000 sched nsubmitted 208.000000
9 97.332652000 po p 93
10 97.333978000 w2 WS "Fi"
6 B22_68 WS B22_68 "0.000000 0.600000 0.400000"
6 B22_68_1 Ctx1 B22_68 "1.0 0.39 1.0"
6 B22_68_2 Ctx2 B22_68 ".0 1.0 .0"
6 B22_68_3 Ctx3 B22_68 "0.87 0.87 .0"
6 B22_68_4 Ctx4 B22_68 ".0 0.95 1.0"
6 B22_68_5 Ctx5 B22_68 ".0 .0 .0"
6 B22_68_6 Ctx6 B22_68 ".0 .0 0.5"
6 B22_68_7 Ctx7 B22_68 "0.41 0.41 0.41"
6 B22_68_8 Ctx8 B22_68 "1.0 .0 1.0"
6 B22_68_9 Ctx9 B22_68 ".0 .0 1.0"
10 97.336390000 w2 WS "B22_68"
20 97.336390000 w2 WS B22_68 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 93
93 0.000000 0 0 -1 -1
10 97.338422000 t4914 S E
10 97.442183000 t4916 S B
10 97.443941000 w4 WS "I"
13 89.746645000 w4 gf 0.000000
13 89.746645000 sched gft 0.000000
13 97.449270000 sched nready 203.000000
13 97.449270000 sched nsubmitted 207.000000
9 97.449270000 po p 95
10 97.450596000 w4 WS "Fi"
6 B22_70 WS B22_70 "0.000000 0.600000 0.400000"
6 B22_70_1 Ctx1 B22_70 "1.0 0.39 1.0"
6 B22_70_2 Ctx2 B22_70 ".0 1.0 .0"
6 B22_70_3 Ctx3 B22_70 "0.87 0.87 .0"
6 B22_70_4 Ctx4 B22_70 ".0 0.95 1.0"
6 B22_70_5 Ctx5 B22_70 ".0 .0 .0"
6 B22_70_6 Ctx6 B22_70 ".0 .0 0.5"
6 B22_70_7 Ctx7 B22_70 "0.41 0.41 0.41"
6 B22_70_8 Ctx8 B22_70 "1.0 .0 1.0"
6 B22_70_9 Ctx9 B22_70 ".0 .0 1.0"
10 97.452940000 w4 WS "B22_70"
20 97.452940000 w4 WS B22_70 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 95
95 0.000000 0 0 -1 -1
10 97.454395000 t4916 S E
10 97.779651000 t4915 S B
10 97.781890000 w3 WS "I"
13 89.928177000 w3 gf 0.000000
13 89.928177000 sched gft 0.000000
13 97.787338000 sched nready 202.000000
13 97.787338000 sched nsubmitted 206.000000
9 97.787338000 po p 88
10 97.788621000 w3 WS "Fi"
6 B22_63 WS B22_63 "0.000000 0.600000 0.400000"
6 B22_63_1 Ctx1 B22_63 "1.0 0.39 1.0"
6 B22_63_2 Ctx2 B22_63 ".0 1.0 .0"
6 B22_63_3 Ctx3 B22_63 "0.87 0.87 .0"
6 B22_63_4 Ctx4 B22_63 ".0 0.95 1.0"
6 B22_63_5 Ctx5 B22_63 ".0 .0 .0"
6 B22_63_6 Ctx6 B22_63 ".0 .0 0.5"
6 B22_63_7 Ctx7 B22_63 "0.41 0.41 0.41"
6 B22_63_8 Ctx8 B22_63 "1.0 .0 1.0"
6 B22_63_9 Ctx9 B22_63 ".0 .0 1.0"
10 97.790883000 w3 WS "B22_63"
20 97.790883000 w3 WS B22_63 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 88
88 0.000000 0 0 -1 -1
10 97.792204000 t4915 S E
10 98.016931000 t4917 S B
10 98.018740000 w5 WS "I"
13 90.348401000 w5 gf 0.000000
13 90.348401000 sched gft 0.000000
13 98.023685000 sched nready 201.000000
13 98.023685000 sched nsubmitted 205.000000
9 98.023685000 po p 96
10 98.025184000 w5 WS "Fi"
6 B22_71 WS B22_71 "0.000000 0.600000 0.400000"
6 B22_71_1 Ctx1 B22_71 "1.0 0.39 1.0"
6 B22_71_2 Ctx2 B22_71 ".0 1.0 .0"
6 B22_71_3 Ctx3 B22_71 "0.87 0.87 .0"
6 B22_71_4 Ctx4 B22_71 ".0 0.95 1.0"
6 B22_71_5 Ctx5 B22_71 ".0 .0 .0"
6 B22_71_6 Ctx6 B22_71 ".0 .0 0.5"
6 B22_71_7 Ctx7 B22_71 "0.41 0.41 0.41"
6 B22_71_8 Ctx8 B22_71 "1.0 .0 1.0"
6 B22_71_9 Ctx9 B22_71 ".0 .0 1.0"
10 98.027321000 w5 WS "B22_71"
20 98.027321000 w5 WS B22_71 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 96
96 0.000000 0 0 -1 -1
10 98.028577000 t4917 S E
10 98.764171000 t4913 S B
10 98.766344000 w1 WS "I"
13 91.062728000 w1 gf 0.000000
13 91.062728000 sched gft 0.000000
13 98.771503000 sched nready 200.000000
13 98.771503000 sched nsubmitted 204.000000
9 98.771503000 po p 98
10 98.772859000 w1 WS "Fi"
6 B22_73 WS B22_73 "0.000000 0.600000 0.400000"
6 B22_73_1 Ctx1 B22_73 "1.0 0.39 1.0"
6 B22_73_2 Ctx2 B22_73 ".0 1.0 .0"
6 B22_73_3 Ctx3 B22_73 "0.87 0.87 .0"
6 B22_73_4 Ctx4 B22_73 ".0 0.95 1.0"
6 B22_73_5 Ctx5 B22_73 ".0 .0 .0"
6 B22_73_6 Ctx6 B22_73 ".0 .0 0.5"
6 B22_73_7 Ctx7 B22_73 "0.41 0.41 0.41"
6 B22_73_8 Ctx8 B22_73 "1.0 .0 1.0"
6 B22_73_9 Ctx9 B22_73 ".0 .0 1.0"
10 98.775080000 w1 WS "B22_73"
20 98.775080000 w1 WS B22_73 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 98
98 0.000000 0 0 -1 -1
10 98.776444000 t4913 S E
10 99.022355000 t4912 S B
10 99.024577000 w0 WS "I"
13 91.294147000 w0 gf 0.000000
13 91.294147000 sched gft 0.000000
13 99.030402000 sched nready 199.000000
13 99.030402000 sched nsubmitted 203.000000
9 99.030402000 po p 91
10 99.031709000 w0 WS "Fi"
6 B22_66 WS B22_66 "0.000000 0.600000 0.400000"
6 B22_66_1 Ctx1 B22_66 "1.0 0.39 1.0"
6 B22_66_2 Ctx2 B22_66 ".0 1.0 .0"
6 B22_66_3 Ctx3 B22_66 "0.87 0.87 .0"
6 B22_66_4 Ctx4 B22_66 ".0 0.95 1.0"
6 B22_66_5 Ctx5 B22_66 ".0 .0 .0"
6 B22_66_6 Ctx6 B22_66 ".0 .0 0.5"
6 B22_66_7 Ctx7 B22_66 "0.41 0.41 0.41"
6 B22_66_8 Ctx8 B22_66 "1.0 .0 1.0"
6 B22_66_9 Ctx9 B22_66 ".0 .0 1.0"
10 99.034190000 w0 WS "B22_66"
20 99.034190000 w0 WS B22_66 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 91
91 0.000000 0 0 -1 -1
10 99.035531000 t4912 S E
10 105.031147000 t4914 S B
10 105.034070000 w2 WS "I"
13 97.326575000 w2 gf 0.000000
13 97.326575000 sched gft 0.000000
13 105.040050000 sched nready 198.000000
13 105.040050000 sched nsubmitted 202.000000
9 105.040050000 po p 99
10 105.041379000 w2 WS "Fi"
6 B22_74 WS B22_74 "0.000000 0.600000 0.400000"
6 B22_74_1 Ctx1 B22_74 "1.0 0.39 1.0"
6 B22_74_2 Ctx2 B22_74 ".0 1.0 .0"
6 B22_74_3 Ctx3 B22_74 "0.87 0.87 .0"
6 B22_74_4 Ctx4 B22_74 ".0 0.95 1.0"
6 B22_74_5 Ctx5 B22_74 ".0 .0 .0"
6 B22_74_6 Ctx6 B22_74 ".0 .0 0.5"
6 B22_74_7 Ctx7 B22_74 "0.41 0.41 0.41"
6 B22_74_8 Ctx8 B22_74 "1.0 .0 1.0"
6 B22_74_9 Ctx9 B22_74 ".0 .0 1.0"
10 105.043655000 w2 WS "B22_74"
20 105.043655000 w2 WS B22_74 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 99
99 0.000000 0 0 -1 -1
10 105.045167000 t4914 S E
10 105.275290000 t4916 S B
10 105.277107000 w4 WS "I"
13 97.443941000 w4 gf 0.000000
13 97.443941000 sched gft 0.000000
13 105.288801000 sched nready 197.000000
13 105.288801000 sched nsubmitted 201.000000
9 105.288801000 po p 101
10 105.290094000 w4 WS "Fi"
6 B22_76 WS B22_76 "0.000000 0.600000 0.400000"
6 B22_76_1 Ctx1 B22_76 "1.0 0.39 1.0"
6 B22_76_2 Ctx2 B22_76 ".0 1.0 .0"
6 B22_76_3 Ctx3 B22_76 "0.87 0.87 .0"
6 B22_76_4 Ctx4 B22_76 ".0 0.95 1.0"
6 B22_76_5 Ctx5 B22_76 ".0 .0 .0"
6 B22_76_6 Ctx6 B22_76 ".0 .0 0.5"
6 B22_76_7 Ctx7 B22_76 "0.41 0.41 0.41"
6 B22_76_8 Ctx8 B22_76 "1.0 .0 1.0"
6 B22_76_9 Ctx9 B22_76 ".0 .0 1.0"
10 105.292599000 w4 WS "B22_76"
20 105.292599000 w4 WS B22_76 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 101
101 0.000000 0 0 -1 -1
10 105.293762000 t4916 S E
10 105.507966000 t4915 S B
10 105.510278000 w3 WS "I"
13 97.781890000 w3 gf 0.000000
13 97.781890000 sched gft 0.000000
13 105.518854000 sched nready 196.000000
13 105.518854000 sched nsubmitted 200.000000
9 105.518854000 po p 94
10 105.520167000 w3 WS "Fi"
6 B22_69 WS B22_69 "0.000000 0.600000 0.400000"
6 B22_69_1 Ctx1 B22_69 "1.0 0.39 1.0"
6 B22_69_2 Ctx2 B22_69 ".0 1.0 .0"
6 B22_69_3 Ctx3 B22_69 "0.87 0.87 .0"
6 B22_69_4 Ctx4 B22_69 ".0 0.95 1.0"
6 B22_69_5 Ctx5 B22_69 ".0 .0 .0"
6 B22_69_6 Ctx6 B22_69 ".0 .0 0.5"
6 B22_69_7 Ctx7 B22_69 "0.41 0.41 0.41"
6 B22_69_8 Ctx8 B22_69 "1.0 .0 1.0"
6 B22_69_9 Ctx9 B22_69 ".0 .0 1.0"
10 105.522253000 w3 WS "B22_69"
20 105.522253000 w3 WS B22_69 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 94
94 0.000000 0 0 -1 -1
10 105.523506000 t4915 S E
10 105.691648000 t4917 S B
10 105.693822000 w5 WS "I"
13 98.018740000 w5 gf 0.000000
13 98.018740000 sched gft 0.000000
13 105.699061000 sched nready 195.000000
13 105.699061000 sched nsubmitted 199.000000
9 105.699061000 po p 102
10 105.700378000 w5 WS "Fi"
6 B22_77 WS B22_77 "0.000000 0.600000 0.400000"
6 B22_77_1 Ctx1 B22_77 "1.0 0.39 1.0"
6 B22_77_2 Ctx2 B22_77 ".0 1.0 .0"
6 B22_77_3 Ctx3 B22_77 "0.87 0.87 .0"
6 B22_77_4 Ctx4 B22_77 ".0 0.95 1.0"
6 B22_77_5 Ctx5 B22_77 ".0 .0 .0"
6 B22_77_6 Ctx6 B22_77 ".0 .0 0.5"
6 B22_77_7 Ctx7 B22_77 "0.41 0.41 0.41"
6 B22_77_8 Ctx8 B22_77 "1.0 .0 1.0"
6 B22_77_9 Ctx9 B22_77 ".0 .0 1.0"
10 105.702847000 w5 WS "B22_77"
20 105.702847000 w5 WS B22_77 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 102
102 0.000000 0 0 -1 -1
10 105.704163000 t4917 S E
10 106.479752000 t4913 S B
10 106.481950000 w1 WS "I"
13 98.766344000 w1 gf 0.000000
13 98.766344000 sched gft 0.000000
13 106.487423000 sched nready 194.000000
13 106.487423000 sched nsubmitted 198.000000
9 106.487423000 po p 104
10 106.488744000 w1 WS "Fi"
6 B22_79 WS B22_79 "0.000000 0.600000 0.400000"
6 B22_79_1 Ctx1 B22_79 "1.0 0.39 1.0"
6 B22_79_2 Ctx2 B22_79 ".0 1.0 .0"
6 B22_79_3 Ctx3 B22_79 "0.87 0.87 .0"
6 B22_79_4 Ctx4 B22_79 ".0 0.95 1.0"
6 B22_79_5 Ctx5 B22_79 ".0 .0 .0"
6 B22_79_6 Ctx6 B22_79 ".0 .0 0.5"
6 B22_79_7 Ctx7 B22_79 "0.41 0.41 0.41"
6 B22_79_8 Ctx8 B22_79 "1.0 .0 1.0"
6 B22_79_9 Ctx9 B22_79 ".0 .0 1.0"
10 106.490956000 w1 WS "B22_79"
20 106.490956000 w1 WS B22_79 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 104
104 0.000000 0 0 -1 -1
10 106.492339000 t4913 S E
10 106.754543000 t4912 S B
10 106.756651000 w0 WS "I"
13 99.024577000 w0 gf 0.000000
13 99.024577000 sched gft 0.000000
13 106.761859000 sched nready 193.000000
13 106.761859000 sched nsubmitted 197.000000
9 106.761859000 po p 97
10 106.763183000 w0 WS "Fi"
6 B22_72 WS B22_72 "0.000000 0.600000 0.400000"
6 B22_72_1 Ctx1 B22_72 "1.0 0.39 1.0"
6 B22_72_2 Ctx2 B22_72 ".0 1.0 .0"
6 B22_72_3 Ctx3 B22_72 "0.87 0.87 .0"
6 B22_72_4 Ctx4 B22_72 ".0 0.95 1.0"
6 B22_72_5 Ctx5 B22_72 ".0 .0 .0"
6 B22_72_6 Ctx6 B22_72 ".0 .0 0.5"
6 B22_72_7 Ctx7 B22_72 "0.41 0.41 0.41"
6 B22_72_8 Ctx8 B22_72 "1.0 .0 1.0"
6 B22_72_9 Ctx9 B22_72 ".0 .0 1.0"
10 106.765322000 w0 WS "B22_72"
20 106.765322000 w0 WS B22_72 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 97
97 0.000000 0 0 -1 -1
10 106.766903000 t4912 S E
10 112.855821000 t4914 S B
10 112.858698000 w2 WS "I"
13 105.034070000 w2 gf 0.000000
13 105.034070000 sched gft 0.000000
13 112.864671000 sched nready 192.000000
13 112.864671000 sched nsubmitted 196.000000
9 112.864671000 po p 105
10 112.866043000 w2 WS "Fi"
6 B22_80 WS B22_80 "0.000000 0.600000 0.400000"
6 B22_80_1 Ctx1 B22_80 "1.0 0.39 1.0"
6 B22_80_2 Ctx2 B22_80 ".0 1.0 .0"
6 B22_80_3 Ctx3 B22_80 "0.87 0.87 .0"
6 B22_80_4 Ctx4 B22_80 ".0 0.95 1.0"
6 B22_80_5 Ctx5 B22_80 ".0 .0 .0"
6 B22_80_6 Ctx6 B22_80 ".0 .0 0.5"
6 B22_80_7 Ctx7 B22_80 "0.41 0.41 0.41"
6 B22_80_8 Ctx8 B22_80 "1.0 .0 1.0"
6 B22_80_9 Ctx9 B22_80 ".0 .0 1.0"
10 112.868620000 w2 WS "B22_80"
20 112.868620000 w2 WS B22_80 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 105
105 0.000000 0 0 -1 -1
10 112.870103000 t4914 S E
10 112.983657000 t4916 S B
10 112.985828000 w4 WS "I"
13 105.277107000 w4 gf 0.000000
13 105.277107000 sched gft 0.000000
13 112.990779000 sched nready 191.000000
13 112.990779000 sched nsubmitted 195.000000
9 112.990779000 po p 107
10 112.992083000 w4 WS "Fi"
6 B22_82 WS B22_82 "0.000000 0.600000 0.400000"
6 B22_82_1 Ctx1 B22_82 "1.0 0.39 1.0"
6 B22_82_2 Ctx2 B22_82 ".0 1.0 .0"
6 B22_82_3 Ctx3 B22_82 "0.87 0.87 .0"
6 B22_82_4 Ctx4 B22_82 ".0 0.95 1.0"
6 B22_82_5 Ctx5 B22_82 ".0 .0 .0"
6 B22_82_6 Ctx6 B22_82 ".0 .0 0.5"
6 B22_82_7 Ctx7 B22_82 "0.41 0.41 0.41"
6 B22_82_8 Ctx8 B22_82 "1.0 .0 1.0"
6 B22_82_9 Ctx9 B22_82 ".0 .0 1.0"
10 112.994446000 w4 WS "B22_82"
20 112.994446000 w4 WS B22_82 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 107
107 0.000000 0 0 -1 -1
10 112.995816000 t4916 S E
10 113.214868000 t4915 S B
10 113.217619000 w3 WS "I"
13 105.510278000 w3 gf 0.000000
13 105.510278000 sched gft 0.000000
13 113.223045000 sched nready 190.000000
13 113.223045000 sched nsubmitted 194.000000
9 113.223045000 po p 100
10 113.224289000 w3 WS "Fi"
6 B22_75 WS B22_75 "0.000000 0.600000 0.400000"
6 B22_75_1 Ctx1 B22_75 "1.0 0.39 1.0"
6 B22_75_2 Ctx2 B22_75 ".0 1.0 .0"
6 B22_75_3 Ctx3 B22_75 "0.87 0.87 .0"
6 B22_75_4 Ctx4 B22_75 ".0 0.95 1.0"
6 B22_75_5 Ctx5 B22_75 ".0 .0 .0"
6 B22_75_6 Ctx6 B22_75 ".0 .0 0.5"
6 B22_75_7 Ctx7 B22_75 "0.41 0.41 0.41"
6 B22_75_8 Ctx8 B22_75 "1.0 .0 1.0"
6 B22_75_9 Ctx9 B22_75 ".0 .0 1.0"
10 113.226721000 w3 WS "B22_75"
20 113.226721000 w3 WS B22_75 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 100
100 0.000000 0 0 -1 -1
10 113.228059000 t4915 S E
10 113.370851000 t4917 S B
10 113.372810000 w5 WS "I"
13 105.693822000 w5 gf 0.000000
13 105.693822000 sched gft 0.000000
13 113.381446000 sched nready 189.000000
13 113.381446000 sched nsubmitted 193.000000
9 113.381446000 po p 108
10 113.382753000 w5 WS "Fi"
6 B22_83 WS B22_83 "0.000000 0.600000 0.400000"
6 B22_83_1 Ctx1 B22_83 "1.0 0.39 1.0"
6 B22_83_2 Ctx2 B22_83 ".0 1.0 .0"
6 B22_83_3 Ctx3 B22_83 "0.87 0.87 .0"
6 B22_83_4 Ctx4 B22_83 ".0 0.95 1.0"
6 B22_83_5 Ctx5 B22_83 ".0 .0 .0"
6 B22_83_6 Ctx6 B22_83 ".0 .0 0.5"
6 B22_83_7 Ctx7 B22_83 "0.41 0.41 0.41"
6 B22_83_8 Ctx8 B22_83 "1.0 .0 1.0"
6 B22_83_9 Ctx9 B22_83 ".0 .0 1.0"
10 113.384997000 w5 WS "B22_83"
20 113.384997000 w5 WS B22_83 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 108
108 0.000000 0 0 -1 -1
10 113.386289000 t4917 S E
10 114.175004000 t4913 S B
10 114.177278000 w1 WS "I"
13 106.481950000 w1 gf 0.000000
13 106.481950000 sched gft 0.000000
13 114.182617000 sched nready 188.000000
13 114.182617000 sched nsubmitted 192.000000
9 114.182617000 po p 110
10 114.183996000 w1 WS "Fi"
6 B22_85 WS B22_85 "0.000000 0.600000 0.400000"
6 B22_85_1 Ctx1 B22_85 "1.0 0.39 1.0"
6 B22_85_2 Ctx2 B22_85 ".0 1.0 .0"
6 B22_85_3 Ctx3 B22_85 "0.87 0.87 .0"
6 B22_85_4 Ctx4 B22_85 ".0 0.95 1.0"
6 B22_85_5 Ctx5 B22_85 ".0 .0 .0"
6 B22_85_6 Ctx6 B22_85 ".0 .0 0.5"
6 B22_85_7 Ctx7 B22_85 "0.41 0.41 0.41"
6 B22_85_8 Ctx8 B22_85 "1.0 .0 1.0"
6 B22_85_9 Ctx9 B22_85 ".0 .0 1.0"
10 114.186179000 w1 WS "B22_85"
20 114.186179000 w1 WS B22_85 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 110
110 0.000000 0 0 -1 -1
10 114.187770000 t4913 S E
10 114.476440000 t4912 S B
10 114.478621000 w0 WS "I"
13 106.756651000 w0 gf 0.000000
13 106.756651000 sched gft 0.000000
13 114.487115000 sched nready 187.000000
13 114.487115000 sched nsubmitted 191.000000
9 114.487115000 po p 103
10 114.488412000 w0 WS "Fi"
6 B22_78 WS B22_78 "0.000000 0.600000 0.400000"
6 B22_78_1 Ctx1 B22_78 "1.0 0.39 1.0"
6 B22_78_2 Ctx2 B22_78 ".0 1.0 .0"
6 B22_78_3 Ctx3 B22_78 "0.87 0.87 .0"
6 B22_78_4 Ctx4 B22_78 ".0 0.95 1.0"
6 B22_78_5 Ctx5 B22_78 ".0 .0 .0"
6 B22_78_6 Ctx6 B22_78 ".0 .0 0.5"
6 B22_78_7 Ctx7 B22_78 "0.41 0.41 0.41"
6 B22_78_8 Ctx8 B22_78 "1.0 .0 1.0"
6 B22_78_9 Ctx9 B22_78 ".0 .0 1.0"
10 114.490751000 w0 WS "B22_78"
20 114.490751000 w0 WS B22_78 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 103
103 0.000000 0 0 -1 -1
10 114.492213000 t4912 S E
10 120.567636000 t4914 S B
10 120.570006000 w2 WS "I"
13 112.858698000 w2 gf 0.000000
13 112.858698000 sched gft 0.000000
13 120.576064000 sched nready 186.000000
13 120.576064000 sched nsubmitted 190.000000
9 120.576064000 po p 111
10 120.577530000 w2 WS "Fi"
6 B22_86 WS B22_86 "0.000000 0.600000 0.400000"
6 B22_86_1 Ctx1 B22_86 "1.0 0.39 1.0"
6 B22_86_2 Ctx2 B22_86 ".0 1.0 .0"
6 B22_86_3 Ctx3 B22_86 "0.87 0.87 .0"
6 B22_86_4 Ctx4 B22_86 ".0 0.95 1.0"
6 B22_86_5 Ctx5 B22_86 ".0 .0 .0"
6 B22_86_6 Ctx6 B22_86 ".0 .0 0.5"
6 B22_86_7 Ctx7 B22_86 "0.41 0.41 0.41"
6 B22_86_8 Ctx8 B22_86 "1.0 .0 1.0"
6 B22_86_9 Ctx9 B22_86 ".0 .0 1.0"
10 120.579901000 w2 WS "B22_86"
20 120.579901000 w2 WS B22_86 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 111
111 0.000000 0 0 -1 -1
10 120.581557000 t4914 S E
10 120.696373000 t4916 S B
10 120.698618000 w4 WS "I"
13 112.985828000 w4 gf 0.000000
13 112.985828000 sched gft 0.000000
13 120.704009000 sched nready 185.000000
13 120.704009000 sched nsubmitted 189.000000
9 120.704009000 po p 113
10 120.705320000 w4 WS "Fi"
6 B22_88 WS B22_88 "0.000000 0.600000 0.400000"
6 B22_88_1 Ctx1 B22_88 "1.0 0.39 1.0"
6 B22_88_2 Ctx2 B22_88 ".0 1.0 .0"
6 B22_88_3 Ctx3 B22_88 "0.87 0.87 .0"
6 B22_88_4 Ctx4 B22_88 ".0 0.95 1.0"
6 B22_88_5 Ctx5 B22_88 ".0 .0 .0"
6 B22_88_6 Ctx6 B22_88 ".0 .0 0.5"
6 B22_88_7 Ctx7 B22_88 "0.41 0.41 0.41"
6 B22_88_8 Ctx8 B22_88 "1.0 .0 1.0"
6 B22_88_9 Ctx9 B22_88 ".0 .0 1.0"
10 120.707754000 w4 WS "B22_88"
20 120.707754000 w4 WS B22_88 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 113
113 0.000000 0 0 -1 -1
10 120.709070000 t4916 S E
10 120.905687000 t4915 S B
10 120.907550000 w3 WS "I"
13 113.217619000 w3 gf 0.000000
13 113.217619000 sched gft 0.000000
13 120.912332000 sched nready 184.000000
13 120.912332000 sched nsubmitted 188.000000
9 120.912332000 po p 106
10 120.913593000 w3 WS "Fi"
6 B22_81 WS B22_81 "0.000000 0.600000 0.400000"
6 B22_81_1 Ctx1 B22_81 "1.0 0.39 1.0"
6 B22_81_2 Ctx2 B22_81 ".0 1.0 .0"
6 B22_81_3 Ctx3 B22_81 "0.87 0.87 .0"
6 B22_81_4 Ctx4 B22_81 ".0 0.95 1.0"
6 B22_81_5 Ctx5 B22_81 ".0 .0 .0"
6 B22_81_6 Ctx6 B22_81 ".0 .0 0.5"
6 B22_81_7 Ctx7 B22_81 "0.41 0.41 0.41"
6 B22_81_8 Ctx8 B22_81 "1.0 .0 1.0"
6 B22_81_9 Ctx9 B22_81 ".0 .0 1.0"
10 120.915566000 w3 WS "B22_81"
20 120.915566000 w3 WS B22_81 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 106
106 0.000000 0 0 -1 -1
10 120.916804000 t4915 S E
10 121.175017000 t4917 S B
10 121.177213000 w5 WS "I"
13 113.372810000 w5 gf 0.000000
13 113.372810000 sched gft 0.000000
13 121.186348000 sched nready 183.000000
13 121.186348000 sched nsubmitted 187.000000
9 121.186348000 po p 114
10 121.187675000 w5 WS "Fi"
6 B22_89 WS B22_89 "0.000000 0.600000 0.400000"
6 B22_89_1 Ctx1 B22_89 "1.0 0.39 1.0"
6 B22_89_2 Ctx2 B22_89 ".0 1.0 .0"
6 B22_89_3 Ctx3 B22_89 "0.87 0.87 .0"
6 B22_89_4 Ctx4 B22_89 ".0 0.95 1.0"
6 B22_89_5 Ctx5 B22_89 ".0 .0 .0"
6 B22_89_6 Ctx6 B22_89 ".0 .0 0.5"
6 B22_89_7 Ctx7 B22_89 "0.41 0.41 0.41"
6 B22_89_8 Ctx8 B22_89 "1.0 .0 1.0"
6 B22_89_9 Ctx9 B22_89 ".0 .0 1.0"
10 121.190036000 w5 WS "B22_89"
20 121.190036000 w5 WS B22_89 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 114
114 0.000000 0 0 -1 -1
10 121.191330000 t4917 S E
10 121.878817000 t4913 S B
10 121.881052000 w1 WS "I"
13 114.177278000 w1 gf 0.000000
13 114.177278000 sched gft 0.000000
13 121.886478000 sched nready 182.000000
13 121.886478000 sched nsubmitted 186.000000
9 121.886478000 po p 116
10 121.887840000 w1 WS "Fi"
6 B22_91 WS B22_91 "0.000000 0.600000 0.400000"
6 B22_91_1 Ctx1 B22_91 "1.0 0.39 1.0"
6 B22_91_2 Ctx2 B22_91 ".0 1.0 .0"
6 B22_91_3 Ctx3 B22_91 "0.87 0.87 .0"
6 B22_91_4 Ctx4 B22_91 ".0 0.95 1.0"
6 B22_91_5 Ctx5 B22_91 ".0 .0 .0"
6 B22_91_6 Ctx6 B22_91 ".0 .0 0.5"
6 B22_91_7 Ctx7 B22_91 "0.41 0.41 0.41"
6 B22_91_8 Ctx8 B22_91 "1.0 .0 1.0"
6 B22_91_9 Ctx9 B22_91 ".0 .0 1.0"
10 121.890030000 w1 WS "B22_91"
20 121.890030000 w1 WS B22_91 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 116
116 0.000000 0 0 -1 -1
10 121.891415000 t4913 S E
10 122.200008000 t4912 S B
10 122.202185000 w0 WS "I"
13 114.478621000 w0 gf 0.000000
13 114.478621000 sched gft 0.000000
13 122.207519000 sched nready 181.000000
13 122.207519000 sched nsubmitted 185.000000
9 122.207519000 po p 109
10 122.208829000 w0 WS "Fi"
6 B22_84 WS B22_84 "0.000000 0.600000 0.400000"
6 B22_84_1 Ctx1 B22_84 "1.0 0.39 1.0"
6 B22_84_2 Ctx2 B22_84 ".0 1.0 .0"
6 B22_84_3 Ctx3 B22_84 "0.87 0.87 .0"
6 B22_84_4 Ctx4 B22_84 ".0 0.95 1.0"
6 B22_84_5 Ctx5 B22_84 ".0 .0 .0"
6 B22_84_6 Ctx6 B22_84 ".0 .0 0.5"
6 B22_84_7 Ctx7 B22_84 "0.41 0.41 0.41"
6 B22_84_8 Ctx8 B22_84 "1.0 .0 1.0"
6 B22_84_9 Ctx9 B22_84 ".0 .0 1.0"
10 122.210887000 w0 WS "B22_84"
20 122.210887000 w0 WS B22_84 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 109
109 0.000000 0 0 -1 -1
10 122.212206000 t4912 S E
10 128.257131000 t4914 S B
10 128.259843000 w2 WS "I"
13 120.570006000 w2 gf 0.000000
13 120.570006000 sched gft 0.000000
13 128.265056000 sched nready 180.000000
13 128.265056000 sched nsubmitted 184.000000
9 128.265056000 po p 117
10 128.266457000 w2 WS "Fi"
6 B22_92 WS B22_92 "0.000000 0.600000 0.400000"
6 B22_92_1 Ctx1 B22_92 "1.0 0.39 1.0"
6 B22_92_2 Ctx2 B22_92 ".0 1.0 .0"
6 B22_92_3 Ctx3 B22_92 "0.87 0.87 .0"
6 B22_92_4 Ctx4 B22_92 ".0 0.95 1.0"
6 B22_92_5 Ctx5 B22_92 ".0 .0 .0"
6 B22_92_6 Ctx6 B22_92 ".0 .0 0.5"
6 B22_92_7 Ctx7 B22_92 "0.41 0.41 0.41"
6 B22_92_8 Ctx8 B22_92 "1.0 .0 1.0"
6 B22_92_9 Ctx9 B22_92 ".0 .0 1.0"
10 128.268442000 w2 WS "B22_92"
20 128.268442000 w2 WS B22_92 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 117
117 0.000000 0 0 -1 -1
10 128.269820000 t4914 S E
10 128.388718000 t4916 S B
10 128.390432000 w4 WS "I"
13 120.698618000 w4 gf 0.000000
13 120.698618000 sched gft 0.000000
13 128.395479000 sched nready 179.000000
13 128.395479000 sched nsubmitted 183.000000
9 128.395479000 po p 119
10 128.396804000 w4 WS "Fi"
6 B22_94 WS B22_94 "0.000000 0.600000 0.400000"
6 B22_94_1 Ctx1 B22_94 "1.0 0.39 1.0"
6 B22_94_2 Ctx2 B22_94 ".0 1.0 .0"
6 B22_94_3 Ctx3 B22_94 "0.87 0.87 .0"
6 B22_94_4 Ctx4 B22_94 ".0 0.95 1.0"
6 B22_94_5 Ctx5 B22_94 ".0 .0 .0"
6 B22_94_6 Ctx6 B22_94 ".0 .0 0.5"
6 B22_94_7 Ctx7 B22_94 "0.41 0.41 0.41"
6 B22_94_8 Ctx8 B22_94 "1.0 .0 1.0"
6 B22_94_9 Ctx9 B22_94 ".0 .0 1.0"
10 128.399232000 w4 WS "B22_94"
20 128.399232000 w4 WS B22_94 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 119
119 0.000000 0 0 -1 -1
10 128.400746000 t4916 S E
10 128.599529000 t4915 S B
10 128.601397000 w3 WS "I"
13 120.907550000 w3 gf 0.000000
13 120.907550000 sched gft 0.000000
13 128.606501000 sched nready 178.000000
13 128.606501000 sched nsubmitted 182.000000
9 128.606501000 po p 112
10 128.607819000 w3 WS "Fi"
6 B22_87 WS B22_87 "0.000000 0.600000 0.400000"
6 B22_87_1 Ctx1 B22_87 "1.0 0.39 1.0"
6 B22_87_2 Ctx2 B22_87 ".0 1.0 .0"
6 B22_87_3 Ctx3 B22_87 "0.87 0.87 .0"
6 B22_87_4 Ctx4 B22_87 ".0 0.95 1.0"
6 B22_87_5 Ctx5 B22_87 ".0 .0 .0"
6 B22_87_6 Ctx6 B22_87 ".0 .0 0.5"
6 B22_87_7 Ctx7 B22_87 "0.41 0.41 0.41"
6 B22_87_8 Ctx8 B22_87 "1.0 .0 1.0"
6 B22_87_9 Ctx9 B22_87 ".0 .0 1.0"
10 128.609904000 w3 WS "B22_87"
20 128.609904000 w3 WS B22_87 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 112
112 0.000000 0 0 -1 -1
10 128.611182000 t4915 S E
10 128.839385000 t4917 S B
10 128.841120000 w5 WS "I"
