Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Issue with distributed NUMA-aware StarPU and dmda scheduler
Archives de la liste
Chronologique Discussions
  • To: Philippe SWARTVAGHER <philippe.swartvagher@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Issue with distributed NUMA-aware StarPU and dmda scheduler
  • Date: Sat, 14 Mar 2020 01:37:35 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Samuel Thibault, le ven. 13 mars 2020 17:55:39 +0100, a ecrit:
> Philippe SWARTVAGHER, le ven. 13 mars 2020 14:02:38 +0100, a ecrit:
> > #5  0x00007ffff7fb0053 in _starpu_mpi_handle_request_termination
> > (req=req@entry
> > =0x55555581b640) at ../../../mpi/src/mpi/starpu_mpi_mpi.c:861
> It seems that it frees the packed data with free(), while the documentation
> says
> that the pack_data method is supposed to use starpu_malloc_on_node_flags
> to allocate it. Please try the attached patch to properly release it.
Yes, that was bogus (and the patch was bogus too), I pushed and
backported a fix.
Samuel
> diff --git a/mpi/src/mpi/starpu_mpi_mpi.c b/mpi/src/mpi/starpu_mpi_mpi.c
> index 01c46fe30..1548641d6 100644
> --- a/mpi/src/mpi/starpu_mpi_mpi.c
> +++ b/mpi/src/mpi/starpu_mpi_mpi.c
> @@ -858,7 +858,7 @@ static void
> _starpu_mpi_handle_request_termination(struct _starpu_mpi_req *req)
> int ret;
> ret =
> MPI_Wait(&req->backend->size_req, MPI_STATUS_IGNORE);
> STARPU_MPI_ASSERT_MSG(ret ==
> MPI_SUCCESS, "MPI_Wait returning %s", _starpu_mpi_get_mpi_error_code(ret));
> - free(req->ptr);
> + starpu_free_on_node(STARPU_MAIN_RAM,
> req->ptr, req->backend->envelope->size);
> req->ptr = NULL;
> else if (req->request_type == RECV_REQ)
Haut de le page
