Archives de la liste
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Cc: "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, "Rabab M. Alomairy" <Rabab.omairy@kaust.edu.sa>
- Subject: [Starpu-devel] purge in starpu
- Date: Thu, 26 Mar 2020 14:27:35 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=835437736b=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear StarPU developers,
I hope this email finds you well.
Be safe!
We would like to know how to predict situations where StarPU has to purge
before it actually happens.
We know that the window sizes has a direct impact on the purge mechanism
within StarPU in addition to the memory capacity available on the system.
Although the purge is a cool feature, it may be quite expensive and slows
down the overall computation.
So, if there are some ways to determine ahead to time when we will be facing
purge situations given the window size,
the aggregated memory capacity, the number of MPI processes/nodes, and the
application memory footprint, (and perhaps other parameters such as
scheduling policies)
we could use such insights to prevent the purge situations by making some
adjustments on these aforementioned parameters.
Thanks for your continuous support.
Best regards,
Hatem
- [Starpu-devel] purge in starpu, Hatem Ltaief, 26/03/2020