13 121.177213000 w5 gf 0.000000
13 121.177213000 sched gft 0.000000
13 128.845851000 sched nready 177.000000
13 128.845851000 sched nsubmitted 181.000000
9 128.845851000 po p 120
10 128.847180000 w5 WS "Fi"
6 B22_95 WS B22_95 "0.000000 0.600000 0.400000"
6 B22_95_1 Ctx1 B22_95 "1.0 0.39 1.0"
6 B22_95_2 Ctx2 B22_95 ".0 1.0 .0"
6 B22_95_3 Ctx3 B22_95 "0.87 0.87 .0"
6 B22_95_4 Ctx4 B22_95 ".0 0.95 1.0"
6 B22_95_5 Ctx5 B22_95 ".0 .0 .0"
6 B22_95_6 Ctx6 B22_95 ".0 .0 0.5"
6 B22_95_7 Ctx7 B22_95 "0.41 0.41 0.41"
6 B22_95_8 Ctx8 B22_95 "1.0 .0 1.0"
6 B22_95_9 Ctx9 B22_95 ".0 .0 1.0"
10 128.849149000 w5 WS "B22_95"
20 128.849149000 w5 WS B22_95 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 120
120 0.000000 0 0 -1 -1
10 128.850412000 t4917 S E
10 129.579672000 t4913 S B
10 129.581858000 w1 WS "I"
13 121.881052000 w1 gf 0.000000
13 121.881052000 sched gft 0.000000
13 129.586922000 sched nready 176.000000
13 129.586922000 sched nsubmitted 180.000000
9 129.586922000 po p 122
10 129.588243000 w1 WS "Fi"
6 B22_97 WS B22_97 "0.000000 0.600000 0.400000"
6 B22_97_1 Ctx1 B22_97 "1.0 0.39 1.0"
6 B22_97_2 Ctx2 B22_97 ".0 1.0 .0"
6 B22_97_3 Ctx3 B22_97 "0.87 0.87 .0"
6 B22_97_4 Ctx4 B22_97 ".0 0.95 1.0"
6 B22_97_5 Ctx5 B22_97 ".0 .0 .0"
6 B22_97_6 Ctx6 B22_97 ".0 .0 0.5"
6 B22_97_7 Ctx7 B22_97 "0.41 0.41 0.41"
6 B22_97_8 Ctx8 B22_97 "1.0 .0 1.0"
6 B22_97_9 Ctx9 B22_97 ".0 .0 1.0"
10 129.590576000 w1 WS "B22_97"
20 129.590576000 w1 WS B22_97 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 122
122 0.000000 0 0 -1 -1
10 129.591859000 t4913 S E
10 129.919702000 t4912 S B
10 129.922069000 w0 WS "I"
13 122.202185000 w0 gf 0.000000
13 122.202185000 sched gft 0.000000
13 129.927462000 sched nready 175.000000
13 129.927462000 sched nsubmitted 179.000000
9 129.927462000 po p 115
10 129.928832000 w0 WS "Fi"
6 B22_90 WS B22_90 "0.000000 0.600000 0.400000"
6 B22_90_1 Ctx1 B22_90 "1.0 0.39 1.0"
6 B22_90_2 Ctx2 B22_90 ".0 1.0 .0"
6 B22_90_3 Ctx3 B22_90 "0.87 0.87 .0"
6 B22_90_4 Ctx4 B22_90 ".0 0.95 1.0"
6 B22_90_5 Ctx5 B22_90 ".0 .0 .0"
6 B22_90_6 Ctx6 B22_90 ".0 .0 0.5"
6 B22_90_7 Ctx7 B22_90 "0.41 0.41 0.41"
6 B22_90_8 Ctx8 B22_90 "1.0 .0 1.0"
6 B22_90_9 Ctx9 B22_90 ".0 .0 1.0"
10 129.930816000 w0 WS "B22_90"
20 129.930816000 w0 WS B22_90 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 115
115 0.000000 0 0 -1 -1
10 129.932146000 t4912 S E
10 135.972285000 t4914 S B
10 135.975148000 w2 WS "I"
13 128.259843000 w2 gf 0.000000
13 128.259843000 sched gft 0.000000
13 135.981355000 sched nready 174.000000
13 135.981355000 sched nsubmitted 178.000000
9 135.981355000 po p 123
10 135.982726000 w2 WS "Fi"
6 B22_98 WS B22_98 "0.000000 0.600000 0.400000"
6 B22_98_1 Ctx1 B22_98 "1.0 0.39 1.0"
6 B22_98_2 Ctx2 B22_98 ".0 1.0 .0"
6 B22_98_3 Ctx3 B22_98 "0.87 0.87 .0"
6 B22_98_4 Ctx4 B22_98 ".0 0.95 1.0"
6 B22_98_5 Ctx5 B22_98 ".0 .0 .0"
6 B22_98_6 Ctx6 B22_98 ".0 .0 0.5"
6 B22_98_7 Ctx7 B22_98 "0.41 0.41 0.41"
6 B22_98_8 Ctx8 B22_98 "1.0 .0 1.0"
6 B22_98_9 Ctx9 B22_98 ".0 .0 1.0"
10 135.984857000 w2 WS "B22_98"
20 135.984857000 w2 WS B22_98 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 123
123 0.000000 0 0 -1 -1
10 135.986269000 t4914 S E
10 136.088302000 t4916 S B
10 136.090206000 w4 WS "I"
13 128.390432000 w4 gf 0.000000
13 128.390432000 sched gft 0.000000
13 136.095111000 sched nready 173.000000
13 136.095111000 sched nsubmitted 177.000000
9 136.095111000 po p 125
10 136.096481000 w4 WS "Fi"
6 B22_100 WS B22_100 "0.000000 0.600000 0.400000"
6 B22_100_1 Ctx1 B22_100 "1.0 0.39 1.0"
6 B22_100_2 Ctx2 B22_100 ".0 1.0 .0"
6 B22_100_3 Ctx3 B22_100 "0.87 0.87 .0"
6 B22_100_4 Ctx4 B22_100 ".0 0.95 1.0"
6 B22_100_5 Ctx5 B22_100 ".0 .0 .0"
6 B22_100_6 Ctx6 B22_100 ".0 .0 0.5"
6 B22_100_7 Ctx7 B22_100 "0.41 0.41 0.41"
6 B22_100_8 Ctx8 B22_100 "1.0 .0 1.0"
6 B22_100_9 Ctx9 B22_100 ".0 .0 1.0"
10 136.098684000 w4 WS "B22_100"
20 136.098684000 w4 WS B22_100 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 125
125 0.000000 0 0 -1 -1
10 136.099968000 t4916 S E
10 136.296186000 t4915 S B
10 136.298252000 w3 WS "I"
13 128.601397000 w3 gf 0.000000
13 128.601397000 sched gft 0.000000
13 136.303307000 sched nready 172.000000
13 136.303307000 sched nsubmitted 176.000000
9 136.303307000 po p 118
10 136.304614000 w3 WS "Fi"
6 B22_93 WS B22_93 "0.000000 0.600000 0.400000"
6 B22_93_1 Ctx1 B22_93 "1.0 0.39 1.0"
6 B22_93_2 Ctx2 B22_93 ".0 1.0 .0"
6 B22_93_3 Ctx3 B22_93 "0.87 0.87 .0"
6 B22_93_4 Ctx4 B22_93 ".0 0.95 1.0"
6 B22_93_5 Ctx5 B22_93 ".0 .0 .0"
6 B22_93_6 Ctx6 B22_93 ".0 .0 0.5"
6 B22_93_7 Ctx7 B22_93 "0.41 0.41 0.41"
6 B22_93_8 Ctx8 B22_93 "1.0 .0 1.0"
6 B22_93_9 Ctx9 B22_93 ".0 .0 1.0"
10 136.306649000 w3 WS "B22_93"
20 136.306649000 w3 WS B22_93 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 118
118 0.000000 0 0 -1 -1
10 136.307953000 t4915 S E
10 136.511221000 t4917 S B
10 136.512982000 w5 WS "I"
13 128.841120000 w5 gf 0.000000
13 128.841120000 sched gft 0.000000
13 136.518359000 sched nready 171.000000
13 136.518359000 sched nsubmitted 175.000000
9 136.518359000 po p 126
10 136.519667000 w5 WS "Fi"
6 B22_101 WS B22_101 "0.000000 0.600000 0.400000"
6 B22_101_1 Ctx1 B22_101 "1.0 0.39 1.0"
6 B22_101_2 Ctx2 B22_101 ".0 1.0 .0"
6 B22_101_3 Ctx3 B22_101 "0.87 0.87 .0"
6 B22_101_4 Ctx4 B22_101 ".0 0.95 1.0"
6 B22_101_5 Ctx5 B22_101 ".0 .0 .0"
6 B22_101_6 Ctx6 B22_101 ".0 .0 0.5"
6 B22_101_7 Ctx7 B22_101 "0.41 0.41 0.41"
6 B22_101_8 Ctx8 B22_101 "1.0 .0 1.0"
6 B22_101_9 Ctx9 B22_101 ".0 .0 1.0"
10 136.521790000 w5 WS "B22_101"
20 136.521790000 w5 WS B22_101 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 126
126 0.000000 0 0 -1 -1
10 136.523138000 t4917 S E
10 137.289058000 t4913 S B
10 137.290983000 w1 WS "I"
13 129.581858000 w1 gf 0.000000
13 129.581858000 sched gft 0.000000
13 137.296033000 sched nready 170.000000
13 137.296033000 sched nsubmitted 174.000000
9 137.296033000 po p 128
10 137.297347000 w1 WS "Fi"
6 B22_103 WS B22_103 "0.000000 0.600000 0.400000"
6 B22_103_1 Ctx1 B22_103 "1.0 0.39 1.0"
6 B22_103_2 Ctx2 B22_103 ".0 1.0 .0"
6 B22_103_3 Ctx3 B22_103 "0.87 0.87 .0"
6 B22_103_4 Ctx4 B22_103 ".0 0.95 1.0"
6 B22_103_5 Ctx5 B22_103 ".0 .0 .0"
6 B22_103_6 Ctx6 B22_103 ".0 .0 0.5"
6 B22_103_7 Ctx7 B22_103 "0.41 0.41 0.41"
6 B22_103_8 Ctx8 B22_103 "1.0 .0 1.0"
6 B22_103_9 Ctx9 B22_103 ".0 .0 1.0"
10 137.299408000 w1 WS "B22_103"
20 137.299408000 w1 WS B22_103 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 128
128 0.000000 0 0 -1 -1
10 137.300780000 t4913 S E
10 137.796047000 t4912 S B
10 137.798425000 w0 WS "I"
13 129.922069000 w0 gf 0.000000
13 129.922069000 sched gft 0.000000
13 137.803619000 sched nready 169.000000
13 137.803619000 sched nsubmitted 173.000000
9 137.803619000 po p 121
10 137.804956000 w0 WS "Fi"
6 B22_96 WS B22_96 "0.000000 0.600000 0.400000"
6 B22_96_1 Ctx1 B22_96 "1.0 0.39 1.0"
6 B22_96_2 Ctx2 B22_96 ".0 1.0 .0"
6 B22_96_3 Ctx3 B22_96 "0.87 0.87 .0"
6 B22_96_4 Ctx4 B22_96 ".0 0.95 1.0"
6 B22_96_5 Ctx5 B22_96 ".0 .0 .0"
6 B22_96_6 Ctx6 B22_96 ".0 .0 0.5"
6 B22_96_7 Ctx7 B22_96 "0.41 0.41 0.41"
6 B22_96_8 Ctx8 B22_96 "1.0 .0 1.0"
6 B22_96_9 Ctx9 B22_96 ".0 .0 1.0"
10 137.807050000 w0 WS "B22_96"
20 137.807050000 w0 WS B22_96 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 121
121 0.000000 0 0 -1 -1
10 137.808388000 t4912 S E
10 143.661743000 t4914 S B
10 143.663912000 w2 WS "I"
13 135.975148000 w2 gf 0.000000
13 135.975148000 sched gft 0.000000
13 143.668995000 sched nready 168.000000
13 143.668995000 sched nsubmitted 172.000000
9 143.668995000 po p 129
10 143.670597000 w2 WS "Fi"
6 B22_104 WS B22_104 "0.000000 0.600000 0.400000"
6 B22_104_1 Ctx1 B22_104 "1.0 0.39 1.0"
6 B22_104_2 Ctx2 B22_104 ".0 1.0 .0"
6 B22_104_3 Ctx3 B22_104 "0.87 0.87 .0"
6 B22_104_4 Ctx4 B22_104 ".0 0.95 1.0"
6 B22_104_5 Ctx5 B22_104 ".0 .0 .0"
6 B22_104_6 Ctx6 B22_104 ".0 .0 0.5"
6 B22_104_7 Ctx7 B22_104 "0.41 0.41 0.41"
6 B22_104_8 Ctx8 B22_104 "1.0 .0 1.0"
6 B22_104_9 Ctx9 B22_104 ".0 .0 1.0"
10 143.672848000 w2 WS "B22_104"
20 143.672848000 w2 WS B22_104 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 129
129 0.000000 0 0 -1 -1
10 143.674125000 t4914 S E
10 143.773371000 t4916 S B
10 143.775171000 w4 WS "I"
13 136.090206000 w4 gf 0.000000
13 136.090206000 sched gft 0.000000
13 143.779973000 sched nready 167.000000
13 143.779973000 sched nsubmitted 171.000000
9 143.779973000 po p 131
10 143.781304000 w4 WS "Fi"
6 B22_106 WS B22_106 "0.000000 0.600000 0.400000"
6 B22_106_1 Ctx1 B22_106 "1.0 0.39 1.0"
6 B22_106_2 Ctx2 B22_106 ".0 1.0 .0"
6 B22_106_3 Ctx3 B22_106 "0.87 0.87 .0"
6 B22_106_4 Ctx4 B22_106 ".0 0.95 1.0"
6 B22_106_5 Ctx5 B22_106 ".0 .0 .0"
6 B22_106_6 Ctx6 B22_106 ".0 .0 0.5"
6 B22_106_7 Ctx7 B22_106 "0.41 0.41 0.41"
6 B22_106_8 Ctx8 B22_106 "1.0 .0 1.0"
6 B22_106_9 Ctx9 B22_106 ".0 .0 1.0"
10 143.783456000 w4 WS "B22_106"
20 143.783456000 w4 WS B22_106 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 131
131 0.000000 0 0 -1 -1
10 143.784692000 t4916 S E
10 143.980500000 t4915 S B
10 143.982359000 w3 WS "I"
13 136.298252000 w3 gf 0.000000
13 136.298252000 sched gft 0.000000
13 143.987019000 sched nready 166.000000
13 143.987019000 sched nsubmitted 170.000000
9 143.987019000 po p 124
10 143.988558000 w3 WS "Fi"
6 B22_99 WS B22_99 "0.000000 0.600000 0.400000"
6 B22_99_1 Ctx1 B22_99 "1.0 0.39 1.0"
6 B22_99_2 Ctx2 B22_99 ".0 1.0 .0"
6 B22_99_3 Ctx3 B22_99 "0.87 0.87 .0"
6 B22_99_4 Ctx4 B22_99 ".0 0.95 1.0"
6 B22_99_5 Ctx5 B22_99 ".0 .0 .0"
6 B22_99_6 Ctx6 B22_99 ".0 .0 0.5"
6 B22_99_7 Ctx7 B22_99 "0.41 0.41 0.41"
6 B22_99_8 Ctx8 B22_99 "1.0 .0 1.0"
6 B22_99_9 Ctx9 B22_99 ".0 .0 1.0"
10 143.990506000 w3 WS "B22_99"
20 143.990506000 w3 WS B22_99 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 124
124 0.000000 0 0 -1 -1
10 143.991797000 t4915 S E
10 144.170067000 t4917 S B
10 144.171624000 w5 WS "I"
13 136.512982000 w5 gf 0.000000
13 136.512982000 sched gft 0.000000
13 144.176601000 sched nready 165.000000
13 144.176601000 sched nsubmitted 169.000000
9 144.176601000 po p 132
10 144.177902000 w5 WS "Fi"
6 B22_107 WS B22_107 "0.000000 0.600000 0.400000"
6 B22_107_1 Ctx1 B22_107 "1.0 0.39 1.0"
6 B22_107_2 Ctx2 B22_107 ".0 1.0 .0"
6 B22_107_3 Ctx3 B22_107 "0.87 0.87 .0"
6 B22_107_4 Ctx4 B22_107 ".0 0.95 1.0"
6 B22_107_5 Ctx5 B22_107 ".0 .0 .0"
6 B22_107_6 Ctx6 B22_107 ".0 .0 0.5"
6 B22_107_7 Ctx7 B22_107 "0.41 0.41 0.41"
6 B22_107_8 Ctx8 B22_107 "1.0 .0 1.0"
6 B22_107_9 Ctx9 B22_107 ".0 .0 1.0"
10 144.179907000 w5 WS "B22_107"
20 144.179907000 w5 WS B22_107 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 132
132 0.000000 0 0 -1 -1
10 144.181162000 t4917 S E
10 145.098852000 t4913 S B
10 145.100907000 w1 WS "I"
13 137.290983000 w1 gf 0.000000
13 137.290983000 sched gft 0.000000
13 145.105753000 sched nready 164.000000
13 145.105753000 sched nsubmitted 168.000000
9 145.105753000 po p 134
10 145.107160000 w1 WS "Fi"
6 B22_109 WS B22_109 "0.000000 0.600000 0.400000"
6 B22_109_1 Ctx1 B22_109 "1.0 0.39 1.0"
6 B22_109_2 Ctx2 B22_109 ".0 1.0 .0"
6 B22_109_3 Ctx3 B22_109 "0.87 0.87 .0"
6 B22_109_4 Ctx4 B22_109 ".0 0.95 1.0"
6 B22_109_5 Ctx5 B22_109 ".0 .0 .0"
6 B22_109_6 Ctx6 B22_109 ".0 .0 0.5"
6 B22_109_7 Ctx7 B22_109 "0.41 0.41 0.41"
6 B22_109_8 Ctx8 B22_109 "1.0 .0 1.0"
6 B22_109_9 Ctx9 B22_109 ".0 .0 1.0"
10 145.109122000 w1 WS "B22_109"
20 145.109122000 w1 WS B22_109 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 134
134 0.000000 0 0 -1 -1
10 145.110387000 t4913 S E
10 145.506389000 t4912 S B
10 145.509280000 w0 WS "I"
13 137.798425000 w0 gf 0.000000
13 137.798425000 sched gft 0.000000
13 145.514403000 sched nready 163.000000
13 145.514403000 sched nsubmitted 167.000000
9 145.514403000 po p 127
10 145.515706000 w0 WS "Fi"
6 B22_102 WS B22_102 "0.000000 0.600000 0.400000"
6 B22_102_1 Ctx1 B22_102 "1.0 0.39 1.0"
6 B22_102_2 Ctx2 B22_102 ".0 1.0 .0"
6 B22_102_3 Ctx3 B22_102 "0.87 0.87 .0"
6 B22_102_4 Ctx4 B22_102 ".0 0.95 1.0"
6 B22_102_5 Ctx5 B22_102 ".0 .0 .0"
6 B22_102_6 Ctx6 B22_102 ".0 .0 0.5"
6 B22_102_7 Ctx7 B22_102 "0.41 0.41 0.41"
6 B22_102_8 Ctx8 B22_102 "1.0 .0 1.0"
6 B22_102_9 Ctx9 B22_102 ".0 .0 1.0"
10 145.517811000 w0 WS "B22_102"
20 145.517811000 w0 WS B22_102 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 127
127 0.000000 0 0 -1 -1
10 145.519229000 t4912 S E
10 151.363765000 t4914 S B
10 151.366346000 w2 WS "I"
13 143.663912000 w2 gf 0.000000
13 143.663912000 sched gft 0.000000
13 151.372131000 sched nready 162.000000
13 151.372131000 sched nsubmitted 166.000000
9 151.372131000 po p 135
10 151.373465000 w2 WS "Fi"
6 B22_110 WS B22_110 "0.000000 0.600000 0.400000"
6 B22_110_1 Ctx1 B22_110 "1.0 0.39 1.0"
6 B22_110_2 Ctx2 B22_110 ".0 1.0 .0"
6 B22_110_3 Ctx3 B22_110 "0.87 0.87 .0"
6 B22_110_4 Ctx4 B22_110 ".0 0.95 1.0"
6 B22_110_5 Ctx5 B22_110 ".0 .0 .0"
6 B22_110_6 Ctx6 B22_110 ".0 .0 0.5"
6 B22_110_7 Ctx7 B22_110 "0.41 0.41 0.41"
6 B22_110_8 Ctx8 B22_110 "1.0 .0 1.0"
6 B22_110_9 Ctx9 B22_110 ".0 .0 1.0"
10 151.375712000 w2 WS "B22_110"
20 151.375712000 w2 WS B22_110 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 135
135 0.000000 0 0 -1 -1
10 151.377070000 t4914 S E
10 151.472064000 t4916 S B
10 151.473982000 w4 WS "I"
13 143.775171000 w4 gf 0.000000
13 143.775171000 sched gft 0.000000
13 151.479058000 sched nready 161.000000
13 151.479058000 sched nsubmitted 165.000000
9 151.479058000 po p 137
10 151.480362000 w4 WS "Fi"
6 B22_112 WS B22_112 "0.000000 0.600000 0.400000"
6 B22_112_1 Ctx1 B22_112 "1.0 0.39 1.0"
6 B22_112_2 Ctx2 B22_112 ".0 1.0 .0"
6 B22_112_3 Ctx3 B22_112 "0.87 0.87 .0"
6 B22_112_4 Ctx4 B22_112 ".0 0.95 1.0"
6 B22_112_5 Ctx5 B22_112 ".0 .0 .0"
6 B22_112_6 Ctx6 B22_112 ".0 .0 0.5"
6 B22_112_7 Ctx7 B22_112 "0.41 0.41 0.41"
6 B22_112_8 Ctx8 B22_112 "1.0 .0 1.0"
6 B22_112_9 Ctx9 B22_112 ".0 .0 1.0"
10 151.482524000 w4 WS "B22_112"
20 151.482524000 w4 WS B22_112 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 137
137 0.000000 0 0 -1 -1
10 151.483798000 t4916 S E
10 151.818200000 t4915 S B
10 151.819881000 w3 WS "I"
13 143.982359000 w3 gf 0.000000
13 143.982359000 sched gft 0.000000
13 151.824680000 sched nready 160.000000
13 151.824680000 sched nsubmitted 164.000000
9 151.824680000 po p 130
10 151.825953000 w3 WS "Fi"
6 B22_105 WS B22_105 "0.000000 0.600000 0.400000"
6 B22_105_1 Ctx1 B22_105 "1.0 0.39 1.0"
6 B22_105_2 Ctx2 B22_105 ".0 1.0 .0"
6 B22_105_3 Ctx3 B22_105 "0.87 0.87 .0"
6 B22_105_4 Ctx4 B22_105 ".0 0.95 1.0"
6 B22_105_5 Ctx5 B22_105 ".0 .0 .0"
6 B22_105_6 Ctx6 B22_105 ".0 .0 0.5"
6 B22_105_7 Ctx7 B22_105 "0.41 0.41 0.41"
6 B22_105_8 Ctx8 B22_105 "1.0 .0 1.0"
6 B22_105_9 Ctx9 B22_105 ".0 .0 1.0"
10 151.827919000 w3 WS "B22_105"
20 151.827919000 w3 WS B22_105 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 130
130 0.000000 0 0 -1 -1
10 151.829193000 t4915 S E
10 151.848259000 t4917 S B
10 151.850604000 w5 WS "I"
13 144.171624000 w5 gf 0.000000
13 144.171624000 sched gft 0.000000
13 151.855890000 sched nready 159.000000
13 151.855890000 sched nsubmitted 163.000000
9 151.855890000 po p 138
10 151.857204000 w5 WS "Fi"
6 B22_113 WS B22_113 "0.000000 0.600000 0.400000"
6 B22_113_1 Ctx1 B22_113 "1.0 0.39 1.0"
6 B22_113_2 Ctx2 B22_113 ".0 1.0 .0"
6 B22_113_3 Ctx3 B22_113 "0.87 0.87 .0"
6 B22_113_4 Ctx4 B22_113 ".0 0.95 1.0"
6 B22_113_5 Ctx5 B22_113 ".0 .0 .0"
6 B22_113_6 Ctx6 B22_113 ".0 .0 0.5"
6 B22_113_7 Ctx7 B22_113 "0.41 0.41 0.41"
6 B22_113_8 Ctx8 B22_113 "1.0 .0 1.0"
6 B22_113_9 Ctx9 B22_113 ".0 .0 1.0"
10 151.859445000 w5 WS "B22_113"
20 151.859445000 w5 WS B22_113 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 138
138 0.000000 0 0 -1 -1
10 151.860803000 t4917 S E
10 152.812921000 t4913 S B
10 152.814869000 w1 WS "I"
13 145.100907000 w1 gf 0.000000
13 145.100907000 sched gft 0.000000
13 152.819989000 sched nready 158.000000
13 152.819989000 sched nsubmitted 162.000000
9 152.819989000 po p 140
10 152.821267000 w1 WS "Fi"
6 B22_115 WS B22_115 "0.000000 0.600000 0.400000"
6 B22_115_1 Ctx1 B22_115 "1.0 0.39 1.0"
6 B22_115_2 Ctx2 B22_115 ".0 1.0 .0"
6 B22_115_3 Ctx3 B22_115 "0.87 0.87 .0"
6 B22_115_4 Ctx4 B22_115 ".0 0.95 1.0"
6 B22_115_5 Ctx5 B22_115 ".0 .0 .0"
6 B22_115_6 Ctx6 B22_115 ".0 .0 0.5"
6 B22_115_7 Ctx7 B22_115 "0.41 0.41 0.41"
6 B22_115_8 Ctx8 B22_115 "1.0 .0 1.0"
6 B22_115_9 Ctx9 B22_115 ".0 .0 1.0"
10 152.823226000 w1 WS "B22_115"
20 152.823226000 w1 WS B22_115 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 140
140 0.000000 0 0 -1 -1
10 152.824638000 t4913 S E
10 153.232649000 t4912 S B
10 153.234701000 w0 WS "I"
13 145.509280000 w0 gf 0.000000
13 145.509280000 sched gft 0.000000
13 153.240071000 sched nready 157.000000
13 153.240071000 sched nsubmitted 161.000000
9 153.240071000 po p 133
10 153.241407000 w0 WS "Fi"
6 B22_108 WS B22_108 "0.000000 0.600000 0.400000"
6 B22_108_1 Ctx1 B22_108 "1.0 0.39 1.0"
6 B22_108_2 Ctx2 B22_108 ".0 1.0 .0"
6 B22_108_3 Ctx3 B22_108 "0.87 0.87 .0"
6 B22_108_4 Ctx4 B22_108 ".0 0.95 1.0"
6 B22_108_5 Ctx5 B22_108 ".0 .0 .0"
6 B22_108_6 Ctx6 B22_108 ".0 .0 0.5"
6 B22_108_7 Ctx7 B22_108 "0.41 0.41 0.41"
6 B22_108_8 Ctx8 B22_108 "1.0 .0 1.0"
6 B22_108_9 Ctx9 B22_108 ".0 .0 1.0"
10 153.243496000 w0 WS "B22_108"
20 153.243496000 w0 WS B22_108 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 133
133 0.000000 0 0 -1 -1
10 153.244804000 t4912 S E
10 159.051513000 t4914 S B
10 159.053663000 w2 WS "I"
13 151.366346000 w2 gf 0.000000
13 151.366346000 sched gft 0.000000
13 159.059211000 sched nready 156.000000
13 159.059211000 sched nsubmitted 160.000000
9 159.059211000 po p 141
10 159.060560000 w2 WS "Fi"
6 B22_116 WS B22_116 "0.000000 0.600000 0.400000"
6 B22_116_1 Ctx1 B22_116 "1.0 0.39 1.0"
6 B22_116_2 Ctx2 B22_116 ".0 1.0 .0"
6 B22_116_3 Ctx3 B22_116 "0.87 0.87 .0"
6 B22_116_4 Ctx4 B22_116 ".0 0.95 1.0"
6 B22_116_5 Ctx5 B22_116 ".0 .0 .0"
6 B22_116_6 Ctx6 B22_116 ".0 .0 0.5"
6 B22_116_7 Ctx7 B22_116 "0.41 0.41 0.41"
6 B22_116_8 Ctx8 B22_116 "1.0 .0 1.0"
6 B22_116_9 Ctx9 B22_116 ".0 .0 1.0"
10 159.062911000 w2 WS "B22_116"
20 159.062911000 w2 WS B22_116 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 141
141 0.000000 0 0 -1 -1
10 159.064347000 t4914 S E
10 159.294986000 t4916 S B
10 159.297040000 w4 WS "I"
13 151.473982000 w4 gf 0.000000
13 151.473982000 sched gft 0.000000
13 159.302166000 sched nready 155.000000
13 159.302166000 sched nsubmitted 159.000000
9 159.302166000 po p 143
10 159.303549000 w4 WS "Fi"
6 B22_118 WS B22_118 "0.000000 0.600000 0.400000"
6 B22_118_1 Ctx1 B22_118 "1.0 0.39 1.0"
6 B22_118_2 Ctx2 B22_118 ".0 1.0 .0"
6 B22_118_3 Ctx3 B22_118 "0.87 0.87 .0"
6 B22_118_4 Ctx4 B22_118 ".0 0.95 1.0"
6 B22_118_5 Ctx5 B22_118 ".0 .0 .0"
6 B22_118_6 Ctx6 B22_118 ".0 .0 0.5"
6 B22_118_7 Ctx7 B22_118 "0.41 0.41 0.41"
6 B22_118_8 Ctx8 B22_118 "1.0 .0 1.0"
6 B22_118_9 Ctx9 B22_118 ".0 .0 1.0"
10 159.305945000 w4 WS "B22_118"
20 159.305945000 w4 WS B22_118 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 143
143 0.000000 0 0 -1 -1
10 159.307277000 t4916 S E
10 159.505427000 t4915 S B
10 159.507352000 w3 WS "I"
13 151.819881000 w3 gf 0.000000
13 151.819881000 sched gft 0.000000
13 159.512018000 sched nready 154.000000
13 159.512018000 sched nsubmitted 158.000000
9 159.512018000 po p 136
10 159.513309000 w3 WS "Fi"
6 B22_111 WS B22_111 "0.000000 0.600000 0.400000"
6 B22_111_1 Ctx1 B22_111 "1.0 0.39 1.0"
6 B22_111_2 Ctx2 B22_111 ".0 1.0 .0"
6 B22_111_3 Ctx3 B22_111 "0.87 0.87 .0"
6 B22_111_4 Ctx4 B22_111 ".0 0.95 1.0"
6 B22_111_5 Ctx5 B22_111 ".0 .0 .0"
6 B22_111_6 Ctx6 B22_111 ".0 .0 0.5"
6 B22_111_7 Ctx7 B22_111 "0.41 0.41 0.41"
6 B22_111_8 Ctx8 B22_111 "1.0 .0 1.0"
6 B22_111_9 Ctx9 B22_111 ".0 .0 1.0"
10 159.515334000 w3 WS "B22_111"
20 159.515334000 w3 WS B22_111 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 136
136 0.000000 0 0 -1 -1
10 159.516591000 t4915 S E
10 159.522064000 t4917 S B
10 159.524543000 w5 WS "I"
13 151.850604000 w5 gf 0.000000
13 151.850604000 sched gft 0.000000
13 159.530284000 sched nready 153.000000
13 159.530284000 sched nsubmitted 157.000000
9 159.530284000 po p 144
10 159.531721000 w5 WS "Fi"
6 B22_119 WS B22_119 "0.000000 0.600000 0.400000"
6 B22_119_1 Ctx1 B22_119 "1.0 0.39 1.0"
6 B22_119_2 Ctx2 B22_119 ".0 1.0 .0"
6 B22_119_3 Ctx3 B22_119 "0.87 0.87 .0"
6 B22_119_4 Ctx4 B22_119 ".0 0.95 1.0"
6 B22_119_5 Ctx5 B22_119 ".0 .0 .0"
6 B22_119_6 Ctx6 B22_119 ".0 .0 0.5"
6 B22_119_7 Ctx7 B22_119 "0.41 0.41 0.41"
6 B22_119_8 Ctx8 B22_119 "1.0 .0 1.0"
6 B22_119_9 Ctx9 B22_119 ".0 .0 1.0"
10 159.533847000 w5 WS "B22_119"
20 159.533847000 w5 WS B22_119 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 144
144 0.000000 0 0 -1 -1
10 159.535445000 t4917 S E
10 160.497990000 t4913 S B
10 160.499808000 w1 WS "I"
13 152.814869000 w1 gf 0.000000
13 152.814869000 sched gft 0.000000
13 160.504704000 sched nready 152.000000
13 160.504704000 sched nsubmitted 156.000000
9 160.504704000 po p 146
10 160.506060000 w1 WS "Fi"
6 B22_121 WS B22_121 "0.000000 0.600000 0.400000"
6 B22_121_1 Ctx1 B22_121 "1.0 0.39 1.0"
6 B22_121_2 Ctx2 B22_121 ".0 1.0 .0"
6 B22_121_3 Ctx3 B22_121 "0.87 0.87 .0"
6 B22_121_4 Ctx4 B22_121 ".0 0.95 1.0"
6 B22_121_5 Ctx5 B22_121 ".0 .0 .0"
6 B22_121_6 Ctx6 B22_121 ".0 .0 0.5"
6 B22_121_7 Ctx7 B22_121 "0.41 0.41 0.41"
6 B22_121_8 Ctx8 B22_121 "1.0 .0 1.0"
6 B22_121_9 Ctx9 B22_121 ".0 .0 1.0"
10 160.508353000 w1 WS "B22_121"
20 160.508353000 w1 WS B22_121 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 146
146 0.000000 0 0 -1 -1
10 160.509634000 t4913 S E
10 160.924694000 t4912 S B
10 160.927109000 w0 WS "I"
13 153.234701000 w0 gf 0.000000
13 153.234701000 sched gft 0.000000
13 160.932049000 sched nready 151.000000
13 160.932049000 sched nsubmitted 155.000000
9 160.932049000 po p 139
