Accéder au contenu.
Menu Sympa
Archives de la liste
Chronologique Discussions
## Core tests. ##
configure:3754: checking build system type
configure:3768: result: x86_64-pc-linux-gnu
configure:3788: checking host system type
configure:3801: result: x86_64-pc-linux-gnu
configure:3821: checking target system type
configure:3834: result: x86_64-pc-linux-gnu
configure:3878: checking for a BSD-compatible install
configure:3946: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/install -c
configure:3957: checking whether build environment is sane
configure:4012: result: yes
configure:4161: checking for a thread-safe mkdir -p
configure:4200: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/mkdir -p
configure:4207: checking for gawk
configure:4223: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gawk
configure:4234: result: gawk
configure:4245: checking whether make sets $(MAKE)
configure:4267: result: yes
configure:4296: checking whether make supports nested variables
configure:4313: result: yes
configure:4451: checking whether make supports nested variables
configure:4468: result: yes
configure:4486: checking whether make supports the include directive
configure:4501: make -f confmf.GNU && cat confinc.out
this is the am__doit target
configure:4504: $? = 0
configure:4523: result: yes (GNU style)
configure:4593: checking for gcc
configure:4609: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gcc
configure:4620: result: gcc
configure:4849: checking for C compiler version
configure:4858: gcc --version >&5
gcc (GCC) 7.5.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4869: $? = 0
configure:4858: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/gnu/store/rn75fm7adgx3pw5j8pg3bczfqq1y17lk-gcc-7.5.0/libexec/gcc/x86_64-unknown-linux-gnu/7.5.0/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with:
Thread model: posix
gcc version 7.5.0 (GCC)
configure:4858: gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4869: $? = 1
configure:4858: gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'; did you mean
'--version'?
configure:4889: checking whether the C compiler works
configure:4911: gcc conftest.c >&5
configure:4915: $? = 0
configure:4963: result: yes
configure:4966: checking for C compiler default output file name
configure:4968: result: a.out
configure:4974: checking for suffix of executables
configure:4981: gcc -o conftest conftest.c >&5
configure:4985: $? = 0
configure:5007: result:
configure:5029: checking whether we are cross compiling
configure:5037: gcc -o conftest conftest.c >&5
configure:5041: $? = 0
configure:5048: ./conftest
configure:5052: $? = 0
configure:5040: result: no
configure:5045: checking for suffix of object files
configure:5067: gcc -c conftest.c >&5
configure:5071: $? = 0
configure:5092: result: o
configure:5096: checking whether we are using the GNU C compiler
configure:5115: gcc -c conftest.c >&5
configure:5115: $? = 0
configure:5124: result: yes
configure:5133: checking whether gcc accepts -g
configure:5153: gcc -c -g conftest.c >&5
configure:5153: $? = 0
configure:5194: result: yes
configure:5211: checking for gcc option to accept ISO C89
configure:5274: gcc -c -g -O2 conftest.c >&5
configure:5274: $? = 0
configure:5287: result: none needed
configure:5312: checking whether gcc understands -c and -o together
configure:5334: gcc -c conftest.c -o conftest2.o
configure:5337: $? = 0
configure:5349: result: yes
configure:5368: checking dependency style of gcc
configure:5479: result: gcc3
configure:5544: checking for ar
configure:5560: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ar
configure:5571: result: ar
configure:5597: checking the archiver (ar) interface
configure:5613: gcc -c -g -O2 conftest.c >&5
configure:5613: $? = 0
configure:5615: ar cru libconftest.a conftest.o >&5
ar: `u' modifier ignored since `D' is the default (see `U')
configure:5618: $? = 0
configure:5617: result: ar
configure:5685: checking for gcc
configure:5712: result: gcc
configure:5941: checking for C compiler version
configure:5950: gcc --version >&5
gcc (GCC) 7.5.0
configure:5961: $? = 0
configure:5950: gcc -v >&5
COLLECT_GCC=gcc
Configured with:
Thread model: posix
configure:5950: gcc -V >&5
configure:5961: $? = 1
configure:5950: gcc -qversion >&5
'--version'?
configure:5965: checking whether we are using the GNU C compiler
configure:5993: result: yes
configure:6002: checking whether gcc accepts -g
configure:6063: result: yes
configure:6080: checking for gcc option to accept ISO C89
configure:6156: result: none needed
configure:6181: checking whether gcc understands -c and -o together
configure:6218: result: yes
configure:6237: checking dependency style of gcc
configure:6348: result: gcc3
configure:6422: checking for g++
configure:6438: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/g++
configure:6449: result: g++
configure:6476: checking for C++ compiler version
configure:6485: g++ --version >&5
g++ (GCC) 7.5.0
configure:6496: $? = 0
configure:6485: g++ -v >&5
COLLECT_GCC=g++
Configured with:
Thread model: posix
configure:6485: g++ -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6496: $? = 1
configure:6485: g++ -qversion >&5
g++: error: unrecognized command line option '-qversion'; did you mean
'--version'?
configure:6500: checking whether we are using the GNU C++ compiler
configure:6519: g++ -c conftest.cpp >&5
configure:6519: $? = 0
configure:6528: result: yes
configure:6537: checking whether g++ accepts -g
configure:6557: g++ -c -g conftest.cpp >&5
configure:6557: $? = 0
configure:6598: result: yes
configure:6623: checking dependency style of g++
configure:6734: result: gcc3
configure:6754: checking how to run the C preprocessor
configure:6785: gcc -E conftest.c
configure:6785: $? = 0
configure:6799: gcc -E conftest.c
conftest.c:14:10: fatal error: ac_nonexistent.h: No such file or directory
#include <ac_nonexistent.h>
configure:6799: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.3.99"
| #define PACKAGE_STRING "StarPU 1.3.99"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://gitlab.inria.fr/starpu/starpu";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 3
| #define STARPU_RELEASE_VERSION 99
| #define PACKAGE "starpu"
| #define VERSION "1.3.99"
| /* end confdefs.h. */
configure:6824: result: gcc -E
configure:6844: gcc -E conftest.c
configure:6844: $? = 0
configure:6858: gcc -E conftest.c
configure:6858: $? = 1
| /* confdefs.h */
configure:6886: checking for a sed that does not truncate output
configure:6950: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/sed
configure:6955: checking whether ln -s works
configure:6959: result: yes
configure:7019: checking for g77
configure:7049: result: no
configure:7019: checking for xlf
configure:7019: checking for f77
configure:7019: checking for frt
configure:7019: checking for pgf77
configure:7019: checking for cf77
configure:7019: checking for fort77
configure:7019: checking for fl32
configure:7019: checking for af77
configure:7019: checking for xlf90
configure:7019: checking for f90
configure:7019: checking for pgf90
configure:7019: checking for pghpf
configure:7019: checking for epcf90
configure:7019: checking for gfortran
configure:7035: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gfortran
configure:7046: result: gfortran
configure:7072: checking for Fortran 77 compiler version
configure:7081: gfortran --version >&5
GNU Fortran (GCC) 7.5.0
configure:7092: $? = 0
configure:7081: gfortran -v >&5
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/gnu/store/rfm558jgb7334zlgywc82fs1jqslql52-gfortran-7.5.0/libexec/gcc/x86_64-unknown-linux-gnu/7.5.0/lto-wrapper
Configured with:
Thread model: posix
configure:7081: gfortran -V >&5
gfortran: error: unrecognized command line option '-V'
gfortran: fatal error: no input files
configure:7092: $? = 1
configure:7081: gfortran -qversion >&5
gfortran: error: unrecognized command line option '-qversion'; did you mean
'--version'?
configure:7101: checking whether we are using the GNU Fortran 77 compiler
configure:7114: gfortran -c conftest.F >&5
configure:7114: $? = 0
configure:7123: result: yes
configure:7129: checking whether gfortran accepts -g
configure:7140: gfortran -c -g conftest.f >&5
configure:7140: $? = 0
configure:7148: result: yes
configure:7230: checking for gfortran
configure:7246: found
configure:7257: result: gfortran
configure:7283: checking for Fortran compiler version
configure:7292: gfortran --version >&5
configure:7303: $? = 0
configure:7292: gfortran -v >&5
Configured with:
Thread model: posix
configure:7292: gfortran -V >&5
configure:7303: $? = 1
configure:7292: gfortran -qversion >&5
'--version'?
configure:7312: checking whether we are using the GNU Fortran compiler
configure:7325: gfortran -c conftest.F >&5
configure:7325: $? = 0
configure:7334: result: yes
configure:7340: checking whether gfortran accepts -g
configure:7351: gfortran -c -g conftest.f >&5
configure:7351: $? = 0
configure:7359: result: yes
configure:7388: checking for grep that handles long lines and -e
configure:7446: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep
configure:7451: checking for egrep
configure:7513: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep -E
configure:7524: checking for gstat
configure:7554: result: no
configure:7524: checking for stat
configure:7540: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/stat
configure:7551: result: stat
configure:7566: checking for gdate
configure:7596: result: no
configure:7566: checking for date
configure:7582: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/date
configure:7593: result: date
configure:7654: checking for pkg-config
configure:7672: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/pkg-config
configure:7684: result:
configure:7709: checking pkg-config is at least version 0.9.0
configure:7712: result: yes
configure:7804: checking for SIMGRID
configure:7812: $PKG_CONFIG --exists --print-errors "simgrid"
configure:7815: $? = 0
configure:7830: $PKG_CONFIG --exists --print-errors "simgrid"
configure:7833: $? = 0
configure:7869: result: yes
configure:7892: checking for main in -lsimgrid
configure:7911: gcc -o conftest
-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include -g -O2
-L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib -lsimgrid
conftest.c -lsimgrid >&5
configure:7911: $? = 0
configure:7920: result: yes
configure:7938: checking for ANSI C header files
configure:7958: gcc -c
conftest.c >&5
configure:7958: $? = 0
configure:8031: gcc -o conftest
configure:8031: $? = 0
configure:8031: ./conftest
configure:8042: result: yes
configure:8055: checking for sys/types.h
configure:8055: gcc -c
conftest.c >&5
configure:8055: $? = 0
configure:8055: result: yes
configure:8055: checking for sys/stat.h
conftest.c >&5
configure:8055: checking for stdlib.h
conftest.c >&5
configure:8055: checking for string.h
conftest.c >&5
configure:8055: checking for memory.h
conftest.c >&5
configure:8055: checking for strings.h
conftest.c >&5
configure:8055: checking for inttypes.h
conftest.c >&5
configure:8055: checking for stdint.h
conftest.c >&5
configure:8055: checking for unistd.h
conftest.c >&5
configure:8069: checking simgrid/msg.h usability
configure:8069: gcc -c
conftest.c >&5
configure:8069: $? = 0
configure:8069: result: yes
configure:8069: checking simgrid/msg.h presence
configure:8069: gcc -E conftest.c
configure:8069: checking for simgrid/msg.h
configure:8083: checking msg/msg.h usability
configure:8083: gcc -c
conftest.c >&5
conftest.c:60:10: fatal error: msg/msg.h: No such file or directory
#include <msg/msg.h>
configure:8083: $? = 1
| /* confdefs.h */
| #define HAVE_LIBSIMGRID 1
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_SIMGRID_MSG_H 1
| #define STARPU_HAVE_SIMGRID_MSG_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
configure:8083: result: no
configure:8083: checking msg/msg.h presence
configure:8083: gcc -E conftest.c
conftest.c:27:10: fatal error: msg/msg.h: No such file or directory
| /* confdefs.h */
configure:8083: checking for msg/msg.h
configure:8097: checking simgrid/host.h usability
configure:8097: gcc -c
conftest.c >&5
configure:8097: $? = 0
configure:8097: result: yes
configure:8097: checking simgrid/host.h presence
configure:8097: gcc -E conftest.c
configure:8097: checking for simgrid/host.h
configure:8111: checking xbt/base.h usability
configure:8111: gcc -c
conftest.c >&5
configure:8111: $? = 0
configure:8111: result: yes
configure:8111: checking xbt/base.h presence
configure:8111: gcc -E conftest.c
configure:8111: checking for xbt/base.h
configure:8125: checking for simgrid/version.h
configure:8125: gcc -c
conftest.c >&5
conftest.c:37:10: fatal error: simgrid/version.h: No such file or directory
#include <simgrid/version.h>
configure:8125: $? = 1
| /* confdefs.h */
| #define HAVE_SIMGRID_HOST_H 1
| #define STARPU_HAVE_SIMGRID_HOST_H 1
| #define HAVE_XBT_BASE_H 1
| #define STARPU_HAVE_XBT_BASE_H 1
| #ifdef STARPU_HAVE_XBT_BASE_H
| #include <xbt/base.h>
| #endif
configure:8125: result: no
configure:8144: checking simgrid/simdag.h usability
configure:8144: gcc -c
conftest.c >&5
configure:8144: $? = 0
configure:8144: result: yes
configure:8144: checking simgrid/simdag.h presence
configure:8144: gcc -E conftest.c
configure:8144: checking for simgrid/simdag.h
configure:8158: checking xbt/synchro.h usability
configure:8158: gcc -c
conftest.c >&5
configure:8158: $? = 0
configure:8158: result: yes
configure:8158: checking xbt/synchro.h presence
configure:8158: gcc -E conftest.c
configure:8158: checking for xbt/synchro.h
configure:8172: checking xbt/config.h usability
configure:8172: gcc -c
conftest.c >&5
configure:8172: $? = 0
configure:8172: result: yes
configure:8172: checking xbt/config.h presence
configure:8172: gcc -E conftest.c
configure:8172: checking for xbt/config.h
configure:8186: checking simgrid/actor.h usability
configure:8186: gcc -c
conftest.c >&5
configure:8186: $? = 0
configure:8186: result: yes
configure:8186: checking simgrid/actor.h presence
configure:8186: gcc -E conftest.c
configure:8186: checking for simgrid/actor.h
configure:8200: checking simgrid/engine.h usability
configure:8200: gcc -c
conftest.c >&5
configure:8200: $? = 0
configure:8200: result: yes
configure:8200: checking simgrid/engine.h presence
configure:8200: gcc -E conftest.c
configure:8200: checking for simgrid/engine.h
configure:8214: checking simgrid/semaphore.h usability
configure:8214: gcc -c
conftest.c >&5
configure:8214: $? = 0
configure:8214: result: yes
configure:8214: checking simgrid/semaphore.h presence
configure:8214: gcc -E conftest.c
configure:8214: checking for simgrid/semaphore.h
configure:8228: checking simgrid/mutex.h usability
configure:8228: gcc -c
conftest.c >&5
configure:8228: $? = 0
configure:8228: result: yes
configure:8228: checking simgrid/mutex.h presence
configure:8228: gcc -E conftest.c
configure:8228: checking for simgrid/mutex.h
configure:8242: checking simgrid/cond.h usability
configure:8242: gcc -c
conftest.c >&5
configure:8242: $? = 0
configure:8242: result: yes
configure:8242: checking simgrid/cond.h presence
configure:8242: gcc -E conftest.c
configure:8242: checking for simgrid/cond.h
configure:8256: checking simgrid/barrier.h usability
configure:8256: gcc -c
conftest.c >&5
configure:8256: $? = 0
configure:8256: result: yes
configure:8256: checking simgrid/barrier.h presence
configure:8256: gcc -E conftest.c
configure:8256: checking for simgrid/barrier.h
configure:8270: checking for simgrid/engine.h
configure:8270: result: yes
configure:8282: checking simgrid/zone.h usability
configure:8282: gcc -c
conftest.c >&5
configure:8282: $? = 0
configure:8282: result: yes
configure:8282: checking simgrid/zone.h presence
configure:8282: gcc -E conftest.c
configure:8282: checking for simgrid/zone.h
configure:8294: checking for smx_actor_t
configure:8294: gcc -c
conftest.c >&5
configure:8294: $? = 0
conftest.c >&5
conftest.c: In function 'main':
conftest.c:57:26: error: expected expression before ')' token
if (sizeof ((smx_actor_t)))
configure:8294: $? = 1
| /* confdefs.h */
| #define HAVE_SIMGRID_SIMDAG_H 1
| #define STARPU_HAVE_SIMGRID_SIMDAG_H 1
| #define HAVE_XBT_SYNCHRO_H 1
| #define STARPU_HAVE_XBT_SYNCHRO_H 1
| #define HAVE_XBT_CONFIG_H 1
| #define STARPU_HAVE_XBT_CONFIG_H 1
| #define HAVE_SIMGRID_ACTOR_H 1
| #define STARPU_HAVE_SIMGRID_ACTOR_H 1
| #define HAVE_SIMGRID_ENGINE_H 1
| #define STARPU_HAVE_SIMGRID_ENGINE_H 1
| #define HAVE_SIMGRID_SEMAPHORE_H 1
| #define STARPU_HAVE_SIMGRID_SEMAPHORE_H 1
| #define HAVE_SIMGRID_MUTEX_H 1
| #define STARPU_HAVE_SIMGRID_MUTEX_H 1
| #define HAVE_SIMGRID_COND_H 1
| #define STARPU_HAVE_SIMGRID_COND_H 1
| #define HAVE_SIMGRID_BARRIER_H 1
| #define STARPU_HAVE_SIMGRID_BARRIER_H 1
| #define HAVE_SIMGRID_ZONE_H 1
| #define STARPU_HAVE_SIMGRID_ZONE_H 1
| #include <simgrid/simix.h>
| int
| main ()
| return 0;
| return 0;
configure:8294: result: yes
configure:8312: checking for MSG_process_attach
configure:8312: gcc -o conftest
configure:8312: $? = 0
configure:8312: result: yes
configure:8312: checking for sg_actor_attach
configure:8312: checking for sg_actor_init
ld: /tmp/cc1O36ZA.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:90: undefined reference to `sg_actor_init'
collect2: error: ld returned 1 exit status
configure:8312: $? = 1
| /* confdefs.h */
| #define HAVE_SMX_ACTOR_T 1
| #define STARPU_HAVE_SMX_ACTOR_T 1
| #define HAVE_MSG_PROCESS_ATTACH 1
| #define HAVE_SG_ACTOR_ATTACH 1
| /* Define sg_actor_init to an innocuous variant, in case <limits.h>
declares sg_actor_init.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define sg_actor_init innocuous_sg_actor_init
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char sg_actor_init (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef sg_actor_init
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_sg_actor_init || defined __stub___sg_actor_init
| choke me
| #endif
| int
| main ()
| return sg_actor_init ();
| return 0;
configure:8312: result: no
configure:8312: checking for sg_actor_set_stacksize
ld: /tmp/ccbaWxkq.o: in function `main':
`sg_actor_set_stacksize'
| /* confdefs.h */
| /* Define sg_actor_set_stacksize to an innocuous variant, in case
<limits.h> declares sg_actor_set_stacksize.
