Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Shaked Regev <sregev@stanford.edu>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Problems with installing starpu
- Date: Fri, 16 Oct 2020 07:31:56 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear Shaked,
You simply do not have the right to
write in the directory /usr/local/lib
You should specify another directory in
which to install StarPU, this is done at the configure step, for
example:
./configure --prefix=$HOME/usr
Cheers,
Nathalie
On 16/10/2020 02:36, Shaked Regev
wrote:
Dear starpu team,
I’m having trouble installing the software. My steps were
./autogen.sh
./configure
make
make install
Everything seemed fine but it failed on the last step with the following error:
/usr/bin/install: cannot create regular file '/usr/local/lib/libstarpu-1.3.so.0.0.0': Permission denied
Any ideas to help me out?
All the best,
Shaked
Shaked Regev +1 (650) 3875768
ICME PhD student
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
-- Dr Nathalie Furmento Ingénieure de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [Starpu-devel] Problems with installing starpu, Shaked Regev, 16/10/2020
- Re: [Starpu-devel] Problems with installing starpu, Nathalie Furmento, 16/10/2020