10 160.933376000 w0 WS "Fi"
6 B22_114 WS B22_114 "0.000000 0.600000 0.400000"
6 B22_114_1 Ctx1 B22_114 "1.0 0.39 1.0"
6 B22_114_2 Ctx2 B22_114 ".0 1.0 .0"
6 B22_114_3 Ctx3 B22_114 "0.87 0.87 .0"
6 B22_114_4 Ctx4 B22_114 ".0 0.95 1.0"
6 B22_114_5 Ctx5 B22_114 ".0 .0 .0"
6 B22_114_6 Ctx6 B22_114 ".0 .0 0.5"
6 B22_114_7 Ctx7 B22_114 "0.41 0.41 0.41"
6 B22_114_8 Ctx8 B22_114 "1.0 .0 1.0"
6 B22_114_9 Ctx9 B22_114 ".0 .0 1.0"
10 160.935395000 w0 WS "B22_114"
20 160.935395000 w0 WS B22_114 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 139
139 0.000000 0 0 -1 -1
10 160.936742000 t4912 S E
10 166.880155000 t4914 S B
10 166.883123000 w2 WS "I"
13 159.053663000 w2 gf 0.000000
13 159.053663000 sched gft 0.000000
13 166.888795000 sched nready 150.000000
13 166.888795000 sched nsubmitted 154.000000
9 166.888795000 po p 147
10 166.890361000 w2 WS "Fi"
6 B22_122 WS B22_122 "0.000000 0.600000 0.400000"
6 B22_122_1 Ctx1 B22_122 "1.0 0.39 1.0"
6 B22_122_2 Ctx2 B22_122 ".0 1.0 .0"
6 B22_122_3 Ctx3 B22_122 "0.87 0.87 .0"
6 B22_122_4 Ctx4 B22_122 ".0 0.95 1.0"
6 B22_122_5 Ctx5 B22_122 ".0 .0 .0"
6 B22_122_6 Ctx6 B22_122 ".0 .0 0.5"
6 B22_122_7 Ctx7 B22_122 "0.41 0.41 0.41"
6 B22_122_8 Ctx8 B22_122 "1.0 .0 1.0"
6 B22_122_9 Ctx9 B22_122 ".0 .0 1.0"
10 166.892545000 w2 WS "B22_122"
20 166.892545000 w2 WS B22_122 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 147
147 0.000000 0 0 -1 -1
10 166.894126000 t4914 S E
10 166.982923000 t4916 S B
10 166.984964000 w4 WS "I"
13 159.297040000 w4 gf 0.000000
13 159.297040000 sched gft 0.000000
13 166.989721000 sched nready 149.000000
13 166.989721000 sched nsubmitted 153.000000
9 166.989721000 po p 149
10 166.991008000 w4 WS "Fi"
6 B22_124 WS B22_124 "0.000000 0.600000 0.400000"
6 B22_124_1 Ctx1 B22_124 "1.0 0.39 1.0"
6 B22_124_2 Ctx2 B22_124 ".0 1.0 .0"
6 B22_124_3 Ctx3 B22_124 "0.87 0.87 .0"
6 B22_124_4 Ctx4 B22_124 ".0 0.95 1.0"
6 B22_124_5 Ctx5 B22_124 ".0 .0 .0"
6 B22_124_6 Ctx6 B22_124 ".0 .0 0.5"
6 B22_124_7 Ctx7 B22_124 "0.41 0.41 0.41"
6 B22_124_8 Ctx8 B22_124 "1.0 .0 1.0"
6 B22_124_9 Ctx9 B22_124 ".0 .0 1.0"
10 166.993371000 w4 WS "B22_124"
20 166.993371000 w4 WS B22_124 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 149
149 0.000000 0 0 -1 -1
10 166.994666000 t4916 S E
10 167.199030000 t4915 S B
10 167.200348000 t4917 S B
10 167.200991000 w3 WS "I"
13 159.507352000 w3 gf 0.000000
13 159.507352000 sched gft 0.000000
10 167.202846000 w5 WS "I"
13 159.524543000 w5 gf 0.000000
13 159.524543000 sched gft 0.000000
13 167.205886000 sched nready 148.000000
13 167.205886000 sched nsubmitted 152.000000
9 167.205886000 po p 142
10 167.207282000 w3 WS "Fi"
13 167.208529000 sched nready 147.000000
13 167.208529000 sched nsubmitted 151.000000
9 167.208529000 po p 150
6 B22_117 WS B22_117 "0.000000 0.600000 0.400000"
6 B22_117_1 Ctx1 B22_117 "1.0 0.39 1.0"
6 B22_117_2 Ctx2 B22_117 ".0 1.0 .0"
6 B22_117_3 Ctx3 B22_117 "0.87 0.87 .0"
6 B22_117_4 Ctx4 B22_117 ".0 0.95 1.0"
6 B22_117_5 Ctx5 B22_117 ".0 .0 .0"
6 B22_117_6 Ctx6 B22_117 ".0 .0 0.5"
6 B22_117_7 Ctx7 B22_117 "0.41 0.41 0.41"
6 B22_117_8 Ctx8 B22_117 "1.0 .0 1.0"
6 B22_117_9 Ctx9 B22_117 ".0 .0 1.0"
10 167.209775000 w3 WS "B22_117"
10 167.209985000 w5 WS "Fi"
20 167.209775000 w3 WS B22_117 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 142
142 0.000000 0 0 -1 -1
10 167.211404000 t4915 S E
6 B22_125 WS B22_125 "0.000000 0.600000 0.400000"
6 B22_125_1 Ctx1 B22_125 "1.0 0.39 1.0"
6 B22_125_2 Ctx2 B22_125 ".0 1.0 .0"
6 B22_125_3 Ctx3 B22_125 "0.87 0.87 .0"
6 B22_125_4 Ctx4 B22_125 ".0 0.95 1.0"
6 B22_125_5 Ctx5 B22_125 ".0 .0 .0"
6 B22_125_6 Ctx6 B22_125 ".0 .0 0.5"
6 B22_125_7 Ctx7 B22_125 "0.41 0.41 0.41"
6 B22_125_8 Ctx8 B22_125 "1.0 .0 1.0"
6 B22_125_9 Ctx9 B22_125 ".0 .0 1.0"
10 167.212897000 w5 WS "B22_125"
20 167.212897000 w5 WS B22_125 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 150
150 0.000000 0 0 -1 -1
10 167.214322000 t4917 S E
10 168.190162000 t4913 S B
10 168.192094000 w1 WS "I"
13 160.499808000 w1 gf 0.000000
13 160.499808000 sched gft 0.000000
13 168.196737000 sched nready 146.000000
13 168.196737000 sched nsubmitted 150.000000
9 168.196737000 po p 152
10 168.198023000 w1 WS "Fi"
6 B22_127 WS B22_127 "0.000000 0.600000 0.400000"
6 B22_127_1 Ctx1 B22_127 "1.0 0.39 1.0"
6 B22_127_2 Ctx2 B22_127 ".0 1.0 .0"
6 B22_127_3 Ctx3 B22_127 "0.87 0.87 .0"
6 B22_127_4 Ctx4 B22_127 ".0 0.95 1.0"
6 B22_127_5 Ctx5 B22_127 ".0 .0 .0"
6 B22_127_6 Ctx6 B22_127 ".0 .0 0.5"
6 B22_127_7 Ctx7 B22_127 "0.41 0.41 0.41"
6 B22_127_8 Ctx8 B22_127 "1.0 .0 1.0"
6 B22_127_9 Ctx9 B22_127 ".0 .0 1.0"
10 168.200107000 w1 WS "B22_127"
20 168.200107000 w1 WS B22_127 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 152
152 0.000000 0 0 -1 -1
10 168.201487000 t4913 S E
10 168.653617000 t4912 S B
10 168.656105000 w0 WS "I"
13 160.927109000 w0 gf 0.000000
13 160.927109000 sched gft 0.000000
13 168.661135000 sched nready 145.000000
13 168.661135000 sched nsubmitted 149.000000
9 168.661135000 po p 145
10 168.662432000 w0 WS "Fi"
6 B22_120 WS B22_120 "0.000000 0.600000 0.400000"
6 B22_120_1 Ctx1 B22_120 "1.0 0.39 1.0"
6 B22_120_2 Ctx2 B22_120 ".0 1.0 .0"
6 B22_120_3 Ctx3 B22_120 "0.87 0.87 .0"
6 B22_120_4 Ctx4 B22_120 ".0 0.95 1.0"
6 B22_120_5 Ctx5 B22_120 ".0 .0 .0"
6 B22_120_6 Ctx6 B22_120 ".0 .0 0.5"
6 B22_120_7 Ctx7 B22_120 "0.41 0.41 0.41"
6 B22_120_8 Ctx8 B22_120 "1.0 .0 1.0"
6 B22_120_9 Ctx9 B22_120 ".0 .0 1.0"
10 168.664894000 w0 WS "B22_120"
20 168.664894000 w0 WS B22_120 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 145
145 0.000000 0 0 -1 -1
10 168.666207000 t4912 S E
10 174.588972000 t4914 S B
10 174.591394000 w2 WS "I"
13 166.883123000 w2 gf 0.000000
13 166.883123000 sched gft 0.000000
13 174.596520000 sched nready 144.000000
13 174.596520000 sched nsubmitted 148.000000
9 174.596520000 po p 153
10 174.597790000 w2 WS "Fi"
6 B22_128 WS B22_128 "0.000000 0.600000 0.400000"
6 B22_128_1 Ctx1 B22_128 "1.0 0.39 1.0"
6 B22_128_2 Ctx2 B22_128 ".0 1.0 .0"
6 B22_128_3 Ctx3 B22_128 "0.87 0.87 .0"
6 B22_128_4 Ctx4 B22_128 ".0 0.95 1.0"
6 B22_128_5 Ctx5 B22_128 ".0 .0 .0"
6 B22_128_6 Ctx6 B22_128 ".0 .0 0.5"
6 B22_128_7 Ctx7 B22_128 "0.41 0.41 0.41"
6 B22_128_8 Ctx8 B22_128 "1.0 .0 1.0"
6 B22_128_9 Ctx9 B22_128 ".0 .0 1.0"
10 174.600376000 w2 WS "B22_128"
20 174.600376000 w2 WS B22_128 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 153
153 0.000000 0 0 -1 -1
10 174.601823000 t4914 S E
10 174.688810000 t4916 S B
10 174.690681000 w4 WS "I"
13 166.984964000 w4 gf 0.000000
13 166.984964000 sched gft 0.000000
13 174.695955000 sched nready 143.000000
13 174.695955000 sched nsubmitted 147.000000
9 174.695955000 po p 155
10 174.697267000 w4 WS "Fi"
6 B22_130 WS B22_130 "0.000000 0.600000 0.400000"
6 B22_130_1 Ctx1 B22_130 "1.0 0.39 1.0"
6 B22_130_2 Ctx2 B22_130 ".0 1.0 .0"
6 B22_130_3 Ctx3 B22_130 "0.87 0.87 .0"
6 B22_130_4 Ctx4 B22_130 ".0 0.95 1.0"
6 B22_130_5 Ctx5 B22_130 ".0 .0 .0"
6 B22_130_6 Ctx6 B22_130 ".0 .0 0.5"
6 B22_130_7 Ctx7 B22_130 "0.41 0.41 0.41"
6 B22_130_8 Ctx8 B22_130 "1.0 .0 1.0"
6 B22_130_9 Ctx9 B22_130 ".0 .0 1.0"
10 174.699513000 w4 WS "B22_130"
20 174.699513000 w4 WS B22_130 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 155
155 0.000000 0 0 -1 -1
10 174.700817000 t4916 S E
10 174.867806000 t4917 S B
10 174.870335000 w5 WS "I"
13 167.202846000 w5 gf 0.000000
13 174.875661000 sched nready 142.000000
13 174.875661000 sched nsubmitted 146.000000
9 174.875661000 po p 156
10 174.876972000 w5 WS "Fi"
6 B22_131 WS B22_131 "0.000000 0.600000 0.400000"
6 B22_131_1 Ctx1 B22_131 "1.0 0.39 1.0"
6 B22_131_2 Ctx2 B22_131 ".0 1.0 .0"
6 B22_131_3 Ctx3 B22_131 "0.87 0.87 .0"
6 B22_131_4 Ctx4 B22_131 ".0 0.95 1.0"
6 B22_131_5 Ctx5 B22_131 ".0 .0 .0"
6 B22_131_6 Ctx6 B22_131 ".0 .0 0.5"
6 B22_131_7 Ctx7 B22_131 "0.41 0.41 0.41"
6 B22_131_8 Ctx8 B22_131 "1.0 .0 1.0"
6 B22_131_9 Ctx9 B22_131 ".0 .0 1.0"
10 174.879171000 w5 WS "B22_131"
20 174.879171000 w5 WS B22_131 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 156
156 0.000000 0 0 -1 -1
10 174.880576000 t4917 S E
10 174.892668000 t4915 S B
10 174.894690000 w3 WS "I"
13 167.200991000 w3 gf 0.000000
13 167.200991000 sched gft 0.000000
13 167.202846000 sched gft 0.000000
13 174.899343000 sched nready 141.000000
13 174.899343000 sched nsubmitted 145.000000
9 174.899343000 po p 148
10 174.900616000 w3 WS "Fi"
6 B22_123 WS B22_123 "0.000000 0.600000 0.400000"
6 B22_123_1 Ctx1 B22_123 "1.0 0.39 1.0"
6 B22_123_2 Ctx2 B22_123 ".0 1.0 .0"
6 B22_123_3 Ctx3 B22_123 "0.87 0.87 .0"
6 B22_123_4 Ctx4 B22_123 ".0 0.95 1.0"
6 B22_123_5 Ctx5 B22_123 ".0 .0 .0"
6 B22_123_6 Ctx6 B22_123 ".0 .0 0.5"
6 B22_123_7 Ctx7 B22_123 "0.41 0.41 0.41"
6 B22_123_8 Ctx8 B22_123 "1.0 .0 1.0"
6 B22_123_9 Ctx9 B22_123 ".0 .0 1.0"
10 174.902711000 w3 WS "B22_123"
20 174.902711000 w3 WS B22_123 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 148
148 0.000000 0 0 -1 -1
10 174.904368000 t4915 S E
10 175.877204000 t4913 S B
10 175.879052000 w1 WS "I"
13 168.192094000 w1 gf 0.000000
13 168.192094000 sched gft 0.000000
13 175.884059000 sched nready 140.000000
13 175.884059000 sched nsubmitted 144.000000
9 175.884059000 po p 158
10 175.885334000 w1 WS "Fi"
6 B22_133 WS B22_133 "0.000000 0.600000 0.400000"
6 B22_133_1 Ctx1 B22_133 "1.0 0.39 1.0"
6 B22_133_2 Ctx2 B22_133 ".0 1.0 .0"
6 B22_133_3 Ctx3 B22_133 "0.87 0.87 .0"
6 B22_133_4 Ctx4 B22_133 ".0 0.95 1.0"
6 B22_133_5 Ctx5 B22_133 ".0 .0 .0"
6 B22_133_6 Ctx6 B22_133 ".0 .0 0.5"
6 B22_133_7 Ctx7 B22_133 "0.41 0.41 0.41"
6 B22_133_8 Ctx8 B22_133 "1.0 .0 1.0"
6 B22_133_9 Ctx9 B22_133 ".0 .0 1.0"
10 175.887379000 w1 WS "B22_133"
20 175.887379000 w1 WS B22_133 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 158
158 0.000000 0 0 -1 -1
10 175.888682000 t4913 S E
10 176.361468000 t4912 S B
10 176.363863000 w0 WS "I"
13 168.656105000 w0 gf 0.000000
13 168.656105000 sched gft 0.000000
13 176.369349000 sched nready 139.000000
13 176.369349000 sched nsubmitted 143.000000
9 176.369349000 po p 151
10 176.370698000 w0 WS "Fi"
6 B22_126 WS B22_126 "0.000000 0.600000 0.400000"
6 B22_126_1 Ctx1 B22_126 "1.0 0.39 1.0"
6 B22_126_2 Ctx2 B22_126 ".0 1.0 .0"
6 B22_126_3 Ctx3 B22_126 "0.87 0.87 .0"
6 B22_126_4 Ctx4 B22_126 ".0 0.95 1.0"
6 B22_126_5 Ctx5 B22_126 ".0 .0 .0"
6 B22_126_6 Ctx6 B22_126 ".0 .0 0.5"
6 B22_126_7 Ctx7 B22_126 "0.41 0.41 0.41"
6 B22_126_8 Ctx8 B22_126 "1.0 .0 1.0"
6 B22_126_9 Ctx9 B22_126 ".0 .0 1.0"
10 176.372936000 w0 WS "B22_126"
20 176.372936000 w0 WS B22_126 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 151
151 0.000000 0 0 -1 -1
10 176.374227000 t4912 S E
10 182.281959000 t4914 S B
10 182.284774000 w2 WS "I"
13 174.591394000 w2 gf 0.000000
13 174.591394000 sched gft 0.000000
13 182.290278000 sched nready 138.000000
13 182.290278000 sched nsubmitted 142.000000
9 182.290278000 po p 159
10 182.291578000 w2 WS "Fi"
6 B22_134 WS B22_134 "0.000000 0.600000 0.400000"
6 B22_134_1 Ctx1 B22_134 "1.0 0.39 1.0"
6 B22_134_2 Ctx2 B22_134 ".0 1.0 .0"
6 B22_134_3 Ctx3 B22_134 "0.87 0.87 .0"
6 B22_134_4 Ctx4 B22_134 ".0 0.95 1.0"
6 B22_134_5 Ctx5 B22_134 ".0 .0 .0"
6 B22_134_6 Ctx6 B22_134 ".0 .0 0.5"
6 B22_134_7 Ctx7 B22_134 "0.41 0.41 0.41"
6 B22_134_8 Ctx8 B22_134 "1.0 .0 1.0"
6 B22_134_9 Ctx9 B22_134 ".0 .0 1.0"
10 182.293828000 w2 WS "B22_134"
20 182.293828000 w2 WS B22_134 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 159
159 0.000000 0 0 -1 -1
10 182.295469000 t4914 S E
10 182.378538000 t4916 S B
10 182.380370000 w4 WS "I"
13 174.690681000 w4 gf 0.000000
13 174.690681000 sched gft 0.000000
13 182.385376000 sched nready 137.000000
13 182.385376000 sched nsubmitted 141.000000
9 182.385376000 po p 161
10 182.386721000 w4 WS "Fi"
6 B22_136 WS B22_136 "0.000000 0.600000 0.400000"
6 B22_136_1 Ctx1 B22_136 "1.0 0.39 1.0"
6 B22_136_2 Ctx2 B22_136 ".0 1.0 .0"
6 B22_136_3 Ctx3 B22_136 "0.87 0.87 .0"
6 B22_136_4 Ctx4 B22_136 ".0 0.95 1.0"
6 B22_136_5 Ctx5 B22_136 ".0 .0 .0"
6 B22_136_6 Ctx6 B22_136 ".0 .0 0.5"
6 B22_136_7 Ctx7 B22_136 "0.41 0.41 0.41"
6 B22_136_8 Ctx8 B22_136 "1.0 .0 1.0"
6 B22_136_9 Ctx9 B22_136 ".0 .0 1.0"
10 182.388861000 w4 WS "B22_136"
20 182.388861000 w4 WS B22_136 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 161
161 0.000000 0 0 -1 -1
10 182.390215000 t4916 S E
10 182.543336000 t4917 S B
10 182.545694000 w5 WS "I"
13 174.870335000 w5 gf 0.000000
13 174.870335000 sched gft 0.000000
13 182.551804000 sched nready 136.000000
13 182.551804000 sched nsubmitted 140.000000
9 182.551804000 po p 162
10 182.553166000 w5 WS "Fi"
6 B22_137 WS B22_137 "0.000000 0.600000 0.400000"
6 B22_137_1 Ctx1 B22_137 "1.0 0.39 1.0"
6 B22_137_2 Ctx2 B22_137 ".0 1.0 .0"
6 B22_137_3 Ctx3 B22_137 "0.87 0.87 .0"
6 B22_137_4 Ctx4 B22_137 ".0 0.95 1.0"
6 B22_137_5 Ctx5 B22_137 ".0 .0 .0"
6 B22_137_6 Ctx6 B22_137 ".0 .0 0.5"
6 B22_137_7 Ctx7 B22_137 "0.41 0.41 0.41"
6 B22_137_8 Ctx8 B22_137 "1.0 .0 1.0"
6 B22_137_9 Ctx9 B22_137 ".0 .0 1.0"
10 182.555475000 w5 WS "B22_137"
20 182.555475000 w5 WS B22_137 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 162
162 0.000000 0 0 -1 -1
10 182.556802000 t4917 S E
10 182.592033000 t4915 S B
10 182.594084000 w3 WS "I"
13 174.894690000 w3 gf 0.000000
13 174.894690000 sched gft 0.000000
13 182.599074000 sched nready 135.000000
13 182.599074000 sched nsubmitted 139.000000
9 182.599074000 po p 154
10 182.600305000 w3 WS "Fi"
6 B22_129 WS B22_129 "0.000000 0.600000 0.400000"
6 B22_129_1 Ctx1 B22_129 "1.0 0.39 1.0"
6 B22_129_2 Ctx2 B22_129 ".0 1.0 .0"
6 B22_129_3 Ctx3 B22_129 "0.87 0.87 .0"
6 B22_129_4 Ctx4 B22_129 ".0 0.95 1.0"
6 B22_129_5 Ctx5 B22_129 ".0 .0 .0"
6 B22_129_6 Ctx6 B22_129 ".0 .0 0.5"
6 B22_129_7 Ctx7 B22_129 "0.41 0.41 0.41"
6 B22_129_8 Ctx8 B22_129 "1.0 .0 1.0"
6 B22_129_9 Ctx9 B22_129 ".0 .0 1.0"
10 182.602175000 w3 WS "B22_129"
20 182.602175000 w3 WS B22_129 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 154
154 0.000000 0 0 -1 -1
10 182.603503000 t4915 S E
10 183.582577000 t4913 S B
10 183.584727000 w1 WS "I"
13 175.879052000 w1 gf 0.000000
13 175.879052000 sched gft 0.000000
13 183.589873000 sched nready 134.000000
13 183.589873000 sched nsubmitted 138.000000
9 183.589873000 po p 164
10 183.591157000 w1 WS "Fi"
6 B22_139 WS B22_139 "0.000000 0.600000 0.400000"
6 B22_139_1 Ctx1 B22_139 "1.0 0.39 1.0"
6 B22_139_2 Ctx2 B22_139 ".0 1.0 .0"
6 B22_139_3 Ctx3 B22_139 "0.87 0.87 .0"
6 B22_139_4 Ctx4 B22_139 ".0 0.95 1.0"
6 B22_139_5 Ctx5 B22_139 ".0 .0 .0"
6 B22_139_6 Ctx6 B22_139 ".0 .0 0.5"
6 B22_139_7 Ctx7 B22_139 "0.41 0.41 0.41"
6 B22_139_8 Ctx8 B22_139 "1.0 .0 1.0"
6 B22_139_9 Ctx9 B22_139 ".0 .0 1.0"
10 183.593135000 w1 WS "B22_139"
20 183.593135000 w1 WS B22_139 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 164
164 0.000000 0 0 -1 -1
10 183.594384000 t4913 S E
10 184.073993000 t4912 S B
10 184.076435000 w0 WS "I"
13 176.363863000 w0 gf 0.000000
13 176.363863000 sched gft 0.000000
13 184.081643000 sched nready 133.000000
13 184.081643000 sched nsubmitted 137.000000
9 184.081643000 po p 157
10 184.082949000 w0 WS "Fi"
6 B22_132 WS B22_132 "0.000000 0.600000 0.400000"
6 B22_132_1 Ctx1 B22_132 "1.0 0.39 1.0"
6 B22_132_2 Ctx2 B22_132 ".0 1.0 .0"
6 B22_132_3 Ctx3 B22_132 "0.87 0.87 .0"
6 B22_132_4 Ctx4 B22_132 ".0 0.95 1.0"
6 B22_132_5 Ctx5 B22_132 ".0 .0 .0"
6 B22_132_6 Ctx6 B22_132 ".0 .0 0.5"
6 B22_132_7 Ctx7 B22_132 "0.41 0.41 0.41"
6 B22_132_8 Ctx8 B22_132 "1.0 .0 1.0"
6 B22_132_9 Ctx9 B22_132 ".0 .0 1.0"
10 184.085134000 w0 WS "B22_132"
20 184.085134000 w0 WS B22_132 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 157
157 0.000000 0 0 -1 -1
10 184.086439000 t4912 S E
10 189.986840000 t4914 S B
10 189.989789000 w2 WS "I"
13 182.284774000 w2 gf 0.000000
13 182.284774000 sched gft 0.000000
13 189.995908000 sched nready 132.000000
13 189.995908000 sched nsubmitted 136.000000
9 189.995908000 po p 165
10 189.997281000 w2 WS "Fi"
6 B22_140 WS B22_140 "0.000000 0.600000 0.400000"
6 B22_140_1 Ctx1 B22_140 "1.0 0.39 1.0"
6 B22_140_2 Ctx2 B22_140 ".0 1.0 .0"
6 B22_140_3 Ctx3 B22_140 "0.87 0.87 .0"
6 B22_140_4 Ctx4 B22_140 ".0 0.95 1.0"
6 B22_140_5 Ctx5 B22_140 ".0 .0 .0"
6 B22_140_6 Ctx6 B22_140 ".0 .0 0.5"
6 B22_140_7 Ctx7 B22_140 "0.41 0.41 0.41"
6 B22_140_8 Ctx8 B22_140 "1.0 .0 1.0"
6 B22_140_9 Ctx9 B22_140 ".0 .0 1.0"
10 189.999557000 w2 WS "B22_140"
20 189.999557000 w2 WS B22_140 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 165
165 0.000000 0 0 -1 -1
10 190.001057000 t4914 S E
10 190.074986000 t4916 S B
10 190.076967000 w4 WS "I"
13 182.380370000 w4 gf 0.000000
13 182.380370000 sched gft 0.000000
13 190.082009000 sched nready 131.000000
13 190.082009000 sched nsubmitted 135.000000
9 190.082009000 po p 167
10 190.083325000 w4 WS "Fi"
6 B22_142 WS B22_142 "0.000000 0.600000 0.400000"
6 B22_142_1 Ctx1 B22_142 "1.0 0.39 1.0"
6 B22_142_2 Ctx2 B22_142 ".0 1.0 .0"
6 B22_142_3 Ctx3 B22_142 "0.87 0.87 .0"
6 B22_142_4 Ctx4 B22_142 ".0 0.95 1.0"
6 B22_142_5 Ctx5 B22_142 ".0 .0 .0"
6 B22_142_6 Ctx6 B22_142 ".0 .0 0.5"
6 B22_142_7 Ctx7 B22_142 "0.41 0.41 0.41"
6 B22_142_8 Ctx8 B22_142 "1.0 .0 1.0"
6 B22_142_9 Ctx9 B22_142 ".0 .0 1.0"
10 190.085753000 w4 WS "B22_142"
20 190.085753000 w4 WS B22_142 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 167
167 0.000000 0 0 -1 -1
10 190.087126000 t4916 S E
10 190.217722000 t4917 S B
10 190.220179000 w5 WS "I"
13 182.545694000 w5 gf 0.000000
13 182.545694000 sched gft 0.000000
13 190.225612000 sched nready 130.000000
13 190.225612000 sched nsubmitted 134.000000
9 190.225612000 po p 168
10 190.226967000 w5 WS "Fi"
6 B22_143 WS B22_143 "0.000000 0.600000 0.400000"
6 B22_143_1 Ctx1 B22_143 "1.0 0.39 1.0"
6 B22_143_2 Ctx2 B22_143 ".0 1.0 .0"
6 B22_143_3 Ctx3 B22_143 "0.87 0.87 .0"
6 B22_143_4 Ctx4 B22_143 ".0 0.95 1.0"
6 B22_143_5 Ctx5 B22_143 ".0 .0 .0"
6 B22_143_6 Ctx6 B22_143 ".0 .0 0.5"
6 B22_143_7 Ctx7 B22_143 "0.41 0.41 0.41"
6 B22_143_8 Ctx8 B22_143 "1.0 .0 1.0"
6 B22_143_9 Ctx9 B22_143 ".0 .0 1.0"
10 190.229330000 w5 WS "B22_143"
20 190.229330000 w5 WS B22_143 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 168
168 0.000000 0 0 -1 -1
10 190.230696000 t4917 S E
10 190.291411000 t4915 S B
10 190.293151000 w3 WS "I"
13 182.594084000 w3 gf 0.000000
13 182.594084000 sched gft 0.000000
13 190.297812000 sched nready 129.000000
13 190.297812000 sched nsubmitted 133.000000
9 190.297812000 po p 160
10 190.299278000 w3 WS "Fi"
6 B22_135 WS B22_135 "0.000000 0.600000 0.400000"
6 B22_135_1 Ctx1 B22_135 "1.0 0.39 1.0"
6 B22_135_2 Ctx2 B22_135 ".0 1.0 .0"
6 B22_135_3 Ctx3 B22_135 "0.87 0.87 .0"
6 B22_135_4 Ctx4 B22_135 ".0 0.95 1.0"
6 B22_135_5 Ctx5 B22_135 ".0 .0 .0"
6 B22_135_6 Ctx6 B22_135 ".0 .0 0.5"
6 B22_135_7 Ctx7 B22_135 "0.41 0.41 0.41"
6 B22_135_8 Ctx8 B22_135 "1.0 .0 1.0"
6 B22_135_9 Ctx9 B22_135 ".0 .0 1.0"
10 190.301198000 w3 WS "B22_135"
20 190.301198000 w3 WS B22_135 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 160
160 0.000000 0 0 -1 -1
10 190.302472000 t4915 S E
10 191.278450000 t4913 S B
10 191.280344000 w1 WS "I"
13 183.584727000 w1 gf 0.000000
13 183.584727000 sched gft 0.000000
13 191.285754000 sched nready 128.000000
13 191.285754000 sched nsubmitted 132.000000
9 191.285754000 po p 170
10 191.287048000 w1 WS "Fi"
6 B22_145 WS B22_145 "0.000000 0.600000 0.400000"
6 B22_145_1 Ctx1 B22_145 "1.0 0.39 1.0"
6 B22_145_2 Ctx2 B22_145 ".0 1.0 .0"
6 B22_145_3 Ctx3 B22_145 "0.87 0.87 .0"
6 B22_145_4 Ctx4 B22_145 ".0 0.95 1.0"
6 B22_145_5 Ctx5 B22_145 ".0 .0 .0"
6 B22_145_6 Ctx6 B22_145 ".0 .0 0.5"
6 B22_145_7 Ctx7 B22_145 "0.41 0.41 0.41"
6 B22_145_8 Ctx8 B22_145 "1.0 .0 1.0"
6 B22_145_9 Ctx9 B22_145 ".0 .0 1.0"
10 191.289293000 w1 WS "B22_145"
20 191.289293000 w1 WS B22_145 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 170
170 0.000000 0 0 -1 -1
10 191.290676000 t4913 S E
10 191.948230000 t4912 S B
10 191.950607000 w0 WS "I"
13 184.076435000 w0 gf 0.000000
13 184.076435000 sched gft 0.000000
13 191.955742000 sched nready 127.000000
13 191.955742000 sched nsubmitted 131.000000
9 191.955742000 po p 163
10 191.957049000 w0 WS "Fi"
6 B22_138 WS B22_138 "0.000000 0.600000 0.400000"
6 B22_138_1 Ctx1 B22_138 "1.0 0.39 1.0"
6 B22_138_2 Ctx2 B22_138 ".0 1.0 .0"
6 B22_138_3 Ctx3 B22_138 "0.87 0.87 .0"
6 B22_138_4 Ctx4 B22_138 ".0 0.95 1.0"
6 B22_138_5 Ctx5 B22_138 ".0 .0 .0"
6 B22_138_6 Ctx6 B22_138 ".0 .0 0.5"
6 B22_138_7 Ctx7 B22_138 "0.41 0.41 0.41"
6 B22_138_8 Ctx8 B22_138 "1.0 .0 1.0"
6 B22_138_9 Ctx9 B22_138 ".0 .0 1.0"
10 191.959128000 w0 WS "B22_138"
20 191.959128000 w0 WS B22_138 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 163
163 0.000000 0 0 -1 -1
10 191.960401000 t4912 S E
10 197.673153000 t4914 S B
10 197.675350000 w2 WS "I"
13 189.989789000 w2 gf 0.000000
13 189.989789000 sched gft 0.000000
13 197.681077000 sched nready 126.000000
13 197.681077000 sched nsubmitted 130.000000
9 197.681077000 po p 171
10 197.682356000 w2 WS "Fi"
6 B22_146 WS B22_146 "0.000000 0.600000 0.400000"
6 B22_146_1 Ctx1 B22_146 "1.0 0.39 1.0"
6 B22_146_2 Ctx2 B22_146 ".0 1.0 .0"
6 B22_146_3 Ctx3 B22_146 "0.87 0.87 .0"
6 B22_146_4 Ctx4 B22_146 ".0 0.95 1.0"
6 B22_146_5 Ctx5 B22_146 ".0 .0 .0"
6 B22_146_6 Ctx6 B22_146 ".0 .0 0.5"
6 B22_146_7 Ctx7 B22_146 "0.41 0.41 0.41"
6 B22_146_8 Ctx8 B22_146 "1.0 .0 1.0"
6 B22_146_9 Ctx9 B22_146 ".0 .0 1.0"
10 197.684575000 w2 WS "B22_146"
20 197.684575000 w2 WS B22_146 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 171
171 0.000000 0 0 -1 -1
10 197.685930000 t4914 S E
10 197.892584000 t4917 S B
10 197.895124000 w5 WS "I"
13 190.220179000 w5 gf 0.000000
10 197.895829000 t4916 S B
10 197.897961000 w4 WS "I"
13 190.076967000 w4 gf 0.000000
13 190.076967000 sched gft 0.000000
13 190.220179000 sched gft 0.000000