| #define sg_actor_set_stacksize innocuous_sg_actor_set_stacksize
| which can conflict with char sg_actor_set_stacksize (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sg_actor_set_stacksize
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_sg_actor_set_stacksize || defined
__stub___sg_actor_set_stacksize
| choke me
| #endif
| int
| main ()
| return sg_actor_set_stacksize ();
| return 0;
configure:8312: checking for sg_actor_on_exit
ld: /tmp/ccJfYQXi.o: in function `main':
`sg_actor_on_exit'
| /* confdefs.h */
| /* Define sg_actor_on_exit to an innocuous variant, in case <limits.h>
declares sg_actor_on_exit.
| #define sg_actor_on_exit innocuous_sg_actor_on_exit
| which can conflict with char sg_actor_on_exit (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sg_actor_on_exit
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_sg_actor_on_exit || defined __stub___sg_actor_on_exit
| choke me
| #endif
| int
| main ()
| return sg_actor_on_exit ();
| return 0;
configure:8312: checking for MSG_zone_get_hosts
configure:8312: checking for sg_zone_get_hosts
configure:8312: checking for MSG_process_self_name
configure:8312: checking for MSG_process_userdata_init
configure:8312: checking for sg_actor_data
configure:8324: checking for xbt_mutex_try_acquire
configure:8324: gcc -o conftest
configure:8324: $? = 0
configure:8324: result: yes
configure:8324: checking for smpi_process_set_user_data
configure:8324: checking for SMPI_thread_create
ld: /tmp/ccnA3vZO.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:97: undefined reference to
`SMPI_thread_create'
configure:8324: $? = 1
| /* confdefs.h */
| #define HAVE_MSG_ZONE_GET_HOSTS 1
| #define HAVE_SG_ZONE_GET_HOSTS 1
| #define HAVE_MSG_PROCESS_SELF_NAME 1
| #define HAVE_MSG_PROCESS_USERDATA_INIT 1
| #define HAVE_SG_ACTOR_DATA 1
| #define HAVE_XBT_MUTEX_TRY_ACQUIRE 1
| #define HAVE_SMPI_PROCESS_SET_USER_DATA 1
| /* Define SMPI_thread_create to an innocuous variant, in case <limits.h>
declares SMPI_thread_create.
| #define SMPI_thread_create innocuous_SMPI_thread_create
| which can conflict with char SMPI_thread_create (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef SMPI_thread_create
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_SMPI_thread_create || defined __stub___SMPI_thread_create
| choke me
| #endif
| int
| main ()
| return SMPI_thread_create ();
| return 0;
configure:8324: result: no
configure:8324: checking for sg_zone_get_by_name
configure:8324: checking for sg_link_name
configure:8324: checking for sg_link_bandwidth_set
ld: /tmp/ccG8QLhC.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:99: undefined reference to
`sg_link_bandwidth_set'
| /* confdefs.h */
| #define HAVE_SG_ZONE_GET_BY_NAME 1
| #define HAVE_SG_LINK_NAME 1
| /* Define sg_link_bandwidth_set to an innocuous variant, in case <limits.h>
declares sg_link_bandwidth_set.
| #define sg_link_bandwidth_set innocuous_sg_link_bandwidth_set
| which can conflict with char sg_link_bandwidth_set (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sg_link_bandwidth_set
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_sg_link_bandwidth_set || defined
__stub___sg_link_bandwidth_set
| choke me
| #endif
| int
| main ()
| return sg_link_bandwidth_set ();
| return 0;
configure:8324: checking for sg_host_route
configure:8324: checking for sg_host_self
configure:8324: checking for sg_host_list
configure:8324: checking for sg_host_speed
configure:8324: checking for simcall_process_create
ld: /tmp/cc4QvgL2.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:103: undefined reference to
`simcall_process_create'
| /* confdefs.h */
| #define HAVE_SG_HOST_ROUTE 1
| #define HAVE_SG_HOST_SELF 1
| #define HAVE_SG_HOST_LIST 1
| #define HAVE_SG_HOST_SPEED 1
| /* Define simcall_process_create to an innocuous variant, in case
<limits.h> declares simcall_process_create.
| #define simcall_process_create innocuous_simcall_process_create
| which can conflict with char simcall_process_create (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef simcall_process_create
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_simcall_process_create || defined
__stub___simcall_process_create
| choke me
| #endif
| int
| main ()
| return simcall_process_create ();
| return 0;
configure:8324: checking for sg_config_continue_after_help
configure:8335: checking for simgrid_init
configure:8335: gcc -o conftest
configure:8335: $? = 0
configure:8335: result: yes
configure:8348: checking for xbt_barrier_init
configure:8348: gcc -o conftest
ld: /tmp/cc1xeiD0.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:106: undefined reference to
`xbt_barrier_init'
configure:8348: $? = 1
| /* confdefs.h */
| #define HAVE_SG_CONFIG_CONTINUE_AFTER_HELP 1
| #define HAVE_SIMGRID_INIT 1
| #define STARPU_SIMGRID_HAVE_SIMGRID_INIT 1
| /* Define xbt_barrier_init to an innocuous variant, in case <limits.h>
declares xbt_barrier_init.
| #define xbt_barrier_init innocuous_xbt_barrier_init
| which can conflict with char xbt_barrier_init (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef xbt_barrier_init
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_xbt_barrier_init || defined __stub___xbt_barrier_init
| choke me
| #endif
| int
| main ()
| return xbt_barrier_init ();
| return 0;
configure:8348: result: no
configure:8362: checking for sg_actor_sleep_for
configure:8362: gcc -o conftest
configure:8362: $? = 0
configure:8362: result: yes
configure:8362: checking for sg_actor_self
configure:8362: checking for sg_actor_ref
configure:8362: checking for sg_host_get_properties
configure:8362: checking for sg_host_send_to
configure:8362: checking for sg_host_sendto
ld: /tmp/ccSu9B7O.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:111: undefined reference to
`sg_host_sendto'
configure:8362: $? = 1
| /* confdefs.h */
| #define HAVE_SG_ACTOR_SLEEP_FOR 1
| #define HAVE_SG_ACTOR_SELF 1
| #define HAVE_SG_ACTOR_REF 1
| #define HAVE_SG_HOST_GET_PROPERTIES 1
| #define HAVE_SG_HOST_SEND_TO 1
| /* Define sg_host_sendto to an innocuous variant, in case <limits.h>
declares sg_host_sendto.
| #define sg_host_sendto innocuous_sg_host_sendto
| which can conflict with char sg_host_sendto (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sg_host_sendto
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_sg_host_sendto || defined __stub___sg_host_sendto
| choke me
| #endif
| int
| main ()
| return sg_host_sendto ();
| return 0;
configure:8362: result: no
configure:8362: checking for sg_cfg_set_int
configure:8362: checking for sg_actor_self_execute
configure:8362: checking for sg_actor_execute
ld: /tmp/cceIeM7t.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:113: undefined reference to
`sg_actor_execute'
| /* confdefs.h */
| #define HAVE_SG_CFG_SET_INT 1
| #define HAVE_SG_ACTOR_SELF_EXECUTE 1
| /* Define sg_actor_execute to an innocuous variant, in case <limits.h>
declares sg_actor_execute.
| #define sg_actor_execute innocuous_sg_actor_execute
| which can conflict with char sg_actor_execute (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef sg_actor_execute
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_sg_actor_execute || defined __stub___sg_actor_execute
| choke me
| #endif
| int
| main ()
| return sg_actor_execute ();
| return 0;
configure:8362: checking for simgrid_get_clock
configure:8371: checking whether smpi_process_set_user_data is declared
configure:8371: gcc -c
conftest.c >&5
configure:8371: $? = 0
configure:8371: result: yes
configure:8388: checking for MSG_get_as_by_name
configure:8388: gcc -o conftest
ld: /tmp/ccQzqUnr.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:115: undefined reference to
`MSG_get_as_by_name'
configure:8388: $? = 1
| /* confdefs.h */
| #define HAVE_SIMGRID_GET_CLOCK 1
| #define HAVE_DECL_SMPI_PROCESS_SET_USER_DATA 1
| /* Define MSG_get_as_by_name to an innocuous variant, in case <limits.h>
declares MSG_get_as_by_name.
| #define MSG_get_as_by_name innocuous_MSG_get_as_by_name
| which can conflict with char MSG_get_as_by_name (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef MSG_get_as_by_name
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_MSG_get_as_by_name || defined __stub___MSG_get_as_by_name
| choke me
| #endif
| int
| main ()
| return MSG_get_as_by_name ();
| return 0;
configure:8388: result: no
configure:8388: checking for MSG_zone_get_by_name
configure:8388: $? = 0
configure:8388: result: yes
configure:8388: checking for MSG_environment_get_routing_root
ld: /tmp/ccsN8Nuh.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:116: undefined reference to
`MSG_environment_get_routing_root'
| /* confdefs.h */
| #define HAVE_MSG_ZONE_GET_BY_NAME 1
| /* Define MSG_environment_get_routing_root to an innocuous variant, in case
<limits.h> declares MSG_environment_get_routing_root.
| #define MSG_environment_get_routing_root
innocuous_MSG_environment_get_routing_root
| which can conflict with char MSG_environment_get_routing_root (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef MSG_environment_get_routing_root
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_MSG_environment_get_routing_root || defined
__stub___MSG_environment_get_routing_root
| choke me
| #endif
| int
| main ()
| return MSG_environment_get_routing_root ();
| return 0;
configure:8388: checking for MSG_host_get_speed
configure:8446: g++ -c
conftest.cpp >&5
configure:8446: $? = 0
configure:8534: checking whether SimGrid is enabled
configure:8536: result: yes
configure:8539: checking whether blocking drivers should be enabled
configure:8548: result: yes
configure:8558: checking whether worker callbacks should be enabled
configure:8567: result: no
configure:8594: checking whether g++ supports C++11 features by default
configure:8888: g++ -c
conftest.cpp >&5
configure:8888: $? = 0
configure:8895: result: yes
configure:9310: checking how to print strings
configure:9337: result: printf
configure:9358: checking for a sed that does not truncate output
configure:9422: result:
configure:9440: checking for fgrep
configure:9502: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep -F
configure:9537: checking for ld used by gcc
configure:9604: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld
configure:9611: checking if the linker
(/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld) is GNU ld
configure:9626: result: yes
configure:9638: checking for BSD- or MS-compatible name lister (nm)
configure:9692: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm -B
configure:9822: checking the name lister
(/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm -B) interface
configure:9829: gcc -c
conftest.c >&5
configure:9832: /gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm -B
"conftest.o"
configure:9835: output
0000000000000000 B some_variable
configure:9836: result: BSD nm
configure:9840: checking the maximum length of command line arguments
configure:9971: result: 1572864
configure:10019: checking how to convert x86_64-pc-linux-gnu file names to
x86_64-pc-linux-gnu format
configure:10059: result: func_convert_file_noop
configure:10066: checking how to convert x86_64-pc-linux-gnu file names to
toolchain format
configure:10086: result: func_convert_file_noop
configure:10093: checking for
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld option to reload
object files
configure:10100: result: -r
configure:10174: checking for objdump
configure:10190: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/objdump
configure:10201: result: objdump
configure:10230: checking how to recognize dependent libraries
configure:10430: result: pass_all
configure:10515: checking for dlltool
configure:10545: result: no
configure:10572: checking how to associate runtime and link libraries
configure:10599: result: printf %s\n
configure:10723: checking for archiver @FILE support
configure:10740: gcc -c
conftest.c >&5
configure:10740: $? = 0
configure:10743: ar cru libconftest.a @conftest.lst >&5
configure:10746: $? = 0
configure:10751: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:10754: $? = 1
configure:10753: result: @
configure:10811: checking for strip
configure:10827: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/strip
configure:10838: result: strip
configure:10910: checking for ranlib
configure:10926: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ranlib
configure:10937: result: ranlib
configure:11039: checking command to parse
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm -B output from gcc
object
configure:11192: gcc -c
conftest.c >&5
configure:11195: $? = 0
configure:11199: /gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm
-B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][
]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
configure:11202: $? = 0
configure:11268: gcc -o conftest
conftest.c conftstm.o >&5
configure:11271: $? = 0
configure:11309: result: ok
configure:11356: checking for sysroot
configure:11386: result: no
configure:11393: checking for a working dd
configure:11431: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/dd
configure:11435: checking how to truncate binary pipes
configure:11450: result:
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/dd bs=4096 count=1
configure:11586: gcc -c
conftest.c >&5
configure:11589: $? = 0
configure:11779: checking for mt
configure:11809: result: no
configure:11829: checking if : is a manifest tool
configure:11835: : '-?'
