Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-announce@lists.gforge.inria.fr
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] StarPU v1.3.4 available
- Date: Thu, 11 Jun 2020 13:12:04 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
All, The release 1.3.4 of StarPU is available, with the following changes * New environment variables STARPU_BUS_STATS_FILE and STARPU_WORKER_STATS_FILE to specify files in which to display statistics about data transfers and workers. * Add starpu_bcsr_filter_vertical_block filtering function. * Add starpu_interface_copy2d, 3d, and 4d to easily request data copies from data interfaces. * Move optimized cuda 2d copy from interfaces to new starpu_cuda_copy2d_async_sync and starpu_cuda_copy3d_async_sync, and use them from starpu_interface_copy2d and 3d. * New function starpu_task_watchdog_set_hook to specify a function to be called when the watchdog is raised * Add STARPU_LIMIT_CPU_NUMA_MEM environment variable. * Add STARPU_WORKERS_GETBIND environment variable. * Add STARPU_SCHED_SIMPLE_DECIDE_ALWAYS modular scheduler flag. * And STARPU_LIMIT_BANDWIDTH environment variable. * Add field starpu_conf::precedence_over_environment_variables to ignore environment variables when parameters are set directly in starpu_conf * Add starpu_data_get_coordinates_array * MPI: new functions starpu_mpi_interface_datatype_register() and starpu_mpi_interface_datatype_unregister() which take a enum starpu_data_interface_id instead of a starpu_data_handle_t * New script starpu_env to set up StarPU environment variables * New configure option --disable-build-doc-pdf We remind you that the 1.3 release serie brings among other
functionalities - a tool to replay execution through SimGrid, - a HDF5 implementation of the Out-of-core, - a new implementation of StarPU-MPI on top of NewMadeleine, - implicit support for asynchronous partition planning, - a resource management module to share processor cores and accelerator devices with other parallel runtime systems, ... The tarball along with the md5sum file and the OpenPGP signature are available as usual on the starpu web site http://starpu.gforge.inria.fr/files/ or directly on the Gforge web site https://gforge.inria.fr/frs/?group_id=1570 Nathalie, for the StarPU team. |
- [Starpu-devel] StarPU v1.3.4 available, Nathalie Furmento, 11/06/2020