13 197.901025000 sched nready 125.000000
13 197.901025000 sched nsubmitted 129.000000
9 197.901025000 po p 174
10 197.902424000 w5 WS "Fi"
13 197.903237000 sched nready 124.000000
13 197.903237000 sched nsubmitted 128.000000
9 197.903237000 po p 173
10 197.904622000 w4 WS "Fi"
6 B22_149 WS B22_149 "0.000000 0.600000 0.400000"
6 B22_149_1 Ctx1 B22_149 "1.0 0.39 1.0"
6 B22_149_2 Ctx2 B22_149 ".0 1.0 .0"
6 B22_149_3 Ctx3 B22_149 "0.87 0.87 .0"
6 B22_149_4 Ctx4 B22_149 ".0 0.95 1.0"
6 B22_149_5 Ctx5 B22_149 ".0 .0 .0"
6 B22_149_6 Ctx6 B22_149 ".0 .0 0.5"
6 B22_149_7 Ctx7 B22_149 "0.41 0.41 0.41"
6 B22_149_8 Ctx8 B22_149 "1.0 .0 1.0"
6 B22_149_9 Ctx9 B22_149 ".0 .0 1.0"
10 197.905354000 w5 WS "B22_149"
20 197.905354000 w5 WS B22_149 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 174
174 0.000000 0 0 -1 -1
6 B22_148 WS B22_148 "0.000000 0.600000 0.400000"
6 B22_148_1 Ctx1 B22_148 "1.0 0.39 1.0"
6 B22_148_2 Ctx2 B22_148 ".0 1.0 .0"
6 B22_148_3 Ctx3 B22_148 "0.87 0.87 .0"
6 B22_148_4 Ctx4 B22_148 ".0 0.95 1.0"
6 B22_148_5 Ctx5 B22_148 ".0 .0 .0"
6 B22_148_6 Ctx6 B22_148 ".0 .0 0.5"
6 B22_148_7 Ctx7 B22_148 "0.41 0.41 0.41"
6 B22_148_8 Ctx8 B22_148 "1.0 .0 1.0"
6 B22_148_9 Ctx9 B22_148 ".0 .0 1.0"
10 197.907015000 w4 WS "B22_148"
10 197.907081000 t4917 S E
20 197.907015000 w4 WS B22_148 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 173
173 0.000000 0 0 -1 -1
10 197.908461000 t4916 S E
10 197.976941000 t4915 S B
10 197.978631000 w3 WS "I"
13 190.293151000 w3 gf 0.000000
13 190.293151000 sched gft 0.000000
13 197.983595000 sched nready 123.000000
13 197.983595000 sched nsubmitted 127.000000
9 197.983595000 po p 166
10 197.984897000 w3 WS "Fi"
6 B22_141 WS B22_141 "0.000000 0.600000 0.400000"
6 B22_141_1 Ctx1 B22_141 "1.0 0.39 1.0"
6 B22_141_2 Ctx2 B22_141 ".0 1.0 .0"
6 B22_141_3 Ctx3 B22_141 "0.87 0.87 .0"
6 B22_141_4 Ctx4 B22_141 ".0 0.95 1.0"
6 B22_141_5 Ctx5 B22_141 ".0 .0 .0"
6 B22_141_6 Ctx6 B22_141 ".0 .0 0.5"
6 B22_141_7 Ctx7 B22_141 "0.41 0.41 0.41"
6 B22_141_8 Ctx8 B22_141 "1.0 .0 1.0"
6 B22_141_9 Ctx9 B22_141 ".0 .0 1.0"
10 197.987030000 w3 WS "B22_141"
20 197.987030000 w3 WS B22_141 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 166
166 0.000000 0 0 -1 -1
10 197.988297000 t4915 S E
10 199.101265000 t4913 S B
10 199.103057000 w1 WS "I"
13 191.280344000 w1 gf 0.000000
13 191.280344000 sched gft 0.000000
13 199.107854000 sched nready 122.000000
13 199.107854000 sched nsubmitted 126.000000
9 199.107854000 po p 176
10 199.109402000 w1 WS "Fi"
6 B22_151 WS B22_151 "0.000000 0.600000 0.400000"
6 B22_151_1 Ctx1 B22_151 "1.0 0.39 1.0"
6 B22_151_2 Ctx2 B22_151 ".0 1.0 .0"
6 B22_151_3 Ctx3 B22_151 "0.87 0.87 .0"
6 B22_151_4 Ctx4 B22_151 ".0 0.95 1.0"
6 B22_151_5 Ctx5 B22_151 ".0 .0 .0"
6 B22_151_6 Ctx6 B22_151 ".0 .0 0.5"
6 B22_151_7 Ctx7 B22_151 "0.41 0.41 0.41"
6 B22_151_8 Ctx8 B22_151 "1.0 .0 1.0"
6 B22_151_9 Ctx9 B22_151 ".0 .0 1.0"
10 199.111511000 w1 WS "B22_151"
20 199.111511000 w1 WS B22_151 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 176
176 0.000000 0 0 -1 -1
10 199.112752000 t4913 S E
10 199.661284000 t4912 S B
10 199.663767000 w0 WS "I"
13 191.950607000 w0 gf 0.000000
13 191.950607000 sched gft 0.000000
13 199.669033000 sched nready 121.000000
13 199.669033000 sched nsubmitted 125.000000
9 199.669033000 po p 169
10 199.670557000 w0 WS "Fi"
6 B22_144 WS B22_144 "0.000000 0.600000 0.400000"
6 B22_144_1 Ctx1 B22_144 "1.0 0.39 1.0"
6 B22_144_2 Ctx2 B22_144 ".0 1.0 .0"
6 B22_144_3 Ctx3 B22_144 "0.87 0.87 .0"
6 B22_144_4 Ctx4 B22_144 ".0 0.95 1.0"
6 B22_144_5 Ctx5 B22_144 ".0 .0 .0"
6 B22_144_6 Ctx6 B22_144 ".0 .0 0.5"
6 B22_144_7 Ctx7 B22_144 "0.41 0.41 0.41"
6 B22_144_8 Ctx8 B22_144 "1.0 .0 1.0"
6 B22_144_9 Ctx9 B22_144 ".0 .0 1.0"
10 199.672840000 w0 WS "B22_144"
20 199.672840000 w0 WS B22_144 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 169
169 0.000000 0 0 -1 -1
10 199.674196000 t4912 S E
10 205.374047000 t4914 S B
10 205.376571000 w2 WS "I"
13 197.675350000 w2 gf 0.000000
13 197.675350000 sched gft 0.000000
13 205.382219000 sched nready 120.000000
13 205.382219000 sched nsubmitted 124.000000
9 205.382219000 po p 177
10 205.383549000 w2 WS "Fi"
6 B22_152 WS B22_152 "0.000000 0.600000 0.400000"
6 B22_152_1 Ctx1 B22_152 "1.0 0.39 1.0"
6 B22_152_2 Ctx2 B22_152 ".0 1.0 .0"
6 B22_152_3 Ctx3 B22_152 "0.87 0.87 .0"
6 B22_152_4 Ctx4 B22_152 ".0 0.95 1.0"
6 B22_152_5 Ctx5 B22_152 ".0 .0 .0"
6 B22_152_6 Ctx6 B22_152 ".0 .0 0.5"
6 B22_152_7 Ctx7 B22_152 "0.41 0.41 0.41"
6 B22_152_8 Ctx8 B22_152 "1.0 .0 1.0"
6 B22_152_9 Ctx9 B22_152 ".0 .0 1.0"
10 205.385669000 w2 WS "B22_152"
20 205.385669000 w2 WS B22_152 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 177
177 0.000000 0 0 -1 -1
10 205.387018000 t4914 S E
10 205.583874000 t4916 S B
10 205.585473000 w4 WS "I"
13 197.897961000 w4 gf 0.000000
13 205.590510000 sched nready 119.000000
13 205.590510000 sched nsubmitted 123.000000
9 205.590510000 po p 179
10 205.591867000 t4917 S B
10 205.591799000 w4 WS "Fi"
6 B22_154 WS B22_154 "0.000000 0.600000 0.400000"
6 B22_154_1 Ctx1 B22_154 "1.0 0.39 1.0"
6 B22_154_2 Ctx2 B22_154 ".0 1.0 .0"
6 B22_154_3 Ctx3 B22_154 "0.87 0.87 .0"
6 B22_154_4 Ctx4 B22_154 ".0 0.95 1.0"
6 B22_154_5 Ctx5 B22_154 ".0 .0 .0"
6 B22_154_6 Ctx6 B22_154 ".0 .0 0.5"
6 B22_154_7 Ctx7 B22_154 "0.41 0.41 0.41"
6 B22_154_8 Ctx8 B22_154 "1.0 .0 1.0"
6 B22_154_9 Ctx9 B22_154 ".0 .0 1.0"
10 205.594189000 w4 WS "B22_154"
10 205.594340000 w5 WS "I"
13 197.895124000 w5 gf 0.000000
13 197.895124000 sched gft 0.000000
13 197.897961000 sched gft 0.000000
20 205.594189000 w4 WS B22_154 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 179
179 0.000000 0 0 -1 -1
10 205.595663000 t4916 S E
13 205.599850000 sched nready 118.000000
13 205.599850000 sched nsubmitted 122.000000
9 205.599850000 po p 180
10 205.601164000 w5 WS "Fi"
6 B22_155 WS B22_155 "0.000000 0.600000 0.400000"
6 B22_155_1 Ctx1 B22_155 "1.0 0.39 1.0"
6 B22_155_2 Ctx2 B22_155 ".0 1.0 .0"
6 B22_155_3 Ctx3 B22_155 "0.87 0.87 .0"
6 B22_155_4 Ctx4 B22_155 ".0 0.95 1.0"
6 B22_155_5 Ctx5 B22_155 ".0 .0 .0"
6 B22_155_6 Ctx6 B22_155 ".0 .0 0.5"
6 B22_155_7 Ctx7 B22_155 "0.41 0.41 0.41"
6 B22_155_8 Ctx8 B22_155 "1.0 .0 1.0"
6 B22_155_9 Ctx9 B22_155 ".0 .0 1.0"
10 205.603401000 w5 WS "B22_155"
20 205.603401000 w5 WS B22_155 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 180
180 0.000000 0 0 -1 -1
10 205.604725000 t4917 S E
10 205.674973000 t4915 S B
10 205.676770000 w3 WS "I"
13 197.978631000 w3 gf 0.000000
13 197.978631000 sched gft 0.000000
13 205.681964000 sched nready 117.000000
13 205.681964000 sched nsubmitted 121.000000
9 205.681964000 po p 172
10 205.683319000 w3 WS "Fi"
6 B22_147 WS B22_147 "0.000000 0.600000 0.400000"
6 B22_147_1 Ctx1 B22_147 "1.0 0.39 1.0"
6 B22_147_2 Ctx2 B22_147 ".0 1.0 .0"
6 B22_147_3 Ctx3 B22_147 "0.87 0.87 .0"
6 B22_147_4 Ctx4 B22_147 ".0 0.95 1.0"
6 B22_147_5 Ctx5 B22_147 ".0 .0 .0"
6 B22_147_6 Ctx6 B22_147 ".0 .0 0.5"
6 B22_147_7 Ctx7 B22_147 "0.41 0.41 0.41"
6 B22_147_8 Ctx8 B22_147 "1.0 .0 1.0"
6 B22_147_9 Ctx9 B22_147 ".0 .0 1.0"
10 205.685431000 w3 WS "B22_147"
20 205.685431000 w3 WS B22_147 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 172
172 0.000000 0 0 -1 -1
10 205.686683000 t4915 S E
10 206.799962000 t4913 S B
10 206.801780000 w1 WS "I"
13 199.103057000 w1 gf 0.000000
13 199.103057000 sched gft 0.000000
13 206.806723000 sched nready 116.000000
13 206.806723000 sched nsubmitted 120.000000
9 206.806723000 po p 182
10 206.808007000 w1 WS "Fi"
6 B22_157 WS B22_157 "0.000000 0.600000 0.400000"
6 B22_157_1 Ctx1 B22_157 "1.0 0.39 1.0"
6 B22_157_2 Ctx2 B22_157 ".0 1.0 .0"
6 B22_157_3 Ctx3 B22_157 "0.87 0.87 .0"
6 B22_157_4 Ctx4 B22_157 ".0 0.95 1.0"
6 B22_157_5 Ctx5 B22_157 ".0 .0 .0"
6 B22_157_6 Ctx6 B22_157 ".0 .0 0.5"
6 B22_157_7 Ctx7 B22_157 "0.41 0.41 0.41"
6 B22_157_8 Ctx8 B22_157 "1.0 .0 1.0"
6 B22_157_9 Ctx9 B22_157 ".0 .0 1.0"
10 206.810096000 w1 WS "B22_157"
20 206.810096000 w1 WS B22_157 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 182
182 0.000000 0 0 -1 -1
10 206.811376000 t4913 S E
10 207.393959000 t4912 S B
10 207.396413000 w0 WS "I"
13 199.663767000 w0 gf 0.000000
13 199.663767000 sched gft 0.000000
13 207.401806000 sched nready 115.000000
13 207.401806000 sched nsubmitted 119.000000
9 207.401806000 po p 175
10 207.403108000 w0 WS "Fi"
6 B22_150 WS B22_150 "0.000000 0.600000 0.400000"
6 B22_150_1 Ctx1 B22_150 "1.0 0.39 1.0"
6 B22_150_2 Ctx2 B22_150 ".0 1.0 .0"
6 B22_150_3 Ctx3 B22_150 "0.87 0.87 .0"
6 B22_150_4 Ctx4 B22_150 ".0 0.95 1.0"
6 B22_150_5 Ctx5 B22_150 ".0 .0 .0"
6 B22_150_6 Ctx6 B22_150 ".0 .0 0.5"
6 B22_150_7 Ctx7 B22_150 "0.41 0.41 0.41"
6 B22_150_8 Ctx8 B22_150 "1.0 .0 1.0"
6 B22_150_9 Ctx9 B22_150 ".0 .0 1.0"
10 207.405449000 w0 WS "B22_150"
20 207.405449000 w0 WS B22_150 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 175
175 0.000000 0 0 -1 -1
10 207.406793000 t4912 S E
10 213.057148000 t4914 S B
10 213.059764000 w2 WS "I"
13 205.376571000 w2 gf 0.000000
13 205.376571000 sched gft 0.000000
13 213.065736000 sched nready 114.000000
13 213.065736000 sched nsubmitted 118.000000
9 213.065736000 po p 183
10 213.067039000 w2 WS "Fi"
6 B22_158 WS B22_158 "0.000000 0.600000 0.400000"
6 B22_158_1 Ctx1 B22_158 "1.0 0.39 1.0"
6 B22_158_2 Ctx2 B22_158 ".0 1.0 .0"
6 B22_158_3 Ctx3 B22_158 "0.87 0.87 .0"
6 B22_158_4 Ctx4 B22_158 ".0 0.95 1.0"
6 B22_158_5 Ctx5 B22_158 ".0 .0 .0"
6 B22_158_6 Ctx6 B22_158 ".0 .0 0.5"
6 B22_158_7 Ctx7 B22_158 "0.41 0.41 0.41"
6 B22_158_8 Ctx8 B22_158 "1.0 .0 1.0"
6 B22_158_9 Ctx9 B22_158 ".0 .0 1.0"
10 213.069290000 w2 WS "B22_158"
20 213.069290000 w2 WS B22_158 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 183
183 0.000000 0 0 -1 -1
10 213.071000000 t4914 S E
10 213.287545000 t4916 S B
10 213.289504000 w4 WS "I"
13 205.585473000 w4 gf 0.000000
13 205.585473000 sched gft 0.000000
13 213.294865000 sched nready 113.000000
13 213.294865000 sched nsubmitted 117.000000
9 213.294865000 po p 185
10 213.296207000 w4 WS "Fi"
6 B22_160 WS B22_160 "0.000000 0.600000 0.400000"
6 B22_160_1 Ctx1 B22_160 "1.0 0.39 1.0"
6 B22_160_2 Ctx2 B22_160 ".0 1.0 .0"
6 B22_160_3 Ctx3 B22_160 "0.87 0.87 .0"
6 B22_160_4 Ctx4 B22_160 ".0 0.95 1.0"
6 B22_160_5 Ctx5 B22_160 ".0 .0 .0"
6 B22_160_6 Ctx6 B22_160 ".0 .0 0.5"
6 B22_160_7 Ctx7 B22_160 "0.41 0.41 0.41"
6 B22_160_8 Ctx8 B22_160 "1.0 .0 1.0"
6 B22_160_9 Ctx9 B22_160 ".0 .0 1.0"
10 213.298616000 w4 WS "B22_160"
20 213.298616000 w4 WS B22_160 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 185
185 0.000000 0 0 -1 -1
10 213.299833000 t4916 S E
10 213.366741000 t4915 S B
10 213.368703000 w3 WS "I"
13 205.676770000 w3 gf 0.000000
13 213.373802000 sched nready 112.000000
13 213.373802000 sched nsubmitted 116.000000
9 213.373802000 po p 178
10 213.375111000 w3 WS "Fi"
6 B22_153 WS B22_153 "0.000000 0.600000 0.400000"
6 B22_153_1 Ctx1 B22_153 "1.0 0.39 1.0"
6 B22_153_2 Ctx2 B22_153 ".0 1.0 .0"
6 B22_153_3 Ctx3 B22_153 "0.87 0.87 .0"
6 B22_153_4 Ctx4 B22_153 ".0 0.95 1.0"
6 B22_153_5 Ctx5 B22_153 ".0 .0 .0"
6 B22_153_6 Ctx6 B22_153 ".0 .0 0.5"
6 B22_153_7 Ctx7 B22_153 "0.41 0.41 0.41"
6 B22_153_8 Ctx8 B22_153 "1.0 .0 1.0"
6 B22_153_9 Ctx9 B22_153 ".0 .0 1.0"
10 213.377029000 w3 WS "B22_153"
20 213.377029000 w3 WS B22_153 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 178
178 0.000000 0 0 -1 -1
10 213.378493000 t4915 S E
10 213.389550000 t4917 S B
10 213.391793000 w5 WS "I"
13 205.594340000 w5 gf 0.000000
13 205.594340000 sched gft 0.000000
13 205.676770000 sched gft 0.000000
13 213.397470000 sched nready 111.000000
13 213.397470000 sched nsubmitted 115.000000
9 213.397470000 po p 186
10 213.398801000 w5 WS "Fi"
6 B22_161 WS B22_161 "0.000000 0.600000 0.400000"
6 B22_161_1 Ctx1 B22_161 "1.0 0.39 1.0"
6 B22_161_2 Ctx2 B22_161 ".0 1.0 .0"
6 B22_161_3 Ctx3 B22_161 "0.87 0.87 .0"
6 B22_161_4 Ctx4 B22_161 ".0 0.95 1.0"
6 B22_161_5 Ctx5 B22_161 ".0 .0 .0"
6 B22_161_6 Ctx6 B22_161 ".0 .0 0.5"
6 B22_161_7 Ctx7 B22_161 "0.41 0.41 0.41"
6 B22_161_8 Ctx8 B22_161 "1.0 .0 1.0"
6 B22_161_9 Ctx9 B22_161 ".0 .0 1.0"
10 213.400997000 w5 WS "B22_161"
20 213.400997000 w5 WS B22_161 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 186
186 0.000000 0 0 -1 -1
10 213.402441000 t4917 S E
10 214.485322000 t4913 S B
10 214.487133000 w1 WS "I"
13 206.801780000 w1 gf 0.000000
13 206.801780000 sched gft 0.000000
13 214.491772000 sched nready 110.000000
13 214.491772000 sched nsubmitted 114.000000
9 214.491772000 po p 188
10 214.493068000 w1 WS "Fi"
6 B22_163 WS B22_163 "0.000000 0.600000 0.400000"
6 B22_163_1 Ctx1 B22_163 "1.0 0.39 1.0"
6 B22_163_2 Ctx2 B22_163 ".0 1.0 .0"
6 B22_163_3 Ctx3 B22_163 "0.87 0.87 .0"
6 B22_163_4 Ctx4 B22_163 ".0 0.95 1.0"
6 B22_163_5 Ctx5 B22_163 ".0 .0 .0"
6 B22_163_6 Ctx6 B22_163 ".0 .0 0.5"
6 B22_163_7 Ctx7 B22_163 "0.41 0.41 0.41"
6 B22_163_8 Ctx8 B22_163 "1.0 .0 1.0"
6 B22_163_9 Ctx9 B22_163 ".0 .0 1.0"
10 214.495462000 w1 WS "B22_163"
20 214.495462000 w1 WS B22_163 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 188
188 0.000000 0 0 -1 -1
10 214.496793000 t4913 S E
10 215.112558000 t4912 S B
10 215.114690000 w0 WS "I"
13 207.396413000 w0 gf 0.000000
13 207.396413000 sched gft 0.000000
13 215.119732000 sched nready 109.000000
13 215.119732000 sched nsubmitted 113.000000
9 215.119732000 po p 181
10 215.121066000 w0 WS "Fi"
6 B22_156 WS B22_156 "0.000000 0.600000 0.400000"
6 B22_156_1 Ctx1 B22_156 "1.0 0.39 1.0"
6 B22_156_2 Ctx2 B22_156 ".0 1.0 .0"
6 B22_156_3 Ctx3 B22_156 "0.87 0.87 .0"
6 B22_156_4 Ctx4 B22_156 ".0 0.95 1.0"
6 B22_156_5 Ctx5 B22_156 ".0 .0 .0"
6 B22_156_6 Ctx6 B22_156 ".0 .0 0.5"
6 B22_156_7 Ctx7 B22_156 "0.41 0.41 0.41"
6 B22_156_8 Ctx8 B22_156 "1.0 .0 1.0"
6 B22_156_9 Ctx9 B22_156 ".0 .0 1.0"
10 215.123145000 w0 WS "B22_156"
20 215.123145000 w0 WS B22_156 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 181
181 0.000000 0 0 -1 -1
10 215.124490000 t4912 S E
10 220.754726000 t4914 S B
10 220.757767000 w2 WS "I"
13 213.059764000 w2 gf 0.000000
13 213.059764000 sched gft 0.000000
13 220.763582000 sched nready 108.000000
13 220.763582000 sched nsubmitted 112.000000
9 220.763582000 po p 189
10 220.764943000 w2 WS "Fi"
6 B22_164 WS B22_164 "0.000000 0.600000 0.400000"
6 B22_164_1 Ctx1 B22_164 "1.0 0.39 1.0"
6 B22_164_2 Ctx2 B22_164 ".0 1.0 .0"
6 B22_164_3 Ctx3 B22_164 "0.87 0.87 .0"
6 B22_164_4 Ctx4 B22_164 ".0 0.95 1.0"
6 B22_164_5 Ctx5 B22_164 ".0 .0 .0"
6 B22_164_6 Ctx6 B22_164 ".0 .0 0.5"
6 B22_164_7 Ctx7 B22_164 "0.41 0.41 0.41"
6 B22_164_8 Ctx8 B22_164 "1.0 .0 1.0"
6 B22_164_9 Ctx9 B22_164 ".0 .0 1.0"
10 220.767024000 w2 WS "B22_164"
20 220.767024000 w2 WS B22_164 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 189
189 0.000000 0 0 -1 -1
10 220.768344000 t4914 S E
10 220.988767000 t4916 S B
10 220.990760000 w4 WS "I"
13 213.289504000 w4 gf 0.000000
13 213.289504000 sched gft 0.000000
13 220.996188000 sched nready 107.000000
13 220.996188000 sched nsubmitted 111.000000
9 220.996188000 po p 191
10 220.997463000 w4 WS "Fi"
6 B22_166 WS B22_166 "0.000000 0.600000 0.400000"
6 B22_166_1 Ctx1 B22_166 "1.0 0.39 1.0"
6 B22_166_2 Ctx2 B22_166 ".0 1.0 .0"
6 B22_166_3 Ctx3 B22_166 "0.87 0.87 .0"
6 B22_166_4 Ctx4 B22_166 ".0 0.95 1.0"
6 B22_166_5 Ctx5 B22_166 ".0 .0 .0"
6 B22_166_6 Ctx6 B22_166 ".0 .0 0.5"
6 B22_166_7 Ctx7 B22_166 "0.41 0.41 0.41"
6 B22_166_8 Ctx8 B22_166 "1.0 .0 1.0"
6 B22_166_9 Ctx9 B22_166 ".0 .0 1.0"
10 220.999927000 w4 WS "B22_166"
20 220.999927000 w4 WS B22_166 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 191
191 0.000000 0 0 -1 -1
10 221.001224000 t4916 S E
10 221.052554000 t4917 S B
10 221.054876000 w5 WS "I"
13 213.391793000 w5 gf 0.000000
10 221.057890000 t4915 S B
10 221.059877000 w3 WS "I"
13 213.368703000 w3 gf 0.000000
13 213.368703000 sched gft 0.000000
13 213.391793000 sched gft 0.000000
13 221.060632000 sched nready 106.000000
13 221.060632000 sched nsubmitted 110.000000
9 221.060632000 po p 192
10 221.062020000 w5 WS "Fi"
6 B22_167 WS B22_167 "0.000000 0.600000 0.400000"
6 B22_167_1 Ctx1 B22_167 "1.0 0.39 1.0"
6 B22_167_2 Ctx2 B22_167 ".0 1.0 .0"
6 B22_167_3 Ctx3 B22_167 "0.87 0.87 .0"
6 B22_167_4 Ctx4 B22_167 ".0 0.95 1.0"
6 B22_167_5 Ctx5 B22_167 ".0 .0 .0"
6 B22_167_6 Ctx6 B22_167 ".0 .0 0.5"
6 B22_167_7 Ctx7 B22_167 "0.41 0.41 0.41"
6 B22_167_8 Ctx8 B22_167 "1.0 .0 1.0"
6 B22_167_9 Ctx9 B22_167 ".0 .0 1.0"
10 221.064341000 w5 WS "B22_167"
13 221.065254000 sched nready 105.000000
13 221.065254000 sched nsubmitted 109.000000
9 221.065254000 po p 184
20 221.064341000 w5 WS B22_167 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 192
192 0.000000 0 0 -1 -1
10 221.065869000 t4917 S E
10 221.066593000 w3 WS "Fi"
6 B22_159 WS B22_159 "0.000000 0.600000 0.400000"
6 B22_159_1 Ctx1 B22_159 "1.0 0.39 1.0"
6 B22_159_2 Ctx2 B22_159 ".0 1.0 .0"
6 B22_159_3 Ctx3 B22_159 "0.87 0.87 .0"
6 B22_159_4 Ctx4 B22_159 ".0 0.95 1.0"
6 B22_159_5 Ctx5 B22_159 ".0 .0 .0"
6 B22_159_6 Ctx6 B22_159 ".0 .0 0.5"
6 B22_159_7 Ctx7 B22_159 "0.41 0.41 0.41"
6 B22_159_8 Ctx8 B22_159 "1.0 .0 1.0"
6 B22_159_9 Ctx9 B22_159 ".0 .0 1.0"
10 221.068648000 w3 WS "B22_159"
20 221.068648000 w3 WS B22_159 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 184
184 0.000000 0 0 -1 -1
10 221.069950000 t4915 S E
10 222.189247000 t4913 S B
10 222.190892000 w1 WS "I"
13 214.487133000 w1 gf 0.000000
13 214.487133000 sched gft 0.000000
13 222.195676000 sched nready 104.000000
13 222.195676000 sched nsubmitted 108.000000
9 222.195676000 po p 194
10 222.196956000 w1 WS "Fi"
6 B22_169 WS B22_169 "0.000000 0.600000 0.400000"
6 B22_169_1 Ctx1 B22_169 "1.0 0.39 1.0"
6 B22_169_2 Ctx2 B22_169 ".0 1.0 .0"
6 B22_169_3 Ctx3 B22_169 "0.87 0.87 .0"
6 B22_169_4 Ctx4 B22_169 ".0 0.95 1.0"
6 B22_169_5 Ctx5 B22_169 ".0 .0 .0"
6 B22_169_6 Ctx6 B22_169 ".0 .0 0.5"
6 B22_169_7 Ctx7 B22_169 "0.41 0.41 0.41"
6 B22_169_8 Ctx8 B22_169 "1.0 .0 1.0"
6 B22_169_9 Ctx9 B22_169 ".0 .0 1.0"
10 222.198973000 w1 WS "B22_169"
20 222.198973000 w1 WS B22_169 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 194
194 0.000000 0 0 -1 -1
10 222.200313000 t4913 S E
10 222.843646000 t4912 S B
10 222.846044000 w0 WS "I"
13 215.114690000 w0 gf 0.000000
13 215.114690000 sched gft 0.000000
13 222.851048000 sched nready 103.000000
13 222.851048000 sched nsubmitted 107.000000
9 222.851048000 po p 187
10 222.852353000 w0 WS "Fi"
6 B22_162 WS B22_162 "0.000000 0.600000 0.400000"
6 B22_162_1 Ctx1 B22_162 "1.0 0.39 1.0"
6 B22_162_2 Ctx2 B22_162 ".0 1.0 .0"
6 B22_162_3 Ctx3 B22_162 "0.87 0.87 .0"
6 B22_162_4 Ctx4 B22_162 ".0 0.95 1.0"
6 B22_162_5 Ctx5 B22_162 ".0 .0 .0"
6 B22_162_6 Ctx6 B22_162 ".0 .0 0.5"
6 B22_162_7 Ctx7 B22_162 "0.41 0.41 0.41"
6 B22_162_8 Ctx8 B22_162 "1.0 .0 1.0"
6 B22_162_9 Ctx9 B22_162 ".0 .0 1.0"
10 222.854365000 w0 WS "B22_162"
20 222.854365000 w0 WS B22_162 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 187
187 0.000000 0 0 -1 -1
10 222.855820000 t4912 S E
10 228.454693000 t4914 S B
10 228.456926000 w2 WS "I"
13 220.757767000 w2 gf 0.000000
13 220.757767000 sched gft 0.000000
13 228.462787000 sched nready 102.000000
13 228.462787000 sched nsubmitted 106.000000
9 228.462787000 po p 195
10 228.464062000 w2 WS "Fi"
6 B22_170 WS B22_170 "0.000000 0.600000 0.400000"
6 B22_170_1 Ctx1 B22_170 "1.0 0.39 1.0"
6 B22_170_2 Ctx2 B22_170 ".0 1.0 .0"
6 B22_170_3 Ctx3 B22_170 "0.87 0.87 .0"
6 B22_170_4 Ctx4 B22_170 ".0 0.95 1.0"
6 B22_170_5 Ctx5 B22_170 ".0 .0 .0"
6 B22_170_6 Ctx6 B22_170 ".0 .0 0.5"
6 B22_170_7 Ctx7 B22_170 "0.41 0.41 0.41"
6 B22_170_8 Ctx8 B22_170 "1.0 .0 1.0"
6 B22_170_9 Ctx9 B22_170 ".0 .0 1.0"
10 228.466655000 w2 WS "B22_170"
20 228.466655000 w2 WS B22_170 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 195
195 0.000000 0 0 -1 -1
10 228.468210000 t4914 S E
10 228.681363000 t4916 S B
10 228.683335000 w4 WS "I"
13 220.990760000 w4 gf 0.000000
13 220.990760000 sched gft 0.000000
13 228.688534000 sched nready 101.000000
13 228.688534000 sched nsubmitted 105.000000
9 228.688534000 po p 197
10 228.689839000 w4 WS "Fi"
6 B22_172 WS B22_172 "0.000000 0.600000 0.400000"
6 B22_172_1 Ctx1 B22_172 "1.0 0.39 1.0"
6 B22_172_2 Ctx2 B22_172 ".0 1.0 .0"
6 B22_172_3 Ctx3 B22_172 "0.87 0.87 .0"
6 B22_172_4 Ctx4 B22_172 ".0 0.95 1.0"
6 B22_172_5 Ctx5 B22_172 ".0 .0 .0"
6 B22_172_6 Ctx6 B22_172 ".0 .0 0.5"
6 B22_172_7 Ctx7 B22_172 "0.41 0.41 0.41"
6 B22_172_8 Ctx8 B22_172 "1.0 .0 1.0"
6 B22_172_9 Ctx9 B22_172 ".0 .0 1.0"
10 228.692135000 w4 WS "B22_172"
20 228.692135000 w4 WS B22_172 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 197
197 0.000000 0 0 -1 -1
10 228.693478000 t4916 S E
10 228.704666000 t4917 S B
10 228.706551000 w5 WS "I"
13 221.054876000 w5 gf 0.000000
13 221.054876000 sched gft 0.000000
13 228.712006000 sched nready 100.000000
13 228.712006000 sched nsubmitted 104.000000
9 228.712006000 po p 198
10 228.713314000 w5 WS "Fi"
6 B22_173 WS B22_173 "0.000000 0.600000 0.400000"
6 B22_173_1 Ctx1 B22_173 "1.0 0.39 1.0"
6 B22_173_2 Ctx2 B22_173 ".0 1.0 .0"
6 B22_173_3 Ctx3 B22_173 "0.87 0.87 .0"
6 B22_173_4 Ctx4 B22_173 ".0 0.95 1.0"
6 B22_173_5 Ctx5 B22_173 ".0 .0 .0"
6 B22_173_6 Ctx6 B22_173 ".0 .0 0.5"
6 B22_173_7 Ctx7 B22_173 "0.41 0.41 0.41"
6 B22_173_8 Ctx8 B22_173 "1.0 .0 1.0"
6 B22_173_9 Ctx9 B22_173 ".0 .0 1.0"
10 228.715522000 w5 WS "B22_173"
20 228.715522000 w5 WS B22_173 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 198
198 0.000000 0 0 -1 -1
10 228.716907000 t4917 S E
10 228.745976000 t4915 S B
10 228.747939000 w3 WS "I"
13 221.059877000 w3 gf 0.000000
13 221.059877000 sched gft 0.000000
13 228.752801000 sched nready 99.000000
13 228.752801000 sched nsubmitted 103.000000
9 228.752801000 po p 190
10 228.754402000 w3 WS "Fi"