configure:11843: result: no
configure:12517: checking for dlfcn.h
configure:12517: gcc -c
conftest.c >&5
configure:12517: $? = 0
configure:12517: result: yes
configure:13083: checking for objdir
configure:13098: result: .libs
configure:13362: checking if gcc supports -fno-rtti -fno-exceptions
configure:13380: gcc -c
-fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not
for C
configure:13384: $? = 0
configure:13397: result: no
configure:13755: checking for gcc option to produce PIC
configure:13762: result: -fPIC -DPIC
configure:13770: checking if gcc PIC flag -fPIC -DPIC works
configure:13788: gcc -c
-fPIC -DPIC -DPIC conftest.c >&5
configure:13792: $? = 0
configure:13805: result: yes
configure:13834: checking if gcc static flag -static works
configure:13862: result: no
configure:13877: checking if gcc supports -c -o file.o
configure:13898: gcc -c
-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include -g -O2 -o
out/conftest2.o conftest.c >&5
configure:13902: $? = 0
configure:13924: result: yes
configure:13932: checking if gcc supports -c -o file.o
configure:13979: result: yes
configure:14012: checking whether the gcc linker
(/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld -m elf_x86_64)
supports shared libraries
configure:15271: result: yes
configure:15308: checking whether -lc should be explicitly linked in
configure:15316: gcc -c
conftest.c >&5
configure:15319: $? = 0
configure:15334: gcc -shared -fPIC -DPIC conftest.o -v -Wl,-soname
-Wl,conftest -o conftest 2\>\&1 \|
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep -lc
\>/dev/null 2\>\&1
configure:15337: $? = 0
configure:15351: result: no
configure:15511: checking dynamic linker characteristics
configure:16092: gcc -o conftest
-Wl,-rpath -Wl,/foo conftest.c -lsimgrid >&5
configure:16092: $? = 0
configure:16329: result: GNU/Linux ld.so
configure:16451: checking how to hardcode library paths into programs
configure:16476: result: immediate
configure:17024: checking whether stripping libraries is possible
configure:17029: result: yes
configure:17064: checking if libtool supports shared libraries
configure:17066: result: yes
configure:17069: checking whether to build shared libraries
configure:17094: result: yes
configure:17097: checking whether to build static libraries
configure:17101: result: yes
configure:13916: checking how to run the C++ preprocessor
configure:13943: g++ -E conftest.cpp
configure:13943: $? = 0
configure:13957: g++ -E conftest.cpp
conftest.cpp:88:10: fatal error: ac_nonexistent.h: No such file or directory
configure:13957: $? = 1
| /* confdefs.h */
| #define HAVE_MSG_HOST_GET_SPEED 1
| #define STARPU_SIMGRID 1
| #define HAVE_CXX11 1
| #define STARPU_HAVE_CXX11 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:13982: result: g++ -E
configure:14002: g++ -E conftest.cpp
configure:14002: $? = 0
configure:14016: g++ -E conftest.cpp
configure:14016: $? = 1
| /* confdefs.h */
configure:14178: checking for ld used by g++
configure:14245: result:
configure:14252: checking if the linker
(/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld -m elf_x86_64) is
GNU ld
configure:14267: result: yes
configure:14322: checking whether the g++ linker
configure:15395: result: yes
configure:15431: g++ -c
conftest.cpp >&5
configure:15434: $? = 0
configure:15915: checking for g++ option to produce PIC
configure:15922: result: -fPIC -DPIC
configure:15930: checking if g++ PIC flag -fPIC -DPIC works
configure:15948: g++ -c
-fPIC -DPIC -DPIC conftest.cpp >&5
configure:15952: $? = 0
configure:15965: result: yes
configure:15988: checking if g++ static flag -static works
configure:16016: result: no
configure:16028: checking if g++ supports -c -o file.o
configure:16049: g++ -c
out/conftest2.o conftest.cpp >&5
configure:16053: $? = 0
configure:16075: result: yes
configure:16080: checking if g++ supports -c -o file.o
configure:16127: result: yes
configure:16157: checking whether the g++ linker
configure:16197: result: yes
configure:16338: checking dynamic linker characteristics
configure:17083: result: GNU/Linux ld.so
configure:17148: checking how to hardcode library paths into programs
configure:17173: result: immediate
configure:16160: checking if libtool supports shared libraries
configure:16162: result: yes
configure:16165: checking whether to build shared libraries
configure:16189: result: yes
configure:16192: checking whether to build static libraries
configure:16196: result: yes
configure:16548: checking for gfortran option to produce PIC
configure:16555: result: -fPIC
configure:16563: checking if gfortran PIC flag -fPIC works
configure:16581: gfortran -c -g -O2 -fPIC conftest.f >&5
configure:16585: $? = 0
configure:16598: result: yes
configure:16621: checking if gfortran static flag -static works
configure:16649: result: no
configure:16661: checking if gfortran supports -c -o file.o
configure:16682: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:16686: $? = 0
configure:16708: result: yes
configure:16713: checking if gfortran supports -c -o file.o
configure:16760: result: yes
configure:16790: checking whether the gfortran linker
configure:17999: result: yes
configure:18140: checking dynamic linker characteristics
configure:18879: result: GNU/Linux ld.so
configure:18944: checking how to hardcode library paths into programs
configure:18969: result: immediate
configure:16796: checking if libtool supports shared libraries
configure:16798: result: yes
configure:16801: checking whether to build shared libraries
configure:16825: result: yes
configure:16828: checking whether to build static libraries
configure:16832: result: yes
configure:16866: gfortran -c -g -O2 conftest.f >&5
configure:16869: $? = 0
configure:17329: checking for gfortran option to produce PIC
configure:17336: result: -fPIC
configure:17344: checking if gfortran PIC flag -fPIC works
configure:17362: gfortran -c -g -O2 -fPIC conftest.f >&5
configure:17366: $? = 0
configure:17379: result: yes
configure:17402: checking if gfortran static flag -static works
configure:17430: result: no
configure:17442: checking if gfortran supports -c -o file.o
configure:17463: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:17467: $? = 0
configure:17489: result: yes
configure:17494: checking if gfortran supports -c -o file.o
configure:17541: result: yes
configure:17571: checking whether the gfortran linker
configure:18780: result: yes
configure:18921: checking dynamic linker characteristics
configure:19660: result: GNU/Linux ld.so
configure:19725: checking how to hardcode library paths into programs
configure:19750: result: immediate
configure:17491: checking for ANSI C header files
configure:17595: result: yes
configure:17604: checking for C/C++ restrict keyword
configure:17629: gcc -c
conftest.c >&5
configure:17629: $? = 0
configure:17637: result: __restrict
configure:17654: checking for bash
configure:17673: found /bin/bash
configure:17685: result: /bin/bash
configure:17697: checking for git
configure:17715: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/git
configure:17727: result:
configure:17776: checking for smpicc
configure:17795: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicc
configure:17808: result:
configure:17824: checking whether mpicc is available
configure:17826: result:
configure:17853: checking for smpicxx
configure:17871: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicxx
configure:17884: result:
configure:17947: checking whether mpicxx is available
configure:17949: result:
configure:17977: checking for smpirun
configure:17995: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpirun
configure:18008: result:
configure:18017: checking whether mpiexec is available
configure:18019: result:
configure:18224: checking whether the master-slave mode should be enabled
configure:18226: result: no
configure:18237: checking maximum number of MPI master-slave devices
configure:18252: result: 0
configure:18309: checking whether MPI tests should be run
configure:18311: result: no
configure:18314: checking whether the StarPU MPI library should be generated
configure:18316: result: no
configure:18318: checking whether the StarPU MPI nmad library should be
generated
configure:18320: result: no
configure:18387: checking whether MPI debug messages should be displayed
configure:18396: result: no
configure:18477: checking maximum number of NUMA nodes
configure:18486: result: 2
configure:18501: checking for lib
configure:18534: result: no
configure:18616: checking size of void *
configure:18621: gcc -o conftest
configure:18621: $? = 0
configure:18621: ./conftest
configure:18635: result: 8
configure:18702: checking for unistd.h
configure:18702: result: yes
configure:18715: checking for struct timespec
configure:18715: gcc -c
conftest.c >&5
configure:18715: $? = 0
conftest.c >&5
conftest.c:112:30: error: expected expression before ')' token
if (sizeof ((struct timespec)))
configure:18715: $? = 1
| /* confdefs.h */
| #define restrict __restrict
| #define STARPU_MAXMPIDEVS 0
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_MAXNUMANODES 2
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/home/mathieu/Git/starpu"
| #define STARPU_SRC_DIR "/home/mathieu/Git/starpu/."
| #define STARPU_HAVE_UNISTD_H 1
| #include <sys/types.h>
| #include <sys/stat.h>
| #include <unistd.h>
| #endif
| #include <time.h>
| #include <pthread.h>
| int
| main ()
| return 0;
| return 0;
configure:18715: result: yes
configure:18757: checking for pthread_create in -lpthread
configure:18782: gcc -o conftest
conftest.c -lpthread -lsimgrid >&5
configure:18782: $? = 0
configure:18791: result: yes
configure:18802: checking for library containing sqrt
configure:18833: gcc -o conftest
conftest.c -lsimgrid -lpthread >&5
conftest.c:107:6: warning: conflicting types for built-in function 'sqrt'
[-Wbuiltin-declaration-mismatch]
char sqrt ();
ld: /tmp/ccqxrWlT.o: undefined reference to symbol 'sqrt@@GLIBC_2.2.5'
ld: /gnu/store/fa6wj5bxkj5ll1d7292a70knmyl7a0cr-glibc-2.31/lib/libm.so.6:
error adding symbols: DSO missing from command line
configure:18833: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_STRUCT_TIMESPEC 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
| return 0;
conftest.c -lm -lsimgrid -lpthread >&5
char sqrt ();
configure:18833: $? = 0
configure:18850: result: -lm
configure:18860: checking for main in -lws2_32
configure:18879: gcc -o conftest
conftest.c -lws2_32 -lm -lsimgrid -lpthread >&5
ld: cannot find -lws2_32
configure:18879: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
| return 0;
configure:18888: result: no
configure:18902: checking for sysconf
configure:18902: gcc -o conftest
configure:18902: $? = 0
configure:18902: result: yes
configure:18913: checking for getrlimit
configure:18913: gcc -o conftest
configure:18913: $? = 0
configure:18913: result: yes
configure:18924: checking for scandir
configure:18924: gcc -o conftest
configure:18924: $? = 0
configure:18924: result: yes
configure:18934: checking for pthread_spin_lock
configure:18934: gcc -o conftest
configure:18934: $? = 0
configure:18934: result: yes
configure:18950: checking for pthread_barrier_init
configure:18950: gcc -o conftest
configure:18950: $? = 0
configure:18950: result: yes
configure:18966: checking for pthread_setaffinity_np
configure:18966: gcc -o conftest
configure:18966: $? = 0
configure:18966: result: yes
configure:18976: checking for pthread_setname_np
configure:18976: gcc -o conftest
configure:18976: $? = 0
configure:18976: result: yes
configure:18990: checking whether PTHREAD_MUTEX_INITIALIZER just zeroes
configure:19015: gcc -o conftest
configure:19015: $? = 0
configure:19015: ./conftest
configure:19019: result: yes
configure:19030: checking whether PTHREAD_COND_INITIALIZER just zeroes
configure:19055: gcc -o conftest
configure:19055: $? = 0
configure:19055: ./conftest
configure:19059: result: yes
configure:19070: checking whether PTHREAD_RWLOCK_INITIALIZER just zeroes
configure:19095: gcc -o conftest
configure:19095: $? = 0
configure:19095: ./conftest
configure:19099: result: yes
configure:19115: checking for posix_memalign
configure:19115: gcc -o conftest
conftest.c:134:6: warning: conflicting types for built-in function
'posix_memalign' [-Wbuiltin-declaration-mismatch]
char posix_memalign ();
configure:19115: $? = 0
configure:19115: result: yes
configure:19128: checking for memalign
configure:19128: gcc -o conftest
configure:19128: $? = 0
configure:19128: result: yes
configure:19141: checking for drand48
configure:19141: gcc -o conftest
configure:19141: $? = 0
configure:19141: result: yes
configure:19148: checking for erand48_r
configure:19148: gcc -o conftest
configure:19148: $? = 0
configure:19148: result: yes
configure:19175: checking for strerror_r
configure:19175: gcc -o conftest
configure:19175: $? = 0
configure:19175: result: yes
configure:19184: checking for setenv
configure:19184: gcc -o conftest
configure:19184: $? = 0
configure:19184: result: yes
configure:19193: checking for unsetenv
configure:19193: gcc -o conftest
configure:19193: $? = 0
configure:19193: result: yes
configure:19202: checking for nearbyintf
configure:19202: gcc -o conftest
conftest.c:143:6: warning: conflicting types for built-in function
'nearbyintf' [-Wbuiltin-declaration-mismatch]
char nearbyintf ();
configure:19202: $? = 0
configure:19202: result: yes
configure:19211: checking for rintf
configure:19211: gcc -o conftest
conftest.c:144:6: warning: conflicting types for built-in function 'rintf'
char rintf ();
configure:19211: $? = 0
configure:19211: result: yes
configure:19287: checking malloc.h usability
configure:19287: gcc -c
conftest.c >&5
configure:19287: $? = 0
configure:19287: result: yes
configure:19287: checking malloc.h presence
configure:19287: gcc -E conftest.c
configure:19287: checking for malloc.h
configure:19310: checking valgrind/valgrind.h usability
configure:19310: gcc -c
conftest.c >&5
conftest.c:157:10: fatal error: valgrind/valgrind.h: No such file or directory
#include <valgrind/valgrind.h>
configure:19310: $? = 1
| /* confdefs.h */
| #define HAVE_SYSCONF 1
| #define HAVE_GETRLIMIT 1
| #define HAVE_SCANDIR 1
| #define HAVE_PTHREAD_SPIN_LOCK 1
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK 1
| #define STARPU_HAVE_PTHREAD_BARRIER 1
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define STARPU_HAVE_PTHREAD_SETNAME_NP 1
| #define STARPU_PTHREAD_MUTEX_INITIALIZER_ZERO 1
| #define STARPU_PTHREAD_COND_INITIALIZER_ZERO 1
| #define STARPU_PTHREAD_RWLOCK_INITIALIZER_ZERO 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:19310: result: no
configure:19310: checking valgrind/valgrind.h presence
configure:19310: gcc -E conftest.c
conftest.c:124:10: fatal error: valgrind/valgrind.h: No such file or directory
| /* confdefs.h */
configure:19310: checking for valgrind/valgrind.h
configure:19324: checking valgrind/memcheck.h usability
configure:19324: gcc -c
conftest.c >&5
conftest.c:157:10: fatal error: valgrind/memcheck.h: No such file or directory
#include <valgrind/memcheck.h>
configure:19324: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:19324: result: no
configure:19324: checking valgrind/memcheck.h presence
configure:19324: gcc -E conftest.c
conftest.c:124:10: fatal error: valgrind/memcheck.h: No such file or directory
| /* confdefs.h */
configure:19324: checking for valgrind/memcheck.h
configure:19338: checking valgrind/helgrind.h usability
configure:19338: gcc -c
conftest.c >&5
conftest.c:157:10: fatal error: valgrind/helgrind.h: No such file or directory
#include <valgrind/helgrind.h>
configure:19338: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:19338: result: no
configure:19338: checking valgrind/helgrind.h presence
configure:19338: gcc -E conftest.c
conftest.c:124:10: fatal error: valgrind/helgrind.h: No such file or directory
| /* confdefs.h */
configure:19338: checking for valgrind/helgrind.h
configure:19357: checking for sched_yield
configure:19357: gcc -o conftest
configure:19357: $? = 0
configure:19357: result: yes
configure:19367: checking aio.h usability
configure:19367: gcc -c
conftest.c >&5
configure:19367: $? = 0
configure:19367: result: yes
configure:19367: checking aio.h presence
configure:19367: gcc -E conftest.c
configure:19367: checking for aio.h
configure:19377: checking for aio_read in -lrt
configure:19402: gcc -o conftest
conftest.c -lrt -lm -lsimgrid -lpthread >&5
configure:19402: $? = 0
configure:19411: result: yes
configure:19426: checking for copy_file_range
configure:19426: gcc -o conftest
configure:19426: $? = 0
configure:19426: result: yes
configure:19438: checking for mkostemp
configure:19438: gcc -o conftest
configure:19438: $? = 0
configure:19438: result: yes
configure:19449: checking for mkdtemp
configure:19449: gcc -o conftest
configure:19449: $? = 0
configure:19449: result: yes
configure:19462: checking for pread
configure:19462: gcc -o conftest
configure:19462: $? = 0
configure:19462: result: yes
configure:19462: checking for pwrite
configure:19619: checking whether the target supports
__sync_val_compare_and_swap
configure:19636: gcc -o conftest
configure:19636: $? = 0
configure:19644: result: yes
configure:19654: checking whether the target supports
__sync_bool_compare_and_swap
configure:19671: gcc -o conftest
configure:19671: $? = 0
configure:19679: result: yes
configure:19689: checking whether the target supports __sync_fetch_and_add
configure:19706: gcc -o conftest
configure:19706: $? = 0
configure:19714: result: yes
configure:19724: checking whether the target supports __sync_fetch_and_or
configure:19741: gcc -o conftest
configure:19741: $? = 0
configure:19749: result: yes
configure:19759: checking whether the target supports __sync_lock_test_and_set
configure:19776: gcc -o conftest
configure:19776: $? = 0
configure:19784: result: yes
configure:19794: checking whether the target supports
__atomic_compare_exchange_n
configure:19811: gcc -o conftest
configure:19811: $? = 0
configure:19819: result: yes
configure:19829: checking whether the target supports __atomic_exchange_n
configure:19846: gcc -o conftest
configure:19846: $? = 0
configure:19854: result: yes
configure:19864: checking whether the target supports __atomic_fetch_add
configure:19881: gcc -o conftest
configure:19881: $? = 0
configure:19889: result: yes
configure:19899: checking whether the target supports __atomic_fetch_or
configure:19916: gcc -o conftest
configure:19916: $? = 0
configure:19924: result: yes
configure:19934: checking whether the target supports __atomic_test_and_set
configure:19951: gcc -o conftest
configure:19951: $? = 0
configure:19959: result: yes
configure:19969: checking whether the target supports __sync_synchronize
configure:19986: gcc -o conftest
configure:19986: $? = 0
configure:19994: result: yes
configure:20006: checking for library containing set_mempolicy
configure:20037: gcc -o conftest
-D_GNU_SOURCE -L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib
-lsimgrid conftest.c >&5
ld: /tmp/cccf251V.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:154: undefined reference to
`set_mempolicy'
configure:20037: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_LIBRT 1
| #define HAVE_COPY_FILE_RANGE 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_MKDTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_ATOMIC_COMPARE_EXCHANGE_N 1
| #define STARPU_HAVE_ATOMIC_EXCHANGE_N 1
| #define STARPU_HAVE_ATOMIC_FETCH_ADD 1
| #define STARPU_HAVE_ATOMIC_FETCH_OR 1
| #define STARPU_HAVE_ATOMIC_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
| return 0;
-lsimgrid conftest.c -lnuma >&5
ld: cannot find -lnuma
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
| return 0;
configure:20054: result: no
configure:20068: checking whether libnuma is available
configure:20070: result: no
configure:20078: checking whether statement expressions are available
configure:20093: gcc -c
-D_GNU_SOURCE conftest.c >&5
configure:20093: $? = 0
configure:20099: result: yes
configure:20112: checking maximum number of sched_ctxs
configure:20121: result: 10
configure:20199: checking maximum number of CPUs
configure:20208: result: 100
configure:20216: checking whether CPUs should be used
configure:20225: result: yes
configure:20250: checking maximum number of CUDA devices
configure:20259: result: 100
configure:20338: checking whether CUDA is available
configure:20341: result:
configure:20355: checking cuda.h usability
configure:20355: gcc -c
conftest.c:181:10: fatal error: cuda.h: No such file or directory
#include <cuda.h>
configure:20355: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_STATEMENT_EXPRESSIONS 1
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 100
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 100
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:20355: result: no
configure:20355: checking cuda.h presence
configure:20355: gcc -E -D_GNU_SOURCE conftest.c
conftest.c:148:10: fatal error: cuda.h: No such file or directory
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:20355: checking for cuda.h
configure:20783: checking whether CUDA is available
configure:20786: result:
configure:20800: checking cuda.h usability
configure:20800: gcc -c
#include <cuda.h>
configure:20800: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:20800: result: no
configure:20800: checking cuda.h presence
configure:20800: gcc -E -D_GNU_SOURCE conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:20800: checking for cuda.h
configure:21228: checking whether CUDA is available in /usr/local/cuda
configure:21234: result:
configure:21248: checking cuda.h usability
configure:21248: gcc -c
-D_GNU_SOURCE -I/usr/local/cuda/include conftest.c >&5
#include <cuda.h>
configure:21248: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:21248: result: no
configure:21248: checking cuda.h presence
configure:21248: gcc -E -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:21248: checking for cuda.h
configure:21228: checking whether CUDA is available in /c/cuda
-D_GNU_SOURCE -I/c/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:21248: gcc -E -D_GNU_SOURCE -I/c/cuda/include conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:21228: checking whether CUDA is available in /cygdrive/c/cuda
-D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:21248: gcc -E -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:21228: checking whether CUDA is available in /opt/cuda
-D_GNU_SOURCE -I/opt/cuda/include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:21248: gcc -E -D_GNU_SOURCE -I/opt/cuda/include conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:21228: checking whether CUDA is available in /..
