Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarVZ available at CRAN
- Date: Wed, 2 Sep 2020 16:29:06 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=schnorr@inf.ufrgs.br; spf=Pass smtp.mailfrom=schnorr@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello members of the StarPU community,
We are happy to announce that StarVZ is now available through the CRAN
(The Comprehensive R Archive Network) [1]. StarVZ is a performance
analysis workflow that combines the power of the R language (and the
tidyverse realm) and many auxiliary tools to provide a consistent,
flexible, extensible, fast, and versatile framework for the
performance analysis of task-based applications that run on top of the
StarPU runtime (with its MPI layer for multi-node support).
[1]: https://CRAN.R-project.org/package=starvz
The goal of StarVZ is to provide a fruitful prototypical environment
to conduct performance analysis hypothesis-checking for task-based
applications that run on heterogeneous (multi-GPU, multi-core)
multi-node HPC (High-performance computing) platforms.
If you are acquainted to the R language, we would be very happy to
receive feedback from the StarPU community to see your performance
analysis with StarVZ.
Best,
Lucas
Lucas M. Schnorr, UFRGS
http://www.inf.ufrgs.br/~schnorr/
- [Starpu-devel] StarVZ available at CRAN, Lucas M. Schnorr, 02/09/2020
- Re: [Starpu-devel] StarVZ available at CRAN, Samuel Thibault, 02/09/2020