6 B22_165 WS B22_165 "0.000000 0.600000 0.400000"
6 B22_165_1 Ctx1 B22_165 "1.0 0.39 1.0"
6 B22_165_2 Ctx2 B22_165 ".0 1.0 .0"
6 B22_165_3 Ctx3 B22_165 "0.87 0.87 .0"
6 B22_165_4 Ctx4 B22_165 ".0 0.95 1.0"
6 B22_165_5 Ctx5 B22_165 ".0 .0 .0"
6 B22_165_6 Ctx6 B22_165 ".0 .0 0.5"
6 B22_165_7 Ctx7 B22_165 "0.41 0.41 0.41"
6 B22_165_8 Ctx8 B22_165 "1.0 .0 1.0"
6 B22_165_9 Ctx9 B22_165 ".0 .0 1.0"
10 228.756579000 w3 WS "B22_165"
20 228.756579000 w3 WS B22_165 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 190
190 0.000000 0 0 -1 -1
10 228.757865000 t4915 S E
10 229.875589000 t4913 S B
10 229.877324000 w1 WS "I"
13 222.190892000 w1 gf 0.000000
13 222.190892000 sched gft 0.000000
13 229.882196000 sched nready 98.000000
13 229.882196000 sched nsubmitted 102.000000
9 229.882196000 po p 200
10 229.883800000 w1 WS "Fi"
6 B22_175 WS B22_175 "0.000000 0.600000 0.400000"
6 B22_175_1 Ctx1 B22_175 "1.0 0.39 1.0"
6 B22_175_2 Ctx2 B22_175 ".0 1.0 .0"
6 B22_175_3 Ctx3 B22_175 "0.87 0.87 .0"
6 B22_175_4 Ctx4 B22_175 ".0 0.95 1.0"
6 B22_175_5 Ctx5 B22_175 ".0 .0 .0"
6 B22_175_6 Ctx6 B22_175 ".0 .0 0.5"
6 B22_175_7 Ctx7 B22_175 "0.41 0.41 0.41"
6 B22_175_8 Ctx8 B22_175 "1.0 .0 1.0"
6 B22_175_9 Ctx9 B22_175 ".0 .0 1.0"
10 229.885828000 w1 WS "B22_175"
20 229.885828000 w1 WS B22_175 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 200
200 0.000000 0 0 -1 -1
10 229.887098000 t4913 S E
10 230.563774000 t4912 S B
10 230.566232000 w0 WS "I"
13 222.846044000 w0 gf 0.000000
13 222.846044000 sched gft 0.000000
13 230.571719000 sched nready 97.000000
13 230.571719000 sched nsubmitted 101.000000
9 230.571719000 po p 193
10 230.573050000 w0 WS "Fi"
6 B22_168 WS B22_168 "0.000000 0.600000 0.400000"
6 B22_168_1 Ctx1 B22_168 "1.0 0.39 1.0"
6 B22_168_2 Ctx2 B22_168 ".0 1.0 .0"
6 B22_168_3 Ctx3 B22_168 "0.87 0.87 .0"
6 B22_168_4 Ctx4 B22_168 ".0 0.95 1.0"
6 B22_168_5 Ctx5 B22_168 ".0 .0 .0"
6 B22_168_6 Ctx6 B22_168 ".0 .0 0.5"
6 B22_168_7 Ctx7 B22_168 "0.41 0.41 0.41"
6 B22_168_8 Ctx8 B22_168 "1.0 .0 1.0"
6 B22_168_9 Ctx9 B22_168 ".0 .0 1.0"
10 230.575130000 w0 WS "B22_168"
20 230.575130000 w0 WS B22_168 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 193
193 0.000000 0 0 -1 -1
10 230.576583000 t4912 S E
10 236.150869000 t4914 S B
10 236.153196000 w2 WS "I"
13 228.456926000 w2 gf 0.000000
13 228.456926000 sched gft 0.000000
13 236.158536000 sched nready 96.000000
13 236.158536000 sched nsubmitted 100.000000
9 236.158536000 po p 201
10 236.160054000 w2 WS "Fi"
6 B22_176 WS B22_176 "0.000000 0.600000 0.400000"
6 B22_176_1 Ctx1 B22_176 "1.0 0.39 1.0"
6 B22_176_2 Ctx2 B22_176 ".0 1.0 .0"
6 B22_176_3 Ctx3 B22_176 "0.87 0.87 .0"
6 B22_176_4 Ctx4 B22_176 ".0 0.95 1.0"
6 B22_176_5 Ctx5 B22_176 ".0 .0 .0"
6 B22_176_6 Ctx6 B22_176 ".0 .0 0.5"
6 B22_176_7 Ctx7 B22_176 "0.41 0.41 0.41"
6 B22_176_8 Ctx8 B22_176 "1.0 .0 1.0"
6 B22_176_9 Ctx9 B22_176 ".0 .0 1.0"
10 236.162260000 w2 WS "B22_176"
20 236.162260000 w2 WS B22_176 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 201
201 0.000000 0 0 -1 -1
10 236.163484000 t4914 S E
10 236.381538000 t4916 S B
10 236.383431000 w4 WS "I"
13 228.683335000 w4 gf 0.000000
13 228.683335000 sched gft 0.000000
13 236.388874000 sched nready 95.000000
13 236.388874000 sched nsubmitted 99.000000
9 236.388874000 po p 203
10 236.389251000 t4917 S B
10 236.390197000 w4 WS "Fi"
10 236.391183000 w5 WS "I"
13 228.706551000 w5 gf 0.000000
13 228.706551000 sched gft 0.000000
6 B22_178 WS B22_178 "0.000000 0.600000 0.400000"
6 B22_178_1 Ctx1 B22_178 "1.0 0.39 1.0"
6 B22_178_2 Ctx2 B22_178 ".0 1.0 .0"
6 B22_178_3 Ctx3 B22_178 "0.87 0.87 .0"
6 B22_178_4 Ctx4 B22_178 ".0 0.95 1.0"
6 B22_178_5 Ctx5 B22_178 ".0 .0 .0"
6 B22_178_6 Ctx6 B22_178 ".0 .0 0.5"
6 B22_178_7 Ctx7 B22_178 "0.41 0.41 0.41"
6 B22_178_8 Ctx8 B22_178 "1.0 .0 1.0"
6 B22_178_9 Ctx9 B22_178 ".0 .0 1.0"
10 236.392560000 w4 WS "B22_178"
20 236.392560000 w4 WS B22_178 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 203
203 0.000000 0 0 -1 -1
10 236.394049000 t4916 S E
13 236.396150000 sched nready 94.000000
13 236.396150000 sched nsubmitted 98.000000
9 236.396150000 po p 204
10 236.397447000 w5 WS "Fi"
6 B22_179 WS B22_179 "0.000000 0.600000 0.400000"
6 B22_179_1 Ctx1 B22_179 "1.0 0.39 1.0"
6 B22_179_2 Ctx2 B22_179 ".0 1.0 .0"
6 B22_179_3 Ctx3 B22_179 "0.87 0.87 .0"
6 B22_179_4 Ctx4 B22_179 ".0 0.95 1.0"
6 B22_179_5 Ctx5 B22_179 ".0 .0 .0"
6 B22_179_6 Ctx6 B22_179 ".0 .0 0.5"
6 B22_179_7 Ctx7 B22_179 "0.41 0.41 0.41"
6 B22_179_8 Ctx8 B22_179 "1.0 .0 1.0"
6 B22_179_9 Ctx9 B22_179 ".0 .0 1.0"
10 236.399492000 w5 WS "B22_179"
20 236.399492000 w5 WS B22_179 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 204
204 0.000000 0 0 -1 -1
10 236.400767000 t4917 S E
10 236.455172000 t4915 S B
10 236.457126000 w3 WS "I"
13 228.747939000 w3 gf 0.000000
13 228.747939000 sched gft 0.000000
13 236.462059000 sched nready 93.000000
13 236.462059000 sched nsubmitted 97.000000
9 236.462059000 po p 196
10 236.463283000 w3 WS "Fi"
6 B22_171 WS B22_171 "0.000000 0.600000 0.400000"
6 B22_171_1 Ctx1 B22_171 "1.0 0.39 1.0"
6 B22_171_2 Ctx2 B22_171 ".0 1.0 .0"
6 B22_171_3 Ctx3 B22_171 "0.87 0.87 .0"
6 B22_171_4 Ctx4 B22_171 ".0 0.95 1.0"
6 B22_171_5 Ctx5 B22_171 ".0 .0 .0"
6 B22_171_6 Ctx6 B22_171 ".0 .0 0.5"
6 B22_171_7 Ctx7 B22_171 "0.41 0.41 0.41"
6 B22_171_8 Ctx8 B22_171 "1.0 .0 1.0"
6 B22_171_9 Ctx9 B22_171 ".0 .0 1.0"
10 236.465504000 w3 WS "B22_171"
20 236.465504000 w3 WS B22_171 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 196
196 0.000000 0 0 -1 -1
10 236.466799000 t4915 S E
10 237.692528000 t4913 S B
10 237.694262000 w1 WS "I"
13 229.877324000 w1 gf 0.000000
13 229.877324000 sched gft 0.000000
13 237.699175000 sched nready 92.000000
13 237.699175000 sched nsubmitted 96.000000
9 237.699175000 po p 206
10 237.700668000 w1 WS "Fi"
6 B22_181 WS B22_181 "0.000000 0.600000 0.400000"
6 B22_181_1 Ctx1 B22_181 "1.0 0.39 1.0"
6 B22_181_2 Ctx2 B22_181 ".0 1.0 .0"
6 B22_181_3 Ctx3 B22_181 "0.87 0.87 .0"
6 B22_181_4 Ctx4 B22_181 ".0 0.95 1.0"
6 B22_181_5 Ctx5 B22_181 ".0 .0 .0"
6 B22_181_6 Ctx6 B22_181 ".0 .0 0.5"
6 B22_181_7 Ctx7 B22_181 "0.41 0.41 0.41"
6 B22_181_8 Ctx8 B22_181 "1.0 .0 1.0"
6 B22_181_9 Ctx9 B22_181 ".0 .0 1.0"
10 237.702702000 w1 WS "B22_181"
20 237.702702000 w1 WS B22_181 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 206
206 0.000000 0 0 -1 -1
10 237.703954000 t4913 S E
10 238.283333000 t4912 S B
10 238.286096000 w0 WS "I"
13 230.566232000 w0 gf 0.000000
13 230.566232000 sched gft 0.000000
13 238.291544000 sched nready 91.000000
13 238.291544000 sched nsubmitted 95.000000
9 238.291544000 po p 199
10 238.292866000 w0 WS "Fi"
6 B22_174 WS B22_174 "0.000000 0.600000 0.400000"
6 B22_174_1 Ctx1 B22_174 "1.0 0.39 1.0"
6 B22_174_2 Ctx2 B22_174 ".0 1.0 .0"
6 B22_174_3 Ctx3 B22_174 "0.87 0.87 .0"
6 B22_174_4 Ctx4 B22_174 ".0 0.95 1.0"
6 B22_174_5 Ctx5 B22_174 ".0 .0 .0"
6 B22_174_6 Ctx6 B22_174 ".0 .0 0.5"
6 B22_174_7 Ctx7 B22_174 "0.41 0.41 0.41"
6 B22_174_8 Ctx8 B22_174 "1.0 .0 1.0"
6 B22_174_9 Ctx9 B22_174 ".0 .0 1.0"
10 238.295491000 w0 WS "B22_174"
20 238.295491000 w0 WS B22_174 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 199
199 0.000000 0 0 -1 -1
10 238.296877000 t4912 S E
10 243.847727000 t4914 S B
10 243.850189000 w2 WS "I"
13 236.153196000 w2 gf 0.000000
13 236.153196000 sched gft 0.000000
13 243.855555000 sched nready 90.000000
13 243.855555000 sched nsubmitted 94.000000
9 243.855555000 po p 207
10 243.857012000 w2 WS "Fi"
6 B22_182 WS B22_182 "0.000000 0.600000 0.400000"
6 B22_182_1 Ctx1 B22_182 "1.0 0.39 1.0"
6 B22_182_2 Ctx2 B22_182 ".0 1.0 .0"
6 B22_182_3 Ctx3 B22_182 "0.87 0.87 .0"
6 B22_182_4 Ctx4 B22_182 ".0 0.95 1.0"
6 B22_182_5 Ctx5 B22_182 ".0 .0 .0"
6 B22_182_6 Ctx6 B22_182 ".0 .0 0.5"
6 B22_182_7 Ctx7 B22_182 "0.41 0.41 0.41"
6 B22_182_8 Ctx8 B22_182 "1.0 .0 1.0"
6 B22_182_9 Ctx9 B22_182 ".0 .0 1.0"
10 243.859178000 w2 WS "B22_182"
20 243.859178000 w2 WS B22_182 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 207
207 0.000000 0 0 -1 -1
10 243.860630000 t4914 S E
10 244.077868000 t4916 S B
10 244.080181000 w4 WS "I"
13 236.383431000 w4 gf 0.000000
13 236.383431000 sched gft 0.000000
10 244.085153000 t4917 S B
13 244.085143000 sched nready 89.000000
13 244.085143000 sched nsubmitted 93.000000
9 244.085143000 po p 209
10 244.086453000 w4 WS "Fi"
10 244.087030000 w5 WS "I"
13 236.391183000 w5 gf 0.000000
13 236.391183000 sched gft 0.000000
6 B22_184 WS B22_184 "0.000000 0.600000 0.400000"
6 B22_184_1 Ctx1 B22_184 "1.0 0.39 1.0"
6 B22_184_2 Ctx2 B22_184 ".0 1.0 .0"
6 B22_184_3 Ctx3 B22_184 "0.87 0.87 .0"
6 B22_184_4 Ctx4 B22_184 ".0 0.95 1.0"
6 B22_184_5 Ctx5 B22_184 ".0 .0 .0"
6 B22_184_6 Ctx6 B22_184 ".0 .0 0.5"
6 B22_184_7 Ctx7 B22_184 "0.41 0.41 0.41"
6 B22_184_8 Ctx8 B22_184 "1.0 .0 1.0"
6 B22_184_9 Ctx9 B22_184 ".0 .0 1.0"
10 244.088938000 w4 WS "B22_184"
20 244.088938000 w4 WS B22_184 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 209
209 0.000000 0 0 -1 -1
10 244.090616000 t4916 S E
13 244.092291000 sched nready 88.000000
13 244.092291000 sched nsubmitted 92.000000
9 244.092291000 po p 210
10 244.093602000 w5 WS "Fi"
6 B22_185 WS B22_185 "0.000000 0.600000 0.400000"
6 B22_185_1 Ctx1 B22_185 "1.0 0.39 1.0"
6 B22_185_2 Ctx2 B22_185 ".0 1.0 .0"
6 B22_185_3 Ctx3 B22_185 "0.87 0.87 .0"
6 B22_185_4 Ctx4 B22_185 ".0 0.95 1.0"
6 B22_185_5 Ctx5 B22_185 ".0 .0 .0"
6 B22_185_6 Ctx6 B22_185 ".0 .0 0.5"
6 B22_185_7 Ctx7 B22_185 "0.41 0.41 0.41"
6 B22_185_8 Ctx8 B22_185 "1.0 .0 1.0"
6 B22_185_9 Ctx9 B22_185 ".0 .0 1.0"
10 244.095723000 w5 WS "B22_185"
20 244.095723000 w5 WS B22_185 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 210
210 0.000000 0 0 -1 -1
10 244.097055000 t4917 S E
10 244.271511000 t4915 S B
10 244.273118000 w3 WS "I"
13 236.457126000 w3 gf 0.000000
13 236.457126000 sched gft 0.000000
13 244.278171000 sched nready 87.000000
13 244.278171000 sched nsubmitted 91.000000
9 244.278171000 po p 202
10 244.279449000 w3 WS "Fi"
6 B22_177 WS B22_177 "0.000000 0.600000 0.400000"
6 B22_177_1 Ctx1 B22_177 "1.0 0.39 1.0"
6 B22_177_2 Ctx2 B22_177 ".0 1.0 .0"
6 B22_177_3 Ctx3 B22_177 "0.87 0.87 .0"
6 B22_177_4 Ctx4 B22_177 ".0 0.95 1.0"
6 B22_177_5 Ctx5 B22_177 ".0 .0 .0"
6 B22_177_6 Ctx6 B22_177 ".0 .0 0.5"
6 B22_177_7 Ctx7 B22_177 "0.41 0.41 0.41"
6 B22_177_8 Ctx8 B22_177 "1.0 .0 1.0"
6 B22_177_9 Ctx9 B22_177 ".0 .0 1.0"
10 244.281483000 w3 WS "B22_177"
20 244.281483000 w3 WS B22_177 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 202
202 0.000000 0 0 -1 -1
10 244.282802000 t4915 S E
10 245.375947000 t4913 S B
10 245.377914000 w1 WS "I"
13 237.694262000 w1 gf 0.000000
13 237.694262000 sched gft 0.000000
13 245.382610000 sched nready 86.000000
13 245.382610000 sched nsubmitted 90.000000
9 245.382610000 po p 212
10 245.383899000 w1 WS "Fi"
6 B22_187 WS B22_187 "0.000000 0.600000 0.400000"
6 B22_187_1 Ctx1 B22_187 "1.0 0.39 1.0"
6 B22_187_2 Ctx2 B22_187 ".0 1.0 .0"
6 B22_187_3 Ctx3 B22_187 "0.87 0.87 .0"
6 B22_187_4 Ctx4 B22_187 ".0 0.95 1.0"
6 B22_187_5 Ctx5 B22_187 ".0 .0 .0"
6 B22_187_6 Ctx6 B22_187 ".0 .0 0.5"
6 B22_187_7 Ctx7 B22_187 "0.41 0.41 0.41"
6 B22_187_8 Ctx8 B22_187 "1.0 .0 1.0"
6 B22_187_9 Ctx9 B22_187 ".0 .0 1.0"
10 245.386193000 w1 WS "B22_187"
20 245.386193000 w1 WS B22_187 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 212
212 0.000000 0 0 -1 -1
10 245.387475000 t4913 S E
10 245.998032000 t4912 S B
10 246.000983000 w0 WS "I"
13 238.286096000 w0 gf 0.000000
13 238.286096000 sched gft 0.000000
13 246.006325000 sched nready 85.000000
13 246.006325000 sched nsubmitted 89.000000
9 246.006325000 po p 205
10 246.007628000 w0 WS "Fi"
6 B22_180 WS B22_180 "0.000000 0.600000 0.400000"
6 B22_180_1 Ctx1 B22_180 "1.0 0.39 1.0"
6 B22_180_2 Ctx2 B22_180 ".0 1.0 .0"
6 B22_180_3 Ctx3 B22_180 "0.87 0.87 .0"
6 B22_180_4 Ctx4 B22_180 ".0 0.95 1.0"
6 B22_180_5 Ctx5 B22_180 ".0 .0 .0"
6 B22_180_6 Ctx6 B22_180 ".0 .0 0.5"
6 B22_180_7 Ctx7 B22_180 "0.41 0.41 0.41"
6 B22_180_8 Ctx8 B22_180 "1.0 .0 1.0"
6 B22_180_9 Ctx9 B22_180 ".0 .0 1.0"
10 246.009998000 w0 WS "B22_180"
20 246.009998000 w0 WS B22_180 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 205
205 0.000000 0 0 -1 -1
10 246.011364000 t4912 S E
10 251.546679000 t4914 S B
10 251.549203000 w2 WS "I"
13 243.850189000 w2 gf 0.000000
13 243.850189000 sched gft 0.000000
13 251.554833000 sched nready 84.000000
13 251.554833000 sched nsubmitted 88.000000
9 251.554833000 po p 213
10 251.556216000 w2 WS "Fi"
6 B22_188 WS B22_188 "0.000000 0.600000 0.400000"
6 B22_188_1 Ctx1 B22_188 "1.0 0.39 1.0"
6 B22_188_2 Ctx2 B22_188 ".0 1.0 .0"
6 B22_188_3 Ctx3 B22_188 "0.87 0.87 .0"
6 B22_188_4 Ctx4 B22_188 ".0 0.95 1.0"
6 B22_188_5 Ctx5 B22_188 ".0 .0 .0"
6 B22_188_6 Ctx6 B22_188 ".0 .0 0.5"
6 B22_188_7 Ctx7 B22_188 "0.41 0.41 0.41"
6 B22_188_8 Ctx8 B22_188 "1.0 .0 1.0"
6 B22_188_9 Ctx9 B22_188 ".0 .0 1.0"
10 251.558541000 w2 WS "B22_188"
20 251.558541000 w2 WS B22_188 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 213
213 0.000000 0 0 -1 -1
10 251.559843000 t4914 S E
10 251.783995000 t4917 S B
10 251.785880000 w5 WS "I"
13 244.087030000 w5 gf 0.000000
13 251.790778000 sched nready 83.000000
13 251.790778000 sched nsubmitted 87.000000
9 251.790778000 po p 216
10 251.792099000 w5 WS "Fi"
6 B22_191 WS B22_191 "0.000000 0.600000 0.400000"
6 B22_191_1 Ctx1 B22_191 "1.0 0.39 1.0"
6 B22_191_2 Ctx2 B22_191 ".0 1.0 .0"
6 B22_191_3 Ctx3 B22_191 "0.87 0.87 .0"
6 B22_191_4 Ctx4 B22_191 ".0 0.95 1.0"
6 B22_191_5 Ctx5 B22_191 ".0 .0 .0"
6 B22_191_6 Ctx6 B22_191 ".0 .0 0.5"
6 B22_191_7 Ctx7 B22_191 "0.41 0.41 0.41"
6 B22_191_8 Ctx8 B22_191 "1.0 .0 1.0"
6 B22_191_9 Ctx9 B22_191 ".0 .0 1.0"
10 251.794196000 w5 WS "B22_191"
20 251.794196000 w5 WS B22_191 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 216
216 0.000000 0 0 -1 -1
10 251.795492000 t4917 S E
10 251.877080000 t4916 S B
10 251.878655000 w4 WS "I"
13 244.080181000 w4 gf 0.000000
13 244.080181000 sched gft 0.000000
13 244.087030000 sched gft 0.000000
13 251.883770000 sched nready 82.000000
13 251.883770000 sched nsubmitted 86.000000
9 251.883770000 po p 215
10 251.885056000 w4 WS "Fi"
6 B22_190 WS B22_190 "0.000000 0.600000 0.400000"
6 B22_190_1 Ctx1 B22_190 "1.0 0.39 1.0"
6 B22_190_2 Ctx2 B22_190 ".0 1.0 .0"
6 B22_190_3 Ctx3 B22_190 "0.87 0.87 .0"
6 B22_190_4 Ctx4 B22_190 ".0 0.95 1.0"
6 B22_190_5 Ctx5 B22_190 ".0 .0 .0"
6 B22_190_6 Ctx6 B22_190 ".0 .0 0.5"
6 B22_190_7 Ctx7 B22_190 "0.41 0.41 0.41"
6 B22_190_8 Ctx8 B22_190 "1.0 .0 1.0"
6 B22_190_9 Ctx9 B22_190 ".0 .0 1.0"
10 251.887076000 w4 WS "B22_190"
20 251.887076000 w4 WS B22_190 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 215
215 0.000000 0 0 -1 -1
10 251.888342000 t4916 S E
10 251.965448000 t4915 S B
10 251.967330000 w3 WS "I"
13 244.273118000 w3 gf 0.000000
13 244.273118000 sched gft 0.000000
13 251.972568000 sched nready 81.000000
13 251.972568000 sched nsubmitted 85.000000
9 251.972568000 po p 208
10 251.974147000 w3 WS "Fi"
6 B22_183 WS B22_183 "0.000000 0.600000 0.400000"
6 B22_183_1 Ctx1 B22_183 "1.0 0.39 1.0"
6 B22_183_2 Ctx2 B22_183 ".0 1.0 .0"
6 B22_183_3 Ctx3 B22_183 "0.87 0.87 .0"
6 B22_183_4 Ctx4 B22_183 ".0 0.95 1.0"
6 B22_183_5 Ctx5 B22_183 ".0 .0 .0"
6 B22_183_6 Ctx6 B22_183 ".0 .0 0.5"
6 B22_183_7 Ctx7 B22_183 "0.41 0.41 0.41"
6 B22_183_8 Ctx8 B22_183 "1.0 .0 1.0"
6 B22_183_9 Ctx9 B22_183 ".0 .0 1.0"
10 251.976144000 w3 WS "B22_183"
20 251.976144000 w3 WS B22_183 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 208
208 0.000000 0 0 -1 -1
10 251.977370000 t4915 S E
10 253.064614000 t4913 S B
10 253.066413000 w1 WS "I"
13 245.377914000 w1 gf 0.000000
13 245.377914000 sched gft 0.000000
13 253.071354000 sched nready 80.000000
13 253.071354000 sched nsubmitted 84.000000
9 253.071354000 po p 218
10 253.072653000 w1 WS "Fi"
6 B22_193 WS B22_193 "0.000000 0.600000 0.400000"
6 B22_193_1 Ctx1 B22_193 "1.0 0.39 1.0"
6 B22_193_2 Ctx2 B22_193 ".0 1.0 .0"
6 B22_193_3 Ctx3 B22_193 "0.87 0.87 .0"
6 B22_193_4 Ctx4 B22_193 ".0 0.95 1.0"
6 B22_193_5 Ctx5 B22_193 ".0 .0 .0"
6 B22_193_6 Ctx6 B22_193 ".0 .0 0.5"
6 B22_193_7 Ctx7 B22_193 "0.41 0.41 0.41"
6 B22_193_8 Ctx8 B22_193 "1.0 .0 1.0"
6 B22_193_9 Ctx9 B22_193 ".0 .0 1.0"
10 253.074688000 w1 WS "B22_193"
20 253.074688000 w1 WS B22_193 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 218
218 0.000000 0 0 -1 -1
10 253.076042000 t4913 S E
10 253.730721000 t4912 S B
10 253.733549000 w0 WS "I"
13 246.000983000 w0 gf 0.000000
13 246.000983000 sched gft 0.000000
13 253.738873000 sched nready 79.000000
13 253.738873000 sched nsubmitted 83.000000
9 253.738873000 po p 211
10 253.740261000 w0 WS "Fi"
6 B22_186 WS B22_186 "0.000000 0.600000 0.400000"
6 B22_186_1 Ctx1 B22_186 "1.0 0.39 1.0"
6 B22_186_2 Ctx2 B22_186 ".0 1.0 .0"
6 B22_186_3 Ctx3 B22_186 "0.87 0.87 .0"
6 B22_186_4 Ctx4 B22_186 ".0 0.95 1.0"
6 B22_186_5 Ctx5 B22_186 ".0 .0 .0"
6 B22_186_6 Ctx6 B22_186 ".0 .0 0.5"
6 B22_186_7 Ctx7 B22_186 "0.41 0.41 0.41"
6 B22_186_8 Ctx8 B22_186 "1.0 .0 1.0"
6 B22_186_9 Ctx9 B22_186 ".0 .0 1.0"
10 253.742616000 w0 WS "B22_186"
20 253.742616000 w0 WS B22_186 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 211
211 0.000000 0 0 -1 -1
10 253.744054000 t4912 S E
10 259.380086000 t4914 S B
10 259.382912000 w2 WS "I"
13 251.549203000 w2 gf 0.000000
13 251.549203000 sched gft 0.000000
13 259.388911000 sched nready 78.000000
13 259.388911000 sched nsubmitted 82.000000
9 259.388911000 po p 219
10 259.390249000 w2 WS "Fi"
6 B22_194 WS B22_194 "0.000000 0.600000 0.400000"
6 B22_194_1 Ctx1 B22_194 "1.0 0.39 1.0"
6 B22_194_2 Ctx2 B22_194 ".0 1.0 .0"
6 B22_194_3 Ctx3 B22_194 "0.87 0.87 .0"
6 B22_194_4 Ctx4 B22_194 ".0 0.95 1.0"
6 B22_194_5 Ctx5 B22_194 ".0 .0 .0"
6 B22_194_6 Ctx6 B22_194 ".0 .0 0.5"
6 B22_194_7 Ctx7 B22_194 "0.41 0.41 0.41"
6 B22_194_8 Ctx8 B22_194 "1.0 .0 1.0"
6 B22_194_9 Ctx9 B22_194 ".0 .0 1.0"
10 259.392983000 w2 WS "B22_194"
20 259.392983000 w2 WS B22_194 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 219
219 0.000000 0 0 -1 -1
10 259.394596000 t4914 S E
10 259.467237000 t4917 S B
10 259.469266000 w5 WS "I"
13 251.785880000 w5 gf 0.000000
13 251.785880000 sched gft 0.000000
13 259.474878000 sched nready 77.000000
13 259.474878000 sched nsubmitted 81.000000
9 259.474878000 po p 222
10 259.476162000 w5 WS "Fi"
6 B22_197 WS B22_197 "0.000000 0.600000 0.400000"
6 B22_197_1 Ctx1 B22_197 "1.0 0.39 1.0"
6 B22_197_2 Ctx2 B22_197 ".0 1.0 .0"
6 B22_197_3 Ctx3 B22_197 "0.87 0.87 .0"
6 B22_197_4 Ctx4 B22_197 ".0 0.95 1.0"
6 B22_197_5 Ctx5 B22_197 ".0 .0 .0"
6 B22_197_6 Ctx6 B22_197 ".0 .0 0.5"
6 B22_197_7 Ctx7 B22_197 "0.41 0.41 0.41"
6 B22_197_8 Ctx8 B22_197 "1.0 .0 1.0"
6 B22_197_9 Ctx9 B22_197 ".0 .0 1.0"
10 259.478883000 w5 WS "B22_197"
20 259.478883000 w5 WS B22_197 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 222
222 0.000000 0 0 -1 -1
10 259.480184000 t4917 S E
10 259.548411000 t4916 S B
10 259.550212000 w4 WS "I"
13 251.878655000 w4 gf 0.000000
13 251.878655000 sched gft 0.000000
13 259.554988000 sched nready 76.000000
13 259.554988000 sched nsubmitted 80.000000
9 259.554988000 po p 221
10 259.556255000 w4 WS "Fi"
6 B22_196 WS B22_196 "0.000000 0.600000 0.400000"
6 B22_196_1 Ctx1 B22_196 "1.0 0.39 1.0"
6 B22_196_2 Ctx2 B22_196 ".0 1.0 .0"
6 B22_196_3 Ctx3 B22_196 "0.87 0.87 .0"
6 B22_196_4 Ctx4 B22_196 ".0 0.95 1.0"
6 B22_196_5 Ctx5 B22_196 ".0 .0 .0"
6 B22_196_6 Ctx6 B22_196 ".0 .0 0.5"
6 B22_196_7 Ctx7 B22_196 "0.41 0.41 0.41"
6 B22_196_8 Ctx8 B22_196 "1.0 .0 1.0"
6 B22_196_9 Ctx9 B22_196 ".0 .0 1.0"
10 259.558320000 w4 WS "B22_196"
20 259.558320000 w4 WS B22_196 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 221
221 0.000000 0 0 -1 -1
10 259.559563000 t4916 S E
10 259.665181000 t4915 S B
10 259.667122000 w3 WS "I"
13 251.967330000 w3 gf 0.000000
13 251.967330000 sched gft 0.000000
13 259.672422000 sched nready 75.000000
13 259.672422000 sched nsubmitted 79.000000
9 259.672422000 po p 214
10 259.673733000 w3 WS "Fi"
6 B22_189 WS B22_189 "0.000000 0.600000 0.400000"
6 B22_189_1 Ctx1 B22_189 "1.0 0.39 1.0"
6 B22_189_2 Ctx2 B22_189 ".0 1.0 .0"
6 B22_189_3 Ctx3 B22_189 "0.87 0.87 .0"
6 B22_189_4 Ctx4 B22_189 ".0 0.95 1.0"
6 B22_189_5 Ctx5 B22_189 ".0 .0 .0"
6 B22_189_6 Ctx6 B22_189 ".0 .0 0.5"
6 B22_189_7 Ctx7 B22_189 "0.41 0.41 0.41"
6 B22_189_8 Ctx8 B22_189 "1.0 .0 1.0"
6 B22_189_9 Ctx9 B22_189 ".0 .0 1.0"
10 259.676266000 w3 WS "B22_189"
20 259.676266000 w3 WS B22_189 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 214
214 0.000000 0 0 -1 -1
10 259.677512000 t4915 S E
10 260.754172000 t4913 S B
10 260.756045000 w1 WS "I"
13 253.066413000 w1 gf 0.000000
13 253.066413000 sched gft 0.000000
13 260.760840000 sched nready 74.000000
13 260.760840000 sched nsubmitted 78.000000
9 260.760840000 po p 224
10 260.762273000 w1 WS "Fi"
6 B22_199 WS B22_199 "0.000000 0.600000 0.400000"
6 B22_199_1 Ctx1 B22_199 "1.0 0.39 1.0"
6 B22_199_2 Ctx2 B22_199 ".0 1.0 .0"
6 B22_199_3 Ctx3 B22_199 "0.87 0.87 .0"
6 B22_199_4 Ctx4 B22_199 ".0 0.95 1.0"
6 B22_199_5 Ctx5 B22_199 ".0 .0 .0"
6 B22_199_6 Ctx6 B22_199 ".0 .0 0.5"
6 B22_199_7 Ctx7 B22_199 "0.41 0.41 0.41"
6 B22_199_8 Ctx8 B22_199 "1.0 .0 1.0"
6 B22_199_9 Ctx9 B22_199 ".0 .0 1.0"
10 260.764315000 w1 WS "B22_199"
20 260.764315000 w1 WS B22_199 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 224
224 0.000000 0 0 -1 -1
10 260.765567000 t4913 S E
10 261.438769000 t4912 S B
10 261.441563000 w0 WS "I"
13 253.733549000 w0 gf 0.000000
13 253.733549000 sched gft 0.000000
13 261.446788000 sched nready 73.000000
13 261.446788000 sched nsubmitted 77.000000
9 261.446788000 po p 217
10 261.448084000 w0 WS "Fi"
6 B22_192 WS B22_192 "0.000000 0.600000 0.400000"