-D_GNU_SOURCE -I/../include conftest.c >&5
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:21248: gcc -E -D_GNU_SOURCE -I/../include conftest.c
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
#include <cuda.h>
| /* confdefs.h */
| #include <cuda.h>
configure:21664: checking whether CUDA is working
configure:21728: result: no
configure:21739: checking whether CUDA should be used
configure:21741: result: no
configure:22090: checking whether MAGMA should be used
configure:22092: result: no
configure:22096: checking for cufftDoubleComplex
configure:22096: gcc -c
conftest.c:148:10: fatal error: cufft.h: No such file or directory
#include <cufft.h>
configure:22096: $? = 1
| /* confdefs.h */
| #include <cufft.h>
| int
| main ()
| if (sizeof (cufftDoubleComplex))
| return 0;
| return 0;
configure:22096: result: no
configure:22162: checking whether CURAND is available
configure:22164: result: no
configure:22208: checking maximum number of OpenCL devices
configure:22217: result: 8
configure:22330: checking whether OpenCL is available
configure:22333: result:
configure:22346: checking CL/cl.h usability
configure:22346: gcc -c
conftest.c:182:10: fatal error: CL/cl.h: No such file or directory
#include <CL/cl.h>
configure:22346: $? = 1
| /* confdefs.h */
| #define STARPU_MAXOPENCLDEVS 8
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22346: result: no
configure:22346: checking CL/cl.h presence
configure:22346: gcc -E -D_GNU_SOURCE conftest.c
conftest.c:149:10: fatal error: CL/cl.h: No such file or directory
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22346: checking for CL/cl.h
configure:22570: checking whether OpenCL is available in /usr/local/cuda no
and no
configure:22576: result:
configure:22589: checking CL/cl.h usability
configure:22589: gcc -c
#include <CL/cl.h>
configure:22589: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22589: result: no
configure:22589: checking CL/cl.h presence
configure:22589: gcc -E -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22589: checking for CL/cl.h
configure:22570: checking whether OpenCL is available in /c/cuda no and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22589: gcc -E -D_GNU_SOURCE -I/c/cuda/include conftest.c
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22570: checking whether OpenCL is available in /cygdrive/c/cuda no
and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22589: gcc -E -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22570: checking whether OpenCL is available in /opt/cuda no and no
#include <CL/cl.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22589: gcc -E -D_GNU_SOURCE -I/opt/cuda/include conftest.c
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22570: checking whether OpenCL is available in /.. no and no
#include <CL/cl.h>
compilation terminated.
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <CL/cl.h>
configure:22589: gcc -E -D_GNU_SOURCE -I/../include conftest.c
#include <CL/cl.h>
| /* confdefs.h */
| #include <CL/cl.h>
configure:22825: checking for clEnqueueMarkerWithWaitList
configure:22825: gcc -o conftest
-lsimgrid conftest.c -lrt -lm -lsimgrid -lpthread >&5
ld: /tmp/ccXNmEOQ.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:183: undefined reference to
`clEnqueueMarkerWithWaitList'
configure:22825: $? = 1
| /* confdefs.h */
| /* Define clEnqueueMarkerWithWaitList to an innocuous variant, in case
<limits.h> declares clEnqueueMarkerWithWaitList.
| #define clEnqueueMarkerWithWaitList innocuous_clEnqueueMarkerWithWaitList
| which can conflict with char clEnqueueMarkerWithWaitList (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef clEnqueueMarkerWithWaitList
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_clEnqueueMarkerWithWaitList || defined
__stub___clEnqueueMarkerWithWaitList
| choke me
| #endif
| int
| main ()
| return clEnqueueMarkerWithWaitList ();
| return 0;
configure:22825: result: no
configure:22837: checking whether OpenCL should be used
configure:22839: result: no
configure:22867: checking whether asynchronous copy should be disabled
configure:22880: result: no
configure:22888: checking whether asynchronous CUDA copy should be disabled
configure:22901: result: no
configure:22909: checking whether asynchronous OpenCL copy should be disabled
configure:22922: result: no
configure:22930: checking whether asynchronous MIC copy should be disabled
configure:22943: result: no
configure:22951: checking whether asynchronous MPI Master Slave copy should
be disabled
configure:22964: result: no
configure:23003: checking maximum number of MIC devices
configure:23018: result: 0
configure:23027: checking maximum number of MIC threads
configure:23036: result:
configure:23547: checking whether debug mode should be enabled
configure:23556: result: no
configure:23600: checking whether full gdb information should be enabled
configure:23609: result: yes
configure:23630: checking whether extra checks should be performed
configure:23639: result: no
configure:23656: checking whether debug messages should be displayed
configure:23665: result: no
configure:23681: checking whether coverage testing should be enabled
configure:23690: result: no
configure:23711: checking whether coverity mode should be enabled
configure:23720: result: no
configure:23732: checking whether FxT traces should be generated
configure:23741: result: yes
configure:23879: checking for FXT
configure:23887: $PKG_CONFIG --exists --print-errors "fxt"
configure:23890: $? = 0
configure:23905: $PKG_CONFIG --exists --print-errors "fxt"
configure:23908: $? = 0
configure:23963: result: yes
configure:23974: checking for enable_fut_flush
configure:23974: gcc -o conftest -O3
-gdwarf-2 -g3 -g -D_GNU_SOURCE -D_FORTIFY_SOURCE=1
-gdwarf-2 -g3 -g conftest.c -lrt -lm -lsimgrid -lpthread
-L/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/lib -lfxt >&5
configure:23974: $? = 0
configure:23974: result: yes
configure:23985: checking for fut_set_filename
configure:23985: gcc -o conftest -O3
configure:23985: $? = 0
configure:23985: result: yes
configure:23996: checking for fut_setup_flush_callback
configure:23996: gcc -o conftest -O3
ld: /tmp/ccSBUOzO.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:189: undefined reference to
`fut_setup_flush_callback'
configure:23996: $? = 1
| /* confdefs.h */
| #define STARPU_MAXMICDEVS 0
| #define STARPU_MAXMICCORES 120
| #define STARPU_USE_FXT 1
| #define CONFIG_FUT 1
| #define HAVE_ENABLE_FUT_FLUSH 1
| #define HAVE_FUT_SET_FILENAME 1
| /* Define fut_setup_flush_callback to an innocuous variant, in case
<limits.h> declares fut_setup_flush_callback.
| #define fut_setup_flush_callback innocuous_fut_setup_flush_callback
| which can conflict with char fut_setup_flush_callback (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef fut_setup_flush_callback
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_fut_setup_flush_callback || defined
__stub___fut_setup_flush_callback
| choke me
| #endif
| int
| main ()
| return fut_setup_flush_callback ();
| return 0;
configure:23996: result: no
configure:24009: checking whether enable_fut_flush is declared
configure:24009: gcc -c -O3
-gdwarf-2 -g3 -g
-I/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/include
-D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c >&5
configure:24009: $? = 0
configure:24009: result: yes
configure:24021: checking whether fut_set_filename is declared
configure:24021: gcc -c -O3
-gdwarf-2 -g3 -g
configure:24021: $? = 0
configure:24021: result: yes
configure:24033: checking whether fut_setup_flush_callback is declared
configure:24033: gcc -c -O3
-gdwarf-2 -g3 -g
conftest.c:166:10: error: 'fut_setup_flush_callback' undeclared (first use in
this function)
(void) fut_setup_flush_callback;
conftest.c:166:10: note: each undeclared identifier is reported only once for
each function it appears in
configure:24033: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.3.99"
| #define PACKAGE_STRING "StarPU 1.3.99"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://gitlab.inria.fr/starpu/starpu";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 3
| #define STARPU_RELEASE_VERSION 99
| #define PACKAGE "starpu"
| #define VERSION "1.3.99"
| #define HAVE_DECL_ENABLE_FUT_FLUSH 1
| #define HAVE_DECL_FUT_SET_FILENAME 1
| /* end confdefs.h. */
| #include <fut.h>
| int
| main ()
| #ifndef fut_setup_flush_callback
| #ifdef __cplusplus
| #else
| #endif
| #endif
| return 0;
configure:24033: result: no
configure:24053: checking for PAPI_library_init in -lpapi
configure:24078: gcc -o conftest -O3
-gdwarf-2 -g3 -g conftest.c -lpapi -lrt -lm -lsimgrid -lpthread >&5
ld: cannot find -lpapi
configure:24078: $? = 1
| /* confdefs.h */
| #define HAVE_DECL_FUT_SETUP_FLUSH_CALLBACK 0
| #ifdef __cplusplus
| extern "C"
| #endif
| char PAPI_library_init ();
| int
| main ()
| return PAPI_library_init ();
| return 0;
configure:24087: result: no
configure:24102: checking for POTI
configure:24110: $PKG_CONFIG --exists --print-errors "poti"
Package poti was not found in the pkg-config search path.
