Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Vinicius Garcia Pinto <vgpinto@inf.ufrgs.br>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu_perfmodel_recdump broken
- Date: Tue, 05 May 2020 18:15:24 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vgpinto@inf.ufrgs.br; spf=Pass smtp.mailfrom=vgpinto@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
ok, thanks
On 2020-05-05 16:40, Samuel Thibault wrote:
Vinicius Garcia Pinto, le mar. 05 mai 2020 16:36:47 -0300, a ecrit:
So what I am trying to do is obtain a good platform.rec file from older
traces (obtained with starpu 2967aade93e0f3291eead61b1398e6da3984e49b) using
a recent starpu_perfmodel_recdump with your fix
(36166edcc195bd87f6bc5ed40a22dfd1b2501f55).
Ah. But the change is on the application side, not on the
starpu_fxt_tool side, so with the recorded trace it will always be so.
There is other option than either re-record the trace, or drop by hand
the spurious fields in the generated files.
Samuel
- Re: [Starpu-devel] starpu_perfmodel_recdump broken, Samuel Thibault, 01/05/2020
- Re: [Starpu-devel] starpu_perfmodel_recdump broken, Vinicius Garcia Pinto, 05/05/2020
- Re: [Starpu-devel] starpu_perfmodel_recdump broken, Samuel Thibault, 05/05/2020