6 B22_192_1 Ctx1 B22_192 "1.0 0.39 1.0"
6 B22_192_2 Ctx2 B22_192 ".0 1.0 .0"
6 B22_192_3 Ctx3 B22_192 "0.87 0.87 .0"
6 B22_192_4 Ctx4 B22_192 ".0 0.95 1.0"
6 B22_192_5 Ctx5 B22_192 ".0 .0 .0"
6 B22_192_6 Ctx6 B22_192 ".0 .0 0.5"
6 B22_192_7 Ctx7 B22_192 "0.41 0.41 0.41"
6 B22_192_8 Ctx8 B22_192 "1.0 .0 1.0"
6 B22_192_9 Ctx9 B22_192 ".0 .0 1.0"
10 261.450192000 w0 WS "B22_192"
20 261.450192000 w0 WS B22_192 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 217
217 0.000000 0 0 -1 -1
10 261.451600000 t4912 S E
10 267.071764000 t4914 S B
10 267.073856000 w2 WS "I"
13 259.382912000 w2 gf 0.000000
13 259.382912000 sched gft 0.000000
13 267.079177000 sched nready 72.000000
13 267.079177000 sched nsubmitted 76.000000
9 267.079177000 po p 225
10 267.080487000 w2 WS "Fi"
6 B22_200 WS B22_200 "0.000000 0.600000 0.400000"
6 B22_200_1 Ctx1 B22_200 "1.0 0.39 1.0"
6 B22_200_2 Ctx2 B22_200 ".0 1.0 .0"
6 B22_200_3 Ctx3 B22_200 "0.87 0.87 .0"
6 B22_200_4 Ctx4 B22_200 ".0 0.95 1.0"
6 B22_200_5 Ctx5 B22_200 ".0 .0 .0"
6 B22_200_6 Ctx6 B22_200 ".0 .0 0.5"
6 B22_200_7 Ctx7 B22_200 "0.41 0.41 0.41"
6 B22_200_8 Ctx8 B22_200 "1.0 .0 1.0"
6 B22_200_9 Ctx9 B22_200 ".0 .0 1.0"
10 267.082775000 w2 WS "B22_200"
20 267.082775000 w2 WS B22_200 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 225
225 0.000000 0 0 -1 -1
10 267.084077000 t4914 S E
10 267.250652000 t4916 S B
10 267.252543000 w4 WS "I"
13 259.550212000 w4 gf 0.000000
13 267.257740000 sched nready 71.000000
13 267.257740000 sched nsubmitted 75.000000
9 267.257740000 po p 227
10 267.259239000 w4 WS "Fi"
6 B22_202 WS B22_202 "0.000000 0.600000 0.400000"
6 B22_202_1 Ctx1 B22_202 "1.0 0.39 1.0"
6 B22_202_2 Ctx2 B22_202 ".0 1.0 .0"
6 B22_202_3 Ctx3 B22_202 "0.87 0.87 .0"
6 B22_202_4 Ctx4 B22_202 ".0 0.95 1.0"
6 B22_202_5 Ctx5 B22_202 ".0 .0 .0"
6 B22_202_6 Ctx6 B22_202 ".0 .0 0.5"
6 B22_202_7 Ctx7 B22_202 "0.41 0.41 0.41"
6 B22_202_8 Ctx8 B22_202 "1.0 .0 1.0"
6 B22_202_9 Ctx9 B22_202 ".0 .0 1.0"
10 267.261590000 w4 WS "B22_202"
20 267.261590000 w4 WS B22_202 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 227
227 0.000000 0 0 -1 -1
10 267.262777000 t4916 S E
10 267.295753000 t4917 S B
10 267.298687000 w5 WS "I"
13 259.469266000 w5 gf 0.000000
13 259.469266000 sched gft 0.000000
13 259.550212000 sched gft 0.000000
13 267.304314000 sched nready 70.000000
13 267.304314000 sched nsubmitted 74.000000
9 267.304314000 po p 228
10 267.305621000 w5 WS "Fi"
6 B22_203 WS B22_203 "0.000000 0.600000 0.400000"
6 B22_203_1 Ctx1 B22_203 "1.0 0.39 1.0"
6 B22_203_2 Ctx2 B22_203 ".0 1.0 .0"
6 B22_203_3 Ctx3 B22_203 "0.87 0.87 .0"
6 B22_203_4 Ctx4 B22_203 ".0 0.95 1.0"
6 B22_203_5 Ctx5 B22_203 ".0 .0 .0"
6 B22_203_6 Ctx6 B22_203 ".0 .0 0.5"
6 B22_203_7 Ctx7 B22_203 "0.41 0.41 0.41"
6 B22_203_8 Ctx8 B22_203 "1.0 .0 1.0"
6 B22_203_9 Ctx9 B22_203 ".0 .0 1.0"
10 267.307872000 w5 WS "B22_203"
20 267.307872000 w5 WS B22_203 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 228
228 0.000000 0 0 -1 -1
10 267.309293000 t4917 S E
10 267.359190000 t4915 S B
10 267.361158000 w3 WS "I"
13 259.667122000 w3 gf 0.000000
13 259.667122000 sched gft 0.000000
13 267.365829000 sched nready 69.000000
13 267.365829000 sched nsubmitted 73.000000
9 267.365829000 po p 220
10 267.367136000 w3 WS "Fi"
6 B22_195 WS B22_195 "0.000000 0.600000 0.400000"
6 B22_195_1 Ctx1 B22_195 "1.0 0.39 1.0"
6 B22_195_2 Ctx2 B22_195 ".0 1.0 .0"
6 B22_195_3 Ctx3 B22_195 "0.87 0.87 .0"
6 B22_195_4 Ctx4 B22_195 ".0 0.95 1.0"
6 B22_195_5 Ctx5 B22_195 ".0 .0 .0"
6 B22_195_6 Ctx6 B22_195 ".0 .0 0.5"
6 B22_195_7 Ctx7 B22_195 "0.41 0.41 0.41"
6 B22_195_8 Ctx8 B22_195 "1.0 .0 1.0"
6 B22_195_9 Ctx9 B22_195 ".0 .0 1.0"
10 267.369351000 w3 WS "B22_195"
20 267.369351000 w3 WS B22_195 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 220
220 0.000000 0 0 -1 -1
10 267.370679000 t4915 S E
10 268.447032000 t4913 S B
10 268.449014000 w1 WS "I"
13 260.756045000 w1 gf 0.000000
13 260.756045000 sched gft 0.000000
13 268.453831000 sched nready 68.000000
13 268.453831000 sched nsubmitted 72.000000
9 268.453831000 po p 230
10 268.455342000 w1 WS "Fi"
6 B22_205 WS B22_205 "0.000000 0.600000 0.400000"
6 B22_205_1 Ctx1 B22_205 "1.0 0.39 1.0"
6 B22_205_2 Ctx2 B22_205 ".0 1.0 .0"
6 B22_205_3 Ctx3 B22_205 "0.87 0.87 .0"
6 B22_205_4 Ctx4 B22_205 ".0 0.95 1.0"
6 B22_205_5 Ctx5 B22_205 ".0 .0 .0"
6 B22_205_6 Ctx6 B22_205 ".0 .0 0.5"
6 B22_205_7 Ctx7 B22_205 "0.41 0.41 0.41"
6 B22_205_8 Ctx8 B22_205 "1.0 .0 1.0"
6 B22_205_9 Ctx9 B22_205 ".0 .0 1.0"
10 268.457380000 w1 WS "B22_205"
20 268.457380000 w1 WS B22_205 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 230
230 0.000000 0 0 -1 -1
10 268.458637000 t4913 S E
10 269.138754000 t4912 S B
10 269.141042000 w0 WS "I"
13 261.441563000 w0 gf 0.000000
13 261.441563000 sched gft 0.000000
13 269.146071000 sched nready 67.000000
13 269.146071000 sched nsubmitted 71.000000
9 269.146071000 po p 223
10 269.147383000 w0 WS "Fi"
6 B22_198 WS B22_198 "0.000000 0.600000 0.400000"
6 B22_198_1 Ctx1 B22_198 "1.0 0.39 1.0"
6 B22_198_2 Ctx2 B22_198 ".0 1.0 .0"
6 B22_198_3 Ctx3 B22_198 "0.87 0.87 .0"
6 B22_198_4 Ctx4 B22_198 ".0 0.95 1.0"
6 B22_198_5 Ctx5 B22_198 ".0 .0 .0"
6 B22_198_6 Ctx6 B22_198 ".0 .0 0.5"
6 B22_198_7 Ctx7 B22_198 "0.41 0.41 0.41"
6 B22_198_8 Ctx8 B22_198 "1.0 .0 1.0"
6 B22_198_9 Ctx9 B22_198 ".0 .0 1.0"
10 269.149685000 w0 WS "B22_198"
20 269.149685000 w0 WS B22_198 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 223
223 0.000000 0 0 -1 -1
10 269.151030000 t4912 S E
10 274.768164000 t4914 S B
10 274.770736000 w2 WS "I"
13 267.073856000 w2 gf 0.000000
13 267.073856000 sched gft 0.000000
13 274.775797000 sched nready 66.000000
13 274.775797000 sched nsubmitted 70.000000
9 274.775797000 po p 231
10 274.777128000 w2 WS "Fi"
6 B22_206 WS B22_206 "0.000000 0.600000 0.400000"
6 B22_206_1 Ctx1 B22_206 "1.0 0.39 1.0"
6 B22_206_2 Ctx2 B22_206 ".0 1.0 .0"
6 B22_206_3 Ctx3 B22_206 "0.87 0.87 .0"
6 B22_206_4 Ctx4 B22_206 ".0 0.95 1.0"
6 B22_206_5 Ctx5 B22_206 ".0 .0 .0"
6 B22_206_6 Ctx6 B22_206 ".0 .0 0.5"
6 B22_206_7 Ctx7 B22_206 "0.41 0.41 0.41"
6 B22_206_8 Ctx8 B22_206 "1.0 .0 1.0"
6 B22_206_9 Ctx9 B22_206 ".0 .0 1.0"
10 274.779314000 w2 WS "B22_206"
20 274.779314000 w2 WS B22_206 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 231
231 0.000000 0 0 -1 -1
10 274.780630000 t4914 S E
10 274.941159000 t4916 S B
10 274.942999000 w4 WS "I"
13 267.252543000 w4 gf 0.000000
13 267.252543000 sched gft 0.000000
13 274.947906000 sched nready 65.000000
13 274.947906000 sched nsubmitted 69.000000
9 274.947906000 po p 233
10 274.949204000 w4 WS "Fi"
6 B22_208 WS B22_208 "0.000000 0.600000 0.400000"
6 B22_208_1 Ctx1 B22_208 "1.0 0.39 1.0"
6 B22_208_2 Ctx2 B22_208 ".0 1.0 .0"
6 B22_208_3 Ctx3 B22_208 "0.87 0.87 .0"
6 B22_208_4 Ctx4 B22_208 ".0 0.95 1.0"
6 B22_208_5 Ctx5 B22_208 ".0 .0 .0"
6 B22_208_6 Ctx6 B22_208 ".0 .0 0.5"
6 B22_208_7 Ctx7 B22_208 "0.41 0.41 0.41"
6 B22_208_8 Ctx8 B22_208 "1.0 .0 1.0"
6 B22_208_9 Ctx9 B22_208 ".0 .0 1.0"
10 274.951681000 w4 WS "B22_208"
20 274.951681000 w4 WS B22_208 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 233
233 0.000000 0 0 -1 -1
10 274.952944000 t4916 S E
10 274.960327000 t4917 S B
10 274.961990000 w5 WS "I"
13 267.298687000 w5 gf 0.000000
13 267.298687000 sched gft 0.000000
13 274.967253000 sched nready 64.000000
13 274.967253000 sched nsubmitted 68.000000
9 274.967253000 po p 234
10 274.968589000 w5 WS "Fi"
6 B22_209 WS B22_209 "0.000000 0.600000 0.400000"
6 B22_209_1 Ctx1 B22_209 "1.0 0.39 1.0"
6 B22_209_2 Ctx2 B22_209 ".0 1.0 .0"
6 B22_209_3 Ctx3 B22_209 "0.87 0.87 .0"
6 B22_209_4 Ctx4 B22_209 ".0 0.95 1.0"
6 B22_209_5 Ctx5 B22_209 ".0 .0 .0"
6 B22_209_6 Ctx6 B22_209 ".0 .0 0.5"
6 B22_209_7 Ctx7 B22_209 "0.41 0.41 0.41"
6 B22_209_8 Ctx8 B22_209 "1.0 .0 1.0"
6 B22_209_9 Ctx9 B22_209 ".0 .0 1.0"
10 274.970673000 w5 WS "B22_209"
20 274.970673000 w5 WS B22_209 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 234
234 0.000000 0 0 -1 -1
10 274.972007000 t4917 S E
10 275.047698000 t4915 S B
10 275.049478000 w3 WS "I"
13 267.361158000 w3 gf 0.000000
13 267.361158000 sched gft 0.000000
13 275.054190000 sched nready 63.000000
13 275.054190000 sched nsubmitted 67.000000
9 275.054190000 po p 226
10 275.055587000 w3 WS "Fi"
6 B22_201 WS B22_201 "0.000000 0.600000 0.400000"
6 B22_201_1 Ctx1 B22_201 "1.0 0.39 1.0"
6 B22_201_2 Ctx2 B22_201 ".0 1.0 .0"
6 B22_201_3 Ctx3 B22_201 "0.87 0.87 .0"
6 B22_201_4 Ctx4 B22_201 ".0 0.95 1.0"
6 B22_201_5 Ctx5 B22_201 ".0 .0 .0"
6 B22_201_6 Ctx6 B22_201 ".0 .0 0.5"
6 B22_201_7 Ctx7 B22_201 "0.41 0.41 0.41"
6 B22_201_8 Ctx8 B22_201 "1.0 .0 1.0"
6 B22_201_9 Ctx9 B22_201 ".0 .0 1.0"
10 275.057648000 w3 WS "B22_201"
20 275.057648000 w3 WS B22_201 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 226
226 0.000000 0 0 -1 -1
10 275.059025000 t4915 S E
10 276.150172000 t4913 S B
10 276.151880000 w1 WS "I"
13 268.449014000 w1 gf 0.000000
13 268.449014000 sched gft 0.000000
13 276.156529000 sched nready 62.000000
13 276.156529000 sched nsubmitted 66.000000
9 276.156529000 po p 236
10 276.157908000 w1 WS "Fi"
6 B22_211 WS B22_211 "0.000000 0.600000 0.400000"
6 B22_211_1 Ctx1 B22_211 "1.0 0.39 1.0"
6 B22_211_2 Ctx2 B22_211 ".0 1.0 .0"
6 B22_211_3 Ctx3 B22_211 "0.87 0.87 .0"
6 B22_211_4 Ctx4 B22_211 ".0 0.95 1.0"
6 B22_211_5 Ctx5 B22_211 ".0 .0 .0"
6 B22_211_6 Ctx6 B22_211 ".0 .0 0.5"
6 B22_211_7 Ctx7 B22_211 "0.41 0.41 0.41"
6 B22_211_8 Ctx8 B22_211 "1.0 .0 1.0"
6 B22_211_9 Ctx9 B22_211 ".0 .0 1.0"
10 276.159987000 w1 WS "B22_211"
20 276.159987000 w1 WS B22_211 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 236
236 0.000000 0 0 -1 -1
10 276.161302000 t4913 S E
10 276.848688000 t4912 S B
10 276.851308000 w0 WS "I"
13 269.141042000 w0 gf 0.000000
13 269.141042000 sched gft 0.000000
13 276.856890000 sched nready 61.000000
13 276.856890000 sched nsubmitted 65.000000
9 276.856890000 po p 229
10 276.858209000 w0 WS "Fi"
6 B22_204 WS B22_204 "0.000000 0.600000 0.400000"
6 B22_204_1 Ctx1 B22_204 "1.0 0.39 1.0"
6 B22_204_2 Ctx2 B22_204 ".0 1.0 .0"
6 B22_204_3 Ctx3 B22_204 "0.87 0.87 .0"
6 B22_204_4 Ctx4 B22_204 ".0 0.95 1.0"
6 B22_204_5 Ctx5 B22_204 ".0 .0 .0"
6 B22_204_6 Ctx6 B22_204 ".0 .0 0.5"
6 B22_204_7 Ctx7 B22_204 "0.41 0.41 0.41"
6 B22_204_8 Ctx8 B22_204 "1.0 .0 1.0"
6 B22_204_9 Ctx9 B22_204 ".0 .0 1.0"
10 276.860619000 w0 WS "B22_204"
20 276.860619000 w0 WS B22_204 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 229
229 0.000000 0 0 -1 -1
10 276.861932000 t4912 S E
10 282.455354000 t4914 S B
10 282.458013000 w2 WS "I"
13 274.770736000 w2 gf 0.000000
13 274.770736000 sched gft 0.000000
13 282.463298000 sched nready 60.000000
13 282.463298000 sched nsubmitted 64.000000
9 282.463298000 po p 237
10 282.464602000 w2 WS "Fi"
6 B22_212 WS B22_212 "0.000000 0.600000 0.400000"
6 B22_212_1 Ctx1 B22_212 "1.0 0.39 1.0"
6 B22_212_2 Ctx2 B22_212 ".0 1.0 .0"
6 B22_212_3 Ctx3 B22_212 "0.87 0.87 .0"
6 B22_212_4 Ctx4 B22_212 ".0 0.95 1.0"
6 B22_212_5 Ctx5 B22_212 ".0 .0 .0"
6 B22_212_6 Ctx6 B22_212 ".0 .0 0.5"
6 B22_212_7 Ctx7 B22_212 "0.41 0.41 0.41"
6 B22_212_8 Ctx8 B22_212 "1.0 .0 1.0"
6 B22_212_9 Ctx9 B22_212 ".0 .0 1.0"
10 282.466951000 w2 WS "B22_212"
20 282.466951000 w2 WS B22_212 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 237
237 0.000000 0 0 -1 -1
10 282.468278000 t4914 S E
10 282.639527000 t4916 S B
10 282.640427000 t4917 S B
10 282.641533000 w4 WS "I"
13 274.942999000 w4 gf 0.000000
13 274.942999000 sched gft 0.000000
10 282.642327000 w5 WS "I"
13 274.961990000 w5 gf 0.000000
13 274.961990000 sched gft 0.000000
13 282.646748000 sched nready 59.000000
13 282.646748000 sched nsubmitted 63.000000
9 282.646748000 po p 239
13 282.647937000 sched nready 58.000000
13 282.647937000 sched nsubmitted 62.000000
9 282.647937000 po p 240
10 282.648133000 w4 WS "Fi"
10 282.649320000 w5 WS "Fi"
6 B22_214 WS B22_214 "0.000000 0.600000 0.400000"
6 B22_214_1 Ctx1 B22_214 "1.0 0.39 1.0"
6 B22_214_2 Ctx2 B22_214 ".0 1.0 .0"
6 B22_214_3 Ctx3 B22_214 "0.87 0.87 .0"
6 B22_214_4 Ctx4 B22_214 ".0 0.95 1.0"
6 B22_214_5 Ctx5 B22_214 ".0 .0 .0"
6 B22_214_6 Ctx6 B22_214 ".0 .0 0.5"
6 B22_214_7 Ctx7 B22_214 "0.41 0.41 0.41"
6 B22_214_8 Ctx8 B22_214 "1.0 .0 1.0"
6 B22_214_9 Ctx9 B22_214 ".0 .0 1.0"
10 282.650605000 w4 WS "B22_214"
6 B22_215 WS B22_215 "0.000000 0.600000 0.400000"
6 B22_215_1 Ctx1 B22_215 "1.0 0.39 1.0"
6 B22_215_2 Ctx2 B22_215 ".0 1.0 .0"
6 B22_215_3 Ctx3 B22_215 "0.87 0.87 .0"
6 B22_215_4 Ctx4 B22_215 ".0 0.95 1.0"
6 B22_215_5 Ctx5 B22_215 ".0 .0 .0"
6 B22_215_6 Ctx6 B22_215 ".0 .0 0.5"
6 B22_215_7 Ctx7 B22_215 "0.41 0.41 0.41"
6 B22_215_8 Ctx8 B22_215 "1.0 .0 1.0"
6 B22_215_9 Ctx9 B22_215 ".0 .0 1.0"
10 282.651846000 w5 WS "B22_215"
20 282.650605000 w4 WS B22_214 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 239
239 0.000000 0 0 -1 -1
10 282.652210000 t4916 S E
20 282.651846000 w5 WS B22_215 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 240
240 0.000000 0 0 -1 -1
10 282.653411000 t4917 S E
10 282.733035000 t4915 S B
10 282.734576000 w3 WS "I"
13 275.049478000 w3 gf 0.000000
13 275.049478000 sched gft 0.000000
13 282.739320000 sched nready 57.000000
13 282.739320000 sched nsubmitted 61.000000
9 282.739320000 po p 232
10 282.740604000 w3 WS "Fi"
6 B22_207 WS B22_207 "0.000000 0.600000 0.400000"
6 B22_207_1 Ctx1 B22_207 "1.0 0.39 1.0"
6 B22_207_2 Ctx2 B22_207 ".0 1.0 .0"
6 B22_207_3 Ctx3 B22_207 "0.87 0.87 .0"
6 B22_207_4 Ctx4 B22_207 ".0 0.95 1.0"
6 B22_207_5 Ctx5 B22_207 ".0 .0 .0"
6 B22_207_6 Ctx6 B22_207 ".0 .0 0.5"
6 B22_207_7 Ctx7 B22_207 "0.41 0.41 0.41"
6 B22_207_8 Ctx8 B22_207 "1.0 .0 1.0"
6 B22_207_9 Ctx9 B22_207 ".0 .0 1.0"
10 282.742555000 w3 WS "B22_207"
20 282.742555000 w3 WS B22_207 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 232
232 0.000000 0 0 -1 -1
10 282.743804000 t4915 S E
10 283.831583000 t4913 S B
10 283.834005000 w1 WS "I"
13 276.151880000 w1 gf 0.000000
13 276.151880000 sched gft 0.000000
13 283.838914000 sched nready 56.000000
13 283.838914000 sched nsubmitted 60.000000
9 283.838914000 po p 242
10 283.840254000 w1 WS "Fi"
6 B22_217 WS B22_217 "0.000000 0.600000 0.400000"
6 B22_217_1 Ctx1 B22_217 "1.0 0.39 1.0"
6 B22_217_2 Ctx2 B22_217 ".0 1.0 .0"
6 B22_217_3 Ctx3 B22_217 "0.87 0.87 .0"
6 B22_217_4 Ctx4 B22_217 ".0 0.95 1.0"
6 B22_217_5 Ctx5 B22_217 ".0 .0 .0"
6 B22_217_6 Ctx6 B22_217 ".0 .0 0.5"
6 B22_217_7 Ctx7 B22_217 "0.41 0.41 0.41"
6 B22_217_8 Ctx8 B22_217 "1.0 .0 1.0"
6 B22_217_9 Ctx9 B22_217 ".0 .0 1.0"
10 283.842405000 w1 WS "B22_217"
20 283.842405000 w1 WS B22_217 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 242
242 0.000000 0 0 -1 -1
10 283.844132000 t4913 S E
10 284.728212000 t4912 S B
10 284.731083000 w0 WS "I"
13 276.851308000 w0 gf 0.000000
13 276.851308000 sched gft 0.000000
13 284.736503000 sched nready 55.000000
13 284.736503000 sched nsubmitted 59.000000
9 284.736503000 po p 235
10 284.737831000 w0 WS "Fi"
6 B22_210 WS B22_210 "0.000000 0.600000 0.400000"
6 B22_210_1 Ctx1 B22_210 "1.0 0.39 1.0"
6 B22_210_2 Ctx2 B22_210 ".0 1.0 .0"
6 B22_210_3 Ctx3 B22_210 "0.87 0.87 .0"
6 B22_210_4 Ctx4 B22_210 ".0 0.95 1.0"
6 B22_210_5 Ctx5 B22_210 ".0 .0 .0"
6 B22_210_6 Ctx6 B22_210 ".0 .0 0.5"
6 B22_210_7 Ctx7 B22_210 "0.41 0.41 0.41"
6 B22_210_8 Ctx8 B22_210 "1.0 .0 1.0"
6 B22_210_9 Ctx9 B22_210 ".0 .0 1.0"
10 284.739870000 w0 WS "B22_210"
20 284.739870000 w0 WS B22_210 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 235
235 0.000000 0 0 -1 -1
10 284.741162000 t4912 S E
10 290.151994000 t4914 S B
10 290.154098000 w2 WS "I"
13 282.458013000 w2 gf 0.000000
13 282.458013000 sched gft 0.000000
13 290.159474000 sched nready 54.000000
13 290.159474000 sched nsubmitted 58.000000
9 290.159474000 po p 243
10 290.161102000 w2 WS "Fi"
6 B22_218 WS B22_218 "0.000000 0.600000 0.400000"
6 B22_218_1 Ctx1 B22_218 "1.0 0.39 1.0"
6 B22_218_2 Ctx2 B22_218 ".0 1.0 .0"
6 B22_218_3 Ctx3 B22_218 "0.87 0.87 .0"
6 B22_218_4 Ctx4 B22_218 ".0 0.95 1.0"
6 B22_218_5 Ctx5 B22_218 ".0 .0 .0"
6 B22_218_6 Ctx6 B22_218 ".0 .0 0.5"
6 B22_218_7 Ctx7 B22_218 "0.41 0.41 0.41"
6 B22_218_8 Ctx8 B22_218 "1.0 .0 1.0"
6 B22_218_9 Ctx9 B22_218 ".0 .0 1.0"
10 290.163234000 w2 WS "B22_218"
20 290.163234000 w2 WS B22_218 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 243
243 0.000000 0 0 -1 -1
10 290.164490000 t4914 S E
10 290.327329000 t4916 S B
10 290.329077000 w4 WS "I"
13 282.641533000 w4 gf 0.000000
13 282.641533000 sched gft 0.000000
13 290.333770000 sched nready 53.000000
13 290.333770000 sched nsubmitted 57.000000
9 290.333770000 po p 245
10 290.335053000 w4 WS "Fi"
10 290.335414000 t4917 S B
10 290.337408000 w5 WS "I"
13 282.642327000 w5 gf 0.000000
13 282.642327000 sched gft 0.000000
6 B22_220 WS B22_220 "0.000000 0.600000 0.400000"
6 B22_220_1 Ctx1 B22_220 "1.0 0.39 1.0"
6 B22_220_2 Ctx2 B22_220 ".0 1.0 .0"
6 B22_220_3 Ctx3 B22_220 "0.87 0.87 .0"
6 B22_220_4 Ctx4 B22_220 ".0 0.95 1.0"
6 B22_220_5 Ctx5 B22_220 ".0 .0 .0"
6 B22_220_6 Ctx6 B22_220 ".0 .0 0.5"
6 B22_220_7 Ctx7 B22_220 "0.41 0.41 0.41"
6 B22_220_8 Ctx8 B22_220 "1.0 .0 1.0"
6 B22_220_9 Ctx9 B22_220 ".0 .0 1.0"
10 290.337484000 w4 WS "B22_220"
20 290.337484000 w4 WS B22_220 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 245
245 0.000000 0 0 -1 -1
10 290.339070000 t4916 S E
13 290.342455000 sched nready 52.000000
13 290.342455000 sched nsubmitted 56.000000
9 290.342455000 po p 246
10 290.343788000 w5 WS "Fi"
6 B22_221 WS B22_221 "0.000000 0.600000 0.400000"
6 B22_221_1 Ctx1 B22_221 "1.0 0.39 1.0"
6 B22_221_2 Ctx2 B22_221 ".0 1.0 .0"
6 B22_221_3 Ctx3 B22_221 "0.87 0.87 .0"
6 B22_221_4 Ctx4 B22_221 ".0 0.95 1.0"
6 B22_221_5 Ctx5 B22_221 ".0 .0 .0"
6 B22_221_6 Ctx6 B22_221 ".0 .0 0.5"
6 B22_221_7 Ctx7 B22_221 "0.41 0.41 0.41"
6 B22_221_8 Ctx8 B22_221 "1.0 .0 1.0"
6 B22_221_9 Ctx9 B22_221 ".0 .0 1.0"
10 290.345797000 w5 WS "B22_221"
20 290.345797000 w5 WS B22_221 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 246
246 0.000000 0 0 -1 -1
10 290.347084000 t4917 S E
10 290.434048000 t4915 S B
10 290.435707000 w3 WS "I"
13 282.734576000 w3 gf 0.000000
13 282.734576000 sched gft 0.000000
13 290.440534000 sched nready 51.000000
13 290.440534000 sched nsubmitted 55.000000
9 290.440534000 po p 238
10 290.441795000 w3 WS "Fi"
6 B22_213 WS B22_213 "0.000000 0.600000 0.400000"
6 B22_213_1 Ctx1 B22_213 "1.0 0.39 1.0"
6 B22_213_2 Ctx2 B22_213 ".0 1.0 .0"
6 B22_213_3 Ctx3 B22_213 "0.87 0.87 .0"
6 B22_213_4 Ctx4 B22_213 ".0 0.95 1.0"
6 B22_213_5 Ctx5 B22_213 ".0 .0 .0"
6 B22_213_6 Ctx6 B22_213 ".0 .0 0.5"
6 B22_213_7 Ctx7 B22_213 "0.41 0.41 0.41"
6 B22_213_8 Ctx8 B22_213 "1.0 .0 1.0"
6 B22_213_9 Ctx9 B22_213 ".0 .0 1.0"
10 290.443637000 w3 WS "B22_213"
20 290.443637000 w3 WS B22_213 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 238
238 0.000000 0 0 -1 -1
10 290.444925000 t4915 S E
10 291.651701000 t4913 S B
10 291.653554000 w1 WS "I"
13 283.834005000 w1 gf 0.000000
13 283.834005000 sched gft 0.000000
13 291.658720000 sched nready 50.000000
13 291.658720000 sched nsubmitted 54.000000
9 291.658720000 po p 248
10 291.660037000 w1 WS "Fi"
6 B22_223 WS B22_223 "0.000000 0.600000 0.400000"
6 B22_223_1 Ctx1 B22_223 "1.0 0.39 1.0"
6 B22_223_2 Ctx2 B22_223 ".0 1.0 .0"
6 B22_223_3 Ctx3 B22_223 "0.87 0.87 .0"
6 B22_223_4 Ctx4 B22_223 ".0 0.95 1.0"
6 B22_223_5 Ctx5 B22_223 ".0 .0 .0"
6 B22_223_6 Ctx6 B22_223 ".0 .0 0.5"
6 B22_223_7 Ctx7 B22_223 "0.41 0.41 0.41"
6 B22_223_8 Ctx8 B22_223 "1.0 .0 1.0"
6 B22_223_9 Ctx9 B22_223 ".0 .0 1.0"
10 291.662218000 w1 WS "B22_223"
20 291.662218000 w1 WS B22_223 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 248
248 0.000000 0 0 -1 -1
10 291.663442000 t4913 S E
10 292.441145000 t4912 S B
10 292.443836000 w0 WS "I"
13 284.731083000 w0 gf 0.000000
13 284.731083000 sched gft 0.000000
13 292.449153000 sched nready 49.000000
13 292.449153000 sched nsubmitted 53.000000
9 292.449153000 po p 241
10 292.450463000 w0 WS "Fi"
6 B22_216 WS B22_216 "0.000000 0.600000 0.400000"
6 B22_216_1 Ctx1 B22_216 "1.0 0.39 1.0"
6 B22_216_2 Ctx2 B22_216 ".0 1.0 .0"
6 B22_216_3 Ctx3 B22_216 "0.87 0.87 .0"
6 B22_216_4 Ctx4 B22_216 ".0 0.95 1.0"
6 B22_216_5 Ctx5 B22_216 ".0 .0 .0"
6 B22_216_6 Ctx6 B22_216 ".0 .0 0.5"
6 B22_216_7 Ctx7 B22_216 "0.41 0.41 0.41"
6 B22_216_8 Ctx8 B22_216 "1.0 .0 1.0"
6 B22_216_9 Ctx9 B22_216 ".0 .0 1.0"
10 292.452594000 w0 WS "B22_216"
20 292.452594000 w0 WS B22_216 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 241
241 0.000000 0 0 -1 -1
10 292.454023000 t4912 S E
10 297.838099000 t4914 S B
10 297.840147000 w2 WS "I"
13 290.154098000 w2 gf 0.000000
13 290.154098000 sched gft 0.000000
13 297.845832000 sched nready 48.000000
13 297.845832000 sched nsubmitted 52.000000
9 297.845832000 po p 249
10 297.847104000 w2 WS "Fi"
6 B22_224 WS B22_224 "0.000000 0.600000 0.400000"
6 B22_224_1 Ctx1 B22_224 "1.0 0.39 1.0"
6 B22_224_2 Ctx2 B22_224 ".0 1.0 .0"
6 B22_224_3 Ctx3 B22_224 "0.87 0.87 .0"
6 B22_224_4 Ctx4 B22_224 ".0 0.95 1.0"
6 B22_224_5 Ctx5 B22_224 ".0 .0 .0"
6 B22_224_6 Ctx6 B22_224 ".0 .0 0.5"
6 B22_224_7 Ctx7 B22_224 "0.41 0.41 0.41"
6 B22_224_8 Ctx8 B22_224 "1.0 .0 1.0"
6 B22_224_9 Ctx9 B22_224 ".0 .0 1.0"
10 297.849396000 w2 WS "B22_224"
20 297.849396000 w2 WS B22_224 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 249
249 0.000000 0 0 -1 -1
10 297.851121000 t4914 S E
10 298.010281000 t4916 S B
10 298.012042000 w4 WS "I"
13 290.329077000 w4 gf 0.000000
13 290.329077000 sched gft 0.000000
13 298.016837000 sched nready 47.000000
13 298.016837000 sched nsubmitted 51.000000
9 298.016837000 po p 251
10 298.018166000 w4 WS "Fi"
6 B22_226 WS B22_226 "0.000000 0.600000 0.400000"
6 B22_226_1 Ctx1 B22_226 "1.0 0.39 1.0"
6 B22_226_2 Ctx2 B22_226 ".0 1.0 .0"