Perhaps you should add the directory containing `poti.pc'
to the PKG_CONFIG_PATH environment variable
No package 'poti' found
configure:24113: $? = 1
configure:24128: $PKG_CONFIG --exists --print-errors "poti"
configure:24131: $? = 1
configure:24159: result: no
configure:24202: checking whether additional locking systems FxT traces
should be enabled
configure:24211: result: no
configure:24219: checking whether performance debugging should be enabled
configure:24228: result: no
configure:24240: checking whether performance model debugging should be
enabled
configure:24249: result: no
configure:24257: checking whether memory stats should be displayed
configure:24266: result: no
configure:24284: checking glpk.h usability
configure:24284: gcc -c -O3
-gdwarf-2 -g3 -g -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c >&5
conftest.c:191:10: fatal error: glpk.h: No such file or directory
#include <glpk.h>
configure:24284: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:24284: result: no
configure:24284: checking glpk.h presence
configure:24284: gcc -E -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c
conftest.c:158:10: fatal error: glpk.h: No such file or directory
#include <glpk.h>
| /* confdefs.h */
| #include <glpk.h>
configure:24284: checking for glpk.h
configure:24298: checking for main in -lglpk
configure:24317: gcc -o conftest -O3
-gdwarf-2 -g3 -g conftest.c -lglpk >&5
ld: cannot find -lglpk
configure:24317: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
| return 0;
configure:24326: result: no
configure:24374: checking Ayudame.h usability
configure:24374: gcc -c -O3
conftest.c:191:10: fatal error: Ayudame.h: No such file or directory
#include <Ayudame.h>
configure:24374: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24374: result: no
configure:24374: checking Ayudame.h presence
configure:24374: gcc -E -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c
conftest.c:158:10: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
configure:24374: checking for Ayudame.h
configure:24394: checking ayudame.h usability
configure:24394: gcc -c -O3
conftest.c:191:10: fatal error: ayudame.h: No such file or directory
#include <ayudame.h>
configure:24394: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24394: result: no
configure:24394: checking ayudame.h presence
configure:24394: gcc -E -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c
conftest.c:158:10: fatal error: ayudame.h: No such file or directory
| /* confdefs.h */
configure:24394: checking for ayudame.h
configure:24454: checking how many buffers can be manipulated per task
configure:24463: result: 8
configure:24471: checking how many MPI nodes fxt files can be manipulated
when generating traces
configure:24480: result: 64
configure:24488: checking maximum number of memory nodes to use per MPI rank
configure:24544: checking maximum number of memory nodes
configure:24546: result: 32
configure:24555: checking whether allocation cache should be used
configure:24564: result: yes
configure:24598: checking using explicit performance model location
configure:24600: result: no
configure:24603: checking performance models location
configure:24605: result: $HOME/.starpu/sampling/
configure:24609: checking for clock_gettime in -lrt
configure:24634: gcc -o conftest -O3
-L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib -lsimgrid
-gdwarf-2 -g3 -g conftest.c -lrt -lrt -lm -lsimgrid -lpthread >&5
configure:24634: $? = 0
configure:24643: result: yes
configure:24656: checking for clock_gettime
configure:24656: gcc -o conftest -O3
configure:24656: $? = 0
configure:24656: result: yes
configure:24688: checking Maximum number of workers
configure:24690: result: 240
configure:24700: checking Maximum number of workers combinations
configure:24702: result: 220
configure:24713: checking maximum number of implementations
configure:24722: result: 4
configure:24823: checking calibration heuristic of history-based StarPU
calibrator
configure:24832: result: 50
configure:24876: checking Maximum number of message-passing kernels
configure:24885: result: 10
configure:24907: checking whether compiler support -Wall
configure:24929: gcc -o conftest -Wall -D_GNU_SOURCE -D_FORTIFY_SOURCE=1
conftest.c:175:18: warning: unused variable 'hello' [-Wunused-variable]
const char *hello = "Hello World";
configure:24929: $? = 0
configure:24932: result: yes
configure:24951: checking whether compiler support -Werror=implicit
configure:24973: gcc -o conftest -Werror=implicit -D_GNU_SOURCE
-D_FORTIFY_SOURCE=1
configure:24973: $? = 0
configure:24976: result: yes
configure:24995: checking whether compiler support
-Werror=implicit-function-declaration
configure:25017: gcc -o conftest -Werror=implicit-function-declaration
configure:25017: $? = 0
configure:25020: result: yes
configure:25536: gfortran -c -O3 -g -O2 -gdwarf-2 -g3 -g -cpp conftest.f >&5
configure:25536: $? = 0
configure:25752: checking for cluster support
configure:25835: result: no
configure:25872: checking for OpenMP runtime support
configure:25882: result: no incompatibility with Simgrid support
configure:25914: checking for SOCL
configure:25939: result: no
configure:25988: checking for gdb
configure:26006: found
/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gdb
configure:26019: result:
configure:26247: checking whether OpenGL rendering is enabled
configure:26251: result: no
configure:26262: checking for X
configure:26370: gcc -E -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c
conftest.c:171:10: fatal error: X11/Xlib.h: No such file or directory
#include <X11/Xlib.h>
configure:26370: $? = 1
| /* confdefs.h */
| #define HAVE_LIBSIMGRID 1
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_SIMGRID_MSG_H 1
| #define STARPU_HAVE_SIMGRID_MSG_H 1
| #define HAVE_SIMGRID_HOST_H 1
| #define STARPU_HAVE_SIMGRID_HOST_H 1
| #define HAVE_XBT_BASE_H 1
| #define STARPU_HAVE_XBT_BASE_H 1
| #define STARPU_NMAXBUFS 8
| #define STARPU_FXT_MAX_FILES 64
| #define STARPU_MAXNODES 32
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 240
| #define STARPU_NMAX_COMBINEDWORKERS 220
| #define STARPU_MAXIMPLEMENTATIONS 4
| #define STARPU_HISTORYMAXERROR 50
| #define STARPU_MAXMPKERNELS 10
| #define STARPU_HAVE_FC 1
| #define STARPU_GDB_PATH
"/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gdb"
configure:26401: gcc -o conftest -O3
-gdwarf-2 -g3 -g conftest.c -lX11 -lrt -lrt -lm -lsimgrid -lpthread >&5
configure:26401: $? = 1
| /* confdefs.h */
| int
| main ()
| XrmInitialize ()
| return 0;
configure:26440: result: no
configure:27360: checking for OPENBLAS
configure:27368: $PKG_CONFIG --exists --print-errors "openblas"
Package openblas was not found in the pkg-config search path.
Perhaps you should add the directory containing `openblas.pc'
No package 'openblas' found
configure:27371: $? = 1
configure:27386: $PKG_CONFIG --exists --print-errors "openblas"
configure:27389: $? = 1
configure:27417: result: no
configure:27869: checking for library containing sgemm_
configure:27900: gcc -o conftest -O3
-gdwarf-2 -g3 -g conftest.c >&5
ld: /tmp/ccPrfjMQ.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:183: undefined reference to `sgemm_'
configure:27900: $? = 1
| /* confdefs.h */
| #define X_DISPLAY_MISSING 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
-gdwarf-2 -g3 -g conftest.c -lblas >&5
ld: cannot find -lblas
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
configure:27917: result: no
configure:28012: checking which BLAS lib should be used
configure:28014: result: none
configure:28039: checking whether multiple linear regression models are
disabled
configure:28159: result: yes
configure:28192: checking for FFTW
configure:28200: $PKG_CONFIG --exists --print-errors "fftw3"
configure:28203: $? = 0
configure:28218: $PKG_CONFIG --exists --print-errors "fftw3"
configure:28221: $? = 0
configure:28257: result: yes
configure:28279: checking for FFTWF
configure:28287: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:28290: $? = 0
configure:28305: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:28308: $? = 0
configure:28344: result: yes
configure:28366: checking for FFTWL
configure:28374: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:28377: $? = 1
configure:28392: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:28395: $? = 1
configure:28423: result: no
configure:28640: checking for hwloc_topology_dup
configure:28640: gcc -o conftest -O3
ld: /tmp/ccetLYr8.o: in function `main':
/home/mathieu/Git/starpu/conftest.c:208: undefined reference to
`hwloc_topology_dup'
configure:28640: $? = 1
| /* confdefs.h */
| #define HAVE_SIMGRID_SIMDAG_H 1
| #define STARPU_HAVE_SIMGRID_SIMDAG_H 1
| #define HAVE_XBT_SYNCHRO_H 1
| #define STARPU_HAVE_XBT_SYNCHRO_H 1
| #define HAVE_XBT_CONFIG_H 1
| #define STARPU_HAVE_XBT_CONFIG_H 1
| #define HAVE_SIMGRID_ACTOR_H 1
| #define STARPU_HAVE_SIMGRID_ACTOR_H 1
| #define HAVE_SIMGRID_ENGINE_H 1
| #define STARPU_HAVE_SIMGRID_ENGINE_H 1
| #define HAVE_SIMGRID_SEMAPHORE_H 1
| #define STARPU_HAVE_SIMGRID_SEMAPHORE_H 1
| #define HAVE_SIMGRID_MUTEX_H 1
| #define STARPU_HAVE_SIMGRID_MUTEX_H 1
| #define HAVE_SIMGRID_COND_H 1
| #define STARPU_HAVE_SIMGRID_COND_H 1
| #define HAVE_SIMGRID_BARRIER_H 1
| #define STARPU_HAVE_SIMGRID_BARRIER_H 1
| #define HAVE_SIMGRID_ZONE_H 1
| #define STARPU_HAVE_SIMGRID_ZONE_H 1
| #define HAVE_SMX_ACTOR_T 1
| #define STARPU_HAVE_SMX_ACTOR_T 1
| #define HAVE_MSG_PROCESS_ATTACH 1
| #define HAVE_SG_ACTOR_ATTACH 1
| #define STARPU_HAVE_FFTW 1
| #define STARPU_HAVE_FFTWF 1
| /* Define hwloc_topology_dup to an innocuous variant, in case <limits.h>
declares hwloc_topology_dup.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define hwloc_topology_dup innocuous_hwloc_topology_dup
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char hwloc_topology_dup (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef hwloc_topology_dup
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_hwloc_topology_dup || defined __stub___hwloc_topology_dup
| choke me
| #endif
| int
| main ()
| return hwloc_topology_dup ();
| return 0;
configure:28640: result: no
configure:28651: checking for hwloc_topology_set_components
configure:28651: gcc -o conftest -O3
ld: /tmp/ccNzJBrq.o: in function `main':
`hwloc_topology_set_components'
collect2: error: ld returned 1 exit status
configure:28651: $? = 1
| /* confdefs.h */
| /* Define hwloc_topology_set_components to an innocuous variant, in case
<limits.h> declares hwloc_topology_set_components.
| #define hwloc_topology_set_components
innocuous_hwloc_topology_set_components
| which can conflict with char hwloc_topology_set_components (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef hwloc_topology_set_components
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_hwloc_topology_set_components || defined
__stub___hwloc_topology_set_components
| choke me
| #endif
| int
| main ()
| return hwloc_topology_set_components ();
| return 0;
configure:28651: result: no
configure:28673: checking whether hwloc should be used
configure:28675: result: no
configure:28680: checking f77.h usability
configure:28680: gcc -c -O3
conftest.c:207:10: fatal error: f77.h: No such file or directory
#include <f77.h>
configure:28680: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <f77.h>
configure:28680: result: no
configure:28680: checking f77.h presence
configure:28680: gcc -E -D_GNU_SOURCE -D_FORTIFY_SOURCE=1 conftest.c
conftest.c:174:10: fatal error: f77.h: No such file or directory
#include <f77.h>
| /* confdefs.h */
| #define HAVE_MSG_ZONE_GET_HOSTS 1
| #define HAVE_SG_ZONE_GET_HOSTS 1
| #define HAVE_MSG_PROCESS_SELF_NAME 1
| #define HAVE_MSG_PROCESS_USERDATA_INIT 1
| #define HAVE_SG_ACTOR_DATA 1
| #define HAVE_XBT_MUTEX_TRY_ACQUIRE 1
| #define HAVE_SMPI_PROCESS_SET_USER_DATA 1
| #include <f77.h>
configure:28680: checking for f77.h
configure:28719: checking for icc
configure:28749: result: no
configure:28818: checking for help2man
configure:28848: result: no
configure:28869: checking for struct cudaDeviceProp.pciDomainID
configure:28869: gcc -c -O3
conftest.c:174:10: fatal error: cuda_runtime_api.h: No such file or directory
#include <cuda_runtime_api.h>
configure:28869: $? = 1
| /* confdefs.h */
| int
| main ()
| static struct cudaDeviceProp ac_aggr;
| if (ac_aggr.pciDomainID)
| return 0;
| return 0;
| /* confdefs.h */
| #define HAVE_SG_ZONE_GET_BY_NAME 1
| #define HAVE_SG_LINK_NAME 1
| int
| main ()
| if (sizeof ac_aggr.pciDomainID)
| return 0;
| return 0;
configure:28869: result: no
configure:28878: checking for struct cudaDeviceProp.pciBusID
configure:28878: gcc -c -O3
configure:28878: $? = 1
| /* confdefs.h */
| int
| main ()
| if (ac_aggr.pciBusID)
| return 0;
| return 0;
| /* confdefs.h */
| int
| main ()
| if (sizeof ac_aggr.pciBusID)
| return 0;
| return 0;
configure:28878: result: no
configure:29240: checking for doxygen
configure:29273: result: no
configure:29284: checking for pdflatex
configure:29317: result: no
configure:29327: checking for epstopdf
configure:29360: result: no
configure:29380: checking whether HTML documentation should be compiled
configure:29382: result: no
configure:29384: checking whether HTML documentation is available
configure:29386: result: no
configure:29388: checking whether PDF documentation should be compiled
configure:29390: result: no
configure:29392: checking whether PDF documentation is available
configure:29394: result: no
configure:29665: checking that generated files are newer than configure
configure:29671: result: done
configure:30002: creating ./config.status
## Running config.status. ##
This file was extended by StarPU config.status 1.3.99, which was
generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on pc-inria
config.status:1938: creating tests/regression/regression.sh
config.status:1938: creating tests/regression/profiles
config.status:1938: creating tests/regression/profiles.build.only
config.status:1938: creating Makefile
config.status:1938: creating src/Makefile
config.status:1938: creating tools/Makefile
config.status:1938: creating tools/starpu_env
config.status:1938: creating tools/starpu_codelet_profile
config.status:1938: creating tools/starpu_codelet_histo_profile
config.status:1938: creating tools/starpu_mpi_comm_matrix.py
config.status:1938: creating tools/starpu_fxt_number_events_to_names.py
config.status:1938: creating tools/starpu_workers_activity
config.status:1938: creating tools/starpu_paje_draw_histogram
config.status:1938: creating tools/starpu_paje_state_stats
config.status:1938: creating tools/starpu_paje_summary
config.status:1938: creating tools/starpu_mlr_analysis
config.status:1938: creating tools/starpu_paje_sort
config.status:1938: creating tools/starpu_smpirun
config.status:1938: creating socl/Makefile
config.status:1938: creating socl/src/Makefile
config.status:1938: creating socl/examples/Makefile
config.status:1938: creating socl/vendors/socl.icd
config.status:1938: creating socl/vendors/install/socl.icd
config.status:1938: creating libstarpu.pc
config.status:1938: creating starpu-1.0.pc
config.status:1938: creating starpu-1.1.pc
config.status:1938: creating starpu-1.2.pc
config.status:1938: creating starpu-1.3.pc
config.status:1938: creating mpi/libstarpumpi.pc
config.status:1938: creating mpi/starpumpi-1.0.pc
config.status:1938: creating mpi/starpumpi-1.1.pc
config.status:1938: creating mpi/starpumpi-1.2.pc
config.status:1938: creating mpi/starpumpi-1.3.pc
config.status:1938: creating starpufft/Makefile
config.status:1938: creating starpufft/src/Makefile
config.status:1938: creating starpufft/tests/Makefile
config.status:1938: creating starpufft/libstarpufft.pc
config.status:1938: creating starpufft/starpufft-1.0.pc
config.status:1938: creating starpufft/starpufft-1.1.pc
config.status:1938: creating starpufft/starpufft-1.2.pc
config.status:1938: creating starpufft/starpufft-1.3.pc
config.status:1938: creating starpurm/Makefile
config.status:1938: creating starpurm/src/Makefile
config.status:1938: creating starpurm/examples/Makefile
config.status:1938: creating starpurm/starpurm-1.3.pc
config.status:1938: creating examples/Makefile
config.status:1938: creating examples/stencil/Makefile
config.status:1938: creating tests/Makefile
config.status:1938: creating tests/loader-cross.sh
config.status:1938: creating tests/model-checking/starpu-mc.sh
config.status:1938: creating examples/loader-cross.sh
config.status:1938: creating examples/stencil/loader-cross.sh
config.status:1938: creating mpi/Makefile
config.status:1938: creating mpi/src/Makefile
config.status:1938: creating mpi/tests/Makefile
config.status:1938: creating mpi/examples/Makefile
config.status:1938: creating mpi/tools/Makefile
config.status:1938: creating sc_hypervisor/Makefile
config.status:1938: creating sc_hypervisor/src/Makefile
config.status:1938: creating sc_hypervisor/examples/Makefile
config.status:1938: creating doc/Makefile
config.status:1938: creating doc/doxygen/Makefile
config.status:1938: creating doc/doxygen/doxygen-config.cfg
config.status:1938: creating doc/doxygen/doxygen_filter.sh
config.status:1938: creating doc/doxygen_dev/Makefile
config.status:1938: creating doc/doxygen_dev/doxygen-config.cfg
config.status:1938: creating doc/doxygen_dev/doxygen_filter.sh
config.status:1938: creating tools/msvc/starpu_var.bat
config.status:1938: creating min-dgels/Makefile
config.status:1938: creating julia/Makefile
config.status:1938: creating julia/src/Makefile
config.status:1938: creating julia/src/dynamic_compiler/Makefile
config.status:1938: creating julia/examples/Makefile
config.status:1938: creating julia/examples/execute.sh
config.status:1938: creating src/common/config.h
config.status:1938: creating include/starpu_config.h
config.status:1938: creating starpurm/include/starpurm_config.h
config.status:2119: starpurm/include/starpurm_config.h is unchanged
config.status:2198: executing depfiles commands
config.status:2275: cd src && sed -e '/# am--include-marker/d' Makefile
| make -f - am--depfiles
make: Nothing to be done for 'am--depfiles'.