6 B22_226_3 Ctx3 B22_226 "0.87 0.87 .0"
6 B22_226_4 Ctx4 B22_226 ".0 0.95 1.0"
6 B22_226_5 Ctx5 B22_226 ".0 .0 .0"
6 B22_226_6 Ctx6 B22_226 ".0 .0 0.5"
6 B22_226_7 Ctx7 B22_226 "0.41 0.41 0.41"
6 B22_226_8 Ctx8 B22_226 "1.0 .0 1.0"
6 B22_226_9 Ctx9 B22_226 ".0 .0 1.0"
10 298.020336000 w4 WS "B22_226"
20 298.020336000 w4 WS B22_226 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 251
251 0.000000 0 0 -1 -1
10 298.021584000 t4916 S E
10 298.022159000 t4917 S B
10 298.024702000 w5 WS "I"
13 290.337408000 w5 gf 0.000000
13 290.337408000 sched gft 0.000000
13 298.030021000 sched nready 46.000000
13 298.030021000 sched nsubmitted 50.000000
9 298.030021000 po p 252
10 298.031351000 w5 WS "Fi"
6 B22_227 WS B22_227 "0.000000 0.600000 0.400000"
6 B22_227_1 Ctx1 B22_227 "1.0 0.39 1.0"
6 B22_227_2 Ctx2 B22_227 ".0 1.0 .0"
6 B22_227_3 Ctx3 B22_227 "0.87 0.87 .0"
6 B22_227_4 Ctx4 B22_227 ".0 0.95 1.0"
6 B22_227_5 Ctx5 B22_227 ".0 .0 .0"
6 B22_227_6 Ctx6 B22_227 ".0 .0 0.5"
6 B22_227_7 Ctx7 B22_227 "0.41 0.41 0.41"
6 B22_227_8 Ctx8 B22_227 "1.0 .0 1.0"
6 B22_227_9 Ctx9 B22_227 ".0 .0 1.0"
10 298.033584000 w5 WS "B22_227"
20 298.033584000 w5 WS B22_227 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 252
252 0.000000 0 0 -1 -1
10 298.034910000 t4917 S E
10 298.244603000 t4915 S B
10 298.246233000 w3 WS "I"
13 290.435707000 w3 gf 0.000000
13 290.435707000 sched gft 0.000000
13 298.250898000 sched nready 45.000000
13 298.250898000 sched nsubmitted 49.000000
9 298.250898000 po p 244
10 298.252422000 w3 WS "Fi"
6 B22_219 WS B22_219 "0.000000 0.600000 0.400000"
6 B22_219_1 Ctx1 B22_219 "1.0 0.39 1.0"
6 B22_219_2 Ctx2 B22_219 ".0 1.0 .0"
6 B22_219_3 Ctx3 B22_219 "0.87 0.87 .0"
6 B22_219_4 Ctx4 B22_219 ".0 0.95 1.0"
6 B22_219_5 Ctx5 B22_219 ".0 .0 .0"
6 B22_219_6 Ctx6 B22_219 ".0 .0 0.5"
6 B22_219_7 Ctx7 B22_219 "0.41 0.41 0.41"
6 B22_219_8 Ctx8 B22_219 "1.0 .0 1.0"
6 B22_219_9 Ctx9 B22_219 ".0 .0 1.0"
10 298.254447000 w3 WS "B22_219"
20 298.254447000 w3 WS B22_219 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 244
244 0.000000 0 0 -1 -1
10 298.255714000 t4915 S E
10 299.335846000 t4913 S B
10 299.337705000 w1 WS "I"
13 291.653554000 w1 gf 0.000000
13 291.653554000 sched gft 0.000000
13 299.342831000 sched nready 44.000000
13 299.342831000 sched nsubmitted 48.000000
9 299.342831000 po p 254
10 299.344118000 w1 WS "Fi"
6 B22_229 WS B22_229 "0.000000 0.600000 0.400000"
6 B22_229_1 Ctx1 B22_229 "1.0 0.39 1.0"
6 B22_229_2 Ctx2 B22_229 ".0 1.0 .0"
6 B22_229_3 Ctx3 B22_229 "0.87 0.87 .0"
6 B22_229_4 Ctx4 B22_229 ".0 0.95 1.0"
6 B22_229_5 Ctx5 B22_229 ".0 .0 .0"
6 B22_229_6 Ctx6 B22_229 ".0 .0 0.5"
6 B22_229_7 Ctx7 B22_229 "0.41 0.41 0.41"
6 B22_229_8 Ctx8 B22_229 "1.0 .0 1.0"
6 B22_229_9 Ctx9 B22_229 ".0 .0 1.0"
10 299.346317000 w1 WS "B22_229"
20 299.346317000 w1 WS B22_229 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 254
254 0.000000 0 0 -1 -1
10 299.347655000 t4913 S E
10 300.157828000 t4912 S B
10 300.160135000 w0 WS "I"
13 292.443836000 w0 gf 0.000000
13 292.443836000 sched gft 0.000000
13 300.165255000 sched nready 43.000000
13 300.165255000 sched nsubmitted 47.000000
9 300.165255000 po p 247
10 300.166557000 w0 WS "Fi"
6 B22_222 WS B22_222 "0.000000 0.600000 0.400000"
6 B22_222_1 Ctx1 B22_222 "1.0 0.39 1.0"
6 B22_222_2 Ctx2 B22_222 ".0 1.0 .0"
6 B22_222_3 Ctx3 B22_222 "0.87 0.87 .0"
6 B22_222_4 Ctx4 B22_222 ".0 0.95 1.0"
6 B22_222_5 Ctx5 B22_222 ".0 .0 .0"
6 B22_222_6 Ctx6 B22_222 ".0 .0 0.5"
6 B22_222_7 Ctx7 B22_222 "0.41 0.41 0.41"
6 B22_222_8 Ctx8 B22_222 "1.0 .0 1.0"
6 B22_222_9 Ctx9 B22_222 ".0 .0 1.0"
10 300.168779000 w0 WS "B22_222"
20 300.168779000 w0 WS B22_222 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 247
247 0.000000 0 0 -1 -1
10 300.170077000 t4912 S E
10 305.542357000 t4914 S B
10 305.544637000 w2 WS "I"
13 297.840147000 w2 gf 0.000000
13 297.840147000 sched gft 0.000000
13 305.550431000 sched nready 42.000000
13 305.550431000 sched nsubmitted 46.000000
9 305.550431000 po p 255
10 305.551843000 w2 WS "Fi"
6 B22_230 WS B22_230 "0.000000 0.600000 0.400000"
6 B22_230_1 Ctx1 B22_230 "1.0 0.39 1.0"
6 B22_230_2 Ctx2 B22_230 ".0 1.0 .0"
6 B22_230_3 Ctx3 B22_230 "0.87 0.87 .0"
6 B22_230_4 Ctx4 B22_230 ".0 0.95 1.0"
6 B22_230_5 Ctx5 B22_230 ".0 .0 .0"
6 B22_230_6 Ctx6 B22_230 ".0 .0 0.5"
6 B22_230_7 Ctx7 B22_230 "0.41 0.41 0.41"
6 B22_230_8 Ctx8 B22_230 "1.0 .0 1.0"
6 B22_230_9 Ctx9 B22_230 ".0 .0 1.0"
10 305.554091000 w2 WS "B22_230"
20 305.554091000 w2 WS B22_230 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 255
255 0.000000 0 0 -1 -1
10 305.555514000 t4914 S E
10 305.714592000 t4917 S B
10 305.716484000 w5 WS "I"
13 298.024702000 w5 gf 0.000000
13 305.721607000 sched nready 41.000000
13 305.721607000 sched nsubmitted 45.000000
9 305.721607000 po p 258
10 305.722899000 w5 WS "Fi"
6 B22_233 WS B22_233 "0.000000 0.600000 0.400000"
6 B22_233_1 Ctx1 B22_233 "1.0 0.39 1.0"
6 B22_233_2 Ctx2 B22_233 ".0 1.0 .0"
6 B22_233_3 Ctx3 B22_233 "0.87 0.87 .0"
6 B22_233_4 Ctx4 B22_233 ".0 0.95 1.0"
6 B22_233_5 Ctx5 B22_233 ".0 .0 .0"
6 B22_233_6 Ctx6 B22_233 ".0 .0 0.5"
6 B22_233_7 Ctx7 B22_233 "0.41 0.41 0.41"
6 B22_233_8 Ctx8 B22_233 "1.0 .0 1.0"
6 B22_233_9 Ctx9 B22_233 ".0 .0 1.0"
10 305.725101000 w5 WS "B22_233"
20 305.725101000 w5 WS B22_233 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 258
258 0.000000 0 0 -1 -1
10 305.726503000 t4917 S E
10 305.822787000 t4916 S B
10 305.824518000 w4 WS "I"
13 298.012042000 w4 gf 0.000000
13 298.012042000 sched gft 0.000000
13 298.024702000 sched gft 0.000000
13 305.829484000 sched nready 40.000000
13 305.829484000 sched nsubmitted 44.000000
9 305.829484000 po p 257
10 305.830781000 w4 WS "Fi"
6 B22_232 WS B22_232 "0.000000 0.600000 0.400000"
6 B22_232_1 Ctx1 B22_232 "1.0 0.39 1.0"
6 B22_232_2 Ctx2 B22_232 ".0 1.0 .0"
6 B22_232_3 Ctx3 B22_232 "0.87 0.87 .0"
6 B22_232_4 Ctx4 B22_232 ".0 0.95 1.0"
6 B22_232_5 Ctx5 B22_232 ".0 .0 .0"
6 B22_232_6 Ctx6 B22_232 ".0 .0 0.5"
6 B22_232_7 Ctx7 B22_232 "0.41 0.41 0.41"
6 B22_232_8 Ctx8 B22_232 "1.0 .0 1.0"
6 B22_232_9 Ctx9 B22_232 ".0 .0 1.0"
10 305.832804000 w4 WS "B22_232"
20 305.832804000 w4 WS B22_232 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 257
257 0.000000 0 0 -1 -1
10 305.834032000 t4916 S E
10 305.944327000 t4915 S B
10 305.946377000 w3 WS "I"
13 298.246233000 w3 gf 0.000000
13 298.246233000 sched gft 0.000000
13 305.951152000 sched nready 39.000000
13 305.951152000 sched nsubmitted 43.000000
9 305.951152000 po p 250
10 305.952443000 w3 WS "Fi"
6 B22_225 WS B22_225 "0.000000 0.600000 0.400000"
6 B22_225_1 Ctx1 B22_225 "1.0 0.39 1.0"
6 B22_225_2 Ctx2 B22_225 ".0 1.0 .0"
6 B22_225_3 Ctx3 B22_225 "0.87 0.87 .0"
6 B22_225_4 Ctx4 B22_225 ".0 0.95 1.0"
6 B22_225_5 Ctx5 B22_225 ".0 .0 .0"
6 B22_225_6 Ctx6 B22_225 ".0 .0 0.5"
6 B22_225_7 Ctx7 B22_225 "0.41 0.41 0.41"
6 B22_225_8 Ctx8 B22_225 "1.0 .0 1.0"
6 B22_225_9 Ctx9 B22_225 ".0 .0 1.0"
10 305.954473000 w3 WS "B22_225"
20 305.954473000 w3 WS B22_225 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 250
250 0.000000 0 0 -1 -1
10 305.955799000 t4915 S E
10 307.031600000 t4913 S B
10 307.033307000 w1 WS "I"
13 299.337705000 w1 gf 0.000000
13 299.337705000 sched gft 0.000000
13 307.038332000 sched nready 38.000000
13 307.038332000 sched nsubmitted 42.000000
9 307.038332000 po p 260
10 307.039630000 w1 WS "Fi"
6 B22_235 WS B22_235 "0.000000 0.600000 0.400000"
6 B22_235_1 Ctx1 B22_235 "1.0 0.39 1.0"
6 B22_235_2 Ctx2 B22_235 ".0 1.0 .0"
6 B22_235_3 Ctx3 B22_235 "0.87 0.87 .0"
6 B22_235_4 Ctx4 B22_235 ".0 0.95 1.0"
6 B22_235_5 Ctx5 B22_235 ".0 .0 .0"
6 B22_235_6 Ctx6 B22_235 ".0 .0 0.5"
6 B22_235_7 Ctx7 B22_235 "0.41 0.41 0.41"
6 B22_235_8 Ctx8 B22_235 "1.0 .0 1.0"
6 B22_235_9 Ctx9 B22_235 ".0 .0 1.0"
10 307.041667000 w1 WS "B22_235"
20 307.041667000 w1 WS B22_235 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 260
260 0.000000 0 0 -1 -1
10 307.042899000 t4913 S E
10 307.885804000 t4912 S B
10 307.888288000 w0 WS "I"
13 300.160135000 w0 gf 0.000000
13 300.160135000 sched gft 0.000000
13 307.893443000 sched nready 37.000000
13 307.893443000 sched nsubmitted 41.000000
9 307.893443000 po p 253
10 307.894730000 w0 WS "Fi"
6 B22_228 WS B22_228 "0.000000 0.600000 0.400000"
6 B22_228_1 Ctx1 B22_228 "1.0 0.39 1.0"
6 B22_228_2 Ctx2 B22_228 ".0 1.0 .0"
6 B22_228_3 Ctx3 B22_228 "0.87 0.87 .0"
6 B22_228_4 Ctx4 B22_228 ".0 0.95 1.0"
6 B22_228_5 Ctx5 B22_228 ".0 .0 .0"
6 B22_228_6 Ctx6 B22_228 ".0 .0 0.5"
6 B22_228_7 Ctx7 B22_228 "0.41 0.41 0.41"
6 B22_228_8 Ctx8 B22_228 "1.0 .0 1.0"
6 B22_228_9 Ctx9 B22_228 ".0 .0 1.0"
10 307.896892000 w0 WS "B22_228"
20 307.896892000 w0 WS B22_228 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 253
253 0.000000 0 0 -1 -1
10 307.898473000 t4912 S E
10 313.369600000 t4914 S B
10 313.372589000 w2 WS "I"
13 305.544637000 w2 gf 0.000000
13 305.544637000 sched gft 0.000000
13 313.378224000 sched nready 36.000000
13 313.378224000 sched nsubmitted 40.000000
9 313.378224000 po p 261
10 313.379887000 w2 WS "Fi"
6 B22_236 WS B22_236 "0.000000 0.600000 0.400000"
6 B22_236_1 Ctx1 B22_236 "1.0 0.39 1.0"
6 B22_236_2 Ctx2 B22_236 ".0 1.0 .0"
6 B22_236_3 Ctx3 B22_236 "0.87 0.87 .0"
6 B22_236_4 Ctx4 B22_236 ".0 0.95 1.0"
6 B22_236_5 Ctx5 B22_236 ".0 .0 .0"
6 B22_236_6 Ctx6 B22_236 ".0 .0 0.5"
6 B22_236_7 Ctx7 B22_236 "0.41 0.41 0.41"
6 B22_236_8 Ctx8 B22_236 "1.0 .0 1.0"
6 B22_236_9 Ctx9 B22_236 ".0 .0 1.0"
10 313.382201000 w2 WS "B22_236"
20 313.382201000 w2 WS B22_236 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 261
261 0.000000 0 0 -1 -1
10 313.383839000 t4914 S E
10 313.406334000 t4917 S B
10 313.408845000 w5 WS "I"
13 305.716484000 w5 gf 0.000000
13 305.716484000 sched gft 0.000000
13 313.414256000 sched nready 35.000000
13 313.414256000 sched nsubmitted 39.000000
9 313.414256000 po p 264
10 313.415568000 w5 WS "Fi"
6 B22_239 WS B22_239 "0.000000 0.600000 0.400000"
6 B22_239_1 Ctx1 B22_239 "1.0 0.39 1.0"
6 B22_239_2 Ctx2 B22_239 ".0 1.0 .0"
6 B22_239_3 Ctx3 B22_239 "0.87 0.87 .0"
6 B22_239_4 Ctx4 B22_239 ".0 0.95 1.0"
6 B22_239_5 Ctx5 B22_239 ".0 .0 .0"
6 B22_239_6 Ctx6 B22_239 ".0 .0 0.5"
6 B22_239_7 Ctx7 B22_239 "0.41 0.41 0.41"
6 B22_239_8 Ctx8 B22_239 "1.0 .0 1.0"
6 B22_239_9 Ctx9 B22_239 ".0 .0 1.0"
10 313.417791000 w5 WS "B22_239"
20 313.417791000 w5 WS B22_239 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 264
264 0.000000 0 0 -1 -1
10 313.419132000 t4917 S E
10 313.493460000 t4916 S B
10 313.495244000 w4 WS "I"
13 305.824518000 w4 gf 0.000000
13 305.824518000 sched gft 0.000000
13 313.499942000 sched nready 34.000000
13 313.499942000 sched nsubmitted 38.000000
9 313.499942000 po p 263
10 313.501234000 w4 WS "Fi"
6 B22_238 WS B22_238 "0.000000 0.600000 0.400000"
6 B22_238_1 Ctx1 B22_238 "1.0 0.39 1.0"
6 B22_238_2 Ctx2 B22_238 ".0 1.0 .0"
6 B22_238_3 Ctx3 B22_238 "0.87 0.87 .0"
6 B22_238_4 Ctx4 B22_238 ".0 0.95 1.0"
6 B22_238_5 Ctx5 B22_238 ".0 .0 .0"
6 B22_238_6 Ctx6 B22_238 ".0 .0 0.5"
6 B22_238_7 Ctx7 B22_238 "0.41 0.41 0.41"
6 B22_238_8 Ctx8 B22_238 "1.0 .0 1.0"
6 B22_238_9 Ctx9 B22_238 ".0 .0 1.0"
10 313.503331000 w4 WS "B22_238"
20 313.503331000 w4 WS B22_238 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 263
263 0.000000 0 0 -1 -1
10 313.504645000 t4916 S E
10 313.632918000 t4915 S B
10 313.634539000 w3 WS "I"
13 305.946377000 w3 gf 0.000000
13 305.946377000 sched gft 0.000000
13 313.639372000 sched nready 33.000000
13 313.639372000 sched nsubmitted 37.000000
9 313.639372000 po p 256
10 313.640645000 w3 WS "Fi"
6 B22_231 WS B22_231 "0.000000 0.600000 0.400000"
6 B22_231_1 Ctx1 B22_231 "1.0 0.39 1.0"
6 B22_231_2 Ctx2 B22_231 ".0 1.0 .0"
6 B22_231_3 Ctx3 B22_231 "0.87 0.87 .0"
6 B22_231_4 Ctx4 B22_231 ".0 0.95 1.0"
6 B22_231_5 Ctx5 B22_231 ".0 .0 .0"
6 B22_231_6 Ctx6 B22_231 ".0 .0 0.5"
6 B22_231_7 Ctx7 B22_231 "0.41 0.41 0.41"
6 B22_231_8 Ctx8 B22_231 "1.0 .0 1.0"
6 B22_231_9 Ctx9 B22_231 ".0 .0 1.0"
10 313.642720000 w3 WS "B22_231"
20 313.642720000 w3 WS B22_231 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 256
256 0.000000 0 0 -1 -1
10 313.643983000 t4915 S E
10 314.713424000 t4913 S B
10 314.715185000 w1 WS "I"
13 307.033307000 w1 gf 0.000000
13 307.033307000 sched gft 0.000000
13 314.720260000 sched nready 32.000000
13 314.720260000 sched nsubmitted 36.000000
9 314.720260000 po p 266
10 314.721543000 w1 WS "Fi"
6 B22_241 WS B22_241 "0.000000 0.600000 0.400000"
6 B22_241_1 Ctx1 B22_241 "1.0 0.39 1.0"
6 B22_241_2 Ctx2 B22_241 ".0 1.0 .0"
6 B22_241_3 Ctx3 B22_241 "0.87 0.87 .0"
6 B22_241_4 Ctx4 B22_241 ".0 0.95 1.0"
6 B22_241_5 Ctx5 B22_241 ".0 .0 .0"
6 B22_241_6 Ctx6 B22_241 ".0 .0 0.5"
6 B22_241_7 Ctx7 B22_241 "0.41 0.41 0.41"
6 B22_241_8 Ctx8 B22_241 "1.0 .0 1.0"
6 B22_241_9 Ctx9 B22_241 ".0 .0 1.0"
10 314.723745000 w1 WS "B22_241"
20 314.723745000 w1 WS B22_241 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 266
266 0.000000 0 0 -1 -1
10 314.725090000 t4913 S E
10 315.594440000 t4912 S B
10 315.596750000 w0 WS "I"
13 307.888288000 w0 gf 0.000000
13 307.888288000 sched gft 0.000000
13 315.602015000 sched nready 31.000000
13 315.602015000 sched nsubmitted 35.000000
9 315.602015000 po p 259
10 315.603310000 w0 WS "Fi"
6 B22_234 WS B22_234 "0.000000 0.600000 0.400000"
6 B22_234_1 Ctx1 B22_234 "1.0 0.39 1.0"
6 B22_234_2 Ctx2 B22_234 ".0 1.0 .0"
6 B22_234_3 Ctx3 B22_234 "0.87 0.87 .0"
6 B22_234_4 Ctx4 B22_234 ".0 0.95 1.0"
6 B22_234_5 Ctx5 B22_234 ".0 .0 .0"
6 B22_234_6 Ctx6 B22_234 ".0 .0 0.5"
6 B22_234_7 Ctx7 B22_234 "0.41 0.41 0.41"
6 B22_234_8 Ctx8 B22_234 "1.0 .0 1.0"
6 B22_234_9 Ctx9 B22_234 ".0 .0 1.0"
10 315.605306000 w0 WS "B22_234"
20 315.605306000 w0 WS B22_234 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 259
259 0.000000 0 0 -1 -1
10 315.606665000 t4912 S E
10 321.076106000 t4914 S B
10 321.078017000 w2 WS "I"
13 313.372589000 w2 gf 0.000000
13 313.372589000 sched gft 0.000000
13 321.083545000 sched nready 30.000000
13 321.083545000 sched nsubmitted 34.000000
9 321.083545000 po p 267
10 321.084864000 w2 WS "Fi"
6 B22_242 WS B22_242 "0.000000 0.600000 0.400000"
6 B22_242_1 Ctx1 B22_242 "1.0 0.39 1.0"
6 B22_242_2 Ctx2 B22_242 ".0 1.0 .0"
6 B22_242_3 Ctx3 B22_242 "0.87 0.87 .0"
6 B22_242_4 Ctx4 B22_242 ".0 0.95 1.0"
6 B22_242_5 Ctx5 B22_242 ".0 .0 .0"
6 B22_242_6 Ctx6 B22_242 ".0 .0 0.5"
6 B22_242_7 Ctx7 B22_242 "0.41 0.41 0.41"
6 B22_242_8 Ctx8 B22_242 "1.0 .0 1.0"
6 B22_242_9 Ctx9 B22_242 ".0 .0 1.0"
10 321.087276000 w2 WS "B22_242"
20 321.087276000 w2 WS B22_242 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 267
267 0.000000 0 0 -1 -1
10 321.088768000 t4914 S E
10 321.095115000 t4917 S B
10 321.097163000 w5 WS "I"
13 313.408845000 w5 gf 0.000000
13 313.408845000 sched gft 0.000000
13 321.102509000 sched nready 29.000000
13 321.102509000 sched nsubmitted 33.000000
9 321.102509000 po p 270
10 321.103783000 w5 WS "Fi"
6 B22_245 WS B22_245 "0.000000 0.600000 0.400000"
6 B22_245_1 Ctx1 B22_245 "1.0 0.39 1.0"
6 B22_245_2 Ctx2 B22_245 ".0 1.0 .0"
6 B22_245_3 Ctx3 B22_245 "0.87 0.87 .0"
6 B22_245_4 Ctx4 B22_245 ".0 0.95 1.0"
6 B22_245_5 Ctx5 B22_245 ".0 .0 .0"
6 B22_245_6 Ctx6 B22_245 ".0 .0 0.5"
6 B22_245_7 Ctx7 B22_245 "0.41 0.41 0.41"
6 B22_245_8 Ctx8 B22_245 "1.0 .0 1.0"
6 B22_245_9 Ctx9 B22_245 ".0 .0 1.0"
10 321.106135000 w5 WS "B22_245"
20 321.106135000 w5 WS B22_245 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 270
270 0.000000 0 0 -1 -1
10 321.107419000 t4917 S E
10 321.158585000 t4916 S B
10 321.160269000 w4 WS "I"
13 313.495244000 w4 gf 0.000000
13 313.495244000 sched gft 0.000000
13 321.164879000 sched nready 28.000000
13 321.164879000 sched nsubmitted 32.000000
9 321.164879000 po p 269
10 321.166146000 w4 WS "Fi"
6 B22_244 WS B22_244 "0.000000 0.600000 0.400000"
6 B22_244_1 Ctx1 B22_244 "1.0 0.39 1.0"
6 B22_244_2 Ctx2 B22_244 ".0 1.0 .0"
6 B22_244_3 Ctx3 B22_244 "0.87 0.87 .0"
6 B22_244_4 Ctx4 B22_244 ".0 0.95 1.0"
6 B22_244_5 Ctx5 B22_244 ".0 .0 .0"
6 B22_244_6 Ctx6 B22_244 ".0 .0 0.5"
6 B22_244_7 Ctx7 B22_244 "0.41 0.41 0.41"
6 B22_244_8 Ctx8 B22_244 "1.0 .0 1.0"
6 B22_244_9 Ctx9 B22_244 ".0 .0 1.0"
10 321.168609000 w4 WS "B22_244"
20 321.168609000 w4 WS B22_244 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 269
269 0.000000 0 0 -1 -1
10 321.169915000 t4916 S E
10 321.324187000 t4915 S B
10 321.326020000 w3 WS "I"
13 313.634539000 w3 gf 0.000000
13 313.634539000 sched gft 0.000000
13 321.331039000 sched nready 27.000000
13 321.331039000 sched nsubmitted 31.000000
9 321.331039000 po p 262
10 321.332340000 w3 WS "Fi"
6 B22_237 WS B22_237 "0.000000 0.600000 0.400000"
6 B22_237_1 Ctx1 B22_237 "1.0 0.39 1.0"
6 B22_237_2 Ctx2 B22_237 ".0 1.0 .0"
6 B22_237_3 Ctx3 B22_237 "0.87 0.87 .0"
6 B22_237_4 Ctx4 B22_237 ".0 0.95 1.0"
6 B22_237_5 Ctx5 B22_237 ".0 .0 .0"
6 B22_237_6 Ctx6 B22_237 ".0 .0 0.5"
6 B22_237_7 Ctx7 B22_237 "0.41 0.41 0.41"
6 B22_237_8 Ctx8 B22_237 "1.0 .0 1.0"
6 B22_237_9 Ctx9 B22_237 ".0 .0 1.0"
10 321.334272000 w3 WS "B22_237"
20 321.334272000 w3 WS B22_237 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 262
262 0.000000 0 0 -1 -1
10 321.335533000 t4915 S E
10 322.416527000 t4913 S B
10 322.418856000 w1 WS "I"
13 314.715185000 w1 gf 0.000000
13 314.715185000 sched gft 0.000000
13 322.423572000 sched nready 26.000000
13 322.423572000 sched nsubmitted 30.000000
9 322.423572000 po p 272
10 322.424899000 w1 WS "Fi"
6 B22_247 WS B22_247 "0.000000 0.600000 0.400000"
6 B22_247_1 Ctx1 B22_247 "1.0 0.39 1.0"
6 B22_247_2 Ctx2 B22_247 ".0 1.0 .0"
6 B22_247_3 Ctx3 B22_247 "0.87 0.87 .0"
6 B22_247_4 Ctx4 B22_247 ".0 0.95 1.0"
6 B22_247_5 Ctx5 B22_247 ".0 .0 .0"
6 B22_247_6 Ctx6 B22_247 ".0 .0 0.5"
6 B22_247_7 Ctx7 B22_247 "0.41 0.41 0.41"
6 B22_247_8 Ctx8 B22_247 "1.0 .0 1.0"
6 B22_247_9 Ctx9 B22_247 ".0 .0 1.0"
10 322.427023000 w1 WS "B22_247"
20 322.427023000 w1 WS B22_247 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 272
272 0.000000 0 0 -1 -1
10 322.428309000 t4913 S E
10 323.315167000 t4912 S B
10 323.317684000 w0 WS "I"
13 315.596750000 w0 gf 0.000000
13 315.596750000 sched gft 0.000000
13 323.322919000 sched nready 25.000000
13 323.322919000 sched nsubmitted 29.000000
9 323.322919000 po p 265
10 323.324219000 w0 WS "Fi"
6 B22_240 WS B22_240 "0.000000 0.600000 0.400000"
6 B22_240_1 Ctx1 B22_240 "1.0 0.39 1.0"
6 B22_240_2 Ctx2 B22_240 ".0 1.0 .0"
6 B22_240_3 Ctx3 B22_240 "0.87 0.87 .0"
6 B22_240_4 Ctx4 B22_240 ".0 0.95 1.0"
6 B22_240_5 Ctx5 B22_240 ".0 .0 .0"
6 B22_240_6 Ctx6 B22_240 ".0 .0 0.5"
6 B22_240_7 Ctx7 B22_240 "0.41 0.41 0.41"
6 B22_240_8 Ctx8 B22_240 "1.0 .0 1.0"
6 B22_240_9 Ctx9 B22_240 ".0 .0 1.0"
10 323.326615000 w0 WS "B22_240"
20 323.326615000 w0 WS B22_240 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 265
265 0.000000 0 0 -1 -1
10 323.327934000 t4912 S E
10 328.760121000 t4914 S B
10 328.762599000 w2 WS "I"
13 321.078017000 w2 gf 0.000000
13 321.078017000 sched gft 0.000000
13 328.768189000 sched nready 24.000000
13 328.768189000 sched nsubmitted 28.000000
9 328.768189000 po p 273
10 328.769584000 w2 WS "Fi"
6 B22_248 WS B22_248 "0.000000 0.600000 0.400000"
6 B22_248_1 Ctx1 B22_248 "1.0 0.39 1.0"
6 B22_248_2 Ctx2 B22_248 ".0 1.0 .0"
6 B22_248_3 Ctx3 B22_248 "0.87 0.87 .0"
6 B22_248_4 Ctx4 B22_248 ".0 0.95 1.0"
6 B22_248_5 Ctx5 B22_248 ".0 .0 .0"
6 B22_248_6 Ctx6 B22_248 ".0 .0 0.5"
6 B22_248_7 Ctx7 B22_248 "0.41 0.41 0.41"
6 B22_248_8 Ctx8 B22_248 "1.0 .0 1.0"
6 B22_248_9 Ctx9 B22_248 ".0 .0 1.0"
10 328.771907000 w2 WS "B22_248"
20 328.771907000 w2 WS B22_248 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 273
273 0.000000 0 0 -1 -1
10 328.773939000 t4914 S E
10 328.797897000 t4917 S B
10 328.799966000 w5 WS "I"
13 321.097163000 w5 gf 0.000000
13 321.097163000 sched gft 0.000000
13 328.805150000 sched nready 23.000000
13 328.805150000 sched nsubmitted 27.000000
9 328.805150000 po p 276
10 328.806488000 w5 WS "Fi"
6 B22_251 WS B22_251 "0.000000 0.600000 0.400000"
6 B22_251_1 Ctx1 B22_251 "1.0 0.39 1.0"
6 B22_251_2 Ctx2 B22_251 ".0 1.0 .0"
6 B22_251_3 Ctx3 B22_251 "0.87 0.87 .0"
6 B22_251_4 Ctx4 B22_251 ".0 0.95 1.0"
6 B22_251_5 Ctx5 B22_251 ".0 .0 .0"
6 B22_251_6 Ctx6 B22_251 ".0 .0 0.5"
6 B22_251_7 Ctx7 B22_251 "0.41 0.41 0.41"
6 B22_251_8 Ctx8 B22_251 "1.0 .0 1.0"
6 B22_251_9 Ctx9 B22_251 ".0 .0 1.0"
10 328.808640000 w5 WS "B22_251"
20 328.808640000 w5 WS B22_251 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 276
276 0.000000 0 0 -1 -1
10 328.809889000 t4917 S E
10 328.827270000 t4916 S B
10 328.829003000 w4 WS "I"
13 321.160269000 w4 gf 0.000000
13 321.160269000 sched gft 0.000000
13 328.834102000 sched nready 22.000000
13 328.834102000 sched nsubmitted 26.000000
9 328.834102000 po p 275
10 328.835677000 w4 WS "Fi"
6 B22_250 WS B22_250 "0.000000 0.600000 0.400000"
6 B22_250_1 Ctx1 B22_250 "1.0 0.39 1.0"
6 B22_250_2 Ctx2 B22_250 ".0 1.0 .0"
6 B22_250_3 Ctx3 B22_250 "0.87 0.87 .0"
6 B22_250_4 Ctx4 B22_250 ".0 0.95 1.0"
6 B22_250_5 Ctx5 B22_250 ".0 .0 .0"
6 B22_250_6 Ctx6 B22_250 ".0 .0 0.5"
6 B22_250_7 Ctx7 B22_250 "0.41 0.41 0.41"
6 B22_250_8 Ctx8 B22_250 "1.0 .0 1.0"
6 B22_250_9 Ctx9 B22_250 ".0 .0 1.0"
10 328.838034000 w4 WS "B22_250"
20 328.838034000 w4 WS B22_250 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 275
275 0.000000 0 0 -1 -1
10 328.839298000 t4916 S E
10 329.016302000 t4915 S B
10 329.018371000 w3 WS "I"
13 321.326020000 w3 gf 0.000000
13 321.326020000 sched gft 0.000000
13 329.023272000 sched nready 21.000000
13 329.023272000 sched nsubmitted 25.000000
9 329.023272000 po p 268
10 329.024881000 w3 WS "Fi"
6 B22_243 WS B22_243 "0.000000 0.600000 0.400000"
6 B22_243_1 Ctx1 B22_243 "1.0 0.39 1.0"
6 B22_243_2 Ctx2 B22_243 ".0 1.0 .0"
6 B22_243_3 Ctx3 B22_243 "0.87 0.87 .0"