config.status:2280: $? = 0
config.status:2275: cd tools && sed -e '/# am--include-marker/d'
Makefile | make -f - am--depfiles
config.status:2275: cd socl/src && sed -e '/# am--include-marker/d'
config.status:2275: cd socl/examples && sed -e '/#
am--include-marker/d' Makefile | make -f - am--depfiles
config.status:2275: cd starpufft/src && sed -e '/#
config.status:2275: cd starpufft/tests && sed -e '/#
config.status:2275: cd starpurm/src && sed -e '/# am--include-marker/d'
config.status:2275: cd starpurm/examples && sed -e '/#
config.status:2275: cd examples && sed -e '/# am--include-marker/d'
config.status:2275: cd examples/stencil && sed -e '/#
config.status:2275: cd tests && sed -e '/# am--include-marker/d'
config.status:2275: cd mpi/src && sed -e '/# am--include-marker/d'
config.status:2275: cd mpi/tests && sed -e '/# am--include-marker/d'
config.status:2275: cd mpi/examples && sed -e '/# am--include-marker/d'
config.status:2275: cd mpi/tools && sed -e '/# am--include-marker/d'
config.status:2275: cd sc_hypervisor/src && sed -e '/#
config.status:2275: cd sc_hypervisor/examples && sed -e '/#
config.status:2275: cd julia/src && sed -e '/# am--include-marker/d'
config.status:2275: cd julia/examples && sed -e '/#
config.status:2198: executing libtool commands
config.status:2198: executing executable-scripts commands
configure:33131:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: no
MIC enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
--enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 100
Maximum number of CUDA devices: 100
Maximum number of OpenCL devices: 8
Maximum number of MIC threads: 120
Maximum number of MPI master-slave devices: 0
Maximum number of memory nodes: 32
Maximum number of task buffers: 8
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: none
hwloc: no
FxT trace enabled: yes
Documentation HTML: no
Documentation PDF: no
Examples: yes
StarPU Extensions:
StarPU MPI enabled: no
StarPU MPI(nmad) enabled: no
MPI test suite: no
Master-Slave MPI enabled: no
FFT Support: yes
Resource Management enable: no
OpenMP runtime support enabled: no
Cluster support enabled: no
SOCL enabled: no
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: yes
ayudame enabled: no
HDF5 enabled: no
Native fortran support: yes
Native MPI fortran support: no
Support for multiple linear regression models: no
JULIA enabled: no
## Cache variables. ##
ac_cv_build=x86_64-pc-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_c_restrict=__restrict
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_BLAS_LIBS_set=
ac_cv_env_BLAS_LIBS_value=
ac_cv_env_BLAS_OPENBLAS_CFLAGS_set=
ac_cv_env_BLAS_OPENBLAS_CFLAGS_value=
ac_cv_env_BLAS_OPENBLAS_LIBS_set=
ac_cv_env_BLAS_OPENBLAS_LIBS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_DGELS_LIBS_set=
ac_cv_env_DGELS_LIBS_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=
ac_cv_env_FC_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FFTWF_CFLAGS_set=
ac_cv_env_FFTWF_CFLAGS_value=
ac_cv_env_FFTWF_LIBS_set=
ac_cv_env_FFTWF_LIBS_value=
ac_cv_env_FFTWL_CFLAGS_set=
ac_cv_env_FFTWL_CFLAGS_value=
ac_cv_env_FFTWL_LIBS_set=
ac_cv_env_FFTWL_LIBS_value=
ac_cv_env_FFTW_CFLAGS_set=
ac_cv_env_FFTW_CFLAGS_value=
ac_cv_env_FFTW_LIBS_set=
ac_cv_env_FFTW_LIBS_value=
ac_cv_env_FXT_CFLAGS_set=
ac_cv_env_FXT_CFLAGS_value=
ac_cv_env_FXT_LDFLAGS_set=
ac_cv_env_FXT_LDFLAGS_value=
ac_cv_env_FXT_LIBS_set=
ac_cv_env_FXT_LIBS_value=
ac_cv_env_HWLOC_CFLAGS_set=
ac_cv_env_HWLOC_CFLAGS_value=
ac_cv_env_HWLOC_LIBS_set=
ac_cv_env_HWLOC_LIBS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_LT_SYS_LIBRARY_PATH_set=
ac_cv_env_LT_SYS_LIBRARY_PATH_value=
ac_cv_env_MAGMA_CFLAGS_set=
ac_cv_env_MAGMA_CFLAGS_value=
ac_cv_env_MAGMA_LIBS_set=
ac_cv_env_MAGMA_LIBS_value=
ac_cv_env_NMAD_CFLAGS_set=
ac_cv_env_NMAD_CFLAGS_value=
ac_cv_env_NMAD_LIBS_set=
ac_cv_env_NMAD_LIBS_value=
ac_cv_env_NVCCFLAGS_set=
ac_cv_env_NVCCFLAGS_value=
ac_cv_env_NVCC_CC_set=
ac_cv_env_NVCC_CC_value=
ac_cv_env_NVCC_set=
ac_cv_env_NVCC_value=
ac_cv_env_OPENBLAS_CFLAGS_set=
ac_cv_env_OPENBLAS_CFLAGS_value=
ac_cv_env_OPENBLAS_LIBS_set=
ac_cv_env_OPENBLAS_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_POTI_CFLAGS_set=
ac_cv_env_POTI_CFLAGS_value=
ac_cv_env_POTI_LIBS_set=
ac_cv_env_POTI_LIBS_value=
ac_cv_env_SIMGRID_CFLAGS_set=
ac_cv_env_SIMGRID_CFLAGS_value=
ac_cv_env_SIMGRID_LIBS_set=
ac_cv_env_SIMGRID_LIBS_value=
ac_cv_env_STARPU_MS_LIB_set=
ac_cv_env_STARPU_MS_LIB_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=yes
ac_cv_fc_compiler_gnu=yes
ac_cv_func_MSG_environment_get_routing_root=no
ac_cv_func_MSG_get_as_by_name=no
ac_cv_func_MSG_host_get_speed=yes
ac_cv_func_MSG_process_attach=yes
ac_cv_func_MSG_process_self_name=yes
ac_cv_func_MSG_process_userdata_init=yes
ac_cv_func_MSG_zone_get_by_name=yes
ac_cv_func_MSG_zone_get_hosts=yes
ac_cv_func_SMPI_thread_create=no
ac_cv_func_clEnqueueMarkerWithWaitList=no
ac_cv_func_clock_gettime=yes
ac_cv_func_copy_file_range=yes
ac_cv_func_drand48=yes
ac_cv_func_enable_fut_flush=yes
ac_cv_func_erand48_r=yes
ac_cv_func_fut_set_filename=yes
ac_cv_func_fut_setup_flush_callback=no
ac_cv_func_getrlimit=yes
ac_cv_func_hwloc_topology_dup=no
ac_cv_func_hwloc_topology_set_components=no
ac_cv_func_memalign=yes
ac_cv_func_mkdtemp=yes
ac_cv_func_mkostemp=yes
ac_cv_func_nearbyintf=yes
ac_cv_func_posix_memalign=yes
ac_cv_func_pread=yes
ac_cv_func_pthread_barrier_init=yes
ac_cv_func_pthread_setaffinity_np=yes
ac_cv_func_pthread_setname_np=yes
ac_cv_func_pthread_spin_lock=yes
ac_cv_func_pwrite=yes
ac_cv_func_rintf=yes
ac_cv_func_scandir=yes
ac_cv_func_sched_yield=yes
ac_cv_func_setenv=yes
ac_cv_func_sg_actor_attach=yes
ac_cv_func_sg_actor_data=yes
ac_cv_func_sg_actor_execute=no
ac_cv_func_sg_actor_init=no
ac_cv_func_sg_actor_on_exit=no
ac_cv_func_sg_actor_ref=yes
ac_cv_func_sg_actor_self=yes
ac_cv_func_sg_actor_self_execute=yes
ac_cv_func_sg_actor_set_stacksize=no
ac_cv_func_sg_actor_sleep_for=yes
ac_cv_func_sg_cfg_set_int=yes
ac_cv_func_sg_config_continue_after_help=yes
ac_cv_func_sg_host_get_properties=yes
ac_cv_func_sg_host_list=yes
ac_cv_func_sg_host_route=yes
ac_cv_func_sg_host_self=yes
ac_cv_func_sg_host_send_to=yes
ac_cv_func_sg_host_sendto=no
ac_cv_func_sg_host_speed=yes
ac_cv_func_sg_link_bandwidth_set=no
ac_cv_func_sg_link_name=yes
ac_cv_func_sg_zone_get_by_name=yes
ac_cv_func_sg_zone_get_hosts=yes
ac_cv_func_simcall_process_create=no
ac_cv_func_simgrid_get_clock=yes
ac_cv_func_simgrid_init=yes
ac_cv_func_smpi_process_set_user_data=yes
ac_cv_func_strerror_r=yes
ac_cv_func_sysconf=yes
ac_cv_func_unsetenv=yes
ac_cv_func_xbt_barrier_init=no
ac_cv_func_xbt_mutex_try_acquire=yes
ac_cv_have_atomic_compare_exchange_n=yes
ac_cv_have_atomic_exchange_n=yes
ac_cv_have_atomic_fetch_add=yes
ac_cv_have_atomic_fetch_or=yes
ac_cv_have_atomic_test_and_set=yes
ac_cv_have_decl_enable_fut_flush=yes
ac_cv_have_decl_fut_set_filename=yes
ac_cv_have_decl_fut_setup_flush_callback=no
ac_cv_have_decl_smpi_process_set_user_data=yes
ac_cv_have_sync_bool_compare_and_swap=yes
ac_cv_have_sync_fetch_and_add=yes
ac_cv_have_sync_fetch_and_or=yes
ac_cv_have_sync_lock_test_and_set=yes
ac_cv_have_sync_synchronize=yes
ac_cv_have_sync_val_compare_and_swap=yes
ac_cv_have_x=have_x=no
ac_cv_header_Ayudame_h=no
ac_cv_header_aio_h=yes
ac_cv_header_ayudame_h=no
ac_cv_header_dlfcn_h=yes
ac_cv_header_f77_h=no
ac_cv_header_glpk_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_malloc_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_msg_msg_h=no
ac_cv_header_simgrid_actor_h=yes
ac_cv_header_simgrid_barrier_h=yes
ac_cv_header_simgrid_cond_h=yes
ac_cv_header_simgrid_engine_h=yes
ac_cv_header_simgrid_host_h=yes
ac_cv_header_simgrid_msg_h=yes
ac_cv_header_simgrid_mutex_h=yes
ac_cv_header_simgrid_semaphore_h=yes
ac_cv_header_simgrid_simdag_h=yes
ac_cv_header_simgrid_version_h=no
ac_cv_header_simgrid_zone_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_valgrind_helgrind_h=no
ac_cv_header_valgrind_memcheck_h=no
ac_cv_header_valgrind_valgrind_h=no
ac_cv_header_xbt_base_h=yes
ac_cv_header_xbt_config_h=yes
ac_cv_header_xbt_synchro_h=yes
ac_cv_host=x86_64-pc-linux-gnu
ac_cv_lib_glpk_main=no
ac_cv_lib_papi_PAPI_library_init=no
ac_cv_lib_pthread_pthread_create=yes
ac_cv_lib_rt_aio_read=yes
ac_cv_lib_rt_clock_gettime=yes
ac_cv_lib_simgrid=ac_cv_lib_simgrid_main
ac_cv_lib_simgrid_main=yes
ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=no
ac_cv_member_struct_cudaDeviceProp_pciBusID=no
ac_cv_member_struct_cudaDeviceProp_pciDomainID=no
ac_cv_objext=o
ac_cv_path_EGREP='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep
-E'
ac_cv_path_FGREP='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep
-F'
ac_cv_path_GDB=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gdb
ac_cv_path_GREP=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep
ac_cv_path_REALBASH=/bin/bash
ac_cv_path_SED=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/pkg-config
ac_cv_path_gitcommand=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/git
ac_cv_path_install='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/install
-c'
ac_cv_path_lt_DD=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/dd
ac_cv_path_mkdir=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/mkdir
ac_cv_path_mpicc_path=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicc
ac_cv_path_mpicxx_path=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicxx
ac_cv_path_mpiexec_path=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpirun
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_PROG_DATE=date
ac_cv_prog_PROG_STAT=stat
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_F77=gfortran
ac_cv_prog_ac_ct_FC=gfortran
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_fc_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_set_mempolicy=no
ac_cv_search_sgemm_=no
ac_cv_search_sqrt=-lm
ac_cv_sizeof_void_p=8
ac_cv_target=x86_64-pc-linux-gnu
ac_cv_type_cufftDoubleComplex=no
ac_cv_type_smx_actor_t=yes
ac_cv_type_struct_timespec=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_ar_interface=ar
am_cv_make_support_nested_variables=yes
am_cv_prog_cc_c_o=yes
ax_cv_cxx_compile_cxx11=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld
lt_cv_path_LDCXX='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld
-m elf_x86_64'
lt_cv_path_NM='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_c_o_FC=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=-fPIC
lt_cv_prog_compiler_pic_FC=-fPIC
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_pic_works_F77=yes
lt_cv_prog_compiler_pic_works_FC=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=no
lt_cv_prog_compiler_static_works_CXX=no
lt_cv_prog_compiler_static_works_F77=no
lt_cv_prog_compiler_static_works_FC=no
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=yes
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[
]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][
]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \(.*\) .*$/
{"\1", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]* .* \(.*\)$/