6 B22_243_4 Ctx4 B22_243 ".0 0.95 1.0"
6 B22_243_5 Ctx5 B22_243 ".0 .0 .0"
6 B22_243_6 Ctx6 B22_243 ".0 .0 0.5"
6 B22_243_7 Ctx7 B22_243 "0.41 0.41 0.41"
6 B22_243_8 Ctx8 B22_243 "1.0 .0 1.0"
6 B22_243_9 Ctx9 B22_243 ".0 .0 1.0"
10 329.026928000 w3 WS "B22_243"
20 329.026928000 w3 WS B22_243 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 268
268 0.000000 0 0 -1 -1
10 329.028239000 t4915 S E
10 330.128757000 t4913 S B
10 330.130547000 w1 WS "I"
13 322.418856000 w1 gf 0.000000
13 322.418856000 sched gft 0.000000
13 330.135242000 sched nready 20.000000
13 330.135242000 sched nsubmitted 24.000000
9 330.135242000 po p 278
10 330.136546000 w1 WS "Fi"
6 B22_253 WS B22_253 "0.000000 0.600000 0.400000"
6 B22_253_1 Ctx1 B22_253 "1.0 0.39 1.0"
6 B22_253_2 Ctx2 B22_253 ".0 1.0 .0"
6 B22_253_3 Ctx3 B22_253 "0.87 0.87 .0"
6 B22_253_4 Ctx4 B22_253 ".0 0.95 1.0"
6 B22_253_5 Ctx5 B22_253 ".0 .0 .0"
6 B22_253_6 Ctx6 B22_253 ".0 .0 0.5"
6 B22_253_7 Ctx7 B22_253 "0.41 0.41 0.41"
6 B22_253_8 Ctx8 B22_253 "1.0 .0 1.0"
6 B22_253_9 Ctx9 B22_253 ".0 .0 1.0"
10 330.138627000 w1 WS "B22_253"
20 330.138627000 w1 WS B22_253 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 278
278 0.000000 0 0 -1 -1
10 330.139933000 t4913 S E
10 331.022835000 t4912 S B
10 331.025231000 w0 WS "I"
13 323.317684000 w0 gf 0.000000
13 323.317684000 sched gft 0.000000
13 331.030524000 sched nready 19.000000
13 331.030524000 sched nsubmitted 23.000000
9 331.030524000 po p 271
10 331.031866000 w0 WS "Fi"
6 B22_246 WS B22_246 "0.000000 0.600000 0.400000"
6 B22_246_1 Ctx1 B22_246 "1.0 0.39 1.0"
6 B22_246_2 Ctx2 B22_246 ".0 1.0 .0"
6 B22_246_3 Ctx3 B22_246 "0.87 0.87 .0"
6 B22_246_4 Ctx4 B22_246 ".0 0.95 1.0"
6 B22_246_5 Ctx5 B22_246 ".0 .0 .0"
6 B22_246_6 Ctx6 B22_246 ".0 .0 0.5"
6 B22_246_7 Ctx7 B22_246 "0.41 0.41 0.41"
6 B22_246_8 Ctx8 B22_246 "1.0 .0 1.0"
6 B22_246_9 Ctx9 B22_246 ".0 .0 1.0"
10 331.034142000 w0 WS "B22_246"
20 331.034142000 w0 WS B22_246 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 271
271 0.000000 0 0 -1 -1
10 331.035467000 t4912 S E
10 336.458758000 t4914 S B
10 336.461006000 w2 WS "I"
13 328.762599000 w2 gf 0.000000
13 328.762599000 sched gft 0.000000
13 336.466829000 sched nready 18.000000
13 336.466829000 sched nsubmitted 22.000000
9 336.466829000 po p 279
10 336.468119000 w2 WS "Fi"
6 B22_254 WS B22_254 "0.000000 0.600000 0.400000"
6 B22_254_1 Ctx1 B22_254 "1.0 0.39 1.0"
6 B22_254_2 Ctx2 B22_254 ".0 1.0 .0"
6 B22_254_3 Ctx3 B22_254 "0.87 0.87 .0"
6 B22_254_4 Ctx4 B22_254 ".0 0.95 1.0"
6 B22_254_5 Ctx5 B22_254 ".0 .0 .0"
6 B22_254_6 Ctx6 B22_254 ".0 .0 0.5"
6 B22_254_7 Ctx7 B22_254 "0.41 0.41 0.41"
6 B22_254_8 Ctx8 B22_254 "1.0 .0 1.0"
6 B22_254_9 Ctx9 B22_254 ".0 .0 1.0"
10 336.470440000 w2 WS "B22_254"
20 336.470440000 w2 WS B22_254 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 279
279 0.000000 0 0 -1 -1
10 336.471972000 t4914 S E
10 336.495248000 t4917 S B
10 336.497104000 w5 WS "I"
13 328.799966000 w5 gf 0.000000
13 328.799966000 sched gft 0.000000
13 336.502300000 sched nready 17.000000
13 336.502300000 sched nsubmitted 21.000000
9 336.502300000 po p 282
10 336.502728000 t4916 S B
10 336.503741000 w5 WS "Fi"
10 336.504567000 w4 WS "I"
13 328.829003000 w4 gf 0.000000
13 328.829003000 sched gft 0.000000
6 B23_aa WS B23_aa "0.000000 0.600000 0.400000"
6 B23_aa_1 Ctx1 B23_aa "1.0 0.39 1.0"
6 B23_aa_2 Ctx2 B23_aa ".0 1.0 .0"
6 B23_aa_3 Ctx3 B23_aa "0.87 0.87 .0"
6 B23_aa_4 Ctx4 B23_aa ".0 0.95 1.0"
6 B23_aa_5 Ctx5 B23_aa ".0 .0 .0"
6 B23_aa_6 Ctx6 B23_aa ".0 .0 0.5"
6 B23_aa_7 Ctx7 B23_aa "0.41 0.41 0.41"
6 B23_aa_8 Ctx8 B23_aa "1.0 .0 1.0"
6 B23_aa_9 Ctx9 B23_aa ".0 .0 1.0"
10 336.506601000 w5 WS "B23_aa"
20 336.506601000 w5 WS B23_aa 196712
M1x8192x8_M2x8194x8_M3x3x8 6ccb5ec1 0000000000000000 282
282 0.000000 0 0 -1 -1
10 336.508178000 t4917 S E
13 336.509980000 sched nready 16.000000
13 336.509980000 sched nsubmitted 20.000000
9 336.509980000 po p 281
10 336.511342000 w4 WS "Fi"
6 B23_ea WS B23_ea "0.000000 0.600000 0.400000"
6 B23_ea_1 Ctx1 B23_ea "1.0 0.39 1.0"
6 B23_ea_2 Ctx2 B23_ea ".0 1.0 .0"
6 B23_ea_3 Ctx3 B23_ea "0.87 0.87 .0"
6 B23_ea_4 Ctx4 B23_ea ".0 0.95 1.0"
6 B23_ea_5 Ctx5 B23_ea ".0 .0 .0"
6 B23_ea_6 Ctx6 B23_ea ".0 .0 0.5"
6 B23_ea_7 Ctx7 B23_ea "0.41 0.41 0.41"
6 B23_ea_8 Ctx8 B23_ea "1.0 .0 1.0"
6 B23_ea_9 Ctx9 B23_ea ".0 .0 1.0"
10 336.513927000 w4 WS "B23_ea"
20 336.513927000 w4 WS B23_ea 131160
M1x8192x8_M1x8194x8_M3x3x8 168cba74 0000000000000000 281
281 0.000000 0 0 -1 -1
10 336.515443000 t4916 S E
10 336.632811000 t4916 S B
10 336.633992000 w4 WS "I"
13 336.504567000 w4 gf 0.000000
13 336.638869000 sched nready 15.000000
13 336.638869000 sched nsubmitted 19.000000
9 336.638869000 po p 289
10 336.640284000 w4 WS "Fi"
6 B32_so WS B32_so "0.000000 0.600000 0.400000"
6 B32_so_1 Ctx1 B32_so "1.0 0.39 1.0"
6 B32_so_2 Ctx2 B32_so ".0 1.0 .0"
6 B32_so_3 Ctx3 B32_so "0.87 0.87 .0"
6 B32_so_4 Ctx4 B32_so ".0 0.95 1.0"
6 B32_so_5 Ctx5 B32_so ".0 .0 .0"
6 B32_so_6 Ctx6 B32_so ".0 .0 0.5"
6 B32_so_7 Ctx7 B32_so "0.41 0.41 0.41"
6 B32_so_8 Ctx8 B32_so "1.0 .0 1.0"
6 B32_so_9 Ctx9 B32_so ".0 .0 1.0"
10 336.642651000 w4 WS "B32_so"
20 336.642651000 w4 WS B32_so 131160
M8192x1x8_M8194x1x8_M3x3x8 a5e481fd 0000000000000000 289
289 0.000000 0 0 -1 -1
10 336.643754000 t4916 S E
10 336.715765000 t4915 S B
10 336.717666000 w3 WS "I"
13 329.018371000 w3 gf 0.000000
13 329.018371000 sched gft 0.000000
13 336.723058000 sched nready 14.000000
13 336.723058000 sched nsubmitted 18.000000
9 336.723058000 po p 274
10 336.724614000 w3 WS "Fi"
6 B22_249 WS B22_249 "0.000000 0.600000 0.400000"
6 B22_249_1 Ctx1 B22_249 "1.0 0.39 1.0"
6 B22_249_2 Ctx2 B22_249 ".0 1.0 .0"
6 B22_249_3 Ctx3 B22_249 "0.87 0.87 .0"
6 B22_249_4 Ctx4 B22_249 ".0 0.95 1.0"
6 B22_249_5 Ctx5 B22_249 ".0 .0 .0"
6 B22_249_6 Ctx6 B22_249 ".0 .0 0.5"
6 B22_249_7 Ctx7 B22_249 "0.41 0.41 0.41"
6 B22_249_8 Ctx8 B22_249 "1.0 .0 1.0"
6 B22_249_9 Ctx9 B22_249 ".0 .0 1.0"
10 336.726600000 w3 WS "B22_249"
20 336.726600000 w3 WS B22_249 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 274
274 0.000000 0 0 -1 -1
10 336.727906000 t4915 S E
10 336.742219000 t4916 S B
10 336.743310000 w4 WS "I"
13 336.633992000 w4 gf 0.000000
13 336.747788000 sched nready 13.000000
13 336.747788000 sched nsubmitted 17.000000
9 336.747788000 po p 13
10 336.749170000 w4 WS "Fi"
6 B11 WS B11 "0.000000 0.600000 0.400000"
6 B11_1 Ctx1 B11 "1.0 0.39 1.0"
6 B11_2 Ctx2 B11 ".0 1.0 .0"
6 B11_3 Ctx3 B11 "0.87 0.87 .0"
6 B11_4 Ctx4 B11 ".0 0.95 1.0"
6 B11_5 Ctx5 B11 ".0 .0 .0"
6 B11_6 Ctx6 B11 ".0 .0 0.5"
6 B11_7 Ctx7 B11 "0.41 0.41 0.41"
6 B11_8 Ctx8 B11 "1.0 .0 1.0"
6 B11_9 Ctx9 B11 ".0 .0 1.0"
10 336.752069000 w4 WS "B11"
20 336.752069000 w4 WS B11 40
M1x1x8_M1x1x8_M1x1x8_M1x1x8_M1x1x8 ac71c29d 0000000000000000
13 13 0.000000 0 0 -1 -1
10 336.753767000 t4916 S E
10 336.754396000 t4916 S B
10 336.755267000 w4 WS "I"
13 336.743310000 w4 gf 0.000000
13 336.760024000 sched nready 12.000000
13 336.760024000 sched nsubmitted 16.000000
9 336.760024000 po p 24
10 336.761391000 w4 WS "Fi"
10 336.763579000 w4 WS "B12"
20 336.763579000 w4 WS B12 196608
M1x8192x8_M1x8192x8_M1x8192x8 5511c035 0000000000000000 24
10 336.764616000 t4916 S E
10 337.034559000 t4916 S B
10 337.037116000 w4 WS "I"
13 336.755267000 w4 gf 0.000000
13 336.763579000 w4 gf 0.000000
18 337.044100000 WSL p 0 w5 steal_6
19 337.044100001 WSL p 0 w4 steal_6
13 337.044642000 sched nready 11.000000
13 337.044642000 sched nsubmitted 15.000000
9 337.044642000 po p 290
10 337.046109000 w4 WS "Fi"
6 B32_aa WS B32_aa "0.000000 0.600000 0.400000"
6 B32_aa_1 Ctx1 B32_aa "1.0 0.39 1.0"
6 B32_aa_2 Ctx2 B32_aa ".0 1.0 .0"
6 B32_aa_3 Ctx3 B32_aa "0.87 0.87 .0"
6 B32_aa_4 Ctx4 B32_aa ".0 0.95 1.0"
6 B32_aa_5 Ctx5 B32_aa ".0 .0 .0"
6 B32_aa_6 Ctx6 B32_aa ".0 .0 0.5"
6 B32_aa_7 Ctx7 B32_aa "0.41 0.41 0.41"
6 B32_aa_8 Ctx8 B32_aa "1.0 .0 1.0"
6 B32_aa_9 Ctx9 B32_aa ".0 .0 1.0"
10 337.048205000 w4 WS "B32_aa"
20 337.048205000 w4 WS B32_aa 196712
M8192x1x8_M8194x2x8_M3x3x8 5212cc39 0000000000000000 290
290 0.000000 0 0 -1 -1
10 337.049382000 t4916 S E
10 337.233041000 t4916 S B
10 337.234663000 w4 WS "I"
13 337.037116000 w4 gf 0.000000
13 337.238681000 sched nready 12.000000
9 337.238681000 pu p 291
13 337.242917000 sched nready 11.000000
13 337.242917000 sched nsubmitted 14.000000
9 337.242917000 po p 291
10 337.244495000 w4 WS "Fi"
10 337.246517000 w4 WS "B12"
20 337.246517000 w4 WS B12 196608
M8192x1x8_M8192x1x8_M8192x1x8 ec48135f 0000000000000000 291
291 0.000000 0 0 -1 -1
10 337.247737000 t4916 S E
10 337.269556000 t4916 S B
10 337.270648000 w4 WS "I"
13 337.234663000 w4 gf 0.000000
18 337.274796000 WSL p 0 w5 steal_7
19 337.274796001 WSL p 0 w4 steal_7
13 337.274927000 sched nready 10.000000
13 337.274927000 sched nsubmitted 13.000000
9 337.274927000 po p 21
10 337.276270000 w4 WS "Fi"
6 B13 WS B13 "0.000000 0.600000 0.400000"
6 B13_1 Ctx1 B13 "1.0 0.39 1.0"
6 B13_2 Ctx2 B13 ".0 1.0 .0"
6 B13_3 Ctx3 B13 "0.87 0.87 .0"
6 B13_4 Ctx4 B13 ".0 0.95 1.0"
6 B13_5 Ctx5 B13 ".0 .0 .0"
6 B13_6 Ctx6 B13 ".0 .0 0.5"
6 B13_7 Ctx7 B13 "0.41 0.41 0.41"
6 B13_8 Ctx8 B13 "1.0 .0 1.0"
6 B13_9 Ctx9 B13 ".0 .0 1.0"
10 337.279077000 w4 WS "B13"
20 337.279077000 w4 WS B13 40
21 21 0.000000 0 0 -1 -1
10 337.280704000 t4916 S E
10 337.281329000 t4916 S B
10 337.282192000 w4 WS "I"
13 337.270648000 w4 gf 0.000000
18 337.286742000 WSL p 0 w0 steal_8
19 337.286742001 WSL p 0 w4 steal_8
13 337.286908000 sched nready 9.000000
13 337.286908000 sched nsubmitted 12.000000
9 337.286908000 po p 277
10 337.288195000 w4 WS "Fi"
6 B22_252 WS B22_252 "0.000000 0.600000 0.400000"
6 B22_252_1 Ctx1 B22_252 "1.0 0.39 1.0"
6 B22_252_2 Ctx2 B22_252 ".0 1.0 .0"
6 B22_252_3 Ctx3 B22_252 "0.87 0.87 .0"
6 B22_252_4 Ctx4 B22_252 ".0 0.95 1.0"
6 B22_252_5 Ctx5 B22_252 ".0 .0 .0"
6 B22_252_6 Ctx6 B22_252 ".0 .0 0.5"
6 B22_252_7 Ctx7 B22_252 "0.41 0.41 0.41"
6 B22_252_8 Ctx8 B22_252 "1.0 .0 1.0"
6 B22_252_9 Ctx9 B22_252 ".0 .0 1.0"
10 337.290204000 w4 WS "B22_252"
20 337.290204000 w4 WS B22_252 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 277
277 0.000000 0 0 -1 -1
10 337.291269000 t4916 S E
10 337.447757000 t4917 S B
10 337.449860000 w5 WS "I"
13 336.497104000 w5 gf 0.000000
13 337.453914000 sched nready 10.000000
9 337.453914000 pu p 283
13 337.458128000 sched nready 9.000000
13 337.458128000 sched nsubmitted 11.000000
9 337.458128000 po p 283
10 337.459347000 w5 WS "Fi"
10 337.461304000 w5 WS "B12"
20 337.461304000 w5 WS B12 196608
M1x8192x8_M1x8192x8_M1x8192x8 5511c035 0000000000000000 283
283 0.000000 0 0 -1 -1
10 337.462696000 t4917 S E
10 337.651496000 t4917 S B
10 337.653271000 w5 WS "I"
13 337.449860000 w5 gf 0.000000
18 337.658310000 WSL p 0 w0 steal_9
19 337.658310001 WSL p 0 w5 steal_9
13 337.658508000 sched nready 8.000000
13 337.658508000 sched nsubmitted 10.000000
9 337.658508000 po p 284
10 337.659805000 w5 WS "Fi"
6 B31_we WS B31_we "0.000000 0.600000 0.400000"
6 B31_we_1 Ctx1 B31_we "1.0 0.39 1.0"
6 B31_we_2 Ctx2 B31_we ".0 1.0 .0"
6 B31_we_3 Ctx3 B31_we "0.87 0.87 .0"
6 B31_we_4 Ctx4 B31_we ".0 0.95 1.0"
6 B31_we_5 Ctx5 B31_we ".0 .0 .0"
6 B31_we_6 Ctx6 B31_we ".0 .0 0.5"
6 B31_we_7 Ctx7 B31_we "0.41 0.41 0.41"
6 B31_we_8 Ctx8 B31_we "1.0 .0 1.0"
6 B31_we_9 Ctx9 B31_we ".0 .0 1.0"
10 337.661797000 w5 WS "B31_we"
20 337.661797000 w5 WS B31_we 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 284 284
0.000000 0 0 -1 -1
10 337.662948000 t4917 S E
10 337.663723000 t4917 S B
10 337.664543000 w5 WS "I"
13 337.653271000 w5 gf 0.000000
18 337.669210000 WSL p 0 w0 steal_10
19 337.669210001 WSL p 0 w5 steal_10
13 337.669356000 sched nready 7.000000
13 337.669356000 sched nsubmitted 9.000000
9 337.669356000 po p 292
10 337.670680000 w5 WS "Fi"
6 B33_ea WS B33_ea "0.000000 0.600000 0.400000"
6 B33_ea_1 Ctx1 B33_ea "1.0 0.39 1.0"
6 B33_ea_2 Ctx2 B33_ea ".0 1.0 .0"
6 B33_ea_3 Ctx3 B33_ea "0.87 0.87 .0"
6 B33_ea_4 Ctx4 B33_ea ".0 0.95 1.0"
6 B33_ea_5 Ctx5 B33_ea ".0 .0 .0"
6 B33_ea_6 Ctx6 B33_ea ".0 .0 0.5"
6 B33_ea_7 Ctx7 B33_ea "0.41 0.41 0.41"
6 B33_ea_8 Ctx8 B33_ea "1.0 .0 1.0"
6 B33_ea_9 Ctx9 B33_ea ".0 .0 1.0"
10 337.673092000 w5 WS "B33_ea"
20 337.673092000 w5 WS B33_ea 65632
M1x1x8_M1x8194x8_M3x3x8 f0de01d7 0000000000000000 292 292
0.000000 0 0 -1 -1
10 337.674137000 t4917 S E
10 337.674811000 t4917 S B
10 337.675636000 w5 WS "I"
13 337.664543000 w5 gf 0.000000
13 337.673092000 w5 gf 0.000000
18 337.680004000 WSL p 0 w1 steal_11
19 337.680004001 WSL p 0 w5 steal_11
13 337.680151000 sched nready 6.000000
13 337.680151000 sched nsubmitted 8.000000
9 337.680151000 po p 285
10 337.681426000 w5 WS "Fi"
6 B31_sw WS B31_sw "0.000000 0.600000 0.400000"
6 B31_sw_1 Ctx1 B31_sw "1.0 0.39 1.0"
6 B31_sw_2 Ctx2 B31_sw ".0 1.0 .0"
6 B31_sw_3 Ctx3 B31_sw "0.87 0.87 .0"
6 B31_sw_4 Ctx4 B31_sw ".0 0.95 1.0"
6 B31_sw_5 Ctx5 B31_sw ".0 .0 .0"
6 B31_sw_6 Ctx6 B31_sw ".0 .0 0.5"
6 B31_sw_7 Ctx7 B31_sw "0.41 0.41 0.41"
6 B31_sw_8 Ctx8 B31_sw "1.0 .0 1.0"
6 B31_sw_9 Ctx9 B31_sw ".0 .0 1.0"
10 337.683406000 w5 WS "B31_sw"
20 337.683406000 w5 WS B31_sw 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 285 285 0.000000 0
0 -1 -1
10 337.684472000 t4917 S E
10 337.685049000 t4917 S B
10 337.685868000 w5 WS "I"
13 337.675636000 w5 gf 0.000000
13 337.683406000 w5 gf 0.000000
18 337.689959000 WSL p 0 w1 steal_12
19 337.689959001 WSL p 0 w5 steal_12
13 337.690045000 sched nready 5.000000
13 337.690045000 sched nsubmitted 7.000000
9 337.690045000 po p 293
10 337.691337000 w5 WS "Fi"
6 B33_so WS B33_so "0.000000 0.600000 0.400000"
6 B33_so_1 Ctx1 B33_so "1.0 0.39 1.0"
6 B33_so_2 Ctx2 B33_so ".0 1.0 .0"
6 B33_so_3 Ctx3 B33_so "0.87 0.87 .0"
6 B33_so_4 Ctx4 B33_so ".0 0.95 1.0"
6 B33_so_5 Ctx5 B33_so ".0 .0 .0"
6 B33_so_6 Ctx6 B33_so ".0 .0 0.5"
6 B33_so_7 Ctx7 B33_so "0.41 0.41 0.41"
6 B33_so_8 Ctx8 B33_so "1.0 .0 1.0"
6 B33_so_9 Ctx9 B33_so ".0 .0 1.0"
10 337.693285000 w5 WS "B33_so"
20 337.693285000 w5 WS B33_so 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 293 293
0.000000 0 0 -1 -1
10 337.694320000 t4917 S E
10 337.694936000 t4917 S B
10 337.695751000 w5 WS "I"
13 337.685868000 w5 gf 0.000000
13 337.693285000 w5 gf 0.000000
18 337.699827000 WSL p 0 w2 steal_13
19 337.699827001 WSL p 0 w5 steal_13
13 337.699919000 sched nready 4.000000
13 337.699919000 sched nsubmitted 6.000000
9 337.699919000 po p 286
10 337.701221000 w5 WS "Fi"
6 B31_so WS B31_so "0.000000 0.600000 0.400000"
6 B31_so_1 Ctx1 B31_so "1.0 0.39 1.0"
6 B31_so_2 Ctx2 B31_so ".0 1.0 .0"
6 B31_so_3 Ctx3 B31_so "0.87 0.87 .0"
6 B31_so_4 Ctx4 B31_so ".0 0.95 1.0"
6 B31_so_5 Ctx5 B31_so ".0 .0 .0"
6 B31_so_6 Ctx6 B31_so ".0 .0 0.5"
6 B31_so_7 Ctx7 B31_so "0.41 0.41 0.41"
6 B31_so_8 Ctx8 B31_so "1.0 .0 1.0"
6 B31_so_9 Ctx9 B31_so ".0 .0 1.0"
10 337.703033000 w5 WS "B31_so"
20 337.703033000 w5 WS B31_so 65632
M1x1x8_M8194x1x8_M3x3x8 f907178d 0000000000000000 286 286
0.000000 0 0 -1 -1
10 337.704027000 t4917 S E
10 337.704642000 t4917 S B
10 337.705464000 w5 WS "I"
13 337.695751000 w5 gf 0.000000
13 337.703033000 w5 gf 0.000000
18 337.709356000 WSL p 0 w2 steal_14
19 337.709356001 WSL p 0 w5 steal_14
13 337.709436000 sched nready 3.000000
13 337.709436000 sched nsubmitted 5.000000
9 337.709436000 po p 294
10 337.710877000 w5 WS "Fi"
6 B33_se WS B33_se "0.000000 0.600000 0.400000"
6 B33_se_1 Ctx1 B33_se "1.0 0.39 1.0"
6 B33_se_2 Ctx2 B33_se ".0 1.0 .0"
6 B33_se_3 Ctx3 B33_se "0.87 0.87 .0"
6 B33_se_4 Ctx4 B33_se ".0 0.95 1.0"
6 B33_se_5 Ctx5 B33_se ".0 .0 .0"
6 B33_se_6 Ctx6 B33_se ".0 .0 0.5"
6 B33_se_7 Ctx7 B33_se "0.41 0.41 0.41"
6 B33_se_8 Ctx8 B33_se "1.0 .0 1.0"
6 B33_se_9 Ctx9 B33_se ".0 .0 1.0"
10 337.712777000 w5 WS "B33_se"
20 337.712777000 w5 WS B33_se 88 M1x1x8_M1x1x8_M3x3x8
6f633132 0000000000000000 294 294 0.000000 0
0 -1 -1
10 337.713768000 t4917 S E
10 337.714420000 t4917 S B
10 337.715220000 w5 WS "I"
13 337.705464000 w5 gf 0.000000
13 337.712777000 w5 gf 0.000000
18 337.719173000 WSL p 0 w3 steal_15
19 337.719173001 WSL p 0 w5 steal_15
13 337.719254000 sched nready 2.000000
13 337.719254000 sched nsubmitted 4.000000
9 337.719254000 po p 280
10 337.720529000 w5 WS "Fi"
6 B22_255 WS B22_255 "0.000000 0.600000 0.400000"
6 B22_255_1 Ctx1 B22_255 "1.0 0.39 1.0"
6 B22_255_2 Ctx2 B22_255 ".0 1.0 .0"
6 B22_255_3 Ctx3 B22_255 "0.87 0.87 .0"
6 B22_255_4 Ctx4 B22_255 ".0 0.95 1.0"
6 B22_255_5 Ctx5 B22_255 ".0 .0 .0"
6 B22_255_6 Ctx6 B22_255 ".0 .0 0.5"
6 B22_255_7 Ctx7 B22_255 "0.41 0.41 0.41"
6 B22_255_8 Ctx8 B22_255 "1.0 .0 1.0"
6 B22_255_9 Ctx9 B22_255 ".0 .0 1.0"
10 337.722540000 w5 WS "B22_255"
20 337.722540000 w5 WS B22_255 4210792
M512x512x8_M514x514x8_M3x3x8 6261aa4d 0000000000000000 280
280 0.000000 0 0 -1 -1
10 337.723592000 t4917 S E
10 337.820694000 t4913 S B
10 337.822836000 w1 WS "I"
13 330.130547000 w1 gf 0.000000
13 330.130547000 sched gft 0.000000
18 337.827929000 WSL p 0 w3 steal_16
19 337.827929001 WSL p 0 w1 steal_16
13 337.828176000 sched nready 1.000000
13 337.828176000 sched nsubmitted 3.000000
9 337.828176000 po p 287
10 337.829544000 w1 WS "Fi"
6 B31_aa WS B31_aa "0.000000 0.600000 0.400000"
6 B31_aa_1 Ctx1 B31_aa "1.0 0.39 1.0"
6 B31_aa_2 Ctx2 B31_aa ".0 1.0 .0"
6 B31_aa_3 Ctx3 B31_aa "0.87 0.87 .0"
6 B31_aa_4 Ctx4 B31_aa ".0 0.95 1.0"
6 B31_aa_5 Ctx5 B31_aa ".0 .0 .0"
6 B31_aa_6 Ctx6 B31_aa ".0 .0 0.5"
6 B31_aa_7 Ctx7 B31_aa "0.41 0.41 0.41"
6 B31_aa_8 Ctx8 B31_aa "1.0 .0 1.0"
6 B31_aa_9 Ctx9 B31_aa ".0 .0 1.0"
10 337.831689000 w1 WS "B31_aa"
20 337.831689000 w1 WS B31_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 287 287 0.000000 0
0 -1 -1
10 337.832937000 t4913 S E
10 337.833554000 t4913 S B
10 337.834369000 w1 WS "I"
13 337.822836000 w1 gf 0.000000
13 337.837496000 sched nready 2.000000
9 337.837496000 pu p 288
13 337.841168000 sched nready 1.000000
13 337.841168000 sched nsubmitted 2.000000
9 337.841168000 po p 288
10 337.842444000 w1 WS "Fi"
10 337.844574000 w1 WS "B13"
20 337.844574000 w1 WS B13 40
288 288 0.000000 0 0 -1 -1
10 337.846201000 t4913 S E
10 337.846691000 t4913 S B
10 337.847520000 w1 WS "I"
13 337.834369000 w1 gf 0.000000
13 337.844574000 w1 gf 0.000000
18 337.851778000 WSL p 0 w3 steal_17
19 337.851778001 WSL p 0 w1 steal_17
13 337.851866000 sched nready 0.000000
13 337.851866000 sched nsubmitted 1.000000
9 337.851866000 po p 295
10 337.853132000 w1 WS "Fi"
6 B33_aa WS B33_aa "0.000000 0.600000 0.400000"
6 B33_aa_1 Ctx1 B33_aa "1.0 0.39 1.0"
6 B33_aa_2 Ctx2 B33_aa ".0 1.0 .0"
6 B33_aa_3 Ctx3 B33_aa "0.87 0.87 .0"
6 B33_aa_4 Ctx4 B33_aa ".0 0.95 1.0"
6 B33_aa_5 Ctx5 B33_aa ".0 .0 .0"
6 B33_aa_6 Ctx6 B33_aa ".0 .0 0.5"
6 B33_aa_7 Ctx7 B33_aa "0.41 0.41 0.41"
6 B33_aa_8 Ctx8 B33_aa "1.0 .0 1.0"
6 B33_aa_9 Ctx9 B33_aa ".0 .0 1.0"
10 337.855074000 w1 WS "B33_aa"
20 337.855074000 w1 WS B33_aa 112 M1x1x8_M2x2x8_M3x3x8
e2d29843 0000000000000000 295 295 0.000000 0
0 -1 -1
10 337.856166000 t4913 S E
10 337.856698000 t4913 S B
10 337.857522000 w1 WS "I"
13 337.847520000 w1 gf 0.000000
13 337.855074000 w1 gf 0.000000
13 337.860312000 sched nready 1.000000
9 337.860312000 pu p 296
13 337.863212000 sched nready 0.000000
13 337.863212000 sched nsubmitted 0.000000
9 337.863212000 po p 296
10 337.864473000 w1 WS "Fi"
10 337.866610000 w1 WS "B13"
20 337.866610000 w1 WS B13 40
296 296 0.000000 0 0 -1 -1
10 337.868203000 t4913 S E
10 337.868654000 t4913 S B
10 337.869477000 w1 WS "I"
13 337.857522000 w1 gf 0.000000
13 337.866610000 w1 gf 0.000000
10 338.914978000 t4912 S B
10 338.917382000 w0 WS "I"
13 331.025231000 w0 gf 0.000000
13 331.025231000 sched gft 0.000000
10 344.142920000 t4914 S B
10 344.144732000 w2 WS "I"
13 336.461006000 w2 gf 0.000000
13 336.461006000 sched gft 0.000000
13 336.497104000 sched gft 0.000000
13 336.504567000 sched gft 0.000000
13 336.633992000 sched gft 0.000000
10 344.398772000 t4915 S B
10 344.400558000 w3 WS "I"
13 336.717666000 w3 gf 0.000000
13 336.717666000 sched gft 0.000000
13 336.743310000 sched gft 0.000000
13 336.755267000 sched gft 0.000000
13 336.763579000 sched gft 0.000000
13 337.037116000 sched gft 0.000000
13 337.234663000 sched gft 0.000000
13 337.270648000 sched gft 0.000000
10 344.960043000 t4916 S B
10 344.961712000 w4 WS "I"
13 337.282192000 w4 gf 0.000000
13 337.290204000 w4 gf 0.000000
13 337.282192000 sched gft 0.000000
13 337.290204000 sched gft 0.000000
13 337.449860000 sched gft 0.000000
13 337.653271000 sched gft 0.000000
13 337.664543000 sched gft 0.000000
13 337.673092000 sched gft 0.000000
13 337.675636000 sched gft 0.000000
13 337.683406000 sched gft 0.000000
13 337.685868000 sched gft 0.000000
13 337.693285000 sched gft 0.000000
13 337.695751000 sched gft 0.000000
13 337.703033000 sched gft 0.000000
13 337.705464000 sched gft 0.000000
13 337.712777000 sched gft 0.000000
10 345.545604000 t4917 S B
10 345.547641000 w5 WS "I"
13 337.715220000 w5 gf 0.000000
13 337.722540000 w5 gf 0.000000
13 337.715220000 sched gft 0.000000
13 337.722540000 sched gft 0.000000
13 337.822836000 sched gft 0.000000
13 337.834369000 sched gft 0.000000
13 337.844574000 sched gft 0.000000
13 337.847520000 sched gft 0.000000
13 337.855074000 sched gft 0.000000
13 337.857522000 sched gft 0.000000
13 337.866610000 sched gft 0.000000
12 345.579546000 t4900 US
9 345.581109000 prog_event p "stop_profiling"
13 337.869477000 sched gft 0.000000
13 338.917382000 sched gft 0.000000
13 344.144732000 sched gft 0.000000
13 344.400558000 sched gft 0.000000
13 344.961712000 sched gft 0.000000
13 338.917382000 w0 gf 0.000000
13 337.869477000 w1 gf 0.000000
13 344.144732000 w2 gf 0.000000
13 344.400558000 w3 gf 0.000000
13 344.961712000 w4 gf 0.000000
13 345.547641000 w5 gf 0.000000
13 345.547641000 sched gft 0.000000
Haut de le page