{"\1", (void *) \&\1},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^:
\(.*\) .*$/ {"\1", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]* .*
\(lib.*\)$/ {"\1", (void *) \&\1},/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]*
.* \(.*\)$/ {"lib\1", (void *) \&\1},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int
\1();/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]* .* \(.*\)$/extern char
\1;/p'\'''
lt_cv_sys_global_symbol_to_import=
lt_cv_sys_max_cmd_len=1572864
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
lt_cv_truncate_bin='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/dd
bs=4096 count=1'
pkg_cv_FFTWF_CFLAGS=-I/gnu/store/02z5vgdhgxw4gcjvhx51mvy1ax4lzxmp-fftwf-3.3.8/include
pkg_cv_FFTWF_LIBS='-L/gnu/store/02z5vgdhgxw4gcjvhx51mvy1ax4lzxmp-fftwf-3.3.8/lib
-lfftw3f'
pkg_cv_FFTW_CFLAGS=-I/gnu/store/85b70gpbs9issc1gbdcvnwb8pip6ihlk-fftw-3.3.8/include
pkg_cv_FFTW_LIBS='-L/gnu/store/85b70gpbs9issc1gbdcvnwb8pip6ihlk-fftw-3.3.8/lib
-lfftw3'
pkg_cv_FXT_CFLAGS=-I/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/include
pkg_cv_FXT_LIBS='-L/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/lib
-lfxt'
pkg_cv_SIMGRID_CFLAGS=-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include
pkg_cv_SIMGRID_LIBS='-L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib
-lsimgrid'
## Output variables. ##
#define _STARPU_FUT_CODELET_DATA 0x513f
#define _STARPU_FUT_CODELET_DETAILS 0x513e
#define _STARPU_FUT_END_ALLOC 0x5128
#define _STARPU_FUT_END_ALLOC_REUSE 0x5130
#define _STARPU_FUT_END_CALLBACK 0x5124
#define _STARPU_FUT_END_CODELET_BODY 0x5103
#define _STARPU_FUT_END_DRIVER_COPY 0x5134
#define _STARPU_FUT_END_DRIVER_COPY_ASYNC 0x5136
#define _STARPU_FUT_END_EXECUTING 0x5169
#define _STARPU_FUT_END_FREE 0x5157
#define _STARPU_FUT_END_MEMRECLAIM 0x5132
#define _STARPU_FUT_END_PROGRESS_ON_TID 0x5138
#define _STARPU_FUT_END_WRITEBACK 0x5159
#define _STARPU_FUT_END_WRITEBACK_ASYNC 0x515d
#define _STARPU_FUT_HYPERVISOR_BEGIN 0x5160
#define _STARPU_FUT_HYPERVISOR_END 0x5161
#define _STARPU_FUT_NEW_MEM_NODE 0x5122
#define _STARPU_FUT_START_ALLOC 0x5127
#define _STARPU_FUT_START_ALLOC_REUSE 0x5129
#define _STARPU_FUT_START_CALLBACK 0x5123
#define _STARPU_FUT_START_CODELET_BODY 0x5102
#define _STARPU_FUT_START_DRIVER_COPY 0x5133
#define _STARPU_FUT_START_DRIVER_COPY_ASYNC 0x5135
#define _STARPU_FUT_START_EXECUTING 0x5168
#define _STARPU_FUT_START_FREE 0x5156
#define _STARPU_FUT_START_MEMRECLAIM 0x5131
#define _STARPU_FUT_START_PROGRESS_ON_TID 0x5137
#define _STARPU_FUT_START_WRITEBACK 0x5158
#define _STARPU_FUT_START_WRITEBACK_ASYNC 0x515c
#define _STARPU_FUT_TAG_DONE 0x5126
#define _STARPU_FUT_TASK_DONE 0x5125
#define _STARPU_FUT_USED_MEM 0x512a
#define _STARPU_FUT_BARRIER_WAIT_BEGIN 0x5162
#define _STARPU_FUT_BARRIER_WAIT_END 0x5163
#define _STARPU_FUT_CODELET_DATA_HANDLE 0x511b
#define _STARPU_FUT_COND_WAIT_BEGIN 0x5150
#define _STARPU_FUT_COND_WAIT_END 0x5151
#define _STARPU_FUT_DATA_COORDINATES 0x511e
#define _STARPU_FUT_DATA_COPY 0x5114
#define _STARPU_FUT_DATA_DOING_WONT_USE 0x512e
#define _STARPU_FUT_DATA_LOAD 0x5153
#define _STARPU_FUT_DATA_NAME 0x511d
#define _STARPU_FUT_DATA_REQUEST_CREATED 0x5185
#define _STARPU_FUT_DATA_STATE_INVALID 0x5182
#define _STARPU_FUT_DATA_STATE_OWNER 0x5183
#define _STARPU_FUT_DATA_STATE_SHARED 0x5184
#define _STARPU_FUT_DATA_WONT_USE 0x512c
#define _STARPU_FUT_END_FETCH_INPUT 0x517f
#define _STARPU_FUT_END_FETCH_INPUT_ON_TID 0x5108
#define _STARPU_FUT_END_PUSH_OUTPUT_ON_TID 0x5110
#define _STARPU_FUT_END_UNPARTITION_ON_TID 0x5155
#define _STARPU_FUT_EVENT 0x513c
#define _STARPU_FUT_HANDLE_DATA_REGISTER 0x517c
#define _STARPU_FUT_HANDLE_DATA_UNREGISTER 0x511f
#define _STARPU_FUT_JOB_POP 0x5105
#define _STARPU_FUT_JOB_PUSH 0x5104
#define _STARPU_FUT_LOCKING_MUTEX 0x5140
#define _STARPU_FUT_LOCKING_SPINLOCK 0x514b
#define _STARPU_FUT_MEMORY_FULL 0x5152
#define _STARPU_FUT_MODEL_NAME 0x511c
#define _STARPU_FUT_MUTEX_LOCKED 0x5141
#define _STARPU_FUT_MUTEX_UNLOCKED 0x5143
#define _STARPU_FUT_PAPI_TASK_EVENT_VALUE 0x5186
#define _STARPU_FUT_RDLOCKING_RWLOCK 0x5145
#define _STARPU_FUT_RWLOCK_RDLOCKED 0x5146
#define _STARPU_FUT_RWLOCK_UNLOCKED 0x514a
#define _STARPU_FUT_RWLOCK_WRLOCKED 0x5148
#define _STARPU_FUT_SCHED_COMPONENT_CONNECT 0x516b
#define _STARPU_FUT_SCHED_COMPONENT_NEW 0x516a
#define _STARPU_FUT_SCHED_COMPONENT_POP_PRIO 0x515b
#define _STARPU_FUT_SCHED_COMPONENT_PULL 0x516d
#define _STARPU_FUT_SCHED_COMPONENT_PUSH 0x516c
#define _STARPU_FUT_SCHED_COMPONENT_PUSH_PRIO 0x515a
#define _STARPU_FUT_SET_PROFILING 0x513a
#define _STARPU_FUT_SPINLOCK_LOCKED 0x514c
#define _STARPU_FUT_SPINLOCK_UNLOCKED 0x514e
#define _STARPU_FUT_START_FETCH_INPUT 0x517e
#define _STARPU_FUT_START_FETCH_INPUT_ON_TID 0x5107
#define _STARPU_FUT_START_PUSH_OUTPUT_ON_TID 0x5109
#define _STARPU_FUT_START_UNPARTITION_ON_TID 0x5154
#define _STARPU_FUT_TAG 0x5111
#define _STARPU_FUT_TAG_DEPS 0x5112
#define _STARPU_FUT_TASK_BUILD_END 0x5171
#define _STARPU_FUT_TASK_BUILD_START 0x5170
#define _STARPU_FUT_TASK_COLOR 0x512d
#define _STARPU_FUT_TASK_DEPS 0x5113
#define _STARPU_FUT_TASK_MPI_DECODE_END 0x5173
#define _STARPU_FUT_TASK_MPI_DECODE_START 0x5172
#define _STARPU_FUT_TASK_MPI_POST_END 0x5177
#define _STARPU_FUT_TASK_MPI_POST_START 0x5176
#define _STARPU_FUT_TASK_MPI_PRE_END 0x5175
#define _STARPU_FUT_TASK_MPI_PRE_START 0x5174
#define _STARPU_FUT_TASK_NAME 0x512b
#define _STARPU_FUT_TASK_SUBMIT 0x511a
#define _STARPU_FUT_TASK_SUBMIT_END 0x516f
#define _STARPU_FUT_TASK_SUBMIT_START 0x516e
#define _STARPU_FUT_TASK_THROTTLE_END 0x5181
#define _STARPU_FUT_TASK_THROTTLE_START 0x5180
#define _STARPU_FUT_TASK_WAIT_END 0x5179
#define _STARPU_FUT_TASK_WAIT_FOR_ALL 0x513b
#define _STARPU_FUT_TASK_WAIT_FOR_ALL_END 0x517b
#define _STARPU_FUT_TASK_WAIT_FOR_ALL_START 0x517a
#define _STARPU_FUT_TASK_WAIT_START 0x5178
#define _STARPU_FUT_THREAD_EVENT 0x513d
#define _STARPU_FUT_TRYLOCK_MUTEX 0x5144
#define _STARPU_FUT_TRYLOCK_SPINLOCK 0x514f
#define _STARPU_FUT_UNLOCKING_MUTEX 0x5142
#define _STARPU_FUT_UNLOCKING_RWLOCK 0x5149
#define _STARPU_FUT_UNLOCKING_SPINLOCK 0x514d
#define _STARPU_FUT_UPDATE_TASK_CNT 0x5106
#define _STARPU_FUT_USER_DEFINED_END 0x5121
#define _STARPU_FUT_USER_DEFINED_START 0x5120
#define _STARPU_FUT_USER_EVENT 0x5139
#define _STARPU_FUT_WORKER_DEINIT_END 0x5117
#define _STARPU_FUT_WORKER_DEINIT_START 0x5116
#define _STARPU_FUT_WORKER_INIT_END 0x5101
#define _STARPU_FUT_WORKER_SCHEDULING_END 0x5165
#define _STARPU_FUT_WORKER_SCHEDULING_POP 0x5167
#define _STARPU_FUT_WORKER_SCHEDULING_PUSH 0x5166
#define _STARPU_FUT_WORKER_SCHEDULING_START 0x5164
#define _STARPU_FUT_WORKER_SLEEP_END 0x5119
#define _STARPU_FUT_WORKER_SLEEP_START 0x5118
#define _STARPU_FUT_WORK_STEALING 0x5115
#define _STARPU_FUT_WRLOCKING_RWLOCK 0x5147
#define _STARPU_MPI_FUT_BARRIER 0x5203
#define _STARPU_MPI_FUT_DATA_SET_RANK 0x521a
#define _STARPU_MPI_FUT_DATA_SET_TAG 0x5218'
#define _STARPU_MPI_FUT_DRIVER_RUN_BEGIN 0x5216
#define _STARPU_MPI_FUT_DRIVER_RUN_END 0x5217
#define _STARPU_MPI_FUT_DTESTING_BEGIN 0x520e
#define _STARPU_MPI_FUT_DTESTING_END 0x520f
#define _STARPU_MPI_FUT_IRECV_COMPLETE_BEGIN 0x520a
#define _STARPU_MPI_FUT_IRECV_COMPLETE_END 0x520b
#define _STARPU_MPI_FUT_IRECV_SUBMIT_BEGIN 0x5206
#define _STARPU_MPI_FUT_IRECV_SUBMIT_END 0x5207
#define _STARPU_MPI_FUT_IRECV_TERMINATED 0x521b
#define _STARPU_MPI_FUT_ISEND_COMPLETE_BEGIN 0x5208
#define _STARPU_MPI_FUT_ISEND_COMPLETE_END 0x5209
#define _STARPU_MPI_FUT_ISEND_SUBMIT_BEGIN 0x5204
#define _STARPU_MPI_FUT_ISEND_SUBMIT_END 0x5205
#define _STARPU_MPI_FUT_ISEND_TERMINATED 0x521c
#define _STARPU_MPI_FUT_POLLING_BEGIN 0x5214
#define _STARPU_MPI_FUT_POLLING_END 0x5215
#define _STARPU_MPI_FUT_SLEEP_BEGIN 0x520c
#define _STARPU_MPI_FUT_SLEEP_END 0x520d
#define _STARPU_MPI_FUT_START 0x5201
#define _STARPU_MPI_FUT_STOP 0x5202
#define _STARPU_MPI_FUT_TESTING_DETACHED_BEGIN 0x521d
#define _STARPU_MPI_FUT_TESTING_DETACHED_END 0x521e
#define _STARPU_MPI_FUT_TEST_BEGIN 0x521f
#define _STARPU_MPI_FUT_TEST_END 0x5220
#define _STARPU_MPI_FUT_UTESTING_BEGIN 0x5210
#define _STARPU_MPI_FUT_UTESTING_END 0x5211
#define _STARPU_MPI_FUT_UWAIT_BEGIN 0x5212
#define _STARPU_MPI_FUT_UWAIT_END 0x5213
ACLOCAL='${SHELL} /home/mathieu/Git/starpu/build-aux/missing aclocal-1.16'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='0'
AM_V='$(V)'
AR='ar'
AS='as'
ATLASDIR=''
AUTOCONF='${SHELL} /home/mathieu/Git/starpu/build-aux/missing autoconf'
AUTOHEADER='${SHELL} /home/mathieu/Git/starpu/build-aux/missing autoheader'
AUTOMAKE='${SHELL} /home/mathieu/Git/starpu/build-aux/missing automake-1.16'
AWK='gawk'
BLAS_LIB='none'
BLAS_LIBS=''
BLAS_OPENBLAS_CFLAGS=''
BLAS_OPENBLAS_LIBS=''
CC='gcc'
CCDEPMODE='depmode=gcc3'
CC_OR_MPICC='gcc'
CC_OR_NVCC='gcc'
CFLAGS='-O3
-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include -g -O2
-gdwarf-2 -g3 -g '
COVERAGE='no'
CPP='gcc -E'
CPPFLAGS=' -D_GNU_SOURCE -D_FORTIFY_SOURCE=1'
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-O3
-gdwarf-2 -g3 -g '
CYGPATH_W='echo'
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DGELS_LIBS=''
DLB_CFLAGS=''
DLB_LIBS=''
DLLTOOL='false'
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep -E'
EXEEXT=''
F77='gfortran'
FC='gfortran'
FCFLAGS='-O3 -g -O2 -gdwarf-2 -g3 -g '
FFLAGS='-O3 -g -O2 -gdwarf-2 -g3 -g '
FFTWF_CFLAGS='-I/gnu/store/02z5vgdhgxw4gcjvhx51mvy1ax4lzxmp-fftwf-3.3.8/include'
-lfftw3f'
FFTWL_CFLAGS=''
FFTWL_LIBS=''
FFTW_CFLAGS='-I/gnu/store/85b70gpbs9issc1gbdcvnwb8pip6ihlk-fftw-3.3.8/include'
-lfftw3'
FGREP='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep -F'
FXTDIR=''
FXT_CFLAGS='-I/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/include'
FXT_LDFLAGS=''
FXT_LIBS='-L/gnu/store/n7zw9fr9i7k6nbin76r0ma7wbqcgpqgd-fxt-0.3.3/lib -lfxt'
GDB='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/gdb'
GLOBAL_AM_CFLAGS=' -Wall -Werror=implicit
-Werror=implicit-function-declaration'
GOTODIR=''
GREP='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/grep'
HAVE_CXX11='1'
HAVE_FFTWFL=''
HELP2MAN=''
HWLOC_CFLAGS=''
HWLOC_LIBS=''
HWLOC_REQUIRES=''
ICC=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
JULIA=''
LD='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/ld -m elf_x86_64'
LDFLAGS='-L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib
-lsimgrid -gdwarf-2 -g3 -g '
LIBOBJS=''
LIBS='-lrt -lrt -lm -lsimgrid -lpthread'
LIBSOCL_INTERFACE_AGE='0'
LIBSOCL_INTERFACE_CURRENT='0'
LIBSOCL_INTERFACE_REVISION='0'
LIBSTARPUFFT_INTERFACE_AGE='0'
LIBSTARPUFFT_INTERFACE_CURRENT='0'
LIBSTARPUFFT_INTERFACE_REVISION='0'
LIBSTARPUJULIA_INTERFACE_AGE='0'
LIBSTARPUJULIA_INTERFACE_CURRENT='0'
LIBSTARPUJULIA_INTERFACE_REVISION='0'
LIBSTARPUMPI_INTERFACE_AGE='0'
LIBSTARPUMPI_INTERFACE_CURRENT='0'
LIBSTARPUMPI_INTERFACE_REVISION='0'
LIBSTARPURM_INTERFACE_AGE='0'
LIBSTARPURM_INTERFACE_CURRENT='0'
LIBSTARPURM_INTERFACE_REVISION='0'
LIBSTARPU_INTERFACE_AGE='0'
LIBSTARPU_INTERFACE_CURRENT='0'
LIBSTARPU_INTERFACE_REVISION='0'
LIBSTARPU_LDFLAGS='
-L/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/lib -lsimgrid '
LIBSTARPU_LINK='libstarpu-1.3.la'
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
LT_SYS_LIBRARY_PATH=''
MAGMA_CFLAGS=''
MAGMA_LIBS=''
MAKEINFO='${SHELL} /home/mathieu/Git/starpu/build-aux/missing makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/mkdir -p'
MPICC='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicc'
MPICC_LDFLAGS=''
MPICXX='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicxx'
MPIEXEC='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpirun'
MPIEXEC_ARGS=''
MPIFORT=''
NMAD_CFLAGS=''
NMAD_LIBS=''
NMEDIT=''
NVCC=''
NVCCFLAGS='-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include
NVCC_CC=''
OBJDUMP='objdump'
OBJEXT='o'
OPENBLAS_CFLAGS=''
OPENBLAS_LIBS=''
OPENMP_CFLAGS=''
OTOOL64=''
OTOOL=''
PACKAGE='starpu'
PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME='StarPU'
PACKAGE_STRING='StarPU 1.3.99'
PACKAGE_TARNAME='starpu'
PACKAGE_URL='http://gitlab.inria.fr/starpu/starpu'
PACKAGE_VERSION='1.3.99'
PATH_SEPARATOR=':'
PKG_CONFIG='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/pkg-config'
POTI_CFLAGS=''
POTI_LIBS=''
PROG_DATE='date'
PROG_STAT='stat'
RANLIB='ranlib'
REALBASH='/bin/bash'
SED='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/sed'
SET_MAKE=''
SHELL='/bin/bash'
SIMGRID_CFLAGS='-I/gnu/store/fif3qkk03ss9adqz6cqjjwk1splq6sz4-simgrid-3.24/include'
-lsimgrid'
SIMGRID_MC=''
SOCL_OCL_LIB_OPENCL_DIR=''
SOCL_VENDORS='vendors/install/socl.icd'
STARPURM_HAVE_DLB_FALSE=''
STARPURM_HAVE_DLB_TRUE='#'
STARPU_ATLAS_BLAS_LIB_FALSE=''
STARPU_ATLAS_BLAS_LIB_TRUE='#'
STARPU_AVAILABLE_DOC_FALSE=''
STARPU_AVAILABLE_DOC_PDF_FALSE=''
STARPU_AVAILABLE_DOC_PDF_TRUE='#'
STARPU_AVAILABLE_DOC_TRUE='#'
STARPU_BLAS_LDFLAGS=' '
STARPU_BUILD_DIR='/home/mathieu/Git/starpu'
STARPU_BUILD_DOC_FALSE=''
STARPU_BUILD_DOC_PDF_FALSE=''
STARPU_BUILD_DOC_PDF_TRUE='#'
STARPU_BUILD_DOC_TRUE='#'
STARPU_BUILD_EXAMPLES_FALSE='#'
STARPU_BUILD_EXAMPLES_TRUE=''
STARPU_BUILD_SC_HYPERVISOR_FALSE=''
STARPU_BUILD_SC_HYPERVISOR_TRUE='#'
STARPU_BUILD_SOCL_FALSE=''
STARPU_BUILD_SOCL_TRUE='#'
STARPU_BUILD_STARPUFFT_EXAMPLES_FALSE=''
STARPU_BUILD_STARPUFFT_EXAMPLES_TRUE='#'
STARPU_BUILD_STARPUFFT_FALSE='#'
STARPU_BUILD_STARPUFFT_TRUE=''
STARPU_BUILD_STARPURM_EXAMPLES_FALSE=''
STARPU_BUILD_STARPURM_EXAMPLES_TRUE='#'
STARPU_BUILD_STARPURM_FALSE=''
STARPU_BUILD_STARPURM_TRUE='#'
STARPU_BUILD_TESTS_FALSE='#'
STARPU_BUILD_TESTS_TRUE=''
STARPU_CLUSTER_FALSE=''
STARPU_CLUSTER_TRUE='#'
STARPU_COI_CPPFLAGS=''
STARPU_COI_LDFLAGS=''
STARPU_COVERAGE_ENABLED_FALSE=''
STARPU_COVERAGE_ENABLED_TRUE='#'
STARPU_COVERITY_FALSE=''
STARPU_COVERITY_TRUE='#'
STARPU_CROSS_COMPILING_FALSE=''
STARPU_CROSS_COMPILING_TRUE='#'
STARPU_CUDA_CPPFLAGS=''
STARPU_CUDA_FORTRAN_LDFLAGS=''
STARPU_CUDA_LDFLAGS=''
STARPU_CUFFT_LDFLAGS=''
STARPU_CURAND_LDFLAGS=''
STARPU_DEVEL_FALSE=''
STARPU_DEVEL_TRUE='#'
STARPU_EFFECTIVE_VERSION='1.3'
STARPU_EXPORTED_LIBS=' -lpthread'
STARPU_EXPORT_DYNAMIC=''
STARPU_FXT_EVENT_DEFINES='#define _STARPU_FUT_WORKER_INIT_START 0x5100
STARPU_GLPK_LDFLAGS=' '
STARPU_GOTO_BLAS_LIB_FALSE=''
STARPU_GOTO_BLAS_LIB_TRUE='#'
STARPU_HAVE_AM111_FALSE='#'
STARPU_HAVE_AM111_TRUE=''
STARPU_HAVE_CBLAS_H_FALSE=''
STARPU_HAVE_CBLAS_H_TRUE='#'
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE='#'
STARPU_HAVE_CXX11='1'
STARPU_HAVE_CXX11_FALSE='#'
STARPU_HAVE_CXX11_TRUE=''
STARPU_HAVE_DARWIN_FALSE=''
STARPU_HAVE_DARWIN_TRUE='#'
STARPU_HAVE_F77_FALSE='#'
STARPU_HAVE_F77_H='no'
STARPU_HAVE_F77_H_FALSE=''
STARPU_HAVE_F77_H_TRUE='#'
STARPU_HAVE_F77_TRUE=''
STARPU_HAVE_FC_FALSE='#'
STARPU_HAVE_FC_TRUE=''
STARPU_HAVE_FFTW='1'
STARPU_HAVE_FFTWF='1'
STARPU_HAVE_FFTWF_FALSE='#'
STARPU_HAVE_FFTWF_TRUE=''
STARPU_HAVE_FFTWL_FALSE=''
STARPU_HAVE_FFTWL_TRUE='#'
STARPU_HAVE_FFTW_FALSE='#'
STARPU_HAVE_FFTW_TRUE=''
STARPU_HAVE_HDF5_FALSE=''
STARPU_HAVE_HDF5_TRUE='#'
STARPU_HAVE_HELP2MAN_FALSE=''
STARPU_HAVE_HELP2MAN_TRUE='#'
STARPU_HAVE_HWLOC=''
STARPU_HAVE_HWLOC_FALSE=''
STARPU_HAVE_HWLOC_TRUE='#'
STARPU_HAVE_ICC_FALSE=''
STARPU_HAVE_ICC_TRUE='#'
STARPU_HAVE_LEVELDB_FALSE=''
STARPU_HAVE_LEVELDB_TRUE='#'
STARPU_HAVE_MAGMA=''
STARPU_HAVE_MAGMA_FALSE=''
STARPU_HAVE_MAGMA_TRUE='#'
STARPU_HAVE_MPIFORT_FALSE=''
STARPU_HAVE_MPIFORT_TRUE='#'
STARPU_HAVE_MS_LIB_FALSE=''
STARPU_HAVE_MS_LIB_TRUE='#'
STARPU_HAVE_OPENGL_FALSE=''
STARPU_HAVE_OPENGL_TRUE='#'
STARPU_HAVE_OPENMP_FALSE=''
STARPU_HAVE_OPENMP_TRUE='#'
STARPU_HAVE_WINDOWS_FALSE=''
STARPU_HAVE_WINDOWS_TRUE='#'
STARPU_HAVE_X11_FALSE=''
STARPU_HAVE_X11_TRUE='#'
STARPU_HDF5_LDFLAGS=''
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_FALSE=''
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_TRUE='#'
STARPU_LAPACK_LDFLAGS=''
STARPU_LEVELDB_LDFLAGS=''
STARPU_LIBNUMA_LDFLAGS=' '
STARPU_LINUX_SYS_FALSE='#'
STARPU_LINUX_SYS_TRUE=''
STARPU_LONG_CHECK_FALSE=''
STARPU_LONG_CHECK_TRUE='#'
STARPU_MAJOR_VERSION='1'
STARPU_MINOR_VERSION='3'
STARPU_MKL_BLAS_LIB_FALSE=''
STARPU_MKL_BLAS_LIB_TRUE='#'
STARPU_MPI_CHECK_FALSE=''
STARPU_MPI_CHECK_TRUE='#'
STARPU_MS_LIB=''
STARPU_MS_LIB_ARCH='X64'
STARPU_NEW_CHECK_FALSE=''
STARPU_NEW_CHECK_TRUE='#'
STARPU_NO_BLAS_LIB_FALSE=''
STARPU_NO_BLAS_LIB_TRUE='#'
STARPU_OPENBLAS=''
STARPU_OPENBLAS_LDFLAGS=''
STARPU_OPENBSD_SYS_FALSE=''
STARPU_OPENBSD_SYS_TRUE='#'
STARPU_OPENCL_CPPFLAGS=''
STARPU_OPENCL_DATAdir=''
STARPU_OPENCL_LDFLAGS=''
STARPU_OPENGL_RENDER='no'
STARPU_OPENGL_RENDER_LDFLAGS=''
STARPU_OPENMP_FALSE=''
STARPU_OPENMP_TRUE='#'
STARPU_PERF_DEBUG='no'
STARPU_QUICK_CHECK_FALSE=''
STARPU_QUICK_CHECK_TRUE='#'
STARPU_RELEASE_VERSION='99'
STARPU_SANITIZE_FALSE=''
STARPU_SANITIZE_TRUE='#'
STARPU_SCIF_CPPFLAGS=''
STARPU_SCIF_LDFLAGS=''
STARPU_SC_HYPERVISOR=''
STARPU_SC_HYPERVISOR_DEBUG='no'
STARPU_SC_HYPERVISOR_DEBUG_FALSE=''
STARPU_SC_HYPERVISOR_DEBUG_TRUE='#'
STARPU_SIMGRID_FALSE='#'
STARPU_SIMGRID_MC_FALSE=''
STARPU_SIMGRID_MC_TRUE='#'
STARPU_SIMGRID_TRUE=''
STARPU_SRC_DIR='/home/mathieu/Git/starpu/.'
STARPU_SYSTEM_BLAS_LIB_FALSE=''
STARPU_SYSTEM_BLAS_LIB_TRUE='#'
STARPU_USE_AYUDAME1_FALSE='#'
STARPU_USE_AYUDAME1_TRUE=''
STARPU_USE_AYUDAME2_FALSE='#'
STARPU_USE_AYUDAME2_TRUE=''
STARPU_USE_CPU='yes'
STARPU_USE_CPU_FALSE='#'
STARPU_USE_CPU_TRUE=''
STARPU_USE_CUDA='no'
STARPU_USE_CUDA_FALSE=''
STARPU_USE_CUDA_TRUE='#'
STARPU_USE_FXT='yes'
STARPU_USE_FXT_FALSE='#'
STARPU_USE_FXT_TRUE=''
STARPU_USE_JULIA_FALSE=''
STARPU_USE_JULIA_TRUE='#'
STARPU_USE_MIC_FALSE=''
STARPU_USE_MIC_TRUE='#'
STARPU_USE_MIN_DGELS_FALSE=''
STARPU_USE_MIN_DGELS_TRUE='#'
STARPU_USE_MPI_FALSE=''
STARPU_USE_MPI_MASTER_SLAVE_FALSE=''
STARPU_USE_MPI_MASTER_SLAVE_TRUE='#'
STARPU_USE_MPI_MPI_FALSE=''
STARPU_USE_MPI_MPI_TRUE='#'
STARPU_USE_MPI_NMAD_FALSE=''
STARPU_USE_MPI_NMAD_TRUE='#'
STARPU_USE_MPI_TRUE='#'
STARPU_USE_MP_FALSE=''
STARPU_USE_MP_TRUE='#'
STARPU_USE_OPENCL='no'
STARPU_USE_OPENCL_FALSE=''
STARPU_USE_OPENCL_TRUE='#'
STARPU_USE_SC_HYPERVISOR_FALSE=''
STARPU_USE_SC_HYPERVISOR_TRUE='#'
STARPU_USE_SOCL_FALSE=''
STARPU_USE_SOCL_TRUE='#'
STRIP='strip'
VERSION='1.3.99'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ac_ct_AR='ar'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
ac_ct_F77='gfortran'
ac_ct_FC='gfortran'
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-pc-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='pc'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=''
dvidir='${docdir}'
epstopdfcommand=''
exec_prefix='${prefix}'
gitcommand='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/git'
host='x86_64-pc-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='pc'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/mathieu/Git/starpu/build-aux/install-sh'
juliapath=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
mpicc_path='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicc'
mpicxx_path='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpicxx'
mpiexec_path='/gnu/store/z2dwr3zj139cgxhjzgwqllybf6djp972-profile/bin/smpirun'
mpifort_path=''
oldincludedir='/usr/include'
pdfdir='${docdir}'
pdflatexcommand=''
pkglibdir='${libdir}/starpu'
prefix='/home/mathieu/Logiciels/starpu-guix'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-pc-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='pc'
## confdefs.h. ##
/* confdefs.h */
#define HAVE_SG_HOST_ROUTE 1
#define HAVE_SG_HOST_SELF 1
#define HAVE_SG_HOST_LIST 1
#define HAVE_SG_HOST_SPEED 1
#define HAVE_SG_CONFIG_CONTINUE_AFTER_HELP 1
#define HAVE_SIMGRID_INIT 1
#define STARPU_SIMGRID_HAVE_SIMGRID_INIT 1
#define HAVE_SG_ACTOR_SLEEP_FOR 1
#define HAVE_SG_ACTOR_SELF 1
#define HAVE_SG_ACTOR_REF 1
#define HAVE_SG_HOST_GET_PROPERTIES 1
#define HAVE_SG_HOST_SEND_TO 1
#define HAVE_SG_CFG_SET_INT 1
#define HAVE_SG_ACTOR_SELF_EXECUTE 1
#define HAVE_SIMGRID_GET_CLOCK 1
#define HAVE_DECL_SMPI_PROCESS_SET_USER_DATA 1
#define HAVE_MSG_ZONE_GET_BY_NAME 1
#define HAVE_MSG_HOST_GET_SPEED 1
#define STARPU_SIMGRID 1
#define HAVE_CXX11 1
#define STARPU_HAVE_CXX11 1
#define HAVE_DLFCN_H 1
#define LT_OBJDIR ".libs/"
#define restrict __restrict
#define STARPU_MAXMPIDEVS 0
#define STARPU_MIC_USE_RMA 1
#define STARPU_MAXNUMANODES 2
#define STARPU_LINUX_SYS 1
#define SIZEOF_VOID_P 8
#define STARPU_BUILD_DIR "/home/mathieu/Git/starpu"
#define STARPU_SRC_DIR "/home/mathieu/Git/starpu/."
#define STARPU_HAVE_UNISTD_H 1
#define STARPU_HAVE_STRUCT_TIMESPEC 1
#define HAVE_SYSCONF 1
#define HAVE_GETRLIMIT 1
#define HAVE_SCANDIR 1
#define HAVE_PTHREAD_SPIN_LOCK 1
#define STARPU_HAVE_PTHREAD_SPIN_LOCK 1
#define STARPU_HAVE_PTHREAD_BARRIER 1
#define HAVE_PTHREAD_SETAFFINITY_NP 1
#define STARPU_HAVE_PTHREAD_SETNAME_NP 1
#define STARPU_PTHREAD_MUTEX_INITIALIZER_ZERO 1
#define STARPU_PTHREAD_COND_INITIALIZER_ZERO 1
#define STARPU_PTHREAD_RWLOCK_INITIALIZER_ZERO 1
#define HAVE_POSIX_MEMALIGN 1
#define STARPU_HAVE_POSIX_MEMALIGN 1
#define HAVE_MEMALIGN 1
#define STARPU_HAVE_MEMALIGN 1
#define STARPU_USE_DRAND48 1
#define STARPU_USE_ERAND48_R 1
#define STARPU_HAVE_STRERROR_R 1
#define STARPU_HAVE_SETENV 1
#define STARPU_HAVE_UNSETENV 1
#define STARPU_HAVE_NEARBYINTF 1
#define STARPU_HAVE_RINTF 1
#define HAVE_MALLOC_H 1
#define STARPU_HAVE_MALLOC_H 1
#define STARPU_HAVE_SCHED_YIELD 1
#define HAVE_AIO_H 1
#define HAVE_LIBRT 1
#define HAVE_COPY_FILE_RANGE 1
#define HAVE_MKOSTEMP 1
#define HAVE_MKDTEMP 1
#define HAVE_PREAD 1
#define HAVE_PWRITE 1
#define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
#define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
#define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
#define STARPU_HAVE_SYNC_FETCH_AND_OR 1
#define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
#define STARPU_HAVE_ATOMIC_COMPARE_EXCHANGE_N 1
#define STARPU_HAVE_ATOMIC_EXCHANGE_N 1
#define STARPU_HAVE_ATOMIC_FETCH_ADD 1
#define STARPU_HAVE_ATOMIC_FETCH_OR 1
#define STARPU_HAVE_ATOMIC_TEST_AND_SET 1
#define STARPU_HAVE_SYNC_SYNCHRONIZE 1
#define STARPU_HAVE_STATEMENT_EXPRESSIONS 1
#define STARPU_NMAX_SCHED_CTXS 10
#define STARPU_MAXCPUS 100
#define STARPU_USE_CPU 1
#define STARPU_MAXCUDADEVS 100
#define STARPU_MAXOPENCLDEVS 8
configure: exit 0
--------------33275C037D4BF5EE7F9108C6--
  • [no subject], Unknown, 16/12/2020
Haut de le page
